Increased PLLC VCO for HDMI configuration to reduce jitter.
Bug 734868
Change-Id: Ie898b3806e4e3c69310e9ea7e45c45fa7862de80
Reviewed-on: http://git-master/r/9660
Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com>
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Updated PLL configuration procedure to stop PLL before new settings
are loaded and to keep PLL's differential output disabled after PLL
is re-started until it is locked.
(cherry picked from commit cf47eb637bb505bf199710bdc2f8158b8ac9223c)
Change-Id: I29ba04ea6d931b168eb47a11f12d0a1241d4a266
Reviewed-on: http://git-master/r/9788
enabling kernel configuration variable BT_BLUESLEEP
to support bluesleep functionility on csr
based boards.
BUG 691608
Change-Id: Ia51b39326d2333382ac2318f4d80a51b43975c02
Reviewed-on: http://git-master/r/9692
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Adding bluesleep support for CSR chip
BUG 691608
Change-Id: I5cb9420201e99b36a9ee26a411c0312b3c6e3fa1
Reviewed-on: http://git-master/r/9678
Bug 745437
(cherry picked from commit 40234b8f9194860cc6634a94b6b093ce42c2b45c)
Change-Id: I3686f931edf8167b01175480a005dca909078166
Reviewed-on: http://git-master/r/9541
The POR value of SDD and SDC pin groups is PULL_UP. Now setting to
NORMAL when entering lowpower state and reset back to PULL_UP when
resuming from low power mode.
Bug 718123
(cherry picked from commit e8de286c6c8e06f67c0102d26b52c3249e416e64)
Change-Id: I7d97312a43953103493762720efc4cf678b6dc25
Reviewed-on: http://git-master/r/8863
Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com>
Tested-by: Suresh Mangipudi <smangipudi@nvidia.com>
Clean up warning message caused by unused variable and
improper struct type.
Bug 682070
Change-Id: I3409ad22e67252df14d6d14898aa8792a0019574
Reviewed-on: http://git-master/r/8436
Reviewed-by: Lance Zhao <lazhao@nvidia.com>
Tested-by: Lance Zhao <lazhao@nvidia.com>
Restored core lock sysfs node accidentally deleted by commit
41aebc5456d4c6ae5f8d1543b478739331d500ec
Bug 749303
Change-Id: I87644bf90b7dfe24fb1e8c03f9bfda44048ecd11
Reviewed-on: http://git-master/r/9607
Reviewed-by: Jeff Weintraub <jweintraub@nvidia.com>
Tested-by: Jeff Weintraub <jweintraub@nvidia.com>
New API added to odm_kit to register a callback to use on RTC interrupt.
Supported added for RTC alarms in the max8907b PMU.
Bug 717253
Bug 734529
Change-Id: I34abebd7dd3caf4ef8923fcf651c50f6d245f6b4
Reviewed-on: http://git-master/r/7328
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Tested-by: Jonathan Mayo <jmayo@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Update card_present variable during resume by reading
card detect gpio value inorder to detect cards inserted
during suspend.
Change-Id: Ie3eb7cb09cf84fa0795a21c44b28e07e6302adb7
Reviewed-on: http://git-master/r/8060
Fixed the following:
Missing node creation for debug_fs while doing compaction.
Missing locks in handle_free
Split heap functionality was not creating debugfs node
Misc code clean-up.
roll up of unmerged changes from other branch
Bug 743185
(Cherry picked from commit 396c587981b2d0d1abb1daf481a5fe4bbd0ba70d)
Change-Id: I55249e14ea69c3780b24efbfaea9ceef9ef23534
Reviewed-on: http://git-master/r/8236
Reviewed-by: Thomas Roell <troell@nvidia.com>
Added dm-crypt, loop device support so that applications can be
installed on external storage locations like /sdcard.
Change-Id: I84ad2216b889ea31347ecef3cc84dbac281620c8
Reviewed-on: http://git-master/r/8818
Tested-by: Thomas Cherry <tcherry@nvidia.com>
corrected the function which was not returning correct board id
causing emc dfs to not scale after resuming from suspend.
