2014-04-30Merge tag 'iio-fixes-for-3.15b' of ↵staging-3.15-rc4Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: Second set of fixes for IIO in the 3.15 cycle. * ad2s1200 - Fix some missing parenthesis in a for statement that could have led to an error being missed when getting gpios. * Fix a null derefference issue in the mpu6050 when platform data is not provided (or is provided via the device tree for example). * exynos_adc bug on remove due to child devices having been added to the parent of the IIO device rather than the IIO device itself. This caused an issue with the IIO device removing itself in it's remove function. * Make all ADC drivers buildable as modules to avoid dependency issues if the IIO core is itself built as a module. The exynos adc bug became apparently whilst this fix was being tested.
2014-04-27Linux 3.15-rc3v3.15-rc3Linus Torvalds
2014-04-27word-at-a-time: avoid undefined behaviour in zero_bytemask macroWill Deacon
The asm-generic, big-endian version of zero_bytemask creates a mask of bytes preceding the first zero-byte by left shifting ~0ul based on the position of the first zero byte. Unfortunately, if the first (top) byte is zero, the output of prep_zero_mask has only the top bit set, resulting in undefined C behaviour as we shift left by an amount equal to the width of the type. As it happens, GCC doesn't manage to spot this through the call to fls(), but the issue remains if architectures choose to implement their shift instructions differently. An example would be arch/arm/ (AArch32), where LSL Rd, Rn, #32 results in Rd == 0x0, whilst on arch/arm64 (AArch64) LSL Xd, Xn, #64 results in Xd == Xn. Rather than check explicitly for the problematic shift, this patch adds an extra shift by 1, replacing fls with __fls. Since zero_bytemask is never called with a zero argument (has_zero() is used to check the data first), we don't need to worry about calling __fls(0), which is undefined. Cc: <stable@vger.kernel.org> Cc: Victor Kamensky <victor.kamensky@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-27Merge branch 'safe-dirty-tlb-flush'Linus Torvalds
This merges the patch to fix possible loss of dirty bit on munmap() or madvice(DONTNEED). If there are concurrent writers on other CPU's that have the unmapped/unneeded page in their TLBs, their writes to the page could possibly get lost if a third CPU raced with the TLB flush and did a page_mkclean() before the page was fully written. Admittedly, if you unmap() or madvice(DONTNEED) an area _while_ another thread is still busy writing to it, you deserve all the lost writes you could get. But we kernel people hold ourselves to higher quality standards than "crazy people deserve to lose", because, well, we've seen people do all kinds of crazy things. So let's get it right, just because we can, and we don't have to worry about it. * safe-dirty-tlb-flush: mm: split 'tlb_flush_mmu()' into tlb flushing and memory freeing parts
2014-04-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: limit the path size in send to PATH_MAX Btrfs: correctly set profile flags on seqlock retry Btrfs: use correct key when repeating search for extent item Btrfs: fix inode caching vs tree log Btrfs: fix possible memory leaks in open_ctree() Btrfs: avoid triggering bug_on() when we fail to start inode caching task Btrfs: move btrfs_{set,clear}_and_info() to ctree.h btrfs: replace error code from btrfs_drop_extents btrfs: Change the hole range to a more accurate value. btrfs: fix use-after-free in mount_subvol()
2014-04-27Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull arm fixes from Russell King: "A number of fixes for the PJ4/iwmmxt changes which arm-soc forced me to take during the merge window. This stuff should have been better tested and sorted out *before* the merge window" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8042/1: iwmmxt: allow to build iWMMXt on Marvell PJ4B ARM: 8041/1: pj4: fix cpu_is_pj4 check ARM: 8040/1: pj4: properly detect existence of iWMMXt coprocessor ARM: 8039/1: pj4: enable iWMMXt only if CONFIG_IWMMXT is set ARM: 8038/1: iwmmxt: explicitly check for supported architectures
2014-04-27Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Catalin Marinas: - compat renameat2 syscall wiring and __NR_compat_syscalls fix - TLB fix for transparent huge pages following switch to generic mmu_gather - spinlock initialisation for init_mm's context - move of_clk_init() earlier - Kconfig duplicate entry fix * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: init: Move of_clk_init to time_init arm64: initialize spinlock for init_mm's context arm64: debug: remove noisy, pointless warning arm64: mm: Add THP TLB entries to general mmu_gather arm64: add renameat2 compat syscall ARM64: Remove duplicated Kconfig entry for "kernel/power/Kconfig" arm64: __NR_compat_syscalls fix
