2007-02-27Linux 2.6.21-rc2v2.6.21-rc2Linus Torvalds
Too many changes for comfort since -rc1. Some missed merges, and some just annoyingly big fixes since. This is not how an -rc2 should look. Need to really calm things down!
2007-02-27[SPARC64]: Fix PCI interrupts on E450 et al.David S. Miller
When the PCI controller OBP node lacks an interrupt-map and interrupt-map-mask property, we need to form the INO by hand. The PCI swizzle logic was not doing that properly. This was a regression added by the of_device code. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-27Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart: [AGPGART] fix compile errors
2007-02-27Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (52 commits) netxen: do_rom_fast_write error handling natsemi: Fix detection of vanilla natsemi cards net: remove a collection of unneeded #undef REALLY_SLOW_IO stuff chelsio: Fix non-NAPI compile cxgb3 - Feed Rx free list with pages cxgb3 - Recovery from HW starvation of response queue entries. cxgb3 - Unmap offload packets when they are freed cxgb3 - FW version update cxgb3 - private ioctl cleanup cxgb3 - manage sysfs attributes per port S2IO: Restoring the mac address in s2io_reset S2IO: Avoid printing the Enhanced statistics for Xframe I card. S2IO: Making LED off during LINK_DOWN notification. S2IO: Added a loadable parameter to enable or disable vlan stripping in frame. S2IO: Optimized the delay to wait for command completion S2IO: Fixes for MSI and MSIX qla3xxx: Bumping driver version number qla3xxx: Kernic Panic on pSeries under stress conditions qla3xxx: bugfix tx reset after stress conditions. qla3xxx: Check return code from pci_map_single() in ql_release_to_lrg_buf_free_list(), ql_populate_free_queue(), ql_alloc_large_buffers(), and ql3xxx_send() ...
2007-02-27Merge branch 'jffs-maint' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6 * 'jffs-maint' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6: remove the jffs MAINTAINERS entry
2007-02-27netxen: do_rom_fast_write error handlingStephen Hemminger
Compiler warning spots real error! The function do_rom_fast_read called in do_rom_fast_write can fail and leave data1 unset. This causes a compile warning. The correct thing is to propagate the error out. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27remove the jffs MAINTAINERS entryAdrian Bunk
This patch removes the MAINTAINERS entry for the removed jffs filesystem. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27natsemi: Fix detection of vanilla natsemi cardsMark Brown
Bob Tracy <rct@gherkin.frus.com> reported that the addition of support for Aculab E1/T1 cPCI carrier cards broke detection of vanilla natsemi cards. This patch fixes that: the problem is that the driver-specific ta in the PCI device table is an index into a second table and this had not been updated for the vanilla cards. This patch fixes the problem minimally. Signed-Off-By: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27net: remove a collection of unneeded #undef REALLY_SLOW_IO stuffAlan
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27chelsio: Fix non-NAPI compileRoland Dreier
Chelsio without NAPI enabled has been broken (won't compile) since 3de00b89 ("chelsio: NAPI speed improvement"): drivers/net/chelsio/sge.c: In function `t1_interrupt`: drivers/net/chelsio/sge.c:1716: error: `Q` undeclared (first use in this function) The change below seems to add back in the declaration and initialization of `Q` that was removed by mistake, and at least makes the driver compile for me, although I have no hardware and hence no way to test whether this actually works. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27cxgb3 - Feed Rx free list with pagesDivy Le Ray
Populate Rx free list with pages. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27cxgb3 - Recovery from HW starvation of response queue entries.Divy Le Ray
Improve the traffic recovery after the HW ran out of response queue entries. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27cxgb3 - Unmap offload packets when they are freedDivy Le Ray
Offload packets may be DMAed long after their SGE Tx descriptors are done so they must remain mapped until they are freed rather than until their descriptors are freed. Unmap such packets through an skb destructor. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27cxgb3 - FW version updateDivy Le Ray
Update FW version to 3.2 Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27cxgb3 - private ioctl cleanupDivy Le Ray
Clean up some private ioctls. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27cxgb3 - manage sysfs attributes per portDivy Le Ray
sysfs attributes are now managed per port, no longer per adapter. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27S2IO: Restoring the mac address in s2io_resetSivakumar Subramani
- Restore in s2io_reset, the mac address assigned during s2io_open. Earlier, it was getting overwritten to the factory default (read from the eeprom) and subsequently dropping received frames. - Fixed the typo in calling rtnl_unlock in s2io_set_link function. Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27S2IO: Avoid printing the Enhanced statistics for Xframe I card.Sivakumar Subramani
