drivers/built-in.o: In function `gp2ap020a00f_thresh_event_handler':
powercap_sys.c:(.text+0x15f90c): undefined reference to `irq_work_queue'
make[1]: *** [vmlinux] Error 1
make[1]: Target `uImage' not remade because of errors.
make: *** [sub-make] Error 2
make: Target `uImage' not remade because of errors.
You need the IRQ work support, but GP2AP020A00F is not selecting this
symbol.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
In the original HID sensor hub firmwares all Named array enums were
to 0-based. But the most recent hub implemented as 1-based,
because of the implementation by one of the major OS vendor.
Using logical minimum for the field as the base of enum. So we add
logical minimum to the selector values before setting those fields.
Some sensor hub FWs already changed logical minimum from 0 to 1
to reflect this and hope every other vendor will follow.
There is no easy way to add a common HID quirk for NAry elements,
even if the standard specifies these field as NAry, the collection
used to describe selectors is still just "logical".
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Exporting logical minimum and maximum of HID fields as part of the
hid sensor attribute info. This can be used for range checking and
to calculate enumeration base for NAry fields of HID sensor hub.
There seems to be no active maintainer for the driver, and there is an
unfixed security bug, so disable the driver for now.
Hopefully someone steps up to be the maintainer, and works to get this
out of staging, otherwise it will be deleted soon.
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Omar Ramirez Luna <omar.ramirez@copitl.com>
Cc: Omar Ramirez Luna <omar.ramirez@ti.com>
Cc: Kanigeri, Hari <h-kanigeri2@ti.com>
Cc: Ameya Palande <ameya.palande@nokia.com>
Cc: Guzman Lugo, Fernando <fernando.lugo@ti.com>
Cc: Hebbar, Shivananda <x0hebbar@ti.com>
Cc: Ramos Falcon, Ernesto <ernesto@ti.com>
Cc: Felipe Contreras <felipe.contreras@gmail.com>
Cc: Anna, Suman <s-anna@ti.com>
Cc: Gupta, Ramesh <grgupta@ti.com>
Cc: Gomez Castellanos, Ivan <ivan.gomez@ti.com>
Cc: Andy Shevchenko <ext-andriy.shevchenko@nokia.com>
Cc: Armando Uribe De Leon <x0095078@ti.com>
Cc: Deepak Chitriki <deepak.chitriki@ti.com>
Cc: Menon, Nishanth <nm@ti.com>
Cc: Phil Carmody <ext-phil.2.carmody@nokia.com>
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Cc: stable <stable@vger.kernel.org>
zsmalloc encodes a handle using the pfn and an object
index. On hardware platforms with physical memory starting
at 0x0 the pfn can be 0. This causes the encoded handle to be
0 and is incorrectly interpreted as an allocation failure.
This issue affects all current and future SoCs with physical
memory starting at 0x0. All MSM8974 SoCs which includes
Google Nexus 5 devices are affected.
To prevent this false error we ensure that the encoded handle
will not be 0 when allocation succeeds.
Signed-off-by: Olav Haugan <ohaugan@codeaurora.org>
It was introduced due to a patch hunk when porting
commit 20802057 (staging/lustre/ptlrpc: race in pinger).
Cc: Andreas Dilger <andreas.dilger@intel.com>
Signed-off-by: Peng Tao <bergwolf@gmail.com>
Cc: stable <stable@vger.kernel.org> # 3.12
Two code lines were accidentally deleted. Restore them.
Cc: Stable <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
First round of fixes for IIO in the 3.13 cycle.
The usual mixed bag of fixes.
* 3 cases where kconfig dependencies were missing. We need to keep a closer
eye on this in new drivers.
* hid_sensors was abusing the iio_dev->trigger pointer. We had a round
of clearing this out some time ago but this driver clearly slipped through.
* A misuse of the IIO_ST macro, in mcp3422, which we should really make a
concertive effort to finish removing.
* Avoid a double free introduced by recent buffer reference counting in the
one driver that (quite reasonably!) does things differently (am335x)
* A missing mutex_unlock in kxsd9 that means that driver has been non
functional for some time and no one noticed (including me who for once
actually has one of the supported devices).
* An incorrect assumption about the parameters of sign_extend32 in mcp3422.
So nothing controversial. The only substantial patch is the hid_sensors
one and that is actually just adding a new pointer to the devices private
state then moving the code over to it.
drivers/staging/btmtk_usb/btmtk_usb.c: In function ‘btmtk_usb_probe’:
drivers/staging/btmtk_usb/btmtk_usb.c:1610: warning: assignment from incompatible pointer type
Add the new hdev parameter, cfr. commit
7bd8f09f69f8a190f9b8334a07bb0a9237612314 ("Bluetooth: Add hdev parameter to
hdev->send driver callback").
