lov_fiemap() does not take consider its @vallen parameter, which is
the max buffer size the caller can hold for the fiemap extents.
This patch fixes this and limits the max mapped fiemap extent count
to fit in the preallocted buffer.
This patch also fixes a memory out of bound write issue when the
fiemap call is only for detecting the number of existing extent.
Signed-off-by: Bobi Jam <bobijam.xu@intel.com>
Reviewed-on: http://review.whamcloud.com/9834
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4619
Reviewed-by: Fan Yong <fan.yong@intel.com>
Reviewed-by: Patrick Farrell <paf@cray.com>
Signed-off-by: Oleg Drokin <oleg.drokin@intel.com>
Apparently we are pretty bad about verifying our buffers passed
from userspace.
Reviewed-on: http://review.whamcloud.com/9059
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4563
Reviewed-by: Dmitry Eremin <dmitry.eremin@intel.com>
Reviewed-by: James Simmons <uja.ornl@gmail.com>
The Linux VFS and Lustre OST_SYNC RPC are both capable of specifying
fsync() on a sub-extent of the file {start, end} instead of the full
file. This allows less than the full amount of data to be flushed,
reducing or possibly eliminating the work needed before the syscall
can return.
However, the handling of sub-extent of the file for fsync was lost
with the move to CLIO on the client and OSD API on the server. They
were ignoring the passed {start, end} and using {0, OBD_OBJECT_EOF}
instead.
Return the ability to pass a sub-extent for fsync() from the client,
to the specific stripes/OSTs that need the sync operation, and pass
it down to the OSD. The ZFS OSD doesn't handle this yet, but there
is room for improvement in a separate patch.
Signed-off-by: Andreas Dilger <andreas.dilger@intel.com>
Reviewed-on: http://review.whamcloud.com/8626
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4388
Reviewed-by: Bobi Jam <bobijam@gmail.com>
Reviewed-by: Jinshan Xiong <jinshan.xiong@intel.com>
In libcfs_debug_vmsg2, cdls_delay is only clamped between the minimum
and the maximum when it is increased by multiplying by the backoff
factor. It is not clamped when it is decreased by dividing by the
backoff factor. This allows it to achieve values less than the
minimum, which allows a console message to be printed that should have
been skipped. This patch moves the clamping outside of the else
statement, ensuring that cdls_delay is always between the min and the
max after the first time through libcfs_debug_vmsg2.
Signed-off-by: Ryan Haasken <haasken@cray.com>
Reviewed-on: http://review.whamcloud.com/9503
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4711
Reviewed-by: Chris Horn <hornc@cray.com>
Reviewed-by: Ann Koehler <amk@cray.com>
Reviewed-by: Andreas Dilger <andreas.dilger@intel.com>
Removed the checks for oi_lockless from osc_io_read_start() and
osc_io_write_start(). This patch also removes the unnecessary call to
cl_object_attr_get() in osc_io_write_start() before calling
cl_object_attr_set()
Signed-off-by: Swapnil Pimpale <spimpale@ddn.com>
Reviewed-on: http://review.whamcloud.com/8797
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-3868
Reviewed-by: John L. Hammond <john.hammond@intel.com>
spin_is_locked() is always false when the platform is
uniprocessor and CONFIG_DEBUG_SPINLOCK is not enabled.
This patch replaces its assertion by assert_spin_locked().
Signed-off-by: Li Xi <lixi@ddn.com>
Signed-off-by: James Simmons <uja.ornl@gmail.com>
Reviewed-on: http://review.whamcloud.com/8144
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4199
Reviewed-by: Alexey Lyashkov <alexey_lyashkov@xyratex.com>
In llite remove unused declarations, parameters, types, and unused,
get-only, or set-only structure members. Add static and const
qualifiers to declarations where possible.
Signed-off-by: John L. Hammond <john.hammond@intel.com>
Reviewed-on: http://review.whamcloud.com/9767
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-2675
Reviewed-by: Lai Siyao <lai.siyao@intel.com>
In some cases, cl_default_mds_easize might be zero, especially for
MDC connected to non-MDT0, then mdc might pack getattr RPC with
zero eadatasize.
