This reverts commit 56b19bb4034bef0952d41e5675d7eab3174c9d39.
Change-Id: I32bb1469171d5161f779e95cdf49c343c35f37f8
Signed-off-by: Harry Hong <hhong@nvidia.com>
Reviewed-on: http://git-master/r/437006
Add log to indicate the power key event.
Update the log info to be self-explanatory.
Bug 200011910
Bug 200012680
Change-Id: Ic06878fc65402c0b4d585967b0f0c7a22e41935c
Signed-off-by: Danny Song <dsong@nvidia.com>
Reviewed-on: http://git-master/r/423608
this is to trigger automatic build
Change-Id: I6771e649d9c42d6b602cca8f7d36e2511c4b0f7b
Reviewed-on: http://git-master/r/423567
LDO4 is turned on from bootloader to meet TS power on sequence.
Bug 200006060
Change-Id: Ic5ece836d940e763da7c6a176bbe33efae6b706b
Signed-off-by: David Pu <dpu@nvidia.com>
Reviewed-on: http://git-master/r/419977
Reviewed-by: Harry Hong <hhong@nvidia.com>
Tested-by: Harry Hong <hhong@nvidia.com>
added 6s delay to fork touch_fusion process to make sure hardware is
ready before calibration.
Bug 200006060
Change-Id: I6b24d2e4a7fa85165c76eb5badb7538e40021e7f
Reviewed-on: http://git-master/r/423472
GVS: Gerrit_Virtual_Submit
Reviewed-by: Gabby Lee <galee@nvidia.com>
Tested-by: Gabby Lee <galee@nvidia.com>
This reverts commit 15f372c27c5c5803a3b129e9fd5bfdc791f701ba.
Bug 200006060
arch/arm/mach-tegra/board-tegranote7c-power.c
Change-Id: I09087bd7dd0c5b3bf8e203f1ec0ae24c90d665ea
Change-Id: Id83812e5ee6bb2d12294b8b6c9bf0da7b0f8dbe4
Reviewed-on: http://git-master/r/423469
Bug 200011910
Bug 200012680
Change-Id: I462d4f1655529c0e964b77812d55d248be541eec
Reviewed-on: http://git-master/r/422752
USB host/device mode eye diagram calibration
host mode using +3 offset for XCVR setup parameter.
device wiht no offset adjustment, but set bit[7:6]
into 01 for slew rate calibration.
Bug 1457966
Bug 1459798
Bug 200010446
Change-Id: Ieae4607d4bc51fa3aa83197318eaec04fd941a8f
Reviewed-on: http://git-master/r/421410
Bug 200006060
Change-Id: I2ad2fb5b287f9c66fdff7d4123dec2e1c7476e77
Reviewed-on: http://git-master/r/419337
Reviewed-by: Danny Song <dsong@nvidia.com>
Tested-by: Danny Song <dsong@nvidia.com>
Enable the GPIO for headset detection work as LP0 wake source.
Bug 1499477
Change-Id: I91ae32f8d687f3de4548b23464072e24adacb201
Signed-off-by: Lei Fan <leif@nvidia.com>
Reviewed-on: http://git-master/r/396887
Reviewed-by: Vijay Mali <vmali@nvidia.com>
Reviewed-by: Martin Chi <mchi@nvidia.com>
Reviewed-on: http://git-master/r/409967
Remove a GPIO for headset detection form the list of LP0 wake source
Bug 1499477
Change-Id: Ie0331079072f2976265d5db1483cd905f0c1f2bc
Reviewed-on: http://git-master/r/396879
Reviewed-on: http://git-master/r/409966
Realtek codec rt5639 needs 400ms delay between signal LDO1_EN and Initial.
