dma_alloc_coherent wants to split pages after allocation in order to
reduce the memory footprint. This does not work well with GFP_COMP
pages, so drop this flag before allocation.
This patch is ported from arch/avr32
(commit 3611553ef985ef7c5863c8a94641738addd04cff).
Change-Id: I455cfdc7a2180b8d9d193da5fc8aaf70f8b94ee2
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/57854
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Add code to manage HDA related clocks from HDMI driver. When no HDMI
device is connected to device HDA clocks are disabled to save power.
Whenever HDMI hot plug in happend HDMI driver needs to enable these
clocks before setting HDA presense bit so that HDA controller recieves
the interrupt.
Bug 862023
Change-Id: I975daa1621098eea2175244ce5774312bc396649
Reviewed-on: http://git-master/r/57846
Initializing the pins which is used in gpio to their inital state.
bug 876305
Reviewed-on: http://git-master/r/57516
(cherry picked from commit 3f33cb777295669e71e291bb05651d3c6c4b37d5)
Change-Id: Ie05862e5184bb95c85cf7aa96ce2eca497c01c93
Reviewed-on: http://git-master/r/57817
Adding api which provides the mechanism to getting charging status.
bug 872697
Reviewed-on: http://git-master/r/56625
(cherry picked from commit 4c271cf84923cd5ae9225f41a1a665b116cb974a)
Change-Id: Ibd88cbb568ac65f992a8142934017ed468268d72
Reviewed-on: http://git-master/r/57808
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Adding support for E1257 platform.
bug 864294
Reviewed-on: http://git-master/r/50662
(cherry picked from commit 8217615021a6ffeb992327f6b010ea9deebc34e7)
Change-Id: I3429da1bca38e1ddc5b3c2156a0db6b23aeb5555
Reviewed-on: http://git-master/r/57806
The w_disable pin is connected to different gpio in
E1198-A02 compare to E1198-A01. Making related changes
to support E1198-A02.
bug 864282
Reviewed-on: http://git-master/r/48877
(cherry picked from commit 009e0b9ccf776e658c27df59716cc1cce075ad31)
Change-Id: I85b7f0b10dd3549f07c48e71ffca1a304afc753d
Reviewed-on: http://git-master/r/57790
Avoiding negative number parsing for debug port id.
bug 854995
Reviewed-on: http://git-master/r/57328
(cherry picked from commit 81ce6594db0a2b9131e3a1317ef1f10e8310aad5)
Change-Id: I38e9e545c06a61b79d292c86dcbf8c595d2eddca
Reviewed-on: http://git-master/r/57787
Adding the handler to parse the kernel command "audio_codec".
bug 876544
Reviewed-on: http://git-master/r/56623
(cherry picked from commit b82c518354864c7dba03beea3c576edfab428efd)
Change-Id: Icb42164ea1276f4f5af941b8ba2f80076759af8b
Reviewed-on: http://git-master/r/57779
- enable gamma look-up hardware only when needed to save power
- add flags field to ioctl TEGRA_DC_EXT_SET_LUT for forward compatibility
Bug 868060
Change-Id: I690f8b8856e0b1acd6215907ca8bd78ecaf30b17
Reviewed-on: http://git-master/r/57736
Reviewed-by: David Schalig <dschalig@nvidia.com>
Tested-by: David Schalig <dschalig@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Adds checks for memory allocation failures, and proper propagation
of error conditions. Adds clearing of pointers after free or unpin
has been called to catch use after free.
Bug 877551
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/54027
Reviewed-by: Antti Miettinen <amiettinen@nvidia.com>
Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Tested-by: Gerrit_Virtual_Submit
(cherry picked from commit bfbf2766d11a5f85781532ddce3a87b7ae762ba3)
Change-Id: I04171ee5db6a42bb1689221d4f80d5f3d35e7399
Reviewed-on: http://git-master/r/57462
Fixed the following issues in i2c slave driver:
1) Driver was failing to receive large data
2) Driver was receiving only eight bytes in a loop
3) Incorrect arguments while calling readl
Change-Id: I5ffe76b800a24270845aced0df30a69d9625f557
Reviewed-on: http://git-master/r/57218
Reviewed-by: Bandi Krishna Chaitanya <bandik@nvidia.com>
Tested-by: Bandi Krishna Chaitanya <bandik@nvidia.com>
Disable old tegra-avp and mediaserver and enable nvavp driver for tegra3.
