[ Upstream commit 47112e25da41d9059626033986dc3353e101f815 ]
This patch clamps the cscov setsockopt values to a maximum of 0xFFFF.
Setsockopt values greater than 0xffff can cause an unwanted
wrap-around. Further, IPv6 jumbograms are not supported (RFC 3838,
3.5), so that values greater than 0xffff are not even useful.
Further changes: fixed a typo in the documentation.
[ Add USHORT_MAX from upstream to linux/kernel.h -DaveM ]
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
[ Upstream commit fe833fca2eac6b3d3ad5e35f44ad4638362f1da8 ]
When generating the ip header for the transformed packet we just copy
the frag_off field of the ip header from the original packet to the ip
header of the new generated packet. If we receive a packet as a chain
of fragments, all but the last of the new generated packets have the
IP_MF flag set. We have to mask the frag_off field to only keep the
IP_DF flag from the original packet. This got lost with git commit
36cf9acf93e8561d9faec24849e57688a81eb9c5 ("[IPSEC]: Separate
inner/outer mode processing on output")
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
[ Upstream commit 68be802cd5ad040fe8cfa33ce3031405df2d9117 ]
I just noticed "cat /proc/net/raw" was buggy, missing '\n' separators.
I believe this was introduced by commit 8cd850efa4948d57a2ed836911cfd1ab299e89c6
([RAW]: Cleanup IPv4 raw_seq_show.)
This trivial patch restores correct behavior, and applies to current
Linus tree (should also be applied to stable tree as well.)
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
[ Upstream commit bc6cffd177f9266af38dba96a2cea06c1e7ff932 ]
We need to unshare the skb first as otherwise pskb_may_pull may
write to a shared skb which could be bad.
[ Upstream commit 392fdb0e35055b96faa9c1cd6ab537805337cdce ]
The length field in the PPPOE header wasn't checked completely.
This patch causes all packets shorter than the declared length
to be dropped.
It also changes the memcpy_toiovec call to skb_copy_datagram_iovec
so that paged packets (rare for PPPOE) are handled properly.
Thanks to Ilja of the Netric Security Team for discovering and
reporting this bug, and Chris Wright for the total_len check.
[ Incorporate warning fix from Stephen Hemminger. -DaveM ]
[ Upstream commit 6b6707a50c7598a83820077393f8823ab791abf8 ]
This patch fixes a potential memory corruption in
pppol2tp_recvmsg(). If skb->len is bigger than the caller's buffer
length, memcpy_toiovec() will go into unintialized data on the kernel
heap, interpret it as an iovec and start modifying memory.
The fix is to change the memcpy_toiovec() call to
skb_copy_datagram_iovec() so that paged packets (rare for PPPOL2TP)
are handled properly. Also check that the caller's buffer is big
enough for the data and set the MSG_TRUNC flag if it is not so.
Reported-by: Ilja <ilja@netric.org>
Signed-off-by: James Chapman <jchapman@katalix.com>
[ Upstream commit 847499ce71bdcc8fc542062df6ebed3e596608dd ]
This fixes the bridge reference count problem and cleanups ipv6 FIB
timer management. Don't use expires field, because it is not a proper
way to test, instead use timer_pending().
[ Upstream commit ebb36a978131810c98e7198b1187090c697cf99f ]
Based upon a report by Olaf Hering.
[ Upstream commit ae6134bdf3197206fba95563d755d2fa50d90ddd ]
This is a trivial patch against the hdlcdrv module that fixes its CRC
calculation. The finished CRC was overwriting the first two bytes of
each packet rather than being appended to the end.
I've tested this with 2.6.8 and 2.6.10-rc1, but hdlcdrv hasn't changed
much recently so it should work with many other kernel versions.
Signed-off-by: Micah Dowty <micah@navi.cx>
Acked-by: Thomas Sailer <t.sailer@alumni.ethz.ch>
commit dc88807ed61ed0fc0d57bd80a92508b9de638f5d upstream.
Alexander Simon found out that the Terratec Cinergy T USB XXS is just a
clone of another DiB7070P-based device.
