2007-09-17Pull misc into release branchLen Brown
2007-09-16Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Warn user if cpu is ignored. [SPARC64]: Fix lockdep, particularly on SMP. [SPARC64]: Update defconfig.
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [VLAN]: Fix net_device leak. [PPP] generic: Fix receive path data clobbering & non-linear handling [PPP] generic: Call skb_cow_head before scribbling over skb [NET] skbuff: Add skb_cow_head [BRIDGE]: Kill clone argument to br_flood_* [PPP] pppoe: Fill in header directly in __pppoe_xmit [PPP] pppoe: Fix data clobbering in __pppoe_xmit and return value [PPP] pppoe: Fix skb_unshare_check call position [SCTP]: Convert bind_addr_list locking to RCU [SCTP]: Add RCU synchronization around sctp_localaddr_list [PKT_SCHED]: sch_cbq.c: Shut up uninitialized variable warning [PKTGEN]: srcmac fix [IPV6]: Fix source address selection. [IPV4]: Just increment OutDatagrams once per a datagram. [IPV6]: Just increment OutDatagrams once per a datagram. [IPV6]: Fix unbalanced socket reference with MSG_CONFIRM. [NET_SCHED] protect action config/dump from irqs [NET]: Fix two issues wrt. SO_BINDTODEVICE.
2007-09-16Fix non-ISA link error in drivers/scsi/advansys.cMatthew Wilcox
When CONFIG_ISA is disabled, the isa_driver support will not be compiled in. Define stubs so that we don't get link-time errors. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-16[VLAN]: Fix net_device leak.Al Viro
In "[VLAN]: Move device registation to seperate function" (commit e89fe42cd03c8fd3686df82d8390a235717a66de), a pile of code got moved to register_vlan_dev(), including grabbing a reference to underlying device. However, original dev_hold() had been left behind, so we leak a reference to net_device now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[PPP] generic: Fix receive path data clobbering & non-linear handlingHerbert Xu
This patch adds missing pskb_may_pull calls to deal with non-linear packets that may arrive from pppoe or pppol2tp. It also copies cloned packets before writing over them. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[PPP] generic: Call skb_cow_head before scribbling over skbHerbert Xu
It's rude to write over data that other people are still using. So call skb_cow_head before PPP proceeds to modify the skb data. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[NET] skbuff: Add skb_cow_headHerbert Xu
This patch adds an optimised version of skb_cow that avoids the copy if the header can be modified even if the rest of the payload is cloned. This can be used in encapsulating paths where we only need to modify the header. As it is, this can be used in PPPOE and bridging. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[BRIDGE]: Kill clone argument to br_flood_*Herbert Xu
The clone argument is only used by one caller and that caller can clone the packet itself. This patch moves the clone call into the caller and kills the clone argument. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[PPP] pppoe: Fill in header directly in __pppoe_xmitHerbert Xu
This patch removes the hdr variable (which is copied into the skb) and instead sets the header directly in the skb. It also uses __skb_push instead of skb_push since we've just checked using skb_cow for enough head room. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[PPP] pppoe: Fix data clobbering in __pppoe_xmit and return valueHerbert Xu
The function __pppoe_xmit modifies the skb data and therefore it needs to copy and skb data if it's cloned. In fact, it currently allocates a new skb so that it can return 0 in case of error without freeing the original skb. This is totally wrong because returning zero is meant to indicate congestion whereupon pppoe is supposed to wake up the upper layer once the congestion subsides. This makes sense for ppp_async and ppp_sync but is out-of-place for pppoe. This patch makes it always return 1 and free the skb. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[PPP] pppoe: Fix skb_unshare_check call positionHerbert Xu
The skb_unshare_check call needs to be made before pskb_may_pull, not after. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[SCTP]: Convert bind_addr_list locking to RCUVlad Yasevich
