Minimum voltage for LDO0 was specified with a code construct,
better solve this with a voltage table. This avoids a warning
in kernel log, too.
Bug 798821
Change-Id: I706276a9aae3359006ddc7fe9134b67e00ec34fd
Reviewed-on: http://git-master/r/25185
Reviewed-by: David Schalig <dschalig@nvidia.com>
Tested-by: David Schalig <dschalig@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Assign 0xFC as i2c slave address for all new i2c slaves
BUG 788286
Reviewed-on: http://git-master/r/25101
(cherry picked from commit 32390e01c72732272c933883d0921a80d369c82f)
Change-Id: Id1d19c7b03ff5ce6b4150f2a84ce2885e8edb44c
Reviewed-on: http://git-master/r/25224
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
New i2c slave should be configured with a non-zero i2c address.
Configure i2c slave with an i2c address assigned by platform
data for an i2c dev.
BUG 788286
Reviewed-on: http://git-master/r/25100
(cherry picked from commit e6e0610c72ffce3b734e079faf88fad3f0468d07)
Change-Id: I440aa2cc72007d2835b2027c0b26089d0aad9263
Reviewed-on: http://git-master/r/25223
For getting actual rate, add mux clock inputs to cdev1 and cdev2.
Change-Id: Ic42eb97a51bceb5249ca29938ac00f8add9ef032
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/23187
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Detect vbus and enable clock for usb otg using the interrupt received in
usb phy. usb phy interrupt is configured to max8907c usb detect interrupt to
get event for usb insertion when otg is suspended.
Bug 806949
Change-Id: I73fb92534ce5ae8d1ea39dfe756f940b89af7d79
Reviewed-on: http://git-master/r/24684
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
- spi slave device added.
- clock entry added for spi slave device.
bug 785523
Change-Id: I6d3daeb3e7f4171f2dc4f9ec1fe255f19ea48928
Reviewed-on: http://git-master/r/23554
- the way spi slave driver waits for fifo to be full is fixed.
- rx and tx fifo fill/drain logic fixed.
- added makefile entry and kconfig entry to enable conditional
compiling.
bug 785523
Change-Id: Ib01381704aa2bd519a1146a9cd8efe75646efd6f
Reviewed-on: http://git-master/r/23416
Using a factor of two to increase the emc frequency required by
the display panel to prevent underflow.
Bug 800993
Change-Id: Ibb60a88a4efb384bce6f1277022b335540f11a2e
Reviewed-on: http://git-master/r/24862
Reviewed-by: Wen Yi <wyi@nvidia.com>
Tested-by: Wen Yi <wyi@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
calculate the number of programming cycles to be used to burn
fuses from the oscillator frequency that is being used.
Bug 796825
Change-Id: I1698017f1c9661560d36a9ad613f6a4b1c51df46
Reviewed-on: http://git-master/r/24922
fuses can be read/written via sysfs entries.
fuse sysfs entries will be present under /sys/firmware/fuse
Based on work done by Venu Byravarasu <vbyravarasu@nvidia.com>
Change-Id: Iadb0a83671c8823c541f6bcc2f5f5583d750c1ed
Reviewed-on: http://git-master/r/22763
Setting the USB_TXFILLTUNING to 0x10, where as power on value
is 0x2. With this updated setting USB2 controller under run
are avoided. Setting this value after power_on and post_resume.
Bug 791857
Change-Id: I10ed644ee90d4bc119562699c624568b3a868942
Reviewed-on: http://git-master/r/22735
Reviewed-on: http://git-master/r/23183
Tested-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Fixing the possible upper range for the 16bit clock source
divisor.
Change-Id: Iae5f06b6ce2cbb9c1693963da1b033cfd330c788
Reviewed-on: http://git-master/r/24947
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Devs can disable SMP for debugging. However, there
was a build failure when CONFIG_SMP=n. This change
fixes it with minimum change. It looks like
headsmp.s and headsmp-t2.s cannot be removed from
Makefile since there are stuff used for both
multicore/unicore cpus in it.