Previous 200ms is not enough, increase it to 450ms
Bug 200005748
Change-Id: I0a11ed8dd064d720631dc6f09de220e87a529a1a
Signed-off-by: ximingc <ximingc@nvidia.com>
Reviewed-on: http://git-master/r/415157
1) Revert "ts :tn7c: support load switch for touch power rail"
2) Remove useless fix regulator: dvdd_ts and dvdd_lcd_1v8(which
would cause lcd and touch use differnt supplies but same ldo4)
3) Enable avdd first
Bug 200006060
Bug 1445143
This reverts commit 8b8d45d48da349159b2006202e13eea1bc652d51.
Change-Id: I807a57ccb2828c53648be6189846a0d734d52e82
Signed-off-by: Nine Feng <nfeng@nvidia.com>
Reviewed-on: http://git-master/r/414671
Reviewed-by: David Pu <dpu@nvidia.com>
SCAN_COLUMN works on the input, filters work on the output. Only input
settings need to be swapped when in SCAN_COLUMN mode (270/90 rotation).
This removes an inadvertant swap of H and V for the filter capabilities.
Bug 1421307
Bug 1413155
Bug 1482737
Change-Id: I53017429fe4f554517ad9e054a0116582585bb56
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/403755
(cherry picked from commit f2d3ce1df0ccd8401aab554853401b5e3afa6859)
Signed-off-by: David Yu <davyu@nvidia.com>
Reviewed-on: http://git-master/r/412020
When determining if the filter should be disabled because input == output,
use the SCAN_COLUMN flag to select the correct dimension.
Bug 1421307
Bug 1413155
Bug 1482737
Change-Id: I19dd5575fb41d8a2b6aa3ee12022acd14232afe4
Reviewed-on: http://git-master/r/340037
(cherry picked from commit 08f1bbbfd9c7484d38db8f4eac3868fa0e9d22c3)
Reviewed-on: http://git-master/r/412018
This reverts commit f08b3a1c970f72c6978979936d117b694ecaeba6.
Change-Id: I078f73db95a55eb56ad0cf44fe612a6f2d10d390
Reviewed-on: http://git-master/r/412015
reduce reserved mem size for fb0 according to lcd resolution.
Bug 200002039
Change-Id: I6931d99ce7c62348c294b8de475e73d3554dfbfd
Reviewed-on: http://git-master/r/412527
Reviewed-by: Min-wuk Lee <mlee@nvidia.com>
Bug 1502030
Change-Id: I48587826212a670b694801b704907bfb8e2f051c
Reviewed-on: http://git-master/r/399386
Reviewed-by: Yong Goo Yi <yyi@nvidia.com>
Reviewed-by: Jinyoung Park <jinyoungp@nvidia.com>
Bug 1478633
Bug 1493749
Change-Id: Ifc89ae12cdb1cb08ffe98d030099a2c7e3823f11
Reviewed-on: http://git-master/r/398060
Bug 1491475
Change-Id: Id5e78b62202d3392911aeb2f9ab820fac50f8969
Reviewed-on: http://git-master/r/392788
(cherry picked from commit c175c99cb831678851de5cf64f3b5a0ed14b1ed4)
Reviewed-on: http://git-master/r/396866
Remove unused baseband configs
Remove unused BCM configs
Remove unused NFC configs / Add NXP PN533 USB NFC driver
Remove unused RTC configs
Remove unused touchscreen configs
Move MPU and AKM from modules to static binary
Bug 1491475
Change-Id: I53d1ef8362ca70aebd3f7afd2faa3516b6e1b06c
Reviewed-on: http://git-master/r/392232
(cherry picked from commit e6498745f12f4266fa366638a2aeb9177b5406ee)
Reviewed-on: http://git-master/r/396864
During HSIC resume the PD_TX circuit is to be turned on before
clearing MASTER_ENABLE of PMC.
Bug 1491453
Change-Id: I26c30fc241f638411b94f45b28f155b4eeabdaea
Signed-off-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-on: http://git-master/r/395472
Tested-by: Martin Chi <mchi@nvidia.com>
This reverts commit 01f05993129d269b9ee10311a66da6d9fec4e8a8.
