(CVE-2006-0744)
Intel EM64T CPUs handle uncanonical return addresses differently from
AMD CPUs.
The exception is reported in the SYSRET, not the next instruction.
Thgis leads to the kernel exception handler running on the user stack
with the wrong GS because the kernel didn't expect exceptions on this
instruction.
This version of the patch has the teething problems that plagued an
earlier version fixed.
This is CVE-2006-0744
Thanks to Ernie Petrides and Asit B. Mallick for analysis and initial
patches.
Signed-off-by: Andi Kleen <ak@suse.de>
Just call IRET always, no need for any special cases.
Needed for the next bug fix.
made this BUG_ON() unsafe. This code runs under ->siglock,
while switch_exec_pids() takes tasklist_lock.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
This fixes the problem of an oops occuring when a user attempts to add a
key to a non-keyring key [CVE-2006-1522].
The problem is that __keyring_search_one() doesn't check that the
keyring it's been given is actually a keyring.
I've fixed this problem by:
(1) declaring that caller of __keyring_search_one() must guarantee that
the keyring is a keyring; and
(2) making key_create_or_update() check that the keyring is a keyring,
and return -ENOTDIR if it isn't.
This can be tested by:
keyctl add user b b `keyctl add user a a @s`
A couple of /proc/vmcore data structures overflow with 32bit systems having
memory more than 4G. This patch fixes those.
Signed-off-by: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp>
Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com>
NFSd makes sure there is enough space to hold the maximum possible reply
before accepting a request. The units for this maximum is (4byte) words.
However in three places, particularly for read request, the number given is
a number of bytes.
This means too much space is reserved which is slightly wasteful.
This is the sort of patch that could uncover a deeper bug, and it is not
critical, so it would be best for it to spend a while in -mm before going
in to mainline.
(akpm: target 2.6.17-rc2, 2.6.16.3 (approx))
Discovered-by: "Eivind Sarto" <ivan@kasenna.com>
Signed-off-by: Neil Brown <neilb@suse.de>
Fixed encrypted of EAPOL frames from wlan#ap interface (hostapd). This
was broken when moving to use new frame control field defines in
net/ieee80211.h. hostapd uses Protected flag, not protocol version
(which was cleared in this function anyway). This fixes WPA group key
handshake and re-authentication.
http://hostap.epitest.fi/bugz/show_bug.cgi?id=126
Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi>
Added the default entry of ALC880 configuration table for
CTL Travel Master U553W.
This patch was already included in Linus' tree.
CRYPTO is a helper variable, and to make it easier for users, it should
therefore select'ed and not be listed in the dependencies.
drivers/net/wireless/airo.c requires CONFIG_CRYPTO for compilations.
Therefore, AIRO_CS also has to select CRYPTO.
Fix NULL pointer dereference in node_read_numastat()
zone_pcp() only returns valid values if the processor is online.
Change node_read_numastat() to only scan online processors.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
This patch fixes a big array overun found by the Coverity checker.
This was already fixed in Linus' tree.
The monochrome->color expansion routine that handles bitmaps which have
(widths % 8) != 0 (slow_imageblit) produces corrupt characters in big-endian.
This is caused by a bogus bit test in slow_imageblit().
Fix.
Signed-off-by: Antonino Daplas <adaplas@pol.net>
Acked-by: Herbert Poetzl <herbert@13thfloor.at>
Please apply to 2.6.{14,15,16} -stable, thanks a lot.
[FIB_TRIE]: Fix leaf freeing.
Seems like leaf (end-nodes) has been freed by __tnode_free_rcu and not
by __leaf_free_rcu. This fixes the problem. Only tnode_free is now
used which checks for appropriate node type. free_leaf can be removed.
Signed-off-by: Robert Olsson <robert.olsson@its.uu.se>
If the change of personality does not lead to change of exec domain,
__set_personality() returned without releasing the module reference
acquired by lookup_exec_domain().
Signed-off-by: Sergey Vlasov <vsu@altlinux.ru>
[CPUFREQ] Fix the p4-clockmod N60 errata workaround.
