2006-04-17Linux 2.6.16.7v2.6.16.7Greg Kroah-Hartman
2006-04-17[PATCH] fix MADV_REMOVE vulnerability (CVE-2006-1524 for real this time)Hugh Dickins
madvise_remove needs to respect file and mmap protections. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17Linux 2.6.16.6v2.6.16.6Greg Kroah-Hartman
2006-04-17[PATCH] shmat: stop mprotect from giving write permission to a readonly ↵Hugh Dickins
attachment (CVE-2006-1524) I found that all of 2.4 and 2.6 have been letting mprotect give write permission to a readonly attachment of shared memory, whether or not IPC would give the caller that permission. SUS says "The behaviour of this function [mprotect] is unspecified if the mapping was not established by a call to mmap", but I don't think we can interpret that as allowing it to subvert IPC permissions. I haven't tried 2.2, but the 2.2.26 source looks like it gets it right; and the patch below reproduces that behaviour - mprotect cannot be used to add write permission to a shared memory segment attached readonly. This patch is simple, and I'm sure it's what we should have done in 2.4.0: if you want to go on to switch write permission on and off with mprotect, just don't attach the segment readonly in the first place. However, we could have accumulated apps which attach readonly (even though they would be permitted to attach read/write), and which subsequently use mprotect to switch write permission on and off: it's not unreasonable. I was going to add a second ipcperms check in do_shmat, to check for writable when readonly, and if not writable find_vma and clear VM_MAYWRITE. But security_ipc_permission might do auditing, and it seems wrong to report an attempt for write permission when there has been none. Or we could flag the vma as SHM, note the shmid or shp in vm_private_data, and then get mprotect to check. But the patch below is a lot simpler: I'd rather stick with it, if we can convince ourselves somehow that it'll be safe. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] atm: clip causes unregister hangStephen Hemminger
If Classical IP over ATM module is loaded, its neighbor table gets populated when permanent neighbor entries are created; but these entries are not flushed when the device is removed. Since the entry never gets flushed the unregister of the network device never completes. This version of the patch also adds locking around the reference to the atm arp daemon to avoid races with events and daemon state changes. (Note: barrier() was never really safe) Bug-reference: http://bugzilla.kernel.org/show_bug.cgi?id=6295 Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] fix non-leader exec under ptraceRoland McGrath
This reverts most of commit 30e0fca6c1d7d26f3f2daa4dd2b12c51dadc778a. It broke the case of non-leader MT exec when ptraced. I think the bug it was intended to fix was already addressed by commit 788e05a67c343fa22f2ae1d3ca264e7f15c25eaf. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] USB: remove __init from usb_console_setupPaul Fulghum
This prevents an Oops if booted with "console=ttyUSB0" but without a USB-serial dongle, and plugged one in afterwards. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] Fix suspend with traced tasksPavel Machek
strace /bin/bash misbehaves after resume; this fixes it. (akpm: it's scary calling refrigerator() in state TASK_TRACED, but it seems to do the right thing). Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] Incorrect signature sent on SMB ReadSteve French
Fixes Samba bug 3621 and kernel.org bug 6147 For servers which require SMB/CIFS packet signing, we were sending the wrong signature (all zeros) on SMB Read request. The new cifs routine to do signatures across an iovec was not complete - and SMB Read, unlike the new SMBWrite2, did not fall back to the older routine (ie use SendReceive vs. the more efficient SendReceive2 ie used the older cifs_sign_smb vs. the disabled cifs_sign_smb2) for calculating signatures. This finishes up cifs_sign_smb2/cifs_calc_signature2 so that the callers of SendReceive2 can get SMB/CIFS packet signatures. Now that cifs_sign_smb2 is supported, we could start using it in the write path but this smaller fix does not include the change to use SMBWrite2 when signatures are required (which when enabled will make more Writes more efficient and alloc less memory). Currently Write2 is only used when signatures are not required at the moment but after more testing we will enable that as well). Thanks to James Slepicka and Sam Flory for initial investigation. Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] RLIMIT_CPU: fix handling of a zero limitAndrew Morton