Signed-off-by: Patrick Boettcher <pb@linuxtv.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Ludwig Nussel <lnussel@novell.com>
commit ee3ece830f6db9837f7ac67008f532a8c1e755f4 upstream.
Due to a possible deadlock, the waking of the softirq was pushed outside
of the hrtimer base locks. See commit 0c96c5979a522c3323c30a078a70120e29b5bdbc
Unfortunately this allows the task to migrate after setting up the softirq
and raising it. Since softirqs run a queue that is per-cpu we may raise the
softirq on the wrong CPU and this will keep the queued softirq task from
running.
To solve this issue, this patch disables preemption around the releasing
of the hrtimer lock and raising of the softirq.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
commit bf5b1935d8e42b36a34645788eb261461fe07f2e upstream.
Even the newer ENE controllers have bugs in their DMA engine that make
it too dangerous to use. Disable it until someone has figured out under
which conditions it corrupts data.
This has caused problems at least once, and can be found as bug report
10925 in the kernel bugzilla.
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
commit 4fe16897c59882420d66f2d503106653d026ed6c upstream
Signed-off-by: Karl Beldan <karl.beldan@gmail.com>
Acked-by: Eric Miao <eric.miao@marvell.com>
commit 97f8571e663c808ad2d01a396627235167291556 upstream
The pxa27x DMA controller defaults to 64-bit alignment. This caused
the SCR reads to fail (and, depending on card type, error out) when
card->raw_scr was not aligned on a 8-byte boundary.
For performance reasons all scatter-gather addresses passed to
pxamci_request should be aligned on 8-byte boundaries, but if
this can't be guaranteed, byte aligned DMA transfers in the
have to be enabled in the controller to get correct behaviour.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
commit ba0fc709e197415aadd46b9ec208dc4abaa21edd upstream
There is dma_mask in of_device upon of_platform_device_create()
but we don't actually set coherent_dma_mask. This may cause weird
behavior of USB subsystem using of_device USB host drivers.
Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org>
Upstream commit: 872ac8743cb400192a9fce4ba2d3ffd7bb309685
When chainiv postpones requests it never calls their completion functions.
This causes symptoms such as memory leaks when IPsec is in use.
commit 081a5bcb39b455405d58f79bb3c9398a9d4477ed upstream
The problem here is that if the ioc faults too early in the bring up
sequence (as it usually does for an irq routing problem), ioc_reset gets
called before the scsi host is even allocated. This causes an oops when
it later schedules a renegotiation. Fix this by checking ioc->sh before
trying to renegotiate.
Cc: Eric Moore <Eric.Moore@lsi.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
commit 43f77e91eadbc290eb76a08110a039c809dde6c9 upstream
Coverity CID: 2172 RESOURCE_LEAK
When pool_allocate() tries to enlarge a packet, if it can not allocate enough
memory, it returns NULL without first freeing the old packet.
This patch just frees the packet first.
Signed-off-by: Darren Jenkins <darrenrjenkins@gmail.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit 4fc89e3911aa5357b55b85b60c4beaeb8a48a290 upstream
Coverity CID: 1356 RESOURCE_LEAK
I found a very old patch for this that was Acked but did not get applied
https://lists.linux-foundation.org/pipermail/kernel-janitors/2006-September/016362.html
There looks to be a small leak in isdn_writebuf_stub() in isdn_common.c, when
copy_from_user() returns an un-copied data length (length != 0). The below
patch should be a minimally invasive fix.
Acked-by: Karsten Keil <kkeil@suse.de>
commit f31ad92f34913043cf008d6e479e92dfbaf02df1 upstream
This patch is a bugfix for how defio handles multiple processes manipulating
the same framebuffer.
Thanks to Bernard Blackham for identifying this bug.
It occurs when two applications mmap the same framebuffer and concurrently
write to the same page. Normally, this doesn't occur since only a single
process mmaps the framebuffer. The symptom of the bug is that the mapping
applications will hang. The cause is that defio incorrectly tries to add the
same page twice to the pagelist. The solution I have is to walk the pagelist
and check for a duplicate before adding. Since I needed to walk the pagelist,
I now also keep the pagelist in sorted order.
Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com>
Cc: Bernard Blackham <bernard@largestprime.net>
commit 05d81d2222beec7b63ac8c1c8cdb5bb4f82c2bad upstream
I had 8250.nr_uarts=16 in the boot line of a test kernel and I had a weird
mysterious crash in sysfs. After taking an in-depth look I realized that
CONFIG_SERIAL_8250_NR_UARTS was set to 4 and I was walking off the end of
the serial8250_ports array.
Ouch!!!
Don't let this happen to someone else.
Acked-by: Alan Cox <alan@redhat.com>
commit bca5c2c550f16d2dc2d21ffb7b4712bd0a7d32a9 upstream
Cortland Setlow pointed out a bug in ov7670.c where the result from
ov7670_read() was just being checked for !0, rather than <0. This made me
realize that ov7670_read's semantics were rather confusing; it both fills
in 'value' with the result, and returns it. This is goes against general
kernel convention; so rather than fixing callers, let's fix the function.
This makes ov7670_read return <0 in the case of an error, and 0 upon
success. Thus, code like:
res = ov7670_read(...);
if (!res)
goto error;
.will work properly.
Signed-off-by: Cortland Setlow <csetlow@tower-research.com>
Signed-off-by: Andres Salomon <dilinger@debian.org>
Acked-by: Jonathan Corbet <corbet@lwn.net>
commit 536abdb0802f3fac1b217530741853843d63c281 upstream
The current definition of wksidarr works fine on little endian arches
(since cpu_to_le32 is a no-op there), but on big-endian arches, it fails
to compile with this error:
error: braced-group within expression allowed only inside a function
The problem is that this static declaration has cpu_to_le32 embedded
within it, and that expands into a function macro. We need to use
__constant_cpu_to_le32() instead.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Cc: Steven French <sfrench@us.ibm.com>
commit fb0e7e11d017beb5f0b1fa25bc51e49e65c46d67 upstream
This patch adds Intel TPM TIS device HID: ICO0102
Signed-off-by: Marcin Obara <marcin_obara@users.sourceforge.net>
Acked-by: Marcel Selhorst <tpm@selhorst.net>
Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
commit a7de3902edce099e4102c1272ec0ab569c1791f7 upstream
Fix RapidIO device reference counting.
Signed-of-by: Eugene Surovegin <ebs@ebshome.net>
Cc: Matt Porter <mporter@kernel.crashing.org>
commit 61ca9daa2ca3022dc9cb22bd98e69c1b61e412ad upstream
The IRQ rate reported back by the RTC is incorrect when HPET is enabled.
Newer hardware that has HPET to emulate the legacy RTC device gets this value
wrong since after it sets the rate, it returns before setting the variable
used to report the IRQ rate back to users of the device -- so the set rate and
the reported rate get out of sync.
Cc: David Brownell <david-b@pacbell.net>
commit bdb21928512a860a60e6a24a849dc5b63cbaf96a upstream
Vegard Nossum reported a crash in kmem_cache_alloc():
BUG: unable to handle kernel paging request at da87d000
IP: [<c01991c7>] kmem_cache_alloc+0xc7/0xe0
*pde = 28180163 *pte = 1a87d160
Oops: 0002 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Pid: 3850, comm: grep Not tainted (2.6.26-rc9-00059-gb190333 #5)
EIP: 0060:[<c01991c7>] EFLAGS: 00210203 CPU: 0
EIP is at kmem_cache_alloc+0xc7/0xe0
EAX: 00000000 EBX: da87c100 ECX: 1adad71a EDX: 6b6b6b6b
ESI: 00200282 EDI: da87d000 EBP: f60bfe74 ESP: f60bfe54
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
and analyzed it:
"The register %ecx looks innocent but is very important here. The disassembly:
mov %edx,%ecx
shr $0x2,%ecx
rep stos %eax,%es:(%edi) <-- the fault
So %ecx has been loaded from %edx... which is 0x6b6b6b6b/POISON_FREE.
(0x6b6b6b6b >> 2 == 0x1adadada.)
