2015-06-16patches: refresh patches on next-20150612Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.107 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.75 [ OK ] 12 3.11.10 [ OK ] 13 3.12.40 [ OK ] 14 3.13.11 [ OK ] 15 3.14.39 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.12 [ OK ] 20 3.19.5 [ OK ] 21 4.0.0 [ OK ] 22 4.1-rc1 [ FAIL ] Only kernel 4.1-rc1 will fail, because tty_set_termios() is not exported, 4.1-rc4 works. manual changes done to: drivers/media/platform/vim2m.c Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15patches: fix tracing on older kernels for mt7601uHauke Mehrtens
On kernel version < 3.4 we have to include linux/interrupt.h, because it otherwise results in a long compile errors about missing HI_SOFTIRQ for example. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15patches: deactivate struct tracing in mt7601uHauke Mehrtens
The mt7601u driver makes use of __field_struct which was added in Linux commit 4d4c9cc83. It is hard to backport this feature, so just remove the code using it on kernel version < 3.16. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15backports: add mediatek mt7601u driverHauke Mehrtens
2015-06-15header: add devm_kcalloc()Hauke Mehrtens
This is needed by the mt7601u driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15header: add dev_dbg_once() and othersHauke Mehrtens
The mt7601u driver makes use of some of these functions and they are not available on kernel version < 3.19. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15backports: add tty_set_termios()Hauke Mehrtens
tty_set_termios() was not exported any more in kernel 4.0-rc1 (commit 632f32e21) and exported again in kernel 4.1-rc2 (commit b00f5c2dc). This patch adds the backport for kernel 4.0.X, we can not detect kernel 4.1-rc1, which would also need this fix, so bluetooth will have a compile error on kernel 4.1-rc1, kernel 4.1-rc2 and more recent versions will work. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15patches: do not use vidioc_expbuf function pointer in v4lHauke Mehrtens
More v4l drivers are now accessing the vidioc_expbuf function pointer in struct v4l2_ioctl_ops which we can not backport to kernel < 3.5. This adds some more checks around the places. We should convert this to an spatch. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15backports: add HDMI driverHauke Mehrtens
Before we only copied the hdmi.h header file and not the driver. Now some other drivers need the hdmi driver code, also copy it now too. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15dependencies: make VIDEO_ADP1653 depend on kernel >= 3.13Hauke Mehrtens
The driver VIDEO_ADP1653 now includes linux/gpio/consumer.h which is not available in kernel versions < 3.13. This patch makes the driver depend on kernel version >= 3.13. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15dependencies: make VIDEO_ADV7604 depend on kernel >= 3.17Hauke Mehrtens
The VIDEO_ADV7604 driver now makes use of devm_gpiod_get_index_optional() which gets less parameters in older kernel versions. This makes the driver depend on kernel >= 3.17. In addition also the VIDEO_COBALT has to depend on this kernel version because it selects VIDEO_ADV7604. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15dependencies: make two media tuners depend on kernel >= 3.3Hauke Mehrtens
The drivers MEDIA_TUNER_FC2580 and MEDIA_TUNER_TUA9001 are using devm_regmap_init_i2c() which is only believable on kernel >= 3.3, add a dependency to the driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15dependencies: make DVB_M88DS3103 and DVB_TS2020 depend on kernel > 3.8Hauke Mehrtens
The drivers DVB_M88DS3103 and DVB_TS2020 are accessing some member in struct regmap_config which is not available in kernel version < 3.8. These drivers are getting selected by some other drivers, which are now also depending on kernel >= 3.8, otherwise KConfig would ignore the dependency on kernel >= 3.8 Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15dependencies: add VIDEO_COBALTHauke Mehrtens
