Remove obsoleted kfree_nochec() (for debug).
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Fix missing makefile entries for echoaudio drivers
Fixed a typo in echoaudio/midi.c.
Add echoaudio sound drivers (darla20, darla24, echo3g, gina20, gina24,
indigo, indigodj, indigoio, layla20, lala24, mia, mona)
Fixes Samba bugzilla bug # 4182
Rename by handle failures (retry after rename by path) were not
being returned back.
Signed-off-by: Steve French <sfrench@us.ibm.com>
It is possible for i2c_add_adapter() to fail. Several I2C algorithm
drivers ignore that fact. This (compile-tested only) patch fixes them.
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
The IGMPV3_EXP() macro doesn't correctly shift the normalization bit, so
time-out values are longer than they should be.
Thanks to Dirk Ooms for finding the problem in IGMPv3 - MLDv2 had a
similar problem that was already fixed a year ago. :-(
Signed-off-by: David L Stevens <dlstevens@us.ibm.com>
This patch (as657) increases the port-reset completion delay in uhci-hcd
for HP's embedded controllers. Unlike other UHCI controllers, the HP
chips can take as long as 250 us to carry out the processing associated
with finishing a port reset.
This fixes Novell bug #148761.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
The hptiop just got merged with a horrible amount of really bad ioctl
code that is against the standards for new scsi drivers. This patch
backs it out (and fixes a small bug where scsi_add_host is called to
early). We can re-add proper APIs once we agree on them.
IOP reset message should be posted to inbound message register
instead of outbound message register.
Signed-off-by: HighPoint Linux Team <linux@highpoint-tech.com>
use cmnd->request_bufflen instead.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Updates:
- don't bypass SYNCHRONIZE_CACHE command
- return SCSI_MLQUEUE_HOST_BUSY when no free request slots
- move scsi_remove_host() to the begin of hpt_remove(), or it will
not work after resources being released.
HighPoint RocketRAID 3220/3320 series 8 channel PCI-X SATA RAID Host
Adapters.
Fixes from original submission:
Merge Andrew Morton's patches:
- Provide locking for global list
- Fix debug printks
- uninline function with multiple callsites
- coding style fixups
- remove unneeded casts of void*
- kfree(NULL) is legal
- Don't "succeed" if register_chrdev() failed - otherwise we'll later
unregister a not-registered chrdev.
- Don't return from hptiop_do_ioctl() with the spinlock held.
- uninline __hpt_do_ioctl()
Update for Arjan van de Ven's comments:
- put all asm/ includes after the linux/ ones
- replace mdelay with msleep
- add pci posting flush
- do not set pci command reqister in map_pci_bar
- do not try merging sg elements in hptiop_buildsgl()
- remove unused outstandingcommands member from hba structure
- remove unimplemented hptiop_abort() handler
- remove typedef u32 hpt_id_t
Other updates:
- fix endianess
Following function can drops d_count twice against one reference
by lookup_one_len.
<SOURCE>
* sysfs_update_file - update the modified timestamp on an object attribute.
* @kobj: object we're acting for.
* @attr: attribute descriptor.
int sysfs_update_file(struct kobject * kobj, const struct attribute * attr)
struct dentry * dir = kobj->dentry;
struct dentry * victim;
int res = -ENOENT;
mutex_lock(&dir->d_inode->i_mutex);
victim = lookup_one_len(attr->name, dir, strlen(attr->name));
if (!IS_ERR(victim)) {
/* make sure dentry is really there */
if (victim->d_inode &&
(victim->d_parent->d_inode == dir->d_inode)) {
victim->d_inode->i_mtime = CURRENT_TIME;
fsnotify_modify(victim);
* Drop reference from initial sysfs_get_dentry().
dput(victim);
res = 0;
} else
d_drop(victim);
* Drop the reference acquired from sysfs_get_dentry() above.
dput(victim);
mutex_unlock(&dir->d_inode->i_mutex);
return res;
</SOURCE>
PCI-hotplug (drivers/pci/hotplug/pci_hotplug_core.c) is only user of
this function. I confirmed that dentry of /sys/bus/pci/slots/XXX/*
have negative d_count value.
This patch removes unnecessary dput().
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
sys_getppid() optimization can access a freed memory. On kernels with
DEBUG_SLAB turned ON, this results in Oops. As Dave Hansen noted, this
optimization is also unsafe for memory hotplug.
So this patch always takes the lock to be safe.
Signed-off-by: Kirill Korotaev <dev@openvz.org>
Calculation of IPX checksum got buggered about 2.4.0. The old variant
mangled the packet; that got fixed, but calculation itself got buggered.
