2012-09-17iio: ad7476: Add support for the ad7091riio-for-v3.7dLars-Peter Clausen
Add support for the ad7091r 12 bit ADC to the ad7476 driver. Although the ad7091r is not really related to any of the other devices supported by this driver, luckily for us there are not so many ways (which are not totally insane) how sampling a single channel ADC via SPI can be implemented and support for the ad7091r can be added to the driver with just a few adjustments. The ad7091r requires an external "conversion start" pulse to start a sample conversion. After the conversion has finished the result can be read via SPI. We depend on a IIO trigger to generate this signal, as a result only sampling in buffered mode and not in manual mode is available. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-17staging:iio:trigger:bfintmr Add output supportLars-Peter Clausen
Some converters require an external signal to start the conversion. This patch adds support to the bfintmr trigger driver to generate such a signal. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-17staging:iio:trigger:bfintmr: Only enable timer when necessaryLars-Peter Clausen
This patch hooks up the set_trigger_state callback for the blackfin timer trigger driver and only enables the timer when a trigger consumer requests it to be enabled. There really is no reason to keep the timer running and generate interrupts if nobody is listening to them. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-17staging:iio:trigger:bfintmr: Avoid divide by zeroLars-Peter Clausen
If the timer frequency has not been configured yet get_gptimer_period() will return 0. Handle this case instead of blindly dividing by the returned value. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-17staging:iio:hwmon bridge: Use iio_read_channel_processedLars-Peter Clausen
Use the iio_read_channel_processed function to read the sample value in the proper unit instead of using iio_read_channel_raw and iio_read_channel_scale and doing the unit conversion manually. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-17iio:inkern: Add function to read the processed valueLars-Peter Clausen
Add a function to read a processed value from a channel. The function will first attempt to read the IIO_CHAN_INFO_PROCESSED attribute. If that fails it will read the IIO_CHAN_INFO_RAW attribute and convert the result from a raw value to a processed value. The patch also introduces a function to convert raw value to a processed value and exports it, in case a user needs or wants to do the conversion by itself. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-17iio: consumer.h: Fix kernel doc incosistencyLars-Peter Clausen
For the iio_read_channel_raw and iio_read_channel_scale the kerneldoc comment refers to an argument called "channel", while the argument is called "chan" in the function signature. This leads to the following warnings from kerneldoc: Warning(include/linux/iio/consumer.h:71): No description found for parameter 'chan' Warning(include/linux/iio/consumer.h:71): Excess function parameter 'channel' description in 'iio_read_channel_raw' Warning(include/linux/iio/consumer.h:109): No description found for parameter 'chan' Warning(include/linux/iio/consumer.h:109): Excess function parameter 'channel' description in 'iio_read_channel_scale' This patch fixes the warnings by naming them consistently. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-17iio:dac: Add ad5755 driverLars-Peter Clausen
This patch adds support for the AD5755, AD5755-1, AD5757, AD5735, AD5737 16 and 14 bit quad-channel DACs. The AD5757/AD5737 only have current outputs, but for the AD5755/AD5757 each of the outputs can be configured to either be a voltage or a current output. We only allow to configure this at device probe time since usually this needs to match the external circuitry and should not be changed on the fly. A few trivial formatting changes on merge. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-17iio: inkern: add error case in iio_channel_get()Kim, Milo
The datasheet name is defined in the IIO driver. On the other hand, the adc_channel_label is configured in the platform side. If the datasheet name is not matched with any adc_channel_label, the iio_channel_get() should be returned as error for preventing invalid channel data access. This can be handled either way. (a) checking null data when using it : in the xxx_read_raw() or (b) error returns when the channel is requested : this patch The IIO consumer can't use the channel with invalid channel spec. Therefore case (b) is more reasonable. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-15iio: inkern: allocate zeroed memoryKim, Milo
Use kzalloc() rather than kmalloc() for initializing the iio_channel structure. This patch enables the iio_dev and iio_chan_spec are set to NULL. This may prevent the page fault problem because the pointer of iio_chan_spec is initialized as NULL. The iio_chan_spec is updated only in case that the IIO map has specific channel label. When the map has no ADC channel label, then the value of iio_chan_spec remains as invalid pointer. To prevent this problem, the pointer should be initialized as NULL. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-15iio: Introduce a new fractional value typeLars-Peter Clausen