2014-04-27Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: "A slighlty large fix for a subtle issue in the CPU hotplug code of certain ARM SoCs, where the not yet online cpu needs to setup the cpu local timer and needs to set the interrupt affinity to itself. Setting interrupt affinity to a not online cpu is prohibited and therefor the timer interrupt ends up on the wrong cpu, which leads to nasty complications. The SoC folks tried to hack around that in the SoC code in some more than nasty ways. The proper solution is to have a way to enforce the affinity setting to a not online cpu. The core patch to the genirq code provides that facility and the follow up patches make use of it in the GIC interrupt controller and the exynos timer driver. The change to the core code has no implications to existing users, except for the rename of the locked function and therefor the necessary fixup in mips/cavium. Aside of that, no runtime impact is possible, as none of the existing interrupt chips implements anything which depends on the force argument of the irq_set_affinity() callback" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clocksource: Exynos_mct: Register clock event after request_irq() clocksource: Exynos_mct: Use irq_force_affinity() in cpu bringup irqchip: Gic: Support forced affinity setting genirq: Allow forcing cpu affinity of interrupts
2014-04-27Merge tag 'tty-3.15-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg KH: "Here are a few tty/serial fixes for 3.15-rc3 that resolve a number of reported issues in the 8250 and samsung serial drivers, as well as a character loss fix for the tty core that was caused by the lock removal patches a release ago" * tag 'tty-3.15-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: serial_core: fix uart PORT_UNKNOWN handling serial: samsung: Change barrier() to cpu_relax() in console output serial: samsung: don't check config for every character serial: samsung: Use the passed in "port", fixing kgdb w/ no console serial: 8250: Fix thread unsafe __dma_tx_complete function 8250_core: Fix unwanted TX chars write tty: Fix race condition between __tty_buffer_request_room and flush_to_ldisc
2014-04-27Merge tag 'staging-3.15-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging / IIO driver fixes from Greg KH: "Here are some small staging and IIO driver fixes for 3.15-rc3. Nothing major at all, just some assorted issues that people have reported" * tag 'staging-3.15-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: comedi: usbdux: bug fix for accessing 'ao_chanlist' in private data iio: adc: mxs-lradc: fix warning when buidling on avr32 iio: cm36651: Fix i2c client leak and possible NULL pointer dereference iio: querying buffer scan_mask should return 0/1 staging:iio:ad2s1200 fix a missing break iio: adc: at91_adc: correct default shtim value ARM: at91: at91sam9260: change at91_adc name ARM: at91: at91sam9g45: change at91_adc name iio: cm32181: Fix read integration time function iio: adc: at91_adc: Repair broken platform_data support
2014-04-27Merge tag 'driver-core-3.15-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core fixes from Greg KH: "Here are some kernfs fixes for 3.15-rc3 that resolve some reported problems. Nothing huge, but all needed" * tag 'driver-core-3.15-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: s390/ccwgroup: Fix memory corruption kernfs: add back missing error check in kernfs_fop_mmap() kernfs: fix a subdir count leak
2014-04-27Merge tag 'usb-3.15-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are a number of USB fixes for 3.15-rc3. The majority are gadget fixes, as we didn't get any of those in for 3.15-rc2. The others are all over the place, and there's a number of new device id addtions as well." * tag 'usb-3.15-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (35 commits) usb: option: add and update a number of CMOTech devices usb: option: add Alcatel L800MA usb: option: add Olivetti Olicard 500 usb: qcserial: add Sierra Wireless MC7305/MC7355 usb: qcserial: add Sierra Wireless MC73xx usb: qcserial: add Sierra Wireless EM7355 USB: io_ti: fix firmware download on big-endian machines usb/xhci: fix compilation warning when !CONFIG_PCI && !CONFIG_PM xhci: extend quirk for Renesas cards xhci: Switch Intel Lynx Point ports to EHCI on shutdown. usb: xhci: Prefer endpoint context dequeue pointer over stopped_trb phy: core: make NULL a valid phy reference if !CONFIG_GENERIC_PHY phy: fix kernel oops in phy_lookup() phy: restore OMAP_CONTROL_PHY dependencies phy: exynos: fix building as a module USB: serial: fix sysfs-attribute removal deadlock usb: wusbcore: fix panic in wusbhc_chid_set usb: wusbcore: convert nested lock to use spin_lock instead of spin_lock_irq uwb: don't call spin_unlock_irq in a USB completion handler usb: chipidea: coordinate usb phy initialization for different phy type ...
