2013-09-21iio:buffer_cb: Add missing iio_buffer_init()iio-fixes-for-3.12aLars-Peter Clausen
Make sure to properly initialize the IIO buffer data structure. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-21iio: Prevent race between IIO chardev opening and IIO device freeLars-Peter Clausen
Set the IIO device as the parent for the character device We need to make sure that the IIO device is not freed while the character device exists, otherwise the freeing of the IIO device might race against the file open callback. Do this by setting the character device's parent to the IIO device, this will cause the character device to grab a reference to the IIO device and only release it once the character device itself has been removed. Also move the registration of the character device before the registration of the IIO device to avoid the (rather theoretical case) that the IIO device is already freed again before we can add the character device and grab a reference to the IIO device. We also need to move the call to cdev_del() from iio_dev_release() to iio_device_unregister() (where it should have been in the first place anyway) to avoid a reference cycle. As iio_dev_release() is only called once all reference are dropped, but the character device holds a reference to the IIO device. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-21iio: fix: Keep a reference to the IIO device for open file descriptorsLars-Peter Clausen
Make sure that the IIO device is not freed while we still have file descriptors for it. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-21iio: Stop sampling when the device is removedLars-Peter Clausen
Make sure to stop sampling when the device is removed, otherwise it will continue to sample forever. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-21iio: Fix crash when scan_bytes is computed with active_scan_mask == NULLPeter Meerwald
if device has available_scan_masks set and the buffer is enabled without any scan_elements enabled, in a NULL pointer is dereferenced in iio_compute_scan_bytes() [ 18.993713] Unable to handle kernel NULL pointer dereference at virtual address 00000000 [ 19.002593] pgd = debd4000 [ 19.005432] [00000000] *pgd=9ebc0831, *pte=00000000, *ppte=00000000 [ 19.012329] Internal error: Oops: 17 [#1] PREEMPT ARM [ 19.017639] Modules linked in: [ 19.020843] CPU: 0 Not tainted (3.9.11-00036-g75c888a-dirty #207) [ 19.027587] PC is at _find_first_bit_le+0xc/0x2c [ 19.032440] LR is at iio_compute_scan_bytes+0x2c/0xf4 [ 19.037719] pc : [<c021dc60>] lr : [<c03198d0>] psr: 200d0013 [ 19.037719] sp : debd9ed0 ip : 00000000 fp : 000802bc [ 19.049713] r10: 00000000 r9 : 00000000 r8 : deb67250 [ 19.055206] r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : deb67000 [ 19.062011] r3 : de96ec00 r2 : 00000000 r1 : 00000004 r0 : 00000000 [ 19.068847] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 19.076324] Control: 10c5387d Table: 9ebd4019 DAC: 00000015 problem is the rollback code in iio_update_buffers(), old_mask may be NULL (e.g. on first call) I'm not too confident about the fix; works for me... Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Reviewed-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-21iio: Fix mcp4725 dev-to-indio_dev conversion in suspend/resumePeter Meerwald
dev_to_iio_dev() is a false friend Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-21iio: Fix bma180 dev-to-indio_dev conversion in suspend/resumePeter Meerwald
dev_to_iio_dev() is a false friend Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Cc: Oleksandr Kravchenko <o.v.kravchenko@globallogic.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-21iio: Fix tmp006 dev-to-indio_dev conversion in suspend/resumePeter Meerwald
2013-09-18iio: iio_device_add_event_sysfs() bugfixLukasz Czerwinski
Fix mask generation for modified channels. Signed-off-by: Lukasz Czerwinski <l.czerwinski@samsung.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-18staging: iio: ade7854-spi: Fix return valueSachin Kamat
ade7854_probe can fail. Return the value obtained from it instead of 0 (success). Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Barry Song <21cnbao@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-18staging:iio:hmc5843: Fix measurement conversionPeter Meerwald
