Upstream commit abe05f0c83f5947f84cc0e6408ee0930595389b7
page_ref_count() was backported to kernel version 4.4.216, do not add it
in backports for this kernel version any more.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Upstream commit eea7eb88324405d9ed90ff0b430d631f5f25b0e0
Since my last system upgrade I started building with gcc 9,
and that complains that a function is cold when the one we
create locally here isn't - mark it as cold always, I don't
think it would complain the other way around.
Upstream commit 3c6ca332a2ea9e3ebc6c99c5095a7acf14f09b91
In v5.2, x509_cert_parser.c implemented a new function,
x509_note_params(). So we need the new generated asn1 files. Update
these files from the ones generated with v5.2
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
Upstream commit a17ed9f1fcd12d56757bc33a275d5dfa98d7e75e
When building with /bin/sh -> bash, things are SUPER slow (at least
for me), because bash takes a LOOONG time to look at the environment
variables (and we typically have around 6k), adding over a second to
each bash invocation for me.
The reason we export them is that we need them in all of the sub-
makes, and those only read auto.conf, which we can't change.
Work around this by overriding 'make' itself, and using --eval to
read *our* .config file into each make that gets called. This way,
the variables are present in all make invocations in the same way
as they would be through the environment, but don't get passed to
shell invocations.
If --eval is not supported, keep doing what we did before.
kvcalloc() was added in kernel commit 1c542f38ab8d ("mm: Introduce
kvcalloc()") and is now used by the fq header filers.
Since Linux upstream commit 4cfd21885592 ("PCI: let
pci_disable_link_state propagate errors") The
pci_disable_link_state() function can return an error. This
return code is now used by the mt76 driver.
In case it is not possible to disable ASPM, for example on some ACPI
systems, we should return an error and mt76 handles this. Do this by
checking the PCI registers if the operation was successfully.
The checking of the PCI register was added by Felix Fietkau.
skb_ext_reset() was added in upstream commit 174e23810cd3 ("sk_buff:
drop all skb extensions on free and skb scrubbing") and is now used by
mac80211_hwsim.
skb_ext_reset() replaced the old call to secpath_reset() in
mac80211_hwsim and other places and it also does similar things than
this function. Juts call the old secpath_reset() on older kernel
versions.
This was added to net/xfrm.h and not linux/skbuff.h because
secpath_reset() is only available in net/xfrm.h in the upstream kernel
and this is not included in linux/skbuff.h.
nf_reset_ct() was added in upstream Linux commit 895b5c9f206e
("netfilter: drop bridge nf reset from nf_reset") and is now used by
mac80211_hwsim.
The upstream commit renamed nf_reset() to nf_reset_ct() and did some
modifications to this inline function, just call the old version on
older kernel versions.
Only build the own lib-arc4 version when it is not build as a module or
into the kernel. Without this change it was also build when
CRYPTO_LIB_ARC4 was build as a module in the kernel.
Add writel_relaxed() from upstream commit 9439eb3ab9d1 ("asm-generic:
io: implement relaxed accessor macros as conditional wrappers") which is
used by the wil6210 driver.
Add __ioread32_copy() from usptream Linux commit a9aec5881b9d
("lib/iomap_copy.c: add __ioread32_copy()") which is used by mt76
driver.
Add skb_mac_offset() from upstream kernel commit ea6da4fd388a
("net/skbuff: Introduce skb_mac_offset()") which is used by the wil6210
driver.
Add skb_frag_off() Which was added in upstream commit 7240b60c98d6
("linux: Add skb_frag_t page_offset accessors") which is used by the
usbnet driver.
Add devm_platform_ioremap_resource() from upstream kernel commit
7945f929f1a7 ("drivers: provide devm_platform_ioremap_resource()") which
Add static_assert() from upstream commit 6bab69c65013 ("build_bug.h: add
wrapper for _Static_assert") which is used by rtw88.
In upstream commit 7ce2e76a0420 linux/pci-aspm.h was removed and the
content included into pci.h. Add an include to have the functions
defined in linux/pci-aspm.h available when linux/pci.h is included.
This updates the KConfig system used in backports to the version from
kernel 4.17. In kernel 4.18 some bigger changes to the KConfig system
were introduced which are harder to backport, so start with using this
older version.
This version now generates the zconf.lex.c and zconf.tab.c files from
the original sources, newer kernel versions will delete these files in
a make clean, after that they are now regenerated. We do not ship them
by default any more, so we need lex and yacc.
The Makefile was not copied from the mainline kernel but this is written
specifically for the backports project.
Cc: Anthony Wong <yp@anthonywong.net>
The arc4 library was extracted from the crypto system in commit
dc51f25752bf ("crypto: arc4 - refactor arc4 core code into separate
library") in kernel 4.20. This is now used by mac80211 and lib80211 for
WEP crypto.
The struct netlink_callback got a new extack attribute in commit
4a19edb60d02 ("netlink: Pass extack to dump handlers") in kernel 4.20.
Use a function instead of directly accessing it to return NULL on older
kernel versions, the code should handle NULL.
The xmit_more member was removed from struture sk_buff and the
skb_xmit_more() function is not used in backports any more, just remove
this code as it does not compile any more on kernel 5.2 and more recent.
This adds the function trace_##name##_enabled to __DECLARE_TRACE() which
was added in commit 7c65bbc7dc ("tracing: Add
trace_<tracepoint>_enabled() function"). This is now used by ath10k.
__DECLARE_TRACE() got other changes wit kernel 3.16, so add two
different versions.
nl80211_validate_nested() was added in commit 901bb9891855 ("nl80211:
require and validate vendor command policy") in kernel 5.3 and is used
by nl80211.
ktime_get_boottime_ns() was added in commit 9285ec4c8b61 ("timekeeping:
Use proper clock specifier names in functions") in kernel 5.3. This is
used by multiple drivers.
