2011-09-23ENGR00157540 asrc: fix mx53 ard p2p mode unworkrel_imx_2.6.35_11.09.01Dong Aisheng
1) ESAI does not support 44.1Khz 2) need checking word width for asrc p2p mode Signed-off-by: Dong Aisheng <b29396@freescale.com>
2011-09-23ENGR00157413 asrc: fix mem to mem mode sounds incorrect issueDong Aisheng
Reset reg variable before setting or it will set an unexpected wrong value. Signed-off-by: Dong Aisheng <b29396@freescale.com>
2011-09-21ENGR00156976 - PxP: fix imx-lib build breakDanny Nold
Change from u8 declaration in pxp_dma.h to __u8 Signed-off-by: Danny Nold <dannynold@freescale.com>
2011-09-14ENGR00156420 - EPDC/PxP: Add support for color mapDanny Nold
- Add support for 8-bit grayscale colormaps to be used during EPDC update processing - Add support in PxP for programming of colormaps Signed-off-by: Danny Nold <dannynold@freescale.com>
2011-09-14ENGR00156183-2 sii902x: add error handle of put_pins for probe failJason Chen
there is hardware pin conflict between sii902x DET and egalax touch screen on mx53 loco board. Request gpio during sii902x probe can fix this conflict only when these two module not co-exist. Signed-off-by: Jason Chen <b02280@freescale.com>
2011-09-14ENGR00156183-1 mx53_loco: add get_pins/put_pins call back for sii902xJason Chen
2011-09-08ENGR00156300 - EPDC fb: Move ISR code to work Q & replace spinlocks with mutexesDanny Nold
- Move the majority of code from the IRQ handler routine into a workqueue routine. This should improve system interrupt latency. - Change the spin_lock protecting EPDC queues into a mutex and change all associated spin_lock calls into mutex calls. Signed-off-by: Danny Nold <dannynold@freescale.com>
2011-09-07ENGR00155880 USB device: Fix RNDIS Full Speed hang during initializationAnish Trivedi
When setup irq is received, the status phase of the transfer is primed on ep0 before the data phase. The usb requests are added to the list of transfer descriptors (maintained by driver) in reverse of their expected completion order. Completion order is data followed by status, however the list of tds contains status followed by data. Upon completion of the data request, the irq handler proceeds to check the 1st td in the list -- the status request. In full speed mode, the status phase has not yet completed at this time, so the td's ACTIVE bit is still set. This leads irq handler to ignore the completion interrupt without checking the actual td for the data request that caused the interrupt. In high speed mode, this issue does not bear itself out because the status request also completes by the time the irq handler goes to process the data completion interrupt. The simple fix for this issue is to prime the status request AFTER the data request, so that the list of tds maintained by the driver contains the tds in the order of expected completion. Signed-off-by: Anish Trivedi <anish@freescale.com>
2011-09-07ENGR00156159 usb-device: do not deal with un-enabled device interruptPeter Chen
Do not deal with un-enabled device interrupt Signed-off-by: Peter Chen <peter.chen@freescale.com>
2011-09-06ENGR00155137 mx53 Ripley: enable SWBST in stop modeRobin Gong
Because VUSB is supply by SWBST , we shouldn't off SWBST, otherwise VUSB will not kept in 3.3V , so there is no normal wakeup signal produced when USB device plug in or out after system go into stop mode. Signed-off-by: Robin Gong <B38343@freescale.com>
2011-09-01ENGR00155763 SR:1-776919222 Noise from sgtl5000 when rebootb02247
powerdown DAC,LINE_OUT,HP in shutdown Signed-off-by: b02247 <b02247@freescale.com>
2011-09-01ENGR00155638 mx53 power: Add DDR float pin operation when system idleWayne Zou