- Enhanced Statistics are supported only for Xframe II (Herculas) card. Add condition check such Enhanced statistics will included only in the case of Xframe II card. Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27S2IO: Making LED off during LINK_DOWN notification.Sivakumar Subramani
- Turning off LED for LINK_DOWN notification - Return from rxd_owner_bit_reset function if call to set_rxd_buffer_pointer fails with ENOMEM Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27S2IO: Added a loadable parameter to enable or disable vlan stripping in frame.Sivakumar Subramani
- Added code to not to strip vlan tag when driver is in promiscuous mode - Added module loadable parameter 'vlan_tag_strip" through which user can enable or disable vlan stripping irrespective of mode ( promiscuous or non-promiscuous ). Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27S2IO: Optimized the delay to wait for command completionSivakumar Subramani
- Optimized delay to wait for command completion so as to reduce the initialization wait time. - Disable differentiated services steering. By default RMAC is configured to steer traffic with certain DS codes to other queues. Driver must initialize the DS memory to 0 to make sure that DS steering will not be used by default. Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27S2IO: Fixes for MSI and MSIXSivakumar Subramani
- Added debug statements to print a debug message if the MSI/MSI-X vector (or) data is zero. - This patch removes the code that will enable NAPI for the case of single ring and MSI-X / MSI case. There are some issue in the enabling NAPI with MSI/MSI-X. So we are turning off NAPI in the case of MSI/MSI-X. Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: Bumping driver version numberBenjamin Li
Signed-off-by: Benjamin Li <benjamin.li@qlogic.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: Kernic Panic on pSeries under stress conditionsBenjamin Li
To reproduce this panic consistently, we run an intensive network application like 'netperf'. After waiting for a couple of seconds, you will see a stack trace and a kernel panic where we are calling pci_unmap_single() in ql_poll(). Changes: 1) Check the flags on the Response MAC IO Control block to check for errors 2) Ensure that if we are on the 4022 we only use one segment 3) Before, we were reading the memory mapped producer index register everytime we iterated in the loop when clearing the queue. We should only be iterating to a known point, not as the producer index is being updated. Signed-off-by: Benjamin Li <benjamin.li@qlogic.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: bugfix tx reset after stress conditions.Ron Mercer
To Reproduce the Problem: To reproduce this panic consistently, we run an intensive network application like 'netperf' and then switch to a different console. After waiting for a couple of seconds, you will see a tx reset has occured. Reason: We enable interrupts even if we were not running. Solution: Now we will enable interrupts only after we are ready to give up the poll routine. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: Check return code from pci_map_single() in ↵Benjamin Li
ql_release_to_lrg_buf_free_list(), ql_populate_free_queue(), ql_alloc_large_buffers(), and ql3xxx_send() pci_map_single() could fail. We need to properly check the return code from pci_map_single(). If we can not properly map this address, then we should cleanup and return the proper return code. Signed-off-by: Benjamin Li <benjamin.li@qlogic.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: bugfix: Fixed jumbo frame handling for 3032 chip.Ron Mercer
The scatter/gather lists were not being build correctly. When large frames spanned several buffers the chip would panic. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: Clean up receive process.Ron Mercer
2007-02-27qla3xxx: Dynamically size the rx buffer queue based on the MTU.Ron Mercer
This change removes use of constants for rx buffer queue size and instead calculates the queue length based on what he MTU is set to. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: Remove API to change MTU.Ron Mercer
This network device driver shares the same hardware as the qla4xxx iSCSI driver. Changing the MTU via the device interface will cause qla4xxx to crash as there is no way to make notification. Users wishing to change the MTU must do so using an iSCSI utility such as Qlogic SanSurfer. This forces the user to unload/reload this network device driver after the MTU value has been changed in flash. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: Fix deadlock issue on error pathsBenjamin Li
1) Fix deadlock issue when in QL_RESET_ACTIVE state and traversing through the Link State Machine 2) Fix deadlock issue when ethtool would call ql_get_settings() 3) Fix deadlock issue when adaptor is ifup'ed but adaptor fails to initialize Signed-off-by: Benjamin Li <benjamin.li@qlogic.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: Changed to use netdev_alloc_skb() from dev_alloc_skbBenjamin Li