recently broken, cd6fe06588423ff4cca85c85c4402027b04dccf1 staging:iio:hmc5843: Use i2c_smbus_read_word_swapped() Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-18iio: isl29018: Fix uninitialized valueDerek Basehore
The lux_uscale value is not initialized at probe. The value will be uninitialized unless a value is written to it through the iio channel interface. This fixes that. Signed-off-by: Derek Basehore <dbasehore@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/65998 Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-18staging:iio:dummy fix kfifo_buf kconfig dependency issue if kfifo modular ↵Jonathan Cameron
and buffer enabled for built in dummy driver. This only occurs in the unlikely event that the example driver is built in whilst the buffer implementation is not. Solved by switching from a depends on to a select for this particular case. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-18iio: at91: fix adc_clk overflowJosh Wu
The adc_clk variable is currently defined using a 32-bits unsigned integer, which will overflow under some very valid range of operations. Such overflow will occur if, for example, the parent clock is set to a 20MHz frequency and the ADC startup time is larger than 215ns. To fix this, introduce an intermediate variable holding the clock rate in kHz. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-17staging: line6: add bounds check in snd_toneport_source_put()Dan Carpenter
"source" comes from the user in snd_ctl_elem_write() so it needs to be checked. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Stefan Hajnoczi <stefanha@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17Staging: comedi: Fix dependencies for drivers misclassified as PCIBen Hutchings
The Fastwel UNIOxx-5 is a PC/104 board, so put COMEDI_UNIOXX5 under COMEDI_ISA_DRIVERS. The DIL/Net-PC 1486 is a 486 system, so put COMEDI_SSV_DNP under COMEDI_MISC_DRIVERS and add a dependency on X86_32 || COMPILE_TEST. Reviewed-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: r8188eu: Adjust RX gainLarry Finger
In some circumstances, the performance of this driver is highly degraded, and ifconfig reports large numbers of dropped packets. By increasing the maximum RX gain from 0x3e to 0x4e, performance is greatly improved. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: r8188eu: Fix smatch warning in core/rtw_ieee80211.Larry Finger
Smatch shows the following warning: drivers/staging/rtl8188eu/core/rtw_ieee80211.c:161 rtw_set_ie() info: ignoring unreachable code. The cause is a module exit tracing statement after a return. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: r8188eu: Fix smatch error in core/rtw_mlme_ext.cLarry Finger
Smatch reports the following warning: "drivers/staging/rtl8188eu/core/rtw_mlme_ext.c:8328 mlme_evt_hdl() error: buffer overflow 'wlanevents' 24 <= 24" 8321 /* checking if event code is valid */ 8322 if (evt_code >= MAX_C2HEVT) { ^^^^^^^^^^^^^^^^^^^^^^ 8323 RT_TRACE(_module_rtl871x_cmd_c_, _drv_err_, ("\nEvent Code(%d) mismatch!\n", evt_code)); 8324 goto _abort_event_; 8325 } 8326 8327 /* checking if event size match the event parm size */ 8328 if ((wlanevents[evt_code].parmsize != 0) && ^^^^^^^^^^^^^^^^^^^^ 8329 (wlanevents[evt_code].parmsize != evt_sz)) { 8330 RT_TRACE(_module_rtl871x_cmd_c_, _drv_err_, 8331 ("\nEvent(%d) Parm Size mismatch (%d vs %d)!\n", 8332 evt_code, wlanevents[evt_code].parmsize, evt_sz)); 8333 goto _abort_event_; 8334 } This warning results because the number of items in "enum rtw_c2h_event", which determines the value of MAX_C2HEVT, is one more than in "struct wlanevents". Adding an extra dummy event to the latter fixes the problem. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: r8188eu: Fix Smatch off-by-one warning in hal/rtl8188e_hal_init.cLarry Finger
Smatch reports the following warning: "drivers/staging/rtl8188eu/hal/rtl8188e_hal_init.c:2008 Hal_ReadPowerValueFromPROM_8188E() error: buffer overflow 'pwrInfo24G->IndexBW40_Base[rfPath]' 5 <= 5" drivers/staging/rtl8188eu/hal/rtl8188e_hal_init.c 2005 /* 2.4G default value */ 2006 for (group = 0; group < MAX_CHNL_GROUP_24G; group++) { 2007 pwrInfo24G->IndexCCK_Base[rfPath][group] = EEPROM_DEFAULT_24G_INDEX; 2008 pwrInfo24G->IndexBW40_Base[rfPath][group] = EEPROM_DEFAULT_24G_INDEX; The reason is that IndexCCK_Base[] has MAX_CHNL_GROUP_24G elements, but IndexBW40_Base is smaller by 1. Make them both have MAX_CHNL_GROUP_24G elements. Reported by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: Disable lustre file system for MIPS, SH, and XTENSAGuenter Roeck
