So far, the required PLL's (PLL1/PLL2/PLL5) have been initialized
by boot loader and the kernel code defined fixed rates according
to those default configurations. Beginning with the USB PLL7 the
code started to initialize the PLL's itself (using imx_clk_pllv3).
However, since commit dc4805c2e78ba5a22ea1632f3e3e4ee601a1743b
(ARM: imx: remove ENABLE and BYPASS bits from clk-pllv3 driver)
imx_clk_pllv3 no longer takes care of the ENABLE and BYPASS bits,
hence the USB PLL were not configured correctly anymore.
This patch not only fixes those USB PLL's, but also makes use of
the imx_clk_pllv3 for all PLL's and alignes the code with the PLL
support of the i.MX6 series.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Pull MTD fixes from Brian Norris:
"Three main MTD fixes for 3.18:
- A regression from 3.16 which was noticed in 3.17. With the
restructuring of the m25p80.c driver and the SPI NOR library
framework, we omitted proper listing of the SPI device IDs. This
means m25p80.c wouldn't auto-load (modprobe) properly when built as
a module. For now, we duplicate the device IDs into both modules.
- The OMAP / ELM modules were depending on an implicit link ordering.
Use deferred probing so that the new link order (in 3.18-rc) can
still allow for successful probing.
- Fix suspend/resume support for LH28F640BF NOR flash"
* tag 'for-linus-20141102' of git://git.infradead.org/linux-mtd:
mtd: cfi_cmdset_0001.c: fix resume for LH28F640BF chips
mtd: omap: fix mtd devices not showing up
mtd: m25p80,spi-nor: Fix module aliases for m25p80
mtd: spi-nor: make spi_nor_scan() take a chip type name, not spi_device_id
mtd: m25p80: get rid of spi_get_device_id
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is a set of six patches consisting of:
- two MAINTAINER updates
- two scsi-mq fixs for the old parallel interface (not every request
is tagged and we need to set the right flags to populate the SPI
tag message)
- a fix for a memory leak in scatterlist traversal caused by a
preallocation update in 3.17
- an ipv6 fix for cxgbi"
[ The scatterlist fix also came in separately through the block layer tree ]
* tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
MAINTAINERS: ufs - remove self
MAINTAINERS: change hpsa and cciss maintainer
libcxgbi : support ipv6 address host_param
scsi: set REQ_QUEUE for the blk-mq case
Revert "block: all blk-mq requests are tagged"
lib/scatterlist: fix memory leak with scsi-mq
Pull drm fixes from Dave Airlie:
"Nothing too astounding or major: radeon, i915, vmwgfx, armada and
exynos.
Biggest ones:
- vmwgfx has one big locking regression fix
- i915 has come displayport fixes
- radeon has some stability and a memory alloc failure
- armada and exynos have some vblank fixes"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (24 commits)
drm/exynos: correct connector->dpms field before resuming
drm/exynos: enable vblank after DPMS on
drm/exynos: init kms poll at the end of initialization
drm/exynos: propagate plane initialization errors
drm/exynos: vidi: fix build warning
drm/exynos: remove explicit encoder/connector de-initialization
drm/exynos: init vblank with real number of crtcs
drm/vmwgfx: Filter out modes those cannot be supported by the current VRAM size.
drm/vmwgfx: Fix hash key computation
drm/vmwgfx: fix lock breakage
drm/i915/dp: only use training pattern 3 on platforms that support it
drm/radeon: remove some buggy dead code
drm/i915: Ignore VBT backlight check on Macbook 2, 1
drm/radeon: remove invalid pci id
drm/radeon: dpm fixes for asrock systems
radeon: clean up coding style differences in radeon_get_bios()
drm/radeon: Use drm_malloc_ab instead of kmalloc_array
drm/radeon/dpm: disable ulv support on SI
drm/i915: Fix GMBUSFREQ on vlv/chv
drm/i915: Ignore long hpds on eDP ports
Pull ARM fixes from Russell King:
- add the new bpf syscall to ARM.
- drop a redundant return statement in __iommu_alloc_remap()
- fix a performance issue noticed by Thomas Petazzoni with
kmap_atomic().