Change-Id: Iea1a8e8241ccca45d6b7961f82175c37f33f25fb
Reviewed-on: http://git-master/r/7786
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Tested-by: Narendra Damahe <ndamahe@nvidia.com>
On Harmony LDK, USB command verifier tests are failing due to non
availability of the usb function driver to handle the USB requests.
This is fixed by enabling the mass storage client function for device
mode. With this all chapter-9 tests are passing on Harmony LDK.
Bug 749305
Change-Id: Ic9c0901f4fff955de761127fef3ab8056a1039e5
Reviewed-on: http://git-master/r/9549
Tested-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Pull up/down the gpio for vbus when entering or exiting out of
suspend/resume.
Bug 718123
(cherry picked from commit 65f04654231877fdf29d766f73f4e60a251fd975)
Change-Id: I9653dd0241b859da5faf19755b2f8f3e494d3beb
Change-Id: I39f07bdd12a6c9c7038b0a9d4d7318f85664fc53
Reviewed-on: http://git-master/r/9008
The tegra_sdhci structure pointer is passed to the sdhci_readl
and sdhci_writel macros instead of the required sdhci_host
structure pointer. Corrected this.
Change-Id: Icc7172387fc206c65c685e5ee5ee6ab390e9ad89
Reviewed-on: http://git-master/r/9020
Tested-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-by: Rahul Bansal <rbansal@nvidia.com>
Tested-by: Rahul Bansal <rbansal@nvidia.com>
The late resume of touch was not invoked when display was not turned on.
This has been handled now.
Bug 740740
(cherry picked from commit ef6a066e3ad9254312660bbb725be9ed49448ffa)
Change-Id: Id2f1cd255ed59019fb46778da1b93cbe7aa3b8bb
Reviewed-on: http://git-master/r/7973
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
When USB cable is removed from the USB1 port side then VBUS is turned
off but, if USB cable is removed from the device side then VBUS is not
getting turned off and is showing high even when USB cable is removed
completely from the USB1 port. Fixed this by checking the OTG state
"OTG_STATE_A_SUSPEND" and then turning off the VBUS and phy power down.
Bug 741587
Change-Id: Ib8f3dbddc48de0d12179dbd504503621854f44cd
Reviewed-on: http://git-master/r/8199
If serial core driver request for the stop rx then dequeue
the dma request and read the rx fifo only if rx is in progress.
Change-Id: I8cd8a75a59773f0195ed876f7faeb89ac0f2cbec
Reviewed-on: http://git-master/r/7579
Reviewed-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Moved dvfs resume into finish suspend ops call (from the 1st dvfs
thread invocation after suspend). This would guarantee dvfs re-start
in case when suspend is aborted by other driver.
Bug 742504
(cherry picked from commit 3a8bf2922f2f266381c887f3c05b7a755b40fae2)
Added thermal monitor (TMON) suspend/resume functionality.
Bug 698425
Bug 746601
(cherry picked from commit d6aa039689b31d311c836fe478c5943470d7203d)
Change-Id: I643f5bd9021989af569bd0ebba40af60738a6bdf
Reviewed-on: http://git-master/r/8719
Keyboard controller goes to continuous polling mode from
wakeup mode if any key is pressed and stay for hw default
to 5 second. This parameter was not configurable from odm.
It is require to configure this parameter from odm based on
platform.
Adding support for keeping this time as configurable. The default
time still be 5 second if it is not configured from odm.
Change-Id: I0fc11cc2a2d64db33b00c048f87081b6181354fa
Reviewed-on: http://git-master/r/8644
Reviewed-by: Chun-Hung (Alex) Wu <chuwu@nvidia.com>
Tested-by: Chun-Hung (Alex) Wu <chuwu@nvidia.com>
Made sure graphics and sdhci clocks are enabled before the respective
rate is configured.
Change-Id: I2d09ad111321b296a8d8fbb2d4bff02016e12feb
Reviewed-on: http://git-master/r/8272
Enable PPP and USB serial driver used by huawei EM700 modem.
