Do not disable and re-enable clocks after deasserting
PCIE, AFI and PCIEX resets. Deasserting the resets should
be followed by programming the PCIE.
Bug 1521306
Change-Id: Idc43bc9b21cac3818852ed059fe512f4cd75b748
Signed-off-by: Shreshtha SAHU <ssahu@nvidia.com>
Reviewed-on: http://git-master/r/495616
GVS: Gerrit_Virtual_Submit
Reviewed-by: Eric Brower <ebrower@nvidia.com>
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
PCIe Reset line must be asserted for at least 100us after clock is enabled.
PEX 2 Controller Register fix, offsets are not at constant intervals.
Bug 1521306
Reviewed-on: http://git-master/r/225399
(cherry picked from commit df0760bf515236bed2e87e590509642ab72a01b5)
Change-Id: I7b44ea51e7e02f2bca93cfc75ed85e01ab91fe03
Signed-off-by: Shreshtha Sahu <ssahu@nvidia.com>
Reviewed-on: http://git-master/r/435598
Reviewed-by: Jay Agarwal <jagarwal@nvidia.com>
Make sure that we dont enter infinite loop due to
negative value of pins in some cases. Also remove
debugging check for refcount.
Bug 1478467
Change-Id: I7df8efa5b3cf8927a0c18363add4f031aca48e48
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/450209
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Also use nvhost_syncpt_incr_max_ext().
Bug 1478352
Change-Id: Ib868bd2bd7a070e4c410e48bd51977ac45b7d477
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/439471
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
There could be race in refcount update leading to
access of module registers without enabling the clock
and power.This patch tries to catch such instances
and enables power.
Bug 1478467
Change-Id: Ia32da44bfcd7838e312815b6261ccadf4470a761
Reviewed-on: http://git-master/r/448701
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
nvhost_job_unpin should always get the nvmap_handle_ref
from rb_entry after validating handle and presence
in the tree.
Bug 1478467
Change-Id: Ibf5f64a1a82fea8adbf7500bdb36b76357776448
Reviewed-on: http://git-master/r/436076
- remove reduntant emc clock rate set which is controlled by DVFS
- VI's maxim working clock freq is 300MHz
- Change VI clock divider from an integer to a decimal, so the
maxim VI clock on Cardhu should be 272MHz (PLL_P is 408MHz and
divider is 1.5)
Bug 1478352
Change-Id: I4028ed8531d92300d131befb53a4c9dc9f90930d
Reviewed-on: http://git-master/r/419071
Tested-by: Winnie Hsu <whsu@nvidia.com>
Change-Id: I67c50ff86b53a6c1001d2b688251dc55bd2eff55
Reviewed-on: http://git-master/r/419070
The driver should not try to switch to 1.8V when the SD 3.0 host
controller does not have any UHS capabilities bits set (SDR50, DDR50
or SDR104). See page 72 of "SD Specifications Part A2 SD Host
Controller Simplified Specification Version 3.00" under
"1.8V Signaling Enable". Instead of setting SDR12 and SDR25 in the host
capabilities data structure for all V3.0 host controllers, only set them
if SDR104, SDR50 or DDR50 is set in the host capabilities register. This
will prevent the switch to 1.8V later.
Bug 1402031
Acked-by: Arindam Nath <arindam.nath@amd.com>
Acked-by: Philip Rakity <prakity@marvell.com>
Acked-by: Girish K S <girish.shivananjappa@linaro.org>
Signed-off-by: Al Cooper <acooper@gmail.com>
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
Change-Id: I61d3fdb96fce223649075b6c063a3dd227aef062
Reviewed-on: http://git-master/r/365451
The OLPC XO-1.75 laptop includes a SDHCI controller which is 1.8v
capable, and it truthfully reports so in its capabilities. This
alternate voltage is used for driving new "UHS-I" SD cards at their
full speed.
However, what the controller doesn't know is that the motherboard
physically doesn't have a 1.8v supply available.
Add a quirk so that systems such as this one can override disable
1.8v support, adding support for UHS-I cards (by running them at
3.3v).
This avoids a problem where the system would first try to run the
card at 1.8v, fail, and then not be able to fully reset the card
to retry at the normal 3.3v voltage.
This is more appropriate than using the MISSING_CAPS quirk, which
is intended for cases where the SDHCI controller is actually lying
about its capabilities, and would force us to somehow override both
caps words from another source.