If client is trying to access remote striped directory with
zero eadatasize, MDT will not return layout information of the
striped direcotry, which will be mis-regarded as non-striped
directory.
So we should use cl_max_mds_easize if cl_default_mds_easize is zero.
Signed-off-by: wang di <di.wang@intel.com>
Reviewed-on: http://review.whamcloud.com/9862
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4847
It's not atomic to check the last reference and state of cl_lock
in cl_lock_put(). This can cause a problem that an using lock is
freed, if the process is preempted between atomic_dec_and_test()
and (lock->cll_state == CLS_FREEING).
This problem can be solved by holding a refcount by coh_locks. In
this case, it can be sure that if the lock refcount reaches zero,
nobody else can have any chance to use it again.
Signed-off-by: Jinshan Xiong <jinshan.xiong@intel.com>
Reviewed-on: http://review.whamcloud.com/9881
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4558
Change the LL_IOC_LLOOP_INFO ioctl in the lustre lloop
device driver to return an error instead of causing
panics with LASSERT().
Signed-off-by: Bob Glossman <bob.glossman@intel.com>
Reviewed-on: http://review.whamcloud.com/9888
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4863
Reviewed-by: Nathaniel Clark <nathaniel.l.clark@intel.com>
Messages which are printed by ll_dirty_page_discard_warn() should not
be rate limited. If they are rate limited, some files which may be
corrupted on client eviction will not be reported to the user.
This patch changes the CWARN to a CDEBUG to disable console message
rate limiting for this message. The dirty page discard warnings are
already limited on a per-file basis by the function vvp_vmpage_error
which calls ll_dirty_page_discard_warn only if the ccc_object's
cob_discard_page_warned == 0.
Reviewed-on: http://review.whamcloud.com/9752
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4799
Reviewed-by: Cory Spitz <spitzcor@cray.com>
According https://www.kernel.org/doc/Documentation/mutex-design.txt:
- the mutex subsystem is slightly faster and has better scalability
for contended workloads. In terms of 'ops per CPU cycle', the
semaphore kernel performed 551 ops/sec per 1% of CPU time used,
while the mutex kernel performed 3825 ops/sec per 1% of CPU time
used - it was 6.9 times more efficient.
- there are no fastpath tradeoffs, the mutex fastpath is just as
tight as the semaphore fastpath. On x86, the locking fastpath is
2 instructions.
- 'struct mutex' semantics are well-defined and are enforced if
CONFIG_DEBUG_MUTEXES is turned on. Semaphores on the other hand
have virtually no debugging code or instrumentation.
One more benefit of mutex is optimistic spinning. It try to spin for
acquisition when there are no pending waiters and the lock owner is
currently running on a (different) CPU. The rationale is that if the
lock owner is running, it is likely to release the lock soon.
This significantly reduce amount of context switches when locked
region is small and we have high contention.
Signed-off-by: Dmitry Eremin <dmitry.eremin@intel.com>
Reviewed-on: http://review.whamcloud.com/9095
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4257
It's just optimization. The mutex subsystem is slightly faster
and has better scalability for contended workloads.
Remove the lustre_lock and it's accessor functions l_lock(),
l_unlock(), l_lock_init(), and l_has_lock() since they have
not been used by the code since Lustre 1.6.
Reviewed-on: http://review.whamcloud.com/9294
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4588
Reviewed-by: Alex Zhuravlev <alexey.zhuravlev@intel.com>
Some CPU table functions for uniprocessor architecture is
missing.
Reviewed-on: http://review.whamcloud.com/8873
Reviewed-by: Bob Glossman <bob.glossman@intel.com>
Reviewed-by: Liang Zhen <liang.zhen@intel.com>
Reviewed-by: Oleg Drokin <oleg.drokin@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core fixes from Greg KH:
"Here are some kernfs fixes for 3.15-rc3 that resolve some reported
problems. Nothing huge, but all needed"
* tag 'driver-core-3.15-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
s390/ccwgroup: Fix memory corruption
kernfs: add back missing error check in kernfs_fop_mmap()
kernfs: fix a subdir count leak
Remove the nowhere included header lustre/include/ioctl.h.
