Signed-off-by: SeongJae Park <sj38.park@gmail.com>
The MCP drivers fails to compile on trial builds due to missing
Kconfig dependency on OF_GPIO. Fix it.
Cc: Lars Poeschel <poeschel@lemonage.de>
This adds interrupt functionality for i2c chips to the driver.
They can act as a interrupt-controller and generate interrupts, if
the inputs change.
This is tested with a mcp23017 chip on an arm based platform.
v3:
- be a bit more clear that the irq functionality is also available
on spi versions of the chips, but the linux driver does not support
this yet
v2:
- some more word about irq-mirror property in binding doc
- use of_read_bool instead of of_find_property for
"interrupt-contrller" and "irq-mirror"
- cache the "interrupt-controller" for remove function
- do set the irq-mirror bit only if device is marked as
- do create the irq mapping and setup of irq_desc of all possible
interrupts in probe path instead of in gpio_to_irq
- mark gpios as in use as interrupts in irq in irq_startup and
unlock it in irq_shutdown
- rename virq to child_irq
- remove dev argument from mcp23s08_irq_setup function
- move gpiochip_add before mcp23s08_irq_setup in probe path
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
gpio-samsung.h header file introduced by commit 93177be0910c
("ARM: S3C[24|64]xx: move includes back under <mach/> scope")
is required only by S3C[24|64]xx machines. Include them conditionally
to avoid the following build errors for other machine configurations.
drivers/gpio/gpio-samsung.c:35:31: fatal error: mach/gpio-samsung.h: No such file or directory
arch/arm/plat-samsung/pm-gpio.c:22:31: fatal error: mach/gpio-samsung.h: No such file or directory
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
It would be convenient to normalize the return value for gpio_get.
I have checked mach-mmp / mach-pxa / plat-pxa / plat-orion / mach-orion5x.
It's OK for all of them to change this function to return 0 and 1.
Signed-off-by: Neil Zhang <zhangwm@marvell.com>
Previously the custom GPIO header for the S3C24xx would in turn
bring in the custom pin control implementation from
<plat/gpio-cfg.h>. This is not good as it mixes up two
subsystems and makes the dependencies hard to track. Make
the dependency explicit by explicitly including the pin
control header where needed.
Cc: Tomasz Figa <tomasz.figa@gmail.com>
Cc: Sylwester Nawrocki <sylvester.nawrocki@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Mark Brown <broonie@kernel.org>
Cc: linux-samsung-soc@vger.kernel.org
Acked-by: Heiko Stuebner <heiko@sntech.de>
When refactoring and breaking out the includes for the
machine-specific GPIO configuration, two files were created
in <linux/platform_data/gpio-samsung-s3c[24|64]xx.h>, but as
that namespace shall be used for defining data exchanged
between machines and drivers, using it for these broad macros
and config settings is wrong.
Move the headers back into the machine-local
<mach/gpio-samsung.h> file and think about the next step.
Acked-by: Mark Brown <broonie@linaro.org>
Update the documentation also to reflect the fact that there are no ACPI
specific GPIO interfaces anymore but drivers should instead use the
descriptor based GPIO APIs.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Now that all users of acpi_gpio.h have been moved to use either the GPIO
descriptor interface or to the internal gpiolib.h we can get rid of
acpi_gpio.h entirely.
Once this is done the only interface to get GPIOs to drivers enumerated
from ACPI namespace is the descriptor based interface.
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Instead of asking each driver to register to ACPI events we can just call
acpi_gpiochip_register_interrupts() for each chip that has an ACPI handle.
The function checks chip->to_irq and if it is set to NULL (a GPIO driver
that doesn't do interrupts) the function does nothing.
We also add the a new header drivers/gpio/gpiolib.h that is used for
functions internal to gpiolib and add ACPI GPIO chip registering functions
to that header.
Once that is done we can remove call to acpi_gpiochip_register_interrupts()
from its only user, pinctrl-baytrail.c
The new descriptor based GPIO interface is now the recommended and safer
way of using GPIOs from device drivers. Convert the ACPI SDHCI driver to
use that interface.
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
When enabling device tree on the S3C an additional build
bug appears in the Osiris DVS board file:
CC arch/arm/mach-s3c24xx/mach-osiris-dvs.o
archh/arm/mach-s3c24xx/mach-osiris-dvs.c:
In function ‘osiris_dvs_notify’:
arch/arm/mach-s3c24xx/mach-osiris-dvs.c:77:4:
error: implicit declaration of function ‘S3C2410_GPB’
[-Werror=implicit-function-declaration]
gpio_set_value(OSIRIS_GPIO_DVS, 1);
Fix this by explicitly including
<linux/platform_data/gpio-samsung-s3c24xx.h>
Since request_muxed_region() is used to synchronize access on the
Super-I/O controller, then the can_sleep attribute must be set for
the f7188x GPIO chips.
