Changes specific to vendor kernels
This reverts commit ab3fd3b9a801a9faa2619e2e65207e736f859a6d.
The name of this configuration option was changed in Linux commit
b7da53cd6cd1 ("qtnfmac_pcie: use single PCIe driver for all platforms").
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
dev_open() got the extra parameter extack in Linux commit 00f54e68924e
("net: core: dev: Add extack argument to dev_open()"), just ignore it on
older kernel versions. This is used by the hostap driver.
This was introduced in Linux commit 58d81d64e06f ("lib: cordic: Move
cordic macros and defines to header file") and is used by the b43 and
brcmsmac driver.
This was introduced in Linux commit 801f87469ee8 ("netlink: add
nl_set_extack_cookie_u64()") and is used by the wireless subsystem.
This was introduced in Linux commit a08f06bb7a07 ("seq_file: Introduce
DEFINE_SHOW_ATTRIBUTE() helper macro" and is used by the cw1200 and the
wil6210 driver.
These functions are not used by any driver any more, remove them. They
were introduced for the frame vector code which was used by the media
subsystem. They also case some compile problems with kernel 4.4 which
get fixed by just removing this code.
Add some new wifi drivers to the default configuration.
The alx, igb and the media driver were removed some time ago, also
remove the default configurations.
This was added in upstream commit 4c96b7dc0d39 ("Add a matching set of
device_ functions for determining mac/phy") and is used by ath10k now.
In the mainline kernel it uses device_property_read_u8_array(), but that
was only introduced in kernel 3.18, use of_property_read_u8_array() only
on all kernel versions where this backport is needed which was added
much earlier.
This was introduced in kernel commit 8c2dd3e4a4b ("mm: rename
__alloc_page_frag to page_frag_alloc and __free_page_frag to
page_frag_free") and commit 44fdffd7050 ("mm: add support for releasing
multiple instances of a page") and is used by the mt76 driver.
Backporting it to kernel older than 4.2 is harder so just do it till
that version.
This was introduced in kernel commit fe896d18789 ("mm: introduce page
reference manipulation functions") and will be used by
__page_frag_cache_drain() in the next commit.
This was added in commit 32751c901728 ("backport: add crypto skcipher
interface"), but all the drivers which need it were deactivated in
commit cdcec8e6128 ("backports: disable things needing LIB80211 unless
SKCIPHER can exist") because it does not compile any more. Remove this
code now completely from the tree.
lib80211 does not use skcipher any more, but directly uses the crpyto
API. since kernel 4.20.
This copies the pci_alloc_irq_vectors() function from kernel 4.9 and
replaces the __pci_enable_msi{x}_range() calls with calls to
pci_enable_msi{x}_range(), these were backported to kernel versions <
3.14, so no need to handle the older kernels specially here.
This also adds support for MSIx IRQs and adds the PCI_IRQ_* defines.
Fixes: 162a6b312f1b ("add support for pci_alloc_irq_vectors")
Cc: Omer Dagan <omer.dagan@tandemg.com>
pci_alloc_irq_vectors() needs to be wrapped in CONFIG_PCI and
CONFIG_PCI_MSI definition to avoid a function redefinition compiler
error.
Signed-off-by: Winnie Chang <winnie.chang@cypress.com>
Signed-off-by: Chi-Hsien Lin <chi-hsien.lin@cypress.com>
add support for function in kernels under 4.8
function is a wrapper around 'pci_enable_msi_block' or
'pci_enable_msi_range' depending on the kernel version
the min\max number of interrupts was overridden to always use the
max number of interrupts which seems correct since it was not
supported in the old APIs
Signed-off-by: Omer Dagan <omer.dagan@tandemg.com>
[use GPL expert as everything in backports, remove unused ifdef]
In the pre_doit and post_doit backports, we set the ops to our
backported version, so genetlink itself will always call it. But then
we don't check if the actual ops are set before calling them, which
causes a call to a NULL pointer. Fix this by checking if the ops are
actually set before calling them.
Fixes: ff6746638cf1 ("backports: genetlink: update completely")
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
Support xz compression in uninstall.
Also use compat.ko instead of mac80211.ko to detect
this, as compat is always compiled and mac80211 may
not be.
Replace all the different nested versions of generic netlink
backport with a single one, covering from < 3.13 all the way
to the upcoming netlink policy improvements in 4.20.
New API slated to show up in 4.20.
Since 4.15 this no longer takes a family argument, so add that
to the backports instead of trying to work around the family
argument having changed type.
Make all the magic variable argument calls inlines and
rename them so we can override them more easily later.
This reverts commit 1b481348b4564970e3cfa04023f1cc22ce2b6931.
It actually broke the build to include this, as memneq.c is always
built for kernels < 3.13, and thus we get a duplicate symbol export
if we skip the backport definitions.
Easier than making the build system depend on the strange versions
is to just always use our backported version with symbol rename.
If we don't include <linux/net.h> then __BACKPORT_NET_GET_RANDOM_ONCE
can never be defined, and we'll never get the compat code. Fix that.
