If struct xc2028_config is passed without a firmware name,
the following trouble may happen:
[11009.907205] xc2028 5-0061: type set to XCeive xc2028/xc3028 tuner
[11009.907491] ==================================================================
[11009.907750] BUG: KASAN: use-after-free in strcmp+0x96/0xb0 at addr ffff8803bd78ab40
[11009.907992] Read of size 1 by task modprobe/28992
[11009.907994] =============================================================================
[11009.907997] BUG kmalloc-16 (Tainted: G W ): kasan: bad access detected
[11009.907999] -----------------------------------------------------------------------------
[11009.908008] INFO: Allocated in xhci_urb_enqueue+0x214/0x14c0 [xhci_hcd] age=0 cpu=3 pid=28992
[11009.908012] ___slab_alloc+0x581/0x5b0
[11009.908014] __slab_alloc+0x51/0x90
[11009.908017] __kmalloc+0x27b/0x350
[11009.908022] xhci_urb_enqueue+0x214/0x14c0 [xhci_hcd]
[11009.908026] usb_hcd_submit_urb+0x1e8/0x1c60
[11009.908029] usb_submit_urb+0xb0e/0x1200
[11009.908032] usb_serial_generic_write_start+0xb6/0x4c0
[11009.908035] usb_serial_generic_write+0x92/0xc0
[11009.908039] usb_console_write+0x38a/0x560
[11009.908045] call_console_drivers.constprop.14+0x1ee/0x2c0
[11009.908051] console_unlock+0x40d/0x900
[11009.908056] vprintk_emit+0x4b4/0x830
[11009.908061] vprintk_default+0x1f/0x30
[11009.908064] printk+0x99/0xb5
[11009.908067] kasan_report_error+0x10a/0x550
[11009.908070] __asan_report_load1_noabort+0x43/0x50
[11009.908074] INFO: Freed in xc2028_set_config+0x90/0x630 [tuner_xc2028] age=1 cpu=3 pid=28992
[11009.908077] __slab_free+0x2ec/0x460
[11009.908080] kfree+0x266/0x280
[11009.908083] xc2028_set_config+0x90/0x630 [tuner_xc2028]
[11009.908086] xc2028_attach+0x310/0x8a0 [tuner_xc2028]
[11009.908090] em28xx_attach_xc3028.constprop.7+0x1f9/0x30d [em28xx_dvb]
[11009.908094] em28xx_dvb_init.part.3+0x8e4/0x5cf4 [em28xx_dvb]
[11009.908098] em28xx_dvb_init+0x81/0x8a [em28xx_dvb]
[11009.908101] em28xx_register_extension+0xd9/0x190 [em28xx]
[11009.908105] em28xx_dvb_register+0x10/0x1000 [em28xx_dvb]
[11009.908108] do_one_initcall+0x141/0x300
[11009.908111] do_init_module+0x1d0/0x5ad
[11009.908114] load_module+0x6666/0x9ba0
[11009.908117] SyS_finit_module+0x108/0x130
[11009.908120] entry_SYSCALL_64_fastpath+0x16/0x76
[11009.908123] INFO: Slab 0xffffea000ef5e280 objects=25 used=25 fp=0x (null) flags=0x2ffff8000004080
[11009.908126] INFO: Object 0xffff8803bd78ab40 @offset=2880 fp=0x0000000000000001
[11009.908130] Bytes b4 ffff8803bd78ab30: 01 00 00 00 2a 07 00 00 9d 28 00 00 01 00 00 00 ....*....(......
[11009.908133] Object ffff8803bd78ab40: 01 00 00 00 00 00 00 00 b0 1d c3 6a 00 88 ff ff ...........j....