This fixes up the remaining "dev is used before it is set" issues in the
go7007 driver that were originally caused by commit
b6ea5ef80aa7fd6f4b18ff2e4174930e8772e812 but not fixed up by reverting
it due to other patches later on adding these "fixes".
Cc: Hans Verkuil <hans.verkuil@cisco.com>
Cc: Mauro Carvalho Chehab <m.chehab@samsung.com>
Cc: Dulshani Gunawardhana <dulshani.gunawardhana89@gmail.com>
Cc: Josh Triplett <josh@joshtriplett.org>
commit b8d181e408af (staging: drm/imx: add drm plane support) added a file
to the make target for DRM_IMX_IPUV3 but didn't adjust the objs required
to actually build that as a module. Kbuild got confused and this lead to
link errors like:
ERROR: "ipu_plane_disable" [drivers/staging/imx-drm/ipuv3-crtc.ko] undefined!
ERROR: "ipu_plane_enable" [drivers/staging/imx-drm/ipuv3-crtc.ko] undefined!
Additionally, it added a call to imx_drm_crtc_id which also fails with a
link error as above. To fix this, we adjust the make target with the proper
objs, which will change the name of the resulting .ko. We also add an
EXPORT_SYMBOL_GPL for imx_drm_crtc_id.
Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org>
Fixes: b8d181e408af '(staging: drm/imx: add drm plane support)'
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
If boot_case is false, status in never assigned a value.
This reverts commit b6ea5ef80aa7fd6f4b18ff2e4174930e8772e812.
Turns out to have lots of run-time issues in that the structure is not
initialized before it is used in the debugging messages.
Reported-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
As suggested by Minchan Kim and Jerome Marchand "The code in reset_store
get the block device (bdget_disk()) but it does not put it (bdput()) when
it's done using it. The usage count is therefore incremented but never
decremented."
This patch also puts bdput() for all error cases.
Acked-by: Minchan Kim <minchan@kernel.org>
Acked-by: Jerome Marchand <jmarchan@redhat.com>
Cc: stable@vger.kernel.org
Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com>
This fixes resets on heavy TX data traffic.
Vendor driver
VT6656_Linux_src_v1.21.03_x86_11.04.zip
http://www.viaembedded.com/servlet/downloadSvl?id=1890&download_file_id=14704
This is GPL-licensed code.
original code
BBbVT3184Init
//2007-0725, RobertChang add, Enable Squelch detect reset option(SQ_RST_Opt), USB (register4, bit1)
CONTROLnsRequestIn(pDevice,
MESSAGE_TYPE_READ,
(WORD)0x600+4, // USB's Reg4's bit1
MESSAGE_REQUEST_MEM,
1,
(PBYTE) &byData);
byData = byData|2 ;
CONTROLnsRequestOut(pDevice,
MESSAGE_TYPE_WRITE,
1,
(PBYTE) &byData);
return TRUE;//ntStatus;
A back port patch is needed for kernels less than 3.10.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
Cc: stable@vger.kernel.org # v3.10+
We assume nvec->rx can be NULL earlier so I have added a check here as
well.
We fixed this to use free_netdev() instead of kfree() but unfortunately
free_netdev() doesn't accept NULL pointers. Smatch complains about
this, it's not something I discovered through testing.
Fixes: 3030d40b5036 ('staging: vt6655: use free_netdev instead of kfree')
Fixes: 0a438d5b381e ('staging: vt6656: use free_netdev instead of kfree')
I broke `s626_set_dac()` by changing the type of the `dacdata` parameter
from `short` to `unsigned short`. It's actually designed to take a
signed value in the range -0x1fff to +0x2000 although values above
0x1fff get clamped to 0x1fff. (We could change the `maxdata` value to
0x1ffe to avoid the clamping, but `maxdata` values are usually a power
of 2 minus 1.) The bug results in all negative values passed to the
function being changed to +0x1fff by the clamp. Change the parameter
type to `int16_t` to fix the problem.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
These conditions are never true because they use bitwise AND instead of
logical ands.
