Add support for the SLEEP_MOCI signal to the dsi-to-lvds overlays, this
allows the driver to turn off the the SLEEP_MOCI in suspend.
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
Add support for the SLEEP_MOCI signal to the dsi-to-hdmi overlay, this
allows the driver to turn off SLEE_MOCI in suspend.
Add support for the SLEEP_MOCI regulator to the dtsi file that is used
by verdin-imx8mm and verdin-imx8mp. The gpio needs to be set in the
corresponding dsi-to-lvds overlay.
allows the driver to turn off SLEEP_MOCI in suspend.
Add overlay to configure the two loudspeaker outputs as a
single Bridge Tied Load output getting higher output power.
Related-to: ELB-5533
Signed-off-by: Hiago De Franco <hiago.franco@toradex.com>
On the Verdin iMX8MP the display sometimes shows issues on vertical
sync resulting in a jittery display. On Verdin iMX8MM the effect
wasn't observed.
Changing the blanking timing improved the situation so that the
jittery display wasn't seen anymore on Verdin iMX8MP and Verdin
iMX8MM works as before.
Related-to: ELB-5389
Add overlay for lvds display for mallow v1.1 using native lvds interface
of verdin imx8mp.
Related-to: ELB-5219
Signed-off-by: Joao Paulo Goncalves <joao.goncalves@toradex.com>
Add overlay for Riverdi 10.1 inch capacitive touch panel
connected via DSI.
It can be directly connected to Mallow carrier board and, using Verdin
DSI display adapter, it can be connected to Dev and Dahlia carrier boards.
Related-to: ELB-5365
Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
connected via DSI.
Related-to: ELB-5364
The video_pll1 is at 1039500000, take PLL1/15 otherwise we don't get a
stable picture on NXP i.MX 8M Mini.
Enable RPMsg for Cortex-M and reserve necessary memory regions
for RPMsg buffers.
This overlay enables the RemoteProc driver, RPMsg, allocates
necessary memory regions and disables necessary peripherals to
prevent kernel panics. This overlay works only on nonwifi modules.
Remove no more used display overlays.
Related-to: ELB-5129
This clarifies which overlay handles which mipi csi2 inputs.
Move the existing overlays to dtsi files and include them into one
accessory dts.
Provide data-mapping timings appropriately for each machine instead
of the hardcoding and use a single overlay per SoC to avoid code
duplication.
Related-to: ELB-4754
Change compatible to bind to imx8 and not to a specific carrier board,
remove unnecessary disabling of mcp2515 and rename overlay.
Related-to: ELB-4489
In case the code is placed inside the DDR region (e.g. DDR linker
script), this area should be reserved.
Rename the file to make it consistent with others overlay file naming.
Fix overlay main node and add 500 ms remote proc startup delay.
The base dtb files got a number of compatibles removed so that not
all dtbs have toradex,apalis-imx8 anymore. Follow that.
- Move to use only one overlay file for each panel/connection variant
- Move lvds overlays to new naming
- Adapt to dtb changes used in BSP6, 5.15-2.1.x kernel
- Rename *mezzanine-can* to *mezzanine_can*
Related-to: ELB-4896 ELB-4901
These overlays enables spidev. One for Apalis SPI1, one for SPI2.
Related-to: ELB-4894
Related-to: ELB-4838
* Update copyright year
* Fix spelling
Convert the HDMI overlays to the new naming scheme. While at it do also
update copyright year.
Fix Verdin iMX8M Mini with OV5640 MIPI CSI camera. That regulator is
optional.
Add device tree overlay suitable to run CAN1 on older module HW samples.
Related-to: ELB-4599, ELB-4645
toradex_5.15-2.0.x-imx
Update the overlay against the changes in the kernel device tree.
Related-to: ELB-4599, ELB-4643
This commit corrects the indentation, adds a comment about the the
compatible chipname used to bind the spidev driver and removes the
redundant status variable.
Fixes: d929016d ("verdin-imx8mm: add spidev overlay")
Related-to: ELB-4652
Signed-off-by: Aishwarya Kothari <aishwarya.kothari@toradex.com>
Fixes: dc60a386 ("verdin-imx8mp: add spidev overlay")
This commit changes the overlay for the DSI-to-HDMI adapter to make use
of the new driver: lontium,lt8912b
This commit suppresses compiler warnings about address-cells and
size-cells properties missing in spidev bloack
size-cells properties missing in spidev block
With the 5.15 NXP kernel the clock/power/reset subsystem was
reworked. Follow the changed node names in the kernel.
Currently these were enabled in the dtb, move this to the overlays
which might make use of the video processing unit VPU.
This overlay enables spidev by default.
Fix reset GPIO polarity in-line with the following upstream fix:
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit?id=feedaacdadfc332e1a6e436f3adfbc67e244db47
this commit adds an overlay which reserves memory for RPMSG
communication as well as the driver to communicate with the M4.
Toradex 32bit machines are no longer supported on the downstream branch
so remove them and adjust the Makefile.