[11009.908137] CPU: 3 PID: 28992 Comm: modprobe Tainted: G B W 4.5.0-rc1+ #43
[11009.908140] Hardware name: /NUC5i7RYB, BIOS RYBDWi35.86A.0350.2015.0812.1722 08/12/2015
[11009.908142] ffff8803bd78a000 ffff8802c273f1b8 ffffffff81932007 ffff8803c6407a80
[11009.908148] ffff8802c273f1e8 ffffffff81556759 ffff8803c6407a80 ffffea000ef5e280
[11009.908153] ffff8803bd78ab40 dffffc0000000000 ffff8802c273f210 ffffffff8155ccb4
[11009.908158] Call Trace:
[11009.908162] [<ffffffff81932007>] dump_stack+0x4b/0x64
[11009.908165] [<ffffffff81556759>] print_trailer+0xf9/0x150
[11009.908168] [<ffffffff8155ccb4>] object_err+0x34/0x40
[11009.908171] [<ffffffff8155f260>] kasan_report_error+0x230/0x550
[11009.908175] [<ffffffff81237d71>] ? trace_hardirqs_off_caller+0x21/0x290
[11009.908179] [<ffffffff8155e926>] ? kasan_unpoison_shadow+0x36/0x50
[11009.908182] [<ffffffff8155f5c3>] __asan_report_load1_noabort+0x43/0x50
[11009.908185] [<ffffffff8155ea00>] ? __asan_register_globals+0x50/0xa0
[11009.908189] [<ffffffff8194cea6>] ? strcmp+0x96/0xb0
[11009.908192] [<ffffffff8194cea6>] strcmp+0x96/0xb0
[11009.908196] [<ffffffffa13ba4ac>] xc2028_set_config+0x15c/0x630 [tuner_xc2028]
[11009.908200] [<ffffffffa13bac90>] xc2028_attach+0x310/0x8a0 [tuner_xc2028]
[11009.908203] [<ffffffff8155ea78>] ? memset+0x28/0x30
[11009.908206] [<ffffffffa13ba980>] ? xc2028_set_config+0x630/0x630 [tuner_xc2028]
[11009.908211] [<ffffffffa157a59a>] em28xx_attach_xc3028.constprop.7+0x1f9/0x30d [em28xx_dvb]
[11009.908215] [<ffffffffa157aa2a>] ? em28xx_dvb_init.part.3+0x37c/0x5cf4 [em28xx_dvb]
[11009.908219] [<ffffffffa157a3a1>] ? hauppauge_hvr930c_init+0x487/0x487 [em28xx_dvb]
[11009.908222] [<ffffffffa01795ac>] ? lgdt330x_attach+0x1cc/0x370 [lgdt330x]
[11009.908226] [<ffffffffa01793e0>] ? i2c_read_demod_bytes.isra.2+0x210/0x210 [lgdt330x]
[11009.908230] [<ffffffff812e87d0>] ? ref_module.part.15+0x10/0x10
[11009.908233] [<ffffffff812e56e0>] ? module_assert_mutex_or_preempt+0x80/0x80
[11009.908238] [<ffffffffa157af92>] em28xx_dvb_init.part.3+0x8e4/0x5cf4 [em28xx_dvb]
[11009.908242] [<ffffffffa157a6ae>] ? em28xx_attach_xc3028.constprop.7+0x30d/0x30d [em28xx_dvb]
[11009.908245] [<ffffffff8195222d>] ? string+0x14d/0x1f0
[11009.908249] [<ffffffff8195381f>] ? symbol_string+0xff/0x1a0
[11009.908253] [<ffffffff81953720>] ? uuid_string+0x6f0/0x6f0
[11009.908257] [<ffffffff811a775e>] ? __kernel_text_address+0x7e/0xa0
[11009.908260] [<ffffffff8104b02f>] ? print_context_stack+0x7f/0xf0
[11009.908264] [<ffffffff812e9846>] ? __module_address+0xb6/0x360
[11009.908268] [<ffffffff8137fdc9>] ? is_ftrace_trampoline+0x99/0xe0
[11009.908271] [<ffffffff811a775e>] ? __kernel_text_address+0x7e/0xa0
[11009.908275] [<ffffffff81240a70>] ? debug_check_no_locks_freed+0x290/0x290
[11009.908278] [<ffffffff8104a24b>] ? dump_trace+0x11b/0x300
[11009.908282] [<ffffffffa13e8143>] ? em28xx_register_extension+0x23/0x190 [em28xx]
[11009.908285] [<ffffffff81237d71>] ? trace_hardirqs_off_caller+0x21/0x290
[11009.908289] [<ffffffff8123ff56>] ? trace_hardirqs_on_caller+0x16/0x590
[11009.908292] [<ffffffff812404dd>] ? trace_hardirqs_on+0xd/0x10
[11009.908296] [<ffffffffa13e8143>] ? em28xx_register_extension+0x23/0x190 [em28xx]
[11009.908299] [<ffffffff822dcbb0>] ? mutex_trylock+0x400/0x400
[11009.908302] [<ffffffff810021a1>] ? do_one_initcall+0x131/0x300
[11009.908306] [<ffffffff81296dc7>] ? call_rcu_sched+0x17/0x20
[11009.908309] [<ffffffff8159e708>] ? put_object+0x48/0x70
[11009.908314] [<ffffffffa1579f11>] em28xx_dvb_init+0x81/0x8a [em28xx_dvb]
[11009.908317] [<ffffffffa13e81f9>] em28xx_register_extension+0xd9/0x190 [em28xx]
[11009.908320] [<ffffffffa0150000>] ? 0xffffffffa0150000