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
hardware.h inclusion is no longer needed. Update the documentation section
related to it and fix a file path.
The contents of this header file are not referenced in the driver.
Remove its inclusion.
Cc: Heiko Stuebner <heiko@sntech.de>
Prevent build failure when the selected variant does not support GPIO32.
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
This helps increasing build testing coverage.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
There is no reason to keep the OF data if the driver was compiled
without DT support.
Convert to the safer gpiod_* family of API functions.
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Commit c67d0f29262b ("ARM: s3c24xx: get rid of custom <mach/gpio.h>")
removed the usage of mach/gpio.h file, but we need to include>
plat/gpio-cfg.h to avoid following build error.
Fixes following build error.
drivers/leds/leds-s3c24xx.c: In function ‘s3c24xx_led_probe’:
drivers/leds/leds-s3c24xx.c:100:2: error: implicit declaration of
function ‘s3c_gpio_setpull’ [-Werror=implicit-function-declaration]
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
Acked-by: Bryan Wu <cooloney@gmail.com>
'tb10x_gpio_dt_ids' is always compiled in. Hence the
helper macro is not needed.
Return the appropriate error code instead of hardcoding it.
Silences the following warning:
why not propagate 'port->irq' from platform_get_irq() instead of (-22)?
Driver core sets it to NULL upon probe failure or release.
Some GPIO line limits are incorrectly set which, for instance,
does not allow nRTS1 (GPH11) configuration on a S3C2416 chip.
Signed-off-by: José Miguel Gonçalves <jose.goncalves@inov.pt>
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Compilation failed on some platforms due to implicit inclusion of
<linux/io.h>, make this dependency explicit.
This isolates the custom S3C64xx GPIO definition table to
<linux/platform_data/gpio-samsung-s3x64xx.h> as this is
used in a few different places in the kernel, removing the
need to depend on the implicit inclusion of <mach/gpio.h>
from <linux/gpio.h> and thus getting rid of a few nasty
cross-dependencies.
Also delete the CONFIG_SAMSUNG_GPIO_EXTRA stuff. Instead
roof the number of GPIOs for this platform:
First sum up all the GPIO banks from A to Q: 187 GPIOs.
Add the 16 "board GPIOs" and the roof for SAMSUNG_GPIO_EXTRA,
128, so in total maximum 187+16+128 = 331 GPIOs, so let's
take the same roof as for S3C24XX: 512. This way we can do
away with the GPIO calculation macros for GPIO_BOARD_START,
BOARD_NR_GPIOS and the definition of ARCH_NR_GPIOS.
[on Mini6410 board]
Tested-by: Tomasz Figa <t.figa@samsung.com>
[for changes in mach-s3c64xx]
Acked-by: Tomasz Figa <t.figa@samsung.com>
Tested-by: Mark Brown <broonie@linaro.org>
This isolates the custom S3C24xx GPIO definition table to
<linux/platform_data/gpio-samsung-s3x24xx.h> as this is
cross-dependencies.
We also delete the nifty CONFIG_S3C24XX_GPIO_EXTRA stuff.
The biggest this can ever be for the S3C24XX is
CONFIG_S3C24XX_GPIO_EXTRA = 128, and then for CPU_S3C2443 or
CPU_S3C2416 32*12 GPIOs are added, so 32*12+128 = 512
is the absolute roof value on this platform. So we set
the size of ARCH_NR_GPIO to this and the GPIOs array will
fit any S3C24XX platform, as per pattern from other archs.
ChangeLog v2->v3:
- Move the movement of the S3C64XX gpio.h file out of
this patch and into the follow-up patch where it belongs.
ChangeLog v1->v2:
- Added an #ifdef ARCH_S3C24XX around the header inclusion
in drivers/gpio/gpio-samsung.c as we would otherwise
have colliding definitions when compiling S3C64XX.
- Rename inclusion guard in the header file.
Tested-by: Heiko Stuebner <heiko@sntech.de>
Fix to return a negative error code from the error handling
case instead of 0.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
There is a error message within devm_ioremap_resource
already, so remove the dev_err call to avoid redundant
error message.
Add missing .owner of struct gpio_chip. This prevents the
module from being removed from underneath its users.
This patch adds support for the GPIOs found on the SMSC "Super I/
SCH311x.
The chip detection and I/O functions are copied from sch311x_wdt.
Signed-off-by: Bruno Randolf <br1@einfach.org>
Doing this allows drivers to distinguish between a real error case (if
there was an error when we tried to resolve the GPIO) and when the optional
GPIO line was not available.
This allows the module to be loaded automatically.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Some devices drivers make use of optional GPIO parameters. For such
drivers, it is important to discriminate between the case where no
GPIO mapping has been defined for the function they are requesting, and
the case where a mapping exists but an error occured while resolving it
or when acquiring the GPIO.
