Increae timeout value for sanitize operation
based on Hynix 16GB emmc Max delay.
Bug 1453048
Change-Id: I2509de6613f0fd3c52ea2fa361b96bd8e3806bbf
Signed-off-by: Harry Hong <hhong@nvidia.com>
Reviewed-on: http://git-master/r/366290
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
GVS: Gerrit_Virtual_Submit
This changes adds condition to check ep->desc
before accessing its contents. ep->desc seems to
get Null on releasing the spin_lock.
Bug 1401730
Change-Id: I48b4c880ced0cd131bd45840839e6635fc1a219c
Signed-off-by: Rohith Seelaboyina <rseelaboyina@nvidia.com>
Reviewed-on: http://git-master/r/362353
(cherry picked from commit 790be48ddf070df3e6357b4e290d8fb4c603a34e)
Reviewed-on: http://git-master/r/363103
Reviewed-by: Harry Hong <hhong@nvidia.com>
Tested-by: Harry Hong <hhong@nvidia.com>
Sometime the BT voice call cannot be broken because the method has bug
which is used to judge current call is BT call or not.
In fact we can make HAL use other control to set BT voice call.
Bug 1443353
Change-Id: I45f7cf876b4e7e53e94aab0a4984bb95d4885701
Signed-off-by: Lei Fan <leif@nvidia.com>
Reviewed-on: http://git-master/r/360827
Reviewed-by: Vijay Mali <vmali@nvidia.com>
Reviewed-by: Martin Chi <mchi@nvidia.com>
Bug 1432052
Change-Id: I1a90dc0098b6deec89c2062c60661ad19b62fc39
Signed-off-by: Nine Feng <nfeng@nvidia.com>
Reviewed-on: http://git-master/r/359258
Reviewed-by: Danny Song <dsong@nvidia.com>
Tested-by: Danny Song <dsong@nvidia.com>
don't boost cpu freq to 816MHz blindly from ehci layer for usb host
instance 1(Bruce Modem).
Bug 1441442
Change-Id: I73d925186976095b62267a806bce30e906202833
Signed-off-by: David Pu <dpu@nvidia.com>
Reviewed-on: http://git-master/r/360253
lcd power rail of EN_LCD_1V8 is shared with touch
module. We should make sure it is enabled before
touch suspend. Therefore, we add a new consumer
for lcd fix regulator, then it would be more
reasonable to turn off/on in terms of use counts.
Bug 1445143
Change-Id: Ieef0fc9ae46918c724d6129f9878be12641f66d0
Reviewed-on: http://git-master/r/360705
remove pm qos request when acm disconects,
otherwise, pm_qos_add_request() will be called
again as it's already added, and then cause some
kernel warning
bug 1448534
Change-Id: I16d0cd823132ac79cc03bd1fc53d12114d6ceb0e
Signed-off-by: Martin Chi <mchi@nvidia.com>
Reviewed-on: http://git-master/r/360679
For TN7C, set PULL_DOWN for gyro irq pin (KB_ROW3)
in LP0 to avoid current leakage
bug 1437281
Change-Id: Icfce785d06bed5769155342154aedfb5a8725d9a
Reviewed-on: http://git-master/r/355908
Bug 1431360
Bug 1443158
Change-Id: Id3654deb1012d0b0826dbf2a11287a000234fd27
Reviewed-on: http://git-master/r/349890
Signed-off-by: Jajambo Liao <jajambol@nvidia.com>
Reviewed-on: http://git-master/r/358110
(cherry picked from commit ed6a521e79b8faadd945e686f6cd415e64221387)
Signed-off-by: Jake Park <jakep@nvidia.com>
Reviewed-on: http://git-master/r/361184
Reviewed-by: Gabby Lee <galee@nvidia.com>
Originally, the dvfs table in ram_code 0 is Hynix
dvfs, and the dvfs table in ram_code 1 is Micron
dvfs, this is not correct.
