2008-06-23Merge branch 'linus' into sched/develtip-sched-devel-2008-06-23_09.30_MonIngo Molnar
2008-06-21Slab: Fix memory leak in fallback_alloc()tip-x86-idle-2008-06-23_09.16_Montip-core-urgent-2008-06-23_08.56_MonChristoph Lameter
The zonelist patches caused the loop that checks for available objects in permitted zones to not terminate immediately. One object per zone per allocation may be allocated and then abandoned. Break the loop when we have successfully allocated one object. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-21Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: Ext4: Fix online resize block group descriptor corruption
2008-06-21Merge branch 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6Linus Torvalds
* 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6: hwmon: (lm75) sensor reading bugfix hwmon: (abituguru3) update driver detection hwmon: (w83791d) new maintainer hwmon: (abituguru3) Identify Abit AW8D board as such hwmon: Update the sysfs interface documentation hwmon: (adt7473) Initialize max_duty_at_overheat before use hwmon: (lm85) Fix function RANGE_TO_REG()
2008-06-21Add return value to reserve_bootmem_node()Bernhard Walle
This patch changes the function reserve_bootmem_node() from void to int, returning -ENOMEM if the allocation fails. This fixes a build problem on x86 with CONFIG_KEXEC=y and CONFIG_NEED_MULTIPLE_NODES=y Signed-off-by: Bernhard Walle <bwalle@suse.de> Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: netns: Don't receive new packets in a dead network namespace. sctp: Make sure N * sizeof(union sctp_addr) does not overflow. pppoe: warning fix ipv6: Drop packets for loopback address from outside of the box. ipv6: Remove options header when setsockopt's optlen is 0 mac80211: detect driver tx bugs
2008-06-20netns: Don't receive new packets in a dead network namespace.Eric W. Biederman
Alexey Dobriyan <adobriyan@gmail.com> writes: > Subject: ICMP sockets destruction vs ICMP packets oops > After icmp_sk_exit() nuked ICMP sockets, we get an interrupt. > icmp_reply() wants ICMP socket. > > Steps to reproduce: > > launch shell in new netns > move real NIC to netns > setup routing > ping -i 0 > exit from shell > > BUG: unable to handle kernel NULL pointer dereference at 0000000000000000 > IP: [<ffffffff803fce17>] icmp_sk+0x17/0x30 > PGD 17f3cd067 PUD 17f3ce067 PMD 0 > Oops: 0000 [1] PREEMPT SMP DEBUG_PAGEALLOC > CPU 0 > Modules linked in: usblp usbcore > Pid: 0, comm: swapper Not tainted 2.6.26-rc6-netns-ct #4 > RIP: 0010:[<ffffffff803fce17>] [<ffffffff803fce17>] icmp_sk+0x17/0x30 > RSP: 0018:ffffffff8057fc30 EFLAGS: 00010286 > RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffff81017c7db900 > RDX: 0000000000000034 RSI: ffff81017c7db900 RDI: ffff81017dc41800 > RBP: ffffffff8057fc40 R08: 0000000000000001 R09: 000000000000a815 > R10: 0000000000000000 R11: 0000000000000001 R12: ffffffff8057fd28 > R13: ffffffff8057fd00 R14: ffff81017c7db938 R15: ffff81017dc41800 > FS: 0000000000000000(0000) GS:ffffffff80525000(0000) knlGS:0000000000000000 > CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b > CR2: 0000000000000000 CR3: 000000017fcda000 CR4: 00000000000006e0 > DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 > DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 > Process swapper (pid: 0, threadinfo ffffffff8053a000, task ffffffff804fa4a0) > Stack: 0000000000000000 ffff81017c7db900 ffffffff8057fcf0 ffffffff803fcfe4 > ffffffff804faa38 0000000000000246 0000000000005a40 0000000000000246 > 000000000001ffff ffff81017dd68dc0 0000000000005a40 0000000055342436 > Call Trace: > <IRQ> [<ffffffff803fcfe4>] icmp_reply+0x44/0x1e0 > [<ffffffff803d3a0a>] ? ip_route_input+0x23a/0x1360 > [<ffffffff803fd645>] icmp_echo+0x65/0x70 > [<ffffffff803fd300>] icmp_rcv+0x180/0x1b0 > [<ffffffff803d6d84>] ip_local_deliver+0xf4/0x1f0 > [<ffffffff803d71bb>] ip_rcv+0x33b/0x650 > [<ffffffff803bb16a>] netif_receive_skb+0x27a/0x340 > [<ffffffff803be57d>] process_backlog+0x9d/0x100 > [<ffffffff803bdd4d>] net_rx_action+0x18d/0x250 > [<ffffffff80237be5>] __do_softirq+0x75/0x100 > [<ffffffff8020c97c>] call_softirq+0x1c/0x30 > [<ffffffff8020f085>] do_softirq+0x65/0xa0 > [<ffffffff80237af7>] irq_exit+0x97/0xa0 > [<ffffffff8020f198>] do_IRQ+0xa8/0x130 > [<ffffffff80212ee0>] ? mwait_idle+0x0/0x60 > [<ffffffff8020bc46>] ret_from_intr+0x0/0xf > <EOI> [<ffffffff80212f2c>] ? mwait_idle+0x4c/0x60 > [<ffffffff80212f23>] ? mwait_idle+0x43/0x60 > [<ffffffff8020a217>] ? cpu_idle+0x57/0xa0 > [<ffffffff8040f380>] ? rest_init+0x70/0x80 > Code: 10 5b 41 5c 41 5d 41 5e c9 c3 66 2e 0f 1f 84 00 00 00 00 00 55 48 89 e5 53 > 48 83 ec 08 48 8b 9f 78 01 00 00 e8 2b c7 f1 ff 89 c0 <48> 8b 04 c3 48 83 c4 08 > 5b c9 c3 66 66 66 66 66 2e 0f 1f 84 00 > RIP [<ffffffff803fce17>] icmp_sk+0x17/0x30 > RSP <ffffffff8057fc30> > CR2: 0000000000000000 > ---[ end trace ea161157b76b33e8 ]--- > Kernel panic - not syncing: Aiee, killing interrupt handler! Receiving packets while we are cleaning up a network namespace is a racy proposition. It is possible when the packet arrives that we have removed some but not all of the state we need to fully process it. We have the choice of either playing wack-a-mole with the cleanup routines or simply dropping packets when we don't have a network namespace to handle them. Since the check looks inexpensive in netif_receive_skb let's just drop the incoming packets. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-20sctp: Make sure N * sizeof(union sctp_addr) does not overflow.David S. Miller
As noticed by Gabriel Campana, the kmalloc() length arg passed in by sctp_getsockopt_local_addrs_old() can overflow if ->addr_num is large enough. Therefore, enforce an appropriate limit. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-20pppoe: warning fixStephen Hemminger
Fix warning: drivers/net/pppoe.c: In function 'pppoe_recvmsg': drivers/net/pppoe.c:945: warning: comparison of distinct pointer types lacks a cast because skb->len is unsigned int and total_len is size_t Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-20Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] SN2: security hole in sn2_ptc_proc_write
2008-06-20alpha: resurrect Cypress IDE quirkIvan Kokshaysky
Which was removed in the hope that generic legacy IDE quirk in drivers/pci/probe.c is sufficient for Cypress IDE. It isn't, as this controller has non-standard BAR layout: secondary channel registers are in the BAR0-1 of the second PCI function - not in the BAR2-3 of the same function, as the generic quirk routine assumes. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20alpha: fix compile failures with gcc-4.3 (bug #10438)Ivan Kokshaysky
Vast majority of these build failures are gcc-4.3 warnings about static functions and objects being referenced from non-static (read: "extern inline") functions, in conjunction with our -Werror. We cannot just convert "extern inline" to "static inline", as people keep suggesting all the time, because "extern inline" logic is crucial for generic kernel build. So - just make sure that all callees of critical "extern inline" functions are also "extern inline"; - use "static inline", wherever it's possible. traps.c: work around gcc-4.3 being too smart about array bounds-checking. TODO: add "gnu_inline" attribute to all our "extern inline" functions to ensure desired behaviour with future compilers. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20alpha: link failure fixIvan Kokshaysky
With built-in scsi disk driver, the final link fails with a following error: `.exit.text' referenced in section `.rodata' of drivers/built-in.o: defined in discarded section `.exit.text' of drivers/built-in.o This happens with -Os (CONFIG_CC_OPTIMIZE_FOR_SIZE=y) with all gcc-4 versions, and also with -O2 and gcc-4.3. The problem is in sd.c:sd_major() being inlined into __exit function exit_sd(), and the compiler generating a jump table in .rodata section for the 'switch' statement in sd_major(). So we have references to discarded section. Fixed with a big hammer in the form of -fno-jump-tables. Note that jump tables vs. discarded sections is a generic problem, other architectures are just lucky not to suffer from it. But with a slightly more complex switch/case statement it can be reproduced on x86 as well. So maybe at some point we should consider -fno-jump-tables as a generic compile option... Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20alpha: fix module load failures on smp (bug #10926)Ivan Kokshaysky