Bug 1402031
Change-Id: I7ca070a13241e6403eb2e243ebbc441a311110bc
Signed-off-by: Daniel Drake <dsd@laptop.org>
Reviewed-by: Philip Rakity <prakity@nvidia.com>
Reviewed-on: http://git-master/r/346323
Reworked driver in order to properly support default watchdog api
such as triggering by writing a character and disable by sending
a magic character. Renamed ENABLE_ON_PROBE to ENABLE_HEARTBEAT
which triggers the watchdog using the interrupt service routine.
Original patch:
http://git.toradex.com/gitweb/linux-toradex.git/commitdiff/5da592b805718b4f33897d642f577b1e6511bc2b
Bug 1402031
Change-Id: I33ef556dac6d6717cadc00f8937437b925dc2ca3
Reviewed-on: http://git-master/r/346477
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Disable PCIe Gen2 capability. This is not supported on Tegra 20/30 SOCs.
Bug 1399592
Change-Id: I696a982b93d2e56a3b24379d38e51a5e93e4b7a1
Signed-off-by: Eric Brower <ebrower@nvidia.com>
Reviewed-on: http://git-master/r/326195
Allow the "user" nvmap client to access the
nvmap memory handle of "videobuf2-dma-nvmap" client.
Bug 1421388
Change-Id: Id7a28c06214508d807098a6b258345023192a601
Signed-off-by: Rahool Paliwal <rpaliwal@nvidia.com>
Reviewed-on: http://git-master/r/344620
verify variable screeninfo by checking xres and yres before
validating aspect ratio.
bug 1417318
Change-Id: I473f3e2f30888c053ca53559e33355f216d2a8d3
Signed-off-by: Pankaj Dabade <pdabade@nvidia.com>
Reviewed-on: http://git-master/r/340236
Reviewed-by: Jong Kim <jongk@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Update and synchronize DC window after enabling DC while unblanking.
bug 1416339
Change-Id: I404004e1cbb3908cceade8aa033a660dc488d400
Reviewed-on: http://git-master/r/344778
A request to set brightness to zero is valid irrespective
of what previous brightness of backlight was. A request of
zero brightness disables PWM; so a re-request can be made
to disable a already disabled PWM.
bug 1416333
Change-Id: Ia5f29911456eb5d76fa303bb9070a6f04ec97002
Reviewed-on: http://git-master/r/348366
SKU 0x81 is identical to 0xB1 so same can be used
for sku to speedo ID conversion.
Bug 1313434
Change-Id: I63f08522878524a05c2a6fb0a82fee90a59a99bd
Reviewed-on: http://git-master/r/334396
Setting the resolution to 1088p (as of now), since
there are flickers observed for 1080p and also
the encoder is not compatible with alignement of
the RM surfaces of 1080p. 1088p is a stop-gap solution
until the issues with 1080p are resolved.
Bug 1369083
Change-Id: I3e73076451e7671d90603c6496ad14733591edeb
Reviewed-on: http://git-master/r/309543
Tested-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-by: Kaustubh Purandare <kpurandare@nvidia.com>
Bug 1369083
Change-Id: I1a81bcb62e8f6bb654ffbebba09661187ab4b512
Reviewed-on: http://git-master/r/309536
The tweaks are only specific to r16-r2 branch
and will not go into mainline.
- Pass nvmap memory handle to the user through
the mmap'd buffer allocated by videobuf2 client.
- Allow the "user" nvmap client to access the
Re-arranging the copyright message in nvmap_dev.c
for Automatic validation to pass.
Bug 1369083
Change-Id: Ia27d172253860e79557911c2e848bc9084d662d4
Signed-off-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-on: http://git-master/r/309494
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
This reverts commit dd9a841da571a41d43f1eeaac1785b2adb1d80f3.
The config changes (for V4L2) can be done manually as per need
basis for V4L2, followed by compiling the kernel.
Change-Id: I9174bce0f3da2974ab703b238dfb8fb3bbf607c5
Reviewed-on: http://git-master/r/327607
- Disables TEGRA_CAMERA
- Enables SOC_CAMERA and OV5640 sensor support
Bug 1369083
Change-Id: I073c226e9f04a6f4f4699051f624a755dceb36cb
Reviewed-on: http://git-master/r/309491
Bug 1369083
Change-Id: I1522b688e0681e52592c0f26a8e335937372836a
Reviewed-on: http://git-master/r/279989
Enable OV5650 and OV5640 sensor in Cardhu board file with the help of
Tegra V4L2 SoC camera interface.
To use V4L2 driver, we need to disable old camera HAL driver.