[11009.908324] [<ffffffffa0150010>] em28xx_dvb_register+0x10/0x1000 [em28xx_dvb]
[11009.908327] [<ffffffff810021b1>] do_one_initcall+0x141/0x300
[11009.908330] [<ffffffff81002070>] ? try_to_run_init_process+0x40/0x40
[11009.908333] [<ffffffff8123ff56>] ? trace_hardirqs_on_caller+0x16/0x590
[11009.908337] [<ffffffff8155e926>] ? kasan_unpoison_shadow+0x36/0x50
[11009.908340] [<ffffffff8155e926>] ? kasan_unpoison_shadow+0x36/0x50
[11009.908343] [<ffffffff8155e926>] ? kasan_unpoison_shadow+0x36/0x50
[11009.908346] [<ffffffff8155ea37>] ? __asan_register_globals+0x87/0xa0
[11009.908350] [<ffffffff8144da7b>] do_init_module+0x1d0/0x5ad
[11009.908353] [<ffffffff812f2626>] load_module+0x6666/0x9ba0
[11009.908356] [<ffffffff812e9c90>] ? symbol_put_addr+0x50/0x50
[11009.908361] [<ffffffffa1580037>] ? em28xx_dvb_init.part.3+0x5989/0x5cf4 [em28xx_dvb]
[11009.908366] [<ffffffff812ebfc0>] ? module_frob_arch_sections+0x20/0x20
[11009.908369] [<ffffffff815bc940>] ? open_exec+0x50/0x50
[11009.908374] [<ffffffff811671bb>] ? ns_capable+0x5b/0xd0
[11009.908377] [<ffffffff812f5e58>] SyS_finit_module+0x108/0x130
[11009.908379] [<ffffffff812f5d50>] ? SyS_init_module+0x1f0/0x1f0
[11009.908383] [<ffffffff81004044>] ? lockdep_sys_exit_thunk+0x12/0x14
[11009.908394] [<ffffffff822e6936>] entry_SYSCALL_64_fastpath+0x16/0x76
[11009.908396] Memory state around the buggy address:
[11009.908398] ffff8803bd78aa00: 00 00 fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[11009.908401] ffff8803bd78aa80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[11009.908403] >ffff8803bd78ab00: fc fc fc fc fc fc fc fc 00 00 fc fc fc fc fc fc
[11009.908405] ^
[11009.908407] ffff8803bd78ab80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[11009.908409] ffff8803bd78ac00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[11009.908411] ==================================================================
In order to avoid it, let's set the cached value of the firmware
name to NULL after freeing it. While here, return an error if
the memory allocation fails.
Bug 1823317
Bug 1935735
Change-Id: I1825fc7eb08bd458ed5413fea8b47de539c9b23f
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Signed-off-by: Gagan Grover <ggrover@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1690296
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Tested-by: Amulya Yarlagadda <ayarlagadda@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
In sg_common_write(), we free the block request and return -ENODEV if
the device is detached in the middle of the SG_IO ioctl().
Unfortunately, sg_finish_rem_req() also tries to free srp->rq, so we
end up freeing rq->cmd in the already free rq object, and then free
the object itself out from under the current user.
This ends up corrupting random memory via the list_head on the rq
object. The most common crash trace I saw is this:
kernel BUG at block/blk-core.c:1420!
Call Trace:
[<ffffffff81281eab>] blk_put_request+0x5b/0x80
[<ffffffffa0069e5b>] sg_finish_rem_req+0x6b/0x120 [sg]
[<ffffffffa006bcb9>] sg_common_write.isra.14+0x459/0x5a0 [sg]
[<ffffffff8125b328>] ? selinux_file_alloc_security+0x48/0x70
[<ffffffffa006bf95>] sg_new_write.isra.17+0x195/0x2d0 [sg]
[<ffffffffa006cef4>] sg_ioctl+0x644/0xdb0 [sg]
[<ffffffff81170f80>] do_vfs_ioctl+0x90/0x520
[<ffffffff81258967>] ? file_has_perm+0x97/0xb0
[<ffffffff811714a1>] SyS_ioctl+0x91/0xb0
[<ffffffff81602afb>] tracesys+0xdd/0xe2
RIP [<ffffffff81281e04>] __blk_put_request+0x154/0x1a0
The solution is straightforward: just set srp->rq to NULL in the
failure branch so that sg_finish_rem_req() doesn't attempt to re-free
it.
