Backports introduced the following compiler warning:
net/ipv6/ip6_offload.c:264:25: warning: 'sit_gro_receive' defined but not used [-Wunused-function]
Remove the static function definition.
Backport 78de28c67 introduced the following compiler warning. The
later function prototype was changed to return a void* while
in 4.1 the function does not return a value.
drivers/of/fdt.c: In function '__unflatten_device_tree':
include/linux/stddef.h:8:14: warning: 'return' with a value, in function returning void
#define NULL ((void *)0)
drivers/of/fdt.c:416:10: note: in expansion of macro 'NULL'
return NULL;
With gcc 5.1 I get:
warning: switch condition has boolean value [-Wswitch-bool]
Signed-off-by: Tomer Barletz <barletz@gmail.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
(cherry picked from commit cc7fce80229067890365c1ee196be5d304d36dea)
Mainline commit 9386aae907d9ee79d54640f09d70909393e0ddeb addresses
macro collisions, however the mainline and downstream kernel driver
do not match.
Fix the issue addressed in mainline in the downstream codebase.
This reverts commit 9386aae907d9ee79d54640f09d70909393e0ddeb.
The fsl-quadspi from mainline is implemented differently, so do not
use it from the mainline backport.
Required to also revert merge conflict resolution.
Linux 4.1.44
* tag 'v4.1.44': (180 commits)
Linux 4.1.44
mtd: fsl-quadspi: fix macro collision problems with READ/WRITE
pinctrl: samsung: Remove bogus irq_[un]mask from resource management
pinctrl: sunxi: add a missing function of A10/A20 pinctrl driver
pnfs/blocklayout: require 64-bit sector_t
iio: adc: vf610_adc: Fix VALT selection value for REFSEL bits
usb:xhci:Add quirk for Certain failing HP keyboard on reset after resume
usb: quirks: Add no-lpm quirk for Moshi USB to Ethernet Adapter
USB: Check for dropped connection before switching to full speed
uas: Add US_FL_IGNORE_RESIDUE for Initio Corporation INIC-3069
iio: light: tsl2563: use correct event code
staging:iio:resolver:ad2s1210 fix negative IIO_ANGL_VEL read
USB: hcd: Mark secondary HCD as dead if the primary one died
USB: serial: pl2303: add new ATEN device id
USB: serial: cp210x: add support for Qivicon USB ZigBee dongle
USB: serial: option: add D-Link DWM-222 device ID
nfs/flexfiles: fix leak of nfs4_ff_ds_version arrays
fuse: initialize the flock flag in fuse_file on allocation
iscsi-target: Fix iscsi_np reset hung task during parallel delete
iscsi-target: fix memory leak in iscsit_setup_text_cmd()
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
[ Upstream commit 04850c4d8613127a9b488321c0ad83bff7519311 ]
Change the READ/WRITE to FSL_READ/FSL_WRITE to resolve any possible
namespace collisions with READ/WRITE macros (e.g., from <linux/fs.h>).
Problems have been seen, for example, on mips:
>> drivers/mtd/spi-nor/fsl-quadspi.c:186:5: error: 'LUT_0' undeclared (first use in this function)
((LUT_##ins) << INSTR0_SHIFT))
>> drivers/mtd/spi-nor/fsl-quadspi.c:188:30: note: in expansion of macro 'LUT0'
On SPARC:
drivers/mtd/spi-nor/fsl-quadspi.c: In function 'fsl_qspi_init_lut':
drivers/mtd/spi-nor/fsl-quadspi.c:369:1: error: 'LUT_0' undeclared (first use in this function)
drivers/mtd/spi-nor/fsl-quadspi.c:418:1: error: pasting "LUT_" and "(" does not give a valid preprocessing token
drivers/mtd/spi-nor/fsl-quadspi.c:418:2: error: implicit declaration of function 'LUT_'
And surely on others.
Fixes: d26a22d06708 ("mtd: fsl-quadspi: allow building for other ARCHes with COMPILE_TEST")
Reported-by: Guenter Roeck <linux@roeck-us.net>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Han Xu <b45815@freescale.com>
[Brian: rewrote commit description]
[ Upstream commit b5bf1733d6a391c4e90ea8f8468d83023be74a2a ]
For cases where implicit fall through case labels are intended,
to let us inform that to gcc >= 7:
CC /tmp/build/perf/util/string.o
util/string.c: In function 'perf_atoll':
util/string.c:22:7: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (*p)
util/string.c:24:3: note: here
case '\0':
So we introduce:
#define __fallthrough __attribute__ ((fallthrough))
And use it in such cases.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Cc: William Cohen <wcohen@redhat.com>
Link: http://lkml.kernel.org/n/tip-qnpig0xfop4hwv6k4mv1wts5@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 3fa53ec2ed885b0aec3f0472e3b4a8a6f1cd748c ]
The irq chip callbacks irq_request/release_resources() have absolutely no
business with masking and unmasking the irq.
The core code unmasks the interrupt after complete setup and masks it
before invoking irq_release_resources().
The unmask is actually harmful as it happens before the interrupt is
completely initialized in __setup_irq().
Remove it.
