2011-07-31arm: tegra: dsi: war to fix dsi issue on suspend DO NOT MERGEtegra-12r5.1-rc1tegra-12r5.1Luke Huang
1. Fix the command for early-suspend/late-resume 2. Disable dsi syncpt, since it is not working reliably Change-Id: I1a1ffc6302b3436c2e3ada328fd3dfd53489d95e Reviewed-on: http://git-master/r/44192 Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com> Tested-by: Chih-Lung Huang <lhuang@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-31arm: tegra: enterprise: disable gov switchingLuke Huang
disable governer switching to avoid kernel panic. Change-Id: I9fc8c9d55f048733d5a502d4c56a3eb0fd786202 Reviewed-on: http://git-master/r/44191 Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com> Tested-by: Chih-Lung Huang <lhuang@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-29arm: tegra: enterprise: disable core dvfs and emc scaling on A01 DO NOT MERGETom Cherry
Change-Id: I4fa224c2ece54aa2f1ccb08d7a6a8b0b86ce2b63 Reviewed-on: http://git-master/r/44037 Reviewed-by: Thomas Cherry <tcherry@nvidia.com> Tested-by: Thomas Cherry <tcherry@nvidia.com> Reviewed-by: Karthik Ramakrishnan <karthikr@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-28nvhost: Re-enabled power gating of MPEtegra-12r5.0Zhijun He
Revert a change that accidentally disabled power gating of MPE. (cherry-pick from http://git-master/r/#change,43047) Bug 854015,854706 Change-Id: Ia56cd22ec44cb4d9fce7ae092485d949b2dc71b5 Reviewed-on: http://git-master/r/43858 Reviewed-by: Zhijun He <zhhe@nvidia.com> Tested-by: Zhijun He <zhhe@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-28arm: tegra: cardhu: Enabling mpu3050 for allAlon Farchy
MPU sensors were disabled for boards other than cardhu e1291. This was because of a bug in the sensor device code, which is fixed in change Ib86327c4. The commit re-enables MPU sensors for other boards. Bug 845739 Bug 828100 Change-Id: I2062598715f820470b05d66ffb2ed4a4a1650eeb Reviewed-on: http://git-master/r/43843 Reviewed-by: Raymond Poudrier <rapoudrier@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com> Tested-by: Ryan Wong <ryanw@nvidia.com>
2011-07-28ARM: tegra: enterprise: Add IO power detection consumers DO NOT MERGEDAlex Frid
Bug 853132 Change-Id: I9b872ca3b741be68cc657b1e44bd026e7266a45d Reviewed-on: http://git-master/r/43798 Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com> Tested-by: Chih-Lung Huang <lhuang@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-28arm: tegra3: enterprise: clean up unused pins DO NOT MERGEWen Yi
Set unused pins to tristate, pull_down, output and gpio mode to minimize power consumption. Special case for bootstrap pins, of which pull_up/ pull_down is set to to normal as they are tugged to ground to the enterpise board. BUG 836834 Change-Id: I2049bd59eae544dbf712280897c1e265dcb0bacd Reviewed-on: http://git-master/r/43813 Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com> Tested-by: Chih-Lung Huang <lhuang@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-28Revert "ARM: tegra: enterprise: Revert Backlight Change" DO NOT MERGELuke Huang
This reverts commit 8b4f1ecadcea91030dfc8522e66aaa339cf95adc. Change-Id: I5bca62b66721dbf8079d49c71d7fbcc39f4eb75e Reviewed-on: http://git-master/r/43810 Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com> Tested-by: Chih-Lung Huang <lhuang@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-28ARM: tegra: enterprise: DC one-shot mode DO NOT MERGEAnimesh Kishore
Send command to panel to enable TE signal. Disable/enable TE signal from panel in suspend/resume. Bug 851754 Change-Id: I63f66d2d16ec43e57c3d2e40abf05acba133fbf0 Reviewed-on: http://git-master/r/43809 Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com> Tested-by: Chih-Lung Huang <lhuang@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-28video:tegra:dsi Add dsi one-shot mode support DO NOT MERGEKevin Huang
Add support for DSI one-shot mode in dsi driver. Change-Id: Ie6762e1a0ea7c32e9a4c3a4642205da639386402 Reviewed-on: http://git-master/r/43808 Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com> Tested-by: Chih-Lung Huang <lhuang@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-28ARM: tegra: cardhu: Enable dynamic IO pad configuration control DO NOT MERGEAlex Frid
