2008-06-16Merge branch 'linus' into x86/irqstatstip-x86-irqstats-2008-06-16_09.27_MonIngo Molnar
2008-06-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6tip-x86-delay-2008-06-23_09.02_Montip-sched-2008-06-16_09.25_Montip-sched-2008-06-16_09.15_Montip-pci-for-jesse-2008-06-16_09.25_Montip-mm-xen-2008-06-23_08.59_MonLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: ide-generic: don't probe all legacy ISA IDE ports by default ide-cs: fix releasing I/O resources ide-cs: fix probing and add warm-plug support ide-pmac: remove bogus comment about pmac_ide_setup_device() ide-pmac: add ->cable_detect method ide-pmac: bugfix for media-bay support rework opti621: add PIO 4 support opti621: use pre-calculated PIO timings opti621: program devices timings separately in ->set_pio_mode opti621: use PCI clock value provided by controller opti621: remove DMA support opti621: disable read prefetch
2008-06-15virtio: Complete feature negotation before updating statusMark McLoughlin
lguest (in rusty's use-tun-ringfd patch) assumes that the guest has updated its feature bits before setting its status to VIRTIO_CONFIG_S_DRIVER_OK. That's pretty reasonable, so let's make it so. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-15ide-generic: don't probe all legacy ISA IDE ports by defaultBartlomiej Zolnierkiewicz
We can't probe all legacy ISA IDE ports by default as the resources may be occupied by other ISA devices. Add "probe_mask" module parameter and probe only first two ISA IDE ports by default leaving the decision about probing the rest to the user (systems with ISA ide2-6 should be very, very rare). This fixes a regression caused by: commit 343a3451e20314d5959b59b992e33fbaadfe52bf Author: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Date: Tue Jun 10 20:56:36 2008 +0200 ide-generic: add missing hwif->chipset setup ... Reported-by: Mikael Pettersson <mikpe@it.uu.se> Bisected-by: Mikael Pettersson <mikpe@it.uu.se> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-15ide-cs: fix releasing I/O resourcesBartlomiej Zolnierkiewicz
hwif content is already freed after ide_release() call so cache hwif->io_ports.{data,ctl}_addr in local variables in ide_detach(). This fixes post-2.6.25 regression. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-15ide-cs: fix probing and add warm-plug supportBartlomiej Zolnierkiewicz
* Fix probing by using ide_port_scan() and moving "retry loop" from ide_config() to idecs_register(). * Don't fail probe if there are no devices attached to a port. * Remove (now redundant) error message from ide_config(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-15ide-pmac: remove bogus comment about pmac_ide_setup_device()Bartlomiej Zolnierkiewicz
Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-15ide-pmac: add ->cable_detect methodBartlomiej Zolnierkiewicz
Add ->cable_detect method and remove no longer needed pmif->cable_80 flag (there is also no need to mask ->udma_mask now). This fixes: - forced ignoring of cable detection (needed for some CF devices & debug) - cable detection for warm-plug Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-15ide-pmac: bugfix for media-bay support reworkBartlomiej Zolnierkiewicz
Fix bug introduced by: commit 2dde7861afa23cd59db83515cb0b810b92b220aa Author: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Date: Fri Apr 18 00:46:23 2008 +0200 ide: rework PowerMac media-bay support (take 2) ... [ Yeah, I suck. ] bay->cd_index shouldn't be changed if IDE devices are not present or retry operations won't happen. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-15opti621: add PIO 4 supportBartlomiej Zolnierkiewicz
* Add PIO 4 support. While at it: * Use a single struct ide_port_info instance for OPTi621 and OPTi621X. Based on a bugreport from Juergen Kosel & inspired by pata_opti.c code. Tested-by: Juergen Kosel <juergen.kosel@gmx.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-15opti621: use pre-calculated PIO timingsBartlomiej Zolnierkiewicz
* Use pre-calculated PIO timings in ->set_pio_mode. * Remove no longer needed compute_clocks(), cmpt_clk(), struct pio_clocks_s, PIO_* defines and OPTI621_DEBUG define. There should be no functional changes caused by this patch. Based on a bugreport from Juergen Kosel & inspired by pata_opti.c code. Tested-by: Juergen Kosel <juergen.kosel@gmx.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-15opti621: program devices timings separately in ->set_pio_modeBartlomiej Zolnierkiewicz
* Set drive->drive_data to 'pio + XFER_PIO_0' instead of 'pio', then simplify selecting maximum adress setup timing. * Remove no longer needed compute_pios() and opti621_port_init_devs(). * Program devices timings separately in ->set_pio_mode. Based on a bugreport from Juergen Kosel & inspired by pata_opti.c code. Tested-by: Juergen Kosel <juergen.kosel@gmx.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-15opti621: use PCI clock value provided by controllerBartlomiej Zolnierkiewicz