Fix the code to disable freqs less than 2GHz in N60 errata.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Dave Jones <davej@redhat.com>
Wrong error path in dup_fd() - it should return NULL on error,
not an address of already freed memory :/
Triggered by OpenVZ stress test suite.
What is interesting is that it was causing different oopses in RCU like
below:
Call Trace:
[<c013492c>] rcu_do_batch+0x2c/0x80
[<c0134bdd>] rcu_process_callbacks+0x3d/0x70
[<c0126cf3>] tasklet_action+0x73/0xe0
[<c01269aa>] __do_softirq+0x10a/0x130
[<c01058ff>] do_softirq+0x4f/0x60
[<c0113817>] smp_apic_timer_interrupt+0x77/0x110
[<c0103b54>] apic_timer_interrupt+0x1c/0x24
Code: Bad EIP value.
<0>Kernel panic - not syncing: Fatal exception in interrupt
Signed-Off-By: Pavel Emelianov <xemul@sw.ru>
Signed-Off-By: Dmitry Mishin <dim@openvz.org>
Signed-Off-By: Kirill Korotaev <dev@openvz.org>
Signed-Off-By: Linus Torvalds <torvalds@osdl.org>
[NETFILTER]: {ip,nf}_conntrack_netlink: fix expectation notifier unregistration
This patch fixes expectation notifier unregistration on module unload to
use ip_conntrack_expect_unregister_notifier(). This bug causes a soft
lockup at the first expectation created after a rmmod ; insmod of this
module.
Should go into -stable as well.
Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se>
The isicom driver uses request_firmware()
and thus needs to select FW_LOADER.
Signed-off-by: maximilian attems <maks@sternwelten.at>
[CPUFREQ] Mark longhaul driver as broken.
This seems to work for a short period of time, but when
used in conjunction with a userspace governor that changes
the frequency regularly, it's only a matter of time before
everything just locks up.
Modules: Opti9xx drivers
Fix compile errors without CONFIG_PNP.
For some time, the core pcmcia drivers seem not to think single
character prod_ids are valid, thus preventing the "cleverly" named
"D" "Link DWL-650 11Mbps WLAN Card"
Before (as in 2.6.16):
PRODID_1=""
PRODID_2="Link DWL-650 11Mbps WLAN Card"
PRODID_3="Version 01.02"
PRODID_4=""
MANFID=0156,0002
FUNCID=6
After (with the patch)
PRODID_1="D"
PRODID_4=""
MANFID=0156,0002
FUNCID=6
Signed-off-by: Janos Farkas <chexum@gmail.com>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
PCMCIA_SPECTRUM must select FW_LOADER.
Reported by "Alexander E. Patrakov" <patrakov@ums.usu.ru>.
We used to assume that a DMA mapping request with a NULL dev was for
ISA DMA. This assumption was broken at some point. Now we explicitly
pass the detected ISA PCI device in the floppy setup.
sbp2util_mark_command_completed takes a lock which was already taken by
sbp2scsi_complete_all_commands. This is a regression in Linux 2.6.15.
Reported by Kristian Harms at
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=187394
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
When trying to deconfigure a device via usb_set_configuration(dev, 0),
2.6.16-rc kernels after 55c527187c9d78f840b284d596a0b298bc1493af oops
with "Unable to handle NULL pointer dereference at...". This is due to
an unchecked dereference of cp in the power budget part.
Signed-off-by: Horst Schirmeier <horst@schirmeier.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
This patch replaces the split ISO raw_mask calculation code in the
iso_stream_init() function that computed incorrect numbers of high
speed transactions for both input and output transfers.
In the output case, it added a superfluous start-split transaction for
all maxmimum packet sizes that are a multiple of 188.
In the input case, it forgot to add complete-split transactions for all
microframes covered by the full speed transaction, and the additional
complete-split transaction needed for the case when full speed data
starts arriving near the end of a microframe.
These changes don't affect the lack of full speed bandwidth, but at
least it removes the MMF errors that the HC raised with some input
streams.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
No one should be writing a PAGE_SIZE worth of data to a normal sysfs
file, so properly terminate the buffer.
Thanks to Al Viro for pointing out my stupidity here.
CVE-2006-1055 has been assigned for this.