Bug 853132 Change-Id: I4a15b6ef75c8ebaf176b5ef791988931998543e2 Reviewed-on: http://git-master/r/43801 Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com> Tested-by: Chih-Lung Huang <lhuang@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-28ARM: tegra: clock: Optimize power consumption of DSI module DO NOT MERGEKevin Huang
- Disable phy clock at early suspend. - Set DSI to LP mode at early suspend Bug 847254 Bug 848069 Change-Id: Ia3199b1848075e7adfc3b8c686d93d4d5655aca5 Reviewed-on: http://git-master/r/43800 Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com> Tested-by: Chih-Lung Huang <lhuang@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-28ARM: tegra: enterprise: Enable dynamic IO pad configuration control DO NOT MERGEAlex Frid
Bug 853132 Change-Id: Ic059afd01a2d0bb664e53b3ed7a939acc7f1bf0c Reviewed-on: http://git-master/r/43799 Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com> Tested-by: Chih-Lung Huang <lhuang@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-28usb: ehci: tegra: Fixing the issues in hsic resume path DO NOT MERGESeshendra Gadagottu
Removed unused legacy code related to "tegra_ehci_recover_rx_error" Correting the sequencing of hsic resume steps. BUG 793840 Change-Id: Ibcbd08bcbd53ce07d4340275932da9989ceedb4f Reviewed-on: http://git-master/r/43748 Reviewed-by: Thomas Cherry <tcherry@nvidia.com> Tested-by: Thomas Cherry <tcherry@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-28arm: tegra: enterprise: EDP support DO NOT MERGEDiwakar Tundlam
Added EDP support for Enterprise board via ext temp sensor nct1008 Bug 824621 Change-Id: Ia3158e9300ac9cd528f25bcfc2dafd15ee90b6da Reviewed-on: http://git-master/r/43749 Tested-by: Thomas Cherry <tcherry@nvidia.com> Reviewed-by: Ryan Wong <ryanw@nvidia.com>
2011-07-27nvhost: Disable 3D power gating due to hangsTerje Bergstrom
After 3D power gating was enabled, the system has exhibited hanging sync points. This patch disables 3D power gating for all systems. Bug 855392,855889 Change-Id: I35c933e31223aacbc2a088793e5c799f2f1ff0ec Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/43427 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Andrew Howe <ahowe@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com>
2011-07-27arm: tegra: cardhu: Fix pinmux warning.Laxman Dewangan
The pin PEX_L1_PRSNT_N is configured in wrong option and so generating the warning. Configuring this in correct option. bug 855392 Change-Id: Ia9131d8e2d68eef1dfe02ff663ec9e1a23e180c8 Reviewed-on: http://git-master/r/43228 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-27ARM: tegra: cardhu: Backlight CorrectionMatt Wagner
Corrected measured backlight linearization table. Bug 827366 Bug 852481 Change-Id: I09a2952f684c4637d0da500c93bd3f1b5ca05daa Reviewed-on: http://git-master/r/42692 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-27tegra: video: dc: Fix no audio after res. changeSumit Bhattacharya
Avoid reseting eld_retrieved flag during tegra_dc_hdmi_disable(). It will ensure if tegra_dc_hdmi_disable() is called due to resolution change, cached eld data is used. It will be reset to zero if during hotplug HDMI driver fails to get valid eld data. Bug 854284 Change-Id: I08c8f48eded0c6a469faf63d601f28627a71602f Reviewed-on: http://git-master/r/42599 Tested-by: Sumit Bhattacharya <sumitb@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2011-07-27video: tegra: dc: fix delay on hdmi modesetDonghan Ryu
wait_event_interruptible_timeout checks the condition before it enters a sleep. Adding a real condition to the function avoids an un-wanted aditional sleep. Bug 833476 Change-Id: I03072d1c3b6efb48e20ed42b55ee2d844a29fbbc Reviewed-on: http://git-master/r/43225 Reviewed-on: http://git-master/r/43426 Reviewed-by: Donghan Ryu <dryu@nvidia.com> Tested-by: Donghan Ryu <dryu@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2011-07-27arm: tegra: fuse: tsensor specific fuse public API addedBitan Biswas
Defined public fuse API to extract tegra3 tsensor configuration parameters. bug 851791 Change-Id: Ia14e2d515ee1d695556492464e8ceaf4b0d13477 Reviewed-on: http://git-master/r/42367 Reviewed-by: Bitan Biswas <bbiswas@nvidia.com> Tested-by: Bitan Biswas <bbiswas@nvidia.com> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com>
