Upstream commit: b3cb62500ef43511480f416f957cb6d60c24984b
commit 2e98a32a274274fca0e6e ("backport: add
of_property_read_u64_array()") added a call
to of_find_property_value_of_size(), which is a
static function, causing compilation error.
Implement it locally as well.
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
[remove of_find_property_value_of_size() from backport-3.10.c]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Upstream commit: 2e98a32a274274fca0e6e4c05bd40bfb0f449bb1
This function was added in commit b31384fa5 "Driver core: Unified
device properties interface for platform firmware".
Upstream commit: 129646a4e199c6442e3da366baf155fccf36aa62
Instead of using the kernel version to check if we have to add a
backport for ACPI_COMPANION check for it directly. RedHat 7 backported
this change to their kernel and writes a warning without this change.
Upstream commit: 6d60d24ef26a14cc8836da3f3b0f03e6097c6b58
The upstream commit that added it was backported in 4.1.9
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Upstream commit: 4760df0f39baef682278986b9f0e85ce8035cdd2
This adds support for gcc 5.
In kernel version >= 3.18 this is shipped with the kernel, in kernel
version >= 4.2 all the gcc version specific files are merged into one
file.
This patch got backported to many kernel versions, but ignore it
because it is always the same file.
Upstream commit: 2fdda07a83179d14f41a15bf88ae396dae9d218d
This adds page_is_pfmemalloc() which is used by the igb driver.
The direct access to page->pfmemalloc was replaced by this function
call in 54d985ce23 upstream commit.
Upstream commit: 4651f18572bb96d7232fdbcfb84beb7d58ab9f8f
In older kernel versions the first parameter is "struct inet_frag_queue
*q", now it is "struct netns_frags *nf", This patch adds the new
versions of this function to all kernel versions older than 4.3.
This change was done in upstream Linux kernel in this commit:
commit 0e60d245a0be7fdbb723607f1d6621007916b252
Author: Florian Westphal <fw@strlen.de>
Date: Thu Jul 23 12:05:38 2015 +0200
inet: frag: change *_frag_mem_limit functions to take netns_frags as argument
Upstream commit: 3fff9e333655c5e8aece30fd387ea5ded2c1bd46
An ifdef for the kernel version was missing around the header of
debugfs_create_devm_seqfile() and the LINUX_BACKPORT() was also not
added.
The media framework now uses the frame vector code which is only
available from kernel 4.2 onwards. This backports the code.
The get_user_pages_locked() function is needed by the frame vector code
which will be added in the next patch. While adding that, this patch
also replaces the get_user_pages_unlocked() function with the original
version from the next kernel.
The led_trigger_remove() function is exported on older kernel versions,
but there is no pubic prototype for this function. Now the first driver
makes use of this function and this patch adds the prototype.
There is no LINUX_BACKPORT() guard here because we want it to point to
the original function which is exported normally.
It should be save to just copy it.
This was added in this upstream commit:
commit 9961127d4bce6325e9a0b0fb105e0c85a6c62cb7
Author: Vincent Cuissard <cuissard@marvell.com>
Date: Thu Jun 11 11:25:47 2015 +0200
NFC: nci: add generic uart support
This is not used by any code in backports and was also removed from the
mainline kernel.
In the mainline kernel the kernel module parameter locking is not
protected by a global lock any more, but each module has its own lock
now. This resulted in some changes in the api. This patch converts
calls to the new api to the old one.
This backports the changes done in this commit:
commit b51d23e4e9fea6f264d39535c2a62d1f51e7ccc3
Author: Dan Streetman <ddstreet@ieee.org>
Date: Wed Jun 17 06:18:52 2015 +0930
module: add per-module param_lock
The same include guard is also used in backport/backport-include
/asm-generic/barrier.h which prevents both files from being included at
the same time.
Reported-by: Martin Tippmann <martin.tippmann@gmail.com>
The net/route.h header is missing when compiling against the android msm
kernel. Explicitly add it here to make the kernel compile.
Signed-off-by: Florian Grandel <fgrandel@gmail.com>
When building the kernel there are lots of warnings like this:
drivers/net/wireless/ath/ath10k/ce.c:404:21: warning: unused variable ‘ar_pci’ [-Wunused-variable]
struct ath10k_pci *ar_pci = ath10k_pci_priv(ar);
They are caused by an empty lockdep_assert_held() which does nothing
with this variable in kernel version < 3.9. This patch replaces this
macro with the version from a recent kernel and silence this warning.
This is needed by the mt7601u driver.
The mt7601u driver makes use of some of these functions and they are
not available on kernel version < 3.19.
tty_set_termios() was not exported any more in kernel 4.0-rc1 (commit
632f32e21) and exported again in kernel 4.1-rc2 (commit b00f5c2dc).