This change swap the two dvfs table and correct
above mistake
bug 1438727
Change-Id: If2b50061166c5f96cf3d2a2b2b70f23dbf8327b0
Reviewed-on: http://git-master/r/360798
- according to calibration result, adjust high/low threshold
to trigger interrupt.
Change-Id: Id14f76cf999b6e6bb7714e5f4ef0e731f3979b72
Signed-off-by: Chen Jian <jackchen@nvidia.com>
Reviewed-on: http://git-master/r/360803
Passing speedo id from sdhci platform data. Speedo id is required
for some calculation in auto tuning.
Set trim delay of SDMMC4 to 3 as per the characterization team
recommendations.
Bug 1423423
Reviewed-on: http://git-master/r/352307
(cherry picked from commit a628fadf080a26d5cedb528d083b1007217072a8)
Change-Id: Icfce5614d410e2770344897ace5c1a9adabca8d8
Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-on: http://git-master/r/356524
Implemented the new tuning algorithm that
- Removes the tap holes from auto tuning windows
- Adjust window ends with margins for Vmin for the corresponding freq
- Dynamically updates dvfs table entry if a new Vmin is found from
auto tuning calculations
- Calculates the best tap value from the windows after removing tap
holes and margin additions.
Disabling external loopback clock for SDMMC3 as per characterization
results.
Bug 1423423
Reviewed-on: http://git-master/r/352306
(cherry picked from commit 26615d96514fc9ccbdcdc9ab89d92def5c1bf977)
Change-Id: I56fd58473ab5b7642d703fc17f0afd5820fe64ea
Reviewed-on: http://git-master/r/356523
Exposing the tegra_dvfs_predict_millivolts interface to drivers to be
used during tuning and getting the minimum core voltage for a given
frequency.
Bug 1423423
Reviewed-on: http://git-master/r/350418
(cherry picked from commit b604de0416eab8e8c32ad9e482fd64d831fb9449)
Change-Id: Icc6492c6d91315020eaec3668e259c523acb218c
Reviewed-on: http://git-master/r/356522
Added interface to specify clock fmax/vmin limits at run-time. Calling
this interface updates frequencies in the respective DVFS table to be
consistent with the new limits (voltage ladder is preserved):
- for voltages below new vmin, the respective frequencies are shifted
below new fmax to the levels already present in the table; if the 1st
table entry has frequency above new fmax, all entries below vmin
are filled in with 1kHz (min rate used in DVFS tables).
- for voltages above new vmin, the respective frequencies are set at
or above new fmax (not necessarily present in DVFS table before)
- if new vmin is already in the table the respective frequency is set
to new fmax (not necessarily present in DVFS table before)
Since, such update may result in changing voltage requirement up at
the same clock frequency, the interface can be called only for clocks
that are allowed to override core voltage (SDMMC on tegra platforms),
and only if core voltage is already overridden to the level higher
than new vmin.
Bug 1423423
Reviewed-on: http://git-master/r/348351
(cherry picked from commit 1dc582f4488beeaea7e859496034a25300b1cb0b)
Signed-off-by: Alex Frid <afrid@nvidia.com>
Change-Id: I4f61ea6e3f8b6792ed058509339e16bff1947104
Reviewed-on: http://git-master/r/356521
Bug 1423423
Reviewed-on: http://git-master/r/348350
(cherry picked from commit 44a97884ff4552ae245e58c7848839b49df8944f)
Change-Id: I19c476cb79bbc3bde528212a80054ddbd9488aea
Reviewed-on: http://git-master/r/356520
Set smps7 to 1.38V for E1569-ERS has Micron 1GB
Change-Id: I1f55e0b2bf96d6efed04e301b800a52e4d23fbb7
Signed-off-by: Yong Goo Yi <yyi@nvidia.com>
Reviewed-on: http://git-master/r/360389
Reviewed-on: http://git-master/r/281633
(cherry picked from commit ded9998ea6e78a3fc2b5be4c12bdb716a0612089)
Reviewed-on: http://git-master/r/348349
(cherry picked from commit 0e1f1108a562be22d41e5c1b19ace29d7696461c)
Change-Id: I94eef4ca0f1610975ae5742ce6d64e05ff76cb1d
Reviewed-on: http://git-master/r/356519
- Only enable/disable regulator when sensor
is enabled/disabled.