2007-02-27qla3xxx: Remove unnecessary memset() in qla3xxx_send()Benjamin Li
We do not need to zero out the 64 byte MAC request I/O control block. By zeroing out the control block and setting it to proper fields is redundant work. This is because in the qla3xxx_send() function we will already set the proper fields in this structure. The unused fields are not looked at by the hardware and do not need to be zeroed out. Signed-off-by: Benjamin Li <benjamin.li@qlogic.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: Return proper error codes when the 4022/4032 is being probedBenjamin Li
The return code was not properly set when when allocating memory or mapping memory failed. Depending on the stack, the return code would sometimes return 0, which indicates everything was ok, when in fact there was an error. This would cause trouble when the module was removed. Now, we will pass back the proper return code when an error occurs during the PCI probe. Signed-off-by: Benjamin Li <benjamin.li@qlogic.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27Alignment in mv643xx_ethRalf Baechle
The driver contains this little piece of candy: #if defined(CONFIG_DMA_NONCOHERENT) || defined(CONFIG_NOT_COHERENT_CACHE) #define ETH_DMA_ALIGN L1_CACHE_BYTES #else #define ETH_DMA_ALIGN 8 #endif Any reason why we're not using dma_get_cache_alignment() instead? Ralf Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27sgiseeq: Don't include unnecessary headerfiles.Ralf Baechle
2007-02-27ucc_geth: use of_get_mac_address()Timur Tabi
Update ucc_geth_probe() to use function of_get_mac_address() to obtain the MAC address. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27skge: comma consistencyStephen Hemminger
Use comma's consistently. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27skge: fix transmitter flow controlStephen Hemminger
It looks like the skge driver inherited another bug from the sk98lin code. If I send from 1000mbit port to a machine on 100mbit port, the switch should be doing hardware flow control, but no pause frames show up in the statistics. This is the analog of the recent sky2 fixes. The device needs to listen for multicast pause frames and then not discard them. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27myri10ge: workaround buggy adopted firmwaresBrice Goglin
Work around a bug which occurs when adopting firmware versions 1.4.4 though 1.4.11 where broadcasts are filtered as if they were multicasts. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27NetXen: Driver ifconfig fixAmit S. Kale
Signed-off-by: Amit S. Kale <amitkale@netxen.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27NetXen: Driver unload fixesAmit S. Kale
2007-02-27spidernet: maintainershipLinas Vepstas
Update driver support contact info. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> Cc: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27spidernet: janitorial, typosLinas Vepstas
Janitorial patch. Undo long lines, fix typo in err msg. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> Cc: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27spidernet: transmit raceLinas Vepstas
Multiple threads performing a transmit can race into the spidernet tx ring cleanup code. This puts the relevant check under a lock. Signed-off-by: Linas Vepstas <lins@austin.ibm.com> Cc: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> Cc: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27spidernet: fix racy double-free of skbLinas Vepstas
It appears that under certain circumstances, a race will result in a double-free of an skb. This patch null's out the skb pointer upon the skb free, avoiding the inadvertent deref of bogus data. The next patch fixes the actual race. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> Cc: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27spidernet: separate hardware state from driver state.Linas Vepstas
This patch separates the hardware descriptor state from the driver descriptor state, per (old) suggestion from Ben Herrenschmidt. This compiles and boots and seems to work. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> Cc: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27spidernet: move medium variable into card structJens Osterkamp
This moves the medium variable into the spidernet card structure. It renames the GMII_ variables to BCM54XX specific ones. Signed-off-by: Jens Osterkamp <jens@de.ibm.com> Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27spidernet: remove txram full loggingIshizaki Kou
This patches removes logging for SPIDER_NET_GTMFLLINT interrupts. Since the interrupts are not irregular, and they happen frequently when using 100Mbps network switches. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27spidernet: spidernet: add support for CellebKou Ishizaki
This patch adds or changes some HW specific settings for spider_net on Celleb. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