At present the kernel doesn't honour an attempt to set RLIMIT_CPU to zero seconds. But the spec says it should, and that's what 2.4.x does. Fixing this for real would involve some complexity (such as adding a new it-has-been-set flag to the task_struct, and testing that everwhere, instead of overloading the value of it_prof_expires). Given that a 2.4 kernel won't actually send the signal until one second has expired anyway, let's just handle this case by treating the caller's zero-seconds as one second. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ulrich Weigand <uweigand@de.ibm.com> Cc: Cliff Wickman <cpw@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-17[PATCH] Fix utime(2) in the case that no times parameter was passed in.Nathan Scott
SGI-PV: 949858 SGI-Modid: xfs-linux-melb:xfs-kern:25717a Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-04-17[PATCH] alpha: SMP boot fixesBrian Uhrain says
I've encountered two problems with 2.6.16 and newer kernels on my API CS20 (dual 833MHz Alpha 21264b processors). The first is the kernel OOPSing because of a NULL pointer dereference while trying to populate SysFS with the CPU information. The other is that only one processor was being brought up. I've included a small Alpha-specific patch that fixes both problems. The first problem was caused by the CPUs never being properly registered using register_cpu(), the way it's done on other architectures. The second problem has to do with the removal of hwrpb_cpu_present_mask in arch/alpha/kernel/smp.c. In setup_smp() in the 2.6.15 kernel sources, hwrpb_cpu_present_mask has a bit set for each processor that is probed, and afterwards cpu_present_mask is set to the cpumask for the boot CPU. In the same function of the same file in the 2.6.16 sources, instead of hwrpb_cpu_present_mask being set, cpu_possible_map is updated for each probed CPU. cpu_present_mask is still set to the cpumask of the boot CPU afterwards. The problem lies in include/asm-alpha/smp.h, where cpu_possible_map is #define'd to be cpu_present_mask. Cleanups from: Ivan Kokshaysky <ink@jurassic.park.msu.ru> - cpu_present_mask and cpu_possible_map are essentially the same thing on alpha, as it doesn't support CPU hotplug; - allocate "struct cpu" only for present CPUs, like sparc64 does. Static array of "struct cpu" is just a waste of memory. Signed-off-by: Brian Uhrain <buhrain@rosettastone.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] cciss: bug fix for crash when running hpacucliMike Miller
Fix a crash when running hpacucli with multiple logical volumes on a cciss controller. We were not properly initializing the disk->queue and causing a fault. Thanks to Hasso Tepper for reporting the problem. Thanks to Steve Cameron for root causing the problem. Most of the patch just moves things around. The fix is a one-liner. Signed-off-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Stephen Cameron <steve.cameron@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] edac_752x needs CONFIG_HOTPLUGRandy Dunlap
EDAC_752X uses pci_scan_single_device(), which is only available if CONFIG_HOTPLUG is enabled, so limit this driver with HOTPLUG. This patch was already included in Linus' tree. Adrian Bunk: Rediffed for 2.6.16.x due to unrelated context changes. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Peterson <dsp@llnl.gov>
2006-04-17[PATCH] ext3: Fix missed mutex unlockAnaniev, Leonid I
Missed unlock_super()call is added in error condition code path. Signed-off-by: Leonid Ananiev <leonid.i.ananiev@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] Fix block device symlink nameStephen Rothwell
As noted further on the this file, some block devices have a / in their name, so fix the "block:..." symlink name the same as the /sys/block name. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] Fix buddy list race that could lead to page lru list corruptionsNick Piggin