mips allmodconfig fails with ERROR: "copy_from_user_page" [drivers/staging/lustre/lustre/libcfs/libcfs.ko] undefined! which is due to LUSTRE using copy_from_user_page which is not exported by any architecture. Unfortunately, LUSTRE can only be built as module, so there is no easy fix. MIPS, SH, and optionally XTENSA implement copy_from_user_page as unexported functions. Disable LUSTRE for those. Cc: Peng Tao <bergwolf@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17Revert "staging: zram: Add auto loading of module if user opens /dev/zram."Greg Kroah-Hartman
This reverts commit c70bda992c12e593e411c02a52e4bd6985407539. It's incorrect, Kay writes: Please just remove it. "devname" is meant to be used for single-instance devices with a static dev_t, never for things like zramX. It will not do anything useful here, it does nothing really without a statically assigned dev_t, and it should not be used for devices of this kind anyway. Reported-by: Tom Gundersen <teg@jklm.no> Reported-by: Kay Sievers <kay@vrfy.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: octeon-ethernet: rgmii: enable interrupts that we can handleAaro Koskinen
Enable only those interrupts that we can handle & acknowledge in the interrupt handler. At least on EdgeRouter Lite, the hardware may occasionally interrupt with some error condition when the physical link status changes frequently. Since the interrupt condition is not acked properly, this leads to the following warning and the IRQ gets disabled completely: [ 41.324700] eth0: Link down [ 44.324721] eth0: 1000 Mbps Full duplex, port 0, queue 0 [ 44.885590] irq 117: nobody cared (try booting with the "irqpoll" option) [ 44.892397] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.11.0-rc5-edge-los.git-27d042f-dirty-00950-gaa42f2d-dirty #8 [ 44.902825] Stack : ffffffff815c0000 0000000000000004 0000000000000003 0000000000000000 ffffffff81fd0000 ffffffff815c0000 0000000000000004 ffffffff8118530c ffffffff815c0000 ffffffff811858d8 0000000000000000 0000000000000000 ffffffff81fd0000 ffffffff81fc0000 ffffffff8152f3a0 ffffffff815b7bf7 ffffffff81fc6688 ffffffff815b8060 0000000000000000 0000000000000000 0000000000000000 ffffffff815346c8 ffffffff815346b0 ffffffff814a6a18 ffffffff8158b848 ffffffff81145614 ffffffff81593800 ffffffff81187174 ffffffff815b7d00 ffffffff8158b760 0000000000000000 ffffffff814a9184 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ffffffff811203b8 0000000000000000 0000000000000000 ... [ 44.968408] Call Trace: [ 44.970873] [<ffffffff811203b8>] show_stack+0x68/0x80 [ 44.975937] [<ffffffff814a9184>] dump_stack+0x78/0xb8 [ 44.980999] [<ffffffff811aac54>] __report_bad_irq+0x44/0x108 [ 44.986662] [<ffffffff811ab238>] note_interrupt+0x248/0x2a0 [ 44.992240] [<ffffffff811a85e4>] handle_irq_event_percpu+0x144/0x200 [ 44.998598] [<ffffffff811a86f4>] handle_irq_event+0x54/0x90 [ 45.004176] [<ffffffff811ab908>] handle_level_irq+0xd0/0x148 [ 45.009839] [<ffffffff811a7b04>] generic_handle_irq+0x34/0x50 [ 45.015589] [<ffffffff8111dae8>] do_IRQ+0x18/0x30 [ 45.020301] [<ffffffff8110486c>] plat_irq_dispatch+0x74/0xb8 [ 45.025958] [ 45.027451] handlers: [ 45.029731] [<ffffffff813fca10>] cvm_oct_rgmii_rml_interrupt [ 45.035397] Disabling IRQ #117 [ 45.038742] Port 0 receive error code 13, packet dropped [ 46.324719] eth0: Link down [ 48.324733] eth0: 1000 Mbps Full duplex, port 0, queue 0 Reported-by: "Jason A. Donenfeld" <Jason@zx2c4.com> Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: David Daney <david.daney@cavium.com> Acked-by: Jason A. Donenfeld <Jason@zx2c4.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: octeon-ethernet: remove skb alloc failure warningsAaro Koskinen
Remove skb allocation failure warnings. They will trigger a page allocation warning already. Also, one of the warnings was not ratelimited, causing the box to lock up under heavy traffic & low memory. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: David Daney <david.daney@cavium.com> Acked-by: Jason A. Donenfeld <Jason@zx2c4.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: octeon-ethernet: make dropped packets to consume NAPI budgetAaro Koskinen