%ecx is the counter for the memset, from here:
memset(object, 0, c->objsize);
i.e. %ecx was loaded from c->objsize, so "c" must have been freed.
Where did "c" come from? Uh-oh...
c = get_cpu_slab(s, smp_processor_id());
This looks like it has very much to do with CPU hotplug/unplug. Is
there a race between SLUB/hotplug since the CPU slab is used after it
has been freed?"
Good analysis.
Yeah, it's possible that a caller of kmem_cache_alloc() -> slab_alloc()
can be migrated on another CPU right after local_irq_restore() and
before memset(). The inital cpu can become offline in the mean time (or
a migration is a consequence of the CPU going offline) so its
'kmem_cache_cpu' structure gets freed ( slab_cpuup_callback).
At some point of time the caller continues on another CPU having an
obsolete pointer...
Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com>
Reported-by: Vegard Nossum <vegard.nossum@gmail.com>
commit 96a8e13ed44e380fc2bb6c711d74d5ba698c00b2 upstream
Kernel Bugzilla #11063 points out that on some architectures (e.g. x86_32)
exec'ing an ELF without a PT_GNU_STACK program header should default to an
executable stack; but this got broken by the unlimited argv feature because
stack vma is now created before the right personality has been established:
so breaking old binaries using nested function trampolines.
Therefore re-evaluate VM_STACK_FLAGS in setup_arg_pages, where stack
vm_flags used to be set, before the mprotect_fixup. Checking through
our existing VM_flags, none would have changed since insert_vm_struct:
so this seems safer than finding a way through the personality labyrinth.
Reported-by: pageexec@freemail.hu
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Commit 9dfd55008e3863dcd93219c74bf05b09e5c549e2 upstream
I would like to inform you of our zd1211 based usb wifi adapter (AirTies
WUS-201), which works with the zd1211rw driver with the following device
id definition.
Signed-off-by: Daniel Drake <dsd@gentoo.org>
Cc: Peter Nixon <listuser@peternixon.net>
Upstream commit 84ebe1c:
Lost connections was reported by Thomas Bätzler (running 2.6.25 kernel) on
the netfilter mailing list (see the thread "Weird nat/conntrack Problem
with PASV FTP upload"). He provided tcpdump recordings which helped to
find a long lingering bug in conntrack.
In TCP connection tracking, checking the lower bound of valid ACK could
lead to mark valid packets as INVALID because:
- We have got a "higher or equal" inequality, but the test checked
the "higher" condition only; fixed.
- If the packet contains a SACK option, it could occur that the ACK
value was before the left edge of our (S)ACK "window": if a previous
packet from the other party intersected the right edge of the window
of the receiver, we could move forward the window parameters beyond
accepting a valid ack. Therefore in this patch we check the rightmost
SACK edge instead of the ACK value in the lower bound of valid (S)ACK
test.
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Upstream commit aebb6a849cfe7d89bcacaaecc20a480dfc1180e7
The current logic has a bug which cannot find matching pattern, if the
pattern is matched from the first character of target string.
for example:
pattern=abc, string=abcdefg
pattern=a, string=abcdefg
Searching algorithm should return 0 for those things.
Signed-off-by: Joonwoo Park <joonwpark81@gmail.com>
commit 7a1fc53c5adb910751a9b212af90302eb4ffb527 upstream
Remove the dubious attempt to prefer 'compute' over 'read'. Not only is it
wrong given commit c337869d (md: do not compute parity unless it is on a failed
drive), but it can trigger a BUG_ON in handle_parity_checks5().
Signed-off-by: Neil Brown <neilb@suse.de>
commit f15e39739a1d7dfaa2173a91707a74c11a246648 upstream
Remove dev_info call on disconnect. The sisusb_dev pointer may have been
set to zero by sisusb_delete at this point causing an oops.
The message does not provide any extra information over the standard USB
subsystem output so removing it does not affect functionality.
Signed-off-by: Will Newton <will.newton@gmail.com>
commit 7f2d38eb7a42bea1c1df51bbdaa2ca0f0bdda07f upstream
Even though the CAN netlayer only deals with CAN netdevices, the
netlayer interface to the userspace and to the device layer should
perform some sanity checks.
