System reboot occur during 1080p recording if exit MovieStudio after play a mixed clip with single HDMI,
Vivante's intial feedback is alloc_pages_exact/free_pages_exact APIs are not stable in some kernel,
In other side, need check if some memory size miscalculated is hided by this optimization.
Temporarily this optimization shall be reverted to fix the critical issue.
Signed-off-by: Xianzhong <b07117@freescale.com>
Acked-by: Jason Liu
gpu kernel dump the error message when enable DEBUG mode:
gckCONTEXT_Update(1493): State 0x0518 is not mapped.
gckCONTEXT_Update(1493): State 0x0520 is not mapped.
align gpu kernel driver to fix the error message
Acked-by: Jason Liu
this is a fake recovery to cause system reboot, when run
http://people.mozilla.org/~sicking/webgl/ray.html
the fix is to disable GPU recovery in Chrome browser,
Acked-by: Jason Liu
commit fc4b514f2727f74a4587c31db87e0e93465518c3 upstream.
8852aac25e ("workqueue: mod_delayed_work_on() shouldn't queue timer on
0 delay") unexpectedly uncovered a very nasty abuse of delayed_work in
megaraid - it allocated work_struct, casted it to delayed_work and
then pass that into queue_delayed_work().
Previously, this was okay because 0 @delay short-circuited to
queue_work() before doing anything with delayed_work. 8852aac25e
moved 0 @delay test into __queue_delayed_work() after sanity check on
delayed_work making megaraid trigger BUG_ON().
Although megaraid is already fixed by c1d390d8e6 ("megaraid: fix
BUG_ON() from incorrect use of delayed work"), this patch converts
BUG_ON()s in __queue_delayed_work() to WARN_ON_ONCE()s so that such
abusers, if there are more, trigger warning but don't crash the
machine.
Cc: Xiaotian Feng <xtfeng@gmail.com>
Signed-off-by: Shuah Khan <shuah.khan@hp.com>
(cherry picked from commit 3ff0aeceb49aca3f99c37189e949bf43bfd393a0)
(cherry picked from commit 5721c2db080cd0f9f7370a5eee6704ea71a5c7a4)
Integrate GPU 4.6.9p13 release kernel driver for Android.
Acked-by: Jason Liu
Fix kernel crash issue meet when do 720p Camera recording
on WFD source side, the crash is related with timer schedule,
fixed by add protection code in gckOS_StartTimer function.
Kernel crash log:
[<c004ffec>] (__bug+0x1c/0x28) from [<c00a7e00>] (queue_delayed_work_on+0x10c/0x148)
[<c00a7e00>] (queue_delayed_work_on+0x10c/0x148) from [<c046f4d0>] (gckOS_StartTimer+0x44/0x84)
[<c046f4d0>] (gckOS_StartTimer+0x44/0x84) from [<c047f4ac>] (gckHARDWARE_SetPowerManagementState+0xa24/0xa5c)
[<c047f4ac>] (gckHARDWARE_SetPowerManagementState+0xa24/0xa5c) from [<c046e608>] (gckOS_Broadcast+0xb8/0xe8)
[<c046e608>] (gckOS_Broadcast+0xb8/0xe8) from [<c0475734>] (_TryToIdleGPU+0xd8/0x18c)
[<c0475734>] (_TryToIdleGPU+0xd8/0x18c) from [<c0476cdc>] (gckEVENT_Notify+0x2dc/0x4c8)
[<c0476cdc>] (gckEVENT_Notify+0x2dc/0x4c8) from [<c047d494>] (gckHARDWARE_Interrupt+0x58/0x68)
[<c047d494>] (gckHARDWARE_Interrupt+0x58/0x68) from [<c04693a8>] (threadRoutine+0x20/0x78)
[<c04693a8>] (threadRoutine+0x20/0x78) from [<c00ad0c8>] (kthread+0x80/0x88)
[<c00ad0c8>] (kthread+0x80/0x88) from [<c004d408>] (kernel_thread_exit+0x0/0x8)
Signed-off-by: Richard Liu <r66033@freescale.com>
Acked-by: Jason Liu
cpufreq and pu power management will oprate the same register, it looks should
keep them operating in order not concurrent. Then use the cpufreq mutex in xPU
driver to make sure.