Bug 721467
Change-Id: Ibeedb2660b041c0d08478ecd26c3e958f775d678
Reviewed-on: http://git-master/r/8471
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Tested-by: Rakesh Kumar <krakesh@nvidia.com>
Reviewed-by: Udaykumar Rameshchan Raval <uraval@nvidia.com>
Tuned recently added (commit 98b1475bce96ad088e4105a73d34f1cf803f2ee0)
2d busy hint level to reduce NV omxplayer video-playback power.
Change-Id: Ic8f807e761e13cefed84a1fdaccb81e8c3c79535
Reviewed-on: http://git-master.nvidia.com/r/8473
Reviewed-by: Michael Frydrych <mfrydrych@nvidia.com>
Drastic reduction of ACM timeout to 2ms (from 1sec) resulted in power
increase for NV omxplayer video-playback (bug 738557). The reason is
that short-term scheduling does not provide enough idle time for LP2
state (CPU powered down). On the other hand, 1 sec timeout prevented
core voltage scaling during Android music audio-playback (bug 735111).
Hence, tuned ACM timeout to 25ms.
(cherry picked from commit 32c727ae2c4f91e8d7c9c261921bb62ad14217c9)
Change-Id: I96c46c43e9b3089b6a7e01db5f6d122122758c90
Reviewed-on: http://git-master.nvidia.com/r/8470
Reviewed-by: Hoang Pham <hopham@nvidia.com>
Bug 731923
Reviewed-on: http://git-master/r/7002
(cherry picked from commit b927a389930941297f987cc7967d10d319deba6b)
Change-Id: I576de9b2dfd4245f471ca26636a146ead3df021b
Reviewed-on: http://git-master.nvidia.com/r/8430
Reviewed-by: Venkata (Muni) Anda <vanda@nvidia.com>
Tested-by: Andrew Wright <awright@nvidia.com>
Added EM770 vendor and product id in usb serial driver.
Bug 721467
Change-Id: Ib64820f25b02a69c8a366b9251f9419dd4bfa786
Reviewed-on: http://git-master.nvidia.com/r/8385
Check for pgalloc is not required.
Bug 731923
Reviewed-on: http://git-master/r/7218
(cherry picked from commit 665dba4dd0617f763815bce96dec4a14f8a0c6f6)
Change-Id: I82e701555605f4322a95a66b75ffe3f3bce2a5a6
Reviewed-on: http://git-master.nvidia.com/r/8266
When the memory for a handle is not allocated, and then
if the caller calls _nvmap_handle_free it should
not do the cache operations on the memory as there
is no memory allocated
Bug 731923
Reviewed-on: http://git-master.nvidia.com/r/7166
(cherry picked from commit f3824fd58e2654a0d8d3159cb1f776d3ad0169a2)
Change-Id: Icf11ece6d07e122991e0d9b6b4a3dbf8c45ea017
Reviewed-on: http://git-master.nvidia.com/r/8265
Reviewed-on: http://git-master/r/6507
(cherry picked from commit 3708cd7a859d1ca4f3230bc8bfb018894bb6277e)
Change-Id: I1609b8b8d1f2de51f7eafa2105fb1f695903a252
Reviewed-on: http://git-master.nvidia.com/r/8262
Code added to track i2c and gpio object types on NVRM reftracker. This can be
used to release handles whenever a system crash happens.
This can help properly shutdown and deinitialize imager peripherals.
Bug 728160
Reviewed-on: http://git-master/r/5877
(cherry picked from commit 2661d755bfb401204cacafcc5f944085c19df627)
Change-Id: Iae3d08ef0fa5ef21d1e243249caa386f2a37fc3a
Reviewed-on: http://git-master.nvidia.com/r/8261
Bug 731173
(cherry picked from commit 8961b22287d3f7b6ea33744905675ebd2df236a2)
Change-Id: Icc323fec5507991184b20fcb22e017d2acadd4e3
Reviewed-on: http://git-master/r/8127
Restarted EMC digital dll after EMC clock change.
Bug 722440
Change-Id: Id8b0ea4381302eb9dec85757840587d782a7a793
Reviewed-on: http://git-master/r/8259
The pta pingroup is in NORMAL at POR. Tristating this pingroup at init
by default to reduce the power when enter LP0 mode
Bug 740749
Change-Id: I5ff86c3ddbeb5c608eaee9e11db462acff8ea222
Reviewed-on: http://git-master/r/8109
Tested-by: Hoang Pham <hopham@nvidia.com>
There was typo bug in the gpio-pingroup table where gpio M6
is configured for LD1 pingroup.