Ubuntu cherry-picked the patch that added
u64_stat_update_begin_irqsave() in their 4.15 kernel, so we get a
redefinition compilation error if we try to compile against that.
To solve this, check UTS_UBUNTU_RELEASE_ABI and don't define our
backported function if it's 33 or higher.
Just clean up the dependency list, skcipher is known to not
work, but we neither backport bluetooth now, nor does current
upstream bluetooth actually need skcipher.
We can't really backport those, but add them anyway for compilation,
perhaps somebody doesn't want to suspend/resume?
With commit 3d6ce86ee794 ("drivers: remove force dma flag from buses")
in kernel 4.18 of_dma_configure() got the extra parameter force_dma.
This is backported by setting the force_dma member which was added in
commit d89e2378a97f ("drivers: flag buses which demand DMA
configuration") in kernel 4.15.
In older kernel versions we just ignore this parameter as the
of_dma_configure() function internally takes care of setting this
correctly.
Since commit 7b07cbefb68d ("iommu: of: Handle IOMMU lookup failure with
deferred probing or error") in kernel 4.12 this function returns int and
not void any more.
This reverts commit 1b4e6ad4d927c7998fa578f2d29e0c4ec01a9217.
Said commit broke b43 on older kernels (<3.16).
This is just a forward include, but earlier versions don't include
linux/types.h despite relying on it.
The getrawmonotonic64() function that is used by the
ktime_get_raw_ts64() backport was only introduced in 3.19. To fix
compilation with earlier kernels, do the convertion from
getrawmonotonic() manually if the kernel is < 3.19.
Additionally, add timespec_to_timespec64() that we need for this
conversion (and which was only introduced in 3.17).
I am not aware of any user of the NFC coded in backports, at least I
haven't seen any patches regarding this. Remove this code to reduce the
efforts needed in the backports project.
Use the versions shipped with the kernel instead.
bcma and ssb didn't change much in the last few years, most of the
changes were related to code only used on embedded devices. Removing
this reduces the number of parts we have to backport. b43, b43legacy and
brcmsmac work well with the in kernel version.
Replace the existing skb->xmit_more semantic patch rule with a more
generic one that uses a helper inline function.
The u64_stats_init() macro was turned into a static inline function in
v4.2 to prevent warnings that happen when its argument is not used
elsewhere.
Since we started hitting these warnings, undefine the macro and define
the static inline to prevent them.
With kernels < 3.17, we need to include hrtimer.h to get ktime_divns()
for the ktime_get_boottime_seconds() backport. But we can't just
include htrtimer.h in the backport timekeeping.h because we run into
some cyclical inclusions that cause problems. To solve that make
ktime_get_boottime_seconds() non-inline and add it to a new
backport-4.18.c file.
In kernels earlier than 3.18, the raw_spin_lock defininition when
CONFIG_DEBUG_LOCK_ALLOC is not enabled, was dropping one of the
parameters, which caused a few "unused variable" warnings at places
where this argument was only used in the call to
raw_spin_lock_nested(). Take the latest definition which evaluates
the argument to avoid compiler warnings.
We were including leds.h twice in backport-4.5.c and one of them was
very early, which caused inclusion conflicts at least with < 3.16
kernels.
This was introduced in 4.18 and is needed by rhashtable.h, that we
copy. So copy it as well.
This function was introduced in v4.6 and now the iwlwifi driver uses
it. Add the function for kernels older than v4.6.
Allow using wait_event_killable_timeout function in kernel
older then 4.13
Signed-off-by: Shahar S Matityahu <shahar.s.matityahu@intel.com>
At least in some older kernel versions (e.g. 3.10), the tcp.h header
file is not implicitly included from other headers if CONFIG_IPV6 is
not set, so we need to include it in backport-4.4.c. Also, there is
an IPv6 structure that is used, so we should ifdef it away when IPv6
is not enabled.
wireless-drivers-next.git commit cb18e2e9ec71 (brcmfmac: fix wrong
strnchr usage) used strreplace(), which is not available in kernel prior
to v4.2. Before this commit proprgates to linux-stable.git, add
strreplace() to avoid gentree failure.
In newer kernels, calling cc-option will use KBUILD_CFLAGS,
which itself gets subdir-ccflags-y added to it. Thus, we get
it referencing itself, since nothing here is evaluated until
KBUILD_CFLAGS is used: KBUILD_CFLAGS contains subdir-ccflags-y,
that in turn contains cc-option call, containing KBUILD_CFLAGS.
To avoid that, use := assignment to subdir-ccflags-y, meaning
the cc-option call is done right away and we don't end up with
KBUILD_CFLAGS referencing itself.
Note that this is the first assignment to subdir-ccflags-y, so
the += was never necessary.
This fixes build of the driver on kernels 4.15 and higher.
ktime_get_raw_ts64() uses the old function which was renamed.
[fix typo in commit message]
These functions are currently used by the usbnet driver.
These functions were introduced in upstream commit 2695578b896ae ("net:
usbnet: fix potential deadlock on 32bit hosts")