Bug 809076
Change-Id: Idc440aa912a98f5decff4c59845af4918e504cd2
Reviewed-on: http://git-master/r/24843
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Tested-by: Donghan Ryu <dryu@nvidia.com>
There is a race condition between fb_blank and pwm_update_status
that could cause kernel panic. The solution is to synchronize
the function tegra_dc_config_pwm with dc->lock.
Bug 803498
Change-Id: I9323cb223aa8feb92f56d0025b2d97ab3b8d1752
Reviewed-on: http://git-master/r/23776
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
clients call the algorithm's close api, which
results in the algo's cra_exit getting called, when
they are done using the hardware. we need to free the
key slot which was being used by the client when its
cra_exit is called.
Change-Id: Ib42d445f5068c4ea1ef6b3edbbc547fe9eeef583
Reviewed-on: http://git-master/r/24673
This reverts commit b7f9c567e6b95074087584672773a167224608d3.
tegra_dma_dequeue() is needed by tegra_hsuart, spi and spi slave.
drivers/serial/tegra_hsuart.c
drivers/usb/host/ehci-tegra.c
Change-Id: Ief6c03a63615a41e85de59ad14dedef309d0b2fb
Change-Id: Iba5041f8428b13791004c96e6e8c2ed4dbcc37b8
Signed-off-by: Erik Gilling <konkers@android.com>
Wait for Start Of Frame interrupt, then wait 20 us, before starting
port resume. Workaround for hardware issue that can cause the SOF to
be sent out at the same time as the phy speed change.
Change-Id: I91ccbd2902448e87aa3cdf1970305de22efa1c10
Signed-off-by: Colin Cross <ccross@android.com>
Add and force debug uart port type to PORT_TEGRA.
Bug 803910
Change-Id: I55c675a4f724bb13005bf37b495df670e208b094
Reviewed-on: http://git-master/r/24468
Set to 18bit which is what Ventana's panel expects.
Enabled ordered dithering for smoother gradients.
Bug 797698
Signed-off-by: Ari Hirvonen <ahirvonen@nvidia.com>
Reviewed-on: http://git-master/r/22717
(cherry picked from commit a904334b06a7b3bf255edadedd8b04055b2a0457)
Change-Id: I4b707068cae7aa91094b77845d779535f276db82
Reviewed-on: http://git-master/r/23346
Change the emc frequency using number of overlays and the frequency
of the display panel.
Bug 800993
Change-Id: I30ef2edd1ed9b43afa8c38b0f05b5d6e49b7f892
Reviewed-on: http://git-master/r/24052
Reviewed-by: Amit Kamath <akamath@nvidia.com>
Reviewed-by: Matthew Longnecker <mlongnecker@nvidia.com>
Currently the machine driver can only do bias level configuration before
the CODEC bias level is brought up. This means that the machine cannot do
any configuration which depends on the CODEC bias level being maintained.
Provide a post-CODEC callback which allows the machine driver to do things
like enable the FLL on a CODEC which is brought down to BIAS_OFF when idle.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cherry-picked from mainline kernel.
Change-Id: Ib0a8533e3762dfc67ee21209a28e9a6603d31a37
Reviewed-on: http://git-master/r/23058
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
In the function tegra_otg_probe(), usbd clock is kept on
after probe function completes. Fix this by disabling the clock
before exiting the probe function.
Bug 803498
Change-Id: I1aa7621f9dfcba1a249cc6d08a23b4106db3c1f2
Change-Id: I3da69f72a312243b3c869543de3f841588bcce89
Reviewed-on: http://git-master/r/23207
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com>
enable debug_uart port as highspeed(ttyHS*) or lowspeed(ttyS*)
according to kernel parameter debug_uartport.