Use PCI clock value provided by controller instead of depending on a default (or user supplied) value. Based on a bugreport from Juergen Kosel & inspired by pata_opti.c code. Tested-by: Juergen Kosel <juergen.kosel@gmx.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-15opti621: remove DMA supportBartlomiej Zolnierkiewicz
These controllers don't support DMA. Based on a bugreport from Juergen Kosel & inspired by pata_opti.c code. Tested-by: Juergen Kosel <juergen.kosel@gmx.de> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-15opti621: disable read prefetchBartlomiej Zolnierkiewicz
This fixes 2.6.25 regression (kernel.org bugzilla bug #10723) caused by: commit 912fb29a36a7269ac1c4a4df45bc0ac1d2637972 Author: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Date: Fri Oct 19 00:30:11 2007 +0200 opti621: always tune PIO ... Based on a bugreport from Juergen Kosel & inspired by pata_opti.c code. Bisected-by: Juergen Kosel <juergen.kosel@gmx.de> Tested-by: Juergen Kosel <juergen.kosel@gmx.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: fixup write combine comment in pci_mmap_resource x86: PAT export resource_wc in pci sysfs x86, pci-dma.c: don't always add __GFP_NORETRY to gfp suspend-vs-iommu: prevent suspend if we could not resume x86: pci-dma.c: use __GFP_NO_OOM instead of __GFP_NORETRY pci, x86: add workaround for bug in ASUS A7V600 BIOS (rev 1005) PCI: use dev_to_node in pci_call_probe PCI: Correct last two HP entries in the bfsort whitelist
2008-06-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: update my email address parisc: fix miscompilation of ip_fast_csum with gcc >= 4.3 parisc: fix off by one in setup_sigcontext32 parisc: export empty_zero_page parisc: export copy_user_page_asm parisc: move head.S to head.text section Revert "parisc: fix trivial section name warnings"
2008-06-13parisc: update my email addressKyle McMartin
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13parisc: fix miscompilation of ip_fast_csum with gcc >= 4.3Kyle McMartin
ip_fast_csum needs an asm "memory" clobber, otherwise the aggressive optimizations in gcc-4.3 cause it to be miscompiled. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13parisc: fix off by one in setup_sigcontext32Kyle McMartin
Thankfully, the values were irrelevant... Spotted by newer gcc. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13parisc: export empty_zero_pageKyle McMartin
Needed by ext4 when built as a module. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13parisc: export copy_user_page_asmKyle McMartin
Needed by fuse (via copy_highpage). Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13parisc: move head.S to head.text sectionKyle McMartin
And explicitly list it in vmlinux.lds... Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13Revert "parisc: fix trivial section name warnings"Kyle McMartin
This reverts commit bd3bb8c15b9a80dbddfb7905b237a4a11a4725b4. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: ahci: Workaround HW bug for SB600/700 SATA controller PMP support ahci: workarounds for mcp65
2008-06-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: tcp: Revert 'process defer accept as established' changes. ipv6: Fix duplicate initialization of rawv6_prot.destroy bnx2x: Updating the Maintainer net: Eliminate flush_scheduled_work() calls while RTNL is held. drivers/net/r6040.c: correct bad use of round_jiffies() fec_mpc52xx: MPC52xx_MESSAGES_DEFAULT: 2nd NETIF_MSG_IFDOWN => IFUP ipg: fix receivemode IPG_RM_RECEIVEMULTICAST{,HASH} in ipg_nic_set_multicast_list() netfilter: nf_conntrack: fix ctnetlink related crash in nf_nat_setup_info() netfilter: Make nflog quiet when no one listen in userspace. ipv6: Fail with appropriate error code when setting not-applicable sockopt. ipv6: Check IPV6_MULTICAST_LOOP option value. ipv6: Check the hop limit setting in ancillary data. ipv6 route: Fix route lifetime in netlink message. ipv6 mcast: Check address family of gf_group in getsockopt(MS_FILTER). dccp: Bug in initial acknowledgment number assignment dccp ccid-3: X truncated due to type conversion dccp ccid-3: TFRC reverse-lookup Bug-Fix dccp ccid-2: Bug-Fix - Ack Vectors need to be ignored on request sockets dccp: Fix sparse warnings dccp ccid-3: Bug-Fix - Zero RTT is possible
2008-06-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: get leo framebuffer working
2008-06-13ahci: Workaround HW bug for SB600/700 SATA controller PMP supportShane Huang
There is one bug in ATI SATA PMP of SB600 and SB700 old revision, which leads to soft reset failure. This patch can fix the bug. Signed-off-by: Shane Huang <shane.huang@amd.com> Acked-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-13ahci: workarounds for mcp65Tejun Heo
MCP65 ahci can do NCQ but doesn't set the CAP bit and rev A0 and A1 can't do MSI but have MSI capability. Implement AHCI_HFLAG_YES_NCQ and apply appropriate workarounds. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Peer Chen <pchen@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 5091/1: Add missing bitfield include to regs-lcd.h [ARM] 5090/1: Correct pxafb palette typo error [ARM] 5077/1: spi: fix list scan success verification in PXA ssp driver
