Allocate driver name string in info struct, rather than passing
a pointer to a stack allocated array when registering a miscdevice.
This prevents 'cat /proc/misc' from dereferencing a dangling
pointer.
Drivers of following devices were updated - ad5816, as364x, dw9718,
imx091, max77387, max77665-flash, ov5693, ov9772, sh532u, ssl3250a
and tps61050.
Change-Id: I2344e6fefabdeda962ea33bc10803881e07ab3f0
Signed-off-by: Shreshtha Sahu <ssahu@nvidia.com>
Reviewed-on: http://git-master/r/256818
GVS: Gerrit_Virtual_Submit
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Accessing DAM registers in debugfs (tegra30_dam_show) without
enabling AHUB clock hangs the system. This patch enables AHUB
APBIF clock along with DAM clock before accessing DAM regsiters.
Bug 1334025
Change-Id: Ibf2bc4c699027b8fc28f3e861e5b306f8ffd9564
Reviewed-on: http://git-master/r/256715
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
This reverts commit 5065f2b7ca2f76f5cf48ceef3f4d09435d30be2e.
Window format is not initialized. Window format is set by
tegra_fb_set_par.
Bug 1326825
Signed-off-by: Pankaj Dabade <pdabade@nvidia.com>
Change-Id: I8c181cfc11f1db1df5b928f0c1216a40a6641160
Reviewed-on: http://git-master/r/254901
6000mA is the max current for regular T30 SOCs. Conditionally changing
it to 10000mA for T33 SOCs to avoid passing the command line parameter
max_cpu_cur_ma=10000 explicitly.
Bug 1166110
Change-Id: I453c8e128a6cf32f10e0f6e4a577b857d38d8e4d
Signed-off-by: Naveen Kumar S <nkumars@nvidia.com>
Reviewed-on: http://git-master/r/245335
(cherry picked from commit 041279fc8d156013558273c8ba33ab718b7f924c)
Reviewed-on: http://git-master/r/251202
Reviewed-by: Bryan Wu <pengw@nvidia.com>
Added function tegra_get_minor_rev() to return minor revision number
of the chip.
Bug 1166110
Change-Id: I087331433cabb35c05fa2ce0bd53013b6fb6624f
Reviewed-on: http://git-master/r/245330
(cherry picked from commit f29df745d2e97c0feb5f9c195202ca55041fa14c)
Reviewed-on: http://git-master/r/251198
- fix i2c timeout issue as I2C_INT_ALL_PACKETS_XFER_COMPLETE is disabled.
bug 1313673
bug 1278481
Change-Id: I2a2c39c64298ed6e087abbe047ba01113db80f3e
Signed-off-by: Nitin Sehgal <nsehgal@nvidia.com>
Reviewed-on: http://git-master/r/243891
(cherry picked from commit ca3063b3717b6cb4777d4ea2882636e98f9ccd5a)
Reviewed-on: http://git-master/r/250779
Register device as EDP client only when EDP_FRAMEWORK is enabled.
Bug 1306131
Change-Id: Id8b3ea91426ba04b402b36b1a61e48b00debbe36
Reviewed-on: http://git-master/r/245369
Remove dangling pointer by removing kfree in tegra_dc_add_modes.
specs.modedb is allocated by tegra_dc_add_modes(), but is consumed
by tegra_fb_update_monspecs(), so releasing specs.modedb creates a
dangling pointer and make the system crashed, especially when the
system suspends to lp0.
bug 1264520
Change-Id: Ic944e75b631800ed552b7e56b5799a3e60b48afe
Signed-off-by: Jong Kim <jongk@nvidia.com>
Reviewed-on: http://git-master/r/248089
(cherry picked from commit e00bcba1c2d54f91d9ff93c5f8fd61c40a9ab5bd)
Reviewed-on: http://git-master/r/248727
Tested-by: Matthew Pedro <mapedro@nvidia.com>
HDCP are not used/tested in L4T. It simply generates a lot of
meaningless i2c timeout messages and wastes CPU cycles. If needed,
individual users may recompile kernel with HDCP enabled.