This patch adds several sanity checks that mainly prevent userspace apps
to send broken content into the system that may be misinterpreted by
some other userspace application.
Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de>
Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de>
Acked-by: Andre Naujoks <nautsch@gmail.com>
commit 7ca796f492a11f9408e661c8f22cd8c4f486b8e5 upstream
As reported by Vipul Gandhi, the current serial_match_port() doesn't work
for tty-devices using dynamic major number allocation. Fix it.
It oopses if you suspend a serial port with _dynamic_ major number. ATM,
I think, there's only the drivers/serial/jsm/jsm_driver.c driver, that
does it in-tree.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Tested-by: Vipul Gandhi <vcgandhi1@aol.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
commit 491539982aa01fa71de93c2a06ac5d890d4cf1e2 upstream
This patch changes the way we determine the maximum number of outstanding
commands for each controller.
Most Smart Array controllers can support up to 1024 commands, the notable
exceptions are the E200 and E200i.
The next generation of controllers which were just added support a mode of
operation called Zero Memory Raid (ZMR). In this mode they only support
64 outstanding commands. In Full Function Raid (FFR) mode they support
1024.
We have been setting the queue depth by arbitrarily assigning some value
for each controller. We needed a better way to set the queue depth to
avoid lots of annoying "fifo full" messages. So we made the driver a
little smarter. We now read the config table and subtract 4 from the
returned value. The -4 is to allow some room for ioctl calls which are
not tracked the same way as io commands are tracked.
Please consider this for inclusion.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
commit eb35c218d83ec0780d9db869310f2e333f628702 upstream
With the removal of struct file from the xattr code,
reiserfs_file_release() isn't used anymore, so the prealloc isn't
discarded. This causes hangs later down the line.
This patch adds it to reiserfs_delete_inode. In most cases it will be a
no-op due to it already having been called, but will avoid hangs with
xattrs.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit 2d5c1be8870383622809c25935fff00d2630c7a5 upstream
There is a bug in the output of /sys/devices/system/node/node[n]/meminfo
where the Active and Inactive values are in pages instead of Kbytes.
Looks like this occurred back in 2.6.20 when the code was changed
over to use node_page_state().
commit c95e62ce8905aab62fed224eaaa9b8558a0ef652 upstream
Timeouts are measured in jiffies, not in seconds.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
commit ec5e69f6d3f4350681d6f7eaae515cf014be9276 upstream
The esp driver currently does hand rolled reference counting of its
target. It's much easier to do what it needs to do if it's plugged into
the mid-layer callbacks (target_alloc and target_destroy) which were
designed for this case, so do it this way and get rid of the internal
target reference count.
commit eadc49b1a8d09480f14caea292142f103a89c77a upstream
OOPS reported by Friedrich Oslage <bluebird@porno-bullen.de>
The problem here is that tp->starget is set every time a lun
is allocated for a particular target so we can catch the
sdev_target parent value.
The reset handler uses the NULL'ness of this value to determine
which targets are active.
But esp_slave_destroy() does not NULL out this value when appropriate.
So for every target that doesn't respond, the SCSI bus scan causes
a stale pointer to be left here, with ensuing crashes like you're
seeing.
commit c5643cab7bf663ae049b11be43de8819683176dd upstream
Original Author: Michael Buesch <mb@bu3sch.de>
net, vortex: fix lockup
Ingo Molnar reported:
-tip testing found that Johannes Berg's "softirq: remove irqs_disabled
warning from local_bh_enable" enhancement to lockdep triggers a new
warning on an old testbox that uses 3c59x vortex and netlogging:
calling vortex_init+0x0/0xb0
PCI: Found IRQ 10 for device 0000:00:0b.0
PCI: Sharing IRQ 10 with 0000:00:0a.0
PCI: Sharing IRQ 10 with 0000:00:0b.1
3c59x: Donald Becker and others.
0000:00:0b.0: 3Com PCI 3c556 Laptop Tornado at e0800400.
