2014-10-02gpio: pch: Build context save/restore only for PMgpio-v3.18-1Thierry Reding
The pch_gpio_save_reg_conf() and pch_gpio_restore_reg_conf() functions are only used in pch_gpio_suspend() and pch_gpio_resume(), respectively. Since the latter are only built if PM is enabled, make the former build under the same conditions. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-02pinctrl: abx500: get rid of unused variableLinus Walleij
commit 2fcea6cecbc965b4e02a39537d9d939f5251bbbd "pinctrl: remove remaining users of gpiochip_remove() retval" removed the use of the return value from gpiochip_remove() but missed to delete the dangling "err" variable: drivers/pinctrl/nomadik/pinctrl-abx500.c: In function 'abx500_gpio_probe': drivers/pinctrl/nomadik/pinctrl-abx500.c:1208:11: warning: unused variable 'err' [-Wunused-variable] Fix this by getting rid of the dangling variable. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-02gpio: ks8695: fix 'else should follow close brace '}''Varka Bhadram
Signed-off-by: Varka Bhadram <varkab@cdac.in> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-02gpio: stmpe: add verbose debug codeLinus Walleij
To troubleshoot the STMPE GPIO driver, some more detailed debug information giving the exact info on how each pin is used will be helpful. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-02gpio: stmpe: fix up interrupt enable logicLinus Walleij
The STMPE driver assumes that the passed in IRQ type is for rising or falling IRQs, not both, even though the hardware actually supports this perfectly well. Likewise the check for level IRQs is done against just high or low level types, not for the case where it is combined with other IRQs. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-30gpio: staticize xway_stp_init()Linus Walleij
This initcall is only called from the driver itself, staticize it. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-26gpio: handle also nested irqchips in the chained handler set-upLinus Walleij
To unify how we connect cascaded IRQ chips to parent IRQs, if NULL us passed as handler to the gpiochip_set_chained_irqchip() function, assume the chips is nested rather than chained, and we still get the parent set up correctly by way of this function call. Alter the drivers for tc3589x and stmpe to use this to set up their chained handlers as a demonstration of the usage. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-26gpio: set parent irq on chained handlersLinus Walleij
If the IRQ from the parent is nested the IRQ may need to be resent under certain conditions. Currently the chained IRQ handler in gpiolib does not handle connecting nested IRQs but it is conceptually correct to indicate the actual parent IRQ. Reported-by: Grygorii Strashko <grygorii.strashko@ti.com> Reported-by: Lothar Waßmann <LW@karo-electronics.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-26gpiolib: irqchip: use irq_find_mapping while removing irqchipGrygorii Strashko
There is no guarantee that VIRQs will be allocated sequentially for gpio irqchip in gpiochip_irqchip_add(). Therefore, it's unsafe to dispose VIRQ in gpiochip_irqchip_remove() basing on index relatively to stored irq_base value. Hence, use irq_find_mapping for VIRQ finding in gpiochip_irqchip_remove() instead of irq_base + index. Reported-by: Wang, Yalin <Yalin.Wang@sonymobile.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-25gpio: crystalcove: support virtual GPIOAaron Lu
The virtual GPIO introduced in ACPI table of Baytrail-T based system is used to solve a problem under Windows. We do not have such problems under Linux so we do not actually need them. But we have to tell GPIO library that the Crystal Cove GPIO chip has this many GPIO pins or the common GPIO handler will refuse any access to those high number GPIO pins, which will resulted in a failure evaluation of every ACPI control method that is used to turn on/off power resource and/or report sensor temperatures. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> [changed vgpio number from 0x5e to 94] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-25pinctrl: bcm281xx: make Kconfig dependency more strictUwe Kleine-König
This driver is only useful on BCM281xx, so let the driver depend on ARCH_BCM_MOBILE but allow compile coverage testing. The main benefit is that the driver isn't available to be selected for machines that don't have the matching hardware. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Reviewed-by: Sherman Yin <syin@broadcom.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-25gpio: kona: enable only on BCM_MOBILE or for compile testingUwe Kleine-König
