2008-02-25Linux 2.6.22.19v2.6.22.19Greg Kroah-Hartman
2008-02-25NETFILTER: nf_conntrack_tcp: conntrack reopening fixJozsef Kadlecsik
[NETFILTER]: nf_conntrack_tcp: conntrack reopening fix [Upstream commits b2155e7f + d0c1fd7a] TCP connection tracking in netfilter did not handle TCP reopening properly: active close was taken into account for one side only and not for any side, which is fixed now. The patch includes more comments to explain the logic how the different cases are handled. The bug was discovered by Jeff Chua. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25SCSI: sd: handle bad lba in sense informationJames Bottomley
patch 366c246de9cec909c5eba4f784c92d1e75b4dc38 in mainline. Some devices report medium error locations incorrectly. Add guards to make sure the reported bad lba is actually in the request that caused it. Additionally remove the large case statment for sector sizes and replace it with the proper u64 divisions. Tested-by: Mike Snitzer <snitzer@gmail.com> Cc: Stable Tree <stable@kernel.org> Cc: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25Be more robust about bad arguments in get_user_pages()Jonathan Corbet
MAINLINE: 900cf086fd2fbad07f72f4575449e0d0958f860f So I spent a while pounding my head against my monitor trying to figure out the vmsplice() vulnerability - how could a failure to check for *read* access turn into a root exploit? It turns out that it's a buffer overflow problem which is made easy by the way get_user_pages() is coded. In particular, "len" is a signed int, and it is only checked at the *end* of a do {} while() loop. So, if it is passed in as zero, the loop will execute once and decrement len to -1. At that point, the loop will proceed until the next invalid address is found; in the process, it will likely overflow the pages array passed in to get_user_pages(). I think that, if get_user_pages() has been asked to grab zero pages, that's what it should do. Thus this patch; it is, among other things, enough to block the (already fixed) root exploit and any others which might be lurking in similar code. I also think that the number of pages should be unsigned, but changing the prototype of this function probably requires some more careful review. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25quicklists: Only consider memory that can be used with GFP_KERNELChristoph Lameter
patch 96990a4ae979df9e235d01097d6175759331e88c in mainline. Quicklists calculates the size of the quicklists based on the number of free pages. This must be the number of free pages that can be allocated with GFP_KERNEL. node_page_state() includes the pages in ZONE_HIGHMEM and ZONE_MOVABLE which may lead the quicklists to become too large causing OOM. Signed-off-by: Christoph Lameter <clameter@sgi.com> Tested-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Oliver Pinter <oliver.pntr@gmail.com>
2008-02-25knfsd: query filesystem for NFSv4 getattr of FATTR4_MAXNAMEJ. Bruce Fields
mainline: a16e92edcd0a2846455a30823e1bac964e743baa Without this we always return 2^32-1 as the the maximum namelength. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25NFS: Fix an Oops in encode_lookup()Trond Myklebust
mainline: 54af3bb543c071769141387a42deaaab5074da55 It doesn't look as if the NFS file name limit is being initialised correctly in the struct nfs_server. Make sure that we limit whatever is being set in nfs_probe_fsinfo() and nfs_init_server(). Also ensure that readdirplus and nfs4_path_walk respect our file name limits. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Neil Brown <neilb@suse.de> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25NFSv2/v3: Fix a memory leak when using -onolockTrond Myklebust
mainline: 5cef338b30c110daf547fb13d99f0c77f2a79fbc Neil Brown said: > Hi Trond, > > We found that a machine which made moderately heavy use of > 'automount' was leaking some nfs data structures - particularly the > 4K allocated by rpc_alloc_iostats. > It turns out that this only happens with filesystems with -onolock > set. > The problem is that if NFS_MOUNT_NONLM is set, nfs_start_lockd doesn't > set server->destroy, so when the filesystem is unmounted, the > ->client_acl is not shutdown, and so several resources are still > held. Multiple mount/umount cycles will slowly eat away memory > several pages at a time. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25NFS: Fix nfs_reval_fsid()Trond Myklebust