Bug 1240806
Bug 1369083
Change-Id: I0dc529d44fba4d80b45690e384e8bf81b29f69e5
Reviewed-on: http://git-master/r/246266
(cherry picked from commit 6b2f7cc4117208dc992478f27d5873ea38071fdc)
Reviewed-on: http://git-master/r/279988
Add support for dual cameras from both CSI-A and CSI-B:
- move all the CSI settings into video buffer struct
- queue the video buffer struct to a dedicated queue
- process one video buffer struct from the queue at one time
Bug 1369083
Change-Id: Ie64d69282ab991b66e97327e288a2bacde088bd6
Reviewed-on: http://git-master/r/246269
(cherry picked from commit 228b0c2d9ae3fa1121f88836626d654ae0fc4ff0)
Reviewed-on: http://git-master/r/279987
soc_camera_link supports passing power on/off control callback to
soc_camera stack. So the power control can be handled by soc_camera
stack instead of our Tegra V4L2 host driver.
Also pass other platform_data fields via soc_camera_link instead of
a hacking nvhost_device_data struct.
Bug 1240806
Bug 1369083
Change-Id: I443a7d28196cc8292805da70d2d5ff1c3cd50a5d
Reviewed-on: http://git-master/r/246267
(cherry picked from commit 9083d270bf93b583cd5bf5151a52ea250f8541a3)
Reviewed-on: http://git-master/r/279986
Bug 1369083
Change-Id: I43acb0d1dd6ca182291895d294a8458bfc99da05
Reviewed-on: http://git-master/r/279985
Reviewed-by: Allen Martin <amartin@nvidia.com>
Use right buffer flag NVMAP_HANDLE_WRITE_COMBINE to allocate buffer,
which can be shared by VI/CSI and CPU. Don't use NVMAP_HEAP_SYSMEM.
It is validated to old T20 silicon and can't support big buffers. By
default, our nvmap_alloc() will use IOVMM to allocate buffers.
nvmap_pin() gives us IOVA for hardware engines like VI/CSI module
with IOMMU enabled in kernel. nvmap_mmap() gives us VA for CPU
read/write operations. So we need to convert VA address to physical
address of the buffer and map that buffer to user space processor's
memory space "page by page".
Bug 1369083
Change-Id: I4629eebe206c7640adf63551968fd89260dd0082
Reviewed-on: http://git-master/r/279984
- tweak offset registers
- add test mode to output color bars
- use BGGR RAW format
Bug 1369083
Change-Id: I61352c018f8ca099ff3d39158a67052a1e185eec
Reviewed-on: http://git-master/r/279983
Configure pll_a during boot so that
locking to pll_a does not fail
Bug 1330751
Change-Id: I188f0be211379f43770b24c5b382dec2788aefda
Reviewed-on: http://git-master/r/269469
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
DVFS entry is fixed for Hynix_2GB_H5TC4G83MFR-PBA
to support all emc frequencies.
Bug 1218885
Change-Id: Id9d578499e495f43db1a072cbcee25a353fa78f5
Reviewed-on: http://git-master/r/210653
(cherry picked from commit 688bf04ff67e2c1ff22762f4f578b925ff3b9f3c)
Reviewed-on: http://git-master/r/273530
fix Coverity issue
Coverity id : 13692
Bug 1046331
Bug 1049868
Change-Id: Iefa6d076d4622368534710630b89b9a15d166378
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/165864
(cherry picked from commit db33c3f3f2447a52a40f4fd001fec9a2932ee4c8)
Reviewed-on: http://git-master/r/244637
Reviewed-by: Shreshtha Sahu <ssahu@nvidia.com>
Tested-by: Shreshtha Sahu <ssahu@nvidia.com>
Reviewed-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
The firmware is not being in use currently.
So, turn the loading code off.
Bug 1236060
Bug 991551
Change-Id: Id41cf762b59502d0ece470e315ac75d93e3b6b39
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/218613
(cherry picked from commit f15976bdfb32d6c5e20057f6d4d57646c15a5591)
Reviewed-on: http://git-master/r/258354
According to Realtek, the firmware provides
power optimizations. The driver works without
the firmware. Plus, there are scenarios where
the firmware is not available, which makes the
driver wait at request_firmware call (i.e.,
60 sec wait).
Bug 1236060
Bug 991551
Change-Id: Ifcaa4b2dd48c4111ded33cf2bade7dc1f6422821
Reviewed-on: http://git-master/r/258353
Trinity discovered that we fail to check all 64 bits of
attr.config passed by user space, resulting to out-of-bounds
access of the perf_swevent_enabled array in
sw_perf_event_destroy().
Introduced in commit b0a873ebb ("perf: Register PMU
implementations").
