2013-12-30Merge remote-tracking branch 'grant/devicetree/merge' into dt-fixesdt-fixes-for-3.13Rob Herring
2013-12-30MAINTAINERS: Update Rob Herring's email addressRob Herring
My Calxeda email address is going away. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Rob Herring <robh@kernel.org>
2013-12-30of/irq: Fix device_node refcount in of_irq_parse_raw()Cédric Le Goater
Commit 2361613206e6, "of/irq: Refactor interrupt-map parsing" changed the refcount on the device_node causing an error in of_node_put(): ERROR: Bad of_node_put() on /pci@800000020000000 CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.13.0-rc3-dirty #2 Call Trace: [c00000003e403500] [c0000000000144fc] .show_stack+0x7c/0x1f0 (unreliable) [c00000003e4035d0] [c00000000070f250] .dump_stack+0x88/0xb4 [c00000003e403650] [c0000000005e8768] .of_node_release+0xd8/0xf0 [c00000003e4036e0] [c0000000005eeafc] .of_irq_parse_one+0x10c/0x280 [c00000003e4037a0] [c0000000005efd4c] .of_irq_parse_pci+0x3c/0x1d0 [c00000003e403840] [c000000000038240] .pcibios_setup_device+0xa0/0x2e0 [c00000003e403910] [c0000000000398f0] .pcibios_setup_bus_devices+0x60/0xd0 [c00000003e403990] [c00000000003b3a4] .__of_scan_bus+0x1a4/0x2b0 [c00000003e403a80] [c00000000003a62c] .pcibios_scan_phb+0x30c/0x410 [c00000003e403b60] [c0000000009fe430] .pcibios_init+0x7c/0xd4 This patch adjusts the refcount in the walk of the interrupt tree. When a match is found, there is no need to increase the refcount on 'out_irq->np' as 'newpar' is already holding a ref. The refcount balance between 'ipar' and 'newpar' is maintained in the skiplevel: goto label. This patch also removes the usage of the device_node variable 'old' which seems useless after the latest changes. Signed-off-by: Cédric Le Goater <clg@fr.ibm.com> Signed-off-by: Rob Herring <robh@kernel.org>
2013-12-30of/Kconfig: Spelling s/one/once/Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Signed-off-by: Rob Herring <robh@kernel.org>
2013-12-30Revert "of/address: Handle #address-cells > 2 specially"Rob Herring
This reverts commit e38c0a1fbc5803cbacdaac0557c70ac8ca5152e7. Nikita Yushchenko reports: While trying to make freescale p2020ds and mpc8572ds boards working with mainline kernel, I faced that commit e38c0a1f (Handle Both these boards have uli1575 chip. Corresponding part in device tree is something like uli1575@0 { reg = <0x0 0x0 0x0 0x0 0x0>; #size-cells = <2>; #address-cells = <3>; ranges = <0x2000000 0x0 0x80000000 0x2000000 0x0 0x80000000 0x0 0x20000000 0x1000000 0x0 0x0 0x1000000 0x0 0x0 0x0 0x10000>; isa@1e { ... I.e. it has #address-cells = <3> With commit e38c0a1f reverted, devices under uli1575 are registered correctly, e.g. for rtc OF: ** translation for device /pcie@ffe09000/pcie@0/uli1575@0/isa@1e/rtc@70 ** OF: bus is isa (na=2, ns=1) on /pcie@ffe09000/pcie@0/uli1575@0/isa@1e OF: translating address: 00000001 00000070 OF: parent bus is default (na=3, ns=2) on /pcie@ffe09000/pcie@0/uli1575@0 OF: walking ranges... OF: ISA map, cp=0, s=1000, da=70 OF: parent translation for: 01000000 00000000 00000000 OF: with offset: 70 OF: one level translation: 00000000 00000000 00000070 OF: parent bus is pci (na=3, ns=2) on /pcie@ffe09000/pcie@0 OF: walking ranges... OF: default map, cp=a0000000, s=20000000, da=70 OF: default map, cp=0, s=10000, da=70 OF: parent translation for: 01000000 00000000 00000000 OF: with offset: 70 OF: one level translation: 01000000 00000000 00000070 OF: parent bus is pci (na=3, ns=2) on /pcie@ffe09000 OF: walking ranges... OF: PCI map, cp=0, s=10000, da=70 OF: parent translation for: 01000000 00000000 00000000 OF: with offset: 70 OF: one level translation: 01000000 00000000 00000070 OF: parent bus is default (na=2, ns=2) on / OF: walking ranges... OF: PCI map, cp=0, s=10000, da=70 OF: parent translation for: 00000000 ffc10000 OF: with offset: 70 OF: one level translation: 00000000 ffc10070 OF: reached root node With commit e38c0a1f in place, address translation fails: OF: ** translation for device /pcie@ffe09000/pcie@0/uli1575@0/isa@1e/rtc@70 ** OF: bus is isa (na=2, ns=1) on /pcie@ffe09000/pcie@0/uli1575@0/isa@1e OF: translating address: 00000001 00000070 OF: parent bus is default (na=3, ns=2) on /pcie@ffe09000/pcie@0/uli1575@0 OF: walking ranges... OF: ISA map, cp=0, s=1000, da=70 OF: parent translation for: 01000000 00000000 00000000 OF: with offset: 70 OF: one level translation: 00000000 00000000 00000070 OF: parent bus is pci (na=3, ns=2) on /pcie@ffe09000/pcie@0 OF: walking ranges... OF: default map, cp=a0000000, s=20000000, da=70 OF: default map, cp=0, s=10000, da=70 OF: not found ! Thierry Reding confirmed this commit was not needed after all: "We ended up merging a different address representation for Tegra PCIe and I've confirmed that reverting this commit doesn't cause any obvious regressions. I think all other drivers in drivers/pci/host ended up copying what we did on Tegra, so I wouldn't expect any other breakage either." There doesn't appear to be a simple way to support both behaviours, so reverting this as nothing should be depending on the new behaviour. Cc: stable@vger.kernel.org # v3.7+ Signed-off-by: Rob Herring <robh@kernel.org>