This patch changes the family of gpiod_get() functions such that they
will return -ENOENT if and only if no GPIO mapping is defined for the
requested function. Other error codes are used when an actual error
occured during the GPIO resolution.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
GPIO32 is a standard optional extension to the Xtensa architecture
core that provides preconfigured output and input ports for intra
SoC signaling. The GPIO32 option is implemented as 32bit Tensilica
Instruction Extension (TIE) output state called EXPSTATE, and 32bit
input wire called IMPWIRE. This driver treats input and output
states as two distinct devices.
v3:
* Use BUG() in xtensa_impwire_set_value() to indicate that
it should never be called (Linus Walleij)
v2:
* Address the comments of Linus Walleij:
- Add a few comments
- Expand commit log message
- Use the BIT() macro for bit offsets
- Rewrite CPENABLE handling as static inlines
- Use device_initcall()
* Depend on !SMP for reason explained in the comments (Marc Gauthier)
* Use XCHAL_CP_ID_XTIOP to enable/disable GPIO32 only
- Removed excess "spi" field from private data.
- Removed excess check for spi_get_drvdata() in remove().
- Removed unneeded message in remove().
- Simplify error path in probe().
- Fixed warnings by scripts/checkfile.pl.
Commit 20bc4d5d565159eb2b942bf4b7fae86fba94e32c
(gpio: 74x164: Add support for the daisy-chaining) introduce check
for DT for the driver, so driver cannot be used without DT.
There are no in-tree users of this driver, so remove non-DT support
completely.
The call to gpiochip_add() is not currently error-checked. Add the
missing checking.
Reviewed-by: Thierry Reding <treding@nvidia.com>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
This makes it possible to request the gpio descriptors in
rfkill_gpio driver regardless of the platform.
The patch just accents that @dev could be NULL.
There is no functional change.
The patch moves description of the fields to the top of struct definition and
converts them to the kernel-doc format.
In several places we are printing messages with prefix based on chip->label.
Introduced macros help us to do this easier and in uniform way.
This patch includes the following amendments:
1) use "?" as a label when the last one is not defined in gpiod_*;
2) whenever it's possible gpiod_* are used;
3) print a function name, if it's already used in other messages.
Additionally it fixes an indentation in few places.
Change the format of the platform GPIO lookup tables to make them less
confusing and improve lookup efficiency.
The previous format was a single linked-list that required to compare
the device name and function ID of every single GPIO defined for each
lookup. Switch that to a list of per-device tables, so that the lookup
can be done in two steps, omitting the GPIOs that are not relevant for a
particular device.
The matching rules are now defined as follows:
- The device name must match *exactly*, and can be NULL for GPIOs not
assigned to a particular device,
- If the function ID in the lookup table is NULL, the con_id argument of
gpiod_get() will not be used for lookup. However, if it is defined, it
must match exactly.
- The index must always match.
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Linux 3.13-rc3
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing fix from Steven Rostedt:
"A regression showed up that there's a large delay when enabling all
events. This was prevalent when FTRACE_SELFTEST was enabled which
enables all events several times, and caused the system bootup to
pause for over a minute.
This was tracked down to an addition of a synchronize_sched()
performed when system call tracepoints are unregistered.
The synchronize_sched() is needed between the unregistering of the
system call tracepoint and a deletion of a tracing instance buffer.
But placing the synchronize_sched() in the unreg of *every* system
call tracepoint is a bit overboard. A single synchronize_sched()
before the deletion of the instance is sufficient"
* tag 'trace-fixes-3.13-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Only run synchronize_sched() at instance deletion time
Pull aio fix from Benjamin LaHaise:
"AIO fix from Gu Zheng that fixes a GPF that Dave Jones uncovered with
trinity"
* git://git.kvack.org/~bcrl/aio-next:
aio: clean up aio ring in the fail path
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is a set of nine fixes (and one author update).
The libsas one should fix discovery in eSATA devices, the WRITE_SAME
one is the largest, but it should fix a lot of problems we've been
getting with the emulated RAID devices (they've been effectively lying
about support and then firmware has been choking on the commands).
The rest are various crash, hang or warn driver fixes"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
[SCSI] bfa: Fix crash when symb name set for offline vport
[SCSI] enclosure: fix WARN_ON in dual path device removing
[SCSI] pm80xx: Tasklets synchronization fix.
[SCSI] pm80xx: Resetting the phy state.
[SCSI] pm80xx: Fix for direct attached device.
[SCSI] pm80xx: Module author addition
[SCSI] hpsa: return 0 from driver probe function on success, not 1
[SCSI] hpsa: do not discard scsi status on aborted commands
[SCSI] Disable WRITE SAME for RAID and virtual host adapter drivers
[SCSI] libsas: fix usage of ata_tf_to_fis
