2006-07-15Linux 2.6.17.6v2.6.17.6Greg Kroah-Hartman
2006-07-15[PATCH] Relax /proc fix a bitLinus Torvalds
Relax /proc fix a bit Clearign all of i_mode was a bit draconian. We only really care about S_ISUID/ISGID, after all. Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-14Linux 2.6.17.5v2.6.17.5Greg Kroah-Hartman
2006-07-14[PATCH] Fix nasty /proc vulnerability (CVE-2006-3626)Linus Torvalds
Fix nasty /proc vulnerability We have a bad interaction with both the kernel and user space being able to change some of the /proc file status. This fixes the most obvious part of it, but I expect we'll also make it harder for users to modify even their "own" files in /proc. Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-06Linux 2.6.17.4v2.6.17.4Greg Kroah-Hartman
2006-07-06fix prctl privilege escalation and suid_dumpable (CVE-2006-2451)Greg Kroah-Hartman
Based on a patch from Ernie Petrides During security research, Red Hat discovered a behavioral flaw in core dump handling. A local user could create a program that would cause a core file to be dumped into a directory they would not normally have permissions to write to. This could lead to a denial of service (disk consumption), or allow the local user to gain root privileges. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-30Linux 2.6.17.3v2.6.17.3Chris Wright
2006-06-30[PATCH] NETFILTER: SCTP conntrack: fix crash triggered by packet without ↵Patrick McHardy
chunks [CVE-2006-2934] When a packet without any chunks is received, the newconntrack variable in sctp_packet contains an out of bounds value that is used to look up an pointer from the array of timeouts, which is then dereferenced, resulting in a crash. Make sure at least a single chunk is present. Problem noticed by George A. Theall <theall@tenablesecurity.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29Linux 2.6.17.2v2.6.17.2Chris Wright
2006-06-29[PATCH] Input: return correct size when reading modalias attributeRichard Purdie
Input: return correct size when reading modalias attribute Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] idr: fix race in idr codeSonny Rao
From: Sonny Rao <sonny@burdell.org> I ran into a bug where the kernel died in the idr code: cpu 0x1d: Vector: 300 (Data Access) at [c000000b7096f710] pc: c0000000001f8984: .idr_get_new_above_int+0x140/0x330 lr: c0000000001f89b4: .idr_get_new_above_int+0x170/0x330 sp: c000000b7096f990 msr: 800000000000b032 dar: 0 dsisr: 40010000 current = 0xc000000b70d43830 paca = 0xc000000000556900 pid = 2022, comm = hwup 1d:mon> t [c000000b7096f990] c0000000000d2ad8 .expand_files+0x2e8/0x364 (unreliable) [c000000b7096faa0] c0000000001f8bf8 .idr_get_new_above+0x18/0x68 [c000000b7096fb20] c00000000002a054 .init_new_context+0x5c/0xf0 [c000000b7096fbc0] c000000000049dc8 .copy_process+0x91c/0x1404 [c000000b7096fcd0] c00000000004a988 .do_fork+0xd8/0x224 [c000000b7096fdc0] c00000000000ebdc .sys_clone+0x5c/0x74 [c000000b7096fe30] c000000000008950 .ppc_clone+0x8/0xc -- Exception: c00 (System Call) at 000000000fde887c SP (f8b4e7a0) is in userspace Turned out to be a race-condition and NULL ptr deref, here's my fix: Users of the idr code are supposed to call idr_pre_get without locking, so the idr code must serialize itself with respect to layer allocations. However, it fails to do so in an error path in idr_get_new_above_int(). I added the missing locking to fix this. Signed-off-by: Sonny Rao <sonny@burdell.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] Link error when futexes are disabled on 64bit architecturesAnton Blanchard
From: Anton Blanchard <anton@samba.org> If futexes are disabled we fail to link on ppc64. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] kbuild: bugfix with initramfsNickolay
This patch fix double inclusion of ramfs-input. Signed-off-by: Nickolay Vinogradov <nickolay@protei.ru> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] ide-io: increase timeout value to allow for slave wakeupAl Boldi
