2008-02-15Linux 2.6.25-rc2v2.6.25-rc2Linus Torvalds
2008-02-15Merge branch 'hotfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'hotfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: add missing spkm3 strings to mount option parser NFS: remove error field from nfs_readdir_descriptor_t NFS: missing spaces in KERN_WARNING NFS: Allow text-based mounts via compat_sys_mount NFS: fix reference counting for NFSv4 callback thread
2008-02-15Merge branch 'linus_origin' into hotfixesTrond Myklebust
2008-02-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (82 commits) [NET]: Make sure sockets implement splice_read netconsole: avoid null pointer dereference at show_local_mac() [IPV6]: Fix reversed local_df test in ip6_fragment [XFRM]: Avoid bogus BUG() when throwing new policy away. [AF_KEY]: Fix bug in spdadd [NETFILTER] nf_conntrack_proto_tcp.c: Mistyped state corrected. net: xfrm statistics depend on INET [NETFILTER]: make secmark_tg_destroy() static [INET]: Unexport inet_listen_wlock [INET]: Unexport __inet_hash_connect [NET]: Improve cache line coherency of ingress qdisc [NET]: Fix race in dev_close(). (Bug 9750) [IPSEC]: Fix bogus usage of u64 on input sequence number [RTNETLINK]: Send a single notification on device state changes. [NETLABLE]: Hide netlbl_unlabel_audit_addr6 under ifdef CONFIG_IPV6. [NETLABEL]: Don't produce unused variables when IPv6 is off. [NETLABEL]: Compilation for CONFIG_AUDIT=n case. [GENETLINK]: Relax dances with genl_lock. [NETLABEL]: Fix lookup logic of netlbl_domhsh_search_def. [IPV6]: remove unused method declaration (net/ndisc.h). ...
2008-02-15[NET]: Make sure sockets implement splice_readRémi Denis-Courmont
Fixes a segmentation fault when trying to splice from a non-TCP socket. Signed-off-by: Rémi Denis-Courmont <rdenis@simphalempin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-15netconsole: avoid null pointer dereference at show_local_mac()Keiichi KII
This patch avoids a null pointer dereference when we read local_mac for netconsole in configfs and shows default local mac address value. A null pointer dereference occurs when we call show_local_mac() via local_mac entry in configfs before we setup the content of netpoll using netpoll_setup(). Signed-off-by: Keiichi KII <k-keiichi@bx.jp.nec.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-14[IPV6]: Fix reversed local_df test in ip6_fragmentHerbert Xu
I managed to reverse the local_df test when forward-porting this patch so it actually makes things worse by never fragmenting at all. Thanks to David Stevens for testing and reporting this bug. Bill Fink pointed out that the local_df setting is also the wrong way around. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: add USB IDs for MacBook 3rd generation HID: add LCSPEC from VERNIER to quirk list HID: fix processing of event quirks HID: Blacklist new GTCO CalComp USB device PIDs
2008-02-14Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: DMI: quirk for FSC ESPRIMO Mobile V5505 ACPI: DMI blacklist updates pnpacpi: __initdata is not an identifier ACPI: static acpi_chain_head ACPI: static acpi_find_dsdt_initrd() ACPI: static acpi_no_initrd_override_setup() thinkpad_acpi: static ACPI suspend: Execute _WAK with the right argument cpuidle: Add Documentation ACPI, cpuidle: Clarify C-state description in sysfs ACPI: fix suspend regression due to idle update
2008-02-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (46 commits) sh: Fix multiple UTLB hit on UP SH-4. sh: fix pci io access for r2d boards sh: fix ioreadN_rep and iowriteN_rep sh: use ctrl_in/out for on chip pci access sh: Kill off more dead symbols. sh: __uncached_start only on sh32. sh: asm/irq.h needs asm/cpu/irq.h. serial: sh-sci: Fix up SH-5 build. sh: Get SH-5 caches working again post-unification. maple: Fix up maple build failure. sh: Kill off bogus SH_SDK7780_STANDALONE symbol. sh: asm/tlb.h needs linux/pagemap.h for CONFIG_SWAP=n. sh: Tidy include/asm-sh/hp6xx.h maple: improve detection of attached peripherals sh: Shut up some trivial build warnings. sh: Update SH-5 flush_cache_sigtramp() for API changes. sh: Fix up set_fixmap_nocache() for SH-5. sh: Fix up pte_mkhuge() build breakage for SH-5. sh: Disable big endian for SH-5. sh: Handle SH7366 CPU in check_bugs(). ...