2014-04-27Merge tag 'pm+acpi-3.15-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These include a fix for a recent ACPI regression related to device notifications, intel_idle fix related to IvyTown support, fix for a buffer size issue in ACPICA, PM core fix related to the "freeze" sleep state, four fixes for various types of breakage in cpufreq drivers, a PNP workaround for a wrong memory region size in ACPI tables, and a fix and cleanup for the ACPI tools Makefile. Specifics: - Fix for broken ACPI notifications on some systems caused by a recent ACPI hotplug commit that blocked the propagation of unknown type notifications to device drivers inadvertently. - intel_idle fix to make the IvyTown C-states handling (added recently) work as intended which now is broken due to missing braces. From Christoph Jaeger. - ACPICA fix to make it allocate buffers of the right sizes for the Generic Serial Bus operation region access. From Lv Zheng. - PM core fix unblocking cpuidle before entering the "freeze" sleep state which causes that state to be able to actually save more energy than runtime idle. - Configuration and build fixes for the highbank and powernv cpufreq drivers from Kefeng Wang and Srivatsa S Bhat. - Coccinelle warning fix related to error pointers for the unicore32 cpufreq driver from Duan Jiong. - Integer overflow fix for the ppc-corenet cpufreq driver from Geert Uytterhoeven. - Workaround for BIOSes that don't report the entire Intel MCH area in their ACPI tables from Bjorn Helgaas. - ACPI tools Makefile fix and cleanup from Thomas Renninger" * tag 'pm+acpi-3.15-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / notify: Do not block unknown type notifications in root handler PNP: Work around BIOS defects in Intel MCH area reporting cpufreq: highbank: fix ARM_HIGHBANK_CPUFREQ dependency warning cpufreq: ppc: Fix integer overflow in expression cpufreq, powernv: Fix build failure on UP cpufreq: unicore32: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO PM / suspend: Make cpuidle work in the "freeze" state intel_idle: fix IVT idle state table setting ACPICA: Fix buffer allocation issue for generic_serial_bus region accesses. tools/power/acpi: Minor bugfixes
2014-04-26Btrfs: limit the path size in send to PATH_MAXChris Mason
fs_path_ensure_buf is used to make sure our path buffers for send are big enough for the path names as we construct them. The buffer size is limited to 32K by the length field in the struct. But bugs in the path construction can end up trying to build a huge buffer, and we'll do invalid memmmoves when the buffer length field wraps. This patch is step one, preventing the overflows. Signed-off-by: Chris Mason <clm@fb.com>
2014-04-26iio: adc: Nothing in ADC should be a bool CONFIGiio-fixes-for-3.15bDoug Anderson
The whole IIO subsystem can be built as modules. If you make it a module then stuff marked as "Y" in the adc directory simply won't be linked in properly. The two configs that were wrong were EXYNOS_ADC and LP8788_ADC. I know for a fact that EXYNOS_ADC will work as a module. I assume LP8788_ADC will also be fine. Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-04-26iio: exynos_adc: use indio_dev->dev structure to handle child nodesNaveen Krishna Ch
Using pdev->dev with device_for_each_child() would iterate over all of the children of the platform device and delete them. Thus, causing crashes during module unload. We should be using the indio_dev->dev structure for registering/unregistering child nodes. Reported-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com> Reviewed-by: Doug Anderson <dianders@chromium.org> Tested-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-04-26iio:imu:mpu6050: Fixed segfault in Invensens MPU driver due to null dereferenceAtilla Filiz
The driver segfaults when the kernel boots with device tree as the platform data is then not present and the pointer is deferenced without checking it is not null. This patch introduces such a check avoiding the crash. Signed-off-by: Atilla Filiz <atilla.filiz@essensium.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Cc: Stable@vger.kernel.org
2014-04-26staging:iio:ad2s1200 fix missing parenthesis in a for statment.Jimmy Li
Signed-off-by: Jimmy Li <coder.liss@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-04-25mm: split 'tlb_flush_mmu()' into tlb flushing and memory freeing partsLinus Torvalds
The mmu-gather operation 'tlb_flush_mmu()' has done two things: the actual tlb flush operation, and the batched freeing of the pages that the TLB entries pointed at. This splits the operation into separate phases, so that the forced batched flushing done by zap_pte_range() can now do the actual TLB flush while still holding the page table lock, but delay the batched freeing of all the pages to after the lock has been dropped. This in turn allows us to avoid a race condition between set_page_dirty() (as called by zap_pte_range() when it finds a dirty shared memory pte) and page_mkclean(): because we now flush all the dirty page data from the TLB's while holding the pte lock, page_mkclean() will be held up walking the (recently cleaned) page tables until after the TLB entries have been flushed from all CPU's. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Tested-by: Dave Hansen <dave.hansen@intel.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King - ARM Linux <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-26Merge branches 'pnp' and 'acpi-hotplug'Rafael J. Wysocki