Rohit found an obscure bug causing buddy list corruption. page_is_buddy is using a non-atomic test (PagePrivate && page_count == 0) to determine whether or not a free page's buddy is itself free and in the buddy lists. Each of the conjuncts may be true at different times due to unrelated conditions, so the non-atomic page_is_buddy test may find each conjunct to be true even if they were not both true at the same time (ie. the page was not on the buddy lists). Signed-off-by: Martin Bligh <mbligh@google.com> Signed-off-by: Rohit Seth <rohitseth@google.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] fuse: fix oops in fuse_send_readpages()Miklos Szeredi
During heavy parallel filesystem activity it was possible to Oops the kernel. The reason is that read_cache_pages() could skip pages which have already been inserted into the cache by another task. Occasionally this may result in zero pages actually being sent, while fuse_send_readpages() relies on at least one page being in the request. So check this corner case and just free the request instead of trying to send it. Reported and tested by Konstantin Isakov. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] m32r: Fix cpu_possible_map and cpu_present_map initialization for ↵Hirokazu Takata
SMP kernel This patch fixes a boot problem of the m32r SMP kernel 2.6.16-rc1-mm3 or later. In this patch, cpu_possible_map is statically initialized, and cpu_present_map is also copied from cpu_possible_map in smp_prepare_cpus(), because the m32r architecture has not supported CPU hotplug yet. Signed-off-by: Hayato Fujiwara <fujiwara.hayato@renesas.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] m32r: security fix of {get, put}_user macrosHirokazu Takata
Update {get,put}_user macros for m32r kernel. - Modify get_user to use __get_user_asm macro, instead of __get_user_x macro. - Remove arch/m32r/lib/{get,put}user.S. - Some cosmetic updates. I would like to thank NIIBE Yutaka for his reporting about the m32r kernel's security problem in {get,put}_user macros. There were no address checking for user space access in {get,put}_user macros. ;-) Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: NIIBE Yutaka <gniibe@fsij.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] NETFILTER: Fix fragmentation issues with bridge netfilterPatrick McHardy
[NETFILTER]: Fix fragmentation issues with bridge netfilter The conntrack code doesn't do re-fragmentation of defragmented packets anymore but relies on fragmentation in the IP layer. Purely bridged packets don't pass through the IP layer, so the bridge netfilter code needs to take care of fragmentation itself. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] sky2: bad memory reference on dual port cardsStephen Hemminger
Sky2 driver will oops referencing bad memory if used on a dual port card. The problem is accessing past end of MIB counter space. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] isd200: limit to BLK_DEV_IDERandy Dunlap
Limit USB_STORAGE_ISD200 to whatever BLK_DEV_IDE and USB_STORAGE are set to (y, m) since isd200 calls ide_fix_driveid() in the BLK_DEV_IDE code. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] MPBL0010 driver sysfs permissions wide openMark Bellon
The MPBL0010 Telco clock driver (drivers/char/tlclk.c) uses 0222 (anyone can write) permissions on its writable sysfs entries. Alter the permissions to 0220 (owner and group can write). The use case for this driver is to configure the fail over behavior of the clock hardware. That should be done by the more privileged users. Signed-off-by: Mark Bellon <mbellon@mvista.com> Acked-by: Gross Mark <mark.gross@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] powerpc: fix incorrect SA_ONSTACK behaviour for 64-bit processesLaurent MEYER
*) When setting a sighandler using sigaction() call, if the flag SA_ONSTACK is set and no alternate stack is provided via sigaltstack(), the kernel still try to install the alternate stack. This behavior is the opposite of the one which is documented in Single Unix Specifications V3. *) Also when setting an alternate stack using sigaltstack() with the flag SS_DISABLE, the kernel try to install the alternate stack on signal delivery. These two use cases makes the process crash at signal delivery. This fixes it. Signed-off-by: Laurent Meyer <meyerlau@fr.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-17[PATCH] powerpc: iSeries needs slb_initialize to be calledStephen Rothwell