2011-07-27hwmon: tegra: tsensor: fix threshold configurationBitan Biswas
tsensor driver changed as follows: 1. conversion of temperature reading into tsensor counter was not working earlier. Fixed this. 2. supported tsensor0 usage for upcoming fuse revision 21 3. tsensor specific fuse data extracted using public fuse APIs bug 851791 bug 855165 Change-Id: I53247f3e029396d5fde479ea168eb279fcae6135 Reviewed-on: http://git-master/r/41037 Reviewed-by: Bitan Biswas <bbiswas@nvidia.com> Tested-by: Bitan Biswas <bbiswas@nvidia.com> Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com> Reviewed-by: Narendra Damahe <ndamahe@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2011-07-27media: tegra: nvavp: Fix for relocation offsetGajanan Bhat
Fix for bug in relocation offset calculation, causing wrong surface offset to be sent to AVP. Change-Id: I6fea7c27a339238d6514276e3316f38ecf8d7742 Reviewed-on: http://git-master/r/42495 Tested-by: Gajanan Bhat <gbhat@nvidia.com> Reviewed-by: Isaac Richards <irichards@nvidia.com> Reviewed-by: Kaz Fukuoka <kfukuoka@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com> Reviewed-by: Soumen Kumar Dey <sdey@nvidia.com> Tested-by: Soumen Kumar Dey <sdey@nvidia.com> Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
2011-07-27ARM: tegra: cardhu: Initialize gpio for lvds_shutdown properly.Kevin Huang
Change-Id: I5f1f13089cc8eaaee9f33b5ef811f4e8036225b0 Reviewed-on: http://git-master/r/43085 Reviewed-by: Kevin Huang <kevinh@nvidia.com> Tested-by: Kevin Huang <kevinh@nvidia.com> Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
2011-07-27regulator: tps6591x: Clear external control setting in shutdownLaxman Dewangan
Clearing the external control configuartion in shutdown on the regulator. bug 839572 Change-Id: I2362c6decb7209aa5f5667de48315ef0bc8926a2 Reviewed-on: http://git-master/r/43048 Tested-by: Vivek Kumar <vivekk@nvidia.com> Reviewed-by: Kaushik Sen <ksen@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com>
2011-07-27ARM: tegra: power: Add package mask to IO pad controlAlex Frid
Modified dynamic IO pad configuration control to support SoC package dependencies: set into "no-io-power state" IO pads that are not bonded out on the particular package. Updated IO power detect table to account for differences in Tegra2 and Tegra3 architecture. Bug 853132 Change-Id: I5f0aedfa784173cc37251ccf4e1dfb4d919db96e Reviewed-on: http://git-master/r/42785 Tested-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Karan Jhavar <kjhavar@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com> Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com> Tested-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
2011-07-26ASOC: tegra: Disable wired jack IRQShridhar Rasal
Added suspend for tegra_wired_jack. Disable tegra_wired_jack GPIO interrupts while going into suspend and enable in resume. Bug 827709 Change-Id: I1f5fd0e0adb437de883a5f897acd22c514e172cb Reviewed-on: http://git-master/r/40363 Reviewed-on: http://git-master/r/42534 Tested-by: Shridhar Rasal <srasal@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2011-07-26arm: tegra: config: Update MODS LDK Kernel configKrishna Monian
- Enable PM in the MODS LDK kernel to resolve a build break caused by dependencies Change-Id: I28a2caad9976860a4a174f650f08e0f8361f73a4 Reviewed-on: http://git-master/r/41925 Tested-by: Krishna Monian <kmonian@nvidia.com> Reviewed-by: Vivek Aseeja <vaseeja@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com>
2011-07-26arm: tegra: enterprise: provide height and width for disp1 panelTom Cherry
Change-Id: Ie6938bfdab2a232c7a79a61faaaaa94718bbbd08 Reviewed-on: http://git-master/r/43139 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-26ARM: tegra: enterprise: Revert Backlight ChangeMatt Wagner
Removed all gpio references to the pwm pin for the backlight. Setting these makes the backlight unchangeable. Change-Id: I9f7d7d909008f083481ec323e6f556c884c1174d Reviewed-on: http://git-master/r/42514 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-26arm: tegra: common: remove initial refcnt on pllmWen Yi