Reviewed-on: http://review.whamcloud.com/9757
lnet_shutdown_lndnis() may enter endless loop if there is a busy NI,
this is injected by LNet SMP improvements. It's fixed in this patch.
Signed-off-by: Liang Zhen <liang.zhen@intel.com>
Reviewed-on: http://review.whamcloud.com/9706
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4780
Reviewed-by: Isaac Huang <he.huang@intel.com>
sscanf format specification '%u' expects type 'unsigned int *'
for 'u', but parameter 3 has a different type 'int*'.
Reviewed-on: http://review.whamcloud.com/9400
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4629
Pointer 'mod' checked for NULL at line 160 may be dereferenced at line 208.
Reviewed-on: http://review.whamcloud.com/9387
Pointer '*exp' returned from call to function 'class_conn2export'
at line 523 may be NULL and may be dereferenced at line 543.
Reviewed-on: http://review.whamcloud.com/9323
Locate the loh_flags and loh_ref fields together in lu_object_header
to avoid holes and shrink the structure by 8 bytes.
Reviewed-on: http://review.whamcloud.com/9185
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-3059
We used to access layout version under the protection of ldlm
lock, this introduces extra overhead for dlm lock matching.
In this patch, lli_layout_lock is introduced to access the layout
version. Also, when a layout lock is losing, we should tear down
mmap of the correspoding inode to avoid stale data accessing in the
future.
This is part of technical verification of replication.
Reviewed-on: http://review.whamcloud.com/8689
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-3254
The statahead debug messages include the pid of the current
process in their body. This is both redudant (because all
lustre log messages contain the pid), and sometimes downright
misleading. For instance the messages would say something like
"stopping statahead thread 3446". One would probably think
that 3446 is the pid of the process that is being stopped,
but in fact it was the pid of the caller issuing the stop signal.
We remove all superfluous pids from the messages.
Next we have the ll_statahead_thread() and the ll_agl_thread() record
their respective pids in their respective ptlrpc_thread structures.
This allows to print the pid of the thread that we are trying to
stop (which is actually useful info) from other threads, such as those
calling ll_stop_statahead().
Signed-off-by: Christopher J. Morrone <morrone2@llnl.gov>
Reviewed-on: http://review.whamcloud.com/9360
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4624
The statahead and statahead agl threads blindly set their
thread state to SVC_RUNNING without checking the state first. If, for
instance, another thread sets the state to SVC_STOPPING that
stop signal will now have been lost. Deadlock ensues.
We also partly improve the sai reference counting, because a race exists
where the ll_stop_statahead thread can drop the default reference, and
the statahead thread can exit and drop its reference as well. With no
references on the sai, the final put will poison and free the buffer. The
original do_statahead_enter() function may then continue to access
the buffer after it is freed because it did not take a reference of its
own. We add a local reference to address that.
Reviewed-on: http://review.whamcloud.com/9358
When allocating a reply buffer for the striping information don't
assume the unlikely worst case. Instead, assume the common case
and size the buffer based on the observed default ea/cookie size.
The default size is initialized to a single stripe and allowed to
grow up to an entire page if needed. This means that for smallish
filesystems (less than ~21 OSTs) where the worst case striping
information can fit in a single page there is effectively no
change. Only for larger filesystem will the default be less than
the maximum. This has a number of advantages.
* By limiting the default reply buffer size we avoid always
vmalloc()'ing the buffer because it exceeds four pages in size
and instead kmalloc() it. This prevents the client from
thrashing on the global vmalloc() spin lock.
* A reply buffer of exactly the right size (no larger) is allocated
in the overflow case. These larger reply buffers are still
unlikely to exceed the 16k limit where a vmalloc() will occur.
* Saves memory in the common case. Wide striped files exceeded
the default are expected to be the exception.