Bug 1446066
Change-Id: I5bff3066f47cbd08e7f88309ec65b41b69763367
Reviewed-on: http://git-master/r/360408
Reviewed-by: David Pu <dpu@nvidia.com>
Tested-by: David Pu <dpu@nvidia.com>
Keep power rail on unless otherwise specified on shutdown.
Bug 1445876
Change-Id: I5a0309226177c10ab52f25703c7133be63faa6b4
Signed-off-by: David Yu <davyu@nvidia.com>
Reviewed-on: http://git-master/r/360385
is used""
This reverts commit 866353859bcd3328dd0be84e0f0ed6d1ba834772. Moving back
suspend and resume to dev_pm_ops to ensure that bus suspend is done before
device suspend and bus resume is done after device resume. Without bus
suspend and resume, there is a chance of some requests being scheduled
after device suspend or before device resume is done.
Bug 1381236
Bug 1446176
Reviewed-on: http://git-master/r/309656
(cherry picked from commit de13dd1f8b0d802914ec4143c42730d4f90f880b)
Change-Id: I842b1e042982f8ac0547936800bbc996643c7d34
Signed-off-by: Naveen Kumar Arepalli <naveenk@nvidia.com>
Change-Id: I7b72b956a617762741854d49b4560d3848cf2b12
Reviewed-on: http://git-master/r/326379
Reviewed-by: R Raj Kumar <rrajk@nvidia.com>
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Change-Id: I0cc4d85c879dcedf671f14a83978524cd0c7f287
Signed-off-by: Ximing Chen <ximingc@nvidia.com>
Reviewed-on: http://git-master/r/360331
Tested-by: Martin Chi <mchi@nvidia.com>
TegraNote7C supports two different DDRs:
RAM_CODE[1:0] = 0x00 -> Micron DDR3L 1GB
RAM_CODE[1:0] = 0x01 -> Hynix DDR3L 1GB
Bug 1438727
Change-Id: Ib4b6f2d38b2667dea1167417ba84388f9739414e
Reviewed-on: http://git-master/r/360204
http://nvbugs/1438727/10
bug 1438727
Change-Id: I8280c79ec88c62a329de7f3d4b46f2623f57887e
Reviewed-on: http://git-master/r/360203
RAM_CODE[1:0]=0x00, Micron DDR3L, requires 1.38V
RAM_CODE[1:0]=0x01, Hynix DDR3L, requires 1.35V
bug 1438727
Change-Id: I8cfe9e7220f197bcf6e00b91c5d354c3eda8b3f0
Reviewed-on: http://git-master/r/360198
This reverts commit d9b262e497e4d760f6c2eea595da6845f8fc4b23.
Change-Id: Iaba5e51ce2b340891c2f4746ae401ecb8dbbcc16
Reviewed-on: http://git-master/r/359766
Set NO_HANGUP_IN_RESET_RESUME flag to Bruce model to
prevent tty hangup during reset resume procedure.
Bug 1446181
Change-Id: I3866e49e8c36ec8627791cd63a237b3bca63e0b9
Signed-off-by: glei <glei@nvidia.com>
Reviewed-on: http://git-master/r/359777
Cut modem buck-boost circuit power if modem part is not inserted.
MDM_APACK2 (gpio input) 0 : modem inserted
1 : not inserted
MODEM_EN (gpio output) 0 : power off
1 : power on
Bug 1443384
Change-Id: Ib79d7c673d98d75dd8294f1568537080b1a65a83
Signed-off-by: ximingc <ximingc@nvidia.com>
Reviewed-on: http://git-master/r/359626
User space can control the output value.