Since the sctp_sockaddr_entry is now RCU enabled as part of the patch to synchronize sctp_localaddr_list, it makes sense to change all handling of these entries to RCU. This includes the sctp_bind_addrs structure and it's list of bound addresses. This list is currently protected by an external rw_lock and that looks like an overkill. There are only 2 writers to the list: bind()/bindx() calls, and BH processing of ASCONF-ACK chunks. These are already seriealized via the socket lock, so they will not step on each other. These are also relatively rare, so we should be good with RCU. The readers are varied and they are easily converted to RCU. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Sridhar Samdurala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[SCTP]: Add RCU synchronization around sctp_localaddr_listVlad Yasevich
sctp_localaddr_list is modified dynamically via NETDEV_UP and NETDEV_DOWN events, but there is not synchronization between writer (even handler) and readers. As a result, the readers can access an entry that has been freed and crash the sytem. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Sridhar Samdurala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[PKT_SCHED]: sch_cbq.c: Shut up uninitialized variable warningSatyam Sharma
net/sched/sch_cbq.c: In function 'cbq_enqueue': net/sched/sch_cbq.c:383: warning: 'ret' may be used uninitialized in this function has been verified to be a bogus case. So let's shut it up. Signed-off-by: Satyam Sharma <satyam@infradead.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[PKTGEN]: srcmac fixAdit Ranadive
From: Adit Ranadive <adit.262@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[IPV6]: Fix source address selection.Jiri Kosina
The commit 95c385 broke proper source address selection for cases in which there is a address which is makred 'deprecated'. The commit mistakenly changed ifa->flags to ifa_result->flags (probably copy/paste error from a few lines above) in the 'Rule 3' address selection code. The patch restores the previous RFC-compliant behavior. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[SPARC64]: Warn user if cpu is ignored.David S. Miller
When NR_CPUS is smaller than the cpu probed, let the user know that the cpu won't be used. Suggested by Al Viro. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[SPARC64]: Fix lockdep, particularly on SMP.David S. Miller
As noted by Al Viro, when we try to call prom_set_trap_table() in the SMP trampoline code we try to take the PROM call spinlock which doesn't work because the current thread pointer isn't valid yet and lockdep depends upon that being correct. Furthermore, we cannot set the current thread pointer register because it can't be properly dereferenced until we return from prom_set_trap_table(). Kernel TLB misses only work after that call. So do the PROM call to set the trap table directly instead of going through the OBP library C code, and thus avoid the lock altogether. These calls are guarenteed to be serialized fully. Since there are now no calls to the prom_set_trap_table{_sun4v}() library functions, they can be deleted. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[SPARC64]: Update defconfig.David S. Miller
2007-09-16clockevents: prevent stale tick update on offline cpuThomas Gleixner
Taking a cpu offline removes the cpu from the online mask before the CPU_DEAD notification is done. The clock events layer does the cleanup of the dead CPU from the CPU_DEAD notifier chain. tick_do_timer_cpu is used to avoid xtime lock contention by assigning the task of jiffies xtime updates to one CPU. If a CPU is taken offline, then this assignment becomes stale. This went unnoticed because most of the time the offline CPU went dead before the online CPU reached __cpu_die(), where the CPU_DEAD state is checked. In the case that the offline CPU did not reach the DEAD state before we reach __cpu_die(), the code in there goes to sleep for 100ms. Due to the stale time update assignment, the system is stuck forever. Take the assignment away when a cpu is not longer in the cpu_online_mask. We do this in the last call to tick_nohz_stop_sched_tick() when the offline CPU is on the way to the final play_dead() idle entry. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-09-16clockevents: do not shutdown the oneshot broadcast deviceThomas Gleixner