- fix an issue with the L2 cache OF parsing code which caused it to
incorrectly print warnings on each boot, and make the warning text
more consistent with the rest of the code
* 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
ARM: 8180/1: mm: implement no-highmem fast path in kmap_atomic_pfn()
ARM: 8183/1: l2c: Improve l2c310_of_parse() error message
ARM: 8181/1: Drop extra return statement
ARM: 8182/1: l2c: Make l2x0_cache_size_of_parse() return 'int'
ARM: enable bpf syscall
Pull kvm fixes from Paolo Bonzini:
"A small set of x86 fixes. The most serious is an SRCU lockdep fix.
A bit late - needed some time to test the SRCU fix, which only came in
on Friday"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: vmx: defer load of APIC access page address during reset
KVM: nVMX: Disable preemption while reading from shadow VMCS
KVM: x86: Fix far-jump to non-canonical check
KVM: emulator: fix execution close to the segment limit
KVM: emulator: fix error code for __linearize
git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into drm-fixes
This pull-request includes some bug fixes and code cleanups.
Especially, this fixes the bind failure issue occurred when it tries
to re-bind Exynos drm driver after unbound, and the modetest failure
issue incurred by not having a pair to vblank on and off requests.
* 'exynos-drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos:
Pull VFS fixes from Al Viro:
"A bunch of assorted fixes, most of them followups to overlayfs merge"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
ovl: initialize ->is_cursor
Return short read or 0 at end of a raw device, not EIO
isofs: don't bother with ->d_op for normal case
isofs_cmp(): we'll never see a dentry for . or ..
overlayfs: fix lockdep misannotation
ovl: fix check for cursor
overlayfs: barriers for opening upper-layer directory
rcu: Provide counterpart to rcu_dereference() for non-RCU situations
staging: android: logger: Fix log corruption regression
The sk_prot is irda's own set of protocol handlers, so irda should
statically know what that function is anyway, without using an indirect
pointer. And as it happens, we know *exactly* what that pointer is
statically: it's NULL, because irda doesn't define a disconnect
operation.
So calling that function is doubly wrong, and will just cause an oops.
Reported-by: Martin Lang <mlg.hessigheim@gmail.com>
Cc: Samuel Ortiz <samuel@sortiz.org>
During system suspend after connector switch off its dpms field
is set to connector previous dpms state. To properly resume dpms field
should be set to its actual state (off) before resuming to previous dpms state.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
Before DPMS off driver disables vblank.
It should be balanced by vblank enable after DPMS on.
The patch fixes issue with page_flip ioctl not being able
to acquire vblank counter introduced by patch:
drm: Always reject drm_vblank_get() after drm_vblank_off()
HPD events can be generated by components even if drm_dev is not fully
initialized, to skip such events kms poll initialization should
be performed at the end of load callback followed directly by forced
connection detection.
In case of error during plane initialization load callback
incorrectly return success, this patch fixes it.
encoder object isn't used anymore so remove it.
All KMS objects are destroyed by drm_mode_config_cleanup in proper order
so component drivers should not care about it.
Initialization of vblank with MAX_CRTC caused attempts
to disabling vblanks for non-existing crtcs in case
drm used fewer crtcs. The patch fixes it.
Most call paths to vmx_vcpu_reset do not hold the SRCU lock. Defer loading
the APIC access page to the next vmentry.
This avoids the following lockdep splat:
[ INFO: suspicious RCU usage. ]
3.18.0-rc2-test2+ #70 Not tainted
include/linux/kvm_host.h:474 suspicious rcu_dereference_check() usage!
