2008-06-06uml: activate_mm: remove the dead PF_BORROWED_MM checktip-core-topology-2008-06-16_09.13_Montip-core-misc-2008-06-16_09.11_MonOleg Nesterov
use_mm() was changed to use switch_mm() instead of activate_mm(), since then nobody calls (and nobody should call) activate_mm() with PF_BORROWED_MM bit set. As Jeff Dike pointed out, we can also remove the "old != new" check, it is always true. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/ipath: Fix SM trap forwarding IB/ehca: Reject send WRs only for RESET, INIT and RTR state MAINTAINERS: Update NetEffect (iw_nes) entry IB/ipath: Fix device capability flags IB/ipath: Avoid test_bit() on u64 SDMA status value
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: x86/PCI: add workaround for bug in ASUS A7V600 BIOS (rev 1005) PCI/x86: fix up PCI stuff so that PCI_GOANY supports OLPC
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: sound: emu10k1 - fix system hang with Audigy2 ZS Notebook PCMCIA card
git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6: capabilities: remain source compatible with 32-bit raw legacy capability support. LSM: remove stale web site from MAINTAINERS
2008-06-06Merge git://git.infradead.org/~dwmw2/mtd-2.6.26Linus Torvalds
* git://git.infradead.org/~dwmw2/mtd-2.6.26: [MTD] m25p80.c mutex unlock fix
2008-06-06ipwireless: Fix blocked sendingDavid Sterba
Packet sending is driven by two flags, tx_ready and tx_queued. It was possible, that there were queued data for sending and hardware was flagged as blocked but in fact it was not. The tx_queued was indicator but should be really a counter else first fragmented packet resets tx_queued flag, but there may be pending packets which do not get sent. New semantics: tx_ready - set, if hw is ready to send packet, no packet is being transferred right now set the flag right at the place where data are copied into hw memory and not earlier without checking if it was succesful tx_queued - count of enqueued packets, including fragments Tested-by: Michal Rokos <michal.rokos@gmail.com> Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06vm: add kzalloc_node() inlineJeff Layton
To get zeroed out memory from a particular NUMA node. To be used by sunrpc. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06pagemap: add documentation for pagemapThomas Tuttle
Just a quick explanation of the pagemap interface from a userspace point of view, and an example of how to use it (in English, not code). Signed-off-by: Thomas Tuttle <ttuttle@google.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06pagemap: return EINVAL, not EIO, for unaligned reads of kpagecount or kpageflagsThomas Tuttle
If the user tries to read from a position that is not a multiple of 8, or read a number of bytes that is not a multiple of 8, they have passed an invalid argument to read, for the purpose of reading these files. It's not an IO error because we didn't encounter any trouble finding the data they asked for. Signed-off-by: Thomas Tuttle <ttuttle@google.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06pagemap: return map count, not reference count, in /proc/kpagecountThomas Tuttle
Since pagemap is all about examining pages mapped into processes' memory spaces, it makes sense for kpagecount to return the map counts, not the reference counts. Signed-off-by: Thomas Tuttle <ttuttle@google.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06hdaps: fix module loading on Thinkpad T61PTim Gardner
Adds DMI system identifier for ThinkPad T61. Originally written by Klaus S. Madsen. Taken from http://launchpadlibrarian.net/10864950/hdaps-t61.patch Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: maximilian attems <max@stro.at> Cc: Klaus S. Madsen <ubuntu@hjernemadsen.org> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06proc: calculate the correct /proc/<pid> link countVegard Nossum
This patch: commit e9720acd728a46cb40daa52c99a979f7c4ff195c Author: Pavel Emelyanov <xemul@openvz.org> Date: Fri Mar 7 11:08:40 2008 -0800 [NET]: Make /proc/net a symlink on /proc/self/net (v3) introduced a /proc/self/net directory without bumping the corresponding link count for /proc/self. This patch replaces the static link count initializations with a call that counts the number of directory entries in the given pid_entry table whenever it is instantiated, and thus relieves the burden of manually keeping the two in sync. [akpm@linux-foundation.org: cleanup] Acked-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06rtc: class driver for ppc_md RTC functionsDavid Woodhouse
This hooks up the platform-specific [gs]et_rtc_time functions so that kernels using CONFIG_RTC_CLASS have RTC support on most PowerPC platforms. A new driver, and one which we've been shipping in Fedora for a while already, since otherwise RTC support breaks. [akpm@linux-foundation.org: fix Kconfig indenting] Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: David Brownell <david-b@pacbell.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06asm-m32r/uaccess.h must #include <asm/setup.h>Adrian Bunk