Fixes: f6a8249f9e55 ("pinctrl: exynos: Lock GPIOs as interrupts when used as EINTs")
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: linux-samsung-soc@vger.kernel.org
Cc: linux-gpio@vger.kernel.org
Acked-by: Tomasz Figa <tomasz.figa@gmail.com>
[ Upstream commit d81ece747d8727bb8b1cfc9a20dbe62f09a4e35a ]
The PH16 pin has a function with mux id 0x5, which is the DET pin of the
"sim" (smart card reader) IP block.
This function is missing in old versions of A10/A20 SoCs' datasheets and
user manuals, so it's also missing in the old drivers. The newest A10
Datasheet V1.70 and A20 Datasheet V1.41 contain this pin function, and
it's discovered during implementing R40 pinctrl driver.
Add it to the driver. As we now merged A20 pinctrl driver to the A10
one, we need to only fix the A10 driver now.
Fixes: f2821b1ca3a2 ("pinctrl: sunxi: Move Allwinner A10 pinctrl
driver to a driver of its own")
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
[ Upstream commit 8a9d6e964d318533ba3d2901ce153ba317c99a89 ]
The blocklayout code does not compile cleanly for a 32-bit sector_t,
and also has no reliable checks for devices sizes, which makes it
unsafe to use with a kernel that doesn't support large block devices.
Fixes: 5c83746a0cf2 ("pnfs/blocklayout: in-kernel GETDEVICEINFO XDR parsing")
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
[ Upstream commit d466d3c1217406b14b834335b5b4b33c0d45bd09 ]
In order to select the alternate voltage reference pair (VALTH/VALTL), the
right value for the REFSEL field in the ADCx_CFG register is "01", leading
to 0x800 as register mask. See section 8.2.6.4 in the reference manual[1].
[1] http://www.nxp.com/docs/en/reference-manual/VFXXXRM.pdf
Fixes: a775427632fd ("iio:adc:imx: add Freescale Vybrid vf610 adc driver")
Signed-off-by: Stefan-Gabriel Mirea <stefan-gabriel.mirea@nxp.com>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
[ Upstream commit e788787ef4f9c24aafefc480a8da5f92b914e5e6 ]
Certain HP keyboards would keep inputting a character automatically which
is the wake-up key after S3 resume
On some AMD platforms USB host fails to respond (by holding resume-K) to
USB device (an HP keyboard) resume request within 1ms (TURSM) and ensures
that resume is signaled for at least 20 ms (TDRSMDN), which is defined in
USB 2.0 spec. The result is that the keyboard is out of function.
In SNPS USB design, the host responds to the resume request only after
system gets back to S0 and the host gets to functional after the internal
HW restore operation that is more than 1 second after the initial resume
request from the USB device.
As a workaround for specific keyboard ID(HP Keyboards), applying port reset
after resume when the keyboard is plugged in.
Signed-off-by: Sandeep Singh <Sandeep.Singh@amd.com>
Signed-off-by: Shyam Sundar S K <Shyam-sundar.S-k@amd.com>
cc: Nehal Shah <Nehal-bakulchandra.Shah@amd.com>
Reviewed-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Cc: stable <stable@vger.kernel.org>
[ Upstream commit 7496cfe5431f21da5d27a8388c326397e3f0a5db ]
Moshi USB to Ethernet Adapter internally uses a Genesys Logic hub to
connect to Realtek r8153.
The Realtek r8153 ethernet does not work on the internal hub, no-lpm quirk
can make it work.
Since another r8153 dongle at my hand does not have the issue, so add
the quirk to the Genesys Logic hub instead.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
[ Upstream commit 94c43b9897abf4ea366ed4dba027494e080c7050 ]
Some buggy USB disk adapters disconnect and reconnect multiple times
during the enumeration procedure. This may lead to a device
connecting at full speed instead of high speed, because when the USB
stack sees that a device isn't able to enumerate at high speed, it
tries to hand the connection over to a full-speed companion
controller.
The logic for doing this is careful to check that the device is still
connected. But this check is inadequate if the device disconnects and
reconnects before the check is done. The symptom is that a device
works, but much more slowly than it is capable of operating.
The situation was made worse recently by commit 22547c4cc4fe ("usb:
hub: Wait for connection to be reestablished after port reset"), which
increases the delay following a reset before a disconnect is
recognized, thus giving the device more time to reconnect.
This patch makes the check more robust. If the device was
disconnected at any time during enumeration, we will now skip the
full-speed handover.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: Zdenek Kabelac <zkabelac@redhat.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
[ Upstream commit 89f23d51defcb94a5026d4b5da13faf4e1150a6f ]
Similar to commit d595259fbb7a ("usb-storage: Add ignore-residue quirk for
Initio INIC-3619") for INIC-3169 in unusual_devs.h but INIC-3069 already
present in unusual_uas.h. Both in same controller IC family.
Issue is that MakeMKV fails during key exchange with installed bluray drive
with following error:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED'
occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:0'
Signed-off-by: Alan Swanson <reiver@improbability.net>
Acked-by: Oliver Neukum <oneukum@suse.com>
[ Upstream commit a3507e48d3f99a93a3056a34a5365f310434570f ]
The TSL2563 driver provides three iio channels, two of which are raw ADC
channels (channel 0 and channel 1) in the device and the remaining one
is calculated by the two. The ADC channel 0 only supports programmable
interrupt with threshold settings and this driver supports the event but
the generated event code does not contain the corresponding iio channel
type.