bug 1264520
Change-Id: I9f23c6850a68c7db0613a737becc95607c7559e7
Reviewed-on: http://git-master/r/248090
(cherry picked from commit f72439306a30ce3fbbb184cbf43129a0ad1d7297)
Reviewed-on: http://git-master/r/248728
Read and write to gpios only when request for the gpio
has suceeded
Bug 1317541
Change-Id: Icfeed36b9e95f4ee03e49bee0cc8b3c2daf4a4a8
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/244190
(cherry picked from commit 1caddafdf260e3521804a02395d42f3f96928b99)
Reviewed-on: http://git-master/r/245281
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Enable HDMI as primary framebuffer console by programming the HW when
new/best mode is detected.
bug 1264520
Change-Id: I8862d2860c97a1241d4acae8206c71de06ea0162
Reviewed-on: http://git-master/r/243981
(cherry picked from commit a49c55a39ee7b6e2b1075b7441f500c4572c2ddd)
Reviewed-on: http://git-master/r/247279
Remove dead lock for HDMI used as the primary display.
tegra_dc_hdmi_detect should not acquire dc->lock, which generates
dead lock because its sub-procedure such as tegra_dc_set_mode(),
tegra_dc_enable(), tegra_dc_disable(), etc... try to acquire same
dc->lock withing same process context.
bug 1264520
Change-Id: I4d5f301a8f46e2ad2f990637b1f1c3b1d02a5054
Reviewed-on: http://git-master/r/243980
(cherry picked from commit 7d88a78ad46d3b6ef106da5b6aeafc77191dfe35)
Reviewed-on: http://git-master/r/247278
Add default 640x480 hdmi panel mode. This HDMI mode is just a dummy
for device probe to pass and finish dc/fb/fbcon registration. The
actual mode will be detected by detect worker and programmed to the
hw a little later during boot process.
bug 1264520
Change-Id: Iad2e3dca1316b347abdc72d8ee8c73444ce368e2
Reviewed-on: http://git-master/r/243979
(cherry picked from commit b44efdeeaa328cb19add0c8f6ef3fb10dc5829dc)
Reviewed-on: http://git-master/r/248024
Remove section mismatch gcc warnings for dalmore.
bug 1264520
Change-Id: Ic19bf04c89de5b9d8f08e702c84150f62c5381e5
Reviewed-on: http://git-master/r/243978
(cherry picked from commit c94da7a824eee8f6df5f893c8a81d56011a51d8a)
Reviewed-on: http://git-master/r/248020
Clear primary framebuffer if bootloader framebuffer is not defined.
(Some bootloader such as u-boot may not support LCD display and not
supporting LCD in bootloader is purely customer's choice and the
kernel display driver should survive such configuration).
bug 1301464
bug 1264520
Change-Id: I919c7961e694461d6083510cdc51e3cd6bcac156
Reviewed-on: http://git-master/r/243977
(cherry picked from commit 6e713daa1b729e341f682568a12bd0ef0249be72)
Reviewed-on: http://git-master/r/248013
Call tegra_hotplug_signal to queue deferred work after a delay of 30ms and call gpio_get_value
in tegra_dc_hpd
bug 1298680
Change-Id: I7e1c15c1445116b4f6400708335590ea6e2d5d0b
Signed-off-by: sharath sarangpur <ssarangpur@nvidia.com>
Reviewed-on: http://git-master/r/241136
(cherry picked from commit a05fe127fde8c6b77aa686248c6bd8387642aa43)
Reviewed-on: http://git-master/r/247366
Tested-by: Jong Kim <jongk@nvidia.com>
On suspend/resume, defer the blocking regulator enable. Place this slow path
in the dedicated hotplug thread.
bug 1299936
bug 1294872
Change-Id: I61a835c2c37dcae47697482e0023b68684ff19dc
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/239058
(cherry picked from commit 6e789c76d47a6e144868d1e33f9d79b7fc58405d)
Reviewed-on: http://git-master/r/247365
Blanking the screen before DC disable is redundant and might cause
momentary screen flash (screen off -> on -> off) in case if DC receives
flip ioctl after screen was blanked.