Bug 880683
Change-Id: Ieefbdf37ffc679ebea37293e89d17856a538f848
Signed-off-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-on: http://git-master/r/54675
Hotplug on usb is supported when hotplug flag is set in platform data
Bug 869745
(cherry picked from commit I57ba0b18a2d4232b2df2074c91aff97c6e639e7d)
Reviewed-on: http://git-master/r/54588
Change-Id: I24e5ddf49cead14d3eebe30da0f92402015c95c7
Reviewed-on: http://git-master/r/57725
Tested-by: Artiste Hsu <chhsu@nvidia.com>
CDC ACM driver needs to be built in and should not be a module that
is (manually or via scripts) loaded every time.
bug 886181
Change-Id: Ib211eff977ccbf2fb595fdb7d32593d534547f7b
Reviewed-on: http://git-master/r/57708
Reviewed-by: Sheshagiri Shenoy <sshenoy@nvidia.com>
Tested-by: Sheshagiri Shenoy <sshenoy@nvidia.com>
Reviewed-by: Michael Hsu <mhsu@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Calling regulator_disable causes system to crash when there
is no regualtor. It calls regulator_disable only when regulators
exist.
Bug 871860
Reviewed-on: http://git-master/r/55603
(cherry picked from commit 042e786e9766c891b44b8e00aa05f4c42b724440)
Reviewed-on: http://git-master/r/56237
(cherry picked from commit 9607d33bfcb84f764935ea911b93e716018ab818)
Change-Id: I06cfaeedcbdf276c3a17a759d410c7b46de8e9b1
Reviewed-on: http://git-master/r/57416
Reviewed-by: Jihoon Bang <jbang@nvidia.com>
Tested-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Add regulators to PCA954x in case PCA954x is controlled
by programmable PMIC. Add two Vcc. One is for PCA954x itself
and the other is for I2C bus.
Bug 871860
Reviewed-on: http://git-master/r/54745
(cherry picked from commit 7beddf4e72024e6f140ed306e80a7e1d19d7f36b)
Reviewed-on: http://git-master/r/55800
(cherry picked from commit 57138283d20301658ffe904577a72e9ea95b053e)
Change-Id: Ic98f33d2b8b324b7539d9b5b000a5591c5f7f742
Reviewed-on: http://git-master/r/57415
Add I2C mux driver instance to support two rear sensors.
Add new GPIO pin to control reset for I2C mux.
If board doesn't have I2C mux, it falls back to previous I2C tree.
Bug 871860
Reviewed-on: http://git-master/r/54763
(cherry picked from commit c53f8fc9d5d05427684aafb4ad6552eb6cff7ff7)
Reviewed-on: http://git-master/r/55799
(cherry picked from commit c5fe68c1b4b1ed1e283526c8ac057efb3a2af5af)
Change-Id: I40a35cbd301e53a8d70700043142d5cac0655b5c
Reviewed-on: http://git-master/r/57414
The Auxiliary Control Register for Way-size is three bits.
Mask should be 7.
Change-Id: I2fce4596a2b8ce46b3072005ff44379804bbb3e7
Reviewed-on: http://git-master/r/57256
Tested-by: Antti Miettinen <amiettinen@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Add advanced IP options, such as Multicast, ip filter, etc.
Bug 876711, 876553
Change-Id: I5dd811078f115ea8db3b37f2896c2d1b5f6bcf0e
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/57153
Bug 876711, 876553
Change-Id: I64ecbc40659ab5c2e639e8f09f8453ea39ff7054
Reviewed-on: http://git-master/r/57152
Wait for CDMA to become idle before freeing resources associated with a
channel.
Bug 877665
Change-Id: I1a25f98ba8620202d349a4c6af38fa0e20839751
Reviewed-on: http://git-master/r/56653
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Tested-by: Terje Bergstrom <tbergstrom@nvidia.com>
this needs to be done when the lp2 is aborted before the
stipulated programmed time to wake-up
for bug 867094
Change-Id: I02102ed8afa69d782de5950118352e80edc79df4
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/52581
Reviewed-by: Jin Qian <jqian@nvidia.com>
Change-Id: I4668077a85d82e08db0fee537712a2e4b949007a
Reviewed-on: http://git-master/r/57426
Tested-by: Scott Williams <scwilliams@nvidia.com>
m, n and p coefficients updated for fuse revision 21 and beyond.