Output 0 to cut power of modem buck-boost circuit.
echo 0 > /sys/class/gpio/gpio122/value
Bug 1443384
Change-Id: I673a1e86099774ecf3ce1c235333abc91217eb6f
Reviewed-on: http://git-master/r/359212
GPIO_PQ1(KB_COL1) needs to re-configure in LP0 state.
Bug 1439735
Change-Id: I5a18136c537e7a6938e19f4e834bde61846c1161
Some GPIO pins need re-configure when system enters LP0
Bug 1439735
Change-Id: I3d9c864b5c099ab834543e2f3c905cab8a957372
Some GPIO pins need re-configure while system enters LP0.
Bug 1439735
Change-Id: I2d21e4119c7a9d762db17b0b753ba12781547a27
Reviewed-on: http://git-master/r/359078
Considering shutdown of the card, the responsibility to initate this
sequence shall be driven from the mmc_bus.
This patch enables the mmc_bus to handle this sequence properly. A new
.shutdown callback is added in the mmc_driver struct which is used to
shutdown the blk device.
Bug 1445876
Change-Id: I947315a7102606a1873eeebf136d741c98b46c76
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
Reviewed-on: http://git-master/r/359692
Fix mmc command error caused by early regulator shutdown.
Bug 1445876
Change-Id: I446dba2b216ca6fdebf38aa7d1afaf88370b5bee
Reviewed-on: http://git-master/r/359698
Bug 1445863
Change-Id: I6d58eed1ffbfc4012f2e4543a87d5f06e59542a7
Reviewed-on: http://git-master/r/359590
Because the channel1 of DAM is used for DL, there is no SRC in DL.
the codec need to be set the same rate with baseband.
Otherwise the I2S Timing REG cannot get the suited value and
left channel may be swapped with right channel.
Bug 1441449
Change-Id: Ib71bb41a7e03d2a85d718be0c94a5a5f525c0ce3
Reviewed-on: http://git-master/r/358078
Disable USB_WAKE_ON_CNNT_EN_DEV bit during phy_power_off for HSIC
Bug 1430974
Change-Id: I545c7cc0f1b87f4540554b3d7e5e9cca89ea2411
Signed-off-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-on: http://git-master/r/359109
For now, only apply it in tegra_ehci_irq when it's
triggered by remote wake-up irq, since, without
wake lock hold here, device may continue the
suspend if remote wake-up comes in suspending.
bug 1431546
Change-Id: I44ea268ca168a1a3a9098ad9f5f6f7b1270a0fa5
Reviewed-on: http://git-master/r/359090
Chnage ehci suspend/resume to noirq suspend/resume
to enable it get more chances to handle the remote
wake-up which may come after normal suspend/resume
bug 1430974
Change-Id: I0e27435c729b515c968990507a1d6ab53c4ce37a
Reviewed-on: http://git-master/r/359052
This change add the capability to override hs_curr_level value read
from usb_calib0 fuse register. Some board designs need different
hs_curr_level value to optimize USB 2.0 signals.
bug 1340062
Change-Id: Ic2435dc1b8c85bea507144558267b8bd29c2dad0
Reviewed-on: http://git-master/r/281745
(cherry picked from commit 938d7343c0f835772aa0f50c9df6cb32ba6b0345)
arch/arm/mach-tegra/include/mach/xusb.h
Change-Id: I611dc365c27caad14d17cb95e4e0d469ec03cc62
Signed-off-by: JC Kuo <jckuo@nvidia.com>
Reviewed-on: http://git-master/r/358216
Reviewed-by: WK Tsai <wtsai@nvidia.com>
Reviewed-by: Joy Wang <joyw@nvidia.com>
Reviewed-by: Henry Lin <henryl@nvidia.com>
Reviewed-by: Ashutosh Jha <ajha@nvidia.com>
ULPI_DATA5 pin is not used in ERS and P1640,
but used to avoid avdd_hdmi_pll regulator leakage.