1. Add DDR self-refresh mode and float pin operation when system idle For audio playback use case on android r10.3, it can save 10mA@1.54V about 15mW on DDRIO+ memory power, and 6.6mA@2.5V -16.5mW on VDD_REG It can reduce more memory power consumption if cpu idle time is longer 2. remove the L1/L2 cache operation during suspend for mx53 The L1/L2 cache are powered by VDDA/VDDAL1 and they should be supplied according to iMX53 datasheet, there is also no EMPG on MX53, so it can be removed to improve system performance and power. 3. remap the suspend_iram_base as MT_MEMORY_NONCACHED instead of MT_HIGH_VECTORS If the IRAM page is marked as Cacheable, the ARM cache controller will attempt to flush dirty cache lines to DDR, so it can fill those lines with IRAM instruction code. The problem is that the DDR is in self-refresh mode and HighZ DDR IO PADs during system idle or suspend, so any DDR access causes the ARM MPU subsystem to hang. It needs to cherry-pick two patches(5a4aeb9f6,7c8d972d8) from community. 4. Add DDR self-refresh mode and float pin operation for mx53 ARD board, and mx53 QS/Ripley board This patch can resovle ramdom suspend/resume issue, since the early code didn't consider the TLB missing case during suspend. It needs to save all the M4IF/IO MUX registers firstly to make sure the page table entried into TLB, and then enter DDR self-refresh mode. Signed-off-by: Wayne Zou <b36644@freescale.com>
2011-08-31ENGR00155562 [eSDHC]fix DDTS ENGcm03648Tony Lin
fix eSDHC errata 'DDTS ENGcm03648' if it's command with busy, we should poll data0 signal until it's high which means bus is idle. Signed-off-by: Tony Lin <tony.lin@freescale.com>
2011-08-31ARM: 6419/1: mmu: Fix MT_MEMORY and MT_MEMORY_NONCACHED pte flagsSantosh Shilimkar
The commit f1a2481c0 sets up the default flags for MT_MEMORY and MT_MEMORY_NONCACHED memory types. L_PTE_USER flag is wrongly set as default for these entries so remove it. Also adding the 'L_PTE_WRITE' flag so that these pages become read-write instead of just being read-only [this stops them being exposed to userspace, which is the main concern here --rmk] Reported-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-31ARM: 6407/1: mmu: Setup MT_MEMORY and MT_MEMORY_NONCACHED L1 entriesSantosh Shilimkar
This patch populates the L1 entries for MT_MEMORY and MT_MEMORY_NONCACHED types so that at boot-up, we can map memories outside system memory at page level granularity Previously the mapping was limiting to section level, which creates unnecessary additional mapping for which physical memory may not present. On the newer ARM with speculation, this is dangerous and can result in untraceable aborts. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-31ENGR00155268 usb-gadget: fix potential risk between rapid usb cable plug in/outTony Liu
- When usb cable is plugged out, the B_SESSION_VALID interrupt is disabled to avoid usb disconection work queue interrupting. After usb disconection work queue task is finished, re-enable it to generate interrupt. Signed-off-by: Tony Liu <b08287@freescale.com>
2011-08-31ENGR00154940 usb-gadget: Fix wrong vbus discharge operation druing suspendTony Liu
-remove all the un-necessary operation in suspend_irq -remove delay work queue -fix review comments Signed-off-by: Tony Liu <b08287@freescale.com>
2011-08-30ENGR00155574 [eSDHC]fix sdio irq enable bugTony Lin
a counter used in sdhci_enable_sdio_irq function is not correct. calling the function with enable flag will skip enabling the irq if it follows two continuous calls with disable flag because of the counter. to resolve this problem, simply set the counter to 1 or 0 instead of counting. this bug is reported by a customer. Signed-off-by: Tony Lin <tony.lin@freescale.com>
2011-08-30Do not call flush_cache_user_range with mmap_sem heldDima Zavin