- code cleanup done. fixed checkpatch warnings.
bug 842208
Reviewed-on: http://git-master/r/53808
(cherry picked from commit 488785f279a5642fffde3d48d62c77f46a20b63a)
Reviewed-on: http://git-master/r/55026
(cherry picked from commit 49a5b4cf51ed43e2a9d25a2603e84ed835446832)
Change-Id: I83db5a746d5960c799fbf09e2334ecc608c44d39
Reviewed-on: http://git-master/r/57367
Tested-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Error handling in the driver was not correctly done earlier. Changes
done are as follows:
- error returned stored in int data type instead of u8 or s8
- few places error was not checked, added the checks needed.
Reviewed-on: http://git-master/r/51855
(cherry picked from commit c8e014fa9d8a7cad2d78d91fad8fe056b4ea0714)
Reviewed-on: http://git-master/r/54990
(cherry picked from commit 8f9f4a8e72998fef8bea9aa00e9ac136920f8dc0)
Change-Id: Id6da54e8d6d39d47962fa8e74ac91934788267fa
Reviewed-on: http://git-master/r/57365
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
These ioctls provides interface to user space for
VDE/AVP/EMC clock rate anagement. This helps to save power.
Bug 876405
Change-Id: Ic36cd78bf78a3c04dac49dd4b3040542130bc855
Reviewed-on: http://git-master/r/54697
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
The clock control apis can be sleepable in tegra platform as
spi require frequency/voltage boosting.
Moving the clock controls api out of spin lock context.
bug 874841
Reviewed-on: http://git-master/r/56869
(cherry picked from commit b316a4e4fd82f1af9af920079119c56bf271c3be)
Change-Id: I8fc824de02cb3af54f6331efa0500c79e806bb03
Reviewed-on: http://git-master/r/57315
Adding api to configure pins in gpio mode with init value before
gpio library is up. This will provide to configure the pins in
initial state and avoid any glitch in pins.
bug 876305
Reviewed-on: http://git-master/r/56630
(cherry picked from commit 9e357b69d25f96c13acb660860bcdf8e0ab0a1ef)
Change-Id: Ia14721c0bf96e1a45561139fdbbf2d995b9a4963
Reviewed-on: http://git-master/r/57265
Adding the handler function for the kernel command line
option "power_supply".
Reviewed-on: http://git-master/r/50674
(cherry picked from commit 8d9e6bbe59ab68f44a4713f5d1bcc7877baf8180)
Change-Id: I07796b6ee5893d73ac7557e81aac5d26b299c491
Reviewed-on: http://git-master/r/57262
bug 875709
Reviewed-on: http://git-master/r/56632
(cherry picked from commit b7077b25dfaa7c92c5f05f50688d26710eb57348)
Change-Id: I46b0bd4d939e5ffbce9599ad2c437a7d424b1d87
Reviewed-on: http://git-master/r/57258
The SDMMC_VDD control is generated from the cpld programming
for pm269 and so it is not require to have gpio control for this.
bug 880984
Reviewed-on: http://git-master/r/56627
(cherry picked from commit 38ad9be02578b64d3f5eab8c6146abfc6c842d35)
Change-Id: Id7cae7a724c02754b3abbc937a7e80b9a51d7977
Reviewed-on: http://git-master/r/57254
Adding support for PM311 based system.
bug 870139
Reviewed-on: http://git-master/r/50012
(cherry picked from commit d319d9980b6b225735ac97160fdee18fbabba2f0)
Change-Id: Iaa28921761e035e8fa29956b776f9379ae326b42
Reviewed-on: http://git-master/r/57251
Bug: 862023
Change-Id: I3163c5560b9ca37f627eca477b267056e04ba4ab
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/56576
In addition to the currently supported analog capture path, the WM8903
also supports digital mics.
The analog and digital capture paths are exclusive; a mux is present to
select the capture source.