mainline: a0356862bcbeb20acf64bc1a82d28a4c5bb957a7 We don't need to revalidate the fsid on the root directory. It suffices to revalidate it on the current directory. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Neil Brown <neilb@suse.de> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25knfsd: fix spurious EINVAL errors on first access of new filesystemJ. Bruce Fields
mainline: ac8587dcb58e40dd336d99d60f852041e06cc3dd The v2/v3 acl code in nfsd is translating any return from fh_verify() to nfserr_inval. This is particularly unfortunate in the case of an nfserr_dropit return, which is an internal error meant to indicate to callers that this request has been deferred and should just be dropped pending the results of an upcall to mountd. Thanks to Roland <devzero@web.de> for bug report and data collection. Cc: Roland <devzero@web.de> Acked-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Reviewed-By: NeilBrown <neilb@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25via-velocity: don't oops on MTU change (resend)Stephen Hemminger
mainline: 48f6b053613b62fed7a2fe3255e5568260a8d615 The VIA veloicty driver needs the following to allow changing MTU when down. The buffer size needs to be computed when device is brought up, not when device is initialized. This also fixes a bug where the buffer size was computed differently on change_mtu versus initial setting. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Acked-by: Jeff Mahoney <jeffm@suse.com> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25VIA_VELOCITY: Don't oops on MTU change.Stephen Hemminger
mainline: bd7b3f34198071d8bec05180530c362f1800ba46 Simple mtu change when device is down. Fix http://bugzilla.kernel.org/show_bug.cgi?id=9382. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Mahoney <jeffm@suse.com> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25sony-laptop: call sonypi_compat_init earlierMattia Dongili
mainline: 015a916fbbf105bb15f4bbfd80c3b9b2f2e0d7db sonypi_compat uses a kfifo that needs to be present before _SRS is called to be able to cope with the IRQs triggered when setting resources. Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Len Brown <len.brown@intel.com> Acked-by: Jeff Mahoney <jeffm@suse.com> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25pci: fix unterminated pci_device_id listsKees Cook
mainline: 248bdd5efca5a113cbf443a993c69e53d370236b Fix a couple drivers that do not correctly terminate their pci_device_id lists. This results in garbage being spewed into modules.pcimap when the module happens to not have 28 NULL bytes following the table, and/or the last PCI ID is actually truncated from the table when calculating the modules.alias PCI aliases, cause those unfortunate device IDs to not auto-load. Signed-off-by: Kees Cook <kees@ubuntu.com> Acked-by: Corey Minyard <minyard@acm.org> Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Jeff Garzik <jeff@garzik.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Jeff Mahoney <jeffm@suse.com> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25Intel_agp: really fix 945/965GMEWang Zhenyu
mainline: dde4787642ee3cb85aef80bdade04b6f8ddc3df8 Fix some missing places to check with device id info, which should probe the device gart correctly. Signed-off-by: Wang Zhenyu <zhenyu.z.wang@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Acked-by: Takashi Iwai <tiwai@suse.de> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25i386: fixup TRACE_IRQ breakage (CVE-2007-3731)Peter Zijlstra
mainline: a10d9a71bafd3a283da240d2868e71346d2aef6f The TRACE_IRQS_ON function in iret_exc: calls a C function without ensuring that the segments are set properly. Move the trace function and the enabling of interrupt into the C stub. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Jeff Mahoney <jeffm@suse.com> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25Handle bogus %cs selector in single-step instruction decoding (CVE-2007-3731)Roland McGrath
Handle bogus %cs selector in single-step instruction decoding mainline: 29eb51101c02df517ca64ec472d7501127ad1da8 The code for LDT segment selectors was not robust in the face of a bogus selector set in %cs via ptrace before the single-step was done. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Jeff Mahoney <jeffm@suse.com> CC: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25NFS: Fix a potential file corruption issue when writingTrond Myklebust