VIDEO_COBALT selects VIDEO_ADV7604, but VIDEO_ADV7604 should only be build on kernel versions >= 3.13. On older kernel versions this causes this warning which makes Kconfig ignore the dependency on kernel version >= 3.13. warning: (VIDEO_COBALT) selects VIDEO_ADV7604 which has unmet direct dependencies (MEDIA_SUPPORT && !KERNEL_3_13 && m && <choice> && VIDEO_V4L2 && I2C && VIDEO_V4L2_SUBDEV_API && GPIOLIB) Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15backports: add backport for new AEAD crypto APIHauke Mehrtens
mac80211 makes use of the new AEAD crypto api since commit 957e0fe629. This patch provides a backport layer which converts the new API to the old one used in older kernel versions. This backport is based on this mainline commit: 996d98d85. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: Johannes Berg <johannes.berg@intel.com>
2015-06-15patches: rhashtable header patch not neededHauke Mehrtens
This patch, adding a missing include to rhashtable.c, is not needed any more, because it went into upstream in commit 6d7954130. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15patches: remove additional member in struct mei_cl_device_idHauke Mehrtens
The uuid member was added to the struct mei_cl_device_id in this commit: commit c93b76b34b4d8dbe8e3443eb27e49ac60034342b Author: Tomas Winkler <tomas.winkler@intel.com> Date: Thu May 7 15:54:02 2015 +0300 mei: bus: report also uuid in module alias Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15header: fix rt6_nexthop() backportHauke Mehrtens
rt6_nexthop() got an additional parameter in commit 2647a9b0. Instead of only backporting it for kernel < 3.10 do it now for kernel version < 4.2. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15patches: include linux/sched.h header in drivers/nfc/mei_phy.cHauke Mehrtens
This additional include is needed to prevent this error with kernel 3.10: In file included from /home/hauke/compat-wireless/tmp/backport-include/linux/wait.h:3:0, from include/linux/mmzone.h:9, from include/linux/gfp.h:4, from include/linux/kmod.h:22, from include/linux/module.h:13, from /home/hauke/compat-wireless/tmp/backport-include/linux/module.h:3, from /home/hauke/compat-wireless/tmp/drivers/nfc/mei_phy.c:21: /home/hauke/compat-wireless/tmp/drivers/nfc/mei_phy.c: In function ‘mei_nfc_send’: include/linux/wait.h:296:33: error: ‘TASK_INTERRUPTIBLE’ undeclared (first use in this function) prepare_to_wait(&wq, &__wait, TASK_INTERRUPTIBLE); \ ^ ..... Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15patches: fix tracing on older kernels for cfg80211, ath6kl and wil6210Hauke Mehrtens
On kernel 3.0 we have to include linux/interrupt.h, because it otherwise results in a long compile errors about missing HI_SOFTIRQ for example. It looks like it was not possible to activate tracing without this patch on these drivers at all. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-14patches: fix spatch for bluetoothHauke Mehrtens
Commit 8e879bf1f in backports converted some bluetooth patches into an spatch. There was a problem in this conversion, the second argument is not struct socket, but struct sock. This causes some warnings in the kernel build. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-06-09backports: refresh patches again for next-20150525Luis R. Rodriguez
This refresh patches again after application of all pending patches. mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --verbose \ --refresh /home/mcgrof/linux-next /home/mcgrof/build/backports-20150525 .... real 3m25.658s user 27m6.472s sys 3m38.704s mcgrof@drvbp1 ~/build/backports-20150525 $ time \ /home/mcgrof/backports/devel/ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.107 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.75 [ OK ] 12 3.11.10 [ OK ] 13 3.12.40 [ OK ] 14 3.13.11 [ OK ] 15 3.14.39 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.12 [ OK ] 20 3.19.5 [ OK ] 21 4.0.0 [ OK ] 22 4.1-rc1 [ OK ] real 53m59.426s user 1440m34.548s sys 219m41.952s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-06-09pycocci: sync pycocci with Coccinelle upstreamLuis R. Rodriguez