2013-12-22Linux 3.13-rc5v3.13-rc5Linus Torvalds
2013-12-22Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Much smaller batch of fixes this week. Biggest one is a revert of an OMAP display change that removed some non-DT pinmux code that was still needed for 3.13 to get DSI displays to work. There's also a fix that resolves some misdescribed GPIO controller resources on shmobile. The rest are mostly smaller fixes, a couple of MAINTAINERS updates, etc" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: Revert "ARM: OMAP2+: Remove legacy mux code for display.c" MAINTAINERS: Add keystone clock drivers MAINTAINERS: Add keystone git tree information ARM: s3c64xx: dt: Fix boot failure due to double clock initialization ARM: shmobile: r8a7790: Fix GPIO resources in DTS irqchip: renesas-intc-irqpin: Fix register bitfield shift calculation ARM: shmobile: lager: phy fixup needs CONFIG_PHYLIB
2013-12-22Merge tag 'firewire-fix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewire fixlet from Stefan Richter: "A one-liner to reenable WRITE SAME over SBP-2 like in v3.8...v3.12. Buggy targets which could malfunction when being subjected to this command are already sufficiently protected by a scsi_level check in sd + SCSI core" * tag 'firewire-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: sbp2: bring back WRITE SAME support
2013-12-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull SCSI target fixes from Nicholas Bellinger: "Mostly minor items this time around, the most notable being a FILEIO backend change to enforce hw_max_sectors based upon the current block_size to address a bug where large sized I/Os (> 1M) where being rejected" * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: qla2xxx: Fix scsi_host leak on qlt_lport_register callback failure target: Remove extra percpu_ref_init target/file: Update hw_max_sectors based on current block_size iser-target: Move INIT_WORK setup into isert_create_device_ib_res iscsi-target: Fix incorrect np->np_thread NULL assignment qla2xxx: Fix schedule_delayed_work() for target timeout calculations iser-target: fix error return code in isert_create_device_ib_res() iscsi-target: Fix-up all zero data-length CDBs with R/W_BIT set target: Remove write-only stats fields and lock from struct se_node_acl iscsi-target: return -EINVAL on oversized configfs parameter
2013-12-22Merge git://git.kvack.org/~bcrl/aio-nextLinus Torvalds
Pull AIO leak fixes from Ben LaHaise: "I've put these two patches plus Linus's change through a round of tests, and it passes millions of iterations of the aio numa migratepage test, as well as a number of repetitions of a few simple read and write tests. The first patch fixes the memory leak Kent introduced, while the second patch makes aio_migratepage() much more paranoid and robust" * git://git.kvack.org/~bcrl/aio-next: aio/migratepages: make aio migrate pages sane aio: fix kioctx leak introduced by "aio: Fix a trinity splat"
2013-12-22aio: clean up and fix aio_setup_ring page mappingLinus Torvalds
Since commit 36bc08cc01709 ("fs/aio: Add support to aio ring pages migration") the aio ring setup code has used a special per-ring backing inode for the page allocations, rather than just using random anonymous pages. However, rather than remembering the pages as it allocated them, it would allocate the pages, insert them into the file mapping (dirty, so that they couldn't be free'd), and then forget about them. And then to look them up again, it would mmap the mapping, and then use "get_user_pages()" to get back an array of the pages we just created. Now, not only is that incredibly inefficient, it also leaked all the pages if the mmap failed (which could happen due to excessive number of mappings, for example). So clean it all up, making it much more straightforward. Also remove some left-overs of the previous (broken) mm_populate() usage that was removed in commit d6c355c7dabc ("aio: fix race in ring buffer page lookup introduced by page migration support") but left the pointless and now misleading MAP_POPULATE flag around. Tested-and-acked-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-21aio/migratepages: make aio migrate pages saneBenjamin LaHaise