BITS_PER_TYPE was moved in the upstream kernel in commit 9144d75e22ca
("include/linux/bitops.h: introduce BITS_PER_TYPE") in kernel 4.19 and
is now used by the ath10k driver.
Older kernel versions are missing these files and still try to include
them, add them to make compile testing on recent system easier.
The behavior of of_get_mac_address() changed in kernel 5.2, it now
returns an error code and not NULL in case of an error.
This was changed in upstream kernel commit d01f449c008a
("of_net: add NVMEM support to of_get_mac_address")
This removes the removed driver CPTCFG_R8822BE and adds the newly added
drivers CPTCFG_MT7603E, CPTCFG_MT7615E and CPTCFG_RTW88
The functions provided by include/net/inet_frag.h are not used by any
code in backports any more and this file causes compile warnings
with kernel 3.16.
ktime_t was converted from the union to s64 in kernel 4.10.
hrtimer_start() was already converted some time ago in backports, now
mac80211_hwsim uses hrtimer_start() together with the newly added
functions.
In the current kernel napi_complete_done() returns a bool and this is
now used by the mt76 driver. Try to backport this functionality by
doing the check which makes the function return false already in
backports.
This was added in upstream kernel commit 364b6055738b ("net: busy-poll:
return busypolling status to drivers")
mac80211_hwsim uses HRTIMER_MODE_ABS_SOFT and HRTIMER_MODE_REL_SOFT now.
These enum entries were added in commit 98ecadd4305d ("hrtimer: Add
clock bases and hrtimer mode for softirq context") in kernel 4.16.
This will execute the timers in hard interrupt context and not in soft
interrupt context like intended.
The brcmfmac driver now uses new sdio_retune*() functions. They are
added with kernel 5.2-rc6 and are backported to kernel 4.19.56 and
5.1.15
sdio_retune_hold_now() and sdio_retune_release() should work like in the
upstream kernel, the implementation of mmc_retune_release() and
mmc_retune_hold() was copied to backports into these functions. On
kernel < 4.3 backporting this is not so easy, so just use an empty
implementation there.
It is not possible to backport sdio_retune_crc_disable() and
sdio_retune_crc_enable() because they need an additional member in a
structure, just add an empty implementation.
ipv6_stubs.h was added in kernel commit 3616d08bcbb5 ("ipv6: Move ipv6
stubs to a separate header file").
Most of its content is from include/net/addrconf.h, so include that file
indirectly on older kernel versions.
This extends the backported netlink handling with strict parsing. the
struct gen_ops now supports the validate member and does the validation
inside the backport layer.
This is needed to use backports with kernel 5.2.
[Hauke: Remove nla_validate_nested()]
[Hauke: Support struct genl_ops on older kernel versions]
The cordic.c file was moved and the driver from drivers/staging/rtlwifi/
was removed in mainline kernel.
include/linux/rhashtable.h now uses struct lockdep_map unconditionally
which is fine for upstream as lockdep.h defines an empty lockdep_map
structure if CONFIG_LOCKDEP is not set. However, that is only true
since kernel 4.15 so adding such definition in our lockdep.h to cover
older kernels.
Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com>
We were not checking if the allocation failed in
backport_genl_register_family(), which could lead to NULL pointer
dereferences later. Fix that.
Include static inline functions that were added by commit
74de6960c99d ("rcu: Provide functions for determining if call_rcu()
has been invoked").
[Activate on < 4.20 only]
smp_acquire__after_ctrl_dep() was introduced in kernel 4.8 in upstream
Linux commit 33ac279677d ("locking/barriers: Introduce
smp_acquire__after_ctrl_dep()") and is used by backports lib-refcount.c
implementation now.
This just adds the default implementation to backports.
rhashtable_lookup_get_insert_fast() was added in kernel 4.12 in Linux
upstream commit f9fe1c12d12 ("rhashtable: Add
rhashtable_lookup_get_insert_fast") It is now used by mac80211.
For kernel < 4.9 we already backport the complete rhashtable
implementation, so this is only needed for kernels more recent than 4.9.
This is copied from upstreamn Linux kernel.
Add new macros introduced from v5.1-rc1
23323289b154 netlink: reduce NLA_POLICY_NESTED{,_ARRAY} arguments
v3: Fix v4.20 compilation error
Signed-off-by: AceLan Kao <acelan.kao@canonical.com>
The iwlwifi driver now needs this function. Backport it.
If we fail to allocate extack, we fall back to the code path
that tries to send an error *with* extack, but that will
access our extack pointer. It also doesn't make sense, so just
return an error back to netlink immediately and let it handle
sending the error message to userspace.
The patch that introduces nospec.h was cherry-picked for 4.15 only in
4.15.2, so we need to adjust the ifdefs of our stub.
At least one function, namely ftrace_print_array_seq(), still needs
the ftrace_event.h header file, otherwise sparse may warning that it
is declared as non-static without pre-declaration.
Now that 4.21 became 5.0, we need to update the Makefile accordingly.
Stop looking at 4.19 for the 4.* series and add 5.*.
Enable users to be able to conveniently select the Marvell wifi drivers that
they need.
Signed-off-by: Tamás Szűcs <tszucs@protonmail.ch>
The name of this configuration option was changed in Linux commit
b7da53cd6cd1 ("qtnfmac_pcie: use single PCIe driver for all platforms").
dev_open() got the extra parameter extack in Linux commit 00f54e68924e
("net: core: dev: Add extack argument to dev_open()"), just ignore it on
older kernel versions. This is used by the hostap driver.
This was introduced in Linux commit 58d81d64e06f ("lib: cordic: Move
cordic macros and defines to header file") and is used by the b43 and
brcmsmac driver.