Bug 778978
Change-Id: Icb56357f62ad8375933fb0fe5032b42a59346d79
Reviewed-on: http://git-master/r/24519
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Make dependency on Android switch class driver conditional
so driver compiles on configurations with switch disabled
Change-Id: If0b3ad9b4582bd07b79f27ca3252eeb45050b7c8
Signed-off-by: Allen Martin <amartin@nvidia.com>
Reviewed-on: http://git-master/r/24364
In case of inband interrupts i.e SDIO CARD INT, two
level of thread switching takes place to process wifi
interrupts one in SDHCI and the other in Wifi driver if
"SDIO_ISR_THREAD" flag is disabled.
Enabling "SDIO_ISR_THREAD" flag will prevent deferred
MAC interrupts processing because it is preventing thread
context switching in wifi driver.
Bug 789444
Bug 787054
Bug 795460
Change-Id: I4b00b5a1a3127380699c958d802e5d823078896e
Reviewed-on: http://git-master/r/24273
* Replace phy->instance == 1 with phy_is_ulpi(phy)
* Make the *_phy_power_on functions pass return codes back.
* Move from the freq_sel and u16 table to a freq pointer and an array of
structures.
See:
commit 27c50127f6f64609b7eb3d43bcfd22e85a3e80cf
Author: Benoit Goby <benoit@android.com>
Date: Thu Feb 10 17:41:00 2011 -0800
ARM: tegra: usb_phy: Fix return values
Changed frequency table into a struct
Change-Id: I6df7d0925e4ff91a5a71f782c4f73a55b2135a83
Reviewed-on: http://git-master/r/22171
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-by: Szming Lin <stlin@nvidia.com>
If the device isn't registered for this board, return out of the init
function early.
Change-Id: Ic806b4be1671a77a8fedc1c0376362bc177b0604
Reviewed-on: http://git-master/r/24254
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Anantha Idapalapati <aidapalapati@nvidia.com>
To turn off usb3 and usb3.emc clock, tegra-ehci.2 should be powered off
when bus is supended. Enable power_down_on_bus_suspend for usb3 (tegra-ehci.2).
Also added the platform data structure which is used when USB suspends.
Bug 807237
Change-Id: I9e975daeb2283bd811b2e32acda78b6fa0d9f2b4
Reviewed-on: http://git-master/r/24089
Add UART_CAP_HW_CTSRTS flag to tegra type for supporting auto control
of RTSCTS.
Bug 803910
Change-Id: I7b69e4b203e66903ba5755338fcb55f4a87b9a43
Reviewed-on: http://git-master/r/24463
Initiate broadcast scan (active scan) just after
initializing with network interface.
BUG 781501
Change-Id: I8165b2901509e1a4dc27aff59618cceb27e5690e
Reviewed-on: http://git-master/r/23217
Reviewed-by: Rahul Bansal <rbansal@nvidia.com>
Tested-by: Rahul Bansal <rbansal@nvidia.com>
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
BUG 781501
Change-Id: I6c9bc7b458fff604c12ea3c94c4d4a5255b3bb91
Reviewed-on: http://git-master/r/23216
Use new cam_i2c slave (i2c2) instead of the legacy one.
With old i2c slave controller, occasionally it generates
spurious slave interrupts causing disruptions in i2c transfers.
BUG 790315
Reviewed-on: http://git-master/r/24287
(cherry picked from commit 001805e9036b647e9a1220f2b50e8973ec28e917)
Change-Id: Icd5310286de0338a4458c26a8d491bcded032b03
Reviewed-on: http://git-master/r/24294
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Write protection was disabled in K36. Enabling this feature by
storing the write protection GPIO pin number (wp_gpio) from
platform_data for the device and reading this GPIO (whenever the
card is inserted) to determine whether the card is write protected
or not.
Bug 686892.
Change-Id: I6f1855b7b974caaa5ea58aaee3881d85d5da6c18
Reviewed-in: http://git-master/r/#change,21101
Reviewed-on: http://git-master/r/23971
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
tegra2 has an improved new i2c slave controller. This should be
used instead of the old i2c slave controller. With old i2c slave
controller, occasionally it generates spurious slave interrupts
causing disruptions in master i2c transfers.