Fixes: b3ff824a81e8 ('staging: comedi: drivers: use comedi_dio_update_state() for complex cases')
Acked-by: Ian Abbott <abbotti@mev.co.uk>
If none of the if conditions take a true path, the ret variable will
never be assigned a value.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs
Pull minor eCryptfs fix from Tyler Hicks:
"Quiet static checkers by removing unneeded conditionals"
* tag 'ecryptfs-3.13-rc1-quiet-checkers' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs:
eCryptfs: file->private_data is always valid
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull second set of sound fixes from Takashi Iwai:
"A collection of small fixes in HD-audio quirks and runtime PM, ASoC
rcar, abs8500 and other codecs. Most of commits are for stable
kernels, too"
* tag 'sound-fix2-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Set current_headset_type to ALC_HEADSET_TYPE_ENUM (janitorial)
ALSA: hda - Provide missing pin configs for VAIO with ALC260
ALSA: hda - Add headset quirk for Dell Inspiron 3135
ALSA: hda - Fix the headphone jack detection on Sony VAIO TX
ALSA: hda - Fix missing bass speaker on ASUS N550
ALSA: hda - Fix unbalanced runtime PM notification at resume
ASoC: arizona: Set FLL to free-run before disabling
ALSA: hda - A casual Dell Headset quirk
ASoC: rcar: fixup dma_async_issue_pending() timing
ASoC: rcar: off by one in rsnd_scu_set_route()
ASoC: wm5110: Add post SYSCLK register patch for rev D chip
ASoC: ab8500: Revert to using custom I/O functions
ALSA: hda - Also enable mute/micmute LED control for "Lenovo dock" fixup
ALSA: firewire-lib: include sound/asound.h to refer to snd_pcm_format_t
ALSA: hda - Select FW_LOADER from CONFIG_SND_HDA_CODEC_CA0132_DSP
ALSA: hda - Enable mute/mic-mute LEDs for more Thinkpads with Realtek codec
ASoC: rcar: fixup mod access before checking
Pull DRM fixes from Dave Airlie:
"I was going to leave this until post -rc1 but sysfs fixes broke
hotplug in userspace, so I had to fix it harder, otherwise a set of
pulls from intel, radeon and vmware,
The vmware/ttm changes are bit larger but since its early and they are
unlikely to break anything else I put them in, it lets vmware work
with dri3"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (36 commits)
drm/sysfs: fix hotplug regression since lifetime changes
drm/exynos: g2d: fix memory leak to userptr
drm/i915: Fix gen3 self-refresh watermarks
drm/ttm: Remove set_need_resched from the ttm fault handler
drm/ttm: Don't move non-existing data
drm/radeon: hook up backlight functions for CI and KV family.
drm/i915: Replicate BIOS eDP bpp clamping hack for hsw
drm/i915: Do not enable package C8 on unsupported hardware
drm/i915: Hold pc8 lock around toggling pc8.gpu_idle
drm/i915: encoder->get_config is no longer optional
drm/i915/tv: add ->get_config callback
drm/radeon/cik: Add macrotile mode array query
drm/radeon/cik: Return backend map information to userspace
drm/vmwgfx: Make vmwgfx dma buffers prime aware
drm/vmwgfx: Make surfaces prime-aware
drm/vmwgfx: Hook up the prime ioctls
drm/ttm: Add a minimal prime implementation for ttm base objects
drm/vmwgfx: Fix false lockdep warning
drm/ttm: Allow execbuf util reserves without ticket
drm/i915: restore the early forcewake cleanup
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Miscellaneous
- Remove duplicate disable from pcie_portdrv_remove() (Yinghai Lu)
- Fix whitespace, capitalization, and spelling errors (Bjorn Helgaas)"
* tag 'pci-v3.13-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: Remove duplicate pci_disable_device() from pcie_portdrv_remove()
PCI: Fix whitespace, capitalization, and spelling errors
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Things have been quiet this round with mostly bugfixes, percpu
conversions, and other minor iscsi-target conformance testing changes.
The highlights include:
- Add demo_mode_discovery attribute for iscsi-target (Thomas)
- Convert tcm_fc(FCoE) to use percpu-ida pre-allocation
- Add send completion interrupt coalescing for ib_isert
- Convert target-core to use percpu-refcounting for se_lun
- Fix mutex_trylock usage bug in iscsit_increment_maxcmdsn
- tcm_loop updates (Hannes)
- target-core ALUA cleanups + prep for v3.14 SCSI Referrals support (Hannes)
v3.14 is currently shaping to be a busy development cycle in target
land, with initial support for T10 Referrals and T10 DIF currently on
the roadmap"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (40 commits)
iscsi-target: chap auth shouldn't match username with trailing garbage
iscsi-target: fix extract_param to handle buffer length corner case
iscsi-target: Expose default_erl as TPG attribute
target_core_configfs: split up ALUA supported states
target_core_alua: Make supported states configurable
target_core_alua: Store supported ALUA states
target_core_alua: Rename ALUA_ACCESS_STATE_OPTIMIZED
target_core_alua: spellcheck
target core: rename (ex,im)plict -> (ex,im)plicit
percpu-refcount: Add percpu-refcount.o to obj-y
iscsi-target: Do not reject non-immediate CmdSNs exceeding MaxCmdSN
iscsi-target: Convert iscsi_session statistics to atomic_long_t
target: Convert se_device statistics to atomic_long_t
target: Fix delayed Task Aborted Status (TAS) handling bug
iscsi-target: Reject unsupported multi PDU text command sequence
ib_isert: Avoid duplicate iscsit_increment_maxcmdsn call
iscsi-target: Fix mutex_trylock usage in iscsit_increment_maxcmdsn
target: Core does not need blkdev.h
target: Pass through I/O topology for block backstores
iser-target: Avoid using FRMR for single dma entry requests
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fixes from Guenter Roeck:
- acpi_power_meter: Fix return value check from call to
acpi_bus_get_device
- nct6775: Fix/improve NCT6791 support
- lm75: Add support for GMT G751
* tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (acpi_power_meter) Fix acpi_bus_get_device() return value check
hwmon: (nct6775) NCT6791 supports weight control only for CPUFAN
hwmon: (nct6775) Monitor additional temperature registers
hwmon: (lm75) Add support for GMT G751 chip
Pull networking fixes from David Miller:
1) Fix memory leaks and other issues in mwifiex driver, from Amitkumar
Karwar.