Currently IIO uses a decimal fixed point representations for real type numbers. This patch introduces a new representation for rational type numbers. The number will be expressed by specifying a numerator and denominator. For converting a raw value to a processed value multiply it by the numerator and divide it by the denominator. The reasoning for introducing this new type is that for a lot of devices the scale can be represented easily by a fractional number, but it is not possible to represent it as fixed point number without rounding. E.g. for a simple DAC the scale is often the reference voltage divided by the number of possible values (Usually 2**n_bits - 1). Each driver currently implements the conversion of this fraction to a fixed point number on its own. Also when it comes to the in-kernel interface this allows to directly use the fractional factors to convert a raw value to a processed value. This should on one hand require less instructions and on the other hand increase the precision. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-15iio: Documentation change for inkern interface.anish kumar
This commit- 314be14bb renamed the _st_ functions to loose the bit that was meant for staging version but forgot to change the documentation which still have _st_ sprinkled in some of the places. Signed-off-by: anish kumar <anish198519851985@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-15iio:ad7476: Add support for ad7273/ad7274/ad7276/ad7277/ad7278Lars-Peter Clausen
The ad7276/ad7277/ad7278 are similar to the ad7476/ad7477/ad7478 but have the same number of leading zeros as the ad7940. The ad7273/ad7274 have a extra pin for VREF where as for the ad7276/ad7277/ad7278 VREF is taken from VDD, but otherwise they are compatible to the ad7276/ad7277. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-15iio:ad7476: Add ad7940 supportLars-Peter Clausen
The AD7940 is a single channel 14 bit ADC similar to the ADCs already supported by the ad7476 driver, but it does have a different shift factor. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-15iio:ad7476: Add ad7910/ad7920 device table entriesLars-Peter Clausen
The ad7910/ad7920 are software compatible to the ad7467/ad7466. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-15iio: Move ad7476 driver out of stagingLars-Peter Clausen
The ad7476 driver is a driver for simple single channel ADCs. The driver does not export any experimental or custom ABI files nor do the static code check tools report any issues, so move the driver out of staging. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-15staging:iio:ad7476: Use be16_to_cpup instead of open-coding itLars-Peter Clausen
2012-09-15staging:iio:ad7476: Squash driver into a single file.Lars-Peter Clausen
After the recent cleanups the buffer support is just a single 23 line function. This does not really justify a file on its own, so move it to the main driver file. And with only one source file left the header file containing the device state struct becomes superflousious so move the content of the header file to the main driver source file as well. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-15staging:iio:ad7476: Rework reference voltage handlingLars-Peter Clausen
Slightly rework the reference voltage handling for the ad7476 driver. Now the only way to specify a external reference voltage is to use the regulator API, previously it was possible to use either platform_data or the regulator API. The new way is more consistent with what other drivers do. Also do not ignore errors when requesting the regulator, since this will cope very poorly with e.g. deferred probing. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-13staging:iio:ad7476: Avoid alloc/free for each sample in buffered modeLars-Peter Clausen
The ad7476 driver has only support for 1 channel ADCs. So the upper limit for the buffer size is the size of one sample plus the size of the timestamp. Preallocate a buffer large enough to hold this to avoid having to allocate and free a new buffer for each sample being captured. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-13staging:iio:ad7476: Remove duplicated chip info entriesLars-Peter Clausen
Some of the parts supported by this driver are software compatible. The difference between them is only in the operating voltage range. So we do not need extra chip info entries for them. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-12staging:iio:ad7476: Fix off by one error for channel shiftLars-Peter Clausen
The datasheet is a bit confusing about this. It says that a dataword has 4 leading zeros, but the first zero is already put on the bus when CS is pulled low and the second zero is put on the bus on the first leading edge of SCLK, so when the first bit is sampled on the first trailing edge it will sample what the datasheet refers to as the second leading zero. Subsequently we only see 3 leading zeros in the 16 bit dataword and the result we get is shifted to the left by one bit. Fix this by adjusting the channel shift by 1. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-12staging: ipack/bridges/tpci200: Use endianess-aware types where applicable.Jens Taprogge
Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/devices/ipoctal: Unmap memory on device removal.Jens Taprogge
2012-09-12Staging: ipack: update TODO fileSamuel Iglesias Gonsalvez
With the latest patches, the TODO file was outdated. Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/devices/ipoctal: read more than one character from RX FIFO.Samuel Iglesias Gonsalvez
The RX FIFO has a size of 3 characters. Check if when we are picking the oldest one, we have more to read. Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/devices/ipoctal: Get rid of ipoctal_list.Jens Taprogge