pycocci is now part of Coccinelle upstream. Coccinelle has a plan to actually extend multithreaded support to enable us to not have to script this out. Until then pyccoci is used and I'll sync both solutions up as there is a bit of latency between a coccinelle release and what we may need from pycocci. Please send patches or report issues about pycocci to the coccinelle mailing list. This commit syncs pycocci with the upstream pycocci with just one minor change introduced: commit cf8ef1aee7d40cddfee0f8707b2f481eb8258b4d Author: Luis R. Rodriguez <mcgrof@suse.com> Date: Fri May 29 15:15:57 2015 -0700 pycocci: update Python script to print errors clearly When you run into errors with the pycocci script errors seem cryptic, fix this. While at it also spit out what the script will run, as typically when debugging you just want to runt he same commands on your own. For instance, when run on a 32 core machine you'll now see: mcgrof@drvbp1 ~/linux-next (git::master)$ time pycocci rename-dma.cocci ./ spatch --sp-file rename-dma.cocci --in-place --recursive-includes --relax-include-path --use-coccigrep --timeout 120 --dir ./ -max 32 -index 0 ... spatch --sp-file rename-dma.cocci --in-place --recursive-includes --relax-include-path --use-coccigrep --timeout 120 --dir ./ -max 32 -index 27 real 0m50.074s user 14m50.168s sys 2m8.260s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-06-09patches: provide 0054-struct-proto_ops-sig SmPL patch replacementLuis R. Rodriguez
This replaces the 436 line of unified diff with 152 lines of grammar Coccinelle SmPL patch. SmPL patch equivalence proof tests reveals only cosmetic changes between using Coccinelle SmPL and unified diff as shown below. The difference shown are the results of two trees, one in which we applied the SmPL patch, and another in which the old unified patch series were used. This gives us an idea of what Coccinelle did differently. 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.107 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.75 [ OK ] 12 3.11.10 [ OK ] 13 3.12.40 [ OK ] 14 3.13.11 [ OK ] 15 3.14.39 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.12 [ OK ] 20 3.19.5 [ OK ] 21 4.0.0 [ OK ] 22 4.1-rc1 [ OK ] mcgrof@ergon ~/backports (git::master)$ time \ ./gentree.py --clean --prove-cocci \ patches/collateral-evolutions/network/0054-struct-proto_ops-sig.cocci \ /home/mcgrof/linux-next/ /home/mcgrof/build/backports-20150525 Copy original source files ... Applying patches from patches to /home/mcgrof/build/backports-20150525 ... Proving Coccinelle SmPL patch: 0054-struct-proto_ops-sig.cocci Aggregating patch for Coccinelle SmPL 0054-struct-proto_ops-sig proof: ieee802154.patch Aggregating patch for Coccinelle SmPL 0054-struct-proto_ops-sig proof: nfc.patch Aggregating patch for Coccinelle SmPL 0054-struct-proto_ops-sig proof: bluetooth.patch Review the difference between what the tree looks like by applying your SmPL patch, then reverting that and only applying your the patches in the patch series. Change directory to /home/mcgrof/build/backports-20150525 and run 'git diff' diff stat of the changes: net/bluetooth/hci_sock.c | 11 +++++------ 1 file changed, 5 insertions(+), 6 deletions(-) Done! real 0m21.965s user 0m45.947s sys 0m4.072s Now when I change directory to /home/mcgrof/build/backports-20150525 and run 'git diff' I get: diff --git a/net/bluetooth/hci_sock.c b/net/bluetooth/hci_sock.c index 9326bc8..9ca0166 100644 --- a/net/bluetooth/hci_sock.c +++ b/net/bluetooth/hci_sock.c @@ -956,7 +956,8 @@ static int hci_sock_recvmsg(struct socket *sock, struct msghdr *msg, size_t len, #if LINUX_VERSION_CODE < KERNEL_VERSION(4,1,0) static int backport_hci_sock_recvmsg(struct kiocb *iocb, struct socket *sock, struct msghdr *msg, size_t len, - int flags){ + int flags) +{ return hci_sock_recvmsg(sock, msg, len, flags); } #endif /* LINUX_VERSION_CODE < KERNEL_VERSION(4,1,0) */ @@ -1198,7 +1199,8 @@ drop: } #if