rcu_scheduler_active = 1, debug_locks = 0
1 lock held by qemu-system-x86/2371:
#0: (&vcpu->mutex){+.+...}, at: [<ffffffffa037d800>] vcpu_load+0x20/0xd0 [kvm]
stack backtrace:
CPU: 4 PID: 2371 Comm: qemu-system-x86 Not tainted 3.18.0-rc2-test2+ #70
Hardware name: Dell Inc. OptiPlex 9010/0M9KCM, BIOS A12 01/10/2013
0000000000000001 ffff880209983ca8 ffffffff816f514f 0000000000000000
ffff8802099b8990 ffff880209983cd8 ffffffff810bd687 00000000000fee00
ffff880208a2c000 ffff880208a10000 ffff88020ef50040 ffff880209983d08
Call Trace:
[<ffffffff816f514f>] dump_stack+0x4e/0x71
[<ffffffff810bd687>] lockdep_rcu_suspicious+0xe7/0x120
[<ffffffffa037d055>] gfn_to_memslot+0xd5/0xe0 [kvm]
[<ffffffffa03807d3>] __gfn_to_pfn+0x33/0x60 [kvm]
[<ffffffffa0380885>] gfn_to_page+0x25/0x90 [kvm]
[<ffffffffa038aeec>] kvm_vcpu_reload_apic_access_page+0x3c/0x80 [kvm]
[<ffffffffa08f0a9c>] vmx_vcpu_reset+0x20c/0x460 [kvm_intel]
[<ffffffffa039ab8e>] kvm_vcpu_reset+0x15e/0x1b0 [kvm]
[<ffffffffa039ac0c>] kvm_arch_vcpu_setup+0x2c/0x50 [kvm]
[<ffffffffa037f7e0>] kvm_vm_ioctl+0x1d0/0x780 [kvm]
[<ffffffff810bc664>] ? __lock_is_held+0x54/0x80
[<ffffffff812231f0>] do_vfs_ioctl+0x300/0x520
[<ffffffff8122ee45>] ? __fget+0x5/0x250
[<ffffffff8122f0fa>] ? __fget_light+0x2a/0xe0
[<ffffffff81223491>] SyS_ioctl+0x81/0xa0
[<ffffffff816fed6d>] system_call_fastpath+0x16/0x1b
Reported-by: Takashi Iwai <tiwai@suse.de>
Reported-by: Alexei Starovoitov <alexei.starovoitov@gmail.com>
Reviewed-by: Wanpeng Li <wanpeng.li@linux.intel.com>
Tested-by: Wanpeng Li <wanpeng.li@linux.intel.com>
Fixes: 38b9917350cb2946e368ba684cfc33d1672f104e
In order to access the shadow VMCS, we need to load it. At this point,
vmx->loaded_vmcs->vmcs and the actually loaded one start to differ. If
we now get preempted by Linux, vmx_vcpu_put and, on return, the
vmx_vcpu_load will work against the wrong vmcs. That can cause
copy_shadow_to_vmcs12 to corrupt the vmcs12 state.
Fix the issue by disabling preemption during the copy operation.
copy_vmcs12_to_shadow is safe from this issue as it is executed by
vmx_vcpu_run when preemption is already disabled before vmentry.
This bug is exposed by running Jailhouse within KVM on CPUs with
shadow VMCS support. Jailhouse never expects an interrupt pending
vmexit, but the bug can cause it if, after copy_shadow_to_vmcs12
is preempted, the active VMCS happens to have the virtual interrupt
pending flag set in the CPU-based execution controls.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Commit d1442d85cc30 ("KVM: x86: Handle errors when RIP is set during far
jumps") introduced a bug that caused the fix to be incomplete. Due to
incorrect evaluation, far jump to segment with L bit cleared (i.e., 32-bit
segment) and RIP with any of the high bits set (i.e, RIP[63:32] != 0) set may
not trigger #GP. As we know, this imposes a security problem.
In addition, the condition for two warnings was incorrect.
Fixes: d1442d85cc30ea75f7d399474ca738e0bc96f715
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
[Add #ifdef CONFIG_X86_64 to avoid complaints of undefined behavior. - Paolo]
A critical 3.18 regression fix from Rob, (thanks!)
A fix to avoid advertizing modes we can't support from Sinclair
(welcome Sinclair!)
and a fix for an incorrect hash key computation from me that is
completely harmless, but can wait 'til the next merge window if necessary.
(I can't really bother stable with this one).
* 'vmwgfx-fixes-3.18' of git://people.freedesktop.org/~thomash/linux:
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging fixes from Greg KH:
"Here are some staging driver fixes for 3.18-rc3. Mostly iio and
comedi driver fixes for issues reported by people.