Use tty_dev->dev's drdata to associate struct ipocal_channel to the respective tty_struct. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/devices/ipoctal: Use KBUILD_MODNAME instead of hardcoded string.Jens Taprogge
2012-09-12Staging: ipack/devices/ipoctal: Check tty_register_device return value.Jens Taprogge
2012-09-12Staging: ipack/devices/ipoctal: Clean up device removal.Jens Taprogge
Make use of dev_set_drvdata() and dev_get_drvdata() to store and obtain a pointer to the ipoctal struct corresponding to a struct dev. Previously we relied on a private list of devices. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack: Let interrupts return irqreturn_t.Jens Taprogge
2012-09-12Staging: ipack/bridges/tpci200: move tpci200_free_irq() and ↵Jens Taprogge
tpci200_request_irq() Now, all the interrupt related functions are next to each other. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/bridges/tpci200: More cleanups.Jens Taprogge
Rename __tpci_request_irq() to tpci_enable_irq() and __tpci_free_irq() to tpci_disable_irq(). Change their second argument, move them above tpci200_interrupt(), and use tpci_disable_irq() in the latter Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/bridges/tpci200: Cleanup in tpci200_slot_irq() and ↵Jens Taprogge
tpci200_interrupt() Minor cleanup. No functional changes. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/bridges/tpci200: Clean up interrupt handling.Jens Taprogge
Previously the return value from tpci200_interrupt was not quite correct if a slot had caused an interrupt but no handler was instellalled: IRQ_NONE was returned. However in this case we react to the interrupt by disabling the IPack device interrupt. Basically there are two cases the code now distinguishes: - The tpci200 has raised an interrupt. We handle it and return IRQ_HANDLED. - Our device did not raise an interrupt. We return IRQ_NONE. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/bridges/tpci200: Protect device registers with spinlock.Jens Taprogge
Some of the device registers are accessed from both interrupt and non-interrupt context. To ensure proper read-modify-write modification of these registers we can not use the "global" tpci200 mutex. Instead a spin-lock is used. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/bridges/tpci200: RCU protect slot_irq pointers.Jens Taprogge
In tpci200_request_irq as well as tpci200_free_irq we set and unset the pointer to struct slot_irq. This pointer is accessed in tpci200_interrupt. To ensure that the pointer is not freed after it has been fetched in tpci200_interrupt() it is now protected through RCU. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/devices/ipoctal: remove superfluous function.Jens Taprogge
ipoctal_write_tty and ipoctal_write are merged. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/devices/ipoctal: Split interrupt service routine.Jens Taprogge
Split the IRQ service routing in TX part and RX part. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/devices/ipoctal: Store isr masks in ipoctal_channelJens Taprogge
This way interrupt handling becomes independent of the channel number. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/devices/ipoctal: put ipoctal_channel into tty->driver_data.Jens Taprogge
Each tty's driver_data is now pointing to the channel it is talking to. struct ipoctal_channel contains all the information the callbacks require to do their work. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/devices/ipoctal: Directly use ioread/iowrite function.Jens Taprogge
2012-09-12Staging: ipack/devices/ipoctal: split ipoctal_channel from ipoctal.Jens Taprogge
By moving everything channel related into a separate struct we will be able to clean up a lot of code. In the end tty->driver_data will no longer need to point to ipoctal but instead can point to the respective channel. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/bridges/tpci200: Clean up interrupt handler.Jens Taprogge
This also removes a possible bug in the unhandles_ints part when slots[i] is not set. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/bridges/tpci200: Remove side effects of ↵Jens Taprogge
tpci200_{request,free}_irq. Use the __tpci200_{set,clear}_mask routines to access control register. Do not overwrite flags unrelated to interrupt handling. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: ipack/bridges/tpci200: add helpers for writing control regs.Jens Taprogge
Convert tpci200_set_clockrate and tpci200_interrupt. Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12staging/gdm72xx: gdm_usb coding style clean upMacpaul Lin
gdm_usb.* coding style clean up. Signed-off-by: Macpaul Lin <macpaul@gmail.com> Cc: Paul Stewart <pstew@chromium.org> Cc: Ben Chan <benchan@chromium.org> Cc: Sage Ahn <syahn@gctsemi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12staging: xgifb: prevent video RAM size exceeding PCI window sizeAaro Koskinen
Add a sanity check for the video RAM size. It should fit into the PCI window. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12staging: xgifb: validate the mode against video memory sizeAaro Koskinen
It's possible to select video mode that exceeds the available video memory. This is potentially dangerous, fix by adding a check. The patch fixes system hangs seen occasionally when playing random videos with mplayer. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12Staging: silicom: remove S_IWOTH from proc declarationDan Carpenter
We don't need these to be world writable or group writable. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Daniel Cotey <puff65537@bansheeslibrary.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