Use pmc registers to shutdown/start pll_m Set the pllm enable bit in APBDEV_PMC_PLLP_WB0_OVERRIDE_0 register before entering LP0 BUG 852523 Change-Id: I8aec1af5ef6ab1cd5c9838232497a54bbc9fa682 Reviewed-on: http://git-master/r/41266 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-26ARM: tegra: add 504MHz entries to pll_d tableJoseph Lehrer
bug 837571 (cherry picked from commit bf2187ca9ebd53a4fdc33135cf2e491361c51f15) Change-Id: Ie961c871f25706deb415dd7820aa1cb0bec79c4b Reviewed-on: http://git-master/r/40379 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-26video: tegra: dc: fix tiled memory efficiencyXin Xie
Tegra3 also supports LPDDR2 which has no tiled memory inefficiency as in DDR3. This patch adds one memory controller API to retrive tiled memory efficiency. BUG 847731 Change-Id: I407914c6035389b696040947e7aebc6ecdb92bb1 Reviewed-on: http://git-master/r/40074 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-26Arm: Tegra: Power: Set throttling ext-sensor temp correctlyDiwakar Tundlam
Bug ID: 844882 - Set throttling temperature in ext temp sensor nct1008 for cardhu to 75C - Fix bug in nct1008 temp sensor driver in disable throttling logic Change-Id: I2ed8aab63186f16c554ca459e71f3437119bd4e6 Reviewed-on: http://git-master/r/42707 Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com> Tested-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Narendra Damahe <ndamahe@nvidia.com> Reviewed-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com>
2011-07-26video: tegra: dsi: Fix DC & DSI clock issue.Kevin Huang
- Balance the clock disable/enable in DSI module to fix the issue that DC can't be disabled in suspend. Bug 847254 Change-Id: I1beaab6d0ba96e9b886526c1f07107b8d27bcf94 Reviewed-on: http://git-master/r/41180 Reviewed-by: Kevin Huang <kevinh@nvidia.com> Tested-by: Kevin Huang <kevinh@nvidia.com> Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com> Tested-by: Chih-Lung Huang <lhuang@nvidia.com> Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
2011-07-26 input: touch: atmel_mxt_ts: Re-enable new Atmel touch driverRobert Collins
BUG 847275 Change-Id: I5db800c2fc37486e04cf1d60e82f03154b4ce221 Reviewed-on: http://git-master/r/40875 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-26input: touch: atmel_mxt_ts: Prevent boot and resume hangs.Robert Collins
Prevents touchscreen hangs during initial TS boot, and TS resume. BUG 847725 BUG 845156 BUG 846711 Change-Id: Ia853574e4b2422eb9368fe37eaf7457bd4022df8 Reviewed-on: http://git-master/r/40261 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-26arm:tegra:pinmux: Set DAP2 to default driveScottPeterson
Removed the setting of the DAP2 pingroup to maximum driver strength. This was a WAR for audio noise issues on Verbier and should not be set on Enterprise. Bug 853161 Change-Id: Ia9bc4021ee1713f0be14e77c984d2266efb06b12 Reviewed-on: http://git-master/r/43084 Tested-by: Scott Peterson <speterson@nvidia.com> Reviewed-by: Chandrakanth Gorantla <cgorantla@nvidia.com> Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com> Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2011-07-25tegra: video: dc: disp1 and overlay at 204MHzVinayak Pane
Overlay was requesting emc 400MHz always during video playback. Playback happens in overlay which was calculated incorrectly. Reducing it to match accurate requirement. Calculate overlay EMC bandwidth requirement same as DC. Change-Id: I5816d9ca1b42cd04048ca16b3e23e6d6ea312137 Reviewed-on: http://git-master/r/42507 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-25ARM: defconfig: enable USB_NET_AX8817X by defaultVandana Salve
This option adds support for ASIX AX88xxx Based USB 2.0 Ethernet Adapters and it works with TrendNet TU2-ET100 devices. Bug 834417 Similar change was done by http://git-master/r/35699 Change-Id: I34ee50e7e872924345ef50e1575eb7cc5f95b5de Reviewed-on: http://git-master/r/42320 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-25ARM: tegra: das: Add port check before set DAP tristateArtiste Hsu