All of these have been in linux-next for a while with no reported
issues"
* tag 'staging-3.18-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: comedi: fix memory leak / bad pointer freeing for chanlist
staging: comedi: Kconfig: fix config COMEDI_ADDI_APCI_3120 dependants
staging: comedi: widen subdevice number argument in ioctl handlers
staging: rtl8723au: Fix alignment of mac_addr for ether_addr_copy() usage
drivers/staging/comedi/Kconfig: Let COMEDI_II_PCI20KC depend on HAS_IOMEM
staging: comedi: (regression) channel list must be set for COMEDI_CMD ioctl
iio: adc: mxs-lradc: Disable the clock on probe failure
iio: st_sensors: Fix buffer copy
staging:iio:ad5933: Drop "raw" from channel names
staging:iio:ad5933: Fix NULL pointer deref when enabling buffer
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are a bunch of USB fixes for 3.18-rc3.
Mostly usb-serial device ids and gadget fixes for issues that have
been reported. Full details are in the shortlog.
All of these have been in linux-next for a while"
* tag 'usb-3.18-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (42 commits)
usb: chipidea: Fix oops when removing the ci_hdrc module
usb: gadget: function: Fixed the return value on error path
usb: dwc2: gadget: disable phy before turning off power regulators
usb: gadget: function: Remove redundant usb_free_all_descriptors
usb: dwc3: gadget: Properly initialize LINK TRB
usb: dwc2: gadget: fix gadget unregistration in udc_stop() function
usb: dwc2: Bits in bitfield should add up to 32
usb: dwc2: gadget: sparse warning of context imbalance
usb: gadget: udc: core: fix kernel oops with soft-connect
usb: musb: musb_dsps: fix NULL pointer in suspend
usb: musb: dsps: start OTG timer on resume again
usb: gadget: loopback: don't queue requests to bogus endpoints
usb: ffs: fix regression when quirk_ep_out_aligned_size flag is set
usb: gadget: f_fs: remove redundant ffs_data_get()
usb: gadget: udc: USB_GADGET_XILINX should depend on HAS_DMA
Revert "usb: dwc3: dwc3-omap: Disable/Enable only wrapper interrupts in prepare/complete"
usb: gadget: composite: enable BESL support
usb: musb: cppi41: restart hrtimer only if not yet done
usb: dwc3: ep0: fix Data Phase for transfer sizes aligned to wMaxPacketSize
usb: serial: ftdi_sio: add "bricked" FTDI device PID
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"Filipe is nailing down some problems with our skinny extent variation,
and Dave's patch fixes endian problems in the new super block checks"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: fix race that makes btrfs_lookup_extent_info miss skinny extent items
Btrfs: properly clean up btrfs_end_io_wq_cache
Btrfs: fix invalid leaf slot access in btrfs_lookup_extent()
btrfs: use macro accessors in superblock validation checks
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"A bunch of fixes for minor defects reported by Coverity, a few driver
fixups and revert of i8042.nomux change so that we are once again
enable active MUX mode if box claims to support it"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Revert "Input: i8042 - disable active multiplexing by default"
Input: altera_ps2 - use correct type for irq return value
Input: altera_ps2 - write to correct register when disabling interrupts
Input: max77693-haptic - fix potential overflow
Input: psmouse - remove unneeded check in psmouse_reconnect()
Input: vsxxxaa - fix code dropping bytes from queue
Input: ims-pcu - fix dead code in ims_pcu_ofn_reg_addr_store()
Input: opencores-kbd - fix error handling
Input: wm97xx - adapt parameters to tosa touchscreen.
Input: i8042 - quirks for Fujitsu Lifebook A544 and Lifebook AH544
Input: stmpe-keypad - fix valid key line bitmask
Input: soc_button_array - update calls to gpiod_get*()
Pull ACPI and power management fixes from Rafael Wysocki:
"These are fixes received after my previous pull request plus one that
has been in the works for quite a while, but its previous version
caused problems to happen, so it's been deferred till now.
Fixed are two recent regressions (MFD enumeration and cpufreq-dt),
ACPI EC regression introduced in 3.17, system suspend error code path
regression introduced in 3.15, an older bug related to recovery from
failing resume from hibernation and a cpufreq-dt driver issue related
to operation performance points.
Specifics:
- Fix a crash on r8a7791/koelsch during resume from system suspend
caused by a recent cpufreq-dt commit (Geert Uytterhoeven).
- Fix an MFD enumeration problem introduced by a recent commit adding
ACPI support to the MFD subsystem that exposed a weakness in the
ACPI core causing ACPI enumeration to be applied to all devices
associated with one ACPI companion object, although it should be
used for one of them only (Mika Westerberg).