The arbitrary restriction on page counts offered by the core migrate_page_move_mapping() code results in rather suspicious looking fiddling with page reference counts in the aio_migratepage() operation. To fix this, make migrate_page_move_mapping() take an extra_count parameter that allows aio to tell the code about its own reference count on the page being migrated. While cleaning up aio_migratepage(), make it validate that the old page being passed in is actually what aio_migratepage() expects to prevent misbehaviour in the case of races. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
2013-12-21aio: fix kioctx leak introduced by "aio: Fix a trinity splat"Benjamin LaHaise
e34ecee2ae791df674dfb466ce40692ca6218e43 reworked the percpu reference counting to correct a bug trinity found. Unfortunately, the change lead to kioctxes being leaked because there was no final reference count to put. Add that reference count back in to fix things. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Cc: stable@vger.kernel.org
2013-12-20Don't set the INITRD_COMPRESS environment variable automaticallyLinus Torvalds
Commit 1bf49dd4be0b ("./Makefile: export initial ramdisk compression config option") started setting the INITRD_COMPRESS environment variable depending on which decompression models the kernel had available. That is completely broken. For example, we by default have CONFIG_RD_LZ4 enabled, and are able to decompress such an initrd, but the user tools to *create* such an initrd may not be availble. So trying to tell dracut to generate an lz4-compressed image just because we can decode such an image is completely inappropriate. Cc: J P <ppandit@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jan Beulich <JBeulich@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-20Merge tag 'xfs-for-linus-v3.13-rc5' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs bugfixes from Ben Myers: "This contains fixes for some asserts related to project quotas, a memory leak, a hang when disabling group or project quotas before disabling user quotas, Dave's email address, several fixes for the alignment of file allocation to stripe unit/width geometry, a fix for an assertion with xfs_zero_remaining_bytes, and the behavior of metadata writeback in the face of IO errors. Details: - fix memory leak in xfs_dir2_node_removename - fix quota assertion in xfs_setattr_size - fix quota assertions in xfs_qm_vop_create_dqattach - fix for hang when disabling group and project quotas before disabling user quotas - fix Dave Chinner's email address in MAINTAINERS - fix for file allocation alignment - fix for assertion in xfs_buf_stale by removing xfsbdstrat - fix for alignment with swalloc mount option - fix for "retry forever" semantics on IO errors" * tag 'xfs-for-linus-v3.13-rc5' of git://oss.sgi.com/xfs/xfs: xfs: abort metadata writeback on permanent errors xfs: swalloc doesn't align allocations properly xfs: remove xfsbdstrat error xfs: align initial file allocations correctly MAINTAINERS: fix incorrect mail address of XFS maintainer xfs: fix infinite loop by detaching the group/project hints from user dquot xfs: fix assertion failure at xfs_setattr_nonsize xfs: fix false assertion at xfs_qm_vop_create_dqattach xfs: fix memory leak in xfs_dir2_node_removename
2013-12-20mm: fix build of split ptlock codeOlof Johansson
Commit 597d795a2a78 ('mm: do not allocate page->ptl dynamically, if spinlock_t fits to long') restructures some allocators that are compiled even if USE_SPLIT_PTLOCKS arn't used. It results in compilation failure: mm/memory.c:4282:6: error: 'struct page' has no member named 'ptl' mm/memory.c:4288:12: error: 'struct page' has no member named 'ptl' Add in the missing ifdef. Fixes: 597d795a2a78 ('mm: do not allocate page->ptl dynamically, if spinlock_t fits to long') Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-20Merge tag 'arc-fixes-for-3.13-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC fix from Vineet Gupta: "Fix busted syscall table due to unistd header inclusion issue" * tag 'arc-fixes-for-3.13-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARC: Allow conditional multiple inclusion of uapi/asm/unistd.h
2013-12-20Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 ptrace fix from Catalin Marinas. * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: ptrace: avoid using HW_BREAKPOINT_EMPTY for disabled events
2013-12-20pstore: Don't allow high traffic options on fragile devicesLuck, Tony
