* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] pxa: fix tosa.c build error
[ARM] 5067/1: _raw_write_can_lock macro bugfix
[ARM] 5070/1: pxa: add GPIO104_PSKTSEL to pxa27x MFP configuration
[ARM] 5068/1: PXA2xx Additional gpio definitions
[ARM] 5066/2: EM-X270: Fix DM9000 IRQ flags initialisation
[ARM] 5065/2: CM-X270: Fix DM9000 IRQ flags initialisation
[ARM] 5062/1: pxa: remove unused definition of CONFIG_ARCH_COTULLA_IDP
[ARM] 5060/1: remove unnecessary include of asm/io.h
[ARM] fix AT91 include loops
Fairly simple. "dev_use" was being allocated as a zero length array
because of bad math on 64-bit systems, causing a crash in
find_first_zero_bit(). One-liner follows:
Signed-off-by: Ben Collins <ben.collins@canonical.com>
Acked-by: Pierre Ossman <drzeus@drzeus.cx>
* git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (48 commits)
V4L/DVB (8001): dib0070: fix dib0070_attach when !CONFIG_DVB_TUNER_DIB0070
V4L/DVB (8000): tda827x: fix NULL pointer in tda827xa_lna_gain
V4L/DVB (7990): Fix entry for PowerColor RA 330 and make it run with firmware version 2.7
V4L/DVB (7983): tda18271_calc_rf_cal must return the return value of tda18271_lookup_map
V4L/DVB (7978): cx18: explicitly test for XC2028 tuner
V4L/DVB (7977): cx18: fix init order and remove duplicate open_on_first_use.
V4L/DVB (7975): saa7134_empress
V4L/DVB (7974): fix MEDIA_TUNER && FW_LOADER build error
V4L/DVB (7972): or51132.c: unaligned
V4L/DVB (7971): usb: unaligned
V4L/DVB (7970): mix trivial endianness annotations
V4L/DVB (7969): m920x: unaligned access
V4L/DVB (7968): zoran: endianness annotations
V4L/DVB (7967): bt8xx: unaligned access
V4L/DVB (7966): cx18: direct dereferencing of iomem
V4L/DVB (7965): annotate bcx_riscmem
V4L/DVB (7964): cx18 iomem annotations
V4L/DVB (7963): ivtv: trivial annotations
V4L/DVB (7962): ttusb endianness annotations and fixes
V4L/DVB (7961): fix endianness bug in dib0700_devices.c
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
Fix divide by zero error in build_clear_page() and build_copy_page()
[MIPS] Fix typo in header guard
[MIPS] Fix build error - Delete debugging crap that crept in with CMP
[MIPS] Add accessors for random register.
[MIPS] IP27: misc fixes
[MIPS] IP27: Fix clockevent setup
[MIPS] IP27: Fix bootmem memory setup
[MIPS] remove CONFIG_CPU_R4000 line from Makefile
[MIPS] Fix check for valid stack pointer during backtrace
[MIPS] Add missing braces to pte_mkyoung
[MIPS] R4700: Fix build_tlb_probe_entry
[MIPS] Alchemy: dbdma: add API to delete custom DDMA device ids.
[MIPS] Alchemy: export get_au1x00_speed for modules
* git://git.infradead.org/~dwmw2/mtd-2.6.26:
[MTD] [MAPS] Fix cmdlineparse handling in mapping files
[MTD] [NAND] pxa: fix incorrect calling of pxa3xx_nand_config() on resume path
Suggest how to deal with patch modifications caused by
merging or back-porting when you're a maintainer.
Signed-off-by: Willy Tarreau <w@1wt.eu>
- Don't trust a length which is greater than the working buffer.
An invalid length could cause overflow when calculating buffer size
for decoding oid.
- An oid length of zero is invalid and allows for an off-by-one error when
decoding oid because the first subid actually encodes first 2 subids.
- A primitive encoding may not have an indefinite length.
Thanks to Wei Wang from McAfee for report.
Cc: Steven French <sfrench@us.ibm.com>
Cc: stable@kernel.org
Acked-by: Patrick McHardy <kaber@trash.net>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Alias brd to rd in the hope of helping legacy users. Suggested by Jan.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Here is an attempt to translate the prompt and help text into something
which is legible and, as a bonus, correct.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
ip_fast_csum() requires a memory clobber on its inline asm as it accesses
memory in a fashion that gcc can't predict.
The GCC manual says:
If your assembler instructions access memory in an unpredictable
fashion, add `memory' to the list of clobbered registers. This will
cause GCC to not keep memory values cached in registers across the
assembler instruction and not optimize stores or loads to that memory.
The bug hasn't been noticed in FRV, but it has been seen in PA-RISC.