- Fix an ACPI EC regression introduced during the 3.17 cycle causing
some Samsung laptops to misbehave as a result of a workaround
targeted at some Acer machines. That includes a revert of a commit
that went too far and a quirk for the Acer machines in question.
From Lv Zheng.
- Fix a regression in the system suspend error code path introduced
during the 3.15 cycle that causes it to fail to take errors from
asychronous execution of "late" suspend callbacks into account
(Imre Deak).
- Fix a long-standing bug in the hibernation resume error code path
that fails to roll back everything correcty on "freeze" callback
errors and leaves some devices in a "suspended" state causing more
breakage to happen subsequently (Imre Deak).
- Make the cpufreq-dt driver disable operation performance points
that are not supported by the VR connected to the CPU voltage plane
with acceptable tolerance instead of constantly failing voltage
scaling later on (Lucas Stach)"
* tag 'pm+acpi-3.18-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / EC: Fix regression due to conflicting firmware behavior between Samsung and Acer.
Revert "ACPI / EC: Add support to disallow QR_EC to be issued before completing previous QR_EC"
cpufreq: cpufreq-dt: Restore default cpumask_setall(policy->cpus)
PM / Sleep: fix recovery during resuming from hibernation
PM / Sleep: fix async suspend_late/freeze_late error handling
ACPI: Use ACPI companion to match only the first physical device
cpufreq: cpufreq-dt: disable unsupported OPPs
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
"These changes, intended for v3.18, fix:
Sysfs
- Fix "enable" filename change (Greg Kroah-Hartman)
An unintentional sysfs filename change in commit 5136b2da770d
("PCI: convert bus code to use dev_groups"), which appeared in
v3.13, changed "enable" to "enabled", and this changes it back.
Old users of "enable" are currently broken and will be helped by
this change. Anything that started to use "enabled" after v3.13
will be broken by this change. If necessary, we can add a symlink
to make both work, but this patch doesn't do that.
PCI device hotplug
- Revert duplicate merge (Kamal Mostafa)
A mistaken duplicate merge that added a check twice. Nothing's
broken; this just removes the unnecessary code.
Freescale i.MX6
- Wait for clocks to stabilize after ref_en (Richard Zhu)
An i.MX6 clock problem that prevents mx6 nitrogen boards from booting"
* tag 'pci-v3.18-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: Rename sysfs 'enabled' file back to 'enable'
PCI: imx6: Wait for clocks to stabilize after ref_en
Revert duplicate "PCI: pciehp: Prevent NULL dereference during probe"
Rusty noticed a Really Bad Bug (tm) in my NT fix. The entry code
reads out of bounds, causing the NT fix to be unreliable. But, and
this is much, much worse, if your stack is somehow just below the
top of the direct map (or a hole), you read out of bounds and crash.
Excerpt from the crash:
[ 1.129513] RSP: 0018:ffff88001da4bf88 EFLAGS: 00010296
2b:* f7 84 24 90 00 00 00 testl $0x4000,0x90(%rsp)
That read is deterministically above the top of the stack. I
thought I even single-stepped through this code when I wrote it to
check the offset, but I clearly screwed it up.
Fixes: 8c7aa698baca ("x86_64, entry: Filter RFLAGS.NT on entry from userspace")
Reported-by: Rusty Russell <rusty@ozlabs.org>
Cc: stable@vger.kernel.org
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 bugfixes from Ted Ts'o:
"A set of miscellaneous ext4 bug fixes for 3.18"
* tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: make ext4_ext_convert_to_initialized() return proper number of blocks
ext4: bail early when clearing inode journal flag fails
ext4: bail out from make_indexed_dir() on first error
jbd2: use a better hash function for the revoke table
ext4: prevent bugon on race between write/fcntl
ext4: remove extent status procfs files if journal load fails
ext4: disallow changing journal_csum option during remount
ext4: enable journal checksum when metadata checksum feature enabled
ext4: fix oops when loading block bitmap failed
ext4: fix overflow when updating superblock backups after resize
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull quota and ext3 fixes from Jan Kara.