Change-Id: Ic3d0bd1051905e8f9a5af9f7f8a97f0e72fe128b
Signed-off-by: Martin Chi <mchi@nvidia.com>
Reviewed-on: http://git-master/r/395471
Increase touch AVDD voltage for TegraNote TN7 and TN7C.
Bug 1478633
Bug 1493749
Change-Id: Id07da3f101ee8f2d42abf5ba0a2d1487bafdec6f
Signed-off-by: Robert Collins <rcollins@nvidia.com>
Reviewed-on: http://git-master/r/392032
Reviewed-by: David Jung <djung@nvidia.com>
Tested-by: David Jung <djung@nvidia.com>
bug 1491453
Change-Id: I4c2bc1bdc33fb3669a06f02b136366816c35d1cb
Reviewed-on: http://git-master/r/392236
Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-by: Rui Zhuo <rzhuo@nvidia.com>
Tested-by: Rui Zhuo <rzhuo@nvidia.com>
Bug 1489970
Change-Id: I8c2e13b5671cfa9f8d3c1237ae81c2195fea613f
Signed-off-by: Vijay Mali <vmali@nvidia.com>
Reviewed-on: http://git-master/r/391712
This reverts commit 5c7cb1dd558fa95521cce4416976157bc13f9d9a.
Bug 1470687
Change-Id: I5b0b47e5cd109607e6e8c98355a3deacd3093b52
Signed-off-by: Simon Je <sje@nvidia.com>
(cherry picked from commit c0e40b1c45c8c1c8fdf19829d6dd38dd9c90f503)
Reviewed-on: http://git-master/r/391602
use tuned tskin parameter for fairfax device according to
macro CONFIG_FAIRFAX_TSKIN
bug 1482306
Change-Id: I2f686edc6f6377958724a329f579d0994b3ca508
Signed-off-by: qtang <qtang@nvidia.com>
Reviewed-on: http://git-master/r/387644
Bug 1461802
Change-Id: Ic49106b81775e5b29bd4db9d453b164ad3f5010c
Reviewed-on: http://git-master/r/387619
Some USB cable connection disturb USB ID pin to GND at a short time.
Add debounce time to skip short USB ID signal.
Bug 1482314
Change-Id: I1bc64b05f102fd0b376b1a8de99bb4cda6e37ec1
Signed-off-by: Hyong Bin Kim <hyongbink@nvidia.com>
(cherry picked from commit 526660bdeb28f009cbd635bfcf8b829f3223b5c2)
Reviewed-on: http://git-master/r/385476
Reviewed-by: Tao Hu (SW-TEGRA) <taoh@nvidia.com>
Disable EDP for HP's request.
Bug 1473466
Change-Id: I438f0248a747f1f5bc9ab6c9bd6ebf956a0daf28
Signed-off-by: ericz <ericz@nvidia.com>
Reviewed-on: http://git-master/r/385510
Then audio path for tone is not disconneted during voice call and it
will cause error at the end of the next voice call.
Bug 1476086
Change-Id: I586e008145370e26b93aa11ebcb70e7efc361015
Reviewed-on: http://git-master/r/385518
Bug 1476086
Change-Id: Ia368e64b59d601124b33abaa4b53aa7f6d321d44
Reviewed-on: http://git-master/r/385535
Reviewed-by: Lei Fan <leif@nvidia.com>
For safety, reduce charge mode display value.
Bug 1470109
Change-Id: Iab1e11871ba82fc0cdd7b8889c0fee3087f1a3fc
Reviewed-on: http://git-master/r/383888
(cherry picked from commit ad41a0b69fa60bd9b50f0a253104f277d8b683df)
Reviewed-on: http://git-master/r/384822
Bug 1468114
Bug 1432052
Change-Id: I534295b63540d3a5604d92f9f5f3c7237edfec77
Reviewed-on: http://git-master/r/380377
Maxim code drop to update delay for legacy irq.