This patch fixes the following compile error caused by commit 4016a1390d07f15b267eecb20e76a48fd5c524ef (mm/nommu.c: return 0 from kobjsize with invalid objects): /home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c: In function 'kobjsize': /home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c:112: error: 'memory_end' undeclared (first use in this function) /home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c:112: error: (Each undeclared identifier is reported only once /home/bunk/linux/kernel-2.6/git/linux-2.6/mm/nommu.c:112: error: for each function it appears in.) The patch also removes now no longer required memory_{start,end} declarations inside access_ok(). Reported-by: Adrian Bunk <adrian.bunk@movial.fi> Signed-off-by: Adrian Bunk <adrian.bunk@movial.fi> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Michael Hennerich <Michael.Hennerich@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06ext3: fix online resize bugJosef Bacik
There is a bug when we are trying to verify that the reserve inode's double indirect blocks point back to the primary gdt blocks. The fix is obvious, we need to mod the gdb count by the addr's per block. You can verify this with the following test case dd if=/dev/zero of=disk1 seek=1024 count=1 bs=100M losetup /dev/loop1 disk1 pvcreate /dev/loop1 vgcreate loopvg1 /dev/loop1 lvcreate -l 100%VG loopvg1 -n looplv1 mkfs.ext3 -J size=64 -b 1024 /dev/loopvg1/looplv1 mount /dev/loopvg1/looplv1 /mnt/loop dd if=/dev/zero of=disk2 seek=1024 count=1 bs=50M losetup /dev/loop2 disk2 pvcreate /dev/loop2 vgextend loopvg1 /dev/loop2 lvextend -l 100%VG /dev/loopvg1/looplv1 resize2fs /dev/loopvg1/looplv1 without this patch the resize2fs fails, with it the resize2fs succeeds. Signed-off-by: Josef Bacik <jbacik@redhat.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06nommu: fix ksize() abusePekka Enberg
The nommu binfmt code uses ksize() for pointers returned from do_mmap() which is wrong. This converts the call-sites to use the nommu specific kobjsize() function which works as expected. Cc: Christoph Lameter <clameter@sgi.com> Cc: Matt Mackall <mpm@selenic.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06doc: document the kernel-doc conventions for kernel hackersPaul Jackson
Provide documentation of the kernel-doc documentation conventions oriented to kernel hackers. Since I figure that there will be more people reading this kernel-doc-nano-HOWTO.txt file who are kernel developers focused on the rest of the kernel, than there will be readers of this file who are documentation developers extracting that embedded kernel-doc documentation, I have taken the liberty of making the new section added here: How to format kernel-doc comments the first section of the kernel-doc-nano-HOWTO.txt file. This first section is intended to introduce, motivate and provide basic usage of the kernel-doc mechanism for kernel hackers developing other portions of the kernel. Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06fbdev: export symbol fb_mode_optionGeoff Levand
Frame buffer and mode setting drivers can be built as modules, so fb_mode_option needs to be exported to support these. Prevents this error: ERROR: "fb_mode_option" [drivers/ps3/ps3av_mod.ko] undefined! Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06MAINTAINERS: reiserfs entry is out of dateAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Edward Shishkin <edward.shishkin@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06v850: fix typo in header guardVegard Nossum
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06h8300: fix typo in header guardVegard Nossum
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06atmel_serial: filter out FP during baud rate detectionHaavard Skinnemoen
I made a change to u-boot that used the FP (Fractional Part) field of BRGR to achieve more accurate baud rate generation. Unfortunately, the atmel_serial driver looks at the whole BRGR register when trying to detect the baud rate that the port is currently running at, so setting FP to a nonzero value breaks the baud rate detection. I'll sit on the u-boot patch for a while longer, but this is clearly a bug in the atmel_serial driver which should be fixed. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06vt: fix vc_resize lockingNick Piggin
Lockdep says we can't take tasklist lock or sighand lock inside ctrl_lock. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Alan Cox <alan@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06ipc: only output msgmni value at boot timeNadia Derbey
When posting: [PATCH 1/8] Scaling msgmni to the amount of lowmem (see http://lkml.org/lkml/2008/2/11/171), I have added a KERN_INFO message that is output each time msgmni is recomputed. In http://lkml.org/lkml/2008/4/29/575 Tony Luck complained that this message references an ipc namespace address that is useless. I first thought of using an audit_log instead of a printk, as suggested by Serge Hallyn. But unfortunately, we do not have any other information than the namespace address to provide here too. So I chose to move the message and output it only at boot time, removing the reference to the namespace. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Acked-by: Tony Luck <tony.luck@intel.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06ipc: restore MSGPOOL original valueNadia Derbey
When posting: [PATCH 1/8] Scaling msgmni to the amount of lowmem (see http://article.gmane.org/gmane.linux.kernel/637849/) I changed the MSGPOOL value to make it fit what is said in the man pages (i.e. a size in bytes). But Michael Kerrisk rightly complained that this change could affect the ABI. So I'm posting this patch to make MSGPOOL expressed back in Kbytes. Michael, on his side, has fixed the man page. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Acked-by: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06vt: fix background color on line feed, DEC invertJan Engelhardt