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs:
fs, jbd: use a more generic hash function
quota: Properly return errors from dquot_writeback_dquots()
ext3: Don't check quota format when there are no quota files
Pull networking fixes from David Miller:
"A bit has accumulated, but it's been a week or so since my last batch
of post-merge-window fixes, so...
1) Missing module license in netfilter reject module, from Pablo.
Lots of people ran into this.
2) Off by one in mac80211 baserate calculation, from Karl Beldan.
3) Fix incorrect return value from ax88179_178a driver's set_mac_addr
op, which broke use of it with bonding. From Ian Morgan.
4) Checking of skb_gso_segment()'s return value was not all
encompassing, it can return an SKB pointer, a pointer error, or
NULL. Fix from Florian Westphal.
This is crummy, and longer term will be fixed to just return error
pointers or a real SKB.
6) Encapsulation offloads not being handled by
skb_gso_transport_seglen(). From Florian Westphal.
7) Fix deadlock in TIPC stack, from Ying Xue.
8) Fix performance regression from using rhashtable for netlink
sockets. The problem was the synchronize_net() invoked for every
socket destroy. From Thomas Graf.
9) Fix bug in eBPF verifier, and remove the strong dependency of BPF
on NET. From Alexei Starovoitov.
10) In qdisc_create(), use the correct interface to allocate
->cpu_bstats, otherwise the u64_stats_sync member isn't
initialized properly. From Sabrina Dubroca.
11) Off by one in ip_set_nfnl_get_byindex(), from Dan Carpenter.
12) nf_tables_newchain() was erroneously expecting error pointers from
netdev_alloc_pcpu_stats(). It only returna a valid pointer or
NULL. From Sabrina Dubroca.
13) Fix use-after-free in _decode_session6(), from Li RongQing.
14) When we set the TX flow hash on a socket, we mistakenly do so
before we've nailed down the final source port. Move the setting
deeper to fix this. From Sathya Perla.
15) NAPI budget accounting in amd-xgbe driver was counting descriptors
instead of full packets, fix from Thomas Lendacky.
16) Fix total_data_buflen calculation in hyperv driver, from Haiyang
Zhang.
17) Fix bcma driver build with OF_ADDRESS disabled, from Hauke
Mehrtens.
18) Fix mis-use of per-cpu memory in TCP md5 code. The problem is
that something that ends up being vmalloc memory can't be passed
to the crypto hash routines via scatter-gather lists. From Eric
Dumazet.
19) Fix regression in promiscuous mode enabling in cdc-ether, from
Olivier Blin.
20) Bucket eviction and frag entry killing can race with eachother,
causing an unlink of the object from the wrong list. Fix from
Nikolay Aleksandrov.
21) Missing initialization of spinlock in cxgb4 driver, from Anish
Bhatt.
22) Do not cache ipv4 routing failures, otherwise if the sysctl for
forwarding is subsequently enabled this won't be seen. From
Nicolas Cavallari"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (131 commits)
drivers: net: cpsw: Support ALLMULTI and fix IFF_PROMISC in switch mode
drivers: net: cpsw: Fix broken loop condition in switch mode
net: ethtool: Return -EOPNOTSUPP if user space tries to read EEPROM with lengh 0
stmmac: pci: set default of the filter bins
net: smc91x: Fix gpios for device tree based booting
mpls: Allow mpls_gso to be built as module
mpls: Fix mpls_gso handler.
r8152: stop submitting intr for -EPROTO
netfilter: nft_reject_bridge: restrict reject to prerouting and input
netfilter: nft_reject_bridge: don't use IP stack to reject traffic
netfilter: nf_reject_ipv6: split nf_send_reset6() in smaller functions
netfilter: nf_reject_ipv4: split nf_send_reset() in smaller functions
netfilter: nf_tables_bridge: update hook_mask to allow {pre,post}routing
drivers/net: macvtap and tun depend on INET
drivers/net, ipv6: Select IPv6 fragment idents for virtio UFO packets
drivers/net: Disable UFO through virtio
net: skb_fclone_busy() needs to detect orphaned skb
gre: Use inner mac length when computing tunnel length
mlx4: Avoid leaking steering rules on flow creation error flow
net/mlx4_en: Don't attempt to TX offload the outer UDP checksum for VXLAN
Pull sparc update from David Miller:
"Two changes:
1) It makes no sense to execute a VTOC partition table request in the
Sun virtual block device driver and fail to load if it doesn't
succeed because a) we don't use the result at all and b) it won't
succeed if there is an EFI partition on the disk, for example.