patch 5d47a35600270e7115061cb1320ee60ae9bcb6b8 in mainline. If the inode is flagged as having an invalid mapping, then we can't rely on the PageUptodate() flag. Ensure that we don't use the "anti-fragmentation" write optimisation in nfs_updatepage(), since that will cause NFS to write out areas of the page that are no longer guaranteed to be up to date. A potential corruption could occur in the following scenario: client 1 client 2 =============== =============== fd=open("f",O_CREAT|O_WRONLY,0644); write(fd,"fubar\n",6); // cache last page close(fd); fd=open("f",O_WRONLY|O_APPEND); write(fd,"foo\n",4); close(fd); fd=open("f",O_WRONLY|O_APPEND); write(fd,"bar\n",4); close(fd); ----- The bug may lead to the file "f" reading 'fubar\n\0\0\0\nbar\n' because client 2 does not update the cached page after re-opening the file for write. Instead it keeps it marked as PageUptodate() until someone calls invalidate_inode_pages2() (typically by calling read()). The bug was introduced by commit 44b11874ff583b6e766a05856b04f3c492c32b84 "NFS: Separate metadata and page cache revalidation mechanisms" Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25quicklists: do not release off node pages earlyChristoph Lameter
dhaval@linux.vnet.ibm.com, clameter@sgi.com Message-ID: <200712222203.lBMM3Nsk021922@imap1.linux-foundation.org> From: Christoph Lameter <clameter@sgi.com> patch ed367fc3a7349b17354c7acef551533337764859 in mainline. quicklists must keep even off node pages on the quicklists until the TLB flush has been completed. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25PCI: Fix fakephp deadlockIan Abbott
This patch works around a problem in the fakephp driver when a process writing "0" to a "power" sysfs file to fake removal of a PCI device ends up deadlocking itself in the sysfs code. The patch is functionally identical to the one in Linus' tree post 2.6.24: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=5c796ae7a7ebe56967ed9b9963d7c16d733635ff I have tested it on a 2.6.22 kernel. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25sata_promise: ASIC PRD table bug workaroundMikael Pettersson
patch b9ccd4a90bbb964506f01b4bdcff4f50f8d5d334 in mainline. Second-generation Promise SATA controllers have an ASIC bug which can trigger if the last PRD entry is larger than 164 bytes, resulting in intermittent errors and possible data corruption. Work around this by replacing calls to ata_qc_prep() with a private version that fills the PRD, checks the size of the last entry, and if necessary splits it to avoid the bug. Also reduce sg_tablesize by 1 to accommodate the new entry. Tested on the second-generation SATA300 TX4 and SATA300 TX2plus, and the first-generation PDC20378. Thanks to Alexander Sabourenkov for verifying the bug by studying the vendor driver, and for writing the initial patch upon which this one is based. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25sata_promise: FastTrack TX4200 is a second-generation chipMikael Pettersson
patch 7f9992a23190418592f0810900e4f91546ec41da in mainline. This patch corrects sata_promise to classify FastTrack TX4200 (DID 3515/3519) as a second-generation chip. Promise's partial- source FT TX4200 driver confirms this classification. Treating it as a first-generation chip causes several problems: 1. Detection failures. This is a recent regression triggered by the hotplug-enabling changes in 2.6.23-rc1. 2. Various "failed to resume link for reset" warnings. This patch fixes <http://bugzilla.kernel.org/show_bug.cgi?id=8936>. Thanks to Stephen Ziemba for reporting the bug and for testing the fix. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-25cciss: fix memory leakJesper Juhl
mainline: f2912a1223c0917a7b4e054f18086209137891ea There's a memory leak in the cciss driver. in alloc_cciss_hba() we may leak sizeof(ctlr_info_t) bytes if a call to alloc_disk(1 << NWD_SHIFT) fails. This patch should fix the issue. Spotted by the Coverity checker. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-10Linux 2.6.22.18v2.6.22.18Greg Kroah-Hartman
2008-02-10splice: fix user pointer access in get_iovec_page_array() (CVE-2008-0600)Bastian Blank
patch 712a30e63c8066ed84385b12edbfb804f49cbc44 in mainline. Commit 8811930dc74a503415b35c4a79d14fb0b408a361 ("splice: missing user pointer access verification") added the proper access_ok() calls to copy_from_user_mmap_sem() which ensures we can copy the struct iovecs from userspace to the kernel. But we also must check whether we can access the actual memory region pointed to by the struct iovec to fix the access checks properly. Signed-off-by: Bastian Blank <waldi@debian.org> Acked-by: Oliver Pinter <oliver.pntr@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06Linux 2.6.22.17v2.6.22.17Greg Kroah-Hartman