During an STR resume cycle, the ide master disk times-out when there is also a slave present (especially CD). Increasing the timeout in ide-io from 10,000 to 100,000 fixes this problem. Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] libata: minor patch for ATA_DFLAG_PIOTejun Heo
Problem: - With 2.6.17 libata, some PIO-only devices are given DMA commands. Changes: - Do not clear the ATA_DFLAG_PIO flag in ata_dev_configure(). Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] ohci1394: Fix broken suspend/resume in ohci1394Robert Hancock
I've been experimenting to track down the cause of suspend/resume problems on my Compaq Presario X1050 laptop: http://bugzilla.kernel.org/show_bug.cgi?id=6075 Essentially the ACPI Embedded Controller and keyboard controller would get into a bizarre, confused state after resume. I found that unloading the ohci1394 module before suspend and reloading it after resume made the problem go away. Diffing the dmesg output from resume, with and without the module loaded, I found that with the module loaded I was missing these: PM: Writing back config space on device 0000:02:00.0 at offset 1. (Was 2100080, writing 2100007) PM: Writing back config space on device 0000:02:00.0 at offset 3. (Was 0, writing 8008) PM: Writing back config space on device 0000:02:00.0 at offset 4. (Was 0, writing 90200000) PM: Writing back config space on device 0000:02:00.0 at offset 5. (Was 1, writing 2401) PM: Writing back config space on device 0000:02:00.0 at offset f. (Was 20000100, writing 2000010a) The default PCI driver performs the pci_restore_state when no driver is loaded for the device. When the ohci1394 driver is loaded, it is supposed to do this, however it appears not to do so. I created the patch below and tested it, and it appears to resolve the suspend problems I was having with the module loaded. I only added in the pci_save_state and pci_restore_state - however, though I know little of this hardware, surely the driver should really be doing more than this when suspending and resuming? Currently it does almost nothing, what if there are commands in progress, etc? Signed-off-by: Robert Hancock <hancockr@shaw.ca> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] IPV6 ADDRCONF: Fix default source address selection without ↵YOSHIFUJI Hideaki
CONFIG_IPV6_PRIVACY We need to update hiscore.rule even if we don't enable CONFIG_IPV6_PRIVACY, because we have more less significant rule; longest match. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] IPV6: Fix source address selection.Łukasz Stelmach
Two additional labels (RFC 3484, sec. 10.3) for IPv6 addreses are defined to make a distinction between global unicast addresses and Unique Local Addresses (fc00::/7, RFC 4193) and Teredo (2001::/32, RFC 4380). It is necessary to avoid attempts of connection that would either fail (eg. fec0:: to 2001:feed::) or be sub-optimal (2001:0:: to 2001:feed::). Signed-off-by: Łukasz Stelmach <stlman@poczta.fm> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] UML: fix uptimeJeff Dike
The use of signed instead of unsigned here broke the calculations on negative numbers that are involved in calculating wall_to_monotonic. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] bcm43xx: init fix for possible Machine CheckMichael Buesch
Place the Init-vs-IRQ workaround before any card register access, because we might not have the wireless core mapped at all times in init. So this will result in a Machine Check caused by a bus error. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] x86: compile fix for asm-i386/alternatives.hKirill Smelkov
compile fix: <asm-i386/alternative.h> needs <asm/types.h> for 'u8' -- just look at struct alt_instr. My module includes <asm/bitops.h> as the first header, and as of 2.6.17 this leads to compilation errors. Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] NTFS: Critical bug fix (affects MIPS and possibly others)Anton Altaparmakov
It fixes a crash in NTFS on architectures where flush_dcache_page() is a real function. I never noticed this as all my testing is done on i386 where flush_dcache_page() is NULL. http://bugzilla.kernel.org/show_bug.cgi?id=6700 Many thanks to Pauline Ng for the detailed bug report and analysis! Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] SPARC32: Fix iommu_flush_iotlb end addressDavid Miller