Restored the correct logics, fixed a subtle breakage we used to have even
back then: if the sum is 0 mod 0xffff, we want to return 0, not 0xffff.
The latter has special meaning for IPX (cheksum disabled). Observation
(and obvious fix) nicked from history of FreeBSD ipx_cksum.c...
Noticed by Dave Jones.
Need to check some more cases in IPX receive. If the skb is purely
fragments, the IPX header needs to be extracted. The function
pskb_may_pull() may in theory invalidate all the pointers in the skb,
so references to ipx header must be refreshed.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
This patch will linearize and check there is enough data.
It handles the pprop case as well as avoiding a whole audit of
the routing code.
Casting BE16 to int and back may or may not work. Correct, to be sure.
Fix recent i2c-ixp4xx compilation breakage. Sorry for overlooking it.
Remove a lot of duplicate #defines from the advansys driver,
and make them look like PCI IDs as defined elsewhere in the kernel.
Also add a module table so that it automatically gets picked up
by tools relying on modinfo output (like say, distro installers).
Signed-off-by: Dave Jones <davej@redhat.com>
Priority: not critical.
Mark 3 functions __init. Saves a little memory.
This makes these functions' calls to AdvWaitEEPCmd() (which is __init)
be clean (i.e., eliminates text -> init -> text call chain).
Fix multiple section mismatch warnings:
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet3550EEPConfig' (at offset 0x7a22) and 'AdvSet38C0800EEPConfig'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet3550EEPConfig' (at offset 0x7a4e) and 'AdvSet38C0800EEPConfig'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet3550EEPConfig' (at offset 0x7a79) and 'AdvSet38C0800EEPConfig'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet3550EEPConfig' (at offset 0x7aa2) and 'AdvSet38C0800EEPConfig'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet3550EEPConfig' (at offset 0x7abb) and 'AdvSet38C0800EEPConfig'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C0800EEPConfig' (at offset 0x7ae0) and 'AdvSet38C1600EEPConfig'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C0800EEPConfig' (at offset 0x7b0c) and 'AdvSet38C1600EEPConfig'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C0800EEPConfig' (at offset 0x7b37) and 'AdvSet38C1600EEPConfig'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C0800EEPConfig' (at offset 0x7b60) and 'AdvSet38C1600EEPConfig'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C0800EEPConfig' (at offset 0x7b79) and 'AdvSet38C1600EEPConfig'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C1600EEPConfig' (at offset 0x7b9e) and 'AdvExeScsiQueue'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C1600EEPConfig' (at offset 0x7bca) and 'AdvExeScsiQueue'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C1600EEPConfig' (at offset 0x7bf5) and 'AdvExeScsiQueue'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C1600EEPConfig' (at offset 0x7c1e) and 'AdvExeScsiQueue'
WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C1600EEPConfig' (at offset 0x7c37) and 'AdvExeScsiQueue'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Let people enable the advansys driver on x86-32, even though it's broken
on other architectures due to missing DMA mapping infrastructure.
It's used by Jeffrey Phillips Freeman <jeffreyfreeman@syncleus.com> and
possibly others.
i2c_bit_add_bus() returns -E;
-E != 0 => err = 1
probe fails with positive error code
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
The alignment exception used to only check the exception table for
-EFAULT, not for other errors. That opens an oops window if we can
coerce the kernel into getting an alignment exception for other reasons
in what would normally be a user-protected accessor, which can be done
via some of the futex ops. This fixes it by always checking the
exception tables.
This patch adds support for a new PHY to the sis900 driver.
See also Bugzilla 6919.
Signed-off-by: Daniele Venzano <venza@brownhat.org>
this patch is required to get a SIS964 based motherboard ethernet working
(FSC D1875) (picking the #1 transceiver, instead of the last one, in case
no known ones were found might be a better default, and would have worked
in this case too)
Signed-off-by: Artur Skawina <art_k@o2.pl>
This patch is identical to that introduced in
1a1276e7b6cba549553285f74e87f702bfff6fac to the Linus' 2.6 development tree
by Alan Cox.
'This is based on the proposed patches flying around but also checks that
the device in question is new enough to have word 93 rather thanb blindly
assuming word 93 == 0 means SATA (see ATA-5, ATA-7)' -- Alan Cox
Required for my SATA drive on an Asus Pundit-R to operate above 33MBps.
Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk>
In bugzilla #6941, Jens Kilian reported:
"The function befs_utf2nls (in fs/befs/linuxvfs.c) writes a 0 byte past the
end of a block of memory allocated via kmalloc(), leading to memory
corruption. This happens only for filenames which are pure ASCII and a
multiple of 4 bytes in length. [...]
Without DEBUG_SLAB, this leads to further corruption and hard lockups; I
believe this is the bug which has made kernels later than 2.6.8 unusable
for me. (This must be due to changes in memory management, the bug has
been in the BeFS driver since the time it was introduced (AFAICT).)
Steps to reproduce:
Create a directory (in BeOS, naturally :-) with files named, e.g.,
"1", "22", "333", "4444", ... Mount it in Linux and do an "ls" or "find""
This patch implements the suggested fix. Credits to Jens Kilian for
debugging the problem and finding the right fix.
Signed-off-by: Diego Calleja <diegocg@gmail.com>
Two different exports with the same name are not a good idea:
$ grep -r EXPORT_SYMBOL\(dmasound_init\) *
drivers/media/video/saa7134/saa7134-core.c:EXPORT_SYMBOL(dmasound_init);
sound/oss/dmasound/dmasound_core.c:EXPORT_SYMBOL(dmasound_init);
This patch renames the saa7134 dmasound_{init,exit} to
saa7134_dmasound_{init,exit}.
The ->set_mac_address handlers expect a pointer to a
sockaddr which contains the MAC address, whereas
IFLA_ADDRESS provides just the MAC address itself.
So whip up a sockaddr to wrap around the netlink
attribute for the ->set_mac_address call.
This patch fixes an array overrun spotted by the Coverity checker.
Use proper upper limits for the loops and check for all error
conditions.
The problem was noticed by Adrian Bunk.
Signed-off-by: Michael Chan <mchan@broadcom.com>
We've confirmed that the debug version of write_lock() can get stuck for long
enough to cause NMI watchdog timeouts and hence a crash.
We don't know why, yet. Disable it for now.
Also disable the similar read_lock() code. Just in case.
Thanks to Dave Olson <olson@unixfolk.com> for reporting and testing.
Replace add_timer() by mod_timer() in dst_run_gc
in order to avoid BUG message.
CPU1 CPU2
dst_run_gc() entered dst_run_gc() entered
spin_lock(&dst_lock) .....
del_timer(&dst_gc_timer) fail to get lock
.... mod_timer() <--- puts
timer back
to the list
add_timer(&dst_gc_timer) <--- BUG because timer is in list already.
Found during OpenVZ internal testing.
At first we thought that it is OpenVZ specific as we
added dst_run_gc(0) call in dst_dev_event(),
but as Alexey pointed to me it is possible to trigger
this condition in mainstream kernel.
F.e. timer has fired on CPU2, but the handler was preeempted
by an irq before dst_lock is tried.
Meanwhile, someone on CPU1 adds an entry to gc list and
starts the timer.
If CPU2 was preempted long enough, this timer can expire
simultaneously with resuming timer handler on CPU1, arriving
exactly to the situation described.
Signed-off-by: Dmitry Mishin <dim@openvz.org>
For files other than IFREG, nobh option doesn't make sense. Modifications
to them are journalled and needs buffer heads to do that. Without this
patch, we get kernel oops in page_buffers().
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
initlvl=2 in seclvl gives the guarantee
"Cannot decrement the system time".
But it was possible to set the time to the maximum unixtime value
(19 Jan 2038) resulting in a wrap to the minimum value.
This patch fixes this by disallowing setting the time to any date
after 2030 with initlvl=2.
Fix receive tty error handling in synclink_gt driver.
Adrian reported compiler warning for incorrect bit test
against char variable. I determined these and other
device specific error bits were incorrectly defined.
Signed-off-by: Paul Fulghum <paulkf@microgate.com>
fix interrput routing for via 586 bridges. pirq can be 5 which needs to be
mapped to INTD. but currently the access functions can handle only pirq 1-4.
this is similar to the other via chipsets where pirq 4 and 5 are both mapped
to INTD. fixes bugzilla #7490
Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch>
This patch adds support for the Promise FastTrak TX4300/TX4310 4-port PCI SATA
controllers based on the PDC40719 chip.
Signed-off-by: Daniel Drake <dsd@gentoo.org>
As detailed at http://bugs.gentoo.org/131534 :
2.6.16 converted many ACPI debug messages into error or warning
messages. One extraneous message was incorrectly converted, resulting in
logs being flooded by "Handle is NULL and Pathname is relative" messages
on some systems.
This patch (part of a larger ACPICA commit) converts the message back to
debug level.