This is going to change userspace ABI. Hopefully fixing this to be
what it should always have been won't break any userspace code.
Cc: Jonathan Cameron <jic23@kernel.org>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
[ Upstream commit 105967ad68d2eb1a041bc041f9cf96af2a653b65 ]
gcc-7 points out an older regression:
drivers/staging/iio/resolver/ad2s1210.c: In function 'ad2s1210_read_raw':
drivers/staging/iio/resolver/ad2s1210.c:515:42: error: '<<' in boolean context, did you mean '<' ? [-Werror=int-in-bool-context]
The original code had 'unsigned short' here, but incorrectly got
converted to 'bool'. This reverts the regression and uses a normal
type instead.
Fixes: 29148543c521 ("staging:iio:resolver:ad2s1210 minimal chan spec conversion.")
Cc: stable@vger.kernel.org
[ Upstream commit cd5a6a4fdaba150089af2afc220eae0fef74878a ]
Make usb_hc_died() clear the HCD_FLAG_RH_RUNNING flag for the shared
HCD and set HCD_FLAG_DEAD for it, in analogy with what is done for
the primary one.
Among other thigs, this prevents check_root_hub_suspended() from
returning -EBUSY for dead HCDs which helps to work around system
suspend issues in some situations.
This actually fixes occasional suspend failures on one of my test
machines.
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
[ Upstream commit 3b6bcd3d093c698d32e93d4da57679b8fbc5e01e ]
This adds a new ATEN device id for a new pl2303-based device.
Reported-by: Peter Kuo <PeterKuo@aten.com.tw>
Cc: Johan Hovold <johan@kernel.org>
[ Upstream commit 9585e340db9f6cc1c0928d82c3a23cc4460f0a3f ]
The German Telekom offers a ZigBee USB Stick under the brand name Qivicon
for their SmartHome Home Base in its 1. Generation. The productId is not
known by the according kernel module, this patch adds support for it.
Signed-off-by: Stefan Triller <github@stefantriller.de>
Reviewed-by: Frans Klaver <fransklaver@gmail.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit fd1b8668af59a11bb754a6c9b0051c6c5ce73b74 ]
Add device id for D-Link DWM-222.
Signed-off-by: Hector Martin <marcan@marcan.st>
[ Upstream commit 1feb26162bee7b2f110facfec71b5c7bdbc7d14d ]
The client was freeing the nfs4_ff_layout_ds, but not the contained
nfs4_ff_ds_version array.
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
Cc: stable@vger.kernel.org # v4.0+
[ Upstream commit 68227c03cba84a24faf8a7277d2b1a03c8959c2c ]
Before the patch, the flock flag could remain uninitialized for the
lifespan of the fuse_file allocation. Unless set to true in
fuse_file_flock(), it would remain in an indeterminate state until read in
an if statement in fuse_release_common(). This could consequently lead to
taking an unexpected branch in the code.
The bug was discovered by a runtime instrumentation designed to detect use
of uninitialized memory in the kernel.
Signed-off-by: Mateusz Jurczyk <mjurczyk@google.com>
Fixes: 37fb3a30b462 ("fuse: fix flock")
Cc: <stable@vger.kernel.org> # v3.1+
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
[ Upstream commit 978d13d60c34818a41fc35962602bdfa5c03f214 ]
This patch fixes a bug associated with iscsit_reset_np_thread()
that can occur during parallel configfs rmdir of a single iscsi_np
used across multiple iscsi-target instances, that would result in
hung task(s) similar to below where configfs rmdir process context
was blocked indefinately waiting for iscsi_np->np_restart_comp
to finish:
[ 6726.112076] INFO: task dcp_proxy_node_:15550 blocked for more than 120 seconds.
[ 6726.119440] Tainted: G W O 4.1.26-3321 #2
[ 6726.125045] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 6726.132927] dcp_proxy_node_ D ffff8803f202bc88 0 15550 1 0x00000000
[ 6726.140058] ffff8803f202bc88 ffff88085c64d960 ffff88083b3b1ad0 ffff88087fffeb08
[ 6726.147593] ffff8803f202c000 7fffffffffffffff ffff88083f459c28 ffff88083b3b1ad0
[ 6726.155132] ffff88035373c100 ffff8803f202bca8 ffffffff8168ced2 ffff8803f202bcb8
[ 6726.162667] Call Trace:
[ 6726.165150] [<ffffffff8168ced2>] schedule+0x32/0x80
[ 6726.170156] [<ffffffff8168f5b4>] schedule_timeout+0x214/0x290
[ 6726.176030] [<ffffffff810caef2>] ? __send_signal+0x52/0x4a0
[ 6726.181728] [<ffffffff8168d7d6>] wait_for_completion+0x96/0x100
[ 6726.187774] [<ffffffff810e7c80>] ? wake_up_state+0x10/0x10
[ 6726.193395] [<ffffffffa035d6e2>] iscsit_reset_np_thread+0x62/0xe0 [iscsi_target_mod]
[ 6726.201278] [<ffffffffa0355d86>] iscsit_tpg_disable_portal_group+0x96/0x190 [iscsi_target_mod]
[ 6726.210033] [<ffffffffa0363f7f>] lio_target_tpg_store_enable+0x4f/0xc0 [iscsi_target_mod]
[ 6726.218351] [<ffffffff81260c5a>] configfs_write_file+0xaa/0x110
[ 6726.224392] [<ffffffff811ea364>] vfs_write+0xa4/0x1b0
[ 6726.229576] [<ffffffff811eb111>] SyS_write+0x41/0xb0
[ 6726.234659] [<ffffffff8169042e>] system_call_fastpath+0x12/0x71
It would happen because each iscsit_reset_np_thread() sets state
to ISCSI_NP_THREAD_RESET, sends SIGINT, and then blocks waiting
for completion on iscsi_np->np_restart_comp.
