2006-10-30Linux 2.6.19-rc4v2.6.19-rc4Linus Torvalds
Not halloween. Not scary. Just a regular -rc release.
2006-10-30Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] MIPS doesn't need compat_sys_getdents. [MIPS] JMR3927: Fixup another victim of the irq pt_regs cleanup. [MIPS] EMMA 2 / Markeins: struct resource takes physical addresses. [MIPS] EMMA 2 / Markeins: Convert to name struct resource initialization. [MIPS] EMMA 2 / Markeins: Formitting fixes split from actual address fixes. [MIPS] EMMA 2 / Markeins: Fix build wreckage due to genirq wreckage. [MIPS] Ocelot G: Fix build error and numerous warnings. [MIPS] Fix return value of TXX9 SPI interrupt handler [MIPS] Au1000: Fix warning about unused variable. [MIPS] Wire up getcpu(2) and epoll_wait(2) syscalls. [MIPS] Make SB1 cache flushes not to use on_each_cpu [MIPS] Fix warning about unused definition in c-sb1.c [MIPS] SMTC: Make 8 the default number of processors. [MIPS] Oprofile: Fix MIPSxx counter number detection. [MIPS] Au1xx0 code sets incorrect mips_hpt_frequency [MIPS] Oprofile: fix on non-VSMP / non-SMTC SMP configurations.
2006-10-30[PATCH] clean up add_bd_holder()Jun'ichi Nomura
add_bd_holder() is called from bd_claim_by_kobject to put a given struct bd_holder in the list if there is no matching entry. There are 3 possible results of add_bd_holder(): 1. there is no matching entry and add the given one to the list 2. there is matching entry, so just increment reference count of the existing one 3. something failed during its course 1 and 2 are successful cases. But for case 2, someone has to free the unused struct bd_holder. The current code frees it inside of add_bd_holder and returns same value 0 for both cases 1 and 2. However, it's natural and less error-prone if caller frees it since it's allocated by the caller. Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] fix bd_claim_by_kobject error handlingJun'ichi Nomura
This fixes bd_claim_by_kobject to release bdev correctly in case that bd_claim succeeds but following add_bd_holder fails. Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[MIPS] MIPS doesn't need compat_sys_getdents.Ralf Baechle
2006-10-30[MIPS] JMR3927: Fixup another victim of the irq pt_regs cleanup.Ralf Baechle
2006-10-30[MIPS] EMMA 2 / Markeins: struct resource takes physical addresses.Ralf Baechle
2006-10-30[MIPS] EMMA 2 / Markeins: Convert to name struct resource initialization.Ralf Baechle
This fixes the wreckage caused by shuffeling the order of struct resource members. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-30[MIPS] EMMA 2 / Markeins: Formitting fixes split from actual address fixes.Ralf Baechle
2006-10-30[MIPS] EMMA 2 / Markeins: Fix build wreckage due to genirq wreckage.Ralf Baechle
I wonder if the original contributor still cares ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-30[MIPS] Ocelot G: Fix build error and numerous warnings.Ralf Baechle
The cause of the build errors was a 64-bit kernel being configured in ocelot_g_defconfig without the code being 64-bit proof. Fixed for now by limiting 64-bit selection to SYS_SUPPORTS_64BIT_KERNEL if BROKEN. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-30[MIPS] Fix return value of TXX9 SPI interrupt handlerYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-30[MIPS] Au1000: Fix warning about unused variable.Yoichi Yuasa
arch/mips/au1000/common/time.c: In function `mips_timer_interrupt': arch/mips/au1000/common/time.c:82: warning: unused variable `count' Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-30[MIPS] Wire up getcpu(2) and epoll_wait(2) syscalls.Ralf Baechle
2006-10-30[MIPS] Make SB1 cache flushes not to use on_each_cpuManish Lachwani
This fixes the start_kernel(): bug: interrupts were enabled early messages. Signed-off-by: Manish Lachwani <mlachwani@mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-30[MIPS] Fix warning about unused definition in c-sb1.cYoichi Yuasa
arch/mips/mm/c-sb1.c: In function `sb1_cache_init': arch/mips/mm/c-sb1.c:447: warning: unused variable `handle_vec2_sb1' Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-30[MIPS] SMTC: Make 8 the default number of processors.Ralf Baechle
