2014-05-29gpio: select IRQ_DOMAIN for gpiolib irqchip helpersgpio-v3.16-1Linus Walleij
These helpers depend on the IRQ_DOMAIN so select it explicitly, as it will not be present on all platforms such as Intel desktops and laptops using Intel-MID. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-28gpio: pca953x: use gpiolib irqchip helpersLinus Walleij
This switches the PCA953x driver over to using the gpiolib irqchip helpers to handle the threaded interrups cascaded off this GPIO chip. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-28gpio: pcf857x: Add IRQF_SHARED when request irqGeorge Cherian
It's quite possible that multiple pcf857x can be hooked up to the same interrupt line with the processor. So add IRQF_SHARED in request irq.. Signed-off-by: George Cherian <george.cherian@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-28gpio: pcf857x: Avoid calling irq_domain_cleanup twiceGeorge Cherian
Currently irq_domain_cleanup is called twice if irq_domain_init fails. This causes the following crash. Unable to handle kernel paging request at virtual address 00100104 pgd = c0004000 [00100104] *pgd=00000000 Internal error: Oops: 805 [#1] SMP ARM Modules linked in: CPU: 0 PID: 6 Comm: kworker/u4:0 Not tainted 3.12.15-01889-gedd10a8-dirty #4 Workqueue: deferwq deferred_probe_work_func task: ed0ee800 ti: ed116000 task.ti: ed116000 PC is at irq_domain_remove+0x3c/0x8c LR is at 0x0 pc : [<c0089734>] lr : [<00000000>] psr: a0000013 sp : ed117b50 ip : 00100100 fp : ed117b64 r10: ed5d1a04 r9 : 00000008 r8 : 00000000 r7 : ffffffea r6 : ed5d1a20 r5 : ed5d1a00 r4 : ed5e7540 r3 : 00200200 r2 : 00100100 r1 : c08aa180 r0 : 00200200 Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c53c7d Table: 8000406a DAC: 00000017 Process kworker/u4:0 (pid: 6, stack limit = 0xed116248) Stack: (0xed117b50 to 0xed118000) 7b40: 0000016b ed5d5f10 ed117b74 ed117b68 7b60: c02c8910 c0089704 ed117bb4 ed117b78 c02c8e14 c02c8900 ed5d1a04 ed5d4e80 ... <snip> ... fe0: 00000000 00000000 00000000 00000000 00000013 00000000 384a13ea 1590210a Backtrace: [<c00896f8>] (irq_domain_remove+0x0/0x8c) from [<c02c8910>] (pcf857x_irq_domain_cleanup+0x1c/0x20) r4:ed5d5f10 r3:0000016b [<c02c88f4>] (pcf857x_irq_domain_cleanup+0x0/0x20) from [<c02c8e14>] (pcf857x_probe+0x2a8/0x364) [<c02c8b6c>] (pcf857x_probe+0x0/0x364) from [<c04787ac>] (i2c_device_probe+0x80/0xc0) [<c047872c>] (i2c_device_probe+0x0/0xc0) from [<c036c33c>] (driver_probe_device+0x104/0x240) r6:00000000 r5:ed5d1a20 r4:c08c709c r3:c047872c [<c036c238>] (driver_probe_device+0x0/0x240) from [<c036c558>] (__device_attach+0x48/0x4c) r7:ed4fc480 r6:c036c510 r5:ed5d1a20 r4:c0866bb8 [<c036c510>] (__device_attach+0x0/0x4c) from [<c036a6d8>] (bus_for_each_drv+0x4c/0x94) r5:ed5d1a20 r4:00000000 [<c036a68c>] (bus_for_each_drv+0x0/0x94) from [<c036c1f4>] (device_attach+0x78/0x90) r6:c087fe50 r5:ed5d1a54 r4:ed5d1a20 [<c036c17c>] (device_attach+0x0/0x90) from [<c036b76c>] (bus_probe_device+0x8c/0xb4) r6:c087fe50 r5:ed5d1a20 r4:ed5d1a20 r3:ed17e1c0 [<c036b6e0>] (bus_probe_device+0x0/0xb4) from [<c0369888>] (device_add+0x34c/0x624) r6:ed5d1a28 r5:00000000 r4:ed5d1a20 r3:fffffffe [<c036953c>] (device_add+0x0/0x624) from [<c0369b7c>] (device_register+0x1c/0x20) ... <snip> ... [<c0060844>] (process_one_work+0x0/0x37c) from [<c0061040>] (worker_thread+0x13c/0x3c4) [<c0060f04>] (worker_thread+0x0/0x3c4) from [<c00670ec>] (kthread+0xac/0xb8) [<c0067040>] (kthread+0x0/0xb8) from [<c00148b8>] (ret_from_fork+0x14/0x3c) r7:00000000 r6:00000000 r5:c0067040 r4:ed105d20 Code: e59fc04c e591e000 e59f0048 e154000e (e5823004) ---[ end trace 59dd1e90032c4217 ]--- Signed-off-by: George Cherian <george.cherian@ti.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-28gpio: mcp23s08: switch chip count to intLinus Walleij
Commit 3e3bed913e8bbd78f38cefd5d575475f45c05dd0 "gpio: mcp23s08: fixed count variable for devicetree probing" introduced a loop check to see if the number of chips were unconsistent and going below zero counting downwards, but this requires the counting variable to be able to be negative, so switch the variable from unsigned to int. Cc: Michael Stickel <ms@mycable.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-27gpio: dwapb: use a second irq chipSebastian Andrzej Siewior
Right new have one irq chip running always in level mode. It would nicer to have two irq chips where one is handling level type interrupts and the other one is doing edge interrupts. So we can have at runtime two users where one is using edge and the other level. Acked-by: Alan Tull <delicious.quinoa@gmail.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-27gpio: ep93xx: Use devm_ioremap_resource()Jingoo Han
Use devm_ioremap_resource() because devm_request_and_ioremap() is obsoleted by devm_ioremap_resource(). Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-27gpio: mcp23s08: fixed count variable for devicetree probingMichael Stickel
