2019-02-06 | Fix UART examples for Colibri iMX7colibri-imx7-m4-freertos-v8 | Andy Kiser | |
The uart_polling and uart_interrupt examples were originally written for a UART used in DCE mode. The Colibri iMX7 is designed to use the UART in DTE mode. The signals are swapped between DTE and DCE (Rx <-> Tx, and control signals). In order to use the correct pin direction, the bit DCEDTE in the UARTx_UFCR register needs to be configured accordingly. Signed-off-by: Andy Kiser <andy.kiser@gmx.ch> | |||
2016-05-09 | resync with FreeRTOS_BSP_1.0.1_iMX7D | Stefan Agner | |
2016-01-12 | initial commit imx7_colibri_m4 examples | Stefan Agner | |
This adds initial examples for imx7_colibri_m4, currently just a copy of the imx7d_sdb_m4 examples. |