The reason this patch works is because the ptlrpc layer is smart
enough to reallocate the reply buffer when an overflow occurs.
Therefore the client doesn't have to drop the incoming reply and
send a new request with a larger reply buffer.
It's also worth mentioning that the reply buffer always contains
a significant amount of extra padding because they are rounded up
to the nearest power of two. This means that even files striped
wider than the default have a good chance of fitting in the
allocated reply buffer.
Also remove client eadatasize check in mdt xattr packing because
as said above client can handle -EOVERFLOW.
Signed-off-by: Brian Behlendorf <behlendorf1@llnl.gov>
Signed-off-by: Lai Siyao <lai.siyao@intel.com>
Reviewed-on: http://review.whamcloud.com/6339
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-3338
Otherwise, it will cause deadlock because it essentially holds
some sub locks and then to request others in an arbitrary order.
Reviewed-on: http://review.whamcloud.com/9152
File write before io loop will take lli_trun_sem read semaphore to
protect osc_extent, while after generic_file_aio_write() done, it
could possible need to kill suid or sgid, which will call
ll_setattr_raw() to change the inode's attribute, and it does not
involve size.
So the ll_truc_sem write semaphore should be constrained
around ll_setattr_ost() to not come across the lli_trunc_sem read
semaphore get from the normal file write path.
Reviewed-on: http://review.whamcloud.com/9267
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4627
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are a number of USB fixes for 3.15-rc3. The majority are gadget
fixes, as we didn't get any of those in for 3.15-rc2. The others are
all over the place, and there's a number of new device id addtions as
well."
* tag 'usb-3.15-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (35 commits)
usb: option: add and update a number of CMOTech devices
usb: option: add Alcatel L800MA
usb: option: add Olivetti Olicard 500
usb: qcserial: add Sierra Wireless MC7305/MC7355
usb: qcserial: add Sierra Wireless MC73xx
usb: qcserial: add Sierra Wireless EM7355
USB: io_ti: fix firmware download on big-endian machines
usb/xhci: fix compilation warning when !CONFIG_PCI && !CONFIG_PM
xhci: extend quirk for Renesas cards
xhci: Switch Intel Lynx Point ports to EHCI on shutdown.
usb: xhci: Prefer endpoint context dequeue pointer over stopped_trb
phy: core: make NULL a valid phy reference if !CONFIG_GENERIC_PHY
phy: fix kernel oops in phy_lookup()
phy: restore OMAP_CONTROL_PHY dependencies
phy: exynos: fix building as a module
USB: serial: fix sysfs-attribute removal deadlock
usb: wusbcore: fix panic in wusbhc_chid_set
usb: wusbcore: convert nested lock to use spin_lock instead of spin_lock_irq
uwb: don't call spin_unlock_irq in a USB completion handler
usb: chipidea: coordinate usb phy initialization for different phy type
The last parameter @datasync of fsync() has following indication:
* if datasync=0, we'd always flush data and metadata
* if datasync=1, we'd always flush data while does not flush modifed
metadata unless that metadata is needed in order to allow a
subsequent data retrieval to be correctly handled. For example, a
change to the file size would require a metadata flush.
Lustre client can not tell the difference easily, and would issue
MDS_SYNC and OST_SYNC in all cases.
Reviewed-on: http://review.whamcloud.com/8684
Setxattr does not check the permission when setting ACL xattrs. This
will cause security problem because any user can walk around
permission checking by changing ACL rules.
Reviewed-on: http://review.whamcloud.com/9473
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4704
The total size of an HSM archive request may exceed the
desired (LNET) message. When this happens, it can hang
the client and not allow the archive request to succeed.
Before we know the total size of the hsm_action_items, we
need to limit the size of the reguest. Doing this limits
the number of items that can be sent in one archive request.
We'e reduced the size allowed for the user archive request
to MDS_MAXREQSIZE/3.
Signed-off-by: James Nunez <james.a.nunez@intel.com>
Reviewed-on: http://review.whamcloud.com/9393
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4639
If fsname is 8-byte aligned, hai_zero fails to count the ending NULL
terminator causing hai to directly attached after fsname and future
hai_zero will return a different position for first hai.