[ARM] Do not call flush_cache_user_range with mmap_sem held We can't be holding the mmap_sem while calling flush_cache_user_range because the flush can fault. If we fault on a user address, the page fault handler will try to take mmap_sem again. Since both places acquire the read lock, most of the time it succeeds. However, if another thread tries to acquire the write lock on the mmap_sem (e.g. mmap) in between the call to flush_cache_user_range and the fault, the down_read in do_page_fault will deadlock. Also, since we really can't be holding the mmap_sem while calling flush_cache_user_range AND vma is actually unused by the flush itself, get rid of vma as an argument. Change-Id: If55409bde41ad1060fa4fe7cbd4ac530d4d9a106 Signed-off-by: Dima Zavin <dima@android.com>
2011-08-29ENGR00155472 mx53_loco: support for RevB and RevA of Ripely mx53_locoRobin Gong
in board_init ,kernel will read the system_rev TAG from uboot and configure the right interrupt gpio Signed-off-by: Robin Gong <B38343@freescale.com>
2011-08-29ENGR00155145 ipuv3 disp pos: restore pos setting after channel disable.Jason Chen
FG pos need be reset to 0 when channel disable, but it will lost old setting. Signed-off-by: Jason Chen <b02280@freescale.com>
2011-08-29ENGR00153474 ipuv3 split mode: vf and enc task display with errorJason Chen
For split mode, if using vf/enc task, the display is not correct. Signed-off-by: Jason Chen <b02280@freescale.com>
2011-08-29ENGR00155141 ipuv3 split mode: adjust split calculate functionJason Chen
One issue was found in split mode: For input 1024x600, output 1360x768, after stripe calculation, input width and input column are not right. This patch fix this issue. Signed-off-by: Jason Chen <b02280@freescale.com>
2011-08-26ENGR00155292 usb-host: do not clear RS bit when usb bus goes to suspendPeter Chen
The standard EHCI design will clear RS bit after usb bus goes to suspend, but it causes some remote wakeup issues, like remote-wakeup featured device will be reset after resuming. According to usb 2.0 spec, the SOF need to be sent out within 3ms after resume signal ends, or device may consider host disconnects with device. Freescale's USB Controller (Chipidea's core) will ends up resume signal automatically within 21ms after it recevices remote wakeup signal. So, if software does not set RS bit within 21ms after it recevices remote wakeup signal, the problem described above will be occurred. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2011-08-24ENGR00155282 mc34708: support to build mc34708 driver onlyLily Zhang
1. If change defconfig and only build in mc34708 dirver, the following error is reported: undefined reference to `mc13892_alloc_data' undefined reference to `mc13892_init_registers' undefined reference to `mc13892_get_revision' This patch is to fix above compiling error. 2. Add mc34708 dependency in Kconfig Signed-off-by: Lily Zhang <r58066@freescale.com>
2011-08-24ENGR00144145-2 usb: can be built as loadable modulesPeter Chen
Driver part Please follow below load sequence to use OTG - fsl_otg_arc - ehci-hcd - arcotg_udc Besides, in order to match i.mx53 release windows, it changes some common code, there will be a better solution at 2.6.38 in future Signed-off-by: Peter Chen <peter.chen@freescale.com>
2011-08-24ENGR00144145-1 usb: can be built as loadable modulesPeter Chen
MSL part Follow below load sequence to use OTG - fsl_otg_arc - ehci-hcd - arcotg_udc Besides, in order to match i.mx53 release windows, it changes some common code, there will be a better solution at 2.6.38 in future Signed-off-by: Peter Chen <peter.chen@freescale.com>
2011-08-22ENGR00155173 mx53_ard: fix CAN unable to communicate issueDong Aisheng
Merge this patch for SR 1-775080061. The error is the system can find the CAN bus, but cannot communicate physically. Signed-off-by: Dong Aisheng <b29396@freescale.com>
2011-08-22ENGR00155100 mx5: Use CONFIG_MXS_DMA_ENGINE to control DMA codeLily Zhang