Additionally, since sg_rq_end_io() will never be called on the object
when this happens, we need to free memory backing ->cmd if it isn't
embedded in the object itself.
KASAN was extremely helpful in finding the root cause of this bug.
Bug 1823317
Bug 1935735
Change-Id: I883243dce583cd79e28facaa2cdd81157b293d74
Signed-off-by: Calvin Owens <calvinowens@fb.com>
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
Reviewed-on: http://git-master/r/1259958
(cherry picked from commit b49da4529988ca02bddaed8091a7f5e91105970a)
Reviewed-on: https://git-master.nvidia.com/r/1690295
get_task_ioprio() accesses the task->io_context without holding the task
lock and thus can race with exit_io_context(), leading to a
use-after-free. The reproducer below hits this within a few seconds on
my 4-core QEMU VM:
int main(int argc, char **argv)
pid_t pid, child;
long nproc, i;
/* ioprio_set(IOPRIO_WHO_PROCESS, 0, IOPRIO_PRIO_VALUE(IOPRIO_CLASS_IDLE, 0)); */
syscall(SYS_ioprio_set, 1, 0, 0x6000);
nproc = sysconf(_SC_NPROCESSORS_ONLN);
for (i = 0; i < nproc; i++) {
pid = fork();
assert(pid != -1);
if (pid == 0) {
for (;;) {
pid = fork();
assert(pid != -1);
if (pid == 0) {
_exit(0);
} else {
child = wait(NULL);
assert(child == pid);
pid = fork();
assert(pid != -1);
if (pid == 0) {
for (;;) {
/* ioprio_get(IOPRIO_WHO_PGRP, 0); */
syscall(SYS_ioprio_get, 2, 0);
for (;;) {
return 0;
This gets us KASAN dumps like this:
[ 35.526914] ==================================================================
[ 35.530009] BUG: KASAN: out-of-bounds in get_task_ioprio+0x7b/0x90 at addr ffff880066f34e6c
[ 35.530009] Read of size 2 by task ioprio-gpf/363
[ 35.530009] =============================================================================
[ 35.530009] BUG blkdev_ioc (Not tainted): kasan: bad access detected
[ 35.530009] -----------------------------------------------------------------------------
[ 35.530009] Disabling lock debugging due to kernel taint
[ 35.530009] INFO: Allocated in create_task_io_context+0x2b/0x370 age=0 cpu=0 pid=360
[ 35.530009] ___slab_alloc+0x55d/0x5a0
[ 35.530009] __slab_alloc.isra.20+0x2b/0x40
[ 35.530009] kmem_cache_alloc_node+0x84/0x200
[ 35.530009] create_task_io_context+0x2b/0x370
[ 35.530009] get_task_io_context+0x92/0xb0
[ 35.530009] copy_process.part.8+0x5029/0x5660
[ 35.530009] _do_fork+0x155/0x7e0
[ 35.530009] SyS_clone+0x19/0x20
[ 35.530009] do_syscall_64+0x195/0x3a0
[ 35.530009] return_from_SYSCALL_64+0x0/0x6a
[ 35.530009] INFO: Freed in put_io_context+0xe7/0x120 age=0 cpu=0 pid=1060
[ 35.530009] __slab_free+0x27b/0x3d0
[ 35.530009] kmem_cache_free+0x1fb/0x220
[ 35.530009] put_io_context+0xe7/0x120
[ 35.530009] put_io_context_active+0x238/0x380
[ 35.530009] exit_io_context+0x66/0x80
[ 35.530009] do_exit+0x158e/0x2b90
[ 35.530009] do_group_exit+0xe5/0x2b0
[ 35.530009] SyS_exit_group+0x1d/0x20
[ 35.530009] entry_SYSCALL_64_fastpath+0x1a/0xa4
[ 35.530009] INFO: Slab 0xffffea00019bcd00 objects=20 used=4 fp=0xffff880066f34ff0 flags=0x1fffe0000004080
[ 35.530009] INFO: Object 0xffff880066f34e58 @offset=3672 fp=0x0000000000000001
Fix it by grabbing the task lock while we poke at the io_context.