Since the powerpc 64k pages patch went in, systems that have SLBs (like Power4 iSeries) needed to have slb_initialize called to set up some variables for the SLB miss handler. This was not being called on the boot processor on iSeries, so on single cpu iSeries machines, we would get apparent memory curruption as soon as we entered user mode. This patch fixes that by calling slb_initialize on the boot cpu if the processor has an SLB. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-12Linux 2.6.16.5v2.6.16.5Greg Kroah-Hartman
2006-04-12[PATCH] x86_64: When user could have changed RIP always force IRET ↵Andi Kleen
(CVE-2006-0744) Intel EM64T CPUs handle uncanonical return addresses differently from AMD CPUs. The exception is reported in the SYSRET, not the next instruction. Thgis leads to the kernel exception handler running on the user stack with the wrong GS because the kernel didn't expect exceptions on this instruction. This version of the patch has the teething problems that plagued an earlier version fixed. This is CVE-2006-0744 Thanks to Ernie Petrides and Asit B. Mallick for analysis and initial patches. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-12[PATCH] x86_64: Clean up execveAndi Kleen
Just call IRET always, no need for any special cases. Needed for the next bug fix. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-11Linux 2.6.16.4v2.6.16.4Greg Kroah-Hartman
2006-04-11[PATCH] RCU signal handlingOleg Nesterov
made this BUG_ON() unsafe. This code runs under ->siglock, while switch_exec_pids() takes tasklist_lock. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-10Linux 2.6.16.3v2.6.16.3Greg Kroah-Hartman
2006-04-10[PATCH] Keys: Fix oops when adding key to non-keyring [CVE-2006-1522]David Howells
This fixes the problem of an oops occuring when a user attempts to add a key to a non-keyring key [CVE-2006-1522]. The problem is that __keyring_search_one() doesn't check that the keyring it's been given is actually a keyring. I've fixed this problem by: (1) declaring that caller of __keyring_search_one() must guarantee that the keyring is a keyring; and (2) making key_create_or_update() check that the keyring is a keyring, and return -ENOTDIR if it isn't. This can be tested by: keyctl add user b b `keyctl add user a a @s` Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07Linux 2.6.16.2v2.6.16.2Greg Kroah-Hartman
2006-04-07[PATCH] kdump proc vmcore size oveflow fixVivek Goyal
A couple of /proc/vmcore data structures overflow with 32bit systems having memory more than 4G. This patch fixes those. Signed-off-by: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] knfsd: Correct reserved reply space for read requests.NeilBrown
NFSd makes sure there is enough space to hold the maximum possible reply before accepting a request. The units for this maximum is (4byte) words. However in three places, particularly for read request, the number given is a number of bytes. This means too much space is reserved which is slightly wasteful. This is the sort of patch that could uncover a deeper bug, and it is not critical, so it would be best for it to spend a while in -mm before going in to mainline. (akpm: target 2.6.17-rc2, 2.6.16.3 (approx)) Discovered-by: "Eivind Sarto" <ivan@kasenna.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] hostap: Fix EAPOL frame encryptionJouni Malinen
Fixed encrypted of EAPOL frames from wlan#ap interface (hostapd). This was broken when moving to use new frame control field defines in net/ieee80211.h. hostapd uses Protected flag, not protocol version (which was cleared in this function anyway). This fixes WPA group key handshake and re-authentication. http://hostap.epitest.fi/bugz/show_bug.cgi?id=126 Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi>
2006-04-07[PATCH] Add default entry for CTL Travel Master U553WTakashi Iwai
Added the default entry of ALC880 configuration table for CTL Travel Master U553W. This patch was already included in Linus' tree. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] AIRO{,_CS} <-> CRYPTO fixesAdrian Bunk