* pnp: PNP: Work around BIOS defects in Intel MCH area reporting * acpi-hotplug: ACPI / notify: Do not block unknown type notifications in root handler
2014-04-25Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon fixes from Guenter Roeck: - ltc2945: Don't unecessarily crash kernel on implementation error - vexpress: Fix 'name' and 'label' attributes * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (ltc2945) Don't crash the kernel unnecessarily hwmon: (vexpress) Avoid creating non-existing attributes hwmon: (vexpress) Use legal hwmon device names
2014-04-25Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "This is a set of seven fixes, three (hpsa) and free'd command references correcting bugs in the last round of updates and the remaining four correcting problems within the SCSI error handler that was causing a deadlock within USB" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: [SCSI] More USB deadlock fixes [SCSI] Fix USB deadlock caused by SCSI error handling [SCSI] Fix command result state propagation [SCSI] Fix spurious request sense in error handling [SCSI] don't reference freed command in scsi_prep_return [SCSI] don't reference freed command in scsi_init_sgtable [SCSI] hpsa: fix NULL dereference in hpsa_put_ctlr_into_performant_mode()
2014-04-25Merge tag 'fixes-3.15-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "Since we didn't get around to collect fixes in time for -rc2 over the easter vacation, this one is unfortunately a bit larger than we'd like for an -rc3 merge. A large set of the changes is in the device tree sources, so I'm splitting out the description between code changes and DT changes. Aside from omap and versatile express, the actual code bugs are and trivial. Here is an overview: imx: - fix video clock settings - fix one clock refcounting bug omap: - update defconfig for renamed USB PHY driver - fix error handling in gpmc - fix N900 video initialization regression - fix reression in hwmod code from missing braces - fix am43xx and omap3 clocks - remove bogus write to voltage control register pxa: - fix build regression from 3.13 header cleanup rockchip: - fix a misleading printk string shmobile: - fix incorrect sound setting on multiple machines spear: - remove incorrect __init section annotation tegra: - remove a stale Kconfig entry u300: - update defconfig ux500: - enable common wireless and sensor drivers in defconfig - more defconfig updates vexpress: - fix voltage calculation for opp - fix reboot hang and warning - fix out-of-bounds array access - improve error handling in clock driver overall: - always select CLKSRC_OF in multiplatform builds And these are the devicetree related changes: imx: - add missing #clock-cell properties - fix pinctrl setting in imx6sl-evk - fix video endpoint on imx53 - remove obsolete lvds-channel nodes (multiple patches) - add missing second stmpe node - fix usb host mode on dmo-edmqmx6 (multiple patches) - fix gic node #address-cells to match usage - add missing legacy IRQ map for PCIe - fix microsom pincontrol setting for rgmii - fix fatal typo in touchscreen DT usage for mx5 - list all RAM present on m53evk and mx53qsb omap: - fix bug in DT handling of gpmc external bus - add DT for older revision of beagleboard - fix regression after DT node name fixes - remove obsolete properties for gpmc - fix pinmux comment to match DT it refers to - fix newly added dra7xx clock node data - add missing clock for USB PHY mvebu: - add missing clock for mdio node - fix nonstandard vendor prefixes on i2c nodes rockchip: - fix pin control setting for uart shmobile: - fix typo in DT data for pin control (multiple patches) - fix gic node #address-cells to match usage tegra: - fix clock and uart DT representation to match hardware zynq: - add DT nodes for newly added driver - add DT properties required for cpufreq-ondemand overall: - restore alphabetic order in Makefile - grammar fixes in bindings" * tag 'fixes-3.15-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (66 commits) ARM: vexpress/TC2: Convert OPP voltage to uV before storing power/reset: vexpress: Fix restart/power off operation dt: tegra: remove non-existent clock IDs clk: tegra: remove non-existent clocks ARM: tegra: remove UART5/UARTE from tegra124.dtsi ARM: tegra: remove TEGRA_EMC_SCALING_ENABLE ARM: Tidy up DTB Makefile entries ARM: fix missing CLKSRC_OF on multi-platform ARM: spear: add __init to spear_clocksource_init() ARM: pxa: hx4700.h: include "irqs.h" for PXA_NR_BUILTIN_GPIO arm/mach-vexpress: array accessed out of bounds clk: vexpress: NULL dereference on error path ARM: OMAP2+: Fix GPMC remap for devices using an offset ARM: zynq: dt: Add I2C nodes to Zynq device tree ARM: zynq: DT: Add 'clock-latency' property ARM: OMAP2+: Fix oops for GPMC free ARM: dts: Add support for the BeagleBoard xM A/B ARM: dts: Grammar /that will/it will/ ARM: dts: Grammar /is uses/ is used/ ARM: OMAP2+: Fix config name for USB3 PHY ...
