2014-07-23ARM: dts: Fix wrong compatible string for Exynos3250 ADCiio-for-3.17dChanwoo Choi
This patchset fix wrong compatible string for Exynos3250 ADC. Exynos3250 SoC need to control only special clock for ADC. Exynos SoC except for Exynos3250 has not included special clock for ADC. The exynos ADC driver can control special clock if compatible string is 'exynos3250-adc-v2'. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-23iio: devicetree: Add DT binding documentation for Exynos3250 ADCChanwoo Choi
This patch add DT binding documentation for Exynos3250 ADC IP. Exynos3250 has special clock ('sclk_adc') for ADC which provide clock to internal ADC. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-23iio: adc: exynos_adc: Control special clock of ADC to support Exynos3250 ADCChanwoo Choi
This patch control special clock for ADC in Exynos series's FSYS block. If special clock of ADC is registerd on clock list of common clk framework, Exynos ADC drvier have to control this clock. Exynos3250/Exynos4/Exynos5 has 'adc' clock as following: - 'adc' clock: bus clock for ADC Exynos3250 has additional 'sclk_adc' clock as following: - 'sclk_adc' clock: special clock for ADC which provide clock to internal ADC Exynos 4210/4212/4412 and Exynos5250/5420 has not included 'sclk_adc' clock in FSYS_BLK. But, Exynos3250 based on Cortex-A7 has only included 'sclk_adc' clock in FSYS_BLK. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-23iio: adc: exynos_adc: Add exynos_adc_data structure to improve readabilityChanwoo Choi
This patchset add 'exynos_adc_data' structure which includes some functions to control ADC operation and specific data according to ADC version (v1 or v2). Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-23staging:iio:hmc5843: Add support for spi hmc5983Josef Gajdusek
This patch adds support for the hmc5983 spi interface. This chip is almost identical to the hmc5883. The difference being added temperature compensation, additional available sample rate (220Hz) and an SPI interface. Signed-off-by: Josef Gajdusek <atx@atx.name> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-23staging:iio:hmc5843: Add support for i2c hmc5983Josef Gajdusek
This patch adds support for the hmc5983 i2c interface. This chip is almost identical to the hmc5883. The difference being added temperature compensation, additional available sample rate (220Hz) and an SPI interface. Signed-off-by: Josef Gajdusek <atx@atx.name> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-23staging:iio:hmc5843: register <-> value arrays now can have different lengthsJosef Gajdusek
Changed structure of struct hmc5843_chip_info to include length of translation arrays. Code previously using #defined constant has been changed accordingly. This allows to integrate devices which do have different amounts of available rates/scales. Signed-off-by: Josef Gajdusek <atx@atx.name> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-23staging:iio:hmc5843: Split hmc5843.c to multiple filesJosef Gajdusek
This patch splits hmc5843.c to multiple files - the interface-agnostic hmc5843_core.c, i2c specific hmc5843_i2c.c and header file hmc5843.h. This is another step to add support of SPI-enabled hmc5983. Signed-off-by: Josef Gajdusek <atx@atx.name> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-23staging:iio:hmc5843: Added regmap supportJosef Gajdusek
This patch changes hmc5843.c to use regmap. This provides transparent caching to the code as well as abstraction necessary to add support for SPI-based hmc5983. Signed-off-by: Josef Gajdusek <atx@atx.name> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-20iio:kxcjk-1013: Fix endianness in scan_typePeter Meerwald
driver uses i2c_smbus_read_word_data() to the data in the trigger handler and hence already does endianness conversion; the I2C chip has data in little endian, but the value is provides in CPU endianness Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Reviewed-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-20iio: accel: kxcjk-1013: Increment ref counter for indio_dev->trigSrinivas Pandruvada
Assigning indio_dev->trig is not a good idea, as this can result in wrong reference count for trigger device. If assigned, it is better to increment reference counter by calling iio_trigger_get. Refer to http://www.spinics.net/lists/linux-iio/msg13669.html for discussion with Jonathan. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-20iio: accel: kxcjk-1013: Use try_reenable to ack intrSrinivas Pandruvada
This chip needs explicit interrupt ack, introducing try_reenable callback. Also removed separate function to ack interrupt as this doesn't add any value. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-20iio: accel: kxcjk-1013: Fix setting frequencySrinivas Pandruvada
Fix issue with setting of 12.5 and 6.25 HZ. The match of val2 fails. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-20iio: hid-sensor-magn-3d: Add support for rotation from northReyad Attiyat
Add the HID usage attribute ID's and IIO channel info for rotation from north support. Signed-off-by: Reyad Attiyat <reyad.attiyat@gmail.com> Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-20iio: hid-sensor-magn-3d: Scan for usage attributes before setting up iio ↵Reyad Attiyat
channels Scan for and count the HID usage attributes supported by the driver. This allows for the driver to only setup the IIO channels for the sensor usages present in the HID USB reports. Changes from v5 -Fixed kernel panic from invalid pointer dereference -Fixed variable assignment style Signed-off-by: Reyad Attiyat <reyad.attiyat@gmail.com> Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-20iio: types: Added support for rotation from north usage attributesReyad Attiyat
