2013-03-29Merge branch '3.0-pcm052' of ssh://github.com/tsfs/Vybrid-Linux into 3.0-pcm0523.0-pcm052-ts2.1Justin Waters
2013-03-29fix scheduler not seeing time pass, would not interrupt cpu bound processRoshni Shah
Signed-off-by: Ed Nash <ed@kidlearn.com> Signed-off-by: Russell Robinson Jr <rrobinson@phytec.com>
2013-03-28pcm052: updating pcm052_defconfigRussell Robinson Jr
2013-03-14Initial changes to support mcc and i2c semaphore for ping pong demoPD13.0.2Russell Robinson Jr
2013-03-14pcm052: audio: audio playback and record support addedRussell Robinson Jr
2013-02-25Merge remote-tracking branch 'github/3.0-pcm052' into 3.0-pcm0523.0-pcm052-ts2Adam Lussier
Release 3.0-ts2: enable USB support for the phyCORE Vybrid
2013-02-11pcm052: usb: enable both USB0 and USB1 as ehci-hostRussell Robinson Jr
note: there are still intermittent detection errors with USB0 Signed-off-by: Russell Robinson Jr <rrobinson@phytec.com>
2013-02-11mvf: usb: create modular defines for ehci and some hardware address changes.Russell Robinson Jr
ehci changes are currently only used with phyCORE-Vybrid (pcm052) Signed-off-by: Russell Robinson Jr <rrobinson@phytec.com>
2013-02-11pcm052: usb: fix VBUS enable mux settings and assert GPIO to enable VBUSRussell Robinson Jr
2013-02-11pcm052: sdhc: fix drive strength and use only hardware pull-upsRussell Robinson Jr
2013-01-25pcm052: enable EEPROM driver in config, fix TSC IRQsRussell Robinson Jr
2013-01-25Initial phyCORE-Vybrid changesRussell Robinson Jr
2012-12-19pcm052: enable EEPROM driver in config, fix TSC IRQsPD13.0.0alpha3.0-pcm052-ts1Russell Robinson Jr
2012-12-19Initial phyCORE-Vybrid changesRussell Robinson Jr
2012-12-12fsl_nfc: Add default partitioningJustin Waters
Allows the NAND to properly probe if cmdline partitioning is not specified. Otherwise, it will fail silently.
2012-12-12Default configuration update for CAAM driverJason Jin
manually integrate from the CAAM part by Jason Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-12-12Vybrid CAAM driverJason Jin
From Singh Pradip-B09147. Integrate by Jason Jin Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-12-12mvf: update default kernel config for FaradayAlison Wang
Signed-off-by: Alison Wang <b18965@freescale.com>
2012-12-12ENGR00181365-2: ADC: Add driver support for ADC VybridWang Xiaojun
Add driver support for ADC Vybrid. Signed-off-by: Wang Xiaojun <b41435@freescale.com>
2012-12-12ENGR00181365-1: ADC: Add platform support for ADC driverWang Xiaojun
Add platform support for ADC driver. Signed-off-by: Wang Xiaojun <b41435@freescale.com>
2012-12-12ENGR00216081-2:Errata workaround for usb suspend and resumeJingchang Lu
Toggle PHYPWD.PWD after set PORTSC.SUSP with 8ms to trigger the LS_SE0/LS_EOP append flag after resume within UTM block. Signed-off-by: Jingchang Lu <b35083@freescale.com>
2012-12-12ENGR00216081-1:Add USB host and gadget PM supportJingchang Lu
Handle usb suspend/resume, currently the BSP doesn't support usb plug/unplug wakeup. Signed-off-by: Jingchang Lu <b35083@freescale.com>
2012-12-12ENGR00216087-2:Add Vybrid ASRC platform deviceJingchang Lu
2012-12-12ENGR00216087-1: ASRC support for VybridJingchang Lu
The ASRC driver supports stereo audio streams resample, the ASRCK1 serial clock using audio external clock source can not support 44.1K sample rate due to divider and prescaler restriction. Signed-off-by: Jingchang Lu <b35083@freescale.com>
2012-12-12ENGR00216076-3: DSPI: Update DSPI driver for PMAlison Wang
Update power management part for DSPI driver. Signed-off-by: Alison Wang <b18965@freescale.com>
2012-12-12ENGR00216076-2: DCU: Update DCU driver for PM and blending issueAlison Wang
Fix layers blending and reinitialization issue for DCU driver. Update power management part for DCU driver. Signed-off-by: Alison Wang <b18965@freescale.com>
2012-12-12ENGR00216076-1: PM: Add Power Management driver for VybridAlison Wang
System could run into STOP and LPRun modes. When system was working in STOP mode, pressing SW1 button or inserting or removing SD card could wake up it. Signed-off-by: Alison Wang <b18965@freescale.com>
2012-11-20mvf-dcu: Move ioctls to public headerAndy Voltz
2012-11-20mvf_dcu: init all dcu registers at boot timeEd Nash
2012-10-17ENGR00216078-2: switch: add L2 switch driver for Vybrid3.0-mvf-201210121659Jason Jin