Don't read from free'd memory after calling netif_rx(). docopy is used as
a boolean (0 and 1) so unsigned int is sufficient.
Coverity bug #928
Signed-off-by: Eugene Teo <eugene.teo@eugeneteo.net>
tlclk calls register_chrdev() and permits register_chrdev() to allocate the
major, but it promptly forgets what that major was. So if there's no hardware
present you still get "telco_clock" appearing in /proc/devices and, I assume,
an oops reading /proc/devices if tlclk was a module.
Fix.
Mark, I'd suggest that that we not call register_chrdev() until _after_ we've
established that the hardware is present.
Cc: Mark Gross <mgross@linux.intel.com>
Fix bug identified by Linus Torvalds <torvalds@osdl.org>: the `out'
instruction depends upon the state of memory_data[], so we need to tell gcc
that before executing it. (The opcode, not gcc).
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=5553
Thanks to Antonio Ospite <ospite@studenti.unina.it> for testing.
Cc: Dave Jones <davej@codemonkey.org.uk>
Attached patch fixes invalid pointer arithmetic in DMI code to make onboard
device discovery working again.
akpm: bug has been present since dmi_find_device() was added in 2.6.14.
Affects ipmi only (I think) - the symptoms weren't described.
akpm: changed to use pointer arithmetic rather than open-coded sizeof.
Signed-off-by: Andrey Panin <pazke@donpac.ru>
Cc: Corey Minyard <minyard@acm.org>
free_hba() sets hba[i] to NULL, the dereference afterwards results in this
crash. Setting busy_initializing to 0 actually looks unnecessary, but I'm
not entirely sure, which is why I left it in.
cciss: controller appears to be disabled
Unable to handle kernel NULL pointer dereference at virtual address 00000370
printing eip:
c1114d53
*pde = 00000000
Oops: 0002 [#1]
Modules linked in:
CPU: 0
EIP: 0060:[<c1114d53>] Not tainted VLI
EFLAGS: 00010286 (2.6.16 #1)
EIP is at cciss_init_one+0x4e9/0x4fe
eax: 00000000 ebx: c132cd60 ecx: c13154e4 edx: c27d3c00
esi: 00000000 edi: c2748800 ebp: c2536ee4 esp: c2536eb8
ds: 007b es: 007b ss: 0068
Process swapper (pid: 1, threadinfo=c2536000 task=c2535a30)
Stack: <0>00000000 00000000 00000000 c13fdba0 c2536ee8 c13159c0 c2536f38
f7c74740
c132cd60 c132cd60 ffffffed c2536ef0 c10c1d51 c2748800 c2536f04
c10c1d85
c132cd60 c2748800 c132cd8c c2536f14 c10c1db8 c2748848 00000000
c2536f28
Call Trace:
[<c10031d5>] show_stack_log_lvl+0xa8/0xb0
[<c1003305>] show_registers+0x102/0x16a
[<c10034a2>] die+0xc1/0x13c
[<c1288160>] do_page_fault+0x38a/0x525
[<c1002e9b>] error_code+0x4f/0x54
[<c10c1d51>] pci_call_probe+0xd/0x10
[<c10c1d85>] __pci_device_probe+0x31/0x43
[<c10c1db8>] pci_device_probe+0x21/0x34
[<c110a654>] driver_probe_device+0x44/0x99
[<c110a73f>] __driver_attach+0x39/0x5d
[<c1109e1c>] bus_for_each_dev+0x35/0x5a
[<c110a777>] driver_attach+0x14/0x16
[<c110a220>] bus_add_driver+0x5c/0x8f
[<c110ab22>] driver_register+0x73/0x78
[<c10c1f6d>] __pci_register_driver+0x5f/0x71
[<c13bf935>] cciss_init+0x1a/0x1c
[<c13aa718>] do_initcalls+0x4c/0x96
[<c13aa77e>] do_basic_setup+0x1c/0x1e
[<c10002b1>] init+0x35/0x118
[<c1000cf5>] kernel_thread_helper+0x5/0xb
Code: 04 b5 e0 de 40 c1 8d 50 04 8b 40 34 e8 3f b7 f9 ff 8b 04 b5 e0 de
40 c1 e8 aa f3 ff ff 89 f0 e8 e8 fa ff ff 8b 04 b5 e0 de 40 c1 <c7> 80
70 03 00 00 00 00 00 00 83 c8 ff 8d 65 f4 5b 5e 5f 5d c3
<0>Kernel panic - not syncing: Attempted to kill init!