Signed-off-by: Peng Tao <bergwolf@gmail.com>
Reviewed-on: http://review.whamcloud.com/9431
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4689
Remove the unused function llog_obd_add(). Remove the unused count and
parameters from llog_cancel(). Move dump_lsm() from obdclass to
the only module that uses it (lov). Remove obd_lov.h.
Reviewed-on: http://review.whamcloud.com/8545
Reviewed-by: Mike Pershin <mike.pershin@intel.com>
Remove the unused functions lov_llog_init(), lov_llog_finish(),
their supporting functions, and the file lov_log.c.
Reviewed-on: http://review.whamcloud.com/8539
Quiet some common console error messages for permission errors
that can be hit in common cases.
Reviewed-on: http://review.whamcloud.com/8988
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4522
Reviewed-by: Faccini Bruno <bruno.faccini@intel.com>
In Lustre 2.4, the flags passed to the memory allocation functions are
translated from CFS enumeration values types to the kernel GFP
values by calling cfs_alloc_flags_to_gfp(). This function adds
__GFP_WAIT to all flags except CFS_ALLOC_ATOMIC. In 2.5, when
the cfs wrappers were dropped, cfs_alloc_flags_to_gfp() was
removed and the CFS_ALLOC_xxxx was simply replaced with __GFP_xxxx.
This means that most memory allocation calls are missing the
__GFP_WAIT flag. The result is that Lustre experiences more ENOMEM
errors, many of which the higher levels of Lustre do not handle
robustly.
Notes GFP_NOFS = __GFP_WAIT | __GFP_IO. So the patch replaces
__GFP_IO with GFP_NOFS.
Patch does not add __GFP_WAIT to GFP_IOFS. GFP_IOFS was not used in
Lustre 2.4 so it has never been used with __GFP_WAIT.
Signed-off-by: Ann Koehler <amk@cray.com>
Signed-off-by: Emoly Liu <emoly.liu@intel.com>
Reviewed-on: http://review.whamcloud.com/9223
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4357
Add rpc_cache for allocating ptlrpc_requests.
Xyratex-bug-id: MRP-689
Signed-off-by: Andriy Skulysh <Andriy_Skulysh@xyratex.com>
Signed-off-by: Niu Yawei <yawei.niu@intel.com>
Reviewed-on: http://review.whamcloud.com/6874
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-2424
Array 'message_buf' of size 500 may use index value(s) -1
Object 'enc_key.data' was freed at line 164 after being freed
by calling 'free' at line 150. Also there are 3 similar errors
on line(s) 164.
Suspicious dereference of pointer 'vmsg' before NULL check at
line 187. Also there are 2 similar errors on line(s) 196, 205.
Suspicious dereference of pointer 'rmsg' before NULL check at
line 191. Also there are 2 similar errors on line(s) 200, 209.
Reviewed-on: http://review.whamcloud.com/9274
If a connection has been stopped with ptlrpc_pinger_del_import() and
marked obd_no_recov, don't reconnect in ptlrpc_disconnect_import() if
the import is already disconnected. Otherwise, without the pinger it
will just wait there indefinitely for the reconnection that will never
happen.
Put the obd_no_recov check inside ptlrpc_import_in_recovery() so that
any threads waiting on the connection to recover would also be broken
out of their sleep if obd_no_recov is set.
Reviewed-on: http://review.whamcloud.com/8996
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4413
Reviewed-by: wangdi <di.wang@intel.com>
The LDLM_FL_BLOCK_NOWAIT flag should be cleared when re-enqueue
the agl lock as normal glimpse, otherwise, it won't get size back
if there is conflicting locks on other client.
Reviewed-on: http://review.whamcloud.com/9249
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4597
Reviewed-by: Ned Bass <bass6@llnl.gov>
This patch moves lock's skip flag clearing from lru-delete to
lru-add code to prevent clearing lock's flag without resource lock
protection.