However, if iscsi_np was active processing a login request and
more than a single iscsit_reset_np_thread() caller to the same
iscsi_np was blocked on iscsi_np->np_restart_comp, iscsi_np
kthread process context in __iscsi_target_login_thread() would
flush pending signals and only perform a single completion of
np->np_restart_comp before going back to sleep within transport
specific iscsit_transport->iscsi_accept_np code.
To address this bug, add a iscsi_np->np_reset_count and update
__iscsi_target_login_thread() to keep completing np->np_restart_comp
until ->np_reset_count has reached zero.
Reported-by: Gary Guo <ghg@datera.io>
Tested-by: Gary Guo <ghg@datera.io>
Cc: Mike Christie <mchristi@redhat.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: stable@vger.kernel.org # 3.10+
[ Upstream commit ea8dc5b4cd2195ee582cae28afa4164c6dea1738 ]
On receiving text request iscsi-target allocates buffer for
payload in iscsit_handle_text_cmd() and assigns buffer pointer
to cmd->text_in_ptr, this buffer is currently freed in
iscsit_release_cmd(), if iscsi-target sets 'C' bit in text
response then it will receive another text request from the
initiator with ttt != 0xffffffff in this case iscsi-target
will find cmd using itt and call iscsit_setup_text_cmd()
which will set cmd->text_in_ptr to NULL without freeing
previously allocated buffer.
This patch fixes this issue by calling kfree(cmd->text_in_ptr)
in iscsit_setup_text_cmd() before assigning NULL to it.
For the first text request cmd->text_in_ptr is NULL as
cmd is memset to 0 in iscsit_allocate_cmd().
Signed-off-by: Varun Prakash <varun@chelsio.com>
Cc: <stable@vger.kernel.org> # 4.0+
[ Upstream commit 75dddef32514f7aa58930bde6a1263253bc3d4ba ]
The RDMA subsystem can generate several thousand of these messages per
second eventually leading to a kernel crash. Ratelimit these messages
to prevent this crash.
Doug said:
"I've been carrying a version of this for several kernel versions. I
don't remember when they started, but we have one (and only one) class
of machines: Dell PE R730xd, that generate these errors. When it
happens, without a rate limit, we get rcu timeouts and kernel oopses.
With the rate limit, we just get a lot of annoying kernel messages but
the machine continues on, recovers, and eventually the memory
operations all succeed"
And:
"> Well... why are all these EBUSY's occurring? It sounds inefficient
> (at least) but if it is expected, normal and unavoidable then
> perhaps we should just remove that message altogether?
I don't have an answer to that question. To be honest, I haven't
looked real hard. We never had this at all, then it started out of the
blue, but only on our Dell 730xd machines (and it hits all of them),
but no other classes or brands of machines. And we have our 730xd
machines loaded up with different brands and models of cards (for
instance one dedicated to mlx4 hardware, one for qib, one for mlx5, an
ocrdma/cxgb4 combo, etc), so the fact that it hit all of the machines
meant it wasn't tied to any particular brand/model of RDMA hardware.
To me, it always smelled of a hardware oddity specific to maybe the
CPUs or mainboard chipsets in these machines, so given that I'm not an
mm expert anyway, I never chased it down.
A few other relevant details: it showed up somewhere around 4.8/4.9 or
thereabouts. It never happened before, but the prinkt has been there
since the 3.18 days, so possibly the test to trigger this message was
changed, or something else in the allocator changed such that the
situation started happening on these machines?
And, like I said, it is specific to our 730xd machines (but they are
all identical, so that could mean it's something like their specific
ram configuration is causing the allocator to hit this on these
machine but not on other machines in the cluster, I don't want to say
it's necessarily the model of chipset or CPU, there are other bits of
identicalness between these machines)"
Link: http://lkml.kernel.org/r/499c0f6cc10d6eb829a67f2a4d75b4228a9b356e.1501695897.git.jtoppins@redhat.com
Signed-off-by: Jonathan Toppins <jtoppins@redhat.com>
Reviewed-by: Doug Ledford <dledford@redhat.com>
Tested-by: Doug Ledford <dledford@redhat.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
[ Upstream commit 7640131032db9118a78af715ac77ba2debeeb17c ]
When removing an element from the mempool, mark it as unpoisoned in KASAN
before verifying its contents for SLUB/SLAB debugging. Otherwise KASAN
will flag the reads checking the element use-after-free writes as
use-after-free reads.