Bug 1823317
Bug 1935735
Change-Id: If331a4574b63e9288d1019c45c28af82731e9abb
Cc: stable@vger.kernel.org
Signed-off-by: Omar Sandoval <osandov@fb.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Reviewed-on: http://git-master/r/1259972
(cherry picked from commit 15e376e5d8b1399d02814cf8b1481f7ac40dc483)
Reviewed-on: https://git-master.nvidia.com/r/1690294
I got a KASAN report of use-after-free:
BUG: KASAN: use-after-free in klist_iter_exit+0x61/0x70 at addr ffff8800b6581508
Read of size 8 by task trinity-c1/315
BUG kmalloc-32 (Not tainted): kasan: bad access detected
INFO: Allocated in disk_seqf_start+0x66/0x110 age=144 cpu=1 pid=315
___slab_alloc+0x4f1/0x520
__slab_alloc.isra.58+0x56/0x80
kmem_cache_alloc_trace+0x260/0x2a0
traverse+0x176/0x860
seq_read+0x7e3/0x11a0
proc_reg_read+0xbc/0x180
do_loop_readv_writev+0x134/0x210
do_readv_writev+0x565/0x660
vfs_readv+0x67/0xa0
do_preadv+0x126/0x170
SyS_preadv+0xc/0x10
do_syscall_64+0x1a1/0x460
INFO: Freed in disk_seqf_stop+0x42/0x50 age=160 cpu=1 pid=315
__slab_free+0x17a/0x2c0
kfree+0x20a/0x220
traverse+0x3b5/0x860
vfs_readv+0x67/0xa0
SyS_preadv+0xc/0x10
CPU: 1 PID: 315 Comm: trinity-c1 Tainted: G B 4.7.0+ #62
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
ffffea0002d96000 ffff880119b9f918 ffffffff81d6ce81 ffff88011a804480
ffff8800b6581500 ffff880119b9f948 ffffffff8146c7bd ffff88011a804480
ffffea0002d96000 ffff8800b6581500 fffffffffffffff4 ffff880119b9f970
Call Trace:
[<ffffffff81d6ce81>] dump_stack+0x65/0x84
[<ffffffff8146c7bd>] print_trailer+0x10d/0x1a0
[<ffffffff814704ff>] object_err+0x2f/0x40
[<ffffffff814754d1>] kasan_report_error+0x221/0x520
[<ffffffff8147590e>] __asan_report_load8_noabort+0x3e/0x40
[<ffffffff83888161>] klist_iter_exit+0x61/0x70
[<ffffffff82404389>] class_dev_iter_exit+0x9/0x10
[<ffffffff81d2e8ea>] disk_seqf_stop+0x3a/0x50
[<ffffffff8151f812>] seq_read+0x4b2/0x11a0
[<ffffffff815f8fdc>] proc_reg_read+0xbc/0x180
[<ffffffff814b24e4>] do_loop_readv_writev+0x134/0x210
[<ffffffff814b4c45>] do_readv_writev+0x565/0x660
[<ffffffff814b8a17>] vfs_readv+0x67/0xa0
[<ffffffff814b8de6>] do_preadv+0x126/0x170
[<ffffffff814b92ec>] SyS_preadv+0xc/0x10
This problem can occur in the following situation:
open()
- pread()
- .seq_start()
- iter = kmalloc() // succeeds
- seqf->private = iter
- .seq_stop()
- kfree(seqf->private)
- pread()
- .seq_start()
- iter = kmalloc() // fails
- .seq_stop()
- class_dev_iter_exit(seqf->private) // boom! old pointer
As the comment in disk_seqf_stop() says, stop is called even if start
failed, so we need to reinitialise the private pointer to NULL when seq
iteration stops.
An alternative would be to set the private pointer to NULL when the
kmalloc() in disk_seqf_start() fails.
Bug 1823317
Bug 1935735
Change-Id: Ic3f82ef82c570866b48c5ea8e195d8e504570d80
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Acked-by: Tejun Heo <tj@kernel.org>
Reviewed-on: http://git-master/r/1259961
(cherry picked from commit 9d4a4a8711e9570c3ead013b64ff6e8bad05afbc)
Reviewed-on: https://git-master.nvidia.com/r/1690293
snd_usb_add_audio_stream() call
create_fixed_stream_quirk(), snd_usb_parse_audio_interface() and
create_uaxx_quirk() functions allocate the audioformat object by themselves
and free it upon error before returning. However, once the object is linked
to a stream, it's freed again in snd_usb_audio_pcm_free(), thus it'll be
double-freed, eventually resulting in a memory corruption.
This patch fixes these failures in the error paths by unlinking the audioformat
object before freeing it.