2014-04-25Merge tag 'locks-v3.15-2' of git://git.samba.org/jlayton/linuxLinus Torvalds
Pull file locking fixes from Jeff Layton: "File locking related bugfixes for v3.15 (pile #2) - fix for a long-standing bug in __break_lease that can cause soft lockups - renaming of file-private locks to "open file description" locks, and the command macros to more visually distinct names The fix for __break_lease is also in the pile of patches for which Bruce sent a pull request, but I assume that your merge procedure will handle that correctly. For the other patches, I don't like the fact that we need to rename this stuff at this late stage, but it should be settled now (hopefully)" * tag 'locks-v3.15-2' of git://git.samba.org/jlayton/linux: locks: rename FL_FILE_PVT and IS_FILE_PVT to use "*_OFDLCK" instead locks: rename file-private locks to "open file description locks" locks: allow __break_lease to sleep even when break_time is 0
2014-04-25Merge branch 'for-3.15' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd bugfixes from Bruce Fields: "Three small nfsd bugfixes (including one locks.c fix for a bug triggered only from nfsd). Jeff's patches are for long-existing problems that became easier to trigger since the addition of vfs delegation support" * 'for-3.15' of git://linux-nfs.org/~bfields/linux: Revert "nfsd4: fix nfs4err_resource in 4.1 case" nfsd: set timeparms.to_maxval in setup_callback_client locks: allow __break_lease to sleep even when break_time is 0
2014-04-25s390/ccwgroup: Fix memory corruptionChristian Borntraeger
commit 0b60f9ead5d4816e7e3d6e28f4a0d22d4a1b2513 (s390: use device_remove_file_self() instead of device_schedule_callback()) caused random memory corruption on my s390 box. Turns out that the last element of the ccwgroup structure is of dynamic size, so we must move the newly introduced work structure _before_ the zero length array. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> CC: Tejun Heo <tj@kernel.org> CC: Martin Schwidefsky <schwidefsky@de.ibm.com> CC: Heiko Carstens <heiko.carstens@de.ibm.com> CC: Sebastian Ott <sebott@linux.vnet.ibm.com> CC: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-25kernfs: add back missing error check in kernfs_fop_mmap()Tejun Heo
While updating how mmap enabled kernfs files are handled by lockdep, 9b2db6e18945 ("sysfs: bail early from kernfs_file_mmap() to avoid spurious lockdep warning") inadvertently dropped error return check from kernfs_file_mmap(). The intention was just dropping "if (ops->mmap)" check as the control won't reach the point if the mmap callback isn't implemented, but I mistakenly removed the error return check together with it. This led to Xorg crash on i810 which was reported and bisected to the commit and then to the specific change by Tobias. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-bisected-by: Tobias Powalowski <tobias.powalowski@googlemail.com> Tested-by: Tobias Powalowski <tobias.powalowski@googlemail.com> References: http://lkml.kernel.org/g/533D01BD.1010200@googlemail.com Cc: stable <stable@vger.kernel.org> # 3.14 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-25kernfs: fix a subdir count leakJianyu Zhan
Currently kernfs_link_sibling() increates parent->dir.subdirs before adding the node into parent's chidren rb tree. Because it is possible that kernfs_link_sibling() couldn't find a suitable slot and bail out, this leads to a mismatch between elevated subdir count with actual children node numbers. This patches fix this problem, by moving the subdir accouting after the actual addtion happening. Signed-off-by: Jianyu Zhan <nasa4836@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-25usb: option: add and update a number of CMOTech devicesBjørn Mork
A number of older CMOTech modems are based on Qualcomm chips. The blacklisted interfaces are QMI/wwan. Reported-by: Lars Melin <larsm17@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-25usb: option: add Alcatel L800MABjørn Mork