We should count also dropped packets, otherwise the NAPI handler may end up running too long. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: Jason A. Donenfeld <Jason@zx2c4.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c: rename PTRS_PER_PAGEAndrew Morton
It duplicates the definition in arch/alpha/include/asm/pgtable.h and emits warnings. Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Peng Tao <tao.peng@emc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: dgnc: fix potential format string flawKees Cook
Make sure that format strings cannot leak into printk() calls from the msgbuf string. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: lustre: clean up format string usagesKees Cook
This fixes up the usage of snprintf, strncpy, and format strings in the call to kthread_run to avoid ever accidentally allowing a format string into the thread name. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: dgap: fix overflows and format stringsKees Cook
The boot message buffer could potentially overflow the stack and the heap. Additionally make sure format strings could not leak into printk() calls. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: xillybus: fix format string usageKees Cook
Makes sure format string cannot leak into device_create() call. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging: r8188eu: Fix uninitialized variable change_inxGeert Uytterhoeven
drivers/staging/rtl8188eu/core/rtw_wlan_util.c: In function ‘WMMOnAssocRsp’: drivers/staging/rtl8188eu/core/rtw_wlan_util.c:634: warning: ‘change_inx’ may be used uninitialized in this function And the compiler is right: change_inx should be initialized to false. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging/lustre: Correct default for LUSTRE_TRANSLATE_ERRNOSGeert Uytterhoeven
LUSTRE_TRANSLATE_ERRNOS is never enabled, a "true" is not a valid value. Use "default y" instead of "default true" to fix this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging/vt6656: Fix screwed up indentation in swGetOFDMControlRateDave Jones
The indentation in the swGetOFDMControlRate function is screwed up. At first it appears that there are missing braces on a multi-line if, but looking at history, commit dd0a774fc727ee793780197beb3f2cf80bfefa99 ("staging: vt6656: card/main_usb/device use new structure names") incorrectly indented the two lines below. Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17staging/rtl8188eu: pass channel list by reference instead of copying struct.Dave Jones
Signed-off-by: Dave Jones <davej@fedoraproject.org> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-16Linux 3.12-rc1v3.12-rc1Linus Torvalds
2013-09-16Merge branch 'timers/core' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer code update from Thomas Gleixner: - armada SoC clocksource overhaul with a trivial merge conflict - Minor improvements to various SoC clocksource drivers * 'timers/core' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clocksource: armada-370-xp: Add detailed clock requirements in devicetree binding clocksource: armada-370-xp: Get reference fixed-clock by name clocksource: armada-370-xp: Replace WARN_ON with BUG_ON clocksource: armada-370-xp: Fix device-tree binding clocksource: armada-370-xp: Introduce new compatibles clocksource: armada-370-xp: Use CLOCKSOURCE_OF_DECLARE clocksource: armada-370-xp: Simplify TIMER_CTRL register access clocksource: armada-370-xp: Use BIT() ARM: timer-sp: Set dynamic irq affinity ARM: nomadik: add dynamic irq flag to the timer clocksource: sh_cmt: 32-bit control register support clocksource: em_sti: Convert to devm_* managed helpers
2013-09-16Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Two minor cifs fixes and a minor documentation cleanup for cifs.txt" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: cifs: update cifs.txt and remove some outdated infos cifs: Avoid calling unlock_page() twice in cifs_readpage() when using fscache cifs: Do not take a reference to the page in cifs_readpage_worker()
2013-09-16Merge tag 'upstream-3.12-rc1' of git://git.infradead.org/linux-ubiLinus Torvalds