Correcting table entry to configure GPIO M6 to pingroup LDI.
Change-Id: I6938e3e7b28525a920c8a8c6eb59d7013c1f97d0
Reviewed-on: http://git-master/r/8182
Reviewed-by: Martin Chi <mchi@nvidia.com>
Tested-by: Martin Chi <mchi@nvidia.com>
Added syncpoints reset to host initialization, to synchronize h/w state
with shadow variables.
Bug 743910
Change-Id: I09420fe2fb85b0e79f0e5d11ade8515e28e96910
Reviewed-on: http://git-master/r/8038
Reviewed-by: Andrew Howe <ahowe@nvidia.com>
Set correct field offset in assert on CPU power request polarity
during suspend initialization.
Bug 741736
Change-Id: Ie7c6589b47b92af815151f6d95ae0acd3030c9cc
Reviewed-on: http://git-master/r/7794
Reviewed-by: Harry Hong <hhong@nvidia.com>
Tested-by: Harry Hong <hhong@nvidia.com>
KBC does not behave properly after resume from LP0 if KBC
is in continuous mode before entering into LP0.
So making sure that KBC should be in wakeup mode before
entering to LP0.
bug 740263
Change-Id: Ia882dfb034bd9ab87811855f2ac20d26fc9581d8
Reviewed-on: http://git-master/r/7756
USB devices are not recognised when connected to the USB port, when system is
already in LP0. Root port power is not getting enabled when resume from LP0.
By the time root hub checks for the port connection auto suspend is getting
called and device is not recognised. Fixed this by enabling the root port power
during the ehci_restart functionality.
Bug 741890
(cherry picked from commit 188bf7050751a40d6f2d6a858e2702774fc70f77)
Change-Id: Ib88ed3fc4b01719777a0e49e27434ef6425bc53d
Reviewed-on: http://git-master/r/7834
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Tested-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Incorrect address is passed to iounmap, which is causing virtual space leak.
Bug 732355
Reviewed-on: http://git-master/r/7554
(cherry picked from commit 593fc2ae6dfadff51ca45353b35dfbd3de0fcce7)
Change-Id: Id69a7b3a6e130c91d594fc0ff32b8080cf192e2c
Reviewed-on: http://git-master/r/7858
Tested-by: Krishna Reddy <vdumpa@nvidia.com>
During resume from LP0 controller is getting restarted in host mode due to this
hcd state is getting changed from the suspend state. Controller state should not
be changed for host mode. Fixed this to restart the controller only in OTG mode.
Bug 724437
(cherry picked from commit cbea530301ae3d9a4a7271d11c819bfc8de8f892)
Change-Id: Idc2897a2790087e00ee66e30fea734c9d117029e
Reviewed-on: http://git-master/r/7833
There is one wmb missing in the usb host controller driver after the queue head
update. Due to this data transaction is not happening on the bus after urb
submission by the hcd driver. Register updates/queue heads data in the memory
is not reflected on the AHB bus. After adding the wmb after queue head update
data transaction the USB bus started with out any delay.
Bug 737242
(cherry picked from commit eff18c3f40253f7af0b576126b954d8572cbea64)
Change-Id: I9f3ae6d8743a03a58034a82f4fe2850fd7278c4f
Reviewed-on: http://git-master/r/7747
In kernel-2.6.32 some times softlockups are seen with cgroup file locking.
Some of the locking issues are fixed in kernel-34. Pulling the kernel-2.6.34
changes related to the cgroups and integrated with k32. With this change
soft lockups with cgroups file locking are not observed.
Bug 714293
Bug 703146
Change-Id: I8debb33d1edb34abdea3169e37a7b4f0ec302f40
cgroups: fix 2.6.32 regression causing BUG_ON() in cgroup_diput()
The LTP cgroup test suite generates a "kernel BUG at kernel/cgroup.c:790!"
here in cgroup_diput():
* if we're getting rid of the cgroup, refcount should ensure
* that there are no pidlists left.