8 is the next larger power of two of the currently 5 supported TCs. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-30[MIPS] Oprofile: Fix MIPSxx counter number detection.Ralf Baechle
2006-10-30[MIPS] Au1xx0 code sets incorrect mips_hpt_frequencySergei Shtylyov
Alchemy CPU counter ticks at the full CPU clock speed. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-30[MIPS] Oprofile: fix on non-VSMP / non-SMTC SMP configurations.Ralf Baechle
2006-10-30[PATCH] fix i386 regparm=3 RT signal handlers on x86_64Albert Cahalan
The recent change to make x86_64 support i386 binaries compiled with -mregparm=3 only covered signal handlers without SA_SIGINFO. (the 3-arg "real-time" ones) This is useful for klibc at least. Signed-off-by: Albert Cahalan <acahalan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] fix "sunrpc: fix refcounting problems in rpc servers"Andrew Morton
- printk should remain dprintk - fix coding-style. Cc: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] APM: URL of APM 1.2 specs has changedKristian Mueller
APM BIOS Interface Secification can now be found at http://www.microsoft.com/whdc/archive/amp_12.mspx Signed-off-by: Kristian Mueller <Kristian-M@Kristian-M.de> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] sunrpc: fix refcounting problems in rpc serversNeil Brown
A recent patch fixed a problem which would occur when the refcount on an auth_domain reached zero. This problem has not been reported in practice despite existing in two major kernel releases because the refcount can never reach zero. This patch fixes the problems that stop the refcount reaching zero. 1/ We were adding to the refcount when inserting in the hash table, but only removing from the hashtable when the refcount reached zero. Obviously it never would. So don't count the implied reference of being in the hash table. 2/ There are two paths on which a socket can be destroyed. One called svcauth_unix_info_release(). The other didn't. So when the other was taken, we can lose a reference to an ip_map which in-turn holds a reference to an auth_domain So unify the exit paths into svc_sock_put. This highlights the fact that svc_delete_socket has slightly odd semantics - it does not drop a reference but probably should. Fixing this need a bit more thought and testing. Signed-off-by: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] drivers/ide/pci/generic.c: add missing newline to the ↵Sergey Vlasov
all-generic-ide message Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] xacct_add_tsk: fix pure theoretical ->mm use-after-freeOleg Nesterov
Paranoid fix. The task can free its ->mm after the 'if (p->mm)' check. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] uml: fix compilation options for USER_OBJSakpm@osdl.org
From: Jeff Dike <jdike@addtoit.com>, Paolo Giarrusso <blaisorblade@yahoo.it> Make sure that when compiling USER_OBJS the correct compilation options are passed; since they are compiled with USER_CFLAGS which is derived from CFLAGS, make sure it is a recursively evaluated variable, so that changes to CFLAGS done afterwards the inclusion of arch/$(ARCH)/Makefile are reflected in USER_CFLAGS. For instance, without this patch userspace objects are never compiled with debug info active. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] Fix "Remove the use of _syscallX macros in UML"Paolo 'Blaisorblade' Giarrusso
Fix commit 5f4c6bc1f369f20807a8e753c2308d1629478c61: it spits out warnings about missing syscall prototype (it is in <unistd.h>) and it does not recognize that two uses of _syscallX are to be resolved against kernel headers in the source tree, not against _syscallX; they in fact do not compile and would not work anyway. If _syscallX macros will be removed from the kernel tree altogether, the only reasonable solution for that piece of code is switching to open-coded inline assembly (it's remapping the whole executable from memory, except the page containing this code). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] docbook: make a filesystems bookRandy Dunlap