2008-06-12rtc: Ramtron FM3130 RTC supportSergey Lapin
Ramtron FM3130 is a chip with two separate devices inside, RTC clock and FRAM. This driver provides only RTC functionality. This chip is met in lots of custom boards with AT91SAMXXXX CPU I work with, is cheap and in no way better or worse than any other RTC on market. While it is mostly met on much smaller devices, I think it is great to have it supported in Linux. Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12rtc: make HPET_RTC_IRQ track HPET_EMULATE_RTCDavid Brownell
More Kconfig tweaks related to the legacy PC RTC code: - Describe the legacy PC RTC driver as such ... it's never quite been clear that this driver is for PC RTCs, and now it's fair to call this the "legacy" driver. - Force it to understand about HPET stealing its IRQs ... kernel code does this always when HPET is in use, there should be no option for users to goof up the config. This seems to fix kernel bugzilla #10729. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12provide rtc_cmos platform deviceStas Sergeev
Recently (around 2.6.25) I've noticed that RTC no longer works for me. It turned out this is because I use pnpacpi=off kernel option to work around the parport_pc bugs. I always did so, but RTC used to work fine in the past, and now it have regressed. The patch fixes the problem by creating the platform device for the RTC when PNP is disabled. This may also help running the PNP-enabled kernel on an older PCs. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Cc: David Brownell <david-b@pacbell.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12radix-tree: fix small lockless radix-tree bugNick Piggin
We shrink a radix tree when its root node has only one child, in the left most slot. The child becomes the new root node. To perform this operation in a manner compatible with concurrent lockless lookups, we atomically switch the root pointer from the parent to its child. However a concurrent lockless lookup may now have loaded a pointer to the parent (and is presently deciding what to do next). For this reason, we also have to keep the parent node in a valid state after shrinking the tree, until the next RCU grace period -- otherwise this lookup with the parent pointer may not do the right thing. Notably, we need to keep the child in the left most slot there in case that is requested by the lookup. This is all pretty standard RCU stuff. It is worth repeating because in my eagerness to obey the radix tree node constructor scheme, I had broken it by zeroing the radix tree node before the grace period. What could happen is that a lookup can load the parent pointer, then decide it wants to follow the left most child slot, only to find the slot contained NULL due to the concurrent shrinker having zeroed the parent node before waiting for a grace period. The lookup would return a false negative as a result. Fix it by doing that clearing in the RCU callback. I would normally want to rip out the constructor entirely, but radix tree nodes are one of those places where they make sense (only few cachelines will be touched soon after allocation). This was never actually found in any lockless pagecache testing or by the test harness, but by seeing the odd problem with my scalable vmap rewrite. I have not tickled the test harness into reproducing it yet, but I'll keep working at it. Fortunately, it is not a problem anywhere lockless pagecache is used in mainline kernels (pagecache probe is not a guarantee, and brd does not have concurrent lookups and deletes). Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12console keyboard mapping broken by 04c71976Jiri Bohac
Several console keyboard maps are broken since commit 04c71976500352d02f60616d2b960267d8c5fe24 Author: Samuel Thibault <samuel.thibault@ens-lyon.org> Date: Tue Oct 16 23:27:04 2007 -0700 unicode diacritics support because that changeset made k_self consider the value as a latin1 character when in Unicode mode, which is wrong; k_self should still take the console map into account. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12/proc/sysvipc/shm: fix 32-bit truncation of segment sizesPaul Menage
sysvipc_shm_proc_show() picks between format strings (based on the expected maximum length of a SHM segment) in a way that prevents gcc from performing format checks on the seq_printf() parameters. This hid two format errors - shp->shm_segsz and shp->shm_nattach are both unsigned long, but were being printed as unsigned int and signed int respectively. This leads to 32-bit truncation of SHM segment sizes reported in /proc/sysvipc/shm. (And for nattach, but that's less of a problem for most users). This patch makes the format string directly visible to gcc's format specifier checker, and fixes the two broken format specifiers. Signed-off-by: Paul Menage <menage@google.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12pagemap: fix large pages in pagemapDave Hansen