Port the L2 switch driver from CF platform for Vybridi plaform. This driver usually should work together with the RSTP demo applications provided by fsl. Signed-off-by: Alison Wang <b18965@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-10-17ENGR00216078-1: switch: add platform support for L2 switchJason Jin
Add platform support for Vybrid L2 switch driver. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-10-17ENGR00181358-3: fec: add second FEC support for VybridAlison Wang
Add second FEC support for Vybrid. Signed-off-by: Alison Wang <b18965@freescale.com>
2012-10-17ENGR00212250-2: watchdog: Add watchdog driver support for VybridAlison Wang
Add watchdog driver support for Vybrid. Signed-off-by: Wang Xiaojun <b41435@freescale.com>
2012-10-17ENGR00212250-1: watchdog: Add platform support for watchdog driverAlison Wang
Add platform support for watchdog driver. Signed-off-by: Wang Xiaojun <b41435@freescale.com>
2012-10-17ENGR00181395-1: Add UART MISC functions support for FaradayJingchang Lu
Add hardware flow control support, Add transmit DMA support, Add FIFO operation support, Add MSB/LSB on data support, Add 9-bits MARK/SPACE support. Signed-off-by: Jingchang Lu <b35083@freescale.com>
2012-10-17ENGR00181390-2: qspi: Add Quad SPI driver support for VybridAlison Wang
Add Quad SPI driver support for Vybrid. Signed-off-by: Alison Wang <b18965@freescale.com> Xiaochun Li <b41219@freescale.com>
2012-10-17ENGR00181390-1: qspi: Add platform support for Quad SPI driverAlison Wang
Add platform support for Quad SPI driver. Signed-off-by: Alison Wang <b18965@freescale.com> Xiaochun Li <b41219@freescale.com>
2012-10-17ENGR00181407-3: Add Compaq touch screen interface for nano-xAlison Wang
Add Compaq touch screen interface for nano-x. Nano-x work with touch screen driver via Compaq touch screen event format, this patch could add the support above mouse device. Signed-off-by: Alison Wang <b18965@freescale.com>
2012-10-17ENGR00181407-2: ts: add touch screen driver support for VybirdAlison Wang
Add touch screen driver support for Vybird. Signed-off-by: Alison Wang <b18965@freescale.com>
2012-10-17ENGR00181407-1: ts: add platform support for touch screen driverAlison Wang
Add platform support for touch screen driver. Signed-off-by: Alison Wang <b18965@freescale.com>
2012-10-17ENGR00180953-2: dspi: update dspi driver support for VybridAlison Wang
Update dspi driver support for Vybrid after debugging on board. Signed-off-by: Jason Jin <jason.jin@freescale.com> Alison Wang <b18965@freescale.com>
2012-10-17ENGR00180953-1: dspi: update platform support for dspi driverAlison Wang
Update platform support for dspi driver after debugging on board. Signed-off-by: Jason Jin <jason.jin@freescale.com> Alison Wang <b18965@freescale.com>
2012-10-17ENGR00180956-3: Add PWM LED device support on MVF600Jingchang Lu
Four LEDS are connected to FTM0 ch0~3 on TWR-MVF600 board, the PWM signal can use control these LEDS on/off or demo. Signed-off-by: Jingchang Lu <b35083@freescale.com>
2012-10-17ENGR00180956-2: Add FlexTimer PWM support on FaradayAlison Wang
The FlexTimer work on PWM mode with EPWM and CPWM supported. The API configures each FTM channels the same due to pwm subsystem interface restriction. Signed-off-by: Jingchang Lu <b35083@freescale.com>
2012-10-17ENGR00180956-1: Add FlexTimer PWM device clock for FaradayJingchang Lu
2012-09-12ENGR00220352: Fix reboot hung after set uart baudrate3.0-mvf-201208141602Jingchang Lu
2012-09-12Enable the FEC as modulesJason Jin
2012-09-12ENGR00212262-3: Faraday:Enable the ADMA2 function for SDHCJason Jin
This patch enable the ADMA2 function for the SDHC module used on Faraday board. Please note that the ADMA address should be 16 bytes aligned other than 4 byte in the spec. This patch also increased the SDHC module frequency to 200MHz. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-09-12ENGR00219771: Fix high-speed usb hub connection detection failure for FaradayJingchang Lu
Only disable the high-speed device disconnection detction for level-1 device, or the connection detecting would fail. Signed-off-by: Jingchang Lu <b35083@freescale.com>
2012-09-12ENGR00219354: Fix USB host driver compiled as module fail problemJingchang Lu