Some pstore backing devices use on board flash as persistent storage. These have limited numbers of write cycles so it is a poor idea to use them from high frequency operations. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-20Merge tag 'dmaengine-fixes-3.13-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine fixes from Dan Williams: - deprecation of net_dma to be removed in 3.14 - crash regression fix in pl330 from the dmaengine_unmap rework - crash regression fix for any channel running raid ops without CONFIG_ASYNC_TX_DMA from dmaengine_unmap - memory leak regression in mv_xor from dmaengine_unmap - build warning regressions in mv_xor, fsldma, ppc4xx, txx9, and at_hdmac from dmaengine_unmap - sleep in atomic regression in dma_async_memcpy_pg_to_pg - new fix in mv_xor for handling channel initialization failures * tag 'dmaengine-fixes-3.13-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine: net_dma: mark broken dma: pl330: ensure DMA descriptors are zero-initialised dmaengine: fix sleep in atomic dmaengine: mv_xor: fix oops when channels fail to initialise dma: mv_xor: Use dmaengine_unmap_data for the self-tests dmaengine: fix enable for high order unmap pools dma: fix build warnings in txx9 dmatest: fix build warning on mips dma: fix fsldma build warnings dma: fix build warnings in ppc4xx dmaengine: at_hdmac: remove unused function dma: mv_xor: remove mv_desc_get_dest_addr()
2013-12-20Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Paolo Bonzini: "The PPC folks had a large amount of changes queued for 3.13, and now they are fixing the bugs" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: PPC: Book3S HV: Don't drop low-order page address bits powerpc: book3s: kvm: Don't abuse host r2 in exit path powerpc/kvm/booke: Fix build break due to stack frame size warning KVM: PPC: Book3S: PR: Enable interrupts earlier KVM: PPC: Book3S: PR: Make svcpu -> vcpu store preempt savvy KVM: PPC: Book3S: PR: Export kvmppc_copy_to|from_svcpu KVM: PPC: Book3S: PR: Don't clobber our exit handler id powerpc: kvm: fix rare but potential deadlock scene KVM: PPC: Book3S HV: Take SRCU read lock around kvm_read_guest() call KVM: PPC: Book3S HV: Make tbacct_lock irq-safe KVM: PPC: Book3S HV: Refine barriers in guest entry/exit KVM: PPC: Book3S HV: Fix physical address calculations
2013-12-20mm: do not allocate page->ptl dynamically, if spinlock_t fits to longKirill A. Shutemov
In struct page we have enough space to fit long-size page->ptl there, but we use dynamically-allocated page->ptl if size(spinlock_t) is larger than sizeof(int). It hurts 64-bit architectures with CONFIG_GENERIC_LOCKBREAK, where sizeof(spinlock_t) == 8, but it easily fits into struct page. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-20mm: page_alloc: revert NUMA aspect of fair allocation policyJohannes Weiner
Commit 81c0a2bb515f ("mm: page_alloc: fair zone allocator policy") meant to bring aging fairness among zones in system, but it was overzealous and badly regressed basic workloads on NUMA systems. Due to the way kswapd and page allocator interacts, we still want to make sure that all zones in any given node are used equally for all allocations to maximize memory utilization and prevent thrashing on the highest zone in the node. While the same principle applies to NUMA nodes - memory utilization is obviously improved by spreading allocations throughout all nodes - remote references can be costly and so many workloads prefer locality over memory utilization. The original change assumed that zone_reclaim_mode would be a good enough predictor for that, but it turned out to be as indicative as a coin flip. Revert the NUMA aspect of the fairness until we can find a proper way to make it configurable and agree on a sane default. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: <stable@kernel.org> # 3.12 Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-20Revert "mm: page_alloc: exclude unreclaimable allocations from zone fairness ↵Mel Gorman
policy" This reverts commit 73f038b863df. The NUMA behaviour of this patch is less than ideal. An alternative approch is to interleave allocations only within local zones which is implemented in the next patch. Cc: stable@vger.kernel.org Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-20mm: Fix NULL pointer dereference in madvise(MADV_WILLNEED) supportKirill A. Shutemov