We don't need to reserve "unset" resources. Trying to reserve
them results in messages like this, which are ugly but harmless:
system 00:08: iomem range 0x0-0x0 could not be reserved
Future PNP patches will remove use of IORESOURCE_UNSET, but
we still need it for now.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
- fix PCI interrupt assignment by emulating ioc3 interrupt pin register
- use pci_probe_only mode
- select correct page size in bridge
- remove no longer needed ioc3_sio_init() code
[Ralf: Fix for 64kB or larger pagesizes]
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Fix breakage introduced by converting hub_rt to clockevent.
Changes in the generic bootmem code broke memory setup for IP27. This
patch fixes this by replacing lots of special IP27 code with generic
bootmon code. This has been tested only on a single node.
The existing options are named CONFIG_CPU_R4300 and CONFIG_CPU_R4X00,
and they are directly below.
Reported-by: Robert P. J. Day <rpjday@crashcourse.ca>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
The newly added check for valid stack pointer address breaks at least for
64bit kernels. Use __get_user() for accessing stack content to avoid crashes,
when doing the backtrace.
Only the version pte_mkyoung for 36-bit pagetables on 32-bit hw was
affected and with this bug being around since November 29, 2004 there
is evidence to suport the assumption it was benign ;-)
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Treat R4700 like R4600 in build_tlb_probe_entry. Without this fix kernel
will lock up.
Add API to delete custom DDMA device ids create with
au1xxx_ddma_device_add().
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
au1xmmc.c driver depends on it, so export it for modules.
Fix G5 SATA irq 18: nobody cared, reported on -rc5 by Olaf Hering:
fixlet to a57c1bade5a0ee5cd8b74502db9cbebb7f5780b2 libata-sff:
Fix oops reported in kerneloops.org for pnp devices with no ctl
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Tested-by: Olaf Hering <olaf@aepfle.de>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Check that tda827x_config is defined before attempting to use it.
Signed-off-by: Sigmund Augdal <sigmund@snap.tv>
Signed-off-by: Daniel Gimpelevich <daniel@gimpelevich.san-francisco.ca.us>
tda18271_lookup_map
On the TDA18271HD/C1, we perform RF tracking filter correction for VHF low
band, only. If supplied a frequency out of range, the error must be returned
to the caller (tda18271c1_rf_tracking_filter_calibration) so that it can
decide whether or not to write to register EB14, RFC_CPROG[7:0]
Testing whether xceive_pin is non-zero is not good enough as 0 is a valid
value. Instead explicitly test whether the Xceive tuner is used.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
This is patch for fix data structure in querycap syscall.
Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com>
-tip testing found the following build failure:
LD .tmp_vmlinux1
drivers/built-in.o: In function `generic_set_freq':
tuner-xc2028.c:(.text+0xbd896): undefined reference to `request_firmware'
tuner-xc2028.c:(.text+0xbdd7a): undefined reference to `release_firmware'
drivers/built-in.o: In function `xc_load_fw_and_init_tuner':
xc5000.c:(.text+0xc68e6): undefined reference to `request_firmware'
xc5000.c:(.text+0xc6abe): undefined reference to `release_firmware'
with this config:
http://redhat.com/~mingo/misc/config-Tue_May_20_18_11_34_CEST_2008.bad
the reason is another kconfig tool bug that has to be worked around in
the driver's Kconfig file: if FW_LOADER is selected in a second
dependency, that is not properly propagated up the dependencies.
in this case, FW_LOADER is selected from MEDIA_TUNER_XC2028:
config MEDIA_TUNER_XC2028
tristate "XCeive xc2028/xc3028 tuners"
depends on VIDEO_MEDIA && I2C
depends on HOTPLUG
select FW_LOADER
which got selected by MEDIA_TUNER:
config MEDIA_TUNER
tristate
default VIDEO_MEDIA && I2C
select FW_LOADER if !MEDIA_TUNER_CUSTOMIZE && HOTPLUG
but the kconfig tool did not pick up this second-order dependency and
allowed CONFIG_FW_LOADER=m to be selected - in which case the build
fails.
the workaround i found was to move the select of FW_LOADER one level up,
so that the buggy kconfig tool can notice it and can act appropriately.
This problem can probably be worked around in other ways as well, i went
for the minimal fix.
Obviously, the kconfig tool should be fixed, it is not reasonable to
expect driver authors to do manual dependency resolution (that kconfig
itself already does) and uglify the Kconfig files. The kconfig tool did
nothing to warn about this situation and did not prevent this faulty
.config from being constructed.
direct dereferencing from user-supplied address
Reviewed-by: Oliver Endriss <o.endriss@gmx.de>
Endianness annotations and fixes + fixing the handling of
->uncorrected_block_count