This pin needs to be selected according to
board selection.
Bug 1439626
Change-Id: I11f9305e718af28f221efae5cfcdd722e0098a29
Signed-off-by: Min-wuk Lee <mlee@nvidia.com>
Reviewed-on: http://git-master/r/358528
Bug 1439626
Change-Id: I621af6dfcc2977f2f30ce3bd7242d016f3eb89f1
Reviewed-on: http://git-master/r/358474
Set number of input devices back to 1 and disable
the mutual exclusion of finger and stylus.
Bug 1439868
Change-Id: I104cd8f4fa71c542399e61ae0015465638f27d3c
Signed-off-by: Youngjin Kim <nkim@nvidia.com>
Reviewed-on: http://git-master/r/356008
mutex_destroy to be called when the driver is removed.
BUG 1401358
Change-Id: Idb6703c01c41d241d8bdb67ca19c80a78c52b513
Reviewed-on: http://git-master/r/328852
(cherry picked from commit 739f06547bff816641eb998e6f109e64b614ebfe)
Reviewed-on: http://git-master/r/358170
For P1988, discharge unit for avdd_hdmi_pll
regulator is prepared and that is handled by
GPIO_PO6 pin. For other platforms like E1569,
P1640 do not have this unit.
This change selects proper avdd_hdmi_pll
regulator platform data according to board
selection.
Bug 1439626
Change-Id: I7515e8a4e4d57a491720fc0adbf7790c7c73a39c
Reviewed-on: http://git-master/r/358158
According to PG to adjust DEF and CTLE context save/restore
programming sequence on T114 rel17 branch.
Bug 1345950
Change-Id: Ie7ef0385ea70616ab69dd251d0b383cd9c62afa8
Signed-off-by: joyw <joyw@nvidia.com>
Reviewed-on: http://git-master/r/271323
(cherry picked from commit 107b3dc2c5feb25e14cf29328323a0dfdec717ce)
Reviewed-on: http://git-master/r/358118
Per UTMIP software guideline document, if xusb own OTG port0,
use xusb padctl register space to power on/off bias pad.
Bug 1334491
Bug 1242148
Change-Id: I28c7b9346b8332352fa53996769d6a76221b5ac4
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
(cherry picked from commit abb84051c9cf6e0709a752081ae2102e349e0955)
Reviewed-on: http://git-master/r/358100
Follow PG, enable host partition clock after unpowergate
host partition.
Bug 1333946
Change-Id: I47d7bfaedded3d8ca07edd9c1315ade2cccdc579
Reviewed-on: http://git-master/r/258633
(cherry picked from commit 02c7352077ef00448f12132478f46b106d4b3033)
Reviewed-on: http://git-master/r/280137
Reviewed-by: Riham Haidar <rhaidar@nvidia.com>
Tested-by: Riham Haidar <rhaidar@nvidia.com>
(cherry picked from commit d844bb935c1aaec4d873175cc8c2270c5247ed45)
Reviewed-on: http://git-master/r/358084
Chaning sys node of "enable" attr from 0x666 to 0x644
due to cts failure.
Bug 1443978
Change-Id: I41d03b8a39a553d8c210791086bbe440416e7415
Reviewed-on: http://git-master/r/358046
Provide a unified sysfs location so that init.xxx.rc
can change the permission without frequent update.
Change-Id: Ic35a122d96de60896f386a042d336ef5dd0a9765
Signed-off-by: Xiaohui Tao <xtao@nvidia.com>
Reviewed-on: http://git-master/r/263540
(cherry picked from commit 5a56bb9fce86683037a1689d137aa4416938d5c0)
Reviewed-on: http://git-master/r/358088
Bug 1439626
Change-Id: I30edf057a89350b6ffd6ab1bdf3418122c1a0494
Reviewed-on: http://git-master/r/358051
Reviewed-by: Min-wuk Lee <mlee@nvidia.com>