This change makes it easier to configure a kernel for a real machine by not showing the option to enable it at all if COMPILE_TEST is off. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Markus Mayer <mmayer@broadcom.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-24gpio, bcm-kona, LLVMLinux: Remove use of __initconstBehan Webster
The __initconst is in the wrong place, and when moved to the correct place it uncovers an error where the variable is used by non-init data structures. Instead merely make them const and put the const in the right spot. Signed-off-by: Behan Webster <behanw@converseincode.com> Reviewed-by: Mark Charlebois <charlebm@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Matt Porter <mporter@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-24gpio: Fix ngpio in gpio-xilinx driverGernot Vormayr
If one adds gpio-controller; to the chip in the devicetree, then initialization fails with 'gpiochip_find_base: cannot find free range', because ngpio is 0. This patch fixes the bug. This version includes the suggestions from Linus Walleij. Tested on ml507 board. Signed-off-by: Gernot Vormayr <gvormayr@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-24gpio: dwapb: fix pointer to integer castLinus Walleij
The statements BUG_ON(ctx == 0) was implicitly casting a pointer to an integer for comparison. Do this with a bool test instead to get away from sparse warnings. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-24gpio: xgene: Remove unneeded #ifdef CONFIG_OF guardAxel Lin
This driver depends on OF_GPIO, so it won't be built if !CONFIG_OF. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-24gpio: xgene: Remove unneeded forward declation for struct xgene_gpioAxel Lin
2014-09-24gpio: xgene: Fix missing spin_lock_init()Axel Lin
2014-09-24gpio: ks8695: fix switch case indentationVarka Bhadram
2014-09-24gpiolib: add irq_not_threaded flag to gpio_chipOctavian Purdila
Some GPIO chips (e.g. the DLN2 USB adapter) have blocking get/set operation but do not need a threaded irq handler. Signed-off-by: Octavian Purdila <octavian.purdila@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-24gpio: Fix return value check in xgene_gpio_probe()Wei Yongjun
In case of error, the function devm_ioremap_nocache() returns NULL pointer not ERR_PTR(). The IS_ERR() test in the return value check should be replaced with NULL test. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23GPIO: gpiolib: trivial: Add missing carriage returnAlexander Shiyan
Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23gpio: omap: Fix interrupt namesNishanth Menon
When viewing the /proc/interrupts, there is no information about which GPIO bank a specific gpio interrupt is hooked on to. This is more than a bit irritating as such information can esily be provided back to the user and at times, can be crucial for debug. So, instead of displaying something like: 31: 0 0 GPIO 0 palmas 32: 0 0 GPIO 27 mmc0 Display the following with appropriate device name: 31: 0 0 4ae10000.gpio 0 palmas 32: 0 0 4805d000.gpio 27 mmc0 This requires that we create irq_chip instance specific for each GPIO bank which is trivial to achieve. Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Kevin Hilman <khilman@linaro.org> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23gpio: samsung: Remove remaining check for CONFIG_S5P_GPIO_DRVSTRPaul Bolle
Commit d78c16ccde96 ("ARM: SAMSUNG: Remove remaining legacy code") removed the Kconfig symbol S5P_GPIO_DRVSTR. It didn't remove one check for the related macro. Remove that check and the dead code it hides. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Reviewed-by: Tomasz Figa <tomasz.figa@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23gpio: Increase ARCH_NR_GPIOs to 512Mika Westerberg
Some newer Intel SoCs, like Braswell already have more than 256 GPIOs available so the default limit is exceeded. Instead of adding more architecture specific gpio.h files with custom ARCH_NR_GPIOs we increase the gpiolib default limit to be twice the current. Current generic ARCH_NR_GPIOS limit is 256 which starts to be too small for newer Intel SoCs like Braswell. In order to support GPIO controllers on these SoCs we increase ARCH_NR_GPIOS to be 512 which should be sufficient for now. The kernel size increases a bit with this change. Below is an example of x86_64 kernel image. ARCH_NR_GPIOS=256 text data bss dec hex filename 11476173 1971328 1265664 14713165 e0814d vmlinux ARCH_NR_GPIOS=512 text data bss dec hex filename 11476173 1971328 1269760 14717261 e0914d vmlinux So the BSS size and this the kernel image size increases by 4k. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23gpio: use container_of to resolve cs5535_gpio_chip from gpio_chipFabian Frederick