2) skb_segment() can choke on packets using frag lists, fix from
Herbert Xu with help from Eric Dumazet and others.
3) IPv4 output cached route instantiation properly handles races
involving two threads trying to install the same route, but we
forgot to propagate this logic to input routes as well. Fix from
Alexei Starovoitov.
4) Put protections in place to make sure that recvmsg() paths never
accidently copy uninitialized memory back into userspace and also
make sure that we never try to use more that sockaddr_storage for
building the on-kernel-stack copy of a sockaddr. Fixes from Hannes
Frederic Sowa.
5) R8152 driver transmit flow bug fixes from Hayes Wang.
6) Fix some minor fallouts from genetlink changes, from Johannes Berg
and Michael Opdenacker.
7) AF_PACKET sendmsg path can race with netdevice unregister notifier,
fix by using RCU to make sure the network device doesn't go away
from under us. Fix from Daniel Borkmann.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (43 commits)
gso: handle new frag_list of frags GRO packets
genetlink: fix genl_set_err() group ID
genetlink: fix genlmsg_multicast() bug
packet: fix use after free race in send path when dev is released
xen-netback: stop the VIF thread before unbinding IRQs
wimax: remove dead code
net/phy: Add the autocross feature for forced links on VSC82x4
net/phy: Add VSC8662 support
net/phy: Add VSC8574 support
net/phy: Add VSC8234 support
net: add BUG_ON if kernel advertises msg_namelen > sizeof(struct sockaddr_storage)
net: rework recvmsg handler msg_name and msg_namelen logic
bridge: flush br's address entry in fdb when remove the
net: core: Always propagate flag changes to interfaces
ipv4: fix race in concurrent ip_route_input_slow()
r8152: fix incorrect type in assignment
r8152: support stopping/waking tx queue
r8152: modify the tx flow
r8152: fix tx/rx memory overflow
netfilter: ebt_ip6: fix source and destination matching
Pull ARM fixes from Russell King:
"Some small fixes for this merge window, most of them quite self
explanatory - the biggest thing here is a fix for the ARMv7 LPAE
suspend/resume support"
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7894/1: kconfig: select GENERIC_CLOCKEVENTS if HAVE_ARM_ARCH_TIMER
ARM: 7893/1: bitops: only emit .arch_extension mp if CONFIG_SMP
ARM: 7892/1: Fix warning for V7M builds
ARM: 7888/1: seccomp: not compatible with ARM OABI
ARM: 7886/1: make OABI default to off
ARM: 7885/1: Save/Restore 64-bit TTBR registers on LPAE suspend/resume
ARM: 7884/1: mm: Fix ECC mem policy printk
ARM: 7883/1: fix mov to mvn conversion in case of 64 bit phys_addr_t and BE
ARM: 7882/1: mm: fix __phys_to_virt to work with 64 bit phys_addr_t in BE case
ARM: 7881/1: __fixup_smp read of SCU config should do byteswap in BE case
ARM: Fix nommu.c build warning
Pull KVM fixes from Gleb Natapov.
* 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: kvm_clear_guest_page(): fix empty_zero_page usage
kvm: mmu: delay mmu audit activation
arm/arm64: KVM: Fix hyp mappings of vmalloc regions
Pull aio fixes from Benjamin LaHaise.