Signed-off-by: Matthew Dawson <matthew@mjdsystems.ca>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
[ Upstream commit 7e5a672289c9754d07e1c3b33649786d3d70f5e4 ]
The mmu_notifier_release() callback of KVM triggers cleaning up
the stage2 page table on kvm-arm. However there could be other
notifier callbacks in parallel with the mmu_notifier_release(),
which could cause the call backs ending up in an empty stage2
page table. Make sure we check it for all the notifier callbacks.
Fixes: commit 293f29363 ("kvm-arm: Unmap shadow pagetables properly")
Reported-by: Alex Graf <agraf@suse.de>
Reviewed-by: Christoffer Dall <cdall@linaro.org>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
[ Upstream commit fc290a114fc6034b0f6a5a46e2fb7d54976cf87a ]
This fixes another cause of random segfaults and bus errors that may
occur while running perf with the callgraph option.
Critical sections beginning with spin_lock_irqsave() raise the interrupt
level to PIL_NORMAL_MAX (14) and intentionally do not block performance
counter interrupts, which arrive at PIL_NMI (15).
But some sections of code are "super critical" with respect to perf
because the perf_callchain_user() path accesses user space and may cause
TLB activity as well as faults as it unwinds the user stack.
One particular critical section occurs in switch_mm:
spin_lock_irqsave(&mm->context.lock, flags);
load_secondary_context(mm);
tsb_context_switch(mm);
spin_unlock_irqrestore(&mm->context.lock, flags);
If a perf interrupt arrives in between load_secondary_context() and
tsb_context_switch(), then perf_callchain_user() could execute with
the context ID of one process, but with an active TSB for a different
process. When the user stack is accessed, it is very likely to
incur a TLB miss, since the h/w context ID has been changed. The TLB
will then be reloaded with a translation from the TSB for one process,
but using a context ID for another process. This exposes memory from
one process to another, and since it is a mapping for stack memory,
this usually causes the new process to crash quickly.
This super critical section needs more protection than is provided
by spin_lock_irqsave() since perf interrupts must not be allowed in.
Since __tsb_context_switch already goes through the trouble of
disabling interrupts completely, we fix this by moving the secondary
context load down into this better protected region.
Orabug: 25577560
Signed-off-by: Dave Aldridge <david.j.aldridge@oracle.com>
Signed-off-by: Rob Gardner <rob.gardner@oracle.com>
[ Upstream commit c27927e372f0785f3303e8fad94b85945e2c97b7 ]
Updates to tp_reserve can race with reads of the field in
packet_set_ring. Avoid this by holding the socket lock during
updates in setsockopt PACKET_RESERVE.
This bug was discovered by syzkaller.
Fixes: 8913336a7e8d ("packet: add PACKET_RESERVE sockopt")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 8d63bee643f1fb53e472f0e135cae4eb99d62d19 ]
skb_warn_bad_offload triggers a warning when an skb enters the GSO
stack at __skb_gso_segment that does not have CHECKSUM_PARTIAL
checksum offload set.
Commit b2504a5dbef3 ("net: reduce skb_warn_bad_offload() noise")
observed that SKB_GSO_DODGY producers can trigger the check and
that passing those packets through the GSO handlers will fix it
up. But, the software UFO handler will set ip_summed to
CHECKSUM_NONE.
When __skb_gso_segment is called from the receive path, this
triggers the warning again.
Make UFO set CHECKSUM_UNNECESSARY instead of CHECKSUM_NONE. On
Tx these two are equivalent. On Rx, this better matches the
skb state (checksum computed), as CHECKSUM_NONE here means no
checksum computed.
See also this thread for context:
http://patchwork.ozlabs.org/patch/799015/
Fixes: b2504a5dbef3 ("net: reduce skb_warn_bad_offload() noise")
[ Upstream commit b0a0c2566f28e71e5e32121992ac8060cec75510 ]
While testing some other work that required JIT modifications, I
run into test_bpf causing a hang when JIT enabled on s390. The
problematic test case was the one from ddc665a4bb4b (bpf, arm64:
fix jit branch offset related to ldimm64), and turns out that we
do have a similar issue on s390 as well. In bpf_jit_prog() we
update next instruction address after returning from bpf_jit_insn()
with an insn_count. bpf_jit_insn() returns either -1 in case of
error (e.g. unsupported insn), 1 or 2. The latter is only the
case for ldimm64 due to spanning 2 insns, however, next address
is only set to i + 1 not taking actual insn_count into account,
thus fix is to use insn_count instead of 1. bpf_jit_enable in
mode 2 provides also disasm on s390:
Before fix:
000003ff800349b6: a7f40003 brc 15,3ff800349bc ; target
000003ff800349ba: 0000 unknown
000003ff800349bc: e3b0f0700024 stg %r11,112(%r15)
000003ff800349c2: e3e0f0880024 stg %r14,136(%r15)
000003ff800349c8: 0db0 basr %r11,%r0
000003ff800349ca: c0ef00000000 llilf %r14,0
000003ff800349d0: e320b0360004 lg %r2,54(%r11)
000003ff800349d6: e330b03e0004 lg %r3,62(%r11)
000003ff800349dc: ec23ffeda065 clgrj %r2,%r3,10,3ff800349b6 ; jmp
000003ff800349e2: e3e0b0460004 lg %r14,70(%r11)
000003ff800349e8: e3e0b04e0004 lg %r14,78(%r11)
000003ff800349ee: b904002e lgr %r2,%r14
000003ff800349f2: e3b0f0700004 lg %r11,112(%r15)
000003ff800349f8: e3e0f0880004 lg %r14,136(%r15)
000003ff800349fe: 07fe bcr 15,%r14
After fix:
000003ff80ef3db4: a7f40003 brc 15,3ff80ef3dba
000003ff80ef3db8: 0000 unknown
000003ff80ef3dba: e3b0f0700024 stg %r11,112(%r15)
000003ff80ef3dc0: e3e0f0880024 stg %r14,136(%r15)
000003ff80ef3dc6: 0db0 basr %r11,%r0
000003ff80ef3dc8: c0ef00000000 llilf %r14,0
000003ff80ef3dce: e320b0360004 lg %r2,54(%r11)
000003ff80ef3dd4: e330b03e0004 lg %r3,62(%r11)
000003ff80ef3dda: ec230006a065 clgrj %r2,%r3,10,3ff80ef3de6 ; jmp
000003ff80ef3de0: e3e0b0460004 lg %r14,70(%r11)
000003ff80ef3de6: e3e0b04e0004 lg %r14,78(%r11) ; target
000003ff80ef3dec: b904002e lgr %r2,%r14
000003ff80ef3df0: e3b0f0700004 lg %r11,112(%r15)
000003ff80ef3df6: e3e0f0880004 lg %r14,136(%r15)
000003ff80ef3dfc: 07fe bcr 15,%r14
test_bpf.ko suite runs fine after the fix.