Original report: """I used to force my console to black-on-white by the command `setterm -inversescreen on`. In 2.6.26-rc4, I get lots of black background characters.""" Another addendum to commit c9e587ab. This was previously missed out since I was not aware of what vc_decscnm was for. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Reported-by: <thunder7@xs4all.nl> Tested-by: <thunder7@xs4all.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06cpufreq: fix null object access on Transmeta CPUCHIKAMA masaki
If cpu specific cpufreq driver(i.e. longrun) has "setpolicy" function, governor object isn't set into cpufreq_policy object at "__cpufreq_set_policy" function in driver/cpufreq/cpufreq.c . This causes a null object access at "store_scaling_setspeed" and "show_scaling_setspeed" function in driver/cpufreq/cpufreq.c when reading or writing through /sys interface (ex. cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed) Addresses: http://bugzilla.kernel.org/show_bug.cgi?id=10654 https://bugzilla.redhat.com/show_bug.cgi?id=443354 Signed-off-by: CHIKAMA Masaki <masaki.chikama@gmail.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Chuck Ebbert <cebbert@redhat.com> Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06fbcon: fix wrong vmode bits copied on console switchKrzysztof Helt
The interlaced and double line mode bits should not be copied to new console when the console is switched. Otherwise, the new console may be set to incorrect refresh rate. Also, the x and y offsets does not need to be copied. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06keys: remove unused key_alloc_semDaniel Walker
This semaphore doesn't appear to be used, so remove it. Signed-off-by: Daniel Walker <dwalker@mvista.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06cpusets: fix bug when adding nonexistent cpu or memLai Jiangshan
Adding a nonexistent cpu to a cpuset will be omitted quietly. It should return -EINVAL. Example: (real_nr_cpus <= 4 < NR_CPUS or cpu#4 was just offline) # cat cpus 0-1 # /bin/echo 4 > cpus # /bin/echo $? 0 # cat cpus # The same occurs when add a nonexistent mem. This patch will fix this bug. And when *buf == "", the check is unneeded. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06pagemap: fix bug in add_to_pagemap, require aligned-length reads of ↵Thomas Tuttle
/proc/pid/pagemap Fix a bug in add_to_pagemap. Previously, since pm->out was a char *, put_user was only copying 1 byte of every PFN, resulting in the top 7 bytes of each PFN not being copied. By requiring that reads be a multiple of 8 bytes, I can make pm->out and pm->end u64*s instead of char*s, which makes put_user work properly, and also simplifies the logic in add_to_pagemap a bit. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Thomas Tuttle <ttuttle@google.com> Cc: Matt Mackall <mpm@selenic.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06devscgroup: make white list more compact in some casesPavel Emelyanov
Consider you added a 'c foo:bar r' permission to some cgroup and then (a bit later) 'c'foo:bar w' for it. After this you'll see the c foo:bar r c foo:bar w lines in a devices.list file. Another example - consider you added 10 'c foo:bar r' permissions to some cgroup (e.g. by mistake). After this you'll see 10 c foo:bar r lines in a list file. This is weird. This situation also has one more annoying consequence. Having many items in a white list makes permissions checking slower, sine it has to walk a longer list. The proposal is to merge permissions for items, that correspond to the same device. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06devscgroup: check for device permissions at mount timePavel Emelyanov
Currently even if a task sits in an all-denied cgroup it can still mount any block device in any mode it wants. Put a proper check in do_open for block device to prevent this. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Tested-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06devscgroup: relax task to dev_cgroup conversionPavel Emelyanov
Two functions, that need to get a device_cgroup from a task (they are devcgroup_inode_permission and devcgroup_inode_mknod) make it in a strange way: They get a css_set from task, then a subsys_state from css_set, then a cgroup from the state and then a subsys_state again from the cgroup. Besides, the devices_subsys_id is read from memory, whilst there's a enum-ed constant for it. Optimize this part a bit: 1. Get the subsys_stats form the task and be done - no 2 extra dereferences, 2. Use the device_subsys_id constant, not the value from memory (i.e. one less dereference). Found while preparing 2.6.26 OpenVZ port. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Paul Menage <menage@google.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06devcgroup: make a helper to convert cgroup_subsys_state to devs_cgroupPavel Emelyanov
This is just picking the container_of out of cgroup_to_devcgroup into a separate function. This new css_to_devcgroup will be used in the 2nd patch. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06introduce memory_read_from_buffer()Akinobu Mita