* git://git.kvack.org/~bcrl/aio-next:
aio: nullify aio->ring_pages after freeing it
aio: prevent double free in ioctx_alloc
aio: Fix a trinity splat
Pull nfsd bugfixes from Bruce Fields:
"A couple nfsd bugfixes"
* 'for-3.13' of git://linux-nfs.org/~bfields/linux:
nfsd4: fix xdr decoding of large non-write compounds
nfsd: make sure to balance get/put_write_access
nfsd: split up nfsd_setattr
git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixes
Pull GFS2 fixes from Steven Whitehouse:
"A couple of small, but important bug fixes for GFS2. The first one
fixes a possible NULL pointer dereference, and the second one resolves
a reference counting issue in one of the lesser used paths through
atomic_open"
* tag 'gfs2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixes:
GFS2: Fix ref count bug relating to atomic_open
GFS2: fix potential NULL pointer dereference
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"Almost all of these are bug fixes. Dave Sterba's documentation update
is the big exception because he removed our promises to set any
machine running Btrfs on fire"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Documentation: filesystems: update btrfs tools section
Documentation: filesystems: add new btrfs mount options
btrfs: update kconfig help text
btrfs: fix bio_size_ok() for max_sectors > 0xffff
btrfs: Use trace condition for get_extent tracepoint
btrfs: fix typo in the log message
Btrfs: fix list delete warning when removing ordered root from the list
Btrfs: print bytenr instead of page pointer in check-int
Btrfs: remove dead codes from ctree.h
Btrfs: don't wait for ordered data outside desired range
Btrfs: fix lockdep error in async commit
Btrfs: avoid heavy operations in btrfs_commit_super
Btrfs: fix __btrfs_start_workers retval
Btrfs: disable online raid-repair on ro mounts
Btrfs: do not inc uncorrectable_errors counter on ro scrubs
Btrfs: only drop modified extents if we logged the whole inode
Btrfs: make sure to copy everything if we rename
Btrfs: don't BUG_ON() if we get an error walking backrefs
Pull second xfs update from Ben Myers:
"There are a couple of patches that I wasn't quite sure about in time
for our initial 3.13 pull request, a bugfix, and an update to add Dave
to MAINTAINERS:
Here we have a performance fix for inode iversion, increased inode
cluster size for v5 superblock filesystems, a fix for error handling
in xfs_bmap_add_attrfork, and a MAINTAINERS update to add Dave"
* tag 'xfs-for-linus-v3.13-rc1-2' of git://oss.sgi.com/xfs/xfs:
xfs: open code inc_inode_iversion when logging an inode
xfs: increase inode cluster size for v5 filesystems
xfs: fix unlock in xfs_bmap_add_attrfork
xfs: update maintainers
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux
Pull SLAB changes from Pekka Enberg:
"The patches from Joonsoo Kim switch mm/slab.c to use 'struct page' for
slab internals similar to mm/slub.c. This reduces memory usage and
improves performance:
https://lkml.org/lkml/2013/10/16/155
Rest of the changes are bug fixes from various people"
* 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: (21 commits)
mm, slub: fix the typo in mm/slub.c
mm, slub: fix the typo in include/linux/slub_def.h
slub: Handle NULL parameter in kmem_cache_flags
slab: replace non-existing 'struct freelist *' with 'void *'
slab: fix to calm down kmemleak warning
slub: proper kmemleak tracking if CONFIG_SLUB_DEBUG disabled
slab: rename slab_bufctl to slab_freelist
slab: remove useless statement for checking pfmemalloc
slab: use struct page for slab management
slab: replace free and inuse in struct slab with newly introduced active
slab: remove SLAB_LIMIT
slab: remove kmem_bufctl_t
slab: change the management method of free objects of the slab
slab: use __GFP_COMP flag for allocating slab pages
slab: use well-defined macro, virt_to_slab()
slab: overloading the RCU head over the LRU for RCU free
slab: remove cachep in struct slab_rcu
slab: remove nodeid in struct slab
slab: remove colouroff in struct slab
slab: change return type of kmem_getpages() to struct page
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull third set of powerpc updates from Benjamin Herrenschmidt:
"This is a small collection of random bug fixes and a few improvements
of Oops output which I deemed valuable enough to include as well.
The fixes are essentially recent build breakage and regressions, and a
couple of older bugs such as the DTL log duplication, the EEH issue
with PCI_COMMAND_MASTER and the problem with small contexts passed to
get/set_context with VSX enabled"
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/signals: Mark VSX not saved with small contexts
powerpc/pseries: Fix SMP=n build of rng.c
powerpc: Make cpu_to_chip_id() available when SMP=n
powerpc/vio: Fix a dma_mask issue of vio
powerpc: booke: Fix build failures
powerpc: ppc64 address space capped at 32TB, mmap randomisation disabled
powerpc: Only print PACATMSCRATCH in oops when TM is active
powerpc/pseries: Duplicate dtl entries sometimes sent to userspace
powerpc: Remove a few lines of oops output
powerpc: Print DAR and DSISR on machine check oopses
powerpc: Fix __get_user_pages_fast() irq handling
powerpc/eeh: More accurate log
powerpc/eeh: Enable PCI_COMMAND_MASTER for PCI bridges
current_headset_type should be of the HEADSET_TYPE enum, not the
HEADSET_MODE enum. Since ALC_HEADSET_TYPE_UNKNOWN and ALC_HEADSET_MODE_UNKNOWN
are both 0, this patch is just janitorial.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
Some models (or maybe depending on BIOS version) of Sony VAIO with
ALC260 give no proper pin configurations as default, resulting in the
non-working speaker, etc. Just provide the whole pin configurations
via a fixup.