2008-02-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-hrtLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-hrt: hrtimer: catch expired CLOCK_REALTIME timers early hrtimer: check relative timeouts for overflow
2008-02-14Merge branch 'slab-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/christoph/vm * 'slab-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/christoph/vm: slub: Support 4k kmallocs again to compensate for page allocator slowness slub: Fallback to kmalloc_large for failing higher order allocs slub: Determine gfpflags once and not every time a slab is allocated make slub.c:slab_address() static slub: kmalloc page allocator pass-through cleanup slab: avoid double initialization & do initialization in 1 place
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/cma: Do not issue MRA if user rejects connection request mlx4_core: Move table_find from fmr_alloc to fmr_enable IB/mlx4: mlx4_ib_fmr_alloc() should call mlx4_fmr_enable() IPoIB: Remove unused struct ipoib_cm_tx.ibwc member IPoIB: On P_Key change event, reset state properly IB/mthca: Convert to use be16_add_cpu() RDMA/cxgb3: Fail loopback connections IB/cm: Fix infiniband_cm class kobject ref counting IB/cm: Remove debug printk()s that snuck upstream IB/mthca: Add missing sg_init_table() in mthca_map_user_db()
2008-02-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: x86: cpa, fix out of date comment KVM is not seen under X86 config with latest git (32 bit compile) x86: cpa: ensure page alignment x86: include proper prototypes for rodata_test x86: fix gart_iommu_init() x86: EFI set_memory_x()/set_memory_uc() fixes x86: make dump_pagetable() static x86: fix "BUG: sleeping function called from invalid context" in print_vma_addr()
2008-02-14Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Remove unused CONFIG_WANT_DEVICE_TREE [POWERPC] Cell RAS: Remove DEBUG, and add license and copyright [POWERPC] hvc_rtas_init() must be __init [POWERPC] free_property() must not be __init [POWERPC] vdso_do_func_patch{32,64}() must be __init [POWERPC] Remove generated files on make clean [POWERPC] Fix arch/ppc compilation - add typedef for pgtable_t [POWERPC] Wire up new timerfd syscalls [POWERPC] PS3: Update sys-manager button events [POWERPC] PS3: Sys-manager code cleanup [POWERPC] PS3: Use system reboot on restart [POWERPC] PS3: Fix bootwrapper hang bug [POWERPC] PS3: Fix reading pm interval in logical performance monitor [POWERPC] PS3: Fix setting bookmark in logical performance monitor [POWERPC] Fix DEBUG_PREEMPT warning when warning
2008-02-14dentries: Extract common code to remove dentry from lruChristoph Lameter
Extract the common code to remove a dentry from the lru into a new function dentry_lru_remove(). Two call sites used list_del() instead of list_del_init(). AFAIK the performance of both is the same. dentry_lru_remove() does a list_del_init(). As a result dentry->d_lru is now always empty when a dentry is freed. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: Make d_path() use a struct pathJan Blunck
d_path() is used on a <dentry,vfsmount> pair. Lets use a struct path to reflect this. [akpm@linux-foundation.org: fix build in mm/memory.c] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: Make seq_path() use a struct path argumentJan Blunck
seq_path() is always called with a dentry and a vfsmount from a struct path. Make seq_path() take it directly as an argument. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Use struct path in struct svc_expkeyJan Blunck
I'm embedding struct path into struct svc_expkey. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Use struct path in struct svc_exportJan Blunck
I'm embedding struct path into struct svc_export. [akpm@linux-foundation.org: coding-style fixes] [ezk@cs.sunysb.edu: NFSD: fix wrong mnt_writer count in rename] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: Make get_dcookie() use a struct path argumentJan Blunck
get_dcookie() is always called with a dentry and a vfsmount from a struct path. Make get_dcookie() take it directly as an argument. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: Make proc_get_link() use a struct path argumentJan Blunck
proc_get_link() is always called with a dentry and a vfsmount from a struct path. Make proc_get_link() take it directly as an argument. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: Use struct path in struct avc_audit_dataJan Blunck
audit_log_d_path() is a d_path() wrapper that is used by the audit code. To use a struct path in audit_log_d_path() I need to embed it into struct avc_audit_data. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: kerneldoc cleanupJan Blunck