This also makes DC shutdown process similar to FB_BLANK_POWERDOWN.
Bug 1299434
Change-Id: I9d3713bae4cc4511c7beb0cef22499cb9b3b5d64
Signed-off-by: Victor Ryabukhin <vryabukhin@nvidia.com>
Reviewed-on: http://git-master/r/237914
(cherry picked from commit 161501da4ae10339e6f8c6ce208cca305d1f6569)
Reviewed-on: http://git-master/r/247364
This reverts commit 439d56a1b2b266d127e021e037be8e30c89f33fb.
Change-Id: I28c7bcf8ad556b6a784d0a00f793cb05e0f94576
Signed-off-by: Matt Pedro <mapedro@nvidia.com>
Reviewed-on: http://git-master/r/247981
This reverts commit 9d1dfe8d12009d7a64e468ec04466f3e3b387149.
Change-Id: I527b106733138e1f093b918d653fa936741cdee4
Reviewed-on: http://git-master/r/247980
This reverts commit ed037358021f408a895cec4be9b6643efe7bee97.
Change-Id: Idd6d4904ace18ceb2cb29d66a7cb2e648ea1610f
Reviewed-on: http://git-master/r/247979
bug 1264520
Change-Id: I79105b760499bb88aae3bc1a01172d31394d6300
Reviewed-on: http://git-master/r/247277
bug 1264520
Change-Id: I880ec7d3846ece5f57881ee4f69281c9b91327b8
Reviewed-on: http://git-master/r/247276
bug 1301464
bug 1264520
Change-Id: Ia37f1f9db08166509bf02673268180f277286dc2
Reviewed-on: http://git-master/r/247275
Removing tegra_fb_set_par from tegra_fb_register which tries to set
videomode to nearest mode before the framebuffer modelist is ready.
Function register_framebuffer() is found to add a mode to modelist
and calls tegra_fb_set_par later.
bug 1194793
Change-Id: I3908a435dddba3b8884f33bcaa0f3955b94b4147
Reviewed-on: http://git-master/r/242499
(cherry picked from commit f6c60cef8e6707e06c5057a43ecf280902eb1cce)
Reviewed-on: http://git-master/r/243328
Reviewed-by: Jong Kim <jongk@nvidia.com>
Wakelocks are not used in L4T. Disabling wakelock config
macros in tegra11 L4T defconfig.
Bug 1314808
Change-Id: I8016d2661db3190a0dba682da62a7659a282c8d2
Reviewed-on: http://git-master/r/243501
(cherry picked from commit 119bd2ae76e4f0d6511f3be64e739b0b5013640d)
Reviewed-on: http://git-master/r/244130
Adding bool prompt and help description for CONFIG_WAKELOCK
and CONFIG_HAS_WAKELOCK options in Kconfig file to ease
menuconfig operations
Bug 1314808
Change-Id: I5c450ef0994a08c1bf51e8c9849bb96c69c69081
Reviewed-on: http://git-master/r/243459
(cherry picked from commit 2dda2db4db3fca12301cab3b9c59fba758573652)
Reviewed-on: http://git-master/r/244125
bug 1298931
Change-Id: Iea46c10c53a1fe76d09d386f45f05f2da7de1d7d
Signed-off-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/237770
Currently we hard wired the OC current to 3.25A on MAX77665. But
different board could use different setting, or do not use MAX77665 to
generate OC alert.
This patch use the board file to config OC current.
bug 1298931
Change-Id: I87872b6c7bc052efec680683dee6cde571359d84
Reviewed-on: http://git-master/r/237769
Check return value of configure_dam function.