Fixes: 054623105728 ("s390/bpf: Add s390x eBPF JIT compiler backend")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Tested-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
[ Upstream commit ed254971edea92c3ac5c67c6a05247a92aa6075e ]
If the sender switches the congestion control during ECN-triggered
cwnd-reduction state (CA_CWR), upon exiting recovery cwnd is set to
the ssthresh value calculated by the previous congestion control. If
the previous congestion control is BBR that always keep ssthresh
to TCP_INIFINITE_SSTHRESH, cwnd ends up being infinite. The safe
step is to avoid assigning invalid ssthresh value when recovery ends.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
__ip_append_data and ip_finish_output
[ Upstream commit 0a28cfd51e17f4f0a056bcf66bfbe492c3b99f38 ]
There is an inconsistent conditional judgement in __ip_append_data and
ip_finish_output functions, the variable length in __ip_append_data just
include the length of application's payload and udp header, don't include
the length of ip header, but in ip_finish_output use
(skb->len > ip_skb_dst_mtu(skb)) as judgement, and skb->len include the
length of ip header.
That causes some particular application's udp payload whose length is
between (MTU - IP Header) and MTU were fragmented by ip_fragment even
though the rst->dev support UFO feature.
Add the length of ip header to length in __ip_append_data to keep
consistent conditional judgement as ip_finish_output for ip fragment.
Signed-off-by: Zheng Li <james.z.li@ericsson.com>
[ Upstream commit f073bdc51771f5a5c7a8d1191bfc3ae371d44de7 ]
The VM_BUG_ON() check in move_freepages() checks whether the node id of
a page matches the node id of its zone. However, it does this before
having checked whether the struct page pointer refers to a valid struct
page to begin with. This is guaranteed in most cases, but may not be
the case if CONFIG_HOLES_IN_ZONE=y.
So reorder the VM_BUG_ON() with the pfn_valid_within() check.
Link: http://lkml.kernel.org/r/1481706707-6211-2-git-send-email-ard.biesheuvel@linaro.org
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Hanjun Guo <hanjun.guo@linaro.org>
Cc: Yisheng Xie <xieyisheng1@huawei.com>
Cc: Robert Richter <rrichter@cavium.com>
Cc: James Morse <james.morse@arm.com>
[ Upstream commit 2d39b3cd34e6d323720d4c61bd714f5ae202c022 ]
Since commit 00cd5c37afd5 ("ptrace: permit ptracing of /sbin/init") we
can now trace init processes. init is initially protected with
SIGNAL_UNKILLABLE which will prevent fatal signals such as SIGSTOP, but
there are a number of paths during tracing where SIGNAL_UNKILLABLE can
be implicitly cleared.
This can result in init becoming stoppable/killable after tracing. For
example, running:
while true; do kill -STOP 1; done &
strace -p 1
and then stopping strace and the kill loop will result in init being
left in state TASK_STOPPED. Sending SIGCONT to init will resume it, but
init will now respond to future SIGSTOP signals rather than ignoring
them.
Make sure that when setting SIGNAL_STOP_CONTINUED/SIGNAL_STOP_STOPPED
that we don't clear SIGNAL_UNKILLABLE.
Link: http://lkml.kernel.org/r/20170104122017.25047-1-jamie.iles@oracle.com
Signed-off-by: Jamie Iles <jamie.iles@oracle.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
[ Upstream commit da0510c47519fe0999cffe316e1d370e29f952be ]
The build of frv allmodconfig was failing with the errors like:
/tmp/cc0JSPc3.s: Assembler messages:
/tmp/cc0JSPc3.s:1839: Error: symbol `.LSLT0' is already defined
/tmp/cc0JSPc3.s:1842: Error: symbol `.LASLTP0' is already defined
/tmp/cc0JSPc3.s:1969: Error: symbol `.LELTP0' is already defined
/tmp/cc0JSPc3.s:1970: Error: symbol `.LELT0' is already defined
Commit 866ced950bcd ("kbuild: Support split debug info v4") introduced
splitting the debug info and keeping that in a separate file. Somehow,
the frv-linux gcc did not like that and I am guessing that instead of
splitting it started copying. The first report about this is at:
https://lists.01.org/pipermail/kbuild-all/2015-July/010527.html.