When a cpu goes offline it is removed from the broadcast masks. If the mask becomes empty the code shuts down the broadcast device. This is wrong, because the broadcast device needs to be ready for the online cpu going idle (into a c-state, which stops the local apic timer). Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-09-16clockevents: Enforce oneshot broadcast when broadcast mask is set on resumeThomas Gleixner
The jinxed VAIO refuses to resume without hitting keys on the keyboard when this is not enforced. It is unclear why the cpu ends up in a lower C State without notifying the clock events layer, but enforcing the oneshot broadcast here is safe. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-09-16ACPI: Reevaluate C/P/T states when a cpu becomes onlineVenkatesh Pallipadi
Reevaluate C/P/T states when a cpu becomes online. This avoids the caching of the broadcast information in the clockevents layer. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Len Brown <len.brown@intel.com>
2007-09-16timekeeping: Prevent time going backwards on resumeThomas Gleixner
Timekeeping resume adjusts xtime by adding the slept time in seconds and resets the reference value of the clock source (clock->cycle_last). clock->cycle last is used to calculate the delta between the last xtime update and the readout of the clock source in __get_nsec_offset(). xtime plus the offset is the current time. The resume code ignores the delta which had already elapsed between the last xtime update and the actual time of suspend. If the suspend time is short, then we can see time going backwards on resume. Suspend: offs_s = clock->read() - clock->cycle_last; now = xtime + offs_s; timekeeping_suspend_time = read_rtc(); Resume: sleep_time = read_rtc() - timekeeping_suspend_time; xtime.tv_sec += sleep_time; clock->cycle_last = clock->read(); offs_r = clock->read() - clock->cycle_last; now = xtime + offs_r; if sleep_time_seconds == 0 and offs_r < offs_s, then time goes backwards. Fix this by storing the offset from the last xtime update and add it to xtime during resume, when we reset clock->cycle_last: sleep_time = read_rtc() - timekeeping_suspend_time; xtime.tv_sec += sleep_time; xtime += offs_s; /* Fixup xtime offset at suspend time */ clock->cycle_last = clock->read(); offs_r = clock->read() - clock->cycle_last; now = xtime + offs_r; Thanks to Marcelo for tracking this down on the OLPC and providing the necessary details to analyze the root cause. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <johnstul@us.ibm.com> Cc: Tosatti <marcelo@kvack.org>
2007-09-16timekeeping: access rtc outside of xtime lockThomas Gleixner
Lockdep complains about the access of rtc in timekeeping_suspend inside the interrupt disabled region of the write locked xtime lock. Move the access outside. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <johnstul@us.ibm.com>
2007-09-15Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: drivers/net/pcmcia/3c589_cs: fix port configuration switcheroo sk98lin: resurrect driver ucc_geth: fix compilation mv643xx_eth: Fix tx_bytes stats calculation As struct iw_point is bi-directional payload, we should copy back the content [PATCH] bcm43xx: Fix cancellation of work queue crashes spidernet: fix interrupt reason recognition ehea: fix last_rx update ehea: propagate physical port state Fix a lock problem in generic phy code sky2: restore multicast list on resume and other ops atl1: disable broken 64-bit DMA
2007-09-15drivers/net/pcmcia/3c589_cs: fix port configuration switcherooJeff Garzik
10base2 and 10baseT were accidentally switched. Noticed by Andreas HÃŒbner, forwarded by Alan Cox. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-09-15sk98lin: resurrect driverStephen Hemminger
This reverts commit e1abecc48938fbe1966ea6e78267fc673fa59295. The driver works on some hardware that skge doesn't handle yet. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-09-15ucc_geth: fix compilationAnton Vorontsov
Currently qe_bd_t is used in the macro call -- dma_unmap_single, which is a no-op on PPC32, thus error is hidden today. Starting with 2.6.24, macro will be replaced by the empty static function, and erroneous use of qe_bd_t will trigger compilation error. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-09-15mv643xx_eth: Fix tx_bytes stats calculationDale Farnsworth
Reported by Corey Minyard <cminyard@mvista.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-09-15Merge branch 'fixes-jgarzik' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream-fixes