BUG_ON(!list_empty(&cgrp->pidlists));
The cgroup pidlist rework in 2.6.32 generates the BUG_ON, which is caused
when pidlist_array_load() calls cgroup_pidlist_find():
(1) if a matching cgroup_pidlist is found, it down_write's the mutex of the
pre-existing cgroup_pidlist, and increments its use_count.
(2) if no matching cgroup_pidlist is found, then a new one is allocated, it
down_write's its mutex, and the use_count is set to 0.
(3) the matching, or new, cgroup_pidlist gets returned back to pidlist_array_load(),
which increments its use_count -- regardless whether new or pre-existing --
and up_write's the mutex.
So if a matching list is ever encountered by cgroup_pidlist_find() during
the life of a cgroup directory, it results in an inflated use_count value,
preventing it from ever getting released by cgroup_release_pid_array().
Then if the directory is subsequently removed, cgroup_diput() hits the
BUG_ON() when it finds that the directory's cgroup is still populated with
a pidlist.
The patch simply removes the use_count increment when a matching pidlist
is found by cgroup_pidlist_find(), because it gets bumped by the calling
pidlist_array_load() function while still protected by the list's mutex.
Signed-off-by: Dave Anderson <anderson@redhat.com>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Ben Blum <bblum@andrew.cmu.edu>
Cc: Paul Menage <menage@google.com>
Cc: <stable@kernel.org>
cgroups: fix to return errno in a failure path
In cgroup_create(), if alloc_css_id() returns failure, the errno is not
propagated to userspace, so mkdir will fail silently.
To trigger this bug, we mount blkio (or memory subsystem), and create more
then 65534 cgroups. (The number of cgroups is limited to 65535 if a
subsystem has use_id == 1)
# mount -t cgroup -o blkio xxx /mnt
# for ((i = 0; i < 65534; i++)); do mkdir /mnt/$i; done
# mkdir /mnt/65534
(should return ENOSPC)
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Acked-by: Paul Menage <menage@google.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
sched, cgroups: Fix module export
I have exported it in d11c563 - but cgroups.c did not have module.h included ...
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <1266887105-1528-6-git-send-email-paulmck@linux.vnet.ibm.com>
cgroup: introduce cancel_attach()
Add cancel_attach() operation to struct cgroup_subsys. cancel_attach()
can be used when can_attach() operation prepares something for the subsys,
but we should rollback what can_attach() operation has prepared if attach
task fails after we've succeeded in can_attach().
Change-Id: I04a834952591179843f925e7db719df4d82a69bf
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: Li Zefan <lizf@cn.fujitsu.com>
Reviewed-by: Paul Menage <menage@google.com>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
cgroup: introduce coalesce css_get() and css_put()
Current css_get() and css_put() increment/decrement css->refcnt one by
one.
This patch add a new function __css_get(), which takes "count" as a arg
and increment the css->refcnt by "count". And this patch also add a new
arg("count") to __css_put() and change the function to decrement the
These coalesce version of __css_get()/__css_put() will be used to improve
performance of memcg's moving charge feature later, where instead of
calling css_get()/css_put() repeatedly, these new functions will be used.
No change is needed for current users of css_get()/css_put().
Cc: Li Zefan <lizf@cn.fujitsu.com>
cgroups: revamp subsys array
This patch series provides the ability for cgroup subsystems to be
compiled as modules both within and outside the kernel tree. This is
mainly useful for classifiers and subsystems that hook into components
that are already modules. cls_cgroup and blkio-cgroup serve as the
example use cases for this feature.
It provides an interface cgroup_load_subsys() and cgroup_unload_subsys()
which modular subsystems can use to register and depart during runtime.
The net_cls classifier subsystem serves as the example for a subsystem
which can be converted into a module using these changes.
Patch #1 sets up the subsys[] array so its contents can be dynamic as
modules appear and (eventually) disappear. Iterations over the array are
modified to handle when subsystems are absent, and the dynamic section of
the array is protected by cgroup_mutex.
