Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
fix compile warning reported by Fengguang Wu:
drivers/iio/light/adjd_s311.c: In function 'adjd_s311_trigger_handler':
drivers/iio/light/adjd_s311.c:188:12: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
drivers/iio/light/adjd_s311.c:188:4: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
185 }
186
187 if (indio_dev->scan_timestamp)
> 188 *(s64 *)((phys_addr_t)data->buffer + ALIGN(len, sizeof(s64)))
189 = time_ns;
190 iio_push_to_buffer(buffer, (u8 *)data->buffer, time_ns);
191
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
The data parameters for request_irq and free_irq have to match, otherwise the
IRQ wont be freed.
The issue has been discovered using the following coccinelle patch:
// <smpl>
@r1@
type T;
T data;
request_irq(..., (void *)data)
request_irq(..., data)
request_threaded_irq(..., (void *)data)
request_threaded_irq(..., data)
@r2@
type r1.T;
T data;
position p;
free_irq@p(..., (void *)data)
free_irq@p(..., data)
@depends on r1@
position p != r2.p;
*free_irq@p(...)
// </smpl>
Cc: Jon Brenner <jbrenner@taosinc.com>
IRQ wont be freed.
// <smpl>
@r1@
type T;
T data;
@r2@
type r1.T;
T data;
position p;
@depends on r1@
position p != r2.p;
*free_irq@p(...)
// </smpl>
Cc: Roland Stigge <stigge@antcom.de>
In probe the I2C client data is set to the iio_dev struct in probe(), but
assumed to be the tsl2X7X_chip struct in remove(). Fix this by reading the
client data back as iio_dev as well.
// <smpl>
@r1@
type T;
T data;
expression dev;
i2c_set_clientdata(dev, (void *)data)
i2c_set_clientdata(dev, data)
@r2@
type r1.T;
T data;
position p;
expression dev;
data = i2c_get_clientdata@p(dev)
@depends on r1@
position p != r2.p;
expression dev;
identifier data;
*data = i2c_get_clientdata@p(dev)
// </smpl>
The SPI drvdata is set to adis16260_state struct in probe(), but assumed to be
the iio_dev struct in remove(). Fix this by setting it to the iio_dev in
probe().
// <smpl>
@r1@
type T;
T data;
expression dev;
spi_set_drvdata(dev, (void *)data)
spi_set_drvdata(dev, data)
@r2@
type r1.T;
T data;
position p;
expression dev;
data = spi_get_drvdata@p(dev)
@depends on r1@
position p != r2.p;
expression dev;
identifier data;
*data = spi_get_drvdata@p(dev)
// </smpl>
This macro uses the 'devpriv' macro which relies on a local variable
having a specific name. Plus it's just a wrapper around a simple
'readw'. Remove the macro.
Cc: Ian Abbott <abbotti@mev.co.uk>
having a specific name. It's also not used. Remove the macro.
'writeb'. Remove the macro.
'writel'. Remove the macro.
'readl'. Remove the macro.
'writew'. Remove the macro.
having a specific name. It's also not used and the comment says it
does not work. Remove it.
having a specific name. It's also not used. Remove it.