Add error message and graceful exit path in
make_voice_call function when DAM controller
allocation fails.
Bug 1274653
Change-Id: I9924c256113c73fb3208c1e0e7225cb485022ca4
Signed-off-by: Vijay Mali <vmali@nvidia.com>
Reviewed-on: http://git-master/r/237664
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Bootloader PWM freq KHz is set to 48MHz and its parent is PLLP.
If PWM frequency is set to different and lower one in kernel begin,
a little flicker can be observed until pwm is configured by
backlight device driver.
Bug 1299402
Change-Id: I1ab1e0e97c952d908fe746a5d5caccfe0ddaa7c6
Signed-off-by: Min-wuk Lee <mlee@nvidia.com>
Reviewed-on: http://git-master/r/236579
Signed-off-by: Marc Yang <yangyang@marvell.com>
Update SD8897 and SD8797 WLAN driver
Add SD8897 and SD8797 BT drivers
Bug 1256420
Bug 1279040
Change-Id: I3338479450b1b6716a1e3b899e33de92850c9e85
Signed-off-by: Nagarjuna Kristam <nkristam@nvidia.com>
Reviewed-on: http://git-master/r/235723
Reviewed-by: Mohan Thadikamalla <mohant@nvidia.com>
Add SUSPEND/RESUME flags to Makefiles of SD8897 and SD8797 WLAN drivers
Bug 1279040
Bug 1256420
Change-Id: I2d0518c38b6003a96d3c7447a8a64210ffc319dc
Reviewed-on: http://git-master/r/235722
Bug 1279040
Change-Id: Ifee06a06feb304b039f62f2a3730dc4f04f1e7b5
Reviewed-on: http://git-master/r/235721
bug 1298931
Change-Id: If0037afb285b88dde11fe5f40def8f8fe9727c56
Reviewed-on: http://git-master/r/235215
Note: HPA01112, INA230 and INA231 are similar devices and using the same
driver.
This patch will set correct calibration for the INA230 on Pluto platform
based on the battery in-serial resistor value and max battery current.
After this patch will can read back battery current and power correctly
using the INA230.
This patch also leave comment on how to enable the over-current(OC)
throttling using the INA230 device. It is not enabled on the Pluto
platform currently because MAX77665 is used for the OC throttling.
bug 1298931
Change-Id: I37f40e0d3a9ca14314af4f7ee5a5007c5665581f
Reviewed-on: http://git-master/r/235214
Some charger detected as SDP but it fails enumeration because it is not PC-USB.
In this case, it makes continuous reboot.
power off in charger mode -> PMU reset -> VBUS poweron -> charger mode ->
not detected charger-> power off in charger mode.
Also, this change prevent continuous reboot in detecting charger error case.
Bug 1242042
Bug 1304013
Change-Id: I086fa17ea912b745d9fa0cd21526b78a7215bb44
Signed-off-by: Hyongbin Kim <hyongbink@nvidia.com>
Reviewed-on: http://git-master/r/236708
Reviewed-by: Harshada Kale <hkale@nvidia.com>
Tested-by: Harshada Kale <hkale@nvidia.com>
Change OV5693 device name from "camera" to
"camera.5693".
Bug 1301059
Change-Id: I5d6b88c1ae3d529deb4f6411a558bdb77e385b7f
Signed-off-by: Frank Chen <frankc@nvidia.com>
Reviewed-on: http://git-master/r/237443
Reviewed-by: Yin-Chia Yeh <yyeh@nvidia.com>
Reviewed-by: John Sasinowski <jsasinowski@nvidia.com>
Reviewed-by: Bo Yan <byan@nvidia.com>
"camera.5693".
Bug 1301059
Change-Id: I66714c952a3b539f683ab8f10df7938e01b7189a
Reviewed-on: http://git-master/r/237442
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Adds support to read fuse ID from OTP memory on
ov2710, ov9726, ov9772, ar0832, and imx091 sensors.