2008-02-06vm audit: add VM_DONTEXPAND to mmap for drivers that need it (CVE-2008-0007)Nick Piggin
Drivers that register a ->fault handler, but do not range-check the offset argument, must set VM_DONTEXPAND in the vm_flags in order to prevent an expanding mremap from overflowing the resource. I've audited the tree and attempted to fix these problems (usually by adding VM_DONTEXPAND where it is not obvious). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06ACPI: apply quirk_ich6_lpc_acpi to more ICH8 and ICH9Zhao Yakui
patch d1ec7298fcefd7e4d1ca612da402ce9e5d5e2c13 in mainline. It is important that these resources be reserved to avoid conflicts with well known ACPI registers. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06POWERPC: Fix invalid semicolon after if statementIlpo Järvinen
Patch 2b02d13996fe28478e45605de9bd8bdca25718de in mainline [POWERPC] Fix invalid semicolon after if statement A similar fix to netfilter from Eric Dumazet inspired me to look around a bit by using some grep/sed stuff as looking for this kind of bugs seemed easy to automate. This is one of them I found where it looks like this semicolon is not valid. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06chelsio: Fix skb->dev settingDivy Le Ray
patch 7de6af0f23b25df8da9719ecae1916b669d0b03d in mainline. eth_type_trans() now sets skb->dev. Access skb->def after it gets set. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06cxgb: fix statsDivy Le Ray
patch e0348b9ae5374f9a24424ae680bcd80724415f60 in mainline. Fix MAC stats accounting. Fix get_stats. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06cxgb: fix T2 GSODivy Le Ray
patch 7832ee034b6ef78aab020c9ec1348544cd65ccbd in mainline. The patch ensures that a GSO skb has enough headroom to push an encapsulating cpl_tx_pkt_lso header. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06vfs: coredumping fix (CVE-2007-6206)Ingo Molnar
vfs: coredumping fix patch c46f739dd39db3b07ab5deb4e3ec81e1c04a91af in mainline fix: http://bugzilla.kernel.org/show_bug.cgi?id=3043 only allow coredumping to the same uid that the coredumping task runs under. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Acked-by: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: maximilian attems <max@stro.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06ACPICA: fix acpi-cpufreq boot crash due to _PSD return-by-referenceBob Moore
patch 152c300d007c70c4a1847dad39ecdaba22e7d457 in mainline. Changed resolution of named references in packages Fixed a problem with the Package operator where all named references were created as object references and left otherwise unresolved. According to the ACPI specification, a Package can only contain Data Objects or references to control methods. The implication is that named references to Data Objects (Integer, Buffer, String, Package, BufferField, Field) should be resolved immediately upon package creation. This is the approach taken with this change. References to all other named objects (Methods, Devices, Scopes, etc.) are all now properly created as reference objects. http://bugzilla.kernel.org/show_bug.cgi?id=5328 http://bugzilla.kernel.org/show_bug.cgi?id=9429 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06CASSINI: Set skb->truesize properly on receive packets.David Miller
[ Upstream commit: d011a231675b240157a3c335dd53e9b849d7d30d ] skb->truesize was not being incremented at all to reflect the page based data added to RX SKBs. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06CASSINI: Revert 'dont touch page_count'.David Miller
[ Upstream commit: 9de4dfb4c7176e5bb232a21cdd8df78da2b15cac ] This reverts changeset fa4f0774d7c6cccb4d1fda76b91dd8eddcb2dd6a ([CASSINI]: dont touch page_count) because it breaks the driver. The local page counting added by this changeset did not account for the asynchronous page count changes done by kfree_skb() and friends. The change adds extra atomics and on top of it all appears to be totally unnecessary as well. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06CASSINI: Fix endianness bug.Al Viro