Make a filesystems DocBook book/file by moving all filesystems info from kernel-api.tmpl. Will also merge journal-api.tmpl into it soon (with permission from Roger Gammans). Localizes filesystem info and reduces size of the huge (produced) kernel-api output files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] MTD: fix last kernel-doc warningRandy Dunlap
Fix the last current kernel-doc warning: Warning(/var/linsrc/linux-2619-rc3g5//include/linux/mtd/nand.h:416): No description found for parameter 'write_page' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] cryptocop: double spin_lock_irqsave()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] lockdep: annotate DECLARE_WAIT_QUEUE_HEADPeter Zijlstra
kernel: INFO: trying to register non-static key. kernel: the code is fine but needs lockdep annotation. kernel: turning off the locking correctness validator. kernel: [<c04051ed>] show_trace_log_lvl+0x58/0x16a kernel: [<c04057fa>] show_trace+0xd/0x10 kernel: [<c0405913>] dump_stack+0x19/0x1b kernel: [<c043b1e2>] __lock_acquire+0xf0/0x90d kernel: [<c043bf70>] lock_acquire+0x4b/0x6b kernel: [<c061472f>] _spin_lock_irqsave+0x22/0x32 kernel: [<c04363d3>] prepare_to_wait+0x17/0x4b kernel: [<f89a24b6>] lpfc_do_work+0xdd/0xcc2 [lpfc] kernel: [<c04361b9>] kthread+0xc3/0xf2 kernel: [<c0402005>] kernel_thread_helper+0x5/0xb Another case of non-static lockdep keys; duplicate the paradigm set by DECLARE_COMPLETION_ONSTACK and introduce DECLARE_WAIT_QUEUE_HEAD_ONSTACK. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Greg KH <gregkh@suse.de> Cc: Markus Lidel <markus.lidel@shadowconnect.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@infradead.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] isdn/gigaset: avoid cs->dev null pointer dereferenceAkinobu Mita
When gigaset_initbcs() is called, cs->dev is not initialized yet. If dev_alloc_skb() failed in this function, NULL poinster dereference will happen at dev_warn(). Cc: Kai Germaschewski <kai.germaschewski@gmx.de> Cc: Hansjoerg Lipp <hjlipp@web.de> Cc: Tilman Schmidt <tilman@imap.cc> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] ndiswrapper: don't set the module->taints flagsRandy Dunlap
For ndiswrapper, don't set the module->taints flags, just set the kernel global tainted flag. This should allow ndiswrapper to continue to use GPL symbols. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Florin Malita <fmalita@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] ioc4_serial: irq flags fixAndrew Morton
Use the correct type for the CPU flags. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] Fix dmsetup table output changeChristophe Saout
Fix dm-crypt after the block cipher API changes to correctly return the backwards compatible cipher-chainmode[-ivmode] format for "dmsetup table". Signed-off-by: Christophe Saout <christophe@saout.de> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Linus Torvalds <torvalds@osdl.org> diff linux-2.6.19-rc3.orig/drivers/md/dm-crypt.c linux-2.6.19-rc3/drivers/md/dm-crypt.c
2006-10-30[PATCH] CFQ: bad locking in changed_ioprio()Jens Axboe
When the ioprio code recently got juggled a bit, a bug was introduced. changed_ioprio() is no longer called with interrupts disabled, so using plain spin_lock() on the queue_lock is a bug. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] CFQ: use irq safe locking in cfq_cic_link()Jens Axboe
If cfq_set_request() is called for a new process AND a non-fs io request (so that __GFP_WAIT may not be set), cfq_cic_link() may use spin_lock_irq() and spin_unlock_irq() with interrupts already disabled. Fix is to always use irq safe locking in cfq_cic_link() Acked-By: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-29Revert "r8169: mac address change support"Linus Torvalds