Based on a patch by Takashi Iwai <tiwai@suse.de>
[Note for stable backports:
this patch requires the commit 902eb7fd1e4a ('ALSA: usb-audio: Minor
code cleanup in create_fixed_stream_quirk()')]
Bug 1823317
Bug 1935735
Change-Id: I4f65a902a19e7b21e8bc0fa21efd833c8360a3cf
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1283358
Reported-by: Ralf Spenneberg <ralf@spenneberg.net>
Cc: <stable@vger.kernel.org> # see the note above
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
Reviewed-on: http://git-master/r/1259999
(cherry picked from commit 14e09c3233fb7578c778b70ec3933ba5cadfccb6)
Reviewed-on: https://git-master.nvidia.com/r/1690292
When tcp_sendmsg() allocates a fresh and empty skb, it puts it
at the tail of the write queue using tcp_add_write_queue_tail()
Then it attempts to copy user data into this fresh skb.
If the copy fails, we undo the work and remove the fresh skb.
Unfortunately, this undo lacks the change done to tp->highest_sack and we can leave a dangling pointer (to a freed skb)
Later, tcp_xmit_retransmit_queue() can dereference this pointer and
access freed memory. For regular kernels where memory is not unmapped,
this might cause SACK bugs because tcp_highest_sack_seq() is buggy,
returning garbage instead of tp->snd_nxt, but with various debug
features like CONFIG_DEBUG_PAGEALLOC, this can crash the kernel.
This bug was found by Marco Grassi thanks to syzkaller.
Bug 1823317
Bug 1935735
Change-Id: I9bf709b21e5637f338c34d894617f33d84f93ecc
Reported-by: Marco Grassi <marco.gra@gmail.com>
Reviewed-on: http://git-master/r/1260003
(cherry picked from commit 0c20962647685008dfc6a15fb8a2169ed2abafe6)
Reviewed-on: https://git-master.nvidia.com/r/1690290
A malicious application can take advantage of the ION kmalloc heap
to create a specific memory chunk size to exercise a rowhammer
attack on the physical hardware.
The fix is designed to disable ION heap type.
CVE-2016-6728: A-30400942
Bug 1823317
Change-Id: I6b6d891a85da0c175f88cc1a3e48875796db80d4
Reviewed-on: https://git-master.nvidia.com/r/1690291
The instruction sequency "dsb sy" followed by "isb" functions as
a speculation barrier, which prevents the instructions after that
from being speculatively executed.
bug 2039126
Change-Id: Ie3b7b873a12002617e60510ed8759bdaa7cd7057
Signed-off-by: Bo Yan <byan@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1618222
Signed-off-by: James Huang <jamehuang@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1650093
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
(cherry picked from commit f125c60045878513902cac4a084fde9a516eb3e2)
Reviewed-on: https://git-master.nvidia.com/r/1660782
bug 2039126
Change-Id: Id1908c3058c9ecc0dfb4f2d85440a8d36db45db5
Signed-off-by: David Gilhooley <dgilhooley@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1650029
(cherry picked from commit 7a0213eca150614fe88d197a09d461fff6168652)
Reviewed-on: https://git-master.nvidia.com/r/1660781
Data can be speculatively loaded from memory and stay in cache even
when bound check fails. This can lead to unintended information
disclosure via side-channel analysis.
To mitigate this problem, insert speculation barrier.
bug 2039126
CVE-2017-5753
Change-Id: Id85eb9c91932f358dd999b28dd53d7788b37ea04
Reviewed-on: https://git-master.nvidia.com/r/1640356
Reviewed-on: https://git-master.nvidia.com/r/1650014
(cherry picked from commit 25bd9436b11f41e23048c9515deae97900a46669)
Reviewed-on: https://git-master.nvidia.com/r/1660780
Tested-by: Winnie Hsu <whsu@nvidia.com>
Bug 1964290
CVE-2017-5753
Change-Id: I7382dbcc6e9f352fafd457301beafe753925f3c4
Signed-off-by: Hien Goi <hgoi@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1650791
(cherry picked from commit 5cabd53985a30aa818896abdb64564a74c09ab9c)
Reviewed-on: https://git-master.nvidia.com/r/1660772
bug 2039126
Change-Id: I898aab771ff82b26b08214a06814d2e6e78969a7
Reviewed-on: https://git-master.nvidia.com/r/1660771
To support a wider variety of backlight setups, introduce an optional
enable GPIO. Legacy users of the platform data already have a means of
supporting GPIOs by using the .init(), .exit() and .notify() hooks. DT
users however cannot use those, so an alternative method is required.