Another code bug is in pu power management which base regulator framework, we
set the reister directly not regulator, then there is the chance set_volatage
will miss the chance if this time voltage setting as the last time setting
before PU disable, but we have to do this, so add regulator_sync_voltage to
force sync the voltage setting. The drawback is setting twice...
Note:
This patch is temporary and supposed to be replaced it once we find the
root cause.
Signed-off-by: Robin Gong <b38343@freescale.com>
Acked-by: Jason Liu
Base on rtl8723as driver(v4.1.8_9180.20130927_BTCOEX20130528_ver3.3_beta)
still do the following changes for imx6:
1.add imx6 in Makefile.
2.fix suspend/resume issue.Just refactor runtime_pm in suspend.
Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
Enable OT limitation for gc880, without this limitation
3D core may stall system bus when it is running at a very low clock.
Signed-off-by: Loren HUANG <b02279@freescale.com>
Acked-by: Shawn Guo
Some of the printks are in the packet handling path.
We now ratelimit the very unlikely errors to avoid
kmsg spamming.
Signed-off-by: JP Abgrall <jpa@google.com>
In the past it would always ignore interfaces with loopback addresses.
Now we just treat them like any other.
This also helps with writing tests that check for the presence
of the qtaguid module.
In the past the iface_stat_fmt would only show global bytes/packets
for the skb-based numbers.
For stall detection in userspace, distinguishing tcp vs other protocols
makes it easier.
Now we report
ifname total_skb_rx_bytes total_skb_rx_packets total_skb_tx_bytes
total_skb_tx_packets {rx,tx}_{tcp,udp,ohter}_{bytes,packets}
Bug: 6818637
qtaguid limits what can be done with /ctrl and /stats based on group
membership.
This changes removes AID_NET_BW_STATS and AID_NET_BW_ACCT, and picks
up the groups from the gid of the matching proc entry files.
Change-Id: I42e477adde78a12ed5eb58fbc0b277cdaadb6f94
If create_if_tag_stat fails to allocate memory (GFP_ATOMIC) the
following will happen:
qtaguid: iface_stat: tag stat alloc failed
kernel BUG at xt_qtaguid.c:1482!
Signed-off-by: Pontus Fuchs <pontus.fuchs@gmail.com>
qtudev_open() could return with a uid_tag_data_tree_lock held
when an kzalloc(..., GFP_ATOMIC) would fail.
Very unlikely to get triggered AND survive the mayhem of running out of mem.
black screen occurs sometimes during 720p recording
when wifi display enable and WFD source is HDMI 720p
or 1080p output. This patch is a workaround to fix
IPU CSC done on IPU0.
console log is below when black screen happen:
imx-ipuv3 imx-ipuv3.1: IPU Warning - IPU_INT_STAT_10 = 0x00080000
imx-ipuv3 imx-ipuv3.1: IPU Warning - IPU_INT_STAT_5 = 0x00800000
Acked-by: Jason Liu
alloc_pages_exact is added by Vivante in gpu git commit
e3debfdf4c3f29519ee66d60ac9b5e4db4c41026.
alloc_pages_exact is more easy make memory fragment,
video playback and camera recording case need large
physical continue memory, using alloc_pages_exact will
easy make memory fragment and no large physical continue
memory, it will impact video playback and camera case.
This patch enable the L2 cache I/D prefetch function on the i.MX6 family.