CRYPTO is a helper variable, and to make it easier for users, it should therefore select'ed and not be listed in the dependencies. drivers/net/wireless/airo.c requires CONFIG_CRYPTO for compilations. Therefore, AIRO_CS also has to select CRYPTO. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] Fix NULL pointer dereference in node_read_numastat()Christoph Lameter
Fix NULL pointer dereference in node_read_numastat() zone_pcp() only returns valid values if the processor is online. Change node_read_numastat() to only scan online processors. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] drivers/net/wireless/ipw2200.c: fix an array overunAdrian Bunk
This patch fixes a big array overun found by the Coverity checker. This was already fixed in Linus' tree. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] fbcon: Fix big-endian bogosity in slow_imageblit()Antonino A. Daplas
The monochrome->color expansion routine that handles bitmaps which have (widths % 8) != 0 (slow_imageblit) produces corrupt characters in big-endian. This is caused by a bogus bit test in slow_imageblit(). Fix. Signed-off-by: Antonino Daplas <adaplas@pol.net> Acked-by: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] fib_trie.c node freeing fixDavid S. Miller
Please apply to 2.6.{14,15,16} -stable, thanks a lot. From: Robert Olsson <robert.olsson@its.uu.se> [FIB_TRIE]: Fix leaf freeing. Seems like leaf (end-nodes) has been freed by __tnode_free_rcu and not by __leaf_free_rcu. This fixes the problem. Only tnode_free is now used which checks for appropriate node type. free_leaf can be removed. Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] Fix module refcount leak in __set_personality()Sergey Vlasov
If the change of personality does not lead to change of exec domain, __set_personality() returned without releasing the module reference acquired by lookup_exec_domain(). This patch was already included in Linus' tree. Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] Fix the p4-clockmod N60 errata workaround.Venkatesh Pallipadi
[CPUFREQ] Fix the p4-clockmod N60 errata workaround. Fix the code to disable freqs less than 2GHz in N60 errata. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] wrong error path in dup_fd() leading to oopses in RCUKirill Korotaev
Wrong error path in dup_fd() - it should return NULL on error, not an address of already freed memory :/ Triggered by OpenVZ stress test suite. What is interesting is that it was causing different oopses in RCU like below: Call Trace: [<c013492c>] rcu_do_batch+0x2c/0x80 [<c0134bdd>] rcu_process_callbacks+0x3d/0x70 [<c0126cf3>] tasklet_action+0x73/0xe0 [<c01269aa>] __do_softirq+0x10a/0x130 [<c01058ff>] do_softirq+0x4f/0x60 ======================= [<c0113817>] smp_apic_timer_interrupt+0x77/0x110 [<c0103b54>] apic_timer_interrupt+0x1c/0x24 Code: Bad EIP value. <0>Kernel panic - not syncing: Fatal exception in interrupt Signed-Off-By: Pavel Emelianov <xemul@sw.ru> Signed-Off-By: Dmitry Mishin <dim@openvz.org> Signed-Off-By: Kirill Korotaev <dev@openvz.org> Signed-Off-By: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] {ip, nf}_conntrack_netlink: fix expectation notifier unregistrationMartin Josefsson
[NETFILTER]: {ip,nf}_conntrack_netlink: fix expectation notifier unregistration This patch fixes expectation notifier unregistration on module unload to use ip_conntrack_expect_unregister_notifier(). This bug causes a soft lockup at the first expectation created after a rmmod ; insmod of this module. Should go into -stable as well. Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] isicom must select FW_LOADERmaximilian attems
The isicom driver uses request_firmware() and thus needs to select FW_LOADER. This patch was already included in Linus' tree. Signed-off-by: maximilian attems <maks@sternwelten.at> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] Mark longhaul driver as broken.Dave Jones
[CPUFREQ] Mark longhaul driver as broken. This seems to work for a short period of time, but when used in conjunction with a userspace governor that changes the frequency regularly, it's only a matter of time before everything just locks up. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] opti9x - Fix compile without CONFIG_PNPTakashi Iwai
Modules: Opti9xx drivers Fix compile errors without CONFIG_PNP. This patch was already included in Linus' tree. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