Fix the calculation of the end address when flushing iotlb entries to ram. This bug has been a cause of esp dma errors, and it affects HyperSPARC systems much worse than SuperSPARC systems. Signed-off-by: Bob Breuer <breuerr@mc.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] ETHTOOL: Fix UFO typoHerbert Xu
The function ethtool_get_ufo was referring to ETHTOOL_GTSO instead of ETHTOOL_GUFO. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] SCTP: Fix persistent slowdown in sctp when a gap ack consumes rx buffer.Neil Horman
In the event that our entire receive buffer is full with a series of chunks that represent a single gap-ack, and then we accept a chunk (or chunks) that fill in the gap between the ctsn and the first gap, we renege chunks from the end of the buffer, which effectively does nothing but move our gap to the end of our received tsn stream. This does little but move our missing tsns down stream a little, and, if the sender is sending sufficiently large retransmit frames, the result is a perpetual slowdown which can never be recovered from, since the only chunk that can be accepted to allow progress in the tsn stream necessitates that a new gap be created to make room for it. This leads to a constant need for retransmits, and subsequent receiver stalls. The fix I've come up with is to deliver the frame without reneging if we have a full receive buffer and the receiving sockets sk_receive_queue is empty(indicating that the receive buffer is being blocked by a missing tsn). Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] SCTP: Send only 1 window update SACK per message.Tsutomu Fujii
Right now, every time we increase our rwnd by more then MTU bytes, we trigger a SACK. When processing large messages, this will generate a SACK for almost every other SCTP fragment. However since we are freeing the entire message at the same time, we might as well collapse the SACK generation to 1. Signed-off-by: Tsutomu Fujii <t-fujii@nb.jp.nec.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] SCTP: Reset rtt_in_progress for the chunk when processing its sack.David Miller
2006-06-29[PATCH] SCTP: Reject sctp packets with broadcast addresses.Vlad Yasevich
Make SCTP handle broadcast properly Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] SCTP: Limit association max_retrans setting in setsockopt.Vlad Yasevich
When using ASSOCINFO socket option, we need to limit the number of maximum association retransmissions to be no greater than the sum of all the path retransmissions. This is specified in Section 7.1.2 of the SCTP socket API draft. However, we only do this if the association has multiple paths. If there is only one path, the protocol stack will use the assoc_max_retrans setting when trying to retransmit packets. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] PFKEYV2: Fix inconsistent typing in struct sadb_x_kmprivate.Tushar Gohad
Fixes inconsistent use of "uint32_t" vs. "u_int32_t". Fix pfkeyv2 userspace builds. Signed-off-by: Tushar Gohad <tgohad@mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] IPV6: Sum real space for RTAs.YOSHIFUJI Hideaki
This patch fixes RTNLGRP_IPV6_IFINFO netlink notifications. Issue pointed out by Patrick McHardy <kaber@trash.net>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] USB: Whiteheat: fix firmware spurious errorsStuart MacDonald
Attached patch fixes spurious errors during firmware load. Signed-off-by: Stuart MacDonald <stuartm@connecttech.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-20Linux 2.6.17.1v2.6.17.1Chris Wright
2006-06-20[PATCH] xt_sctp: fix endless loop caused by 0 chunk length (CVE-2006-3085)Patrick McHardy
Fix endless loop in the SCTP match similar to those already fixed in the SCTP conntrack helper (was CVE-2006-1527). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-17Linux v2.6.17v2.6.17Linus Torvalds
Being named "Crazed Snow-Weasel" instills a lot of confidence in this release, so I'm sure this will be one of the better ones.