Patch #2 implements an interface for modules to load subsystems, called
cgroup_load_subsys, similar to cgroup_init_subsys, and adds a module
pointer in struct cgroup_subsys.
Patch #3 adds a mechanism for unloading modular subsystems, which includes
a more advanced rework of the rudimentary reference counting introduced in
patch 2.
Patch #4 modifies the net_cls subsystem, which already had some module
declarations, to be configurable as a module, which also serves as a
simple proof-of-concept.
Part of implementing patches 2 and 4 involved updating css pointers in
each css_set when the module appears or leaves. In doing this, it was
discovered that css_sets always remain linked to the dummy cgroup,
regardless of whether or not any subsystems are actually bound to it
(i.e., not mounted on an actual hierarchy). The subsystem loading and
unloading code therefore should keep in mind the special cases where the
added subsystem is the only one in the dummy cgroup (and therefore all
css_sets need to be linked back into it) and where the removed subsys was
the only one in the dummy cgroup (and therefore all css_sets should be
unlinked from it) - however, as all css_sets always stay attached to the
dummy cgroup anyway, these cases are ignored. Any fix that addresses this
issue should also make sure these cases are addressed in the subsystem
loading and unloading code.
This patch:
Make subsys[] able to be dynamically populated to support modular
subsystems
This patch reworks the way the subsys[] array is used so that subsystems
can register themselves after boot time, and enables the internals of
cgroups to be able to handle when subsystems are not present or may
appear/disappear.
Signed-off-by: Ben Blum <bblum@andrew.cmu.edu>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
cgroups: subsystem module loading interface
Add interface between cgroups subsystem management and module loading
This patch implements rudimentary module-loading support for cgroups -
namely, a cgroup_load_subsys (similar to cgroup_init_subsys) for use as a
module initcall, and a struct module pointer in struct cgroup_subsys.
Several functions that might be wanted by modules have had EXPORT_SYMBOL
added to them, but it's unclear exactly which functions want it and which
won't.
cgroups: subsystem module unloading
Provides support for unloading modular subsystems.
This patch adds a new function cgroup_unload_subsys which is to be used
for removing a loaded subsystem during module deletion. Reference
counting of the subsystems' modules is moved from once (at load time) to
once per attached hierarchy (in parse_cgroupfs_options and
rebind_subsystems) (i.e., 0 or 1).
cgroups: clean up cgroup_pidlist_find() a bit
Don't call get_pid_ns() before we locate/alloc the ns.
Cc: Serge Hallyn <serue@us.ibm.com>
cgroup: implement eventfd-based generic API for notifications
This patchset introduces eventfd-based API for notifications in cgroups
and implements memory notifications on top of it.
It uses statistics in memory controler to track memory usage.
Output of time(1) on building kernel on tmpfs:
Root cgroup before changes:
make -j2 506.37 user 60.93s system 193% cpu 4:52.77 total
Non-root cgroup before changes:
make -j2 507.14 user 62.66s system 193% cpu 4:54.74 total
Root cgroup after changes (0 thresholds):
make -j2 507.13 user 62.20s system 193% cpu 4:53.55 total
Non-root cgroup after changes (0 thresholds):
make -j2 507.70 user 64.20s system 193% cpu 4:55.70 total
Root cgroup after changes (1 thresholds, never crossed):
make -j2 506.97 user 62.20s system 193% cpu 4:53.90 total
Non-root cgroup after changes (1 thresholds, never crossed):
make -j2 507.55 user 64.08s system 193% cpu 4:55.63 total
This patch:
Introduce the write-only file "cgroup.event_control" in every cgroup.
To register new notification handler you need:
- create an eventfd;
- open a control file to be monitored. Callbacks register_event() and
unregister_event() must be defined for the control file;
- write "<event_fd> <control_fd> <args>" to cgroup.event_control.
Interpretation of args is defined by control file implementation;
eventfd will be woken up by control file implementation or when the
cgroup is removed.
To unregister notification handler just close eventfd.
If you need notification functionality for a control file you have to
implement callbacks register_event() and unregister_event() in the
struct cftype.
