Upstream commit: bda1096b3dfe00f19b30fc85f282b2a9ad2f67f0
Fixes a recent iwlwifi build error
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
This file is needed by the wil6210 driver now.
It looks like no one is using the regulator drivers and maintaining
them costs some time because they often break. When someone needs
a specific driver please send a patch adding this one specific driver,
maintaining a small subset is not a problem, but maintaining all is a
big task.
This is needed by drivers/nfc/st21nfcb/i2c.c
This adds the cc2520.h and disables the driver on kernel < 3.5.
This is provides in-kernel functionality, to include
it assuems we have provided a backport for this functionality
and that's not true.
This reverts commit 16472f0c6924f0fa54c68a024a55d89689b413a0.
While doing a make allmodconfig I noticed the following:
CC [M] /dev/shm/backports-next/drivers/media/i2c/adv7604.o
/dev/shm/backports-next/drivers/media/i2c/adv7604.c:31:33: fatal error: linux/gpio/consumer.h: No such file or directory
Including the header fixes the error.
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
This header file is used by net/mac802154/llsec.h and does not provide
any function prototype so it is save to copy it.
This is needed by the st21nfca nfc driver.
These new drivers are compile tested only.
This adds Redpine Signals Inc 91x WLAN driver support
Required by CONFIG_VIDEO_ADV7343 and others.
Jean nuked display output class support so we won't
be needing the respective headers for compilation on
backports now. This is as seen on next-20140409.
commit f167a64e9d67ebd03d304e369c12011cf2bffaf5
Author: Jean Delvare <jdelvare@suse.de>
Date: Mon Mar 17 15:49:10 2014 +0100
video / output: Drop display output class support
It was only ever used by the ACPI video driver, and that only use case
vanished over 3 years ago (see commit 677bd810, "ACPI video: remove
output switching control".) So this is dead code and I guess we can
remove it now.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Commit 633fc86ff62 added the ieee802154_6lowpan namespace
and 7240cdec60b extended it (as on linux-next next-20140311).
Its important to note though that 633fc86ff62 also extends the
global net namespace. Since we cannot extend the global net
namespace we define our own backport namespace for 6lowpan
that can be used only be used by our backported subsystems,
nothing more. Since ieee802154_6lowpan requires support for
net_get_random_once() which uses static keys and a slew of
new skb fragment support we simply require at least 3.5 to
use 6lowpan. I did my best effort to backport this to kernels
older than 3.5 but quickly ran into a slew of hairy issues.
The last thing we needed to address was usage of the helper
inet_frag_evictor() added by Alexander via commit 6b102865e7
through v3.7. Since we can't backport that with macros or
inline helpers we add a patch to carry the changes there. If
that grows we can consider using Coccinelle.
If you are going to try to backport 6lowpan to kernels older
than 3.5 be warned that the litmus test for patches will be
to pass ckmake --allyesconfig for all supported kernels for
every patch you provide.
Cc: Alexander Aring <alex.aring@gmail.com>
Cc: Alexander Smirnov <alex.bluesman.smirnov@gmail.com>
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: Amerigo Wang <amwang@redhat.com>
Cc: linux-zigbee-devel@lists.sourceforge.net
We backport both the bluetooth and ieee802154 subsystems
and commit cefc8c8a7c moved the 6lowpan it out under from
net/ieee802154/6lowpan.h to include/net/6lowpan.h as bluetooth
now uses it. Since we backport both subsystems just copy the
header over.
commit cefc8c8a7c9e4867c45407f7f9a44fe80c5ea58a
Author: Alexander Aring <alex.aring@gmail.com>
Date: Wed Mar 5 14:29:05 2014 +0100
6lowpan: move 6lowpan header to include/net
This header is used by bluetooth and ieee802154 branch. This patch
move this header to the include/net directory to avoid a use of a
relative path in include.
Signed-off-by: Alexander Aring <alex.aring@gmail.com>
This simply the files that define the structures and
defines used to decode MPLS on the skb. For an example
usage see 960d97f95. The headers were added first via
f3baa393ff.
commit f3baa393ffc9a7aefc0bf767729382085e81f606
Author: Simon Wunderlich <sw@simonwunderlich.de>
Date: Mon Mar 3 17:23:11 2014 +0100
UAPI: add MPLS label stack definition
Labels for the Multiprotocol Label Switching are defined in RFC 3032
which was superseded by RFC 5462. Add the definition to UAPI and a stub
header for include/linux.