Based on Android test result, it has the performance improvement:
Before the change:
JB4.3 RC1:
Browser Vellamo scores See The Sun Canvas: 51.16
Browser Vellamo scores Deep Sea Canvas: 65.41
Browser Vellamo scores Aquarium Canvas: 50.23
After the change:
Browser Vellamo scores See The Sun Canvas: 70.28
Browser Vellamo scores Deep Sea Canvas: 78.57
Browser Vellamo scores Aquarium Canvas: 53.73
Signed-off-by: Jason Liu <r64343@freescale.com>
(cherry picked from commit a51f75c318241c26bf7d41ad92c0e255b925863c)
In this new implementation, gpu memory can be queried with seperate types,
root@sabresd_6dq:/ # ./gmem_info
Pid Total Reserved Contiguous Virtual Nonpaged Name
2367 143,845,248 42,575,232 98,124,288 0 3,145,728 /system/bin/surfaceflinger
3870 46,297,952 19,706,720 26,066,944 0 524,288 com.android.email
2794 32,802,656 9,753,952 22,524,416 0 524,288 com.android.inputmethod.latin
2844 21,292,240 20,767,952 0 0 524,288 com.android.launcher
2735 15,037,248 14,512,960 0 0 524,288 com.android.systemui
2658 13,812,480 10,273,536 0 0 3,538,944 system_server
3706 10,759,776 10,235,488 0 0 524,288 com.android.settings
3654 10,742,656 10,218,368 0 0 524,288 com.android.contacts
3725 10,719,552 10,195,264 0 0 524,288 com.android.gallery3d
3793 10,715,456 10,191,168 0 0 524,288 com.android.calendar
3837 10,707,904 10,183,616 0 0 524,288 com.android.mms
3774 10,707,072 10,182,784 0 0 524,288 com.android.calculator2
2370 262,144 0 0 0 262,144 /system/bin/mediaserver
13 337,702,384 178,797,040 146,715,648 0 12,189,696 Summary
- - 5,752,336 - - - Availabe
Acked-by: Jason Liu
2G above address will be converted to gpu virtual address in i.MX6,
gpu baseaddr can be used to reduce contiguous memory address conversion,
the benifit for gpu applications and external memory consumers(VPU/IPU) have,
- gpu mmu performance penalty is reduce in most cases,
- more system memory can be exported for external use
gpu virtual memory cannot be allocated for external use
this issue occurs in ARD board with 2G above memory address
Acked-by: Jason Liu
ION memory is only used in camera for taking picture.
Default size is met for two buffers of 5M pixel YUV420.
Signed-off-by: guoyin.chen <guoyin.chen@freescale.com>
This patch updates IPUv3 IC RGB to YUV color space conversion
matrix's parameters to align with the default VIV GPU CSC
implementation so that we may pass relevant Android CTS test
cases.
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
(cherry picked from commit 17b6dbef8eea2051a6c3819f3690c21948bd0e93)
Android Recovery UI framework uses FBIOPUT_VSCREENINFO with yoffset update
to update display.
Both elcdif and ipuv3 FB will set var.activate to be FB_ACTIVATE_FORCE in
driver's probe. User space will get the VSCREENINFO with activate been set
to FB_ACTIVE_FORCE. Each FBIOPUT_VSCREENINFO with only yoffset update will
make the driver reinit.The activate should be cleared once set_par() been
finished.
HDMI driver should only reinit hdmi only when the mode changed. fbmem will
broadcast MODE_CHANGE for each FBIOPUT_VSCREENINFO ioctl even it only have
yoffset update.
It can fix the bugs that there is no SOF after resume sometimes.
Without SOF after resume the device will go to suspend again,
and host assumes it is disconnected and sends reset later.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
this issue cause system boot with multi-user switch on JB4.3,
root cause is gpu memory cannot be multi-locked in same process,
gpu memory lock reference is added to allow multi-lock in kernel driver.
Acked-by: Jason Liu
add USB_VIDEO to kernel
Signed-off-by: Fang Hui <b31070@freescale.com>
Make onboard key pad can be met the normal android usage:
SW6: Volume +, SW7: Volume -, SW11: POWER, SW10: UP
SW13: DOWN, SW12: BACK, SW9:LEFT, SW8: RIGHT
Change rule of cfg80211 and wireless driver to support rtl8723as.
Use savedefconfig to create imx6sl's compact defconfig.this will
make config real and clean.
Fixed by add check for cam->sensor
We enable WOW mode last commit, it will try to set mmc host's power
capability to keep power on at some points. Delete this act which is
bond with one force scan action. For we didn't add force scan function
in it. We are using runtime_pm feature to trigger scan when doing init.