2007-09-15sparc64 (and others): fix tty_ioctl.c buildTony Breeds
Add Guards around TIOCSLCKTRMIOS and TIOCGLCKTRMIOS. Several architectures are still broken. Put temporary-for-2.6.23 ifdef guards around the offending code. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by:: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-14[IPV4]: Just increment OutDatagrams once per a datagram.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-14[IPV6]: Just increment OutDatagrams once per a datagram.YOSHIFUJI Hideaki
2007-09-14Merge git://git.linux-xtensa.org/kernel/xtensa-feedLinus Torvalds
* git://git.linux-xtensa.org/kernel/xtensa-feed: [patch 1/2] Xtensa: enable arbitary tty speed setting ioctls [patch 2/2] xtensa console.c: remove duplicate #include [XTENSA] Add support for cache-aliasing [XTENSA] Add kernel module support [XTENSA] Add support for executable/non-executable feature in the mmu [XTENSA] Use the generic version of get_order [XTENSA] Initialize semaphore_wake_lock [XTENSA] Add typecast macro for constants [XTENSA] Fix timer instabilities. [XTENSA] Fix fadvise64_64 [XTENSA] Remove extraneous include statement [XTENSA] Move string-io functions to io.c from pci.c [XTENSA] Move pre-initialized structures to init_task.c [XTENSA] Add freestanding option to CFLAGS [XTENSA] Add getpgrp system-call to unistd.h [XTENSA] add missing system calls [XTENSA] fix wrong usage of __init and __initdata in traps.c
2007-09-14[IPV6]: Fix unbalanced socket reference with MSG_CONFIRM.YOSHIFUJI Hideaki
2007-09-14[NET_SCHED] protect action config/dump from irqsJamal Hadi Salim
(with no apologies to C Heston) On Mon, 2007-10-09 at 21:00 +0800, Herbert Xu wrote: On Sun, Sep 02, 2007 at 01:11:29PM +0000, Christian Kujau wrote: > > > > after upgrading to 2.6.23-rc5 (and applying davem's fix [0]), lockdep > > was quite noisy when I tried to shape my external (wireless) interface: > > > > [ 6400.534545] FahCore_78.exe/3552 just changed the state of lock: > > [ 6400.534713] (&dev->ingress_lock){-+..}, at: [<c038d595>] > > netif_receive_skb+0x2d5/0x3c0 > > [ 6400.534941] but this lock took another, soft-read-irq-unsafe lock in the > > past: > > [ 6400.535145] (police_lock){-.--} > > This is a genuine dead-lock. The police lock can be taken > for reading with softirqs on. If a second CPU tries to take > the police lock for writing, while holding the ingress lock, > then a softirq on the first CPU can dead-lock when it tries > to get the ingress lock. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-14[NET]: Fix two issues wrt. SO_BINDTODEVICE.David S. Miller
1) Comments suggest that setting optlen to zero will unbind the socket from whatever device it might be attached to. This hasn't been the case since at least 2.2.x because the first thing this function does is return -EINVAL if 'optlen' is less than sizeof(int). This check also means that passing in a two byte string doesn't work so well. It's almost as if this code was testing with "eth?" patterned strings and nothing else :-) Fix this by breaking the logic of this facility out into a seperate function which validates optlen more appropriately. The optlen==0 and small string cases now work properly. 2) We should reset the cached route of the socket after we have made the device binding changes, not before. Reported by Ben Greear. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-14Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/cooloney/blackfin-2.6 * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/cooloney/blackfin-2.6: Blackfin arch: fix some bugs in lib/string.h functions found by our string testing modules Blackfin arch: fix the aliased write macros Blackfin arch: Update/Fix PM support add new pm_ops valid
2007-09-14Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 4567/1: Fix 'Oops - undefined instruction' when CONFIG_VFP=y on non VFP device [ARM] realview: disable second GIC on RevB MPCore platforms
2007-09-14Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] 20Kc: Disable use of WAIT instruction. [MIPS] Workaround for 4Kc machine check exception [MIPS] Malta: Fix off by one bug in interrupt handler. [MIPS] No ide_default_io_base() if PCI IDE was not found [MIPS] Add #include <linux/profile.h> to arch/mips/kernel/time.c [MIPS] N32 needs to use compat_sys_futimesat [MIPS] rtlx: Fix build error. [MIPS] rtlx: fix int vs. long bug.
