2006-10-17Linux 2.6.16.30-rc1v2.6.16.30-rc1Adrian Bunk
2006-10-17[IA64] correct file descriptor reference counting in perfmon (CVE-2006-3741)Stephane Eranian
Fix a bug in sys_perfmonctl() whereby it was not correctly decrementing the file descriptor reference count. Signed-off-by: Stephane Eranian <eranian@hpl.hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-14[PPPOE]: Advertise PPPoE MTUMichal Ostrowski
PPPoE must advertise the underlying device's MTU via the ppp channel descriptor structure, as multilink functionality depends on it. Signed-off-by: Michal Ostrowski <mostrows@earthlink.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-14PKT_SCHED: cls_basic: Use unsigned int when generating handleKim Nordlund
Prevents filters from being added if the first generated handle already exists. Signed-off-by: Kim Nordlund <kim.nordlund@nokia.com> Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-14[SPARC64]: Kill bogus check from bootmem_init().David S. Miller
There is an ancient and totally incorrect sanity check being done on the ramdisk location. The check assumes that the kernel is always loaded to physical address zero, which is wrong. It was trying to validate the ramdisk value by saying that if it fell within the kernel image address range it must be wrong. Anyways, kill this because it actually creates problems. The 'ramdisk_image' should always be adjusted down by KERNBASE. SILO can easily put the ramdisk in a location which causes this test to trigger, breaking things. [ Based almost entirely upon a patch from Ben Collins. ] Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-14[SPARC64]: Fix sched_clock() wrapping every ~17 seconds.David S. Miller
Unfortunately, sparc64 doesn't have an easy way to do a "64 X 64 --> 128" bit multiply like PowerPC and IA64 do. We were doing a "64 X 64 --> 64" bit multiple which causes overflow very quickly with a 30-bit quotient shift. So use a quotientshift count of 10 instead of 30, just like x86 and ARM do. This also fixes the wrapping of printk timestamp values every ~17 seconds. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-14[CIFS] Allow cifsd to suspend if connection is lostRafael J. Wysocki
Make cifsd allow us to suspend if it has lost the connection with a server Ref: http://bugzilla.kernel.org/show_bug.cgi?id=6811 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-14[CIFS] Fix typo in earlier cifs_unlink change and protect one extra path.Steve French
Since cifs_unlink can also be called from rename path and there was one report of oops am making the extra check for null inode. Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-14[CIFS] Fix unlink oops when indirectly called in rename error path under ↵Steve French
heavy stress. Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-14[CIFS] fs/cifs/dir.c: fix possible NULL dereferenceSteve French
2006-10-14[ATM] CLIP: Do not refer freed skbuff in clip_mkip() (CVE-2006-4997)YOSHIFUJI Hideaki
In clip_mkip(), skb->dev is dereferenced after clip_push(), which frees up skb. Advisory: AD_LAB-06009 (<adlab@venustech.com.cn>). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-13fbdev: add modeline for 1680x1050@60Olaf Hering
Add a modeline for the Philips 200W display. aty128fb does not do DDC, it picks 1920x1440 or similar. It works ok with nvidiafb because it can ask for DDC data. mode "1680x1050-60" # D: 146.028 MHz, H: 65.191 kHz, V: 59.863 Hz geometry 1680 1050 1680 1050 16 timings 6848 280 104 30 3 176 6 hsync high vsync high rgba 5/11,6/5,5/0,0/0 endmode hwinfo --monitor 20: None 00.0: 10000 Monitor [Created at monitor.206] Unique ID: rdCR.pzUFTofo1S4 Parent ID: 002j.bJRsY88eNSC Hardware Class: monitor Model: "PHILIPS Philips 200W" Vendor: PHL "PHILIPS" Device: eisa 0x0832 "Philips 200W" Serial ID: "VN 016596" Resolution: 720x400@70Hz Resolution: 640x480@60Hz Resolution: 640x480@67Hz Resolution: 640x480@72Hz Resolution: 640x480@75Hz Resolution: 800x600@56Hz Resolution: 800x600@60Hz Resolution: 800x600@72Hz Resolution: 800x600@75Hz Resolution: 832x624@75Hz Resolution: 1024x768@60Hz Resolution: 1024x768@70Hz Resolution: 1024x768@75Hz Resolution: 1280x1024@75Hz Resolution: 1152x864@70Hz Resolution: 1152x864@75Hz Resolution: 1280x960@60Hz Resolution: 1280x1024@60Hz Resolution: 1680x1050@60Hz Size: 433x271 mm Driver Info #0: Max. Resolution: 1680x1050 Vert. Sync Range: 56-85 Hz Hor. Sync Range: 30-93 kHz Config Status: cfg=new, avail=yes, need=no, active=unknown Attached to: #5 (VGA compatible controller) Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-13sky2: accept flow controlStephen Hemminger