Move and update d_path() kernel API documentation. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14One less parameter to __d_pathJan Blunck
All callers to __d_path pass the dentry and vfsmount of a struct path to __d_path. Pass the struct path directly, instead. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Make set_fs_{root,pwd} take a struct pathJan Blunck
In nearly all cases the set_fs_{root,pwd}() calls work on a struct path. Change the function to reflect this and use path_get() here. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Use struct path in fs_structJan Blunck
* Use struct path in fs_struct. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Introduce path_get()Jan Blunck
This introduces the symmetric function to path_put() for getting a reference to the dentry and vfsmount of a struct path in the right order. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Use path_put() in a few places instead of {mnt,d}put()Jan Blunck
Use path_put() in a few places instead of {mnt,d}put() Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Introduce path_put()Jan Blunck
* Add path_put() functions for releasing a reference to the dentry and vfsmount of a struct path in the right order * Switch from path_release(nd) to path_put(&nd->path) * Rename dput_path() to path_put_conditional() [akpm@linux-foundation.org: fix cifs] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: <linux-fsdevel@vger.kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Embed a struct path into struct nameidata instead of nd->{dentry,mnt}Jan Blunck
This is the central patch of a cleanup series. In most cases there is no good reason why someone would want to use a dentry for itself. This series reflects that fact and embeds a struct path into nameidata. Together with the other patches of this series - it enforced the correct order of getting/releasing the reference count on <dentry,vfsmount> pairs - it prepares the VFS for stacking support since it is essential to have a struct path in every place where the stack can be traversed - it reduces the overall code size: without patch series: text data bss dec hex filename 5321639 858418 715768 6895825 6938d1 vmlinux with patch series: text data bss dec hex filename 5320026 858418 715768 6894212 693284 vmlinux This patch: Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix cifs] [akpm@linux-foundation.org: fix smack] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Move struct path into its own headerJan Blunck
Move the definition of struct path into its own header file for further patches. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Remove path_release_on_umount()Jan Blunck
path_release_on_umount() should only be called from sys_umount(). I merged the function into sys_umount() instead of having in in namei.c. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Dont touch fs_struct in usermodehelperJan Blunck
This test seems to be unnecessary since we always have rootfs mounted before calling a usermodehelper. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Dont touch fs_struct in driversJan Blunck
The sound drivers and the pnpbios core test for current->root != NULL. This test seems to be unnecessary since we always have rootfs mounted before initializing the drivers. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14vfs: add explanation of I_DIRTY_DATASYNC bitJan Kara
Add explanation of I_DIRTY_DATASYNC bit. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Joern Engel <joern@logfs.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Include kernel.h from configfs.hBen Nizette
configfs.h uses the container_of macro and as such should include kernel.h. Signed-off-by: Ben Nizette <bn@niasdigital.com> Cc: Joel Becker <Joel.Becker@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14MAINTAINERS: update decnet and DLM entriesChristine Caulfield
Change my name & email in MAINTAINERS Signed-off-by: Christine Caulfield <christine.caulfield@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14FLAT binaries: drop BINFMT_FLAT bad header magic warningMike Frysinger
The warning issued by fs/binfmt_flat.c when the format handler is given a non-FLAT and non-script executable is annoying to say the least when working with FDPIC ELF objects. If you build a kernel that supports both FLAT and FDPIC ELFs on no-mmu, every time you execute an FDPIC ELF, the kernel spits out this message. While I understand a lot of newcomers to the no-mmu world screw up generation of FLAT binaries, this warning is not usable for systems that support more than just FLAT. Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Bernd Schmidt <bernds_cb1@t-online.de> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14m68knommu: use tabs not spaces in cacheflush.hGreg Ungerer