2007-09-14KVM: MMU: Fix rare oops on guest context switchAvi Kivity
A guest context switch to an uncached cr3 can require allocation of shadow pages, but we only recycle shadow pages in kvm_mmu_page_fault(). Move shadow page recycling to mmu_topup_memory_caches(), which is called from both the page fault handler and from guest cr3 reload. Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-14Merge branch 'master' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb * 'master' of ssh://master.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: V4L/DVB (6220a): fix build error for et61x251 driver V4L/DVB (6188): Avoid a NULL pointer dereference during mpeg_open() V4L/DVB (6173a): Documentation: Remove reference to dead "cpia_pp=" boot-time option V4L/DVB (6148): Fix a warning at saa7191_probe V4L/DVB (6147): Pwc: Fix a broken debug message V4L/DVB (6144): Fix mux setup for composite sound on AverTV 307 V4L/DVB (6095): ivtv: fix VIDIOC_G_ENC_INDEX flag handling
2007-09-14Correctly close old nfsd/lockd sockets.Neil Brown
Commit aaf68cfbf2241d24d46583423f6bff5c47e088b3 added a bias to sk_inuse, so this test for an unused socket now fails. So no sockets get closed because they are old (they might get closed if the client closed them). This bug has existed since 2.6.21-rc1. Thanks to Wolfgang Walter for finding and reporting the bug. Cc: Wolfgang Walter <wolfgang.walter@studentenwerk.mhn.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-14Fix kernel buuild with (CONFIG_COMPAT && ! CONFIG_BLOCK)aherrman@arcor.de
Commit 02a5e0acb3cb85d80d0fe834e366d38a92bbaa22 ("BLOCK: Hide the contents of linux/bio.h if CONFIG_BLOCK=n") broke the kernel build for the CONFIG_COMPAT && !CONFIG_BLOCK case: CC fs/compat_ioctl.o In file included from include/linux/raid/md_k.h:19, from include/linux/raid/md.h:54, from fs/compat_ioctl.c:25: include/linux/raid/../../../drivers/md/dm-bio-list.h: In bio_list_: include/linux/raid/../../../drivers/md/dm-bio-list.h:40: error: dereferencing pointer to incomplete type include/linux/raid/../../../drivers/md/dm-bio-list.h: In bio_list_: include/linux/raid/../../../drivers/md/dm-bio-list.h:48: error: dereferencing pointer to incomplete type include/linux/raid/../../../drivers/md/dm-bio-list.h:51: error: dereferencing pointer to incomplete type include/linux/raid/../../../drivers/md/dm-bio-list.h: In bio_list_: include/linux/raid/../../../drivers/md/dm-bio-list.h:64: error: dereferencing pointer to incomplete type include/linux/raid/../../../drivers/md/dm-bio-list.h: In bio_list_merge_: include/linux/raid/../../../drivers/md/dm-bio-list.h:78: error: dereferencing pointer to incomplete type include/linux/raid/../../../drivers/md/dm-bio-list.h: In bio_list_: include/linux/raid/../../../drivers/md/dm-bio-list.h:90: error: dereferencing pointer to incomplete type include/linux/raid/../../../drivers/md/dm-bio-list.h:94: error: dereferencing pointer to incomplete type make[1]: *** [fs/compat_ioctl.o] Error 1 make: *** [fs] Error 2 Signed-off-by: Andreas Herrmann <aherrman@arcor.de> Acked-By: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-14shared tag queue barrier commentNick Piggin
Should add some comments for the tag barriers (they won't be so important if we can switch over to the explicit _lock bitops, but for now we should make it clear). Jens' original patch said a barrier after the test_and_clear_bit was also required. I can't see why (and it would prevent the use of the _lock bitop). Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> --
2007-09-14As struct iw_point is bi-directional payload, we should copy back the contentMasakazu Mokuno
on return from ioctl calls Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-09-14[PATCH] bcm43xx: Fix cancellation of work queue crashesLarry Finger
A crash upon booting that is caused by bcm43xx has been reported [1] and found to be due to a work queue being reinitialized while work on that queue is still pending. This fix modifies the shutdown of work queues and prevents periodic work from being requeued during shutdown. With this patch, no more crashes on reboot were observed by the original reporter. I do not get that particular failure on my system; however, when running a large number of ifdown/ifup sequences, my system would kernel panic with the 'caps lock' light blinking at roughly a 1 Hz rate. In addition, there were infrequent failures in the firmware that resulted in 'IRQ READY TIMEOUT' errors. With this patch, no more of the first type of failure occur, and incidence of the second type is greatly reduced. [1] http://bugzilla.kernel.org/show_bug.cgi?id=8937 Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-09-14[MIPS] 20Kc: Disable use of WAIT instruction.Ralf Baechle
Another issue with 20Kc's WAIT, waiting for more details. With the 2.6.23 release immindent simply disable the use of WAIT instead of a more fancy workaround. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