Use container_of instead of casting first structure member. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23GPIO: gpio-dwapb: Suspend & Resume PM enablingWeike Chen
This patch enables suspend and resume mode for the power management, and it is based on Josef Ahmad's previous work. Reviewed-by: Hock Leong Kweh <hock.leong.kweh@intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@intel.com> Signed-off-by: Weike Chen <alvin.chen@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23GPIO: gpio-dwapb: Support DebounceWeike Chen
This patch enables 'debounce' for the designware GPIO, and it is based on Josef Ahmad's previous work. Reviewed-by: Hock Leong Kweh <hock.leong.kweh@intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Weike Chen <alvin.chen@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23GPIO: gpio-dwapb: Change readl&writel to dwapb_read&dwapb_writeWeike Chen
This patch replaces 'readl&writel' with 'dwapb_read&dwapb_write'. Reviewed-by: Shevchenko, Andriy <andriy.shevchenko@intel.com> Signed-off-by: Weike Chen <alvin.chen@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23GPIO: gpio-dwapb: Enable platform driver binding to MFD driverWeike Chen
The Synopsys DesignWare APB GPIO driver only supports open firmware devices. But, like Intel Quark X1000 SOC, which has a single PCI function exporting a GPIO and an I2C controller, it is a Multifunction device. This patch is to enable the current Synopsys DesignWare APB GPIO driver to support the Multifunction device which exports the designware GPIO controller. Reviewed-by: Hock Leong Kweh <hock.leong.kweh@intel.com> Signed-off-by: Weike Chen <alvin.chen@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23gpio: gpiolib: set gpiochip_remove retval to voidabdoulaye berthe
This avoids handling gpiochip remove error in device remove handler. Signed-off-by: Abdoulaye Berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23tty: sc16is7xx: remove retval from gpiochip_remove()Linus Walleij
We are trying to smoke out the use of the return value from gpiochip_remove() from the kernel, this has been missed. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23gpio: remove remaining users of gpiochip_remove() retvalLinus Walleij
Some drivers accidentally still use the return value from gpiochip_remove(). Get rid of them so we can simplify this function and get rid of the return value. Cc: Abdoulaye Berthe <berthe.ab@gmail.com> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Javier Martinez Canillas <javier@dowhile0.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23pinctrl: remove remaining users of gpiochip_remove() retvalLinus Walleij
Some drivers accidentally still use the return value from gpiochip_remove(). Get rid of them so we can simplify this function and get rid of the return value. Cc: Abdoulaye Berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-18driver:gpio remove all usage of gpio_remove retval in driverabdoulaye berthe
this remove all reference to gpio_remove retval in all driver except pinctrl and gpio. the same thing is done for gpio and pinctrl in two different patches. Signed-off-by: Abdoulaye Berthe <berthe.ab@gmail.com> Acked-by: Michael Büsch <m@bues.ch> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-16gpio: syscon: reuse for keystone 2 socsGrygorii Strashko
On Keystone SOCs, ARM host can send interrupts to DSP cores using the DSP GPIO controller IP. Each DSP GPIO controller provides 28 IRQ signals for each DSP core. This is one of the component used by the IPC mechanism used on Keystone SOCs. Keystone 2 DSP GPIO controller has specific features: - each GPIO can be configured only as output pin; - setting GPIO value to 1 causes IRQ generation on target DSP core; - reading pin value returns 0 - if IRQ was handled or 1 - IRQ is still pending. This patch updates gpio-syscon driver to be reused by Keystone 2 SoCs, because the Keystone 2 DSP GPIO controller is controlled through Syscon devices and, as requested by Linus Walleij, such kind of GPIO controllers should be integrated with drivers/gpio/gpio-syscon.c driver. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-16gpio: syscon: retrive syscon node and regs offsets from dtGrygorii Strashko
This patch adds handling of new "gpio,syscon-dev" DT property, which allows to specify syscon node and data/direction registers offsets in DT. "gpio,syscon-dev" has following format: gpio,syscon-dev = <&syscon_dev data_reg_offset [direction_reg_offset]>; where - syscon_dev - phandle on syscon node - data_reg_offset - offset of data register (in bytes) - direction_reg_offset - offset of dirrection register (optional, in bytes) for example: gpio,syscon-dev = <&devctrl 0x254>; In such way, the support of multiple Syscon GPIO devices is added. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-16gpio: syscon: add soc specific callback to assign output valueGrygorii Strashko