Use CONFIG_MXS_DMA_ENGINE flag to control mxs dma engine code Signed-off-by: Lily Zhang <r58066@freescale.com>
2011-08-22ENGR00154458 Mx53 clock: close ssi_ext1_clkYuxi Sun
Set this clock closed by default, and open it when it is needed. Signed-off-by: Yuxi Sun <b36102@freescale.com>
2011-08-19ENGR00144056 MX53_SMD: COIN_CELL, no power supply for coin cellWayne Zou
enable coin cell battery charger Signed-off-by: Wayne Zou <b36644@freescale.com>
2011-08-19ENGR00154704 usb-gadget: wmb is needed after dtd pointer is updated for armv7Peter Chen
At armv7 SoC, the dma_alloc_coherent returns non-cachable, but bufferable region, so the driver needs to drain write buffer by itself, if the controller needs to visit dma buffer immediately after cpu writes There is a discussion for this armv7 change: http://marc.info/?t=127918539100004&r=1&w=2 For this issue, the next dtd pointer is invalid sometimes, the reason is the region which is used to store dtd is dma buffer, so the data may not be written to memory when the controller visit this data. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2011-08-19ENGR00154703 usb-gadget: fix spin_lock recursion problem at SMP platformPeter Chen
- The spin_lock is at interrupt handler, so all code routines using at interrupt handler are forbidden to hold spin_lock again - Move the code which needs to be protected by spin_lock to workqueue, and it will be called when workqueue is scheduled. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2011-08-17ENGR00154044 usb-otg: the device is invalid when usb device at otg portPeter Chen
Below bugs are fixes: - the device is invalid when usb device at otg port The reason is udc->suspended is incorrect when otg as host mode during boot up - The disconnect can't be detected if usb is online when booting up The reason is the vbus interrupt enable is cleared by otg switch work Signed-off-by: Peter Chen <peter.chen@freescale.com>
2011-08-16ENGR00154880 ipuv3 dev: wait event could be signal returnJason Chen
wait_event_interruptible_timeout function could be signal return, so we need add ERESTARTSYS return value to let libc retry sys call. Signed-off-by: Jason Chen <b02280@freescale.com>
2011-08-12ENGR00154775 esdhc: provide clock enable interfaceDong Aisheng
1) do not always open clock for sdio card until sdio driver loaded 2) WiFi should disable host clock for host when unloaded because host has no sense when sdio driver unloadded. Noted the clock disable should at the end of SDIO driver remove callback. Signed-off-by: Dong Aisheng <b29396@freescale.com>
2011-08-10ENGR00152844 pmic_wm8325: Add wm8325 driver supportWayne Zou
Add Wolfson PMIC WM8325 driver support Signed-off-by: Wayne Zou <b36644@freescale.com>
2011-08-09ENGR00154437 mxc edid: add cea extend revision 1 and 2 supportJason Chen
Add cea extend revision 1 and 2 support. Signed-off-by: Jason Chen <b02280@freescale.com>
2011-08-08ENGR00154431 - MXCFB_SET_WAVEFORMS ioctl brokenDanny Nold
- Fixed bug in how new waveform set is copied into EPDC driver internal copy of waveform modes. Signed-off-by: Danny Nold <dannynold@freescale.com>
2011-08-08ENGR00154432 PMIC DA9053: fix I2C NAK for first access and shutdown issueWayne Zou
During the platform boot up, during the platform does DA9053 Read/Write operation, it writes slave address and wait for ACK . Instead of ACK PMIC sends NAK. A workaround fix is provided as a part of retries fix I2C NAK for very first access. Also fix a bug when the system fails to start after software shutdown. Signed-off-by: Wayne Zou <b36644@freescale.com>
2011-08-08ENGR00154016 DA9053 TSI: stop TSI threads during system idle and no touch eventWayne Zou