To calculate addresses of locally defined variables, GCC uses 32-bit displacement from the GP. Which doesn't work for per cpu variables in modules, as an offset to the kernel per cpu area is way above 4G. The workaround is to force allocation of a GOT entry for per cpu variable using ldq instruction with a 'literal' relocation. I had to use custom asm/percpu.h, as a required argument magic doesn't work with asm-generic/percpu.h macros. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20Linux 2.6.26-rc7v2.6.26-rc7Linus Torvalds
2008-06-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: BAST: Remove old IDE driver pcmcia ide kingston compactflash's have a new manufacturer id pcmcia: add another pata/ide ID pcmcia: add an pata/ide ID ide: increase timeout in wait_drive_not_busy() palm_bk3710: fix resource management
2008-06-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: ieee1394: Kconfig menu touch-up firewire: Kconfig menu touch-up firewire: deadline for PHY config transmission firewire: fw-ohci: unify printk prefixes firewire: fill_bus_reset_event needs lock protection firewire: fw-ohci: write selfIDBufferPtr before LinkControl.rcvSelfID firewire: fw-ohci: disable PHY packet reception into AR context firewire: fw-ohci: use of uninitialized data in AR handler firewire: don't panic on invalid AR request buffer
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: no AC status notification ACPI Exception (video-1721): UNKNOWN_STATUS_CODE, Cant attach device
2008-06-20Merge branch 'drm-patches' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (21 commits) drm: only trust core drm ioctls - driver ioctls are a mess. drm/i915: add support for Intel series 4 chipsets. drm/radeon: add hier-z registers for r300 and r500 chipsets drm/radeon: use DSTCACHE_CTLSTAT rather than RB2D_DSTCACHE_CTLSTAT drm/radeon: switch IGP gart to use radeon_write_agp_base() drm/radeon: Restore sw interrupt on resume drm/r500: add support for AGP based cards. drm/radeon: fix texture uploads with large 3d textures (bug 13980) drm/radeon: add initial r500 support. drm/radeon: init pipe setup in kernel code. drm/radeon: fixup radeon_do_engine_reset drm/radeon: fix pixcache and purge/cache flushing registers drm/radeon: write AGP_BASE_2 on chips that support it. drm/radeon: merge IGP chip setup and fixup RS400 vs RS480 support drm/radeon: IGP clean up register and magic numbers. drm/rs690: set base 2 to 0. drm/rs690: set all of gart base address. radeon: add production microcode from AMD drm: pcigart use proper pci map interfaces. drm: the sg alloc ioctl should write back the handle to userspace ...
2008-06-20Merge branch 'agp-patches' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6 * 'agp-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6: [agp]: fixup chipset flush for new Intel G4x. agp: brown paper bag patch - put back the two lines it took out.
2008-06-20Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: softlockup: fix NMI hangs due to lock race - 2.6.26-rc regression rcupreempt: remove export of rcu_batches_completed_bh cpuset: limit the input of cpuset.sched_relax_domain_level
2008-06-20Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched, delay accounting: fix incorrect delay time when constantly waiting on runqueue sched: CPU hotplug events must not destroy scheduler domains created by the cpusets sched: rt-group: fix RR buglet sched: rt-group: heirarchy aware throttle sched: rt-group: fix hierarchy sched: NULL pointer dereference while setting sched_rt_period_us sched: fix defined-but-unused warning
2008-06-20Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, geode: add a VSA2 ID for General Software x86: use BOOTMEM_EXCLUSIVE on 32-bit x86, 32-bit: fix boot failure on TSC-less processors x86: fix NULL pointer deref in __switch_to x86: set PAE PHYSICAL_MASK_SHIFT to 44 bits.