Bug 1289245
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
(cherry picked from commit 8176cced706b5e5d15887584150764894e94e02f)
Change-Id: Idde0330d7430f2ba1645f4dfed063c5df9bbb44a
Reviewed-on: http://git-master/r/228851
Reviewed-by: Bo Yan <byan@nvidia.com>
This change is intended to add a few modifications to
cardhu board file (which is also used for beaver)
to get rid of NACK errors occuring due to the absence
of certain hardware components on beaver
Bug 1217572
Change-Id: I1df7b7f777014610e4d64695d89324808ea4f266
Signed-off-by: Darbha Sriharsha <dsriharsha@nvidia.com>
Reviewed-on: http://git-master/r/215983
Reviewed-by: Ramalingam C <ramalingamc@nvidia.com>
Cleaning up of the vdd_ldo4 regulator handling and also control
the multiple calls for regulator_get call for vdd_ldo4
Bug 1241274
Change-Id: I0f62d5059212302956bfe7e48d24eb7f45ff2dda
Signed-off-by: Ramalingam C <ramalingamc@nvidia.com>
Reviewed-on: http://git-master/r/207516
This change is intended to add modifications to
Bug 1217572
Change-Id: I36dfcda1b133c983ce25d56729505bce8b99fdf1
Reviewed-on: http://git-master/r/193667
Disabled CONFIG_INPUT_MOUSEDEV to avoid kernel registering PS/2 mouse
devices, which are mostly not in use now.
Bug 1162832
Change-Id: I0b44af668fa94ffc589e646a842259afa837731e
Signed-off-by: Naveen Kumar S <nkumars@nvidia.com>
Reviewed-on: http://git-master/r/187807
Bug 1162832
Change-Id: If47e654063934d3b60d033a0d2523b8caf97825b
Reviewed-on: http://git-master/r/187808
Enable OV5650 sensor in Cardhu board file with the help of Tegra
Change-Id: I6ff8456941267c05986760f46f658962a940d07e
Reviewed-on: http://git-master/r/200226
CSI host controller of Tegra can support Bayer Raw8 and Raw 10 data
input, it also output data as extended 16-bit data format in memory
directly.
Raw data output should be handled by the second output channel.
This patch add supporting for Raw data input/output and the second
output channel.
All were tested on Cardhu board.
Change-Id: Ifd1d8c94671a1d4571dcf176774e2d3cffafc399
Reviewed-on: http://git-master/r/200225
Change-Id: Ie685ad11a0847be5b51c752ec593aec857e2f0e2
Reviewed-on: http://git-master/r/200224
OV5650 is a RAW sensor outputing Bayer RAW 8 or RAW 10 data.
This driver uses SoC camera interface and supports several
different resolution.
Change-Id: I8075b63b42f7949a264bdef446f5ed8bdc0a9eee
Reviewed-on: http://git-master/r/200223
The VI client within drivers/video/tegra is mutually exclusive with the
Tegra V4L2 framework, since they both want to own the camera hardware.
Change-Id: Idebd0f619f5fc7eb6323b2e08c29c9692c8887a0
Signed-off-by: Andrew Chew <achew@nvidia.com>
Reviewed-on: http://git-master/r/200221
Make it accessible outside of drivers/video/tegra. V4L2 driver needs
to set some platform_data.
Add suport for T20.
Change-Id: I98353c2874ea28cfa0a7a5dd8a1dc4c586af4dd7
Reviewed-on: http://git-master/r/200220
Add battery regulator which is always-on. The rail which is
powered from battery can be added on this rail as consumer.
bug 1218527
Change-Id: I2394e1894649cd4fa736646981374681f603c832
Reviewed-on: http://git-master/r/#change,193052
(cherry picked from commit 4b9cabe87060bf5f252206aba5b62ea1ccb2ff83)
Reviewed-on: http://git-master/r/193777
Tested-by: Preetham Chandru <pchandru@nvidia.com>
enable /dev mount with ACL
Bug 1225372
Bug 1219372
Change-Id: I3b80012e97c3a5ec8358285f81c5111a30ed19f8
Reviewed-on: http://git-master/r/196206
set is_int_enable to true only if we register for a irq.
Bug 1211260
Change-Id: I603efe721796db70d504da7999e5d7939d45d13a
Reviewed-on: http://git-master/r/193047
(cherry picked from commit 8b89b2b64c67d80fcfc29cd4f6a92d4527e70df9)
Reviewed-on: http://git-master/r/195844
Add support for PM315
Bug 1217569
Change-Id: I230fcec04eb5a96441e2c19b304d608d86eaf996
Reviewed-on: http://git-master/r/191555