PCI: Enabling bus mastering for device 0000:00:0b.0
initcall vortex_init+0x0/0xb0 returned 0 after 47 msecs
calling init_netconsole+0x0/0x1b0
netconsole: local port 4444
netconsole: local IP 10.0.1.9
netconsole: interface eth0
netconsole: remote port 4444
netconsole: remote IP 10.0.1.16
netconsole: remote ethernet address 00:19:xx:xx:xx:xx
netconsole: device eth0 not up yet, forcing it
eth0: setting half-duplex.
eth0: setting full-duplex.
WARNING: at kernel/softirq.c:137 local_bh_enable_ip+0xd1/0xe0()
Pid: 1, comm: swapper Not tainted 2.6.26-rc6-tip #2091
[<c0125ecf>] warn_on_slowpath+0x4f/0x70
[<c0126834>] ? release_console_sem+0x1b4/0x1d0
[<c0126d00>] ? vprintk+0x2a0/0x450
[<c012fde5>] ? __mod_timer+0xa5/0xc0
[<c046f7fd>] ? mdio_sync+0x3d/0x50
[<c0160ef6>] ? marker_probe_cb+0x46/0xa0
[<c0126ed7>] ? printk+0x27/0x50
[<c046f4c3>] ? vortex_set_duplex+0x43/0xc0
[<c046f521>] ? vortex_set_duplex+0xa1/0xc0
[<c0471b92>] ? vortex_timer+0xe2/0x3e0
[<c012b361>] local_bh_enable_ip+0xd1/0xe0
[<c08d9f9f>] _spin_unlock_bh+0x2f/0x40
[<c0471b92>] vortex_timer+0xe2/0x3e0
[<c014743b>] ? trace_hardirqs_on+0xb/0x10
[<c0147358>] ? trace_hardirqs_on_caller+0x88/0x160
[<c012f8b2>] run_timer_softirq+0x162/0x1c0
[<c0471ab0>] ? vortex_timer+0x0/0x3e0
[<c012b60a>] __do_softirq+0x9a/0x160
[<c012b570>] ? __do_softirq+0x0/0x160
[<c0106775>] call_on_stack+0x15/0x30
[<c012b4f5>] ? irq_exit+0x55/0x60
[<c0106e85>] ? do_IRQ+0x85/0xd0
[<c0147391>] ? trace_hardirqs_on_caller+0xc1/0x160
[<c0104888>] ? common_interrupt+0x28/0x30
[<c08d8ac8>] ? mutex_unlock+0x8/0x10
[<c08d8180>] ? _cond_resched+0x10/0x30
[<c07a3be7>] ? netpoll_setup+0x117/0x390
[<c0cbfcfe>] ? init_netconsole+0x14e/0x1b0
[<c013d539>] ? ktime_get+0x19/0x40
[<c0c9bab2>] ? kernel_init+0x1b2/0x2c0
[<c0cbfbb0>] ? init_netconsole+0x0/0x1b0
[<c0396aa4>] ? trace_hardirqs_on_thunk+0xc/0x10
[<c0103f12>] ? restore_nocheck_notrace+0x0/0xe
[<c0c9b900>] ? kernel_init+0x0/0x2c0
[<c0104aa7>] ? kernel_thread_helper+0x7/0x10
---[ end trace 37f9c502aff112e0 ]---
console [netcon0] enabled
netconsole: network logging started
initcall init_netconsole+0x0/0x1b0 returned 0 after 2914 msecs
looking at the driver I think the bug is real and the fix actually
is trivial.
vp->lock is also taken in hardware IRQ context, so we _have_ to always
use irqsafe locking. As we run in a timer with IRQs disabled,
we can simply use spin_lock.
commit 2f9ec47d0954f9d2e5a00209c2689cbc477a8c89 upstream
This fixes a possible NULL pointer dereference in an error path of the
DMA allocation error checking code. This is also necessary for a future
DMA API change that is on its way into the mainline kernel that adds
an additional dev parameter to dma_mapping_error().
Signed-off-by: Michael Buesch <mb@bu3sch.de>
commit 292d73551d0aa19526c3417e791c529b49ebadf3 upstream
Adds R61, T61p, X61s, X61, Z61m, Z61p models to whitelist.