We read the partition table via the normal means in the block layer
anyways, so this is really completely useless, so just remove it.
From Dwight Engen.
2) Hook up new bpf system call"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sunvdc: don't call VD_OP_GET_VTOC
sparc: Hook up bpf system call.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Pull Microblaze updates from Michal Simek:
- wire-up new bpf syscall
- fix PCI bug
- fix Kconfig warning
* tag 'microblaze-3.18-rc3' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: Wire up bpf syscall
microblaze: Fix IO space breakage after of_pci_range_to_resource() change
microblaze: Fix missing NR_CPUS in menuconfig
Pull x86 fixes from Ingo Molnar:
"Fixes from all around the place:
- hyper-V 32-bit PAE guest kernel fix
- two IRQ allocation fixes on certain x86 boards
- intel-mid boot crash fix
- intel-quark quirk
- /proc/interrupts duplicate irq chip name fix
- cma boot crash fix
- syscall audit fix
- boot crash fix with certain TSC configurations (seen on Qemu)
- smpboot.c build warning fix"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, pageattr: Prevent overflow in slow_virt_to_phys() for X86_PAE
ACPI, irq, x86: Return IRQ instead of GSI in mp_register_gsi()
x86, intel-mid: Create IRQs for APB timers and RTC timers
x86: Don't enable F00F workaround on Intel Quark processors
x86/irq: Fix XT-PIC-XT-PIC in /proc/interrupts
x86, cma: Reserve DMA contiguous area after initmem_init()
i386/audit: stop scribbling on the stack frame
x86, apic: Handle a bad TSC more gracefully
x86: ACPI: Do not translate GSI number if IOAPIC is disabled
x86/smpboot: Move data structure to its primary usage scope
* pm-cpufreq:
* pm-sleep:
* acpi-scan:
* acpi-ec:
Pull scheduler fixes from Ingo Molnar:
"Various scheduler fixes all over the place: three SCHED_DL fixes,
three sched/numa fixes, two generic race fixes and a comment fix"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/dl: Fix preemption checks
sched: Update comments for CLONE_NEWNS
sched: stop the unbound recursion in preempt_schedule_context()
sched/fair: Fix division by zero sysctl_numa_balancing_scan_size
sched/fair: Care divide error in update_task_scan_period()
sched/numa: Fix unsafe get_task_struct() in task_numa_assign()
sched/deadline: Fix races between rt_mutex_setprio() and dl_task_timer()
sched/deadline: Don't replenish from a !SCHED_DEADLINE entity
sched: Fix race between task_group and sched_task_group
Pull perf fixes from Ingo Molnar:
"Mostly tooling fixes, plus on the kernel side:
- a revert for a newly introduced PMU driver which isn't complete yet
and where we ran out of time with fixes (to be tried again in
v3.19) - this makes up for a large chunk of the diffstat.
- compilation warning fixes
- a printk message fix
- event_idx usage fixes/cleanups"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf probe: Trivial typo fix for --demangle
perf tools: Fix report -F dso_from for data without branch info
perf tools: Fix report -F dso_to for data without branch info
perf tools: Fix report -F symbol_from for data without branch info
perf tools: Fix report -F symbol_to for data without branch info
perf tools: Fix report -F mispredict for data without branch info
perf tools: Fix report -F in_tx for data without branch info
perf tools: Fix report -F abort for data without branch info
perf tools: Make CPUINFO_PROC an array to support different kernel versions
perf callchain: Use global caching provided by libunwind
perf/x86/intel: Revert incomplete and undocumented Broadwell client support
perf/x86: Fix compile warnings for intel_uncore
perf: Fix typos in sample code in the perf_event.h header
perf: Fix and clean up initialization of pmu::event_idx
perf: Fix bogus kernel printk
perf diff: Add missing hists__init() call at tool start
Pull futex fixes from Ingo Molnar:
"This contains two futex fixes: one fixes a race condition, the other
clarifies shared/private futex comments"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
futex: Fix a race condition between REQUEUE_PI and task death
futex: Mention key referencing differences between shared and private futexes
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John W. Linville says:
pull request: wireless 2014-10-31
Please pull this small batch of spooky fixes intended for the 3.18
stream...boo!