Don't program the GMAC to reject flow control packets. This maybe the cause of some of the transmit hangs. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-13sky2: fix fiber supportStephen Hemminger
Fix support for fiber based devices. Needed to keep track of PMD type to add workaround in setup. Add support for gigabit half duplex fiber. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-13sky2: use dev_alloc_skb for receive buffersStephen Hemminger
Several code paths assume an additional 16 bytes of header padding on the receive path. Use dev_alloc_skb to get that padding. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-13v4l/dvb: Backport the budget driver DISEQC instability fixOliver Endriss
Backport the budget driver DISEQC instability fix. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
2006-10-13v4l/dvb: Backport fix to artec USB DVB devicesAndrew de Quincey
Backport fix to artec USB DVB devices Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-13v4l/dvb: Fix budget-av frontend detectionAndrew de Quincey
The budget-av needs this GPIO set low for most cards to work. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-13dvb-core: Proper handling ULE SNDU length of 0 (CVE-2006-4623)Ang Way Chuang
ULE (Unidirectional Lightweight Encapsulation RFC 4326) decapsulation code has a bug that allows an attacker to send a malformed ULE packet with SNDU length of 0 and bring down the receiving machine. This patch fix the bug and has been tested on version 2.6.17.11. This bug is 100% reproducible and the modified source code (GPL) used to produce this bug will be posted on http://nrg.cs.usm.my/downloads.htm shortly. The kernel will produce a dump during CRC32 checking on faulty ULE packet. Signed-off-by: Ang Way Chuang <wcang@nrg.cs.usm.my> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-13IPV6: Sum real space for RTAs.YOSHIFUJI Hideaki
This patch fixes RTNLGRP_IPV6_IFINFO netlink notifications. Issue pointed out by Patrick McHardy <kaber@trash.net>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-13fix fdset leakageKirill Korotaev
When found, it is obvious. nfds calculated when allocating fdsets is rewritten by calculation of size of fdtable, and when we are unlucky, we try to free fdsets of wrong size. Found due to OpenVZ resource management (User Beancounters). Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-22Linux 2.6.16.30-pre1v2.6.16.30-pre1Adrian Bunk
2006-09-22USB: add YEALINK phones to the HID_QUIRK_IGNORE blacklistHenk Vergonet
Keys on Yealink based phones will not function properly when using the generic HID driver. This patch prevents the generic HID code from grabbing the device before the regular yealink driver can get a grip on it. Signed-off-by: Henk Vergonet <Henk.Vergonet@gmail.com> Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-22USB: Fix unload oops and memory leak in yealink driverHenk Vergonet
This patch fixes a memory leak and a kernel oops when trying to unload the driver, due to an unbalanced cleanup. Thanks Ivar Jensen for spotting my mistake. Signed-off-by: Henk Vergonet <henk.vergonet@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-22kernel/kmod.c: fix a race condition in usermodehelper.Martin Schwidefsky
There is a race between call_usermodehelper_keys, __call_usermodehelper and wait_for_helper. It should only happen if preemption is enabled or on a virtualized system. If the cpu is preempted or put to sleep by the hypervisor in __call_usermodehelper between the creation of the wait_for_helper thread and the second check on sub_info->wait, the whole execution of wait_for_helper including the complete call and the continuation after the wait_for_completion in call_usermodehelper_keys can have happened before __call_usermodehelper checks sub_info->wait for the second time. Since sub_info can already have been clobbered, sub_info->wait could be zero and complete is called a second time with an invalid argument. This has happened on s390. It took me only three days to find out .. Thanks to Arnd Bergmann for his help to spot this bug. Kenneth Lee also sent the same patch independently. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-22I2C: fix 'ignore' module parameter handlingMark M. Hoffman