Bug 1478046
Change-Id: Id3c0f0e173f7b46afcdca7c7c29aa2e2c0bdaec6
Signed-off-by: David Jung <djung@nvidia.com>
Reviewed-on: http://git-master/r/382243
Reviewed-by: Youngjin Kim <nkim@nvidia.com>
Set usb.emc 100MHz but if type is HSIC, remain to 200MHz
Bug 1466876
Change-Id: I9933090ab33e7ab7e394bdf53607d0a2707e99d1
Reviewed-on: http://git-master/r/383802
Reviewed-by: Hyong Bin Kim <hyongbink@nvidia.com>
Tested-by: Hyong Bin Kim <hyongbink@nvidia.com>
Bug 1482346
Change-Id: I44b56956441f38416aee7a986229707687e27d6f
Reviewed-on: http://git-master/r/383138
Bug 1482346
Change-Id: I7472fb40f93833196af9969c08d62466dcc6d31f
Reviewed-on: http://git-master/r/382838
Bug 1439626
Change-Id: Iff23da5367b426ade1875f50cf5a3bdfa4441544
Reviewed-on: http://git-master/r/382407
On TN7C, these pins has nothing to do with codec.
They are actually connecting to modem as:
TEGRA_GPIO_PP3 --> AP_WAKE_MDM
TEGRA_GPIO_PP1 --> W_DISABLE_N
Change-Id: I509c3ce017036f2cd3e2d72a08a23605fd73084d
Reviewed-on: http://git-master/r/382441
Tested-by: Lei Fan <leif@nvidia.com>
Reviewed-by: Gray Lei <glei@nvidia.com>
Bug 1438727
Change-Id: I4aa2c704e3223352f26834bee172116d151d75e4
Reviewed-on: http://git-master/r/382396
Removed 1Hz margin from target rate request during PLL resume.
Although the PLL output rate is restored correctly in any case, PLL
dividers settings may differ from tabulated targets (if any) when non
exact rate is requested.
Bug 1473597
Change-Id: I5307ee49fcac4ce6dc6b3c38d1841629060700d7
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/379620
(cherry-picked from 96a02b52db51498756967864d9c5a3596f812570)
Reviewed-on: http://git-master/r/381927
Set the suspended flag to true during bootup. With
this vbus/id notifications will be ignored until
gadget driver is ready.
Bug 1473703
Change-Id: If20245f8056ec7da8f4d9a1fe463378992fff6ca
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/381971
it is sw WAR to fix screen flicker when charging.
Bug 1480539
Bug 1475028
Bug 1480536
Change-Id: I0115aec93149997cf6f10ba1b4a740427eddbdba
Reviewed-on: http://git-master/r/381897
Bug 1475028
Bug 1480536
Change-Id: I3cf660157d34b4e8ebdd6235cc38c86ea9210657
Reviewed-on: http://git-master/r/381329
- Change LED pulse count from 4 to 8 according to vendor
suggestion.
- Assume enable routine is called in uncovering state,
and collect ps_data to calibrate high and low threshold.
- Export distance node, 1 : near, 0 : far.
Bug 1472752
Bug 1470053
Change-Id: I8b749a243d7f03e3c85316c08a67c1bb3ac0cd35
Signed-off-by: Chen Jian <jackchen@nvidia.com>
Reviewed-on: http://git-master/r/378341
add 10ms delay in hsic phy resume for auto-resume
bug 1476774
Change-Id: I54d0b46347084b3e41520f4c0f878a1336b54931
Reviewed-on: http://git-master/r/380736
disable pmc remote wake-up detection in usb resume
to prevent the pmc remote wake-up during usb
auto-resume, otherwise, the concurrent resume may
cause hsic bus entering unexpected state and
cause 'XactErr' errs.
bug 1476774
Change-Id: I0d2babbb196208b454c3de31492a703dafeb6629
Reviewed-on: http://git-master/r/380735
Bug 1464185
Change-Id: I80830cbafbca43161bc6e1c4e9cdd9e599e551e5
Signed-off-by: Tao Hu <taoh@nvidia.com>
Reviewed-on: http://git-master/r/374118
Reviewed-by: David Yu (Engrg-SW) <davyu@nvidia.com>