Added the rotation from north usage attributes to the iio modifier enum and to the iio modifier names array. Signed-off-by: Reyad Attiyat <reyad.attiyat@gmail.com> Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-20iio: Documentation: Add documentation for rotation from north sensor usage ↵Reyad Attiyat
attributes Added documentation for the sysfs attributes supported by the rotation from north sensor. Signed-off-by: Reyad Attiyat <reyad.attiyat@gmail.com> Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-13iio:adc:ad799x: Allow writing of event configPeter Meerwald
Allows explicity enabling of events Previously, events were always reported as enabled, but actually only implicitly enabled when updating the buffer scan mode Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-13iio:adc:ad799x: Return more meaningful event enabled statePeter Meerwald
only report an event as enabled if it actually is enabled Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-13iio:adc:ad799x: Set conversion channels and rename ad7997_8_update_scan_mode()Peter Meerwald
rename since function is used by all chips with ALERT pin, not just ad7997/8 Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-13iio:adc:ad799x: Write default config on probe and reset alert status on probePeter Meerwald
writing ALERT_EN and BUSY_ALERT to the chip config register clears pending alerts, BUSY_ALERT is cleared when reading back the register Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-13iio:adc:ad799x: Add helper function to read/write config registerPeter Meerwald
16-bit on ad7997/ad7998, 8-bit elsewhere Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-13iio:adc:ad799x: Make chan_spec const in ad799x_chip_config structPeter Meerwald
2014-07-13iio:adc:ad799x: Only expose event interface when IRQ is availablePeter Meerwald
an IRQ is necessary to handle the ALERT condition; without IRQ, the IIO event interface serves no purpose Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-13iio:adc:ad799x: Use BIT() and GENMASK()Peter Meerwald
2014-07-13iio:adc:ad799x: Save some lines in ad7997_8_update_scan_mode() exit handlingPeter Meerwald
2014-07-13iio:adc:ad799x: Drop I2C access helper functionsPeter Meerwald
2014-07-13Merge tag 'iio-for-3.17c' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: 3rd round of IIO new drivers, cleanups and functionality for the 3.17 cycle. New drivers * isl29125 digital color light sensor driver * TAOS/AMS tcs3414 digital color sensor Staging graduation * ad7291 ADC driver. New functionality * st_sensors - device tree support and bindings * mma8452 - device tree support Cleanups * Drop redundant variables in a number of drivers. * Reorder a structure definition to ealy wiht a warning about static not being at the beginning in the hid-sensors driver. * Switch a few more drivers away from using explicit sampling_frequency attribute to providing this through the core. * Make hid_sensor_get_reporting_interval static as only used within a single file. * Drop a redundant check for negative values in an unsigned variable from ad9832 * Drop some duplicate case labels in the event monitor example code. * Use devm_ioremap_resource to simplify error handling. * Use devm_kzalloc within the blackfin timer driver to simplify error handling and removal. * A number of cleanups of the ad7291 from Hartmut Knaack in response to a patch moving it out of staging. * Core support for the period info element about events. It has been in the abi for a while, but not added until now to the newer handling of information related to events. * Add HAS_IOMEM dependency to mxs_lradc to avoid build issues when testing enabled.
2014-07-13staging: rtl8188eu: Rename _rtw_init_mlme_priv() to rtw_init_mlme_priv()navin patidar
Signed-off-by: navin patidar <navin.patidar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-13staging: rtl8188eu: Rename _rtw_free_mlme_priv() to rtw_free_mlme_priv()navin patidar
2014-07-13staging: rtl8188eu: Remove unused function _rtw_enqueue_network()navin patidar
2014-07-13staging: rtl8188eu: Remove unused function _rtw_dequeue_network()navin patidar
2014-07-13staging: rtl8188eu: Make _rtw_free_network() staticnavin patidar
2014-07-13staging: rtl8188eu: Rename _rtw_find_network() to rtw_find_network()navin patidar
2014-07-13staging: rtl8188eu: Rename _rtw_free_network_queue() to rtw_free_network_queue()navin patidar
2014-07-13staging: rtl8188eu: Remove unused function rtw_get_timestampe_from_ie()navin patidar
2014-07-13staging: rtl8188eu: Remove unused function _rtw_IOL_append_WW_cmd()navin patidar
2014-07-13staging: rtl8188eu: Remove unused function rtw_set_802_11_remove_wep()navin patidar
2014-07-13staging: rtl8188eu: Remove unused function rtw_set_802_11_remove_key()navin patidar
2014-07-13staging: rtl8188eu: Remove unused function rtw_set_802_11_add_key()navin patidar
2014-07-13staging: rtl8188eu: Remove unused function rtw_validate_ssid()navin patidar
2014-07-13staging: rtl8188eu: Remove unused function rtw_set_scan_mode()navin patidar
2014-07-13staging: rtl8188eu: Remove function rtw_set_channel_plan()navin patidar
2014-07-13staging: rtl8188eu: Remove unused function rtw_use_tkipkey_handler()navin patidar
2014-07-13staging: vt6656: wcnd.c clean up commentsMalcolm Priestley
Removing old functions and comments. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-13staging: vt6656: wcmd remove unneeded headersMalcolm Priestley
2014-07-13staging: vt6656: rename vResetCommandTimer to vnt_reset_command_timerMalcolm Priestley
2014-07-13staging: vt6656: Drop u8 pointer and rename bScheduleCommand.Malcolm Priestley
Rename to vnt_schedule_command removing unused u8 pointer. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-13staging: vt6656: rename vRunCommand to vnt_run_commandMalcolm Priestley
2014-07-13staging: vt6656: rename vCommandTimerWait to vnt_cmd_timer_waitMalcolm Priestley