Sasha Levin found a NULL pointer dereference that is due to a missing page table lock, which in turn is due to the pmd entry in question being a transparent huge-table entry. The code - introduced in commit 1998cc048901 ("mm: make madvise(MADV_WILLNEED) support swap file prefetch") - correctly checks for this situation using pmd_none_or_trans_huge_or_clear_bad(), but it turns out that that function doesn't work correctly. pmd_none_or_trans_huge_or_clear_bad() expected that pmd_bad() would trigger if the transparent hugepage bit was set, but it doesn't do that if pmd_numa() is also set. Note that the NUMA bit only gets set on real NUMA machines, so people trying to reproduce this on most normal development systems would never actually trigger this. Fix it by removing the very subtle (and subtly incorrect) expectation, and instead just checking pmd_trans_huge() explicitly. Reported-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Andrea Arcangeli <aarcange@redhat.com> [ Additionally remove the now stale test for pmd_trans_huge() inside the pmd_bad() case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-20Merge tag 'renesas-fixes-for-v3.13' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes From Simon Horman: Renesas ARM based SoC fixes for v3.13 * r8a7790 (R-Car H1) SoC - Correct GPIO resources in DT. This problem has been present since GPIOs were added to the r8a7790 SoC by f98e10c88aa95bf7 ("ARM: shmobile: r8a7790: Add GPIO controller devices to device tree") in v3.12-rc1. * irqchip renesas-intc-irqpin - Correct register bitfield shift calculation This bug has been present since the renesas-intc-irqpin driver was introduced by 443580486e3b9657 ("irqchip: Renesas INTC External IRQ pin driver") in v3.10-rc1 * Lager board - Do not build the phy fixup unless CONFIG_PHYLIB is enabled This problem was introduced by 48c8b96f21817aad * tag 'renesas-fixes-for-v3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: ARM: shmobile: r8a7790: Fix GPIO resources in DTS irqchip: renesas-intc-irqpin: Fix register bitfield shift calculation ARM: shmobile: lager: phy fixup needs CONFIG_PHYLIB Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-12-20Merge tag 'signed-for-3.13' of git://github.com/agraf/linux-2.6 into kvm-masterPaolo Bonzini
Patch queue for 3.13 - 2013-12-18 This fixes some grave issues we've only found after 3.13-rc1: - Make the modularized HV/PR book3s kvm work well as modules - Fix some race conditions - Fix compilation with certain compilers (booke) - Fix THP for book3s_hv - Fix preemption for book3s_pr Alexander Graf (4): KVM: PPC: Book3S: PR: Don't clobber our exit handler id KVM: PPC: Book3S: PR: Export kvmppc_copy_to|from_svcpu KVM: PPC: Book3S: PR: Make svcpu -> vcpu store preempt savvy KVM: PPC: Book3S: PR: Enable interrupts earlier Aneesh Kumar K.V (1): powerpc: book3s: kvm: Don't abuse host r2 in exit path Paul Mackerras (5): KVM: PPC: Book3S HV: Fix physical address calculations KVM: PPC: Book3S HV: Refine barriers in guest entry/exit KVM: PPC: Book3S HV: Make tbacct_lock irq-safe KVM: PPC: Book3S HV: Take SRCU read lock around kvm_read_guest() call KVM: PPC: Book3S HV: Don't drop low-order page address bits Scott Wood (1): powerpc/kvm/booke: Fix build break due to stack frame size warning pingfan liu (1): powerpc: kvm: fix rare but potential deadlock scene
2013-12-20Merge tag 'stable/for-linus-3.13-rc4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen bugfixes from Konrad Rzeszutek Wilk: - Fix balloon driver for auto-translate guests (PVHVM, ARM) to not use scratch pages. - Fix block API header for ARM32 and ARM64 to have proper layout - On ARM when mapping guests, stick on PTE_SPECIAL - When using SWIOTLB under ARM, don't call swiotlb functions twice - When unmapping guests memory and if we fail, don't return pages which failed to be unmapped. - Grant driver was using the wrong address on ARM. * tag 'stable/for-linus-3.13-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/balloon: Seperate the auto-translate logic properly (v2) xen/block: Correctly define structures in public headers on ARM32 and ARM64 arm: xen: foreign mapping PTEs are special. xen/arm64: do not call the swiotlb functions twice xen: privcmd: do not return pages which we have failed to unmap XEN: Grant table address, xen_hvm_resume_frames, is a phys_addr not a pfn
2013-12-20Merge tag 'trace-fixes-v3.13-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull ftrace fix from Steven Rostedt: "This fixes a long standing bug in the ftrace profiler. The problem is that the profiler only initializes the online CPUs, and not possible CPUs. This causes issues if the user takes CPUs online or offline while the profiler is running. If we online a CPU after starting the profiler, we lose all the trace information on the CPU going online. If we offline a CPU after running a test and start a new test, it will not clear the old data from that CPU. This bug causes incorrect data to be reported to the user if they online or offline CPUs during the profiling" * tag 'trace-fixes-v3.13-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ftrace: Initialize the ftrace profiler for each possible cpu