In order to ease the introduction of the optional enable GPIO, make it
available in the platform data first, so that existing users can be
converted. Once that has happened a second patch will add code to make
use of it in the driver.
Signed-off-by: Thierry Reding <treding@nvidia.com>
(cherry picked from commit 2b9b1620349e325f184c68cddf3b484499c163c0)
When a device is shut down, make sure to disable the backlight. If it
stays lit, it gives the impression that the device hasn't turned off.
Furthermore keeping the backlight on may consume power, which is not
what users expect when they shut down a device.
(cherry picked from commit 5f33b896246a2d9bdf01352de11d4dab96ba2fc9)
No need to have a specific OOM message, since there is generic MM out of memory
message in place.
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
(cherry picked from commit ca7a97add4d4a7b0602b3bd1eff5c89da8636713)
I forgot to remove this during earlier cleanup patches and only checked
various builds for errors, not warnings.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
(cherry picked from commit 73d4e2b82b4bb1571b1a7f97012c0db8a0faef42)
Use SIMPLE_DEV_PM_OPS macro will initialize the member "freeze"
and "thaw" of pwm_backlight_pm_ops as below,
.freeze = suspend_fn,
.thaw = resume_fn,
then during the process of making hibernation snapshot, screen
will be blank at the moment of freezing, and then light at the
moment of thawing.
this is not the right user experience for suspending to disk.
so this patch drops freeze and thaw callback, make the LCD is
always lighting before the final shutdown.
Signed-off-by: Huayi Li <huayi.li@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
(cherry picked from commit 1dea1fd09246ada581a99d0669108eea94b7bfee)
Split adjustment of the brightness (by changing the PWM duty cycle) from
the power on sequence. This fixes an issue where the brightness can no
longer be updated once the backlight has been enabled.
Reported-by: Marc Dietrich <marvin24@gmx.de>
(cherry picked from commit e4bfeda96872bfe6015cd360008b77cd3b981b2b)
Currently the driver assumes that the values specified in the
brightness-levels device tree property increase as they are parsed from
left to right. But boards that invert the signal between the PWM output
and the backlight will need to specify decreasing brightness-levels.
This patch removes the assumption that the last element of the array is
the maximum value, and instead searches the array for the maximum value
and uses that in the duty cycle calculation.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
(cherry picked from commit 8f43e18e2769b3b28383903d501b4da29e388aad)
Backlights require a power supply to work properly. This commit adds a
regulator to power up and power down the backlight.
(cherry picked from commit 22ceeee16eb8f0d04de3ef43a5174fb30ec18af9)
Make use of the new enable_gpio field and allow it to be set from DT as
well. Now that all legacy users of platform data have been converted to
initialize this field to an invalid value, it is safe to use the field
from the driver.
(cherry picked from commit 8265b2e4e62632b01f998095d1bbda4d281629fe)
Follow up patches will add support for more complex means of powering
the backlight on and off such as using a regulator. To prevent calls to
the regulator API from becoming unbalanced, keep track of the enabled
state internally.
(cherry picked from commit 97c38437115aa0c3fb2d50c488814b503ba529e0)
In preparation for adding an optional regulator and enable GPIO to the
driver, split the power on and power off sequences into separate
functions to reduce code duplication at the multiple call sites.
(cherry picked from commit 62b744a87c1170b339f993aa3cfb22465974816a)
Add more blank lines to increase readability. While at it, remove a
trailing blank line at the end of the file.
(cherry picked from commit 668e63c6701d486c68b49ffffc0e5b7de1a2e95c)
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly. This is a cosmetic change to
make the code simpler and enhance the readability.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
(cherry picked from commit c512794cada491e008eeca822af7e4ad5db72a56)
This reverts commit 95730406a0e3bbd7f862718782924a3c367845a1.
This reverts commit 74df06fb565b7250bc86d79727b66bb02259d54c.
This reverts commit 08a13bacb43f206239ae0f1ccbe37325993e2b1b.
This reverts commit 153a5d54d1a10c5a35f6923e0c6423430d2c7c89.
Both firmware and kernel are using the same set of constants
in a header file, this patch separates them in to a single file.
That way it will be easier to track changes to FW or kernel.
DC initialization now relays only on device-tree entry.
Add ability to switch between 24.1 and 24.0 lvds modes.
Mode description can be found in "Using 24-bpp LVDS Panels with
Intel® Mobile Chipsets for Embedded Applications".