imx_3.0.35_android
When do stream on/off in pair repeatedly without close the v4l device,
the kernel dump happens:
Unable to handle kernel paging request at virtual address 00200200
pgd = c0004000
[00200200] *pgd=00000000
Internal error: Oops: 805 [#1] PREEMPT
Modules linked in:
CPU: 0 Not tainted (3.0.35-06027-gbbea887-dirty #21)
PC is at camera_callback+0x15c/0x1c8
LR is at 0x200200
pc : [<c03747d0>] lr : [<00200200>] psr: 20000193
sp : c0b0fed0 ip : 00200200 fp : daf1102c
r10: daf11034 r9 : 00100100 r8 : daf11098
r7 : daf11100 r6 : daf11034 r5 : daf11000 r4 : c0b0e000
r3 : 00000000 r2 : 00000001 r1 : 00000001 r0 : daf114b8
Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c53c7d Table: 8cc8c059 DAC: 00000015
Process swapper (pid: 0, stack limit = 0xc0b0e2e8)
Stack: (0xc0b0fed0 to 0xc0b10000)
fec0: c0374674 822a4000 daf11000 c0b87eb4
fee0: 00000000 00000027 c0b73904 c0b305e0 00000001 c0374090 da2bbbe0 c0b0e000
ff00: 00000000 c00acc58 00000000 c0098058 00989680 c0b305e0 c0b0e000 00000000
ff20: 00000002 00000001 c0b0e000 00000000 00000000 c00acdf8 00000000 c0b0e000
ff40: 9e4e7881 c0b305e0 c0b0e000 c00aee44 c00aed9c c0b43c6c 00000027 c00ac634
ff60: 00000270 c004257c ffffffff f2a00100 00000027 c00417cc 20000000 00000006
ff80: f40c4000 00000000 c0b0e000 c0b6a924 c0b1876c c0b18764 80004059 412fc09a
ffa0: 00000000 00000000 c0063a40 c0b0ffc0 c004f758 c0042690 80000013 ffffffff
ffc0: c004266c c004294c c0b1013c 00000000 c10960c0 c00088ec c0008334 00000000
ffe0: 00000000 c00337d4 10c53c7d c0b10060 c00337d0 80008040 00000000 00000000
[<c03747d0>] (camera_callback+0x15c/0x1c8) from [<c0374090>] (csi_irq_handler+
0x7c/0x160)
[<c0374090>] (csi_irq_handler+0x7c/0x160) from [<c00acc58>] (
handle_irq_event_percpu+0x50/0x19c)
[<c00acc58>] (handle_irq_event_percpu+0x50/0x19c) from [<c00acdf8>] (
handle_irq_event+0x54/0x84)
[<c00acdf8>] (handle_irq_event+0x54/0x84) from [<c00aee44>] (handle_fasteoi_irq
+0xa8/0x160)
[<c00aee44>] (handle_fasteoi_irq+0xa8/0x160) from [<c00ac634>] (
generic_handle_irq+0x2c/0x40)
[<c00ac634>] (generic_handle_irq+0x2c/0x40) from [<c004257c>] (handle_IRQ
+0x30/0x84)
[<c004257c>] (handle_IRQ+0x30/0x84) from [<c00417cc>] (__irq_svc+0x4c/0xa8)
[<c00417cc>] (__irq_svc+0x4c/0xa8) from [<c0042690>] (default_idle+0x24/0x28)
[<c0042690>] (default_idle+0x24/0x28) from [<c004294c>] (cpu_idle+0x8c/0xc0)
[<c004294c>] (cpu_idle+0x8c/0xc0) from [<c00088ec>] (start_kernel+0x294/0x2e4)
[<c00088ec>] (start_kernel+0x294/0x2e4) from [<80008040>] (0x80008040)
Code: e88c4200 e595c030 e5858030 e8881800 (e58c8000)
---[ end trace 224150c26d2bd5f7 ]---
The root cause is cam->enc_counter is not re-initialized to 0 when calls
STREAMOFF ioctl, and then in DQBUF ioctl wait_event_interruptible_timeout()
sees the condition is true and access cam->done_q queue which has no strict
check and could be empty.
This patch adds the re-initialization and the sanity check.
Also, add the pointer check for memcpy because the destination may be
NULL on UERSPTR mode.
Signed-off-by: Robby Cai <R63905@freescale.com>
Register boot SD's SDHC first
Make boot SD as no removeable and always present
The L2 cache controller(PL310) version on the i.MX6D/Q is r3p1-50rel0
The L2 cache controller(PL310) version on the i.MX6DL/SOLO/SL is r3p2
But according to ARM PL310 errata: 752271
ID: 752271: Double linefill feature can cause data corruption
Fault Status: Present in: r3p0, r3p1, r3p1-50rel0. Fixed in r3p2
Workaround: The only workaround to this erratum is to disable the
double linefill feature. This is the default behavior.