Cyril Brulebois adds an rt2x00 device ID.
Dan Carpenter provides a one-line masking fix for an ath9k debugfs
entry.
Larry Finger gives us a package of small rtlwifi fixes which add some
bits that were left out of some feature updates that were included
in the merge window. Hopefully this isn't a sign that the rtlwifi
base is getting too big...
Marc Yang brings a fix for a temporary mwifiex stall when doing 11n
RX reordering.
Please let me know if there are problems!
The cpsw driver did not support the IFF_ALLMULTI flag which makes dynamic
multicast routing not work. Related to this, when enabling IFF_PROMISC
in switch mode, all registered multicast addresses are flushed, resulting
in only broadcast and unicast traffic being received.
A new cpsw_ale_set_allmulti function now scans through the ALE entry
table and adds/removes the host port from the unregistered multicast
port mask of each vlan entry depending on the state of IFF_ALLMULTI.
In promiscious mode, cpsw_ale_set_allmulti is used to force reception
of all multicast traffic in addition to the unicast and broadcast traffic.
With this change dynamic multicast and promiscious mode both work in
switch mode.
Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca>
0d961b3b52f566f823070ce2366511a7f64b928c (drivers: net: cpsw: fix buggy
loop condition) accidentally fixed a loop comparison in too many places
while fixing a real bug.
It was correct to fix the dual_emac mode section since there 'i' is used
as an index into priv->slaves which is a 0 based array.
However the other two changes (which are only used in switch mode)
are wrong since there 'i' is actually the ALE port number, and port 0
is the host port, while port 1 and up are the slave ports.
Putting the loop condition back in the switch mode section fixes it.
A comment has been added to point out the intent clearly to avoid future
confusion. Also a comment is fixed that said the opposite of what was
actually happening.
Acked-by: Heiko Schocher <hs@denx.de>
If a driver supports reading EEPROM but no EEPROM is installed in the system,
the driver's get_eeprom_len function returns 0. ethtool will subsequently
try to read that zero-length EEPROM anyway. If the driver does not support
EEPROM access at all, this operation will return -EOPNOTSUPP. If the driver
does support EEPROM access but no EEPROM is installed, the operation will
return -EINVAL. Return -EOPNOTSUPP in both cases for consistency.
Tested-by: Andrew Lunn <andrew@lunn.ch>
The commit 3b57de958e2a brought the support for a different amount of the
filter bins, but didn't update the PCI driver accordingly. This patch appends
the default values when the device is enumerated via PCI bus.
Fixes: 3b57de958e2a (net: stmmac: Support devicetree configs for mcast and ucast filter entries)
With legacy booting, the platform init code was taking care of
the configuring of GPIOs. With device tree based booting, things
may or may not work depending what bootloader has configured or
if the legacy platform code gets called.
Let's add support for the pwrdn and reset GPIOs to the smc91x
driver to fix the issues of smc91x not working properly when
booted in device tree mode.
And let's change n900 to use these settings as some versions
of the bootloader do not configure things properly causing
errors.
Reported-by: Kevin Hilman <khilman@linaro.org>
The VD_OP_GET_VTOC operation will succeed only if the vdisk backend has a
VTOC label, otherwise it will fail. In particular, it will return error
48 (ENOTSUP) if the disk has an EFI label. VTOC disk labels are already
handled by directly reading the disk in block/partitions/sun.c (enabled by
CONFIG_SUN_PARTITION which defaults to y on SPARC). Since port->label is
unused in the driver, remove the call and the field.
Signed-off-by: Dwight Engen <dwight.engen@oracle.com>
Kconfig already allows mpls to be built as module. Following patch
fixes Makefile to do same.
CC: Simon Horman <simon.horman@netronome.com>
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
Acked-by: Simon Horman <simon.horman@netronome.com>
mpls gso handler needs to pull skb after segmenting skb.
Pull core fixes from Ingo Molnar:
"The tree contains two RCU fixes and a compiler quirk comment fix"
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
rcu: Make rcu_barrier() understand about missing rcuo kthreads
compiler/gcc4+: Remove inaccurate comment about 'asm goto' miscompiles
rcu: More on deadlock between CPU hotplug and expedited grace periods