I will try and see if this can work with frv and if still fails I will
open a bug report with gcc. But meanwhile this is the easiest option to
solve build failure of frv.
Fixes: 866ced950bcd ("kbuild: Support split debug info v4")
Link: http://lkml.kernel.org/r/1482062348-5352-1-git-send-email-sudipm.mukherjee@gmail.com
Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
[ Upstream commit bb1107f7c6052c863692a41f78c000db792334bf ]
Andrey Konovalov has reported the following warning triggered by the
syzkaller fuzzer.
WARNING: CPU: 1 PID: 9935 at mm/page_alloc.c:3511 __alloc_pages_nodemask+0x159c/0x1e20
Kernel panic - not syncing: panic_on_warn set ...
CPU: 1 PID: 9935 Comm: syz-executor0 Not tainted 4.9.0-rc7+ #34
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
__alloc_pages_slowpath mm/page_alloc.c:3511
__alloc_pages_nodemask+0x159c/0x1e20 mm/page_alloc.c:3781
alloc_pages_current+0x1c7/0x6b0 mm/mempolicy.c:2072
alloc_pages include/linux/gfp.h:469
kmalloc_order+0x1f/0x70 mm/slab_common.c:1015
kmalloc_order_trace+0x1f/0x160 mm/slab_common.c:1026
kmalloc_large include/linux/slab.h:422
__kmalloc+0x210/0x2d0 mm/slub.c:3723
kmalloc include/linux/slab.h:495
ep_write_iter+0x167/0xb50 drivers/usb/gadget/legacy/inode.c:664
new_sync_write fs/read_write.c:499
__vfs_write+0x483/0x760 fs/read_write.c:512
vfs_write+0x170/0x4e0 fs/read_write.c:560
SYSC_write fs/read_write.c:607
SyS_write+0xfb/0x230 fs/read_write.c:599
entry_SYSCALL_64_fastpath+0x1f/0xc2
The issue is caused by a lack of size check for the request size in
ep_write_iter which should be fixed. It, however, points to another
problem, that SLUB defines KMALLOC_MAX_SIZE too large because the its
KMALLOC_SHIFT_MAX is (MAX_ORDER + PAGE_SHIFT) which means that the
resulting page allocator request might be MAX_ORDER which is too large
(see __alloc_pages_slowpath).
The same applies to the SLOB allocator which allows even larger sizes.
Make sure that they are capped properly and never request more than
MAX_ORDER order.
Link: http://lkml.kernel.org/r/20161220130659.16461-2-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 270c8cf1cacc69cb8d99dea812f06067a45e4609 ]
ARM has a few system calls (most notably mmap) for which the names of
the functions which are referenced in the syscall table do not match the
names of the syscall tracepoints. As a consequence of this, these
tracepoints are not made available. Implement
arch_syscall_match_sym_name to fix this and allow tracing even these
system calls.
Signed-off-by: Rabin Vincent <rabinv@axis.com>
[ Upstream commit 6bf6b0aa3da84a3d9126919a94c49c0fb7ee2fb3 ]
If blk_mq_init_queue() returns an error, it gets assigned to
vblk->disk->queue. Then, when we call put_disk(), we end up calling
blk_put_queue() with the ERR_PTR, causing a bad dereference. Fix it by
only assigning to vblk->disk->queue on success.
Signed-off-by: Omar Sandoval <osandov@fb.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit c7702b8c22712a06080e10f1d2dee1a133ec8809 ]
There is a race condition with qla2xxx optrom functions where one thread
might modify optrom buffer, optrom_state while other thread is still
reading from it.
In couple of crashes, it was found that we had successfully passed the
following 'if' check where we confirm optrom_state to be
QLA_SREADING. But by the time we acquired mutex lock to proceed with
memory_read_from_buffer function, some other thread/process had already
modified that option rom buffer and optrom_state from QLA_SREADING to
QLA_SWAITING. Then we got ha->optrom_buffer 0x0 and crashed the system:
if (ha->optrom_state != QLA_SREADING)
return 0;
mutex_lock(&ha->optrom_mutex);
rval = memory_read_from_buffer(buf, count, &off, ha->optrom_buffer,
ha->optrom_region_size);
mutex_unlock(&ha->optrom_mutex);
With current optrom function we get following crash due to a race
condition:
[ 1479.466679] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 1479.466707] IP: [<ffffffff81326756>] memcpy+0x6/0x110
[ 1479.473673] Call Trace:
[ 1479.474296] [<ffffffff81225cbc>] ? memory_read_from_buffer+0x3c/0x60
[ 1479.474941] [<ffffffffa01574dc>] qla2x00_sysfs_read_optrom+0x9c/0xc0 [qla2xxx]
[ 1479.475571] [<ffffffff8127e76b>] read+0xdb/0x1f0
[ 1479.476206] [<ffffffff811fdf9e>] vfs_read+0x9e/0x170
[ 1479.476839] [<ffffffff811feb6f>] SyS_read+0x7f/0xe0
[ 1479.477466] [<ffffffff816964c9>] system_call_fastpath+0x16/0x1b
Below patch modifies qla2x00_sysfs_read_optrom,
qla2x00_sysfs_write_optrom functions to get the mutex_lock before
checking ha->optrom_state to avoid similar crashes.