2013-12-20Merge tag 'omap-for-v3.13/display-fix' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes I accidentally removed some mux code for omap4 that I thought was dead code as omap4 has been booting with device tree only since v3.10. Turns out I also removed some display related mux code, so let's revert that except for the dead code parts. * tag 'omap-for-v3.13/display-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (439 commits) Revert "ARM: OMAP2+: Remove legacy mux code for display.c" +Linux 3.13-rc4
2013-12-19Merge tag 'keystone/maintainer-file' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/ssantosh/linux-keystone into fixes From Santosh Shilimkar: Couple of updates to MAINTAINERS file for Keystone - Add git tree information - Add clock drivers entry * tag 'keystone/maintainer-file' of git://git.kernel.org/pub/scm/linux/kernel/git/ssantosh/linux-keystone: MAINTAINERS: Add keystone clock drivers MAINTAINERS: Add keystone git tree information Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-12-19qla2xxx: Fix scsi_host leak on qlt_lport_register callback failureNicholas Bellinger
This patch fixes a possible scsi_host reference leak in qlt_lport_register(), when a non zero return from the passed (*callback) does not call drop the local reference via scsi_host_put() before returning. This currently does not effect existing tcm_qla2xxx code as the passed callback will never fail, but fix this up regardless for future code. Cc: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-12-19target: Remove extra percpu_ref_initAndy Grover
lun->lun_ref is also initialized in core_tpg_post_addlun, so it doesn't need to be done in core_tpg_setup_virtual_lun0. (nab: Drop left-over percpu_ref_cancel_init in failure path) Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-12-19arm64: ptrace: avoid using HW_BREAKPOINT_EMPTY for disabled eventsWill Deacon
Commit 8f34a1da35ae ("arm64: ptrace: use HW_BREAKPOINT_EMPTY type for disabled breakpoints") fixed an issue with GDB trying to zero breakpoint control registers. The problem there is that the arch hw_breakpoint code will attempt to create a (disabled), execute breakpoint of length 0. This will fail validation and report unexpected failure to GDB. To avoid this, we treated disabled breakpoints as HW_BREAKPOINT_EMPTY, but that seems to have broken with recent kernels, causing watchpoints to be treated as TYPE_INST in the core code and returning ENOSPC for any further breakpoints. This patch fixes the problem by prioritising the `enable' field of the breakpoint: if it is cleared, we simply update the perf_event_attr to indicate that the thing is disabled and don't bother changing either the type or the length. This reinforces the behaviour that the breakpoint control register is essentially read-only apart from the enable bit when disabling a breakpoint. Cc: <stable@vger.kernel.org> Reported-by: Aaron Liu <liucy214@gmail.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-12-19Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "An RT group-scheduling fix and the sched-domains topology setup fix from Mel" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/rt: Fix rq's cpupri leak while enqueue/dequeue child RT entities sched: Assign correct scheduling domain to 'sd_llc'
2013-12-19Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "An ABI documentation fix, and a mixed-PMU perf-info-corruption fix" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Document the new transaction sample type perf: Disable all pmus on unthrottling and rescheduling
2013-12-19Merge tag 'sound-3.13-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "We have a bit more changes than usual in ASoC here, as it was slipped from the previous update. There are one minr ASoC PCM code fix and ASoC dmaengine fix, in addition of a collection of small ASoC driver fixes. The rest are a couple of HD-audio stable fixups, and a long-standing fix for the paused stream handling. So, all commits look not scary (and hopefully won't give you disastrous holiday season)" * tag 'sound-3.13-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Add Dell headset detection quirk for one more laptop model ASoC: wm8904: fix DSP mode B configuration ASoC: wm_adsp: Add small delay while polling DSP RAM start ALSA: Add SNDRV_PCM_STATE_PAUSED case in wait_for_avail function ASoC: kirkwood: Fix the CPU DAI rates ASoC: wm5110: Correct HPOUT3 DAPM route typo ALSA: hda - Add Dell headset detection quirk for three laptop models ALSA: hda - Add enable_msi=0 workaround for four HP machines ASoC: don't leak on error in snd_dmaengine_pcm_register ASoC: fsl: imx-wm8962: Don't update bias_level in machine driver ASoC: tegra: fix uninitialized variables in set_fmt ASoC: wm8962: Enable SYSCLK provisonally before fetching generated DSPCLK_DIV ASoC: sam9x5_wm8731: change to work in DSP A mode ASoC: atmel_ssc_dai: add dai trigger ops ASoC: soc-pcm: Use valid condition for snd_soc_dai_digital_mute() in hw_free()