Device interface layout: 0: ff/ff/ff - serial 1: ff/00/00 - serial AT+PPP 2: ff/ff/ff - QMI/wwan 3: 08/06/50 - storage Cc: <stable@vger.kernel.org> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-25usb: option: add Olivetti Olicard 500Bjørn Mork
Device interface layout: 0: ff/ff/ff - serial 1: ff/ff/ff - serial AT+PPP 2: 08/06/50 - storage 3: ff/ff/ff - serial 4: ff/ff/ff - QMI/wwan Cc: <stable@vger.kernel.org> Reported-by: Julio Araujo <julio.araujo@wllctel.com.br> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-25usb: qcserial: add Sierra Wireless MC7305/MC7355Bjørn Mork
2014-04-25usb: qcserial: add Sierra Wireless MC73xxBjørn Mork
2014-04-25usb: qcserial: add Sierra Wireless EM7355Bjørn Mork
2014-04-25arm64: init: Move of_clk_init to time_initChanho Min
Clock providers should be initialized before clocksource_of_init. If not, Clock source initialization can be fail to get the clock. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Chanho Min <chanho.min@lge.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-04-25USB: io_ti: fix firmware download on big-endian machinesJohan Hovold
During firmware download the device expects memory addresses in big-endian byte order. As the wIndex parameter which hold the address is sent in little-endian byte order regardless of host byte order, we need to use swab16 rather than cpu_to_be16. Also make sure to handle the struct ti_i2c_desc size parameter which is returned in little-endian byte order. Reported-by: Ludovic Drolez <ldrolez@debian.org> Tested-by: Ludovic Drolez <ldrolez@debian.org> Cc: stable@vger.kernel.org Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-25usb/xhci: fix compilation warning when !CONFIG_PCI && !CONFIG_PMDavid Cohen
When CONFIG_PCI and CONFIG_PM are not selected, xhci.c gets this warning: drivers/usb/host/xhci.c:409:13: warning: ‘xhci_msix_sync_irqs’ defined but not used [-Wunused-function] Instead of creating nested #ifdefs, this patch fixes it by defining the xHCI PCI stubs as inline. This warning has been in since 3.2 kernel and was caused by commit 421aa841a134f6a743111cf44d0c6d3b45e3cf8c "usb/xhci: hide MSI code behind PCI bars", but wasn't noticed until 3.13 when a configuration with these options was tried Signed-off-by: David Cohen <david.a.cohen@linux.intel.com> Cc: stable@vger.kernel.org # 3.2 Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-25xhci: extend quirk for Renesas cardsIgor Gnatenko
After suspend another Renesas PCI-X USB 3.0 card doesn't work. [root@fedora-20 ~]# lspci -vmnnd 1912: Device: 03:00.0 Class: USB controller [0c03] Vendor: Renesas Technology Corp. [1912] Device: uPD720202 USB 3.0 Host Controller [0015] SVendor: Renesas Technology Corp. [1912] SDevice: uPD720202 USB 3.0 Host Controller [0015] Rev: 02 ProgIf: 30 This patch should be applied to stable kernel 3.14 that contain the commit 1aa9578c1a9450fb21501c4f549f5b1edb557e6d "xhci: Fix resume issues on Renesas chips in Samsung laptops" Reported-and-tested-by: Anatoly Kharchenko <rfr-bugs@yandex.ru> Reference: http://redmine.russianfedora.pro/issues/1315 Signed-off-by: Igor Gnatenko <i.gnatenko.brain@gmail.com> Cc: stable@vger.kernel.org # 3.14 Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-25xhci: Switch Intel Lynx Point ports to EHCI on shutdown.Denis Turischev
The same issue like with Panther Point chipsets. If the USB ports are switched to xHCI on shutdown, the xHCI host will send a spurious interrupt, which will wake the system. Some BIOS have work around for this, but not all. One example is Compulab's mini-desktop, the Intense-PC2. The bug can be avoided if the USB ports are switched back to EHCI on shutdown. This patch should be backported to stable kernels as old as 3.12, that contain the commit 638298dc66ea36623dbc2757a24fc2c4ab41b016 "xhci: Fix spurious wakeups after S5 on Haswell" Signed-off-by: Denis Turischev <denis@compulab.co.il> Cc: stable@vger.kernel.org Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-25usb: xhci: Prefer endpoint context dequeue pointer over stopped_trbJulius Werner