[ Upstream commit: e5e025401f6e926c1d9dc3f3f2813cf98a2d8708 ] Here's proposed fix for RX checksum handling in cassini; it affects little-endian working with half-duplex gigabit, but obviously needs testing on big-endian too. The problem is, we need to convert checksum to fixed-endian *before* correcting for (unstripped) FCS. On big-endian it won't matter (conversion is no-op), on little-endian it will, but only if FCS is not stripped by hardware; i.e. in half-duplex gigabit mode when ->crc_size is set. cassini.c part is that fix, cassini.h one consists of trivial endianness annotations. With that applied the sucker is endian-clean, according to sparse. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06ATM: Check IP header validity in mpc_send_packetHerbert Xu
[ATM]: Check IP header validity in mpc_send_packet [ Upstream commit: 1c9b7aa1eb40ab708ef3242f74b9a61487623168 ] Al went through the ip_fast_csum callers and found this piece of code that did not validate the IP header. While root crashing the machine by sending bogus packets through raw or AF_PACKET sockets isn't that serious, it is still nice to react gracefully. This patch ensures that the skb has enough data for an IP header and that the header length field is valid. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06ATM: [nicstar] delay irq setup until card is configuredChas Williams
[ATM]: [nicstar] delay irq setup until card is configured [ Upstream commit: 52961955aa180959158faeb9fd6b4f8a591450f5 ] Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06CONNECTOR: Don't touch queue dev after decrement of ref count.Li Zefan
[CONNECTOR]: Don't touch queue dev after decrement of ref count. [ Upstream commit: cf585ae8ae9ac7287a6d078425ea32f22bf7f1f7 ] cn_queue_free_callback() will touch 'dev'(i.e. cbq->pdev), so it should be called before atomic_dec(&dev->refcnt). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06Fix sparc64 cpu cross call hangs.David Miller
[SPARC64]: Fix endless loop in cheetah_xcall_deliver(). [ Upsteam commit: 0de56d1ab83323d604d95ca193dcbd28388dbabb ] We need to mask out the proper bits when testing the dispatch status register else we can see unrelated NACK bits from previous cross call sends. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-06INET: Fix netdev renaming and inet address labelsMark McLoughlin
[INET]: Fix netdev renaming and inet address labels [ Upstream commit: 44344b2a85f03326c7047a8c861b0c625c674839 ] When re-naming an interface, the previous secondary address labels get lost e.g. $> brctl addbr foo $> ip addr add 192.168.0.1 dev foo $> ip addr add 192.168.0.2 dev foo label foo:00 $> ip addr show dev foo | grep inet inet 192.168.0.1/32 scope global foo inet 192.168.0.2/32 scope global foo:00 $> ip link set foo name bar $> ip addr show dev bar | grep inet inet 192.168.0.1/32 scope global bar inet 192.168.0.2/32 scope global bar:2 Turns out to be a simple thinko in inetdev_changename() - clearly we want to look at the address label, rather than the device name, for a suffix to retain. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06IPSEC: Avoid undefined shift operation when testing algorithm IDHerbert Xu
[IPSEC]: Avoid undefined shift operation when testing algorithm ID [ Upstream commit: f398035f2dec0a6150833b0bc105057953594edb ] The aalgos/ealgos fields are only 32 bits wide. However, af_key tries to test them with the expression 1 << id where id can be as large as 253. This produces different behaviour on different architectures. The following patch explicitly checks whether ID is greater than 31 and fails the check if that's the case. We cannot easily extend the mask to be longer than 32 bits due to exposure to user-space. Besides, this whole interface is obsolete anyway in favour of the xfrm_user interface which doesn't use this bit mask in templates (well not within the kernel anyway). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06IPSEC: Fix potential dst leak in xfrm_lookupHerbert Xu
[IPSEC]: Fix potential dst leak in xfrm_lookup [ Upstream commit: 75b8c133267053c9986a7c8db5131f0e7349e806 ] If we get an error during the actual policy lookup we don't free the original dst while the caller expects us to always free the original dst in case of error. This patch fixes that. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06IPV4: ip_gre: set mac_header correctly in receive pathTimo Teras
[IPV4] ip_gre: set mac_header correctly in receive path [ Upstream commit: 1d0691674764098304ae4c63c715f5883b4d3784 ] mac_header update in ipgre_recv() was incorrectly changed to skb_reset_mac_header() when it was introduced. Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06IPV4 ROUTE: ip_rt_dump() is unecessary slowEric Dumazet