2013-12-19ARC: Allow conditional multiple inclusion of uapi/asm/unistd.hVineet Gupta
Commit 97bc386fc12d "ARC: Add guard macro to uapi/asm/unistd.h" inhibited multiple inclusion of ARCH unistd.h. This however hosed the system since Generic syscall table generator relies on it being included twice, and in lack-of an empty table was emitted by C preprocessor. Fix that by allowing one exception to rule for the special case (just like Xtensa) Suggested-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2013-12-19Merge tag 'asoc-v3.13-rc4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v3.13 The fixes here are all driver specific ones, none of which particularly stand out but all of which are useful to users of those drivers.
2013-12-19Merge remote-tracking branches 'asoc/fix/adsp', 'asoc/fix/arizona', ↵Mark Brown
'asoc/fix/atmel', 'asoc/fix/fsl', 'asoc/fix/kirkwood', 'asoc/fix/tegra', 'asoc/fix/wm8904' and 'asoc/fix/wm8962' into asoc-linus
2013-12-19Merge remote-tracking branch 'asoc/fix/dma' into asoc-linusMark Brown
2013-12-19Merge remote-tracking branch 'asoc/fix/core' into asoc-linusMark Brown
2013-12-19target/file: Update hw_max_sectors based on current block_sizeNicholas Bellinger
This patch allows FILEIO to update hw_max_sectors based on the current max_bytes_per_io. This is required because vfs_[writev,readv]() can accept a maximum of 2048 iovecs per call, so the enforced hw_max_sectors really needs to be calculated based on block_size. This addresses a >= v3.5 bug where block_size=512 was rejecting > 1M sized I/O requests, because FD_MAX_SECTORS was hardcoded to 2048 for the block_size=4096 case. (v2: Use max_bytes_per_io instead of ->update_hw_max_sectors) Reported-by: Henrik Goldman <hg@x-formation.com> Cc: <stable@vger.kernel.org> #3.5+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-12-19iser-target: Move INIT_WORK setup into isert_create_device_ib_resNicholas Bellinger
This patch moves INIT_WORK setup for cq_desc->cq_[rx,tx]_work into isert_create_device_ib_res(), instead of being done each callback invocation in isert_cq_[rx,tx]_callback(). This also fixes a 'INFO: trying to register non-static key' warning when cancel_work_sync() is called before INIT_WORK has setup the struct work_struct. Reported-by: Or Gerlitz <ogerlitz@mellanox.com> Cc: <stable@vger.kernel.org> #3.12+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-12-19iscsi-target: Fix incorrect np->np_thread NULL assignmentNicholas Bellinger
When shutting down a target there is a race condition between iscsit_del_np() and __iscsi_target_login_thread(). The latter sets the thread pointer to NULL, and the former tries to issue kthread_stop() on that pointer without any synchronization. This patch moves the np->np_thread NULL assignment into iscsit_del_np(), after kthread_stop() has completed. It also removes the signal_pending() + np_state check, and only exits when kthread_should_stop() is true. Reported-by: Hannes Reinecke <hare@suse.de> Cc: <stable@vger.kernel.org> #3.12+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-12-18Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge patches from Andrew Morton: "23 fixes and a MAINTAINERS update" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (24 commits) mm/hugetlb: check for pte NULL pointer in __page_check_address() fix build with make 3.80 mm/mempolicy: fix !vma in new_vma_page() MAINTAINERS: add Davidlohr as GPT maintainer mm/memory-failure.c: recheck PageHuge() after hugetlb page migrate successfully mm/compaction: respect ignore_skip_hint in update_pageblock_skip mm/mempolicy: correct putback method for isolate pages if failed mm: add missing dependency in Kconfig sh: always link in helper functions extracted from libgcc mm: page_alloc: exclude unreclaimable allocations from zone fairness policy mm: numa: defer TLB flush for THP migration as long as possible mm: numa: guarantee that tlb_flush_pending updates are visible before page table updates mm: fix TLB flush race between migration, and change_protection_range mm: numa: avoid unnecessary disruption of NUMA hinting during migration mm: numa: clear numa hinting information on mprotect sched: numa: skip inaccessible VMAs mm: numa: avoid unnecessary work on the failure path mm: numa: ensure anon_vma is locked to prevent parallel THP splits mm: numa: do not clear PTE for pte_numa update mm: numa: do not clear PMD during PTE update scan ...