2006-06-17[PATCH] powerpc: enable CPU_FTR_CI_LARGE_PAGE for cellArnd Bergmann
Reflect the fact that the Cell Broadband Engine supports 64k pages by adding the bit to the CPU features. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] powerpc: Fix 64k pages on non-partitioned machinesArnd Bergmann
The page size encoding passed to tlbie is incorrect for new-style large pages. This fixes it. This doesn't affect anything on older machines because mmu_psize_defs[psize].penc (the page size encoding) is 0 for 4k and 16M pages (the two are distinguished by a separate "is a large page" bit). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] arm_timer: remove a racy and obsolete PF_EXITING checkOleg Nesterov
arm_timer() checks PF_EXITING to prevent BUG_ON(->exit_state) in run_posix_cpu_timers(). However, for some reason it does so only for CPUCLOCK_PERTHREAD case (which is imho wrong). Also, this check is not reliable, PF_EXITING could be set on another cpu without any locks/barriers just after the check, so it can't prevent from attaching the timer to the exiting task. The previous patch makes this check unneeded. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] run_posix_cpu_timers: remove a bogus BUG_ON()Oleg Nesterov
do_exit() clears ->it_##clock##_expires, but nothing prevents another cpu to attach the timer to exiting process after that. arm_timer() tries to protect against this race, but the check is racy. After exit_notify() does 'write_unlock_irq(&tasklist_lock)' and before do_exit() calls 'schedule() local timer interrupt can find tsk->exit_state != 0. If that state was EXIT_DEAD (or another cpu does sys_wait4) interrupted task has ->signal == NULL. At this moment exiting task has no pending cpu timers, they were cleanuped in __exit_signal()->posix_cpu_timers_exit{,_group}(), so we can just return from irq. John Stultz recently confirmed this bug, see http://marc.theaimsgroup.com/?l=linux-kernel&m=115015841413687 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] check_process_timers: fix possible lockupOleg Nesterov
If the local timer interrupt happens just after do_exit() sets PF_EXITING (and before it clears ->it_xxx_expires) run_posix_cpu_timers() will call check_process_timers() with tasklist_lock + ->siglock held and check_process_timers: t = tsk; do { .... do { t = next_thread(t); } while (unlikely(t->flags & PF_EXITING)); } while (t != tsk); the outer loop will never stop. Actually, the window is bigger. Another process can attach the timer after ->it_xxx_expires was cleared (see the next commit) and the 'if (PF_EXITING)' check in arm_timer() is racy (see the one after that). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] sky2: netconsole suspend/resume interactionStephen Hemminger
A couple of fixes that should prevent crashes when using netconsole and suspend/resume. First, netconsole poll routine shouldn't run unless the device is up; second, the NAPI poll should be disabled during suspend. This is only an issue on sky2, because it has to have one NAPI poll routine for both ports on dual port boards. Normal drivers use netif_rx_schedule_prep and that checks for netif_running. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] Fix missing ret assignment in __bio_map_user() error pathJens Axboe
If get_user_pages() returns less pages than what we asked for, we jump to out_unmap which will return ERR_PTR(ret). But ret can contain a positive number just smaller than local_nr_pages, so be sure to set it to -EFAULT always. Problem found and diagnosed by Damien Le Moal <damien@sdl.hitachi.co.jp> Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] fix cdrom openJens Axboe
Some time ago the cdrom open routine was changed so that we call the driver's open routine before checking to see if it is read only. However, if we discovered that a read write open was not possible and the open flags required a writable open, we just returned -EROFS without calling the driver's release routine. This seems to work for most cdrom drivers, but breaks the Powerpc iSeries virtual cdrom rather badly. This just inserts the release call in the error path to balance the call to "->open()" done by "open_for_data()". Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-14[PATCH] cfq-iosched: fix crash in do_div()Jens Axboe
We don't clear the seek stat values in cfq_alloc_io_context(), and if ->seek_mean is unlucky enough to be set to -36 by chance, the first invocation of cfq_update_io_seektime() will oops with a divide by zero in do_div(). Just memset the entire cic instead of filling invididual values independently. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-14[PATCH] Return error in case flock_lock_file failureKirill Korotaev
If flock_lock_file() failed to allocate flock with locks_alloc_lock() then "error = 0" is returned. Need to return some non-zero. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-13[PATCH] sky2: stop/start hardware idle timer on suspend/resumeStephen Hemminger
The resume bug was caused not by an early interrupt but because the idle timeout was not being stopped on suspend. Also disable hardware IRQ's on suspend. Will need to revisit this with hotplug? Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-13[PATCH] sky2: save/restore base hardware irq during suspend/resumeStephen Hemminger
The hardware should be fully shut off during suspend, and the base irq mask restored during resume. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-13[PATCH] sky2: fix hotplug detect during pollStephen Hemminger
If the poll routine detects no hardware available, it needs to dequeue it self from the network poll list. Linus didn't understand NAPI. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-13[PATCH] sky2: don't hard code number of portsStephen Hemminger
It is cleaner, to not loop over both ports if only one exists. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-13[PATCH] sky2: set_power_state should be voidStephen Hemminger
The set power state function is cleaner if it doesn't return anything. The only caller that could fail is in suspend() and it can check the argument there. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