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6: Blackfin Serial Driver: Use timer to poll CTS PIN instead of workqueue. Blackfin arch: fix typo error in bf548 serial header file
2008-06-20Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: ahci: sis can't do PMP ata_piix: add TECRA M4 to broken suspend list LIBATA: Add HAVE_PATA_PLATFORM to select PATA_PLATFORM driver sata_mv: warn on PIO with multiple DRQs sata_mv: enable async_notify for 60x1 Rev.C0 and higher libata: don't check whether to use DMA or not for no data commands ahci: jmb361 has only one port
2008-06-20[watchdog] hpwdt: fix use of inline assemblyLinus Torvalds
The inline assembly in drivers/watchdog/hpwdt.c was incredibly broken, and included all the function prologue and epilogue stuff, even though it was itself then inside a C function where the compiler would add its own prologue and epilogue on top of it all. This then just _happened_ to work if you had exactly the right compiler version and exactly the right compiler flags, so that gcc just happened to not create any prologue at all (the gcc-generated epilogue wouldn't matter, since it would never be reached). But the more proper way to fix it is to simply not do this. Move the inline asm to the top level, with no surrounding function at all (the better alternative would be to remove the prologue and make it actually use proper description of the arguments to the inline asm, but that's a bigger change than the one I'm willing to make right now). Tested-by: S.Çağlar Onur <caglar@pardus.org.tr> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20[IA64] SN2: security hole in sn2_ptc_proc_writeCliff Wickman
Security hole in sn2_ptc_proc_write It is possible to overrun a buffer with a write to this /proc file. Signed-off-by: Cliff Wickman <cpw@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-06-20BAST: Remove old IDE driverBen Dooks
Remove the old BAST IDE driver, as we are now using the platform-pata support. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-20pcmcia ide kingston compactflash's have a new manufacturer idChristophe Niclaes
Up to now, Kingston compactflash cards (ab)used the Toshiba Manufacturer's ID, In their new CF cards, they use a new one. Let's the ide subsystem recognize CF cards with the new id. Signed-off-by: Christophe Niclaes <cniclaes@develtech.com> Acked-by: Philippe De Muyter <phdm@macqel.be> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-20pcmcia: add another pata/ide IDKristoffer Ericson
Addition of Transcend 1GB 45x id so that it is properly detected. [bart: fix typo in ide-cs's ID spotted by Alan Cox] Signed-off-by: William Peters <w1ll14@gmail.com> Signed-off-by: Kristoffer Ericson <Kristoffer_e1@hotmail.com> CC: Alan Cox <alan@lxorguk.ukuu.org.uk> CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-20pcmcia: add an pata/ide IDMatt Reimer
Add an id for: product info: "M-Systems", "CF300", "" manfid: 0x000a, 0x0000 function: 4 (fixed disk) Signed-off-by: Matt Reimer <mreimer@vpop.net> CC: Alan Cox <alan@lxorguk.ukuu.org.uk> CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-20ide: increase timeout in wait_drive_not_busy()Bartlomiej Zolnierkiewicz
Some ATAPI devices take longer than the current max timeout value to become ready (i.e. TEAC DV-W28ECW takes 6 ms) so increase the timeout value to 10 ms. This fixes kernel.org bugzilla bug #10887: http://bugzilla.kernel.org/show_bug.cgi?id=10887 Reported-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-20palm_bk3710: fix resource managementSergei Shtylyov
The driver expected a *virtual* address in the IDE platform device's memory resource and didn't request the memory region for the register block. Fix this taking into account the fact that DaVinci SoC devices are fixed-mapped to the virtual memory early and we can get their virtual addresses using IO_ADDRESS() macro, not having to call ioremap()... While at it, also do some cosmetic changes... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-20Reinstate ZERO_PAGE optimization in 'get_user_pages()' and fix XIPLinus Torvalds
KAMEZAWA Hiroyuki and Oleg Nesterov point out that since the commit 557ed1fa2620dc119adb86b34c614e152a629a80 ("remove ZERO_PAGE") removed the ZERO_PAGE from the VM mappings, any users of get_user_pages() will generally now populate the VM with real empty pages needlessly. We used to get the ZERO_PAGE when we did the "handle_mm_fault()", but since fault handling no longer uses ZERO_PAGE for new anonymous pages, we now need to handle that special case in follow_page() instead. In particular, the removal of ZERO_PAGE effectively removed the core file writing optimization where we would skip writing pages that had not been populated at all, and increased memory pressure a lot by allocating all those useless newly zeroed pages. This reinstates the optimization by making the unmapped PTE case the same as for a non-existent page table, which already did this correctly. While at it, this also fixes the XIP case for follow_page(), where the caller could not differentiate between the case of a page that simply could not be used (because it had no "struct page" associated with it) and a page that just wasn't mapped. We do that by simply returning an error pointer for pages that could not be turned into a "struct page *". The error is arbitrarily picked to be EFAULT, since that was what get_user_pages() already used for the equivalent IO-mapped page case. [ Also removed an impossible test for pte_offset_map_lock() failing: that's not how that function works ] Acked-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Nick Piggin <npiggin@suse.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20Ext4: Fix online resize block group descriptor corruptionFrederic Bohe