Reported-by: Matthew Markus <mmarkus@hearit.co>
Cc: <stable@vger.kernel.org>
Merge patches from Andrew Morton:
"13 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
mm: place page->pmd_huge_pte to right union
MAINTAINERS: add keyboard driver to Hyper-V file list
x86, mm: do not leak page->ptl for pmd page tables
ipc,shm: correct error return value in shmctl (SHM_UNLOCK)
mm, mempolicy: silence gcc warning
block/partitions/efi.c: fix bound check
ARM: drivers/rtc/rtc-at91rm9200.c: disable interrupts at shutdown
mm: hugetlbfs: fix hugetlbfs optimization
kernel: remove CONFIG_USE_GENERIC_SMP_HELPERS cleanly
ipc,shm: fix shm_file deletion races
mm: thp: give transparent hugepage code a separate copy_page
checkpatch: fix "Use of uninitialized value" warnings
configfs: fix race between dentry put and lookup
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"In this patchset, we finally get an SELinux update, with Paul Moore
taking over as maintainer of that code.
Also a significant update for the Keys subsystem, as well as
maintenance updates to Smack, IMA, TPM, and Apparmor"
and since I wanted to know more about the updates to key handling,
here's the explanation from David Howells on that:
"Okay. There are a number of separate bits. I'll go over the big bits
and the odd important other bit, most of the smaller bits are just
fixes and cleanups. If you want the small bits accounting for, I can
do that too.
(1) Keyring capacity expansion.
KEYS: Consolidate the concept of an 'index key' for key access
KEYS: Introduce a search context structure
KEYS: Search for auth-key by name rather than target key ID
Add a generic associative array implementation.
KEYS: Expand the capacity of a keyring
Several of the patches are providing an expansion of the capacity of a
keyring. Currently, the maximum size of a keyring payload is one page.
Subtract a small header and then divide up into pointers, that only gives
you ~500 pointers on an x86_64 box. However, since the NFS idmapper uses
a keyring to store ID mapping data, that has proven to be insufficient to
the cause.
Whatever data structure I use to handle the keyring payload, it can only
store pointers to keys, not the keys themselves because several keyrings
may point to a single key. This precludes inserting, say, and rb_node
struct into the key struct for this purpose.
I could make an rbtree of records such that each record has an rb_node
and a key pointer, but that would use four words of space per key stored
in the keyring. It would, however, be able to use much existing code.
I selected instead a non-rebalancing radix-tree type approach as that
could have a better space-used/key-pointer ratio. I could have used the
radix tree implementation that we already have and insert keys into it by
their serial numbers, but that means any sort of search must iterate over
the whole radix tree. Further, its nodes are a bit on the capacious side
for what I want - especially given that key serial numbers are randomly
allocated, thus leaving a lot of empty space in the tree.
So what I have is an associative array that internally is a radix-tree
with 16 pointers per node where the index key is constructed from the key
type pointer and the key description. This means that an exact lookup by
type+description is very fast as this tells us how to navigate directly to
the target key.
I made the data structure general in lib/assoc_array.c as far as it is
concerned, its index key is just a sequence of bits that leads to a
pointer. It's possible that someone else will be able to make use of it
also. FS-Cache might, for example.
(2) Mark keys as 'trusted' and keyrings as 'trusted only'.
KEYS: verify a certificate is signed by a 'trusted' key
KEYS: Make the system 'trusted' keyring viewable by userspace
KEYS: Add a 'trusted' flag and a 'trusted only' flag
KEYS: Separate the kernel signature checking keyring from module signing
These patches allow keys carrying asymmetric public keys to be marked as
being 'trusted' and allow keyrings to be marked as only permitting the
addition or linkage of trusted keys.
Keys loaded from hardware during kernel boot or compiled into the kernel
during build are marked as being trusted automatically. New keys can be
loaded at runtime with add_key(). They are checked against the system
keyring contents and if their signatures can be validated with keys that
are already marked trusted, then they are marked trusted also and can
thus be added into the master keyring.
Patches from Mimi Zohar make this usable with the IMA keyrings also.