Pull UBI fixes from Artem Bityutskiy: "Just a single fastmap fix plus a regression fix" * tag 'upstream-3.12-rc1' of git://git.infradead.org/linux-ubi: UBI: Fix invalidate_fastmap() UBI: Fix PEB leak in wear_leveling_worker()
2013-09-16Merge tag 'upstream-3.12-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull ubifs fix from Artem Bityutskiy: "Just one patch which fixes the power-cut recovery testing mode. I'll start using a single UBI/UBIFS tree instead of 2 trees from now on. So in the future you'll get 1 small pull request instead of 2 tiny ones" * tag 'upstream-3.12-rc1' of git://git.infradead.org/linux-ubifs: UBIFS: remove invalid warn msg with tst_recovery enabled
2013-09-15Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "These are four patches for three construction sites: - Fix register decoding for the combination of multi-core processors and multi-threading. - Two more fixes that are part of the ongoing DECstation resurrection work. One of these touches a DECstation-only network driver. - Finally Markos' trivial build fix for the AP/SP support. (With this applied now all MIPS defconfigs are building again)" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: kernel: vpe: Make vpe_attrs an array of pointers. MIPS: Fix SMP core calculations when using MT support. MIPS: DECstation I/O ASIC DMA interrupt handling fix MIPS: DECstation HRT initialization rearrangement
2013-09-15Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform updates from Matthew Garrett: "Nothing amazing here, almost entirely cleanups and minor bugfixes and one bit of hardware enablement in the amilo-rfkill driver" * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: platform/x86: panasonic-laptop: reuse module_acpi_driver samsung-laptop: fix config build error platform: x86: remove unnecessary platform_set_drvdata() amilo-rfkill: Enable using amilo-rfkill with the FSC Amilo L1310. wmi: parse_wdg() should return kernel error codes hp_wmi: Fix unregister order in hp_wmi_rfkill_setup() platform: replace strict_strto*() with kstrto*() x86: irst: use module_acpi_driver to simplify the code x86: smartconnect: use module_acpi_driver to simplify the code platform samsung-q10: use ACPI instead of direct EC calls thinkpad_acpi: add the ability setting TPACPI_LED_NONE by quirk thinkpad_acpi: return -NODEV while operating uninitialized LEDs
2013-09-15Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull misc SCSI driver updates from James Bottomley: "This patch set is a set of driver updates (megaraid_sas, fnic, lpfc, ufs, hpsa) we also have a couple of bug fixes (sd out of bounds and ibmvfc error handling) and the first round of esas2r checker fixes and finally the much anticipated big endian additions for megaraid_sas" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (47 commits) [SCSI] fnic: fnic Driver Tuneables Exposed through CLI [SCSI] fnic: Kernel panic while running sh/nosh with max lun cfg [SCSI] fnic: Hitting BUG_ON(io_req->abts_done) in fnic_rport_exch_reset [SCSI] fnic: Remove QUEUE_FULL handling code [SCSI] fnic: On system with >1.1TB RAM, VIC fails multipath after boot up [SCSI] fnic: FC stat param seconds_since_last_reset not getting updated [SCSI] sd: Fix potential out-of-bounds access [SCSI] lpfc 8.3.42: Update lpfc version to driver version 8.3.42 [SCSI] lpfc 8.3.42: Fixed issue of task management commands having a fixed timeout [SCSI] lpfc 8.3.42: Fixed inconsistent spin lock usage. [SCSI] lpfc 8.3.42: Fix driver's abort loop functionality to skip IOs already getting aborted [SCSI] lpfc 8.3.42: Fixed failure to allocate SCSI buffer on PPC64 platform for SLI4 devices [SCSI] lpfc 8.3.42: Fix WARN_ON when driver unloads [SCSI] lpfc 8.3.42: Avoided making pci bar ioremap call during dual-chute WQ/RQ pci bar selection [SCSI] lpfc 8.3.42: Fixed driver iocbq structure's iocb_flag field running out of space [SCSI] lpfc 8.3.42: Fix crash on driver load due to cpu affinity logic [SCSI] lpfc 8.3.42: Fixed logging format of setting driver sysfs attributes hard to interpret [SCSI] lpfc 8.3.42: Fixed back to back RSCNs discovery failure. [SCSI] lpfc 8.3.42: Fixed race condition between BSG I/O dispatch and timeout handling [SCSI] lpfc 8.3.42: Fixed function mode field defined too small for not recognizing dual-chute mode ...