Fixes this:
cullen@lenny:~$ sudo modprobe hdaps
FATAL: Error inserting hdaps (/lib/modules/2.6.22-10-generic/kernel/drivers/hwmon/hdaps.ko): No such device
[25192.888000] hdaps: supported laptop not found!
[25192.888000] hdaps: driver init failed (ret=-19)!
Originally based on an Ubuntu patch that got it wrong, the dmidecode
output of the corresponding laptops shows LENOVO as the manufacturer.
https://bugs.launchpad.net/ubuntu/+source/linux-source-2.6.22/+bug/133636
tested on X61s:
[ 184.893588] hdaps: inverting axis readings.
[ 184.893588] hdaps: LENOVO ThinkPad X61s detected.
[ 184.893588] input: hdaps as /class/input/input12
[ 184.924326] hdaps: driver successfully loaded.
Cc: Klaus S. Madsen <ubuntu@hjernemadsen.org>
Cc: Chuck Short <zulcss@ubuntu.com>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Tim Gardner <tim.gardner@canonical.com>
Signed-off-by: maximilian attems <max@stro.at>
Cc: Mark M. Hoffman <mhoffman@lightlink.com>
commit de85422b94ddb23c021126815ea49414047c13dc upstream
As has been discussed several times on LKML, IRQF_SHARED | IRQF_DISABLED
doesn't work reliably, i.e. a shared interrupt handler CAN'T be certain to
be called with interrupts disabled. Most USB HCD handlers use IRQF_DISABLED
and therefore havoc can break out if they share their interrupt with a
handler that doesn't use it.
On my test machine the yenta_socket interrupt handler (no IRQF_DISABLED)
was registered before ehci_hcd and one uhci_hcd instance. Therefore all
usb_hcd_irq() invocations for ehci_hcd and for one uhci_hcd instance
happened with interrupts enabled. That led to random lockups as USB core
HCD functions that acquire the same spinlock could be called twice
from interrupt handlers.
This patch updates usb_hcd_irq() to always disable/restore interrupts.
usb_add_hcd() will silently remove any IRQF_DISABLED requested from HCD code.
Signed-off-by: Stefan Becker <stefan.becker@nokia.com>
Acked-by: David Brownell <david-b@pacbell.net>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 29c8f6a727a683b5988877dd80dbdefd49e64a51 upstream
This patch fixes a problem with OHCI where canceling bulk or
interrupt URBs may lose track of the right data toggle. This
seems to be a longstanding bug, possibly dating back to the
Linux 2.4 kernel, which stayed hidden because
(a) about half the time the data toggle bit was correct;
(b) canceling such URBs is unusual; and
(c) the few drivers which cancel these URBs either
[1] do it only as part of shutting down, or
[2] have fault recovery logic, which recovers.
For those transfer types, the toggle is normally written back
into the ED when each TD is retired. But canceling bypasses
the mechanism used to retire TDs ... so on average, half the
time the toggle bit will be invalid after cancelation.
The fix is simple: the toggle state of any canceled TDs are
propagated back to the ED in the finish_unlinks function.
(Issue found by leonidv11@gmail.com ...)
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Leonid <leonidv11@gmail.com>
commit 056761e55c8687ddf3db14226213f2e8dc2689bc upstream
This patch fixes a regression in the EHCI driver's TIMER_IO_WATCHDOG
behavior. The patch "USB: EHCI: add separate IAA watchdog timer" changed
how that timer is handled, so that short timeouts on the remaining
timer (unfortunately, overloaded) would never be used.
This takes a more direct approach, reorganizing the code slightly to
be explicit about only the I/O watchdog role now being overridable.
It also replaces a now-obsolete comment describing older timer behavior.
Cc: Alan Stern <stern@rowland.harvard.edu>
commit 3ee38d8bf46b364b1ca364ddb7c379a4afcd8bbb upstream
If the SM501 and another platform driver, such as the SM501
then we end up defining PLATFORM_DRIVER twice. This patch
seperated the SM501 onto a seperate define of SM501_OHCI_DRIVER
so that it can be selected without overwriting the original
definition.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