Fixed missing increase of count variable for devicetree path in driver probing. The gpio-mcp23s08 driver has two paths for getting the platform registration information. One for the classic platform initialization and one for openfirmware devicetree based initialization. The devicetree based path is missing the increase of the count variable, which results in the count variable to become negative in the later use, where it is decreased. The count variable is used as an index into a vector. This results in accessing invalid memory space and can result in an exception. Tested this with an AM3352 SoC with two mcp23s17 on two chip selects as well as on a shared chip select. Signed-off-by: Michael Stickel <ms@mycable.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-27gpio: Add run-time dependencies to R-Car driverJean Delvare
The Renesas R-Car GPIO driver is only useful on shmobile unless build testing. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Magnus Damm <damm@opensource.se> Cc: Alexandre Courbot <gnurou@gmail.com> Acked-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-27gpio: pch: add slab includeLinus Walleij
After change 3ff35cbcfa4bc7d7dbdd0279e32ea677567ded02 "gpio-pch: Fix Kconfig dependencies" which enabled COMPILE_TEST as an alternative for the PCH driver, we get build failures like this: drivers/gpio/gpio-pch.c: In function 'pch_gpio_probe': drivers/gpio/gpio-pch.c:359:2: error: implicit declaration of function 'kzalloc' [-Werror=implicit-function-declaration] drivers/gpio/gpio-pch.c:359:7: warning: assignment makes pointer from integer without a cast [enabled by default] drivers/gpio/gpio-pch.c:442:2: error: implicit declaration of function 'kfree' [-Werror=implicit-function-declaration] Fix this by including <linux/slab.h> explicitly. Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-23Documentation / ACPI: Fix location of GPIO documentationJarkko Nikula
Commit fd8e198cfcaa ("Documentation: gpiolib: document new interface") moved Documentation/gpio.txt to Documentation/gpio/gpio-legacy.txt and added new documents for descriptor-based interface so fix the the location here to point Documentation/gpio/ since that what commit ccb6fbb99020 ("Documentation / ACPI: update to GPIO descriptor API") was looking for. Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-23gpio / ACPI: use *_cansleep version of gpiod_get/set APIsAaron Lu
The GPIO operation region handler should be called where sleep is allowed, so we should use the *_cansleep version of gpiod_get/set APIs or we will get a warning message complaining invalid context if the GPIO chip has the cansleep flag set. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-23gpio: generic: add request function pointerAnthony Fee
gpiolib will require all gpio drivers to expicitly set the request function pointer in the future. To encourage gpio driver developers to adhere to this standard gpio-generic.c now sets this function pointer. Signed-off-by: Anthony Fee <anthony.fee@emutex.com> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-23gpio-pch: Fix Kconfig dependenciesJean Delvare
The gpio-pch driver is for a companion chip to the Intel Atom E600 series processors. These are 32-bit x86 processors so the driver is only needed on X86_32. Add COMPILE_TEST as an alternative, so that the driver can still be build-tested elsewhere. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-21gpio: make of_get_named_gpiod_flags() privateAlexandre Courbot
of_get_named_gpiod_flags() is visible and directly usable by GPIO consumers, but it really should not as the gpiod interface relies on the simpler gpiod_get() to provide properly-configured GPIOs. of_get_named_gpiod_flags() is just used internally by gpiolib to implement gpiod_get(), and by the old of_get_named_gpio_flags() function, therefore it makes sense to make it gpiolib-private. As a side-effect, the unused (and unneeded) of_get_gpiod_flags() inline function is also removed, and of_get_named_gpio_flags() is moved from a static inline function to a regular one in gpiolib-of.c This results in all references to gpiod_* functions in of_gpio.h being gone, which is the way it should be since this file is part of the old integer GPIO interface. Changes since v1: - Fixed compilation error when CONFIG_OF_GPIO is not defined - Fixed warning due to of_gpio_flags enum not being declared in private gpiolib.h header Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-16gpio: gpioep93xx: use devm functionsabdoulaye berthe
This uses devm functions for mem allocation Signed-off-by: abdoulaye berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-16gpio: janzttl: use devm functionabdoulaye berthe