(3) Remove the date checks on the key used to validate a module signature.
X.509: Remove certificate date checks
It's not reasonable to reject a signature just because the key that it was
generated with is no longer valid datewise - especially if the kernel
hasn't yet managed to set the system clock when the first module is
loaded - so just remove those checks.
(4) Make it simpler to deal with additional X.509 being loaded into the kernel.
KEYS: Load *.x509 files into kernel keyring
KEYS: Have make canonicalise the paths of the X.509 certs better to deduplicate
The builder of the kernel now just places files with the extension ".x509"
into the kernel source or build trees and they're concatenated by the
kernel build and stuffed into the appropriate section.
(5) Add support for userspace kerberos to use keyrings.
KEYS: Add per-user_namespace registers for persistent per-UID kerberos caches
KEYS: Implement a big key type that can save to tmpfs
Fedora went to, by default, storing kerberos tickets and tokens in tmpfs.
We looked at storing it in keyrings instead as that confers certain
advantages such as tickets being automatically deleted after a certain
amount of time and the ability for the kernel to get at these tokens more
easily.
To make this work, two things were needed:
(a) A way for the tickets to persist beyond the lifetime of all a user's
sessions so that cron-driven processes can still use them.
The problem is that a user's session keyrings are deleted when the
session that spawned them logs out and the user's user keyring is
deleted when the UID is deleted (typically when the last log out
happens), so neither of these places is suitable.
I've added a system keyring into which a 'persistent' keyring is
created for each UID on request. Each time a user requests their
persistent keyring, the expiry time on it is set anew. If the user
doesn't ask for it for, say, three days, the keyring is automatically
expired and garbage collected using the existing gc. All the kerberos
tokens it held are then also gc'd.
(b) A key type that can hold really big tickets (up to 1MB in size).
The problem is that Active Directory can return huge tickets with lots
of auxiliary data attached. We don't, however, want to eat up huge
tracts of unswappable kernel space for this, so if the ticket is
greater than a certain size, we create a swappable shmem file and dump
the contents in there and just live with the fact we then have an
inode and a dentry overhead. If the ticket is smaller than that, we
slap it in a kmalloc()'d buffer"
* 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (121 commits)
KEYS: Fix keyring content gc scanner
KEYS: Fix error handling in big_key instantiation
KEYS: Fix UID check in keyctl_get_persistent()
KEYS: The RSA public key algorithm needs to select MPILIB
ima: define '_ima' as a builtin 'trusted' keyring
ima: extend the measurement list to include the file signature
kernel/system_certificate.S: use real contents instead of macro GLOBAL()
KEYS: fix error return code in big_key_instantiate()
KEYS: Fix keyring quota misaccounting on key replacement and unlink
KEYS: Fix a race between negating a key and reading the error set
KEYS: Make BIG_KEYS boolean
apparmor: remove the "task" arg from may_change_ptraced_domain()
apparmor: remove parent task info from audit logging
apparmor: remove tsk field from the apparmor_audit_struct
apparmor: fix capability to not use the current task, during reporting
Smack: Ptrace access check mode
ima: provide hash algo info in the xattr
ima: enable support for larger default filedata hash algorithms
ima: define kernel parameter 'ima_template=' to change configured default
ima: add Kconfig default measurement list template
Pull audit updates from Eric Paris:
"Nothing amazing. Formatting, small bug fixes, couple of fixes where
we didn't get records due to some old VFS changes, and a change to how
we collect execve info..."
Fixed conflict in fs/exec.c as per Eric and linux-next.
* git://git.infradead.org/users/eparis/audit: (28 commits)
audit: fix type of sessionid in audit_set_loginuid()
audit: call audit_bprm() only once to add AUDIT_EXECVE information
audit: move audit_aux_data_execve contents into audit_context union
audit: remove unused envc member of audit_aux_data_execve
audit: Kill the unused struct audit_aux_data_capset
audit: do not reject all AUDIT_INODE filter types
audit: suppress stock memalloc failure warnings since already managed
audit: log the audit_names record type
audit: add child record before the create to handle case where create fails
audit: use given values in tty_audit enable api
audit: use nlmsg_len() to get message payload length
audit: use memset instead of trying to initialize field by field
audit: fix info leak in AUDIT_GET requests
audit: update AUDIT_INODE filter rule to comparator function
audit: audit feature to set loginuid immutable
audit: audit feature to only allow unsetting the loginuid
audit: allow unsetting the loginuid (with priv)
audit: remove CONFIG_AUDIT_LOGINUID_IMMUTABLE
audit: loginuid functions coding style
selinux: apply selinux checks on new audit message types
I don't know what went wrong, mis-merge or something, but ->pmd_huge_pte
placed in wrong union within struct page.
