Version string PD13.2.2_EA1
Signed-off-by: Christian Hemp <c.hemp@phytec.de>
Add support for the phytec WLAN module.
Signed-off-by: Grigory Milev <g.milev@sam-solutions.net>
Signed-off-by: Dmitry Lavnikevich <d.lavnikevich@sam-solutions.net>
Micrel phy KSZ9031 and KSZ9021 have both the same HW bug
with asym_pause.
If asym_pause is enable you will have to unplug and replug the cable to make
the phy work.
It is not working correct
To allocate memory for the GPU we need the RAM size.
We can choose the ramsize over the Kernelkonfig.
The PMIC DA9063 has no reset. We need to reset the voltages
themselves on reboot.
Change display eeprom address to 0x50, which is default.
Don't filter mode get from EDID.
The filter was added with this patch:
ENGR00180117 HDMI: No audio output in 1080P on some TV
Some TV support specific video mode that different with
CEA standard, and it's pixel clock not comply CEA standard.
But audio configuration paramter N and CTS should follow CEA standard.
So audio may not work in these specific video mode.
Filter video mode get from EDID, only keep standard CEA video mode
in the modelist.
Set the correct phyID for Micrel KSZ9031
For the DL we need a delay on the RX lines. Without the delay
we loos all packages.
Add support for duallite and single core version of i.MX6 CPU
Minor changes into camera host driver:
- reinitialize current buffer index with 0 on each capture start;
- do not change buffer index if channel buffer wasn't updated.
On some modules SATA don't work if pcie disable the SATA clock.
Remove the SATA clock from pcie clock tree and enable SATA clock before the
pcie clock.
PCIe needs the SATA clock:
* Enable SATA ref clock.
* PCIe needs both sides to have the same source of refernce clock,
* The SATA reference clock is taken out to link partner.
The busfreq function support is in the kernel since:
commit 32ea8aa56866047e100c6600cf663aaf786d8dbe
Author: Ranjani Vaidyanathan <ra5478@freescale.com>
Date: Tue Feb 7 14:34:13 2012 -0600
|ENGR00179574: MX6- Add bus frequency scaling support
|Add support for scaling the bus frequency (both DDR
|and ahb_clk).
|The DDR and AHB_CLK are dropped to 24MHz when all devices
|that need high AHB frequency are disabled and the CORE
|frequency is at the lowest setpoint.
|The DDR is dropped to 400MHz for the video playback usecase.
|In this mode the GPU, FEC, SATA etc are disabled.
|To scale the bus frequency, its necessary that all cores
|except the core that is executing the DDR frequency change
|are in WFE. This is achieved by generating interrupts on
|un-used interrupts (Int no 139, 144, 145 and 146).
|Signed-off-by: Ranjani Vaidyanathan <ra5478@freescale.com>
Add freescale SATA platform changes to phyFLEX-i.MX6
|ENGR00243339 imx: sata: disable sata phy when sata is not enabled
|In order to save power consumption, disable sata phy
|(enable PDDQ mode) in kernel level, if the sata module
|is not enabled in kernel configuration.
|Signed-off-by: Richard Zhu <r65037@freescale.com>
Remove not needed code from ethernet phy init
Fix calculation for phy_speed (MII_SPEED)
and use the right clock (ipg_clk).
Module revison 2 has some changes compared to revision 1.
NAND:
- disconnected NAND_D8-D15 because only 8-Bit NAND is supported by i.MX 6
- connected NANDF_DQS (SD4_DAT0) to NAND-Flash to support sync. mode
PMIC:
- Moved PMIC_nIRQ from DI0_PIN15 to SD4_DAT1
PCIe:
- Added nPCIe0_PERST to pad DI0_PIN15 (GPIO4_17)
That we can change the values of the structs revisions depending
the structs can't be const.
The pin SD4_DAT4 until SD4_DAT7 be used as revison control.
The pins will be internel pulled up so we read a 1111 for revison 1.
For revison two the first pin (bit) is pulled down (see schematic pfla-02
page 4 "SDIO, NAND-Flash".
On Module rev 1 the pins are connectet to the NAND but we have only 8bit NAND
also the i.MX6 only can handle 8bit NAND flashs.
Revisions:
Rev 1: 0xF
Rev 2: 0xE
Rev 15: 0x1
Rev 16: 0x0
Fix cam selection typo, the cam name is tw9910
Change the frequencies for the pll4 (clock.c)
Change the frequencies for the different phytec camera moduls (board-mx6q_phyflex.c)
Add new pll configs for the mt9p031 sensor (mt9p031.c)
This is not need in the platform code.
This is only a workarround to fix bootproblems with i.MX6.
Sometimes the kernel dosn't boot and print the message
"COULD NOT SET GP VOLTAGE".
With the delay it look likes the kernel boot correct.
For more informations look at:
https://community.freescale.com/message/319514#319514
If didn't set the param ldo_active param in command line we use LDO_MODE_BYPASS
Signed-off-by: Andrei Andreyanau <a.andreyanau@sam-solutions.com>
modified: arch/arm/mach-mx6/board-mx6q_phyflex.c
New bootargs added
The change is needed because of the setting in the platformcode.
(VM-009) camera.
modified: drivers/media/video/mt9m111.c
clko2
modified: arch/arm/mach-mx6/board-mx6q_phyflex.h
modified: arch/arm/mach-mx6/board-mx6q_phytec-nand.c
clko2_clk parent clock source.
modified: arch/arm/mach-mx6/clock.c
Signed-off-by: Uladzimir Bely <u.bely@sam-solutions.net>
particular 'power' button)
modified: drivers/media/video/mxc_camera.c
modified: include/media/soc_camera.h
dividers for 26MHz clock source and 48/96MHz PCLK for mt9p031 camera.
modified: drivers/media/video/mt9p031.c