This uses dem function for mem allocation Signed-off-by: abdoulaye berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-16gpio: timberdale: use devm functionsabdoulaye berthe
This eases memory allocation and provides appropriate logging. Signed-off-by: abdoulaye berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-16gpio: bt8xx: use devm function for memory allocationabdoulaye berthe
2014-05-16gpio: include linux/bug.h in interface headerArnd Bergmann
Today's linux-next kernel started showing build errors for the use of WARN_ON in linux/gpio/consumer.h: In file included from drivers/video/backlight/pwm_bl.c:13:0: include/linux/gpio/consumer.h: In function 'gpiod_put': include/linux/gpio/consumer.h:81:2: error: implicit declaration of function 'WARN_ON' [-Werror=implicit-function-declaration] It's not clear why this never happened before, but this patch fixes it by including the header that contains the defintion of this macro. Signed-off-by: Arnd Bergmann <arnd@arnd.de> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-16gpio: omap: prepare and unprepare the debounce clockRajendra Nayak
Replace the clk_enable()s with a clk_prepare_enable() and the clk_disables()s with a clk_disable_unprepare() This never showed issues due to the OMAP platform code (hwmod) leaving these clocks in clk_prepare()ed state by default. Reported-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Acked-by: Javier Martinez Canillas <javier@dowhile0.org> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-13Merge tag 'v3.15-rc4' into develLinus Walleij
Linux 3.15-rc4
2014-05-09gpio: Add helpers for optional GPIOsThierry Reding
Introduce gpiod_get_optional() and gpiod_get_index_optional() helpers that make it easier for drivers to handle optional GPIOs. Currently in order to handle optional GPIOs, a driver needs to special case error handling for -ENOENT, such as this: gpio = gpiod_get(dev, "foo"); if (IS_ERR(gpio)) { if (PTR_ERR(gpio) != -ENOENT) return PTR_ERR(gpio); gpio = NULL; } if (gpio) { /* set up GPIO */ } With these new helpers the above is reduced to: gpio = gpiod_get_optional(dev, "foo"); if (IS_ERR(gpio)) return PTR_ERR(gpio); if (gpio) { /* set up GPIO */ } While at it, device-managed variants of these functions are also provided. Signed-off-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: pca953x: request a shared interruptToby Smith
Request a shared interrupt when requesting a pca953x GPIO interrupt Signed-off-by: Toby Smith <toby@tismith.id.au> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: pca953x: return IRQ_NONE when appropriateToby Smith
The irq handler should return IRQ_NONE or IRQ_HANDLED to report if we have handled the interrupt. Signed-off-by: Toby Smith <toby@tismith.id.au> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: mvebu: Remove initcall-based driver initializationEzequiel Garcia
There's no reason to use an initcall to initialize this driver, and regular module_platform_driver() can be used instead. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org> Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: zevio: Make of_device_id array constJingoo Han
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: xilinx: Make of_device_id array constJingoo Han
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: tegra: Make of_device_id array constJingoo Han
2014-05-09gpio: palmas: Make of_device_id array constJingoo Han
2014-05-09gpio: mvebu: Make of_device_id array constJingoo Han
2014-05-09gpio: mcp23s08: Make of_device_id array constJingoo Han
2014-05-09gpio: grgpio: Make of_device_id array constJingoo Han
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Andreas Larsson <andreas@gaisler.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: zevio: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: tps65910: remove unnecessary OOM messagesJingoo Han
2014-05-09gpio: tps6586x: remove unnecessary OOM messagesJingoo Han
2014-05-09gpio: tegra: remove unnecessary OOM messagesJingoo Han
2014-05-09gpio: SPEAr: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: rdc321x: remove unnecessary OOM messagesJingoo Han
2014-05-09gpio: rcar: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: rc5t583: remove unnecessary OOM messagesJingoo Han
2014-05-09gpio: palmas: remove unnecessary OOM messagesJingoo Han
2014-05-09gpio: mvebu: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: moxart: remove unnecessary OOM messagesJingoo Han
2014-05-09gpio: lynxpoint: remove unnecessary OOM messagesJingoo Han
2014-05-09gpio: janz-ttl: remove unnecessary OOM messagesJingoo Han
2014-05-09gpio: em: remove unnecessary OOM messagesJingoo Han
2014-05-09gpio: davinci: remove unnecessary OOM messagesJingoo Han
2014-05-09gpio: adp5588: remove unnecessary OOM messagesJingoo Han
2014-05-09gpio: adp5520: remove unnecessary OOM messagesJingoo Han