In original patch[1] it's placed to union with ->lru and ->slab, but in
commit e009bb30c8df ("mm: implement split page table lock for PMD
level") it's in union with ->index and ->freelist.
That union seems also unused for pages with table tables and safe to
re-use, but it's not what I've tested.
Let's move it to original place. It fixes indentation at least. :)
[1] https://lkml.org/lkml/2013/10/7/288
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
There are two code paths how page with pmd page table can be freed:
pmd_free() and pmd_free_tlb().
I've missed the second one and didn't add page table destructor call
there. It leads to leak of page->ptl for pmd page tables, if
dynamically allocated page->ptl is in use.
The patch adds the missed destructor and modifies documentation
accordingly.
Reported-by: Andrey Vagin <avagin@openvz.org>
Tested-by: Andrey Vagin <avagin@openvz.org>
Commit 2caacaa82a51 ("ipc,shm: shorten critical region for shmctl")
restructured the ipc shm to shorten critical region, but introduced a
path where the return value could be -EPERM, even if the operation
actually was performed.
Before the commit, the err return value was reset by the return value
from security_shm_shmctl() after the if (!ns_capable(...)) statement.
Now, we still exit the if statement with err set to -EPERM, and in the
case of SHM_UNLOCK, it is not reset at all, and used as the return value
from shmctl.
To fix this, we only set err when errors occur, leaving the fallthrough
case alone.
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: <stable@vger.kernel.org> [3.12.x]
Fengguang Wu reports that compiling mm/mempolicy.c results in a warning:
mm/mempolicy.c: In function 'mpol_to_str':
mm/mempolicy.c:2878:2: error: format not a string literal and no format arguments
Kees says this is because he is using -Wformat-security.
Silence the warning.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Suggested-by: Kees Cook <keescook@chromium.org>
Use ARRAY_SIZE instead of sizeof to get proper max for label length.
Since this is just a read out of bounds it's not that bad, but the
problem becomes user-visible eg if one tries to use DEBUG_PAGEALLOC and
DEBUG_RODATA, at least with some enhancements from Hiroshi. Of course
the destination array can contain garbage when we read beyond the end of
source array so that would be another user-visible problem.
Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com>
Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com>
Tested-by: Hiroshi Doyu <hdoyu@nvidia.com>
Cc: Will Drewry <wad@chromium.org>
Cc: Matt Fleming <matt.fleming@intel.com>
Acked-by: Davidlohr Bueso <davidlohr@hp.com>
Make sure RTC-interrupts are disabled at shutdown.
As the RTC is generally powered by backup power (VDDBU), its interrupts
are not disabled on wake-up, user, watchdog or software reset. This
could cause troubles on other systems (e.g. older kernels) if an
interrupt occurs before a handler has been installed at next boot.
Let us be well-behaved and disable them on clean shutdowns at least (as
do the RTT-based rtc-at91sam9 driver).
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Commit 7cb2ef56e6a8 ("mm: fix aio performance regression for database
caused by THP") can cause dereference of a dangling pointer if
split_huge_page runs during PageHuge() if there are updates to the
tail_page->private field.
Also it is repeating compound_head twice for hugetlbfs and it is running
compound_head+compound_trans_head for THP when a single one is needed in
both cases.
The new code within the PageSlab() check doesn't need to verify that the
THP page size is never bigger than the smallest hugetlbfs page size, to
avoid memory corruption.
A longstanding theoretical race condition was found while fixing the
above (see the change right after the skip_unlock label, that is
relevant for the compound_lock path too).
By re-establishing the _mapcount tail refcounting for all compound
pages, this also fixes the below problem:
echo 0 >/sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages
BUG: Bad page state in process bash pfn:59a01
page:ffffea000139b038 count:0 mapcount:10 mapping: (null) index:0x0
page flags: 0x1c00000000008000(tail)
Modules linked in:
CPU: 6 PID: 2018 Comm: bash Not tainted 3.12.0+ #25
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x55/0x76
bad_page+0xd5/0x130
free_pages_prepare+0x213/0x280
__free_pages+0x36/0x80
update_and_free_page+0xc1/0xd0
free_pool_huge_page+0xc2/0xe0
set_max_huge_pages.part.58+0x14c/0x220
nr_hugepages_store_common.isra.60+0xd0/0xf0
nr_hugepages_store+0x13/0x20
kobj_attr_store+0xf/0x20
sysfs_write_file+0x189/0x1e0
vfs_write+0xc5/0x1f0
SyS_write+0x55/0xb0
system_call_fastpath+0x16/0x1b
Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Khalid Aziz <khalid.aziz@oracle.com>
Cc: Pravin Shelar <pshelar@nicira.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Cc: Minchan Kim <minchan@kernel.org>