The patch was applied and tested and same crashes were no longer
observed again.
Tested-by: Milan P. Gandhi <mgandhi@redhat.com>
Signed-off-by: Milan P. Gandhi <mgandhi@redhat.com>
Reviewed-by: Laurence Oberman <loberman@redhat.com>
Acked-by: Himanshu Madhani <himanshu.madhani@cavium.com>
[ Upstream commit fac69d0efad08fc15e4dbfc116830782acc0dc9a ]
Add the missing declarations of basic string functions to string.h to allow
a clean build.
Fixes: 5be865661516 ("String-handling functions for the new x86 setup code.")
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Link: http://lkml.kernel.org/r/1483781911-21399-1-git-send-email-hofrat@osadl.org
[ Upstream commit f5992b72ebe0dde488fa8f706b887194020c66fc ]
The driver's ndo_get_stats64() method is not always called under RTNL.
So it can race with driver close or ethtool reconfigurations. Fix the
race condition by taking tp->lock spinlock in tg3_free_consistent()
when freeing the tp->hw_stats memory block. tg3_get_stats64() is
already taking tp->lock.
Reported-by: Wang Yufen <wangyufen@huawei.com>
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
[ Upstream commit 0f1f9cbc04dbb3cc310f70a11cba0cf1f2109d9c ]
The R8A7740 GEther controller supports the packet checksum offloading
but the 'hw_crc' (bad name, I'll fix it) flag isn't set in the R8A7740
data, thus CSMR isn't cleared...
Fixes: 73a0d907301e ("net: sh_eth: add support R8A7740")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit 93be2b74279c15c2844684b1a027fdc71dd5d9bf ]
gcc-7 complains that wl3501_cs passes NULL into a function that
then uses the argument as the input for memcpy:
drivers/net/wireless/wl3501_cs.c: In function 'wl3501_get_scan':
include/net/iw_handler.h:559:3: error: argument 2 null where non-null expected [-Werror=nonnull]
memcpy(stream + point_len, extra, iwe->u.data.length);
This works fine here because iwe->u.data.length is guaranteed to be 0
and the memcpy doesn't actually have an effect.
Making the length check explicit avoids the warning and should have
no other effect here.
Also check the pointer itself, since otherwise we get warnings
elsewhere in the code.
[ Upstream commit 9d53caec84c7c5700e7c1ed744ea584fff55f9ac ]
A large sun4v SPARC system may have moments of intensive xcall activities,
usually caused by unmapping many pages on many CPUs concurrently. This can
flood receivers with CPU mondo interrupts for an extended period, causing
some unlucky senders to hit send-mondo timeout. This problem gets worse
as cpu count increases because sometimes mappings must be invalidated on
all CPUs, and sometimes all CPUs may gang up on a single CPU.
But a busy system is not a broken system. In the above scenario, as long
as the receiver is making forward progress processing mondo interrupts,
the sender should continue to retry.
This patch implements the receiver's forward progress meter by introducing
a per cpu counter 'cpu_mondo_counter[cpu]' where 'cpu' is in the range
of 0..NR_CPUS. The receiver increments its counter as soon as it receives
a mondo and the sender tracks the receiver's counter. If the receiver has
stopped making forward progress when the retry limit is reached, the sender
declares send-mondo-timeout and panic; otherwise, the receiver is allowed
to keep making forward progress.
In addition, it's been observed that PCIe hotplug events generate Correctable
Errors that are handled by hypervisor and then OS. Hypervisor 'borrows'
a guest cpu strand briefly to provide the service. If the cpu strand is
simultaneously the only cpu targeted by a mondo, it may not be available
for the mondo in 20msec, causing SUN4V mondo timeout. It appears that 1 second
is the agreed wait time between hypervisor and guest OS, this patch makes
the adjustment.
Orabug: 25476541
Orabug: 26417466
Signed-off-by: Jane Chu <jane.chu@oracle.com>
Reviewed-by: Steve Sistare <steven.sistare@oracle.com>
Reviewed-by: Anthony Yznaga <anthony.yznaga@oracle.com>
Reviewed-by: Rob Gardner <rob.gardner@oracle.com>
Reviewed-by: Thomas Tai <thomas.tai@oracle.com>
[ Upstream commit dfa523ae9f2542bee4cddaea37b3be3e157f6e6b ]
Add a flag to indicate if a queue is rate-limited. Test the flag in
NAPI poll handler and avoid rescheduling the queue if true, otherwise
we risk locking up the host. The rescheduling will be done in the
timer callback function.
Reported-by: Jean-Louis Dupond <jean-louis@dupond.be>
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Tested-by: Jean-Louis Dupond <jean-louis@dupond.be>
Reviewed-by: Paul Durrant <paul.durrant@citrix.com>