We were walking right into huge page areas in the pagemap walker, and calling the pmds pmd_bad() and clearing them. That leaked huge pages. Bad. This patch at least works around that for now. It ignores huge pages in the pagemap walker for the time being, and won't leak those pages. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12pagemap: pass mm into pagewalkersDave Hansen
We need this at least for huge page detection for now, because powerpc needs the vm_area_struct to be able to determine whether a virtual address is referring to a huge page (its pmd_huge() doesn't work). It might also come in handy for some of the other users. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12driver/char/generic_nvram: fix bannerPhilippe De Muyter
The generic nvram driver announces itself as 'Macintosh non-volatile memory driver' instead of 'Generic non-volatile memory driver'. Fix that. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12drivers/video/cirrusfb: fix RAM address printkPhilippe De Muyter
In the cirrusfb driver, the RAM address printk has a superfluous 'x' that could be interpreted as "don't care", while it is actually a typo. Fix that. [akpm@linux-foundation.org: join the two printk strings to make it atomic] Signed-off-by: Philippe De Muyter <phdm@macqel.be> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12intel_rng: make device not found a warningStephen Hemminger
Since many distros load this driver by default (throw it against the wall and see what sticks method). Change the error message severity level to avoid alarming users. Isn't it annoying when users actually read the error logs... Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Cc: Michael Buesch <mb@bu3sch.de> Acked-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12drivers/isdn/sc/ioctl.c: add missing kfreeJulia Lawall
spid has been allocated in this function and so should be freed before leaving it, as in the other error handling cases. The semantic match that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) @r exists@ expression E,E1; statement S; position p1,p2,p3; @@ E =@p1 \(kmalloc\|kcalloc\|kzalloc\)(...) ... when != E = E1 if (E == NULL || ...) S ... when != E = E1 if@p2 (...) { ... when != kfree(E) } ... when != E = E1 kfree@p3(E); @forall@ position r.p2; expression r.E; int E1 != 0; @@ * if@p2 (...) { ... when != kfree(E) when strict return E1; } Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12mmc: wbsd: initialize tasklets before requesting interruptChuck Ebbert
With CONFIG_DEBUG_SHIRQ set we will get an interrupt as soon as we allocate one. Tasklets may be scheduled in the interrupt handler but they will be initialized after the handler returns, causing a BUG() in kernel/softirq.c when they run. Should fix this Fedora bug report: https://bugzilla.redhat.com/show_bug.cgi?id=449817 Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12MAINTAINERS: update maintainership of pxa2xx/pxa3xxEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Russell King <rmk@arm.linux.org.uk> Acked-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12uml: work around broken host PTRACE_SYSEMUJeff Dike
Fedora broke PTRACE_SYSEMU again, and UML crashes as a result when it doesn't need to. This patch makes the PTRACE_SYSEMU check fail gracefully and makes UML fall back to PTRACE_SYSCALL. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12uml: remove include of asm/user.hJeff Dike
I allowed an include of asm/user.h to sneak back in. This patch replaces it with sys/user.h. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12rtc-at32ap700x: fix bug in at32_rtc_readalarm()Haavard Skinnemoen
alarm->pending indicates whether there's an alarm that has actually been triggered, not whether we're waiting for it. alarm->enabled indicates that. Also add missing locking around reading the RTC registers. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12m68knommu: init coldfire timer TRR with n - 1, not nPhilippe De Muyter
The coldfire timer must be initialised to n - 1 if we want it to count n cycles between each tick interrupt. This was already fixed, but has been lost with the conversion to GENERIC_TIMER. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12kprobes: fix error checking of batch registrationMasami Hiramatsu
Fix error checking routine to catch an error which occurs in first __register_*probe(). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: David Miller <davem@davemloft.net> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12cciss: add new hardware supportMike Miller
Add support for the next generation of HP Smart Array SAS/SATA controllers. Shipping date is late Fall 2008. Bump the driver version to 3.6.20 to reflect the new hardware support from patch 1 of this set. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