Logically, the mux exists to select the decimator's input, from either
the ADC or DMIC block outputs. However, the ADC power domain also
includes the DMIC interface. Consequently, this change represents the
mux as existing immediately before the ADC, and selecting between the
Input PGA and DMIC block outputs.
An alternative might be to represent the mux in its correct location,
and associate the ADC power enable controls with both the real ADC, and
a fake ADC for the DMIC?
Change-Id: I96dff6a95ce7e5c0d90369cb1bc178d2b14b0f14
Acked-by: Liam Girdwood <lrg@ti.com>
Reviewed-on: http://git-master/r/56137
Bug 872652
Change-Id: Iaea76918169f3270f865122f824f60678c419b50
Reviewed-on: http://git-master/r/55970
Bug: 862023
Change-Id: I1784a813ad8ef224f0587ba977518c2940b66e01
Reviewed-on: http://git-master/r/55674
Add support to convey HP and mic jack status to switch class.
Bug 872652
Change-Id: I2d64c97ef8bf0ab3dfeec3c711ef0e8048bff133
Reviewed-on: http://git-master/r/55670
Complete DAPM route map for cardhu and ventana. Expose more alsa
controls to facilitate codec routing. Properly handle speaker,
internal mic and external mic routing events.
Bug 872652
Change-Id: I4620d08ade1f455a4075d9822fcfd5e34474133f
Reviewed-on: http://git-master/r/55669
Specify device names for ventana and cardhu speaker and digital mic
regulators. Also use same regulator name for ventana and cardhu
speaker supply.
Bug 872652
Change-Id: I5a254eee2037c86e208818f34cdff24aee0edad9
Reviewed-on: http://git-master/r/55668
On cardhu and ventana WM8903 GPIO1 is used for digital mic lrclk
output and GPIO2 is used for digital mic data input. Pass corresponding
WM8903 gpio configuration through platform data to enable cardhu and
ventana digital mic support.
Bug 872652
Change-Id: I410265f1b4f9a8c5e43e5437ed6bac4122709178
Reviewed-on: http://git-master/r/55654
Optimizing the time require to change the voltage by using the
register caching.
bug 870689
Reviewed-on: http://git-master/r/51754
(cherry picked from commit cb2676e3e25f3a6134f38ecb0e3dfe9e7a1f4fd4)
Change-Id: I771d6d0ebad60d05381af07cc791f5ad8b4426fd
Reviewed-on: http://git-master/r/55643
Bug: 862023
Change-Id: Ibaa3ffbb9e81736e45c2bccb0d6e1828cde4025b
Reviewed-on: http://git-master/r/55474
Bug: 862023
Change-Id: I0302091654c5394733264712269be4fe0aefa39a
Reviewed-on: http://git-master/r/55466
Bug: 862023
Change-Id: Ieb9247cef5feecf3e241d8980f9c4376cadf2965
Reviewed-on: http://git-master/r/55465
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
This change enables the below config variables
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_TEGRA=y
CONFIG_INPUT_MOUSE=y
Change-Id: I611d2837a984d6fab5a857f031b7d74169e6b8d5
Signed-off-by: Ramalingam C <ramalingamc@nvidia.com>
Reviewed-on: http://git-master/r/57263
This change includes the keymapping details for chicony keyboard and registers
the platform_device called "tegra-kbc" with all board resources corresponding
to KBC.
Change-Id: I4222914f09520b60882a447fc149fd1c352be037
Reviewed-on: http://git-master/r/57233
Bug 872025
(cherry picked from commit d71aae19a06b591312703d146c9a9adf9f7e729b)
Change-Id: If1c0e3b22079b00b9cabfc1e9f4e5c4c5d206f5b
Reviewed-on: http://git-master/r/57214
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Bo Yan <byan@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Bug 817679
(cherry picked from commit 86acefef882428c6cad6b761521f74b054adba24)
Change-Id: I992c9682fd6bcc9984968f56da661f76a04edecd
Reviewed-on: http://git-master/r/57213
Enabled USB storage & SCSI support
Bug: 879944
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Ifda0c387dd5fab1c4d48c7ab23abab7f3736200b
Reviewed-on: http://git-master/r/56227
Bug 876711, 876553
Change-Id: I7c221f5162411285e9c2c811670ba5c9010fa676
Reviewed-on: http://git-master/r/57154