This patch fixes a bug in the handling of 'ignore' module parameters of I2C client drivers. Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-19V4L/DVB: TDA8290 updateHartmut Hackmann
This patch - works around a bug in the I2C bridge that makes the initialization of the TDA10046 fail on recent LifeView cards - puts the AGC output to tristate in sleep mode. This is necessary for recent hybrid cards that switch the AGC via tristateing. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-18Convert idr's internal locking to _irqsave variantRoland Dreier
Currently, the code in lib/idr.c uses a bare spin_lock(&idp->lock) to do internal locking. This is a nasty trap for code that might call idr functions from different contexts; for example, it seems perfectly reasonable to call idr_get_new() from process context and idr_remove() from interrupt context -- but with the current locking this would lead to a potential deadlock. The simplest fix for this is to just convert the idr locking to use spin_lock_irqsave(). In particular, this fixes a very complicated locking issue detected by lockdep, involving the ib_ipoib driver's priv->lock and dev->_xmit_lock, which get involved with the ib_sa module's query_idr.lock. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-18[TEXTSEARCH]: Fix Boyer Moore initialization bugMichael Rash
The pattern is set after trying to compute the prefix table, which tries to use it. Initialize it before calling compute_prefix_tbl, make compute_prefix_tbl consistently use only the data from struct ts_bm and remove the now unnecessary arguments. Signed-off-by: Michael Rash <mbr@cipherdyne.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-18via-velocity: fix speed and link status reported by ethtoolJay Cliburn
The via-velocity driver reports incorrect speed and link detected status as viewed by ethtool (and probably other tools). This patch fixes those incorrect reports and prettifies a long line. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-18via-velocity: the link is not correctly detected when the device startsRoy Marples
The patch fixes http://bugzilla.kernel.org/show_bug.cgi?id=6711 Signed-off-by: Roy Marples <uberlord@gentoo.org> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-18[AGPGART] VIA PT880 Ultra support.Magnus Kessler
This patch enables agpgart on a Via "PT880 Ultra" based motherboard (Asus P4V800D-X). The PCI ID of the PT880 Ultra is 0x0308 instead of 0x0258 of the PT880. The patched via-agp passes testgart. Signed-off-by: Magnus Kessler <Magnus.Kessler@gmx.net> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-18[AGPGART] ATI RS350 support.Julien Tous
From: Julien Tous <julien.tous@gmail.com> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-18PFKEYV2: Fix inconsistent typing in struct sadb_x_kmprivate.Tushar Gohad
Fixes inconsistent use of "uint32_t" vs. "u_int32_t". Fix pfkeyv2 userspace builds. Signed-off-by: Tushar Gohad <tgohad@mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-17V4L/DVB: TDA10046 Driver updateHartmut Hackmann
- Set outputs to tristate in sleep mode - Reduce dangerously high firmware download speed with 16MHz xtal - added tda827x configuration with GPIOs low - added comments to stupid looking IIC reads that work around bugs in the tda10046. - some minor updates Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-17add drivers/media/video/saa7134/saa7134-input.c:flydvb_codesAdrian Bunk
based on drivers/media/common/ir-keymaps.c:ir_codes_flydvb in Linus' tree. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Added support for the new Lifeview hybrid cardbus modulesHartmut Hackmann
There seem to be many variants of this cards with different feature sets. This entry supports analog TV, CVBS and s-video input, FM radio and DVB-T if they are supported by the hardware. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Corrected CVBS input for the AVERMEDIA 777 DVB-THartmut Hackmann