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de>
commit 960d97f9518ef6fb8ff87450d6b0c88ce5df9532
Date: Mon Mar 3 17:23:12 2014 +0100
cfg80211: add MPLS and 802.21 classification
MPLS labels may contain traffic control information, which should be
evaluated and used by the wireless subsystem if present.
Also check for IEEE 802.21 which is always network control traffic.
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Add defconfig and necessary files to copy-list.
This copies the sdio device id list into backprots, this is used by
brcmfmac.
The act8865 regulator driver needs this header file.
This header file is now needed by a media driver.
This file was added in kernel 2.6.32 and is now needed by bluetooth.
v4l2 now supports tracing and needs a new header file that was missing.
These files are now copied from the kernel like normal files we take
from the kernel.
This file is now copied from the kernel like a normal file we take from
the kernel.
The driver is not included in backports and we should use the in kernel
headers.
There is some code for the mdio driver in backports, but it does not
get build on any kernel, just remove it till someone wants to make it
work.
The platform drivers were only needed by some DRM drivers and are not
needed any more with the DRM driver being removed.
Maintaining the DRM driver takes a lot of recourses as there they are
depending on many API changes done to the core kernel code and
currently we do not have that many recourses to follow them. On the
other side one needs also new userspace drivers to make use of the new
features added to the DRM kernel drivers and it is not easy to update
the X drivers. Therefore we came to the conclusion to remove the drm
drivers for now.
There were also some problems with some DRM drivers, like the Intel
i915 driver caused kernel panic on some systems and was probably only
usable on some very recent kernel versions.
This file was newly added to drm.
This adds the missing file include/drm/drm_agpsupport.h
The intel i915 drm driver uses the declarations from intel-gtt.h to
interact with drivers/char/agp/intel-gtt.c which is not
backported by backports project. To prevent some strange problems when
using i915, use the headers from the kernel and do not use our own. This
causes some compile problems which where runtime problems before and
bumps the minimal kernel version to 3.7.
This i915 still crash on my device with kernel 3.7.
This is a new driver which needs a new header file.
Some of the header files for the regulators framework where used by
regulator core, which does not get backported or some of them are also
used by mfd drivers. Now only the headers which are only used by the
regulator driver are copied, it could still be that these headers are
also used in some platform specific code where the driver gets
registered.
This patch then fixed some dependencies which where wrong because of
using the wrong header files.
The cw1200 WLAN driver was added in 3.11-rc; include it in backports.
Signed-off-by: Solomon Peachy <pizza@shaftnet.org>
Add cdc_mbim, cdc_ncm, sierra_net, qmi_wwan device drivers.
Signed-off-by: Patrick Ziegler <patrick.ziegler@fh-kl.de>
This is required by s2mps11 as of at least next-20130709.
This is required by CONFIG_REGULATOR_MAX8998
which builds drivers/regulator/max8998.c as of
next-20130703.
There is a symbol missing otherwise that is currently
only provided by the core, ie, non modular.
This adds the ieee802154 subsystem.
== ckmake-report.log ==
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
Directory copying is recursive, so there's no need
to list subdirectories. All atheros ethernet drivers
are copied, so don't list them one by one. The same
is true for the Bluetooth include files.
Samuel folded code under net/nfc/llcp/ onto
the parent net/nfc/ directory with llcp_ prefixes
for the files. Address this change introduced
as of next-20130430.
commit 30cc4587659e1c9b1bfade8b2a757d91e04758ab
Author: Samuel Ortiz <sameo@linux.intel.com>
Date: Fri Apr 26 11:49:40 2013 +0200
NFC: Move LLCP code to the NFC top level diirectory
And stop making it optional. LLCP is a fundamental part of the NFC
specifications and making it optional does not make much sense.
There's not much point in backporting rfkill, if the base kernel
doesn't have it then providing the it as /dev/rfkill_backport
won't be picked up by any apps, and if the base kernel has it
then it would cause odd behaviour as the base kernel's platform
drivers using the rfkill API would not talk to the backported
modules rfkill.
An unusable backported rfkill isn't much better than not having
it at all, so change the way we backport rfkill and don't carry
the code but simply provide the API as wrappers.