This patch introduces memory_read_from_buffer(). The only difference between memory_read_from_buffer() and simple_read_from_buffer() is which address space the function copies to. simple_read_from_buffer copies to user space memory. memory_read_from_buffer copies to normal memory. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Doug Warzecha <Douglas_Warzecha@dell.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: Abhay Salunke <Abhay_Salunke@dell.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Markus Rechberger <markus.rechberger@amd.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Bob Moore <robert.moore@intel.com> Cc: Thomas Renninger <trenn@suse.de> Cc: Len Brown <lenb@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Cc: Michael Holzheu <holzheu@de.ibm.com> Cc: Brian King <brking@us.ibm.com> Cc: James E.J. Bottomley <James.Bottomley@HansenPartnership.com> Cc: Andrew Vasquez <linux-driver@qlogic.com> Cc: Seokmann Ju <seokmann.ju@qlogic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06lib: export bitrev16Harvey Harrison
Bluetooth will be able to use this. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Dave Young <hidave.darkstar@gmail.com> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06rtc-ds1374: rename device to just "ds1374"Jean Delvare
Change the name of the device from "rtc-ds1374" to just "ds1374", to match what all other RTC drivers do. I seem to remember that this name was chosen to avoid possible confusion with an older ds1374 driver, but that driver was removed 3 months ago. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Kumar Gala <galak@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06Fix various old email addresses for dwmw2David Woodhouse
Although if people have questions about ARCnet, perhaps it's _better_ for them to be mailing dwmw2@cam.ac.uk about it... Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06uml: PATH_MAX needs limits.hIngo Molnar
Include limits.h to get a definition of PATH_MAX. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06uml: stub needs to tolerate SIGWINCHJeff Dike
We lost the marking of SIGWINCH as being OK to receive during stub execution, causing a panic should that happen. Cc: Benedict Verheyen <benedict.verheyen@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06uml: memcpy export needs to follow host declarationJeff Dike
x86_64 defines either memcpy or __memcpy depending on the gcc version, and it looks like UML needs to follow that in its exporting. Cc: Gabriel C <nix.or.die@googlemail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06uml: deal with inaccessible address space startTom Spink
This patch makes os_get_task_size locate the bottom of the address space, as well as the top. This is for systems which put a lower limit on mmap addresses. It works by manually scanning pages from zero onwards until a valid page is found. Because the bottom of the address space may not be zero, it's not sufficient to assume the top of the address space is the size of the address space. The size is the difference between the top address and bottom address. [jdike@addtoit.com: changed the name to reflect that this function is supposed to return the top of the process address space, not its size and changed the return value to reflect that. Also some minor formatting changes] Signed-off-by: Tom Spink <tspink@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06uml: remove a duplicate includeHuang Weiyi
Removed duplicated include file "kern_util.h" in arch/um/drivers/ubd_kern.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06uml: deal with host time going backwardsJeff Dike
Protection against the host's time going backwards (eg, ntp activity on the host) by keeping track of the time at the last tick and if it's greater than the current time, keep time stopped until the host catches up. Cc: Nix <nix@esperi.org.uk> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06doc: update to URL and status of kernel-docs.txt entryPaul Jackson
Update status and URL for the "Gary's Encyclopedia" entry. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06fujitsu-laptop: autoload module on Lifebook P1510DDan Williams
Signed-off-by: Dan Williams <dcbw@redhat.com> Cc: Jonathan Woithe <jwoithe@physics.adelaide.edu.au> Cc: Len Brown <len.brown@intel.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06nommu: fix kobjsize() for SLOB and SLUBPaul Mundt
kobjsize() has been abusing page->index as a method for sorting out compound order, which blows up both for page cache pages, and SLOB's reuse of the index in struct slob_page. Presently we are not able to accurately size arbitrary pointers that don't come from kmalloc(), so the best we can do is sort out the compound order from the head page if it's a compound page, or default to 0-order if it's impossible to ksize() the object. Obviously this leaves quite a bit to be desired in terms of object sizing accuracy, but the behaviour is unchanged over the existing implementation, while fixing the page->index oopses originally reported here: http://marc.info/?l=linux-mm&m=121127773325245&w=2 Accuracy could also be improved by having SLUB and SLOB both set PG_slab on ksizeable pages, rather than just handling the __GFP_COMP cases irregardless of the PG_slab setting, as made possibly with Pekka's patches: http://marc.info/?l=linux-kernel&m=121139439900534&w=2 http://marc.info/?l=linux-kernel&m=121139440000537&w=2 http://marc.info/?l=linux-kernel&m=121139440000540&w=2 This is primarily a bugfix for nommu systems for 2.6.26, with the aim being to gradually kill off kobjsize() and its particular brand of object abuse entirely. Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06m68k: enable CONFIG_COMPAT_BRK by defaultGeert Uytterhoeven
As some m68k machines have plenty of libc5 binaries in active use, enable CONFIG_COMPAT_BRK by default. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