Cc: <mike.miller@hp.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Both R1BIO_Barrier and R1BIO_Returned are 4 !!!!
This means that barrier requests don't get returned (i.e. b_endio called)
because it looks like they already have been.
We have noticed lockups during boot when stress testing kexec on ppc64.
Two cpus would deadlock in scheduler code trying to grab already taken
spinlocks.
The double_rq_lock code uses the address of the runqueue to order the
taking of multiple locks. This address is a per cpu variable:
if (rq1 < rq2) {
spin_lock(&rq1->lock);
spin_lock(&rq2->lock);
} else {
On the other hand, the code in wake_sleeping_dependent uses the cpu id
order to grab locks:
for_each_cpu_mask(i, sibling_map)
spin_lock(&cpu_rq(i)->lock);
This means we rely on the address of per cpu data increasing as cpu ids
increase. While this will be true for the generic percpu implementation it
may not be true for arch specific implementations.
One way to solve this is to always take runqueues in cpu id order. To do
this we add a cpu variable to the runqueue and check it in the
double runqueue locking functions.
Fix a duplicate block device line printed after the "Block device" header
in /proc/devices.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Git patch 52dfa9a64cfb3dd01fa1ee1150d589481e54e28e
[PATCH] move rtc_interrupt() prototype to rtc.h
broke strace(1) builds. The below moves the kernel-only additions lower,
under the already provided #ifdef __KERNEL__ statement.
The code that handles bios that span table target boundaries by breaking
them up into smaller bios will not split an individual struct bio_vec into
more than two pieces. Sometimes more than that are required.
This patch adds a loop to break the second piece up into as many pieces as
are necessary.
Cc: "Abhishek Gupta" <abhishekgupt@gmail.com>
Cc: Dan Smith <danms@us.ibm.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
If a file is not found in v9fs_vfs_lookup, the function creates negative
dentry, but doesn't assign any dentry ops. This leaves the negative entry
in the cache (there is no d_delete to mark it for removal). If the file is
created outside of the mounted v9fs filesystem, the file shows up in the
directory with weird permissions.
This patch assigns the default v9fs dentry ops to the negative dentry.
Signed-off-by: Latchesar Ionkov <lucho@ionkov.net>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
The console cursor can be called in atomic context. Change memory
allocation to use the GFP_ATOMIC flag in i810fb_cursor().
The user can pass us arbitrary garbage so we should ensure the
string they give us is null terminated before we pass it on
to dev_get_by_index() et al.
Found by Solar Designer.
[XFS] Check that a page has dirty buffers before finding it acceptable for
rewrite clustering. This prevents writing excessive amounts of clean data
when doing random rewrites of a cached file.
Signed-off-by: David Chinner <dgc@sgi.com>
Signed-off-by: Nathan Scott <nathans@sgi.com>
As pointed out by Oliver Neukum.
Cc: Maneesh Soni <maneesh@in.ibm.com>
Cc: Oliver Neukum <oliver@neukum.org>
Doing (int < NR_CPUS) doesn't dtrt if it's negative..
The fw_realloc_buffer routine does not handle an increase in buffer size of
more than 4k. It's not clear to me why it expects that it will only get an
extra 4k of data. The attached patch modifies fw_realloc_buffer to vmalloc
as much memory as is requested, instead of what we previously had + 4k.
I've tested this on my laptop, which would crash occaisionally on boot
without the patch. With the patch, it hasn't crashed, but I can't be
certain that this code path is exercised.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
When calling sysfs_remove_dir() don't allow any further sysfs functions
to work for this kobject anymore. This fixes a nasty USB cdc-acm oops
on disconnect.
Many thanks to Bob Copeland and Paul Fulghum for taking the time to
track this down.
Cc: Bob Copeland <email@bobcopeland.com>
Cc: Paul Fulghum <paulkf@microgate.com>