The .vmux entry needs to be 1 instead of 0 Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Added PCI IDs of 2 LifeView CardsHartmut Hackmann
Added ID entries for the Genius VideoWonder DVB-T and the LifeView FlyTV Platinum Gold Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Saa7134: select FW_LOADERmaximilian attems
The saa7134 drivers uses request_firmware() and thus needs to select FW_LOADER. Signed-off-by: maximilian attems <maks@sternwelten.at> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Medion 7134: Autodetect second bridge chipMichael Krufky
The device, Medion 7134, has two saa7134 chips on it, but only one of them is functional in the current saa7134 driver. This patch adds autodetection for the second, unsupported saa7134 chip, as SAA7134_BOARD_MD7134_BRIDGE_2, and displays a message to the user (in dmesg) indicating that the second chip isn't yet functional. This is useful for users, since two instances of the saa7134 driver will spawn. This patch will prevent confusion by warning the user that only one of the chips on the board are functional. There are other versions of the SAA7134_BOARD_MD7134 with only a single saa7134 bridge/decoder -- those devices will not be affected by this patch. Only devices containing the second chip will display the warning. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Saa7134: make unsupported secondary decoder message genericMichael Krufky
There are already some supported devices that contain two saa713x chips on-board, where only one of these chips is currently functional in the driver. We are already printing a warning message for the second saa7134 decoder in SAA7134_BOARD_AVERMEDIA_A169_B. This patch alters that case to make it generic, so that other cards in the same situation can use it. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Saa7134: add support for AVerMedia A169 Dual Analog tuner cardRickard Osser
- Added support for AVerMedia A169 Dual Analog tuner card (dual saa7134 decoders - only 1 working right now) - Added autodetection for both parts of the card. It shows up like 2 cards, B1 and B - Enabled tuner B1, SVIDEO on B1 and composite1 through SVIDEO, FIXME: B is more or less dead at this point and I suspect the FM-radio is on the B part of the board Adrian Bunk: slightly adapted to 2.6.16 Signed-off-by: Rickard Osser <ricky@osser.se> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Saa7134: document that there's also a 220RF from KWorldAdrian Bunk
I have the same card with the same PCI id, but from KWorld. The patch documents that this is the same card. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-16V4L/DVB: ELSA EX-VISION 700TV: fix incorrect PCI subsystem IDTAMUKI Shoichi
- Corrected autodetection for saa7130 card: subsystem: 1048:226c, board: ELSA EX-VISION 700TV Signed-off-by: TAMUKI Shoichi <tamuki@linet.gr.jp> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Kworld ATSC110: initialize the tuner for analog mode on module loadCurt Meyers
- Enable the tuv1236 tuner on the Kworld-ATSC110 card so that the tuner can be identified when tuners.ko loads. - With this change it is no longer necessary to remove and reload the tuner module in order to get the tuv1236 identified. - This code was copied from the ATI HDTV Wonder init routine (in cx88-cards.c) which also uses the TUV1236D. Signed-off-by: Curt Meyers <cmeyers@boilerbots.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Kworld ATSC110: cleanupsMichael Krufky
- There is no radio with this tuner card... Thanks-to: Dwaine Garden <DwaineGarden@rogers.com> - fixed capitalization in card name. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Kworld ATSC110: enable composite and svideo inputsCurt Meyers
- corrected composite input. - verified s-video input. Signed-off-by: Curt Meyers <cmeyers@boilerbots.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: KWorld ATSC110: implement set_pll_inputCurt Meyers
- When tuning VSB, use ANT input - When tuning QAM, use CABLE input Signed-off-by: Curt Meyers <cmeyers@boilerbots.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Add support for Kworld ATSC110Andrew Burri
Signed-off-by: Andrew Burri <andrew.burri@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