2013-09-15Merge branch 'slab/next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux Pull SLAB update from Pekka Enberg: "Nothing terribly exciting here apart from Christoph's kmalloc unification patches that brings sl[aou]b implementations closer to each other" * 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: slab: Use correct GFP_DMA constant slub: remove verify_mem_not_deleted() mm/sl[aou]b: Move kmallocXXX functions to common code mm, slab_common: add 'unlikely' to size check of kmalloc_slab() mm/slub.c: beautify code for removing redundancy 'break' statement. slub: Remove unnecessary page NULL check slub: don't use cpu partial pages on UP mm/slub: beautify code for 80 column limitation and tab alignment mm/slub: remove 'per_cpu' which is useless variable
2013-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input update from Dmitry Torokhov: "The only change is David Hermann's new EVIOCREVOKE evdev ioctl that allows safely passing file descriptors to input devices to session processes and later being able to stop delivery of events through these fds so that inactive sessions will no longer receive user input that does not belong to them" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: evdev - add EVIOCREVOKE ioctl
2013-09-15vfs: fix typo in comment in recent dentry workLinus Torvalds
Sedat points out that I transposed some letters in "LRU" and wrote "RLU" instead in one of the new comments explaining the flow. Let's just fix it. Reported-by: Sedat Dilek <sedat.dilek@jpberlin.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-15partitions/efi: loosen check fot pmbr size in lbaDavidlohr Bueso
Matt found that commit 27a7c642174e ("partitions/efi: account for pmbr size in lba") caused his GPT formatted eMMC device not to boot. The reason is that this commit enforced Linux to always check the lesser of the whole disk or 2Tib for the pMBR size in LBA. While most disk partitioning tools out there create a pMBR with these characteristics, Microsoft does not, as it always sets the entry to the maximum 32-bit limitation - even though a drive may be smaller than that[1]. Loosen this check and only verify that the size is either the whole disk or 0xFFFFFFFF. No tool in its right mind would set it to any value other than these. [1] http://thestarman.pcministry.com/asm/mbr/GPT.htm#GPTPT Reported-and-tested-by: Matt Porter <matt.porter@linaro.org> Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-13Merge tag 'writeback-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux Pull writeback fix from Wu Fengguang: "A trivial writeback fix" * tag 'writeback-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: Do not sort b_io list only because of block device inode
2013-09-13vfs: fix dentry LRU list handling and nr_dentry_unused accountingLinus Torvalds
The LRU list changes interacted badly with our nr_dentry_unused accounting, and even worse with the new DCACHE_LRU_LIST bit logic. This introduces helper functions to make sure everything follows the proper dcache d_lru list rules: the dentry cache is complicated by the fact that some of the hotpaths don't even want to look at the LRU list at all, and the fact that we use the same list entry in the dentry for both the LRU list and for our temporary shrinking lists when removing things from the LRU. The helper functions temporarily have some extra sanity checking for the flag bits that have to match the current LRU state of the dentry. We'll remove that before the final 3.12 release, but considering how easy it is to get wrong, this first cleanup version has some very particular sanity checking. Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-13cifs: update cifs.txt and remove some outdated infosBjörn Jacke
Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Björn JACKE <bj@sernet.de> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-13cifs: Avoid calling unlock_page() twice in cifs_readpage() when using fscacheSachin Prabhu
When reading a single page with cifs_readpage(), we make a call to fscache_read_or_alloc_page() which once done, asynchronously calls the completion function cifs_readpage_from_fscache_complete(). This completion function unlocks the page once it has been populated from cache. The module then attempts to unlock the page a second time in cifs_readpage() which leads to warning messages. In case of a successful call to fscache_read_or_alloc_page() we should skip the second unlock_page() since this will be called by the cifs_readpage_from_fscache_complete() once the page has been populated by fscache. With the modifications to cifs_readpage_worker(), we will need to re-grab the page lock in cifs_write_begin(). The problem was first noticed when testing new fscache patches for cifs. https://bugzilla.redhat.com/show_bug.cgi?id=1005737 Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