Use tabs instead of spaces. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14m68knommu: fix profile timerMatt Waddel
I was looking at timers in the Coldfire system and I noticed that the CONFIG_HIGHPROFILE option seems to be a little out of date. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14m68knommu: use asflags instead of EXTRA_AFLAGSGreg Ungerer
Modify the extra asm flags for debugger capabilities, use asflags instead for EXTRA_AFLAGS. Suggestion from Sam Ravnborg. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14m68knommu: avoid unneccessary use of xchg() in set_mb()Greg Ungerer
Avoid unneccessary use of xchg() in set_mb(). Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14m68knommu: fix coldfire interrupt exit pathWalter T Gruczka
Remove bogus conditional jump in return from interrupt path. Reorder the code path now that is not there. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14MAINTAINERS: add linux-fsdevel to VFS entryPaul Menage
Add linux-fsdevel to the VFS entry in MAINTAINERS Signed-off-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14kernel-doc: remove fastcallHarvey Harrison
fastcall is gone from the tree, no need to adjust the function prototypes anymore for this. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14cris: import memset.c from newlib: fixes compile error with newer (pre4.3) gccJesper Nilsson
Adrian Bunk reported the following compile error with a SVN head GCC: ... CC arch/cris/arch-v10/lib/memset.o /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c: In function 'memset': /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:164: error: lvalue required as increment operand /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:165: error: lvalue required as increment operand /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:166: error: lvalue required as increment operand /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:167: error: lvalue required as increment operand /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:185: error: lvalue required as increment operand /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:189: error: lvalue required as increment operand /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:192: error: lvalue required as increment operand ... etc ... This is due to the use of the construct: *((long*)dst)++ = lc; Which is no longer legal since casts don't return an lvalue. The solution is to import the implementation from newlib, which is continually autotested together with GCC mainline, and uses the construct: *(long *) dst = lc; dst += 4; With this change, the generated code actually shrinks 76 bytes since gcc notices that it can use autoincrement for the move instruction in CRIS. text data bss dec hex filename 304 0 0 304 130 memset.old.o text data bss dec hex filename 228 0 0 228 e4 memset.o Since this is an import of a file from newlib, I'm not touching the formatting or correcting any checkpatch errors. Note also that even if the two files for the CRIS v10 and CRIS v32 are identical at the moment, it might be possible to tweak the CRIS v32 version. Thus, I'm not yet folding them into the same file, at least not until we've done some research on it. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Mikael Starvik <mikael.starvik@axis.com> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14inotify: make variables static in inotify_user.cHarvey Harrison
inotify_max_user_instances, inotify_max_user_watches, inotify_max_queued_events can all be made static. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14fix module_update_markers() compile errorAdrian Bunk
This patch fixes the following compile error with CONFIG_MODULES=n caused by commit fb40bd78b0f91b274879cf5db8facd1e04b6052e: /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/marker.c: In function `marker_update_probes': /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/marker.c:627: error: too few arguments to function `module_update_markers' Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Fix compile of swim3 as moduleTony Breeds
The current pmac32_defconfig fails to build with the following error: Building modules, stage 2. ERROR: "check_media_bay" [drivers/block/swim3.ko] undefined! WARNING: modpost: Found 23 section mismatch(es). To see full details build your kernel with: 'make CONFIG_DEBUG_SECTION_MISMATCH=y' make[2]: *** [__modpost] Error 1 This patch fixes that. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