This change also modifies SPI clock for ezPort mode.
Increased SPI speed for transfers and peripheral speed.
Switch to cleaning IRQ flags on read, instead of separate write.
Switched to zero-copy on SPI reads.
Make sure that the VM owned by a channel lives for at least
as long as that channel does. If the channel's VM is cleaned
up before the channel then use-after-free bugs can occur.
Bug: 31680980
NvBug 1825464
Bug: 1885921
Change-Id: I0711781492a764b643c2ed1da1b3ba87fda72744
Signed-off-by: Alex Waterman <alexw@nvidia.com>
Reviewed-on: https://git-psac.nvidia.com/r/#/c/9261
Signed-off-by: Debarshi Dutta <ddutta@nvidia.com>
(cherry picked from commit e205f2720fcee61886e7979e9588602d691507ea)
Reviewed-on: https://git-master.nvidia.com/r/1681801
In RSA operations use copy_from_user to get key data
into local buffer before using it.
This will avoid untrusted user pointer dereference.
Coverity ID 24040
Bug 200192571
Bug 1932494
Change-Id: I9c8f3fd7cfc18121d9c2179127dfb28202f38cdb
Signed-off-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1676570
Check ucode size for upper limit.
Bug 1901435
Bug 1954563
Bug 1917589
Signed-off-by: Ravindra Lokhande <rlokhande@nvidia.com>
Signed-off-by: Xia Yang <xiay@nvidia.com>
Change-Id: I2f455771147bb4466d154878d2461e472647c4fb
Reviewed-on: https://git-master.nvidia.com/r/1575925
Reviewed-on: https://git-master.nvidia.com/r/1674399
Tested-by: James Huang <jamehuang@nvidia.com>
Reviewed-by: James Huang <jamehuang@nvidia.com>
drive current for LANE4 was not set if configured as 24bpp lvds out.
fix it by programming proper drive current register if using 24bpp out.
Bug 1724122
Change-Id: Ie2ad71ace0b4f247e007e671be828230545b15f6
Signed-off-by: David Pu <dpu@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1544691
Tested-by: Wayne Wang (SW-TEGRA) <waywang@nvidia.com>
Validate the mapping_size argument in the VM mapping IOCTL before
attempting to use the argument for anything.
Manual Cherry pick - https://git-master.nvidia.com/r/1547046
Bug 1954931
Bug 1965443
Change-Id: I81b22dc566c6c6f89e5e62604ce996376b33a343
Reviewed-on: https://git-master.nvidia.com/r/1547046
(cherry picked from commit e68391690cfcc23b77c68aec3f9605badea226ed in
dev-kernel)
Reviewed-on: https://git-master.nvidia.com/r/1671883
Prevent sysfs from setting a cur_state that exceeds the max cur_state
of the cooling device.
Bug 200334223
Bug 200331706
Bug 1968660
Bug 1968616
Change-Id: I935be6166a9e184683abfcdce70cb08cbe4a1350
Signed-off-by: Srikar Srimath Tirumala <srikars@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1558407
(cherry picked from commit 142cf9d96ed221124ea2b778dc37cf5db8d5702c)
Reviewed-on: https://git-master.nvidia.com/r/1661413
Reviewed-on: https://git-master.nvidia.com/r/1662626
disabling tegra SE crypto dev for
t124 platform.
Bug 1927682
Change-Id: I16a24009e8f528df4be40ec65aa621b4ac779e41
Signed-off-by: Konduri Praveen <kondurip@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1582395
Use sp->syncpt_mutex lock to get syncpt name in
syncpt_name_show()
Without the lock, it is possible for user to read
syncpt name in corrupted state if user read
coincides with syncpt free
Bug 1838598
Bug 1883567
Change-Id: I69ca5c1d80adaca4b93a337fe4a5debeb78f34fc
Reviewed-on: http://git-master/r/1252580
Reviewed-on: http://git-master/r/1258020
(cherry picked from commit 9a7d12e49ca6c627dff2dc4c15fa9ba153e9265d in rel-24)
Reviewed-on: https://git-master.nvidia.com/r/1513005
Reviewed-on: https://git-master.nvidia.com/r/1650064
add algo variable for avoid the usage of
user space pointers
Bug 200286426
Change-Id: I7e208b45ba11348e7b89a429d457ae51ac29bde0
Reviewed-on: https://git-master.nvidia.com/r/1530560
Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Tested-by: Bibek Basu <bbasu@nvidia.com>