We have observed a rare cycle state desync bug after Set TR Dequeue Pointer commands on Intel LynxPoint xHCs (resulting in an endpoint that doesn't fetch new TRBs and thus an unresponsive USB device). It always triggers when a previous Set TR Dequeue Pointer command has set the pointer to the final Link TRB of a segment, and then another URB gets enqueued and cancelled again before it can be completed. Further investigation showed that the xHC had returned the Link TRB in the TRB Pointer field of the Transfer Event (CC == Stopped -- Length Invalid), but when xhci_find_new_dequeue_state() later accesses the Endpoint Context's TR Dequeue Pointer field it is set to the first TRB of the next segment. The driver expects those two values to be the same in this situation, and uses the cycle state of the latter together with the address of the former. This should be fine according to the XHCI specification, since the endpoint ring should be stopped when returning the Transfer Event and thus should not advance over the Link TRB before it gets restarted. However, real-world XHCI implementations apparently don't really care that much about these details, so the driver should follow a more defensive approach to try to work around HC spec violations. This patch removes the stopped_trb variable that had been used to store the TRB Pointer from the last Transfer Event of a stopped TRB. Instead, xhci_find_new_dequeue_state() now relies only on the Endpoint Context, requiring a small amount of additional processing to find the virtual address corresponding to the TR Dequeue Pointer. Some other parts of the function were slightly rearranged to better fit into this model. This patch should be backported to kernels as old as 2.6.31 that contain the commit ae636747146ea97efa18e04576acd3416e2514f5 "USB: xhci: URB cancellation support." Signed-off-by: Julius Werner <jwerner@chromium.org> Cc: stable@vger.kernel.org Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-25arm64: initialize spinlock for init_mm's contextLeo Yan
ARM64 has defined the spinlock for init_mm's context, so need initialize the spinlock structure; otherwise during the suspend flow it will dump the info for spinlock's bad magic warning as below: [ 39.084394] Disabling non-boot CPUs ... [ 39.092871] BUG: spinlock bad magic on CPU#1, swapper/1/0 [ 39.092896] lock: init_mm+0x338/0x3e0, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0 [ 39.092907] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G O 3.10.33 #125 [ 39.092912] Call trace: [ 39.092927] [<ffffffc000087e64>] dump_backtrace+0x0/0x16c [ 39.092934] [<ffffffc000087fe0>] show_stack+0x10/0x1c [ 39.092947] [<ffffffc000765334>] dump_stack+0x1c/0x28 [ 39.092953] [<ffffffc0007653b8>] spin_dump+0x78/0x88 [ 39.092960] [<ffffffc0007653ec>] spin_bug+0x24/0x34 [ 39.092971] [<ffffffc000300a28>] do_raw_spin_lock+0x98/0x17c [ 39.092979] [<ffffffc00076cf08>] _raw_spin_lock_irqsave+0x4c/0x60 [ 39.092990] [<ffffffc000094044>] set_mm_context+0x1c/0x6c [ 39.092996] [<ffffffc0000941c8>] __new_context+0x94/0x10c [ 39.093007] [<ffffffc0000d63d4>] idle_task_exit+0x104/0x1b0 [ 39.093014] [<ffffffc00008d91c>] cpu_die+0x14/0x74 [ 39.093021] [<ffffffc000084f74>] arch_cpu_idle_dead+0x8/0x14 [ 39.093030] [<ffffffc0000e7f18>] cpu_startup_entry+0x1ec/0x258 [ 39.093036] [<ffffffc00008d810>] secondary_start_kernel+0x114/0x124 Signed-off-by: Leo Yan <leoy@marvell.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-04-25arm64: debug: remove noisy, pointless warningWill Deacon
Sending a SIGTRAP to a user task after execution of a BRK instruction at EL0 is fundamental to the way in which software breakpoints work and doesn't deserve a warning to be logged in dmesg. Whilst the warning can be justified from EL1, do_debug_exception will already do the right thing, so simply remove the code altogether. Cc: Sandeepa Prabhu <sandeepa.prabhu@linaro.org> Reported-by: Kyrylo Tkachov <kyrylo.tkachov@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-04-25arm64: mm: Add THP TLB entries to general mmu_gatherSteve Capper