[IPV4] ROUTE: ip_rt_dump() is unecessary slow [ Upstream commit: d8c9283089287341c85a0a69de32c2287a990e71 ] I noticed "ip route list cache x.y.z.t" can be *very* slow. While strace-ing -T it I also noticed that first part of route cache is fetched quite fast : recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"p\0\0\0\30\0\2\0\254i\202 GXm\0\0\2 \0\376\0\0\2\0\2\0"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3772 <0.000047> recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"\234\0\0\0\30\0\2\0\254i\ 202GXm\0\0\2 \0\376\0\0\1\0\2"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3736 <0.000042> recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"\204\0\0\0\30\0\2\0\254i\ 202GXm\0\0\2 \0\376\0\0\1\0\2"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3740 <0.000055> recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"\234\0\0\0\30\0\2\0\254i\ 202GXm\0\0\2 \0\376\0\0\1\0\2"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3712 <0.000043> recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"\204\0\0\0\30\0\2\0\254i\ 202GXm\0\0\2 \0\376\0\0\1\0\2"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3732 <0.000053> recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"p\0\0\0\30\0\2\0\254i\202 GXm\0\0\2 \0\376\0\0\2\0\2\0"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3708 <0.000052> recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"p\0\0\0\30\0\2\0\254i\202 GXm\0\0\2 \0\376\0\0\2\0\2\0"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3680 <0.000041> while the part at the end of the table is more expensive: recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"\204\0\0\0\30\0\2\0\254i\202GXm\0\0\2 \0\376\0\0\1\0\2"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3656 <0.003857> recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"\204\0\0\0\30\0\2\0\254i\202GXm\0\0\2 \0\376\0\0\1\0\2"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3772 <0.003891> recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"p\0\0\0\30\0\2\0\254i\202GXm\0\0\2 \0\376\0\0\2\0\2\0"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3712 <0.003765> recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"p\0\0\0\30\0\2\0\254i\202GXm\0\0\2 \0\376\0\0\2\0\2\0"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3700 <0.003879> recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"p\0\0\0\30\0\2\0\254i\202GXm\0\0\2 \0\376\0\0\2\0\2\0"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3676 <0.003797> recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"p\0\0\0\30\0\2\0\254i\202GXm\0\0\2 \0\376\0\0\2\0\2\0"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3724 <0.003856> recvmsg(3, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"\234\0\0\0\30\0\2\0\254i\202GXm\0\0\2 \0\376\0\0\1\0\2"..., 16384}], msg_controllen=0, msg_flags=0}, 0) = 3736 <0.003848> The following patch corrects this performance/latency problem, removing quadratic behavior. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06IRDA: irda_create() nuke user triggable printkmaximilian attems
[IRDA]: irda_create() nuke user triggable printk [ Upstream commit: 9e8d6f8959c356d8294d45f11231331c3e1bcae6 ] easy to trigger as user with sfuzz. irda_create() is quiet on unknown sock->type, match this behaviour for SOCK_DGRAM unknown protocol Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06NET: Correct two mistaken skb_reset_mac_header() conversions.David Miller
[NET]: Correct two mistaken skb_reset_mac_header() conversions. [ Upstream commit: c6e6ca712b5cc06a662f900c0484d49d7334af64 ] This operation helper abstracts: skb->mac_header = skb->data; but it was done in two more places which were actually: skb->mac_header = skb->network_header; and those are corrected here. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06NET: kaweth was forgotten in msec switchover of usb_start_wait_urbRuss Dill
[NET]: kaweth was forgotten in msec switchover of usb_start_wait_urb [ Upstream commit: 2b2b2e35b71e5be8bc06cc0ff38df15dfedda19b ] Back in 2.6.12-pre, usb_start_wait_urb was switched over to take milliseconds instead of jiffies. kaweth.c was never updated to match. Signed-off-by: Russ Dill <Russ.Dill@asu.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06NET: mcs7830 passes msecs instead of jiffies to usb_control_msgRuss Dill
[NET]: mcs7830 passes msecs instead of jiffies to usb_control_msg [ Upstream commit 1d39da3dcaad4231f0fa75024b1d6d710a2ced74 ] usb_control_msg was changed long ago (2.6.12-pre) to take milliseconds instead of jiffies. Oddly, mcs7830 wasn't added until 2.6.19-rc3. Signed-off-by: Russ Dill <Russ.Dill@asu.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