If tagra_dap_port_info_table.dac_port is tegra_das_port_none, das_set_pin_state() should not control tri-state for the DAP pingroup. Bug 824362 Reviewed-on: http://git-master/r/41489 (cherry picked from commit Id48945c21c0e383f5b43cc62ccc610af3a0fd2ee) Change-Id: Ice963957753a2ee6e8be5db2c4d02b2f2e48c694 Reviewed-on: http://git-master/r/42293 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-25arm: tegra: cardhu: Add support for hsic baseband power managementSeshendra Gadagottu
Added required Cardu specific changes for hsic baseband xmm modem power management. BUG 828389 Change-Id: I119f541544cd34e1584608826714d2bfd9cbfe34 Reviewed-on: http://git-master/r/40789 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-25nvhost: Set gr2d clocks to minimum and set timeout=0Mandar Potdar
Set gr2d and related clocks (epp, emc) to minimum. Set Timeout for 2D only to 0. bug: 845598 bug: 843716 Change-Id: I1367274469ef290a08c3fb1f348664b3a38fecd7 Reviewed-on: http://git-master/r/39992 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2011-07-25tegra: alsa: fix headset detection after bootupRavindra Lokhande
if headset is connected during bootup then it was not detected, need to call handler function first time inorder to get status of jack detection during bootup. Change-Id: I39537ac071413717c34e0b13c8527a040c82521e Reviewed-on: http://git-master/r/43063 Tested-by: Ravindra Lokhande <rlokhande@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com> Tested-by: Gerrit_Virtual_Submit
2011-07-25ARM: tegra: ventana: support power sequence timingKen Chang
below variables should be defined according to power sequence specifications of panels. - timing between panel power on to lvds singal enable - timing between lvds signal enable to backlight enable bug 818959 (cherry picked from commit 38c3b4bc7fcda70df84bd4a10112cc1468f0a856) (reviewed on http://git-master/r/41669) Change-Id: I4844baf2cb680e3e898bcf0907be57f29e0c71da Reviewed-on: http://git-master/r/42967 Tested-by: Ken Chang <kenc@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: ChihJen Hsu <chhsu@nvidia.com>
2011-07-25arm: tegra: whistler: defconfig: enable pca953xVarun Wadekar
Bug 836963 Reviewed-on: http://git-master/r/#change,42318 (cherry picked from commit 942ef7c8b435af61f35eb18da89ec1d895a50902) Change-Id: Ia4944e2705f1a6867975835aad0adc29429fc5dc Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/42823 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2011-07-25arm: tegra: whistler: add tca6416 deviceVarun Wadekar
the gpio used for vdd_fuse is powered on by the i2c expander (GPIO_P02) present on the pmu board. Bug 836963 Reviewed-on: http://git-master/r/#change,41738 (cherry picked from commit f0a8261c68a5a7512c940b4098341b98d239580e) Change-Id: Iea34da2f4d86a55a5fcd8748a8512bee3f3480f6 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/42822 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2011-07-25arm: tegra: fuse: declare tegra_fuse_regulator_en() as externVarun Wadekar
platforms need to implement their fuse power on functions if they do not use regulators to power on the fuse block Bug 836963 Reviewed-on: http://git-master/r/#change,41737 (cherry picked from commit 02747e1ddd8391dbb73ee04493417846508ebfbc) Change-Id: I1f462c1e92574e8f64ce2158a4fee8be7f5441ce Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/42821 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2011-07-25ARM: Tegra: Cardhu: Adding SDMMC drive strengthsPavan Kunapuli
Configuring the drive strengths for SDMMC1, SDMMC3 and SDMMC4. Bug 799568 Bug 826694 Change-Id: Ib18c002993eddaf622f48faa0b4e4c9deb0f8e3c Reviewed-on: http://git-master/r/42608 Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com> Tested-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2011-07-25tegra: nand: Added features in the driverBhavesh Parekh
Added 4K page support. Added 16-bit support Added sys interfaces for various operations. Added support for un-aligned page read. Added setting timing values based on vendor-id/device-id. Moved support for setting clock to platform from the driver. Fixed OOB-Read/Write issues. Change-Id: Idf920c1cb0352dcda0282fa399d6c1f57a20736c Reviewed-on: http://git-master/r/42347 Tested-by: Bhavesh Parekh <bparekh@nvidia.com> Reviewed-by: Sandeep Trasi <strasi@nvidia.com> Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