Changes Made -------------- 1) On Pen UP the TSI threads are stopped and On Pen DOWN TSI threads are started 2) Removed TSI thread creation from Probe, instead creating the TSI threads when PEN DOWN Expected Output ------------------- 1) TSI threads to stop either when system is suspended or, there is no touch event.Thus conserving power during system suspend, idle and no touch event. 2) TSI threads to start only on touch event and not when system is resumed. 3) On system Start/Restart TSI threads will not be created and started till the touch detection. Signed-off-by: Wayne Zou <b36644@freescale.com>
2011-08-08ENGR00154433 ASRC: Fix ASRC build error.Zeng Zhaoming
Fix asrc build error introduced by: 'be75f376017a04b55cc9f4b3d1c3f2836deb9e47' Signed-off-by: Zeng Zhaoming <b32542@freescale.com>
2011-08-05ENGR00154300-2 ASRC: Fix Mx53 ASRC not works with SSIZeng Zhaoming
Asrc not works with ssi, it partly caused by ASRC driver not correctly handle ssi input clock and data format. SSI frame clock counting by word, when data format is 16bit-LE, two channel data combine to one word, and frame rate used by ASRC should take this into account. And more, unlike Mx3x, Mx5x should set input and output data format correctly in its ASRMCR1x register. Signed-off-by: Zeng Zhaoming <b32542@freescale.com>
2011-08-05ENGR00154300-1 SDMA: Fix Mx53 ASRC not works with SSIZeng Zhaoming
The following case not works in mx53: memory --> asrc --> ssi It is partly caused by asrc --> ssi using per_2_per sdma script to transfer data. And this script not works in sdma driver. In the per_2_per script, two sdma events trigger one channel, the watermark level setting different from ordinary sdma script, we need to set two watermark levels and map each watermark to event one-by-one. Signed-off-by: Zeng Zhaoming <b32542@freescale.com>
2011-08-04ENGR00144281 SDMA: System hangs in bootup when kernel_preempt not enableZeng Zhaoming
When kernel_preempt not enable in configure, system bootup hangs in sdma initialization. This is caused by sdma initialization waiting for channel0 complete loading script in queue, and arch_idle happens with action to disable some clocks, if DDR clock disabled, script loading will failed and SoC hangs. Solve it by make sure DDR clock is enabled during sdma initialization. Signed-off-by: Zeng Zhaoming <b32542@freescale.com>
2011-08-03ENGR00154226-2 IPUv3 FB:Improve driverLiu Ying
1) Current blank information should be unblank if we return back from mxcfb_set_par() function successfully. 2) Remove bypassing the suspend handling for overlay framebuffer for Android. 3) Synchronize fb unblanking operation bewteen Android early suspend and mxcfb_set_par() to avoid fb being unblanked after early suspend is done, as Android early suspend doesn't guarantee fb cannot be operated after early suspend. Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
2011-08-03ENGR00154226-1 IPUv3:Improve driverLiu Ying
1) Fix race condition issue for enable/disable ipu clk. 2) Remove uninitializing MEM_FG_SYNC channel when suspend for Android. Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
2011-07-29ENGR00153941 input: egalax_ts - not dump the i2c package in debug level.Zhang Jiejing
Found the driver will leave i2c package dump message in kernel debug level, it create too much noice, this should be deleted. Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
2011-07-30ENGR00153830-2 vpu: Add VPU_IOC_REQ_VSHARE_MEM ioctl for shared memorySammy He
Add vmalloced memory for multi-instances shared memory, vpu lib will call mmap for accessing the memory. VPU_IOC_GET_SHARE_MEM ioctl is still reserved for some time since vpu lib still uses it for mx5x now. Will remove it after mx5x changes to this new added memory later. Signed-off-by: Sammy He <r62914@freescale.com>
2011-07-30ENGR00153830-1 vpu: Add new VPU_IOC_REQ_VSHARE_MEM ioctl in mxc_vpu.hSammy He
Add new VPU_IOC_REQ_VSHARE_MEM ioctl to request vmalloced share memory. Signed-off-by: Sammy He <r62914@freescale.com>