[in the commit:c483abdca0011c1342bad42f16925dd5a2c7c091]
ENGR00271977-1 imx6_defconfig: enable PL310_ERRATA_769419
There is one error in the commit log, the correct PL310 version in
i.MX6DL/SOLO should be r3p2, not r3p1-50rel0.
so, PL310_ERRATA_769419, will not apply to i.MX6DL/SOLO. But since we build
one image to support both i.MX6Q and i.MX6DL/SOLO, the ideal solution is to
manage this errata in dynamic way. Someone did post the patches here:
http://lists.infradead.org/pipermail/linux-arm-kernel/2013-January/145593.html
As the discussion on the above link, Russell King, the ARM arch maintainer said:
"As I already said, there is _no_ point making the barrier conditional;
it's probably more expensive to make it conditional than just to execute
it every time. But we still might as well optimize it away if we are
running _only_ on platforms which _do_ _not_ have that errata."
So, we will turn on the PL310_ERRATA_769419 on both i.MX6D/Q and i.MX6DL/SOLO.
V4L2_PIX_FMT_YUYV is the original format from camera and the source format
for CSI. This format may be needed on Android to do CSC before encoding.
We can now choose V4L2_PIX_FMT_YUYV or V4L2_PIX_FMT_UYVY for the CSI
output format.
enable ion device for evk_6sl, so takepicture can use it's memory
Fix "Timeout Waiting for Hardware Interrupt on mmc1" issue in
suspend/resume which is caused by not keep power in host.
Enable WOW mode in card side to enable MMC_KEEP_POWER capability
of host will tackle this issue.
The baseAddress of contiguousVidMem is the actual physical address
which is not subtracted by gpu baseAddress, but the allocated physical address
has been subtracted by gpu baseAddress in gckVIDMEM_Lock,
so the invalid offset is produced and used to calculate the logical address.
Acked-by: Shawn Guo
imx_3.0.35_android
Remove CONFIG_IKCONFIG_PROC as android cts requirement
Trinity discovered that we fail to check all 64 bits of
attr.config passed by user space, resulting to out-of-bounds
access of the perf_swevent_enabled array in
sw_perf_event_destroy().
Introduced in commit b0a873ebb ("perf: Register PMU
implementations").
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
Cc: davej@redhat.com
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/1365882554-30259-1-git-send-email-tt.rantala@gmail.com
There's an interim buffer which should only be used when PxP CSC is used.
Otherwise the video buffer gets incorrect data by copying the content of
interim buffer. The patch fixes this by moving the memcpy to the right place.
(cherry picked from commit 8e0b8ff485dd7cdeabc653f1e27c271ac923710e)
One bd actually needs 4KB page size. So changed the iram_alloc()
size parameter to allocate a precise iram memory for bd.
This patch also removed the extra iram pool for SDMA due to its
insufficient total size: SDMA allows around 48 channels to work
simultaneously, so it's better to allocate memory from iram pool
directly.
[There will be 3KB size waste in sdma->channel_control, which is
640B but actually using 4KB due to 4KB alignment for iram pool.]
Acked-by: Huang Shijie <b32955@freescale.com>
Signed-off-by: Nicolin Chen <b42378@freescale.com>
This reverts commit 7b60e285b7b019185389326c2d989f5e42d9736e.
With the commit 881e21c1 and 7b60e285, the system will hang when do suspend
and resume stress test continuouly while run edpc test in the background.
Revert it now and revisit it later.
This reverts commit 881e21c1275dcc40ccd63fb4fa46b990eeb4fb00.
The transceiver TJA1041A on sabreauto RevE baseboard will
fail to transit to Normal state if EN/STBY is high by default
after board power up. So we set the EN/STBY initial state to low
first then to high to guarantee the state transition successfully.
Signed-off-by: Dong Aisheng <b29396@freescale.com>
Acked-by: Jason Liu <r64343@freescale.com>
imx_3.0.35_android
CONFIG_USB_EHCI_TT_NEWSCHED introduces a new schedule method
for periodic transfer, it can cover more peridic transfers which
introduced recently years.
Meanwhile, both PC and our 3.5.7 (and coming 3.10) enable it,
and have not found any issues, this commit also fixes a bug
this CR reported.