2013-12-18mm/hugetlb: check for pte NULL pointer in __page_check_address()Jianguo Wu
In __page_check_address(), if address's pud is not present, huge_pte_offset() will return NULL, we should check the return value. Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mgorman@suse.de> Cc: qiuxishi <qiuxishi@huawei.com> Cc: Hanjun Guo <guohanjun@huawei.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18fix build with make 3.80Jan Beulich
According to Documentation/Changes, make 3.80 is still being supported for building the kernel, hence make files must not make (unconditional) use of features introduced only in newer versions. Commit 1bf49dd4be0b ("./Makefile: export initial ramdisk compression config option") however introduced "else ifeq" constructs which make 3.80 doesn't understand. Replace the logic there with more conventional (in the kernel build infrastructure) list constructs (except that the list here is intentionally limited to exactly one element). Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: P J P <ppandit@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm/mempolicy: fix !vma in new_vma_page()Wanpeng Li
BUG_ON(!vma) assumption is introduced by commit 0bf598d863e3 ("mbind: add BUG_ON(!vma) in new_vma_page()"), however, even if address = __vma_address(page, vma); and vma->start < address < vma->end page_address_in_vma() may still return -EFAULT because of many other conditions in it. As a result the while loop in new_vma_page() may end with vma=NULL. This patch revert the commit and also fix the potential dereference NULL pointer reported by Dan. http://marc.info/?l=linux-mm&m=137689530323257&w=2 kernel BUG at mm/mempolicy.c:1204! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC CPU: 3 PID: 7056 Comm: trinity-child3 Not tainted 3.13.0-rc3+ #2 task: ffff8801ca5295d0 ti: ffff88005ab20000 task.ti: ffff88005ab20000 RIP: new_vma_page+0x70/0x90 RSP: 0000:ffff88005ab21db0 EFLAGS: 00010246 RAX: fffffffffffffff2 RBX: 0000000000000000 RCX: 0000000000000000 RDX: 0000000008040075 RSI: ffff8801c3d74600 RDI: ffffea00079a8b80 RBP: ffff88005ab21dc8 R08: 0000000000000004 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: fffffffffffffff2 R13: ffffea00079a8b80 R14: 0000000000400000 R15: 0000000000400000 FS: 00007ff49c6f4740(0000) GS:ffff880244e00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007ff49c68f994 CR3: 000000005a205000 CR4: 00000000001407e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 Stack: ffffea00079a8b80 ffffea00079a8bc0 ffffea00079a8ba0 ffff88005ab21e50 ffffffff811adc7a 0000000000000000 ffff8801ca5295d0 0000000464e224f8 0000000000000000 0000000000000002 0000000000000000 ffff88020ce75c00 Call Trace: migrate_pages+0x12a/0x850 SYSC_mbind+0x513/0x6a0 SyS_mbind+0xe/0x10 ia32_do_call+0x13/0x13 Code: 85 c0 75 2f 4c 89 e1 48 89 da 31 f6 bf da 00 02 00 65 44 8b 04 25 08 f7 1c 00 e8 ec fd ff ff 5b 41 5c 41 5d 5d c3 0f 1f 44 00 00 <0f> 0b 66 0f 1f 44 00 00 4c 89 e6 48 89 df ba 01 00 00 00 e8 48 RIP [<ffffffff8119f200>] new_vma_page+0x70/0x90 RSP <ffff88005ab21db0> Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reported-by: Dave Jones <davej@redhat.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Bob Liu <bob.liu@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18MAINTAINERS: add Davidlohr as GPT maintainerDavidlohr Bueso
Add a new entry for the GPT standard. Any future changes will now be routed through linux-efi. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Matt Fleming <matt.fleming@intel.com> Cc: Jens Axboe <axboe@kernel.dk> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