When arm64 moved over to the core mmu_gather, it lost the logic to flush THP TLB entries (tlb_remove_pmd_tlb_entry was removed and the core implementation only signals that the mmu_gather needs a flush). This patch ensures that tlb_add_flush is called for THP TLB entries. Signed-off-by: Steve Capper <steve.capper@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-04-25ARM: 8042/1: iwmmxt: allow to build iWMMXt on Marvell PJ4BSebastian Hesselbarth
Some Marvell PJ4B CPUs also implement iWMMXt extensions. With a proper check for iWMMXt coprocessors now in place, enable it by default on PJ4B. While at it, also allow to manually select the corresponding Kconfig option. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-25ARM: 8041/1: pj4: fix cpu_is_pj4 checkSebastian Hesselbarth
Commit fdb487f5c961b94486a78fa61fa28b8eff1954ab ("ARM: 8015/1: Add cpu_is_pj4 to distinguish PJ4 because it has some differences with V7") introduced a cpuid check for Marvell PJ4 processors to fix a regression caused by adding PJ4 based Marvell Dove into multi_v7. Unfortunately, this check is too narrow to catch PJ4 used on Dove itself and breaks iWMMXt support. This patch therefore relaxes the cpuid mask to match both PJ4 and PJ4B. Also, rework the given comment about PJ4/PJ4B modifications to be a little bit more specific about the differences. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-25ARM: 8040/1: pj4: properly detect existence of iWMMXt coprocessorSebastian Hesselbarth
commit fdb487f5c961b94486a78fa61fa28b8eff1954ab ("ARM: 8015/1: Add cpu_is_pj4 to distinguish PJ4 because it has some differences with V7") introduced a fix for checking PJ4 cpuid to not use PJ4 specific coprocessor access on non-PJ4 platforms. Unfortunately, this in turn broke Marvell Armada 370/XP, both comprising Marvell PJ4B CPUs without iWMMXt extension. Instead of only checking for cpuid, which may not be sufficient to determine iWMMXt support, the presence of iWMMXt coprocessors can be checked by enabling and reading the Coprocessor ID register (wCID, register 0 of CP1). Therefore this adds an explicit check for the presence and correct wCID value, before enabling iWMMXt capabilities. As a bonus, also print the iWMMXt version of a detected coprocessor. This has been tested to properly detect iWMMXt presence/absence on: - PJ4, CPUID 0x560f5815, wCID 0x56052001: Marvell Dove, iWMMXt v2 - PJ4B, CPUID 0x561f5811: Marvell Armada 370, no iWMMXt - PJ4B, CPUID 0x562f5841, wCID 0x56052001: Marvell Armada 1500, iWMMXt v2 - PJ4B, CPUID 0x562f5842: Marvell Armada XP, no iWMMXt Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-25ARM: 8039/1: pj4: enable iWMMXt only if CONFIG_IWMMXT is setSebastian Hesselbarth
This fixes PJ4 coprocessor init to only expose iWMMXt capabilities, if the corresponding kernel support for iWMMXt is enabled. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-25ARM: 8038/1: iwmmxt: explicitly check for supported architecturesSebastian Hesselbarth
iwmmxt.S requires special treatment of coprocessor access registers for PJ4 and XScale-based CPUs. It only checks for CPU_PJ4 and drops down to XScale-based treatment on all other architectures. As some PJ4B also come with iWMMXt and also need PJ4 treatment, rework the corresponding preprocessor directives to explicitly check for supported architectures and fail on unsupported ones. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-25Merge tag 'zynq-dt-fixes-for-3.15' of git://git.xilinx.com/linux-xlnx into fixesArnd Bergmann
arm: Xilinx Zynq DT fixes for v3.15 - Enable Zynq I2c - Fix cpufreq DT binding * tag 'zynq-dt-fixes-for-3.15' of git://git.xilinx.com/linux-xlnx: ARM: zynq: dt: Add I2C nodes to Zynq device tree ARM: zynq: DT: Add 'clock-latency' property Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-04-24Btrfs: correctly set profile flags on seqlock retryFilipe Manana
If we had to retry on the profiles seqlock (due to a concurrent write), we would set bits on the input flags that corresponded both to the current profile and to previous values of the profile. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