Reviewed-on: http://review.whamcloud.com/8772
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4269
LNET messages that are dropped are not accounted for correctly in
/proc/sys/lnet/stats. What I assume to be a simple typo is causing
drop_length to be double-counted and drop_count to never be
incremented.
Signed-off-by: Matt Ezell <ezellma@ornl.gov>
Reviewed-on: http://review.whamcloud.com/9096
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4577
Reviewed-by: James Nunez <james.a.nunez@intel.com>
In ptlrpc_activate_import(), obd_import->imp_deactive should
be checked if it is deactivated, otherwise it will trigger an
LBUG in ptlrpc_invalidate_import():
ptlrpc_invalidate_import() ASSERTION(imp->imp_invalid) failed
Signed-off-by: Hongchao Zhang <hongchao.zhang@intel.com>
Reviewed-on: http://review.whamcloud.com/8747
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4386
Function ptlrpc_update_export_timer generates lots of D_HA level log
messages whenever the export timer gets updated. Those log messages
are found little use for issue investigations, and it will take space
in the Lustre log buffer. We are removing it now.
Xyratex-bug-id: MRP-733
Signed-off-by: Cheng Shao <cheng_shao@xyratex.com>
Reviewed-on: http://review.whamcloud.com/9147
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4590
lustre_get_emerg_rs() set the size of the reply buffer to zero
by mistake, which will cause LBUG in null_alloc_rs() when memory
pressure is high. This patch fix this problem and adds a size
check to avoid the problem of insufficient buffer size.
Signed-off-by: Patrick Farrell <paf@cray.com>
Reviewed-on: http://review.whamcloud.com/8200
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-3680
Pull ACPI and power management fixes from Rafael Wysocki:
"These include a fix for a recent ACPI regression related to device
notifications, intel_idle fix related to IvyTown support, fix for a
buffer size issue in ACPICA, PM core fix related to the "freeze" sleep
state, four fixes for various types of breakage in cpufreq drivers, a
PNP workaround for a wrong memory region size in ACPI tables, and a
fix and cleanup for the ACPI tools Makefile.
Specifics:
- Fix for broken ACPI notifications on some systems caused by a
recent ACPI hotplug commit that blocked the propagation of unknown
type notifications to device drivers inadvertently.
- intel_idle fix to make the IvyTown C-states handling (added
recently) work as intended which now is broken due to missing
braces. From Christoph Jaeger.
- ACPICA fix to make it allocate buffers of the right sizes for the
Generic Serial Bus operation region access. From Lv Zheng.
- PM core fix unblocking cpuidle before entering the "freeze" sleep
state which causes that state to be able to actually save more
energy than runtime idle.
- Configuration and build fixes for the highbank and powernv cpufreq
drivers from Kefeng Wang and Srivatsa S Bhat.
- Coccinelle warning fix related to error pointers for the unicore32
cpufreq driver from Duan Jiong.
- Integer overflow fix for the ppc-corenet cpufreq driver from Geert
Uytterhoeven.
- Workaround for BIOSes that don't report the entire Intel MCH area
in their ACPI tables from Bjorn Helgaas.
- ACPI tools Makefile fix and cleanup from Thomas Renninger"
* tag 'pm+acpi-3.15-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / notify: Do not block unknown type notifications in root handler
PNP: Work around BIOS defects in Intel MCH area reporting
cpufreq: highbank: fix ARM_HIGHBANK_CPUFREQ dependency warning
cpufreq: ppc: Fix integer overflow in expression
cpufreq, powernv: Fix build failure on UP
cpufreq: unicore32: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
PM / suspend: Make cpuidle work in the "freeze" state
intel_idle: fix IVT idle state table setting
ACPICA: Fix buffer allocation issue for generic_serial_bus region accesses.
tools/power/acpi: Minor bugfixes
_rtw_free_network23a() and _rtw_free_network23a_nolock23a() are now
identical - one copy should do.
Signed-off-by: Jes Sorensen <Jes.Sorensen@redhat.com>
'isfreeall'
'lifetime'