This reverts commit a2b98a697fa4e7564f78905b83db122824916cf9. As per Guennadi Liakhovetski, the mac address change support code breaks some normal uses (_without_ any address changes), and until it's all sorted out, we're better off without it. Says Francois: "Go revert it. Despite what I claimed, I can not find a third-party confirmation by email that it works elsewhere. It would probably be enough to remove the call to __rtl8169_set_mac_addr() in rtl8169_hw_start() though." See also http://bugzilla.kernel.org/show_bug.cgi?id=6032 Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-29Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3914/1: [Jornada7xx] - Typo Fix in cpu-sa1110.c (b != B) [ARM] 3913/1: n2100: fix IRQ routing for second ethernet port [ARM] Add KBUILD_IMAGE target support [ARM] Fix suspend oops caused by PXA2xx PCMCIA driver [ARM] Fix i2c-pxa slave mode support [ARM] 3900/1: Fix VFP Division by Zero exception handling. [ARM] 3899/1: Fix the normalization of the denormal double precision number. [ARM] 3909/1: Disable UWIND_INFO for ARM (again) [ARM] Add __must_check to uaccess functions [ARM] Add realview SMP default configuration [ARM] Fix SMP irqflags support
2006-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-fixes-2.6: [PATCH] PCMCIA: fix __must_check warnings [PATCH] PCMCIA: handle sysfs, PCI errors [PATCH] Export soc_common_drv_pcmcia_remove to allow modular PCMCIA. [PATCH] ioremap balanced with iounmap for drivers/pcmcia [PATCH] pcmcia: au1000_generic fix [PATCH] i82092: wire up errors from pci_register_driver() [PATCH] CONFIG_PM=n slim: drivers/pcmcia/* [PATCH] pcmcia/ds: driver layer error checking [PATCH] pcmcia: update alloc_io_space for conflict checking for multifunction PC card [PATCH] pcmcia: add more IDs to hostap_cs.c [PATCH] pcmcia: at91_cf update
2006-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] sc1200wdt.c pnp unregister fix.
2006-10-29[ARM] 3914/1: [Jornada7xx] - Typo Fix in cpu-sa1110.c (b != B)Kristoffer Ericson
"K4S281632b-1H" should read "K4S281632B-1H" (As it does everywhere else). No more coffe! Signed-off-by: Kristoffer Ericson <Kristoffer_e1@hotmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: ieee1394: ohci1394: revert fail on error in suspend
2006-10-29[WATCHDOG] sc1200wdt.c pnp unregister fix.Akinobu Mita
If no devices found or invalid parameter is specified, scl200wdt_pnp_driver is left unregistered. It breaks global list of pnp drivers. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-10-29[PATCH] m68k: consolidate initcall sectionsGeert Uytterhoeven
Commit 61ce1efe6e40233663d27ab8ac9ba9710eebcaad missed the m68k initcall sections. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-29[PATCH] taskstats: fix sk_buff size calculationOleg Nesterov
prepare_reply() adds GENL_HDRLEN to the payload (genlmsg_total_size()), but then it does genlmsg_put()->nlmsg_put(). This means we forget to reserve a room for 'struct nlmsghdr'. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Thomas Graf <tgraf@suug.ch> Cc: Andrew Morton <akpm@osdl.org> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-29[PATCH] taskstats: fix sk_buff leakOleg Nesterov
'return genlmsg_cancel()' in taskstats_user_cmd/taskstats_exit_send potentially leaks a skb. Unless we pass 'rep_skb' to the netlink layer we own sk_buff. This means we should always do kfree_skb() on failure. [ Thomas acked and pointed out missing return value in original version ] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Thomas Graf <tgraf@suug.ch> Cc: Andrew Morton <akpm@osdl.org> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-29ieee1394: ohci1394: revert fail on error in suspendStefan Richter
Some errors during preparation for suspended state can be skipped with a warning instead of a failure of the whole suspend transition, notably an error in pci_set_power_state. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-10-29[ARM] 3913/1: n2100: fix IRQ routing for second ethernet portLennert Buytenhek
The second ethernet port on the Thecus n2100 was incorrectly assigned to XINT1 instead of the correct XINT3 (PCI INTB instead of INTD), which caused that port to be non-functional. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