[kamezawa.hiroyu@jp.fujitsu.com: Kconfig fix]
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: Dan Malek <dan@embeddedalley.com>
Cc: Vladislav Buzov <vbuzov@embeddedalley.com>
Cc: Alexander Shishkin <virtuoso@slind.org>
Cc: Davide Libenzi <davidel@xmailserver.org>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Change-Id: I73060a6a951a86a6e2b5d03d36e1777aaf4f9fe2
cgroups: fix race between userspace and kernelspace
Notify userspace about cgroup removing only after rmdir of cgroup
directory to avoid race between userspace and kernelspace.
eventfd are used to notify about two types of event:
- control file-specific, like crossing memory threshold;
- cgroup removing.
To understand what really happen, userspace can check if the cgroup still
exists. To avoid race beetween userspace and kernelspace we have to
notify userspace about cgroup removing only after rmdir of cgroup
directory.
cgroups: remove duplicate include
commit e6a1105b ("cgroups: subsystem module loading interface") and commit
c50cc752 ("sched, cgroups: Fix module export") result in duplicate
including of module.h
cgroup: Fix an RCU warning in alloc_css_id()
With CONFIG_PROVE_RCU=y, a warning can be triggered:
# mount -t cgroup -o memory xxx /mnt
# mkdir /mnt/0
kernel/cgroup.c:4442 invoked rcu_dereference_check() without protection!
This is a false-positive. It's safe to directly access parent_css->id.
(cherry picked from commit cf6e8b67221b96d73c0a9dfb71856627ab4bd1b7)
Change-Id: Ibc9f6adcb55e37834ce030036c83b0405afc13f4
Reviewed-on: http://git-master/r/7823
aplay app and dmix plugin are behaving differently with ALSA
kernel. aplay app modifies appl_ptr on every new buffer.
dmix plugin does not update appl_ptr for new buffers. To
handle these cases play_thread function is split in to three
small functions and checks are added to identify if appl_ptr
gets updated.
For Bug 741242
Change-Id: I24f621a98ba1948dd3f4ae047f7ab407ff473c7b
Reviewed-on: http://git-master/r/7751
Tested-by: Vijay Mali <vmali@nvidia.com>
When user switches on wifi, wifi driver need to poweron wifi card and
ask sdhci stack to enumerate the card. Sdhci stack does not provide any
interface to achieve this. Major wifi vendors depend on platform to
provide wifi poweron/reset/carddetect abstraction function.
Bug ID 739374
Change-Id: I988393352ff6cb54be3d70a59c94f67eedff06fb
Reviewed-on: http://git-master/r/7097
To enable dpd override of the kbc pins during suspend, it needs to
write into dpd override register. By mistake, it was also resetting
the other configuration bits.
Fixing this issue.
bug 739052
Change-Id: I06cf4a7252157418a4789281a79f79946d7f2bdc
Reviewed-on: http://git-master/r/7500
Adding this support to allow USB webcam verification on Ventana.
Bug 722146
Change-Id: Id856ca674faf9cd663fcaf1042569c9b2d733aa8
Reviewed-on: http://git-master/r/7595
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
On k32, remote wake up is enabled in the descriptor based on gadget->ops. Since,
remote wakeup is not supported, disabled gadget->op->remote_wakeup based
on USB_ANDROID.
Bug 710624
(cherry picked from commit c0340053278c9c9ceb98772cc3566d298dca4d9a)
Change-Id: I760632dd38a9f56dadfbb4d446e83f28cdb5338f
Reviewed-on: http://git-master/r/7556
Keep enabling the kc controller only if any of keys are configured
as wakeup source during suspend.
bug 735233
(cherry picked from commit 13825a46587b0508aa7a43054964b76524d5f2b6)
Change-Id: I028965400ee4f96c1460f8e261a2376943384030
Reviewed-on: http://git-master/r/7499
Enabling the config variable CONFIG_I2C_CHARDEV to
enable I2C device interface from user space.
With enabling this, i2c-* device files will be found
in /dev directory. This make it possible to use the
user-space programs to use the I2C bus.
bug 723618
Change-Id: Ib0702e02638f34089ff448b5f28ba8e999544612
Reviewed-on: http://git-master/r/7423