This is the patch for the group descriptor table corruption during online resize pointed out by Theodore Tso. The problem was caused by the fact that the ext4 group descriptor can be either 32 or 64 bytes long. Only the 64 bytes structure was taken into account. Signed-off-by: Frederic Bohe <frederic.bohe@bull.net> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-06-20sched: rt: dont stop the period timer when there are tasks wanting to runPeter Zijlstra
So if the group ever gets throttled, it will never wake up again. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Daniel K." <dk@uw.no> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: "Daniel K." <dk@uw.no>
2008-06-20sched: rt: fix the bandwidth contraint computationsPeter Zijlstra
Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Daniel K." <dk@uw.no> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-20sched: rt: move some code aroundPeter Zijlstra
2008-06-20sched: rt: fix SMP bandwidth balancing for throttled groupsPeter Zijlstra
Now we exceed the runtime and get throttled - the period rollover tick will subtract the cpu quota from the runtime and check if we're below quota. However with this cpu having a very small portion of the runtime it will not refresh as fast as it should. Therefore, also rebalance the runtime when we're throttled. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Daniel K." <dk@uw.no> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-20sched: debug: add some rt debug outputPeter Zijlstra
2008-06-20Merge branch 'bugzilla-9761' into releaseLen Brown
2008-06-20Merge branch 'bugzilla-10695' into releaseLen Brown
2008-06-20drm: only trust core drm ioctls - driver ioctls are a mess.Dave Airlie
So driver ioctls need a full auditing before we can make this change. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-20drm/i915: add support for Intel series 4 chipsets.Zhenyu Wang
Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-20[agp]: fixup chipset flush for new Intel G4x.Zhenyu Wang
2008-06-19ipv6: Drop packets for loopback address from outside of the box.YOSHIFUJI Hideaki
[ Based upon original report and patch by Karsten Keil. Karsten has verified that this fixes the TAHI test case "ICMPv6 test v6LC.5.1.2 Part F". -DaveM ] Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-19ipv6: Remove options header when setsockopt's optlen is 0Shan Wei
Remove the sticky Hop-by-Hop options header by calling setsockopt() for IPV6_HOPOPTS with a zero option length, per RFC3542. Routing header and Destination options header does the same as Hop-by-Hop options header. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-19x86, geode: add a VSA2 ID for General SoftwareJordan Crouse
General Software writes their own VSA2 module for their version of the Geode BIOS, which returns a different ID then the standard VSA2. This was causing the framebuffer driver to break for most GSW boards. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Cc: tglx@linutronix.de Cc: linux-geode@lists.infradead.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19sched, delay accounting: fix incorrect delay time when constantly waiting on ↵Bharath Ravi
runqueue This patch corrects the incorrect value of per process run-queue wait time reported by delay statistics. The anomaly was due to the following reason. When a process leaves the CPU and immediately starts waiting for CPU on the runqueue (which means it remains in the TASK_RUNNABLE state), the time of re-entry into the run-queue is never recorded. Due to this, the waiting time on the runqueue from this point of re-entry upto the next time it hits the CPU is not accounted for. This is solved by recording the time of re-entry of a process leaving the CPU in the sched_info_depart() function IF the process will go back to waiting on the run-queue. This IF condition is verified by checking whether the process is still in the TASK_RUNNABLE state. The patch was tested on 2.6.26-rc6 using two simple CPU hog programs. The values noted prior to the fix did not account for the time spent on the runqueue waiting. After the fix, the correct values were reported back to user space. Signed-off-by: Bharath Ravi <bharathravi1@gmail.com> Signed-off-by: Madhava K R <madhavakr@gmail.com> Cc: dhaval@linux.vnet.ibm.com Cc: vatsa@in.ibm.com Cc: balbir@in.ibm.com Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19hwmon: (lm75) sensor reading bugfixDavid Brownell
LM75 sensor reading bugfix: never save error status as valid sensor output. This could be improved, but at least this prevents certain rude failure modes. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