Some SoCs (like Keystone) may require to perform special sequence of operations to assign output GPIO value, so default implementation of .set() callback from gpio-syscon driver can't be used. Hence, add optional, SoC specific callback to assign output gpio value. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-04gpio: mcp23s08 to support both device tree and platform dataSonic Zhang
Device tree is not enabled in some architecture where gpio driver mcp23s08 is still required. v2-changes: - Parse device tree properties into platform data other than individual variables. v3-changes: - Use of_node in gpio_chip device structure, because the struct device * always has an of_node which is NULL when OF is not used. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-04gpio: zynq: Fixed broken wakeup implementationEzra Savard
Use of unmask/mask in set_wake was an incorrect implementation. The new implementation correctly sets wakeup for the gpio chip's IRQ so the gpio chip will not sleep while wakeup-enabled gpio are in use. Signed-off-by: Ezra Savard <ezra.savard@xilinx.com> Reviewed-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-04gpio: zynq: Mask non-wakeup GPIO interrupts on suspendEzra Savard
Added flag to the GPIO chip so that IRQ from non-wakeup GPIO will not wake the system. Signed-off-by: Ezra Savard <ezra.savard@xilinx.com> Reviewed-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-03gpio: zynq: Take bank offset into account when reporting a IRQLars-Peter Clausen
When looking up the IRQ the bank offset needs to be taken into account. Otherwise interrupts for banks other than bank 0 get incorrectly reported as interrupts for bank 0. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-02gpio: adnp: switch to use irqchip helpersLinus Walleij
This switches the ADNP GPIO driver to use the gpiolib irqchip helpers. Also do some random refactoring to make it look like most other GPIO drivers. Cc: Roland Stigge <stigge@antcom.de> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-08-29gpio: change gpiochip_request_own_desc() prototypeAlexandre Courbot
The current prototype of gpiochip_request_own_desc() requires to obtain a pointer to a descriptor. This is in contradiction to all other GPIO request schemes, and imposes an extra step of obtaining a descriptor to drivers. Most drivers actually cannot even perform that step since the function that does it (gpichip_get_desc()) is gpiolib-private. Change gpiochip_request_own_desc() to return a descriptor from a (chip, hwnum) tuple and update users of this function (currently gpiolib-acpi only). Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-08-29gpio: acpi: normalize use of gpiochip_get_desc()Alexandre Courbot
GPIO descriptors are changing from unique and permanent tokens to allocated resources. Therefore gpiochip_get_desc() cannot be used as a way to obtain a global GPIO descriptor anymore. This patch updates the gpiolib ACPI support code to keep and use the descriptor returned by a centralized call to gpiochip_get_desc(). Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-08-29gpio: zynq: Reduce level of indention in zynq_gpio_irqhandler()Lars-Peter Clausen
zynq_gpio_irqhandler() uses up to 7 tabs of indention in some parts. Refactor things to use a helper function for the inner loop to reduce the indention to a sane level. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-08-29gpio: pxa: Documentation: provide example bindings for PXA3xxDaniel Mack
Add another example to describe bindings that work for PXA3xx boards. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-08-29gpio: zynq: Remove .owner field for driverMichal Simek
There is no need to init .owner field. Based on the patch from Peter Griffin <peter.griffin@linaro.org> "mmc: remove .owner field for drivers using module_platform_driver" This patch removes the superflous .owner field for drivers which use the module_platform_driver API, as this is overriden in platform_driver_register anyway." Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-08-28Documentation: gpio: Add APM X-Gene SoC GPIO controller DTS bindingFeng Kan
Documentation for APM X-Gene SoC GPIO controller DTS binding. Signed-off-by: Feng Kan <fkan@apm.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-08-28gpio: Add APM X-Gene SoC GPIO controller supportFeng Kan
Add APM X-Gene SoC gpio controller driver. Signed-off-by: Feng Kan <fkan@apm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