If the base kernel is 3.10 or higher (the current version) then
don't change anything at all.
If the base kernel is 2.6.33 or higher (with the new rfkill API)
then just wrap the API and disable rfkill registrations for any
types that the base kernel doesn't know about.
For all other kernels, provide only static inlines that behave
like the rfkill API when rfkill isn't compiled in.
The downside is that we need to copy the rfkill API. This is,
however, very very stable (it essentially hasn't changed since
2.6.33), so that's not a problem.
On next-20130415 commit 668761ac0 added platform
specific data for brcmfmac for SDIO. Copy that
over. This is the first in a series of changes
required for next-20130415.
commit 668761ac01d6f5a36b8e5a24d4e154550e2c4c3b
Author: Hante Meuleman <meuleman@broadcom.com>
Date: Fri Apr 12 10:55:55 2013 +0200
brcmfmac: define and use platform specific data for SDIO.
This patch adds support for platform specific data for SDIO
fullmac devices. Currently OOB interrupts are configured by Kconfig
BRCMFMAC_SDIO_OOB but that is now determined dynamically by checking
availibility of platform data.
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Reviewed-by: Arend Van Spriel <arend@broadcom.com>
Reviewed-by: Franky (Zhenhui) Lin <frankyl@broadcom.com>
Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com>
Reviewed-by: Piotr Haber <phaber@broadcom.com>
Signed-off-by: Hante Meuleman <meuleman@broadcom.com>
Signed-off-by: Arend van Spriel <arend@broadcom.com>
Apparently I missed this during the conversion to the new
copy-list etc. The rndis_wlan driver requires some usbnet
and rndis code, if that's not present then it is either
not selectable or can be compiled but won't link against
older kernels that don't have the right requirements (or
don't have the symbols exported.)
For now, because the makefile parser is stupid, patch out
the asix driver objects because otherwise it's possible
to select it and fail the build. Improving the parser is
possible but I need to finish other things first.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.65 [ OK ]
18 3.1.10 [ OK ]
19 3.2.38 [ OK ]
20 3.3.8 [ OK ]
21 3.4.32 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.9 [ OK ]
25 3.8.0 [ OK ]
26 3.9-rc1 [ OK ]
real 39m35.615s
user 1068m47.428s
sys 155m55.657s
This adds backport support for all media subsystem
drivers. This is enabled only for >= 3.2. Some media
drivers rely on the new probe deferrral mechanism
(-EPROBE_DEFER see commit d1c3414c), those are only
enabled for kernels >= 3.4. Some media drivers only
depend on the regulatory but since we only support
backporting the regulatory on kernels >= 3.4 we only
enable those media drivers for >= 3.4.
This backports 433 media drivers.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.65 [ OK ]
18 3.1.10 [ OK ]
19 3.2.38 [ OK ]
20 3.3.8 [ OK ]
21 3.4.32 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.9 [ OK ]
25 3.8.0 [ OK ]
26 3.9-rc1 [ OK ]
real 39m35.615s
user 1068m47.428s
sys 155m55.657s
Cc: linux-media@vger.kernel.org
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
This backports the latest regulator drivers for kernels >= 3.4.
We enable the regulator only on kernels >= 3.4 given that
it relies on the new probe deferral mechanism which would
otherwise mean having to support drivers that do not probe
correctly. Note that 3.2 had a base regulator implementation
but that was just stubs.
I did look into a way to upgrade the core kernel regulator
but given that it relies on late_initcall() and core_initcall()
we can't update this part of the kernel. I even looked at
using ksplice for this but it seems ksplice can't be used to
update init sections on the vmlinux ELF. I also haven't much
updates to these routines since 3.4 except for 86f5fcfc.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.65 [ OK ]
18 3.1.10 [ OK ]
19 3.2.38 [ OK ]
20 3.3.8 [ OK ]
21 3.4.32 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.9 [ OK ]
25 3.8.0 [ OK ]
26 3.9-rc1 [ OK ]
real 39m35.615s
user 1068m47.428s
sys 155m55.657s
Cc: Liam Girdwood <lgirdwood@gmail.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
This grabs NFC core and drivers files from your linux tree.
Signed-off-by: Thierry Escande <thierry.escande@linux.intel.com>