This patch adds the backport for kernel 4.0.X, we can not detect kernel
4.1-rc1, which would also need this fix, so bluetooth will have a
compile error on kernel 4.1-rc1, kernel 4.1-rc2 and more recent
versions will work.
Before we only copied the hdmi.h header file and not the driver. Now
some other drivers need the hdmi driver code, also copy it now too.
mac80211 makes use of the new AEAD crypto api since commit 957e0fe629.
This patch provides a backport layer which converts the new API to the
old one used in older kernel versions. This backport is based on this
mainline commit: 996d98d85.
Cc: Johannes Berg <johannes.berg@intel.com>
rt6_nexthop() got an additional parameter in commit 2647a9b0. Instead
of only backporting it for kernel < 3.10 do it now for kernel version <
4.2.
The brcmfmac driver now uses the ACPI_COMPANION() macro which was
introduced in v3.13 kernel. This provides a backport of that macro
for older kernels.
Signed-off-by: Arend van Spriel <arend@broadcom.com>
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Signed-off-by: Jonathan Liu <net147@gmail.com>
Linux commit eeb1bd5c4 added a new parameter to sock_create_kern(). In
the original function it was replaced with &init_net every time, now it
is taken from the parameter.
Linux commit 11aa9c28 added a new parameter to sk_alloc() which is not
available on older kernel versions. Just ignore it on these older
versions.
This feature was backported to kernel 3.18.12 and we should not
activate it on these kernel versions any more.
Reported-by: Jonas Gorski <jogo@openwrt.org>
Canonical backported:
Author: Or Gerlitz <ogerlitz@mellanox.com>
Date: Mon Jan 20 13:59:19 2014 +0200
net: Add GRO support for UDP encapsulating protocols
This is commit 2da204a8f67fbe25816cbce8cc8551f03d5b951a in their
tree.
Cope with that.
[changed bool, it should be build when the kernel version is != 3.13.11]
add_device_randomness() is now used by ath9k. This function was
introduced in commit a2080a67abe9 , and then backported to many stable
kernel versions.
backports only adds the possible_{write,read}_pnet() functions for
kernel < 4.1. This results in a compile error on kernel 4.1. This patch
make it use the original functions on these kernel versions. This fixes
a problem introduced in 3d418885971.
Cc: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
This adds the necessary backporting to handle netdev->tstats which
was introduced in 3.14 (and some helper macros in 3.15).
For some reason my spatch isn't reliably patching the occurrence
in net/mac80211/tx.c, so for now I'm including a manual patch.
Change-Id: Ib22e307a9bd31f6c31372ef8cc2828ca6e14fce4
debugfs.h needs device.h, otherwise you get a warning
backport-include/linux/debugfs.h:11:10: warning: ‘struct device’ declared inside parameter list
Change-Id: Ic669c855d47a8114649d1d319fcb1bcdc024415c
These functions are used by some media drivers since 4f528afc.
v4l2 makes use of TRACE_DEFINE_ENUM. This was introduced in 0c564a538
and is not supported in older kernel versions, implement it empty.
This was introduced in commit 9b174527e and is used by the media
drivers.
The genl changes were backported to RHEL 7.0
This fixes compalation on RHEL 7.1
This backport is not needed because it is already provided by all
supported kernel versions.
This macro is used by some media drivers and was added to the kernel in
commit 95c0fd457.
This adds the DIV_ROUND_CLOSEST_ULL macro which was added to the kernel
in 350f28a7a. In addition this patch fixes some problems in the
DIV_ROUND_CLOSEST macro. Both are copied from the kernel.
In kernel 3.17 struct timespec64 was introduced.
commit 361a3bf00582469877f8d18ff20f1efa6b781274
Author: John Stultz <john.stultz@linaro.org>
Date: Wed Jul 16 21:03:58 2014 +0000
time64: Add time64.h header and define struct timespec64
git describe --contains 361a3bf00582469877f8d18ff20f1efa6b781274
v3.17-rc1~109^2~62
Deal with the required changes via defines.
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
[Moved defines into the same header files as in mailine kernel, removed some ktime_*]
This is required by igb and possibly other network drivers.
[change to EXPORT_SYMBOL_GPL]
Instead of just assuming CONFIG_NET_NS is defined, deal with
this better. Sadly, it needs a header file patch (as an spatch
doesn't deal properly with header files.)
This wifi driver was missing before.
This driver uses the cfg80211 so we should ship it.
The bluetooth code needs this function. It was introduced in upstream
commit b4772ef87.
backport the commit 36ef906ee8fefbfac3844206e66d8450e6221c69
("wext: add checked wrappers for adding events/points to streams")