Also includes macro-enabled fuse ID programming for
ov2710. Adjusts data structure used by fuse ID ioctl
to include a field for fuse ID size.
Required by nvcamera version 1.8.0
Required by NVCS version 4.10.0
Bug 1198663
Change-Id: Ib3bb0e100e49aea2c6ce13cd069862476d7f4bb6
Signed-off-by: Phil Breczinski <pbreczinski@nvidia.com>
Reviewed-on: http://git-master/r/169187
(cherry picked from commit 0ce57617ee1f735759333a589aa2890559053fe0)
Reviewed-on: http://git-master/r/232254
Reviewed-by: Brian Bamsch <bbamsch@nvidia.com>
Tested-by: Brian Bamsch <bbamsch@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
wifi 32K clk source
ERS(E1569) : clk_32k_out
DVT1(P1640_A00) : clk3_out
DVT2(P1640_A01) : PMIC 32K out
bug 1297696
Change-Id: I54d31c66ad1f8c5bbe61798abc2039aa3bf85f9a
Signed-off-by: Harry Hong <hhong@nvidia.com>
Reviewed-on: http://git-master/r/237553
Reviewed-by: Gabby Lee <galee@nvidia.com>
Reviewed-by: Shawn Joo <sjoo@nvidia.com>
Apply ov7695 qualiy tune register change from OV,
'OV7695 reference setting_MIPI_24MCLK_060713_nVidia.txt'.
Bug 1278482
Change-Id: If14deae5e49cc766c226e57d91a325b3fb1a8134
Signed-off-by: Jake Park <jakep@nvidia.com>
Reviewed-on: http://git-master/r/237108
(cherry picked from commit bf6303da0d525e9656e3da04bde609589945a0c6)
Reviewed-on: http://git-master/r/237161
Change-Id: I292d92ed2abeda5fb2c821b8dc7437771d0a9cf7
Signed-off-by: Sivaram Nair <sivaramn@nvidia.com>
Reviewed-on: http://git-master/r/237147
Reviewed-by: Riham Haidar <rhaidar@nvidia.com>
Tested-by: Riham Haidar <rhaidar@nvidia.com>
Enable TEGRA_PLLM_SCALED & TEGRA_CPU_DVFS
for l4t kernel
Bug 1304476
Change-Id: I235d4a0d056d400c741c0f451a4c15284bbc59fb
Reviewed-on: http://git-master/r/237115
Add typecast in switch statement
Bug 1274537
Change-Id: I03fbce68d449500a3f1de60798e875d5905176eb
Reviewed-on: http://git-master/r/237042
Update cable state during initialisation to have the sync
with the cable state if cable state event is missed which is
happened before initialisation of driver.
bug 1304013
Change-Id: I87eb4c41ab589094639379eff8ed2837893ca892
Reviewed-on: http://git-master/r/234771
Reviewed-by: Hyong Bin Kim <hyongbink@nvidia.com>
Tested-by: Hyong Bin Kim <hyongbink@nvidia.com>
Load xhci dynamically when otg cable is connected
Bug 1242148
Change-Id: If6b9b3ad198e3d1aef7636e9a7752be7a4ccc1c7
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/234146
Enable platform data to load xhci
Bug 1242148
Change-Id: I586f035ceedf49fb321242e7ac2e272620315d7a
Reviewed-on: http://git-master/r/234145
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Keep power on after probe function.
Also change focus position type from u16 to s32 so garbage bytes
aren't passed to the raw header.
Bug 1283378
Change-Id: I6a045ac93a3045e390cee9bd0a9772c6d7668290
Reviewed-on: http://git-master/r/237032
Reviewed-by: Zhaoyi Wei <zwei@nvidia.com>
Reviewed-by: Gilbert Yeung <gyeung@nvidia.com>
Making current x and y offset comparison android specific.
Bug 1216329
Change-Id: Ie28d81fc2bff06237528fba56a348a442233e6c7
Reviewed-on: http://git-master/r/236257