BUG 788286
BUG 804545
Reviewed-on: http://git-master/r/24107
(cherry picked from commit 64a6e1d5a555be1c330de80cfb477563ae061452)
Change-Id: Id5d5bd809df4a583a743d84a91aecbb78889a3c6
Reviewed-on: http://git-master/r/24246
Update harmony LDK defconfig to savedefconfig format
Change-Id: I449b5a5e64ee3fecbbbe675232399c325addbc6c
Reviewed-on: http://git-master/r/23274
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Tested-by: Winnie Hsu <whsu@nvidia.com>
Use debug_uartport kernel option to configure debug uart port as
high speed(ttyHS1) or low speed(ttyS0) according to odmdata(19:18).
Bug 803465
Change-Id: Ide9a74c358a42f25ddb3ca03f4d949dc053f59f4
Reviewed-on: http://git-master/r/24019
Ventana has external 20pF cap on RTC XTAL, set PMU
internal cap to minimum value.
Bug 798832, Tested on Ventana/wake via Alarm Clock
Change-Id: I67495f7daddbb226c3b9c652d037fa05766b8276
Reviewed-on: http://git-master/r/22403
Change-Id: Ifb9469d85096eedc0d872b8aac086facfdf7c843
Reviewed-on: http://git-master/r/24084
- fix an incorrect i2c address and a function return check.
- add checks for function returns.
- remove the developer name in the beginning comment.
- fix an uninitialized variable..
Change-Id: I2d42025b7ff47eb6228e626e65990f4da04b94ac
Reviewed-on: http://git-master/r/23594
Tested-by: Qinggang Zhou <qzhou@nvidia.com>
Turn on CONFIG_TEGRA_PWM to expose the functionality of
tegra pwm
Bug 803498
Change-Id: If54876026870d121f6d324ff3c41f8e627c5c5b3
Reviewed-on: http://git-master/r/23720
Reviewed-by: Peter Zu <pzu@nvidia.com>
When early suspension is triggered, blank display and
when later_resume is triggered, un-blank display.
Bug 803498
Change-Id: I2c2a18fbc0074215cf2adf668097d32fa3dbd566
Reviewed-on: http://git-master/r/23719
bug 804615
Change-Id: I11d450febb9ab7b5576f2f67cbf03b8d953c3669
Reviewed-on: http://git-master/r/23885
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
bug 802909
Change-Id: I061eb7082b251ef6963e2a68fd9821122e010966
Reviewed-on: http://git-master/r/23871
Tested-by: Peter Zu <pzu@nvidia.com>
The drive pin groups for i2c are DBG(GEN1_I2C), VI2(CAM_I2C),
AT1(GEN2_I2C) and AO1(PWR_I2C). As there are no entries in
tegra_soc_drive_pingroups table for DTF, I2CP and RM, pg_readl()
and pg_writel() use '0' as reg offset while configuring i2c drive
pin groups.
Change-Id: Ide6aa68ad0d7247791169f1b3e6c84b324c1dfcf
Reviewed-on: http://git-master/r/23831
Change-Id: I82081f6e4e3646fbf7c265851e548ca64b2415db
Reviewed-on: http://git-master/r/23760
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com>
Reviewed-by: Kevin Huang <kevinh@nvidia.com>
Change-Id: Ic9f248b692a2cf7069a39473f0d9ed8266c04ffe
Reviewed-on: http://git-master/r/23748
During suspend/resume wifi chip's power mode is changed and this
impacts chip's internal registers reading/writing. Delaying reads/
writes to wifi chip from HZ/100 to 3*HZ which gives time for chip
to settle its state.
BUG 798783
Change-Id: Ie9c06c2d03fb38b6fba5acca48490d12c358e496
Reviewed-on: http://git-master/r/22150