LINUX_VERSION_CODE < KERNEL_VERSION(4,1,0) static int backport_hci_sock_sendmsg(struct kiocb *iocb, struct socket *sock, - struct msghdr *msg, size_t len){ + struct msghdr *msg, size_t len) +{ return hci_sock_sendmsg(sock, msg, len); } #endif /* LINUX_VERSION_CODE < KERNEL_VERSION(4,1,0) */ @@ -1360,12 +1362,9 @@ static const struct proto_ops hci_sock_ops = { .getname = hci_sock_getname, #if LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0) .sendmsg = hci_sock_sendmsg, -#else - .sendmsg = backport_hci_sock_sendmsg, -#endif /* LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0) */ -#if LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0) .recvmsg = hci_sock_recvmsg, #else + .sendmsg = backport_hci_sock_sendmsg, .recvmsg = backport_hci_sock_recvmsg, #endif /* LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0) */ .ioctl = hci_sock_ioctl, Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-06-09patches: change 0054-struct-proto_ops-sig backport strategyLuis R. Rodriguez
This modifies we backport the struct proto_ops and struct proto declarations from adding #idefs around the function prototype arguments to just declaring our own new backport callback for older kernels with the extra argument which calls the the upstream function. This is done because we cannot write an SmPL grammar patch to backport the collateral evolution as we do it now. The backport strategy we provide now is equivalent in terms of functionality but also a lot more clear, it also leaves the upstream code unmodified as much as possible, this should enable anyone reviewing the code to be able to more easily determine exactly what is going on. 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.107 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.75 [ OK ] 12 3.11.10 [ OK ] 13 3.12.40 [ OK ] 14 3.13.11 [ OK ] 15 3.14.39 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.12 [ OK ] 20 3.19.5 [ OK ] 21 4.0.0 [ OK ] 22 4.1-rc1 [ OK ] real 53m48.791s user 1437m15.048s sys 217m20.652s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-06-09patches: remove bt_sock_stream_recvmsg() and bt_sock_recvmsg() from ifdefsLuis R. Rodriguez
Both bt_sock_recvmsg() and bt_sock_stream_recvmsg() are used within bluetooth code but the backport actually required is only for the struct proto_ops and struct proto sendmsg and recvmsg callbacks. The bt_sock_recvmsg() and bt_sock_stream_recvmsg() are not callbacks, they are exported but are used all within the code we provide and carry. This will help simplify the network/0054-struct-proto_ops-sig collateral evolution port to Coccinelle SmPL. 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.107 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.75 [ OK ] 12 3.11.10 [ OK ] 13 3.12.40 [ OK ] 14 3.13.11 [ OK ] 15 3.14.39 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.12 [ OK ] 20 3.19.5 [ OK ] 21 4.0.0 [ OK ] 22 4.1-rc1 [ OK ] Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-06-09backports: include: introduce backport for ACPI_COMPANION() macroArend van Spriel
The brcmfmac driver now uses the ACPI_COMPANION() macro which was introduced in v3.13 kernel. This provides a backport of that macro for older kernels. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-06-09backports: add missing include for vfreeJonathan Liu
Signed-off-by: Jonathan Liu <net147@gmail.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-06-09backports: replace igb pfmemalloc patch with semantic patchStefan Assmann
Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-06-09backports: replace igb xmit_more patch with semantic patchStefan Assmann
2015-06-09backports: replace igb ethtool_cmd_mdix patch with semantic patchStefan Assmann
2015-06-09backports: replace igb skb->no_fcs patch with semantic patchStefan Assmann
2015-05-25patches: refresh patches on next-20150525backports-20150525Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.107 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.75 [ OK ] 12 3.11.10 [ OK ] 13 3.12.40 [ OK ] 14 3.13.11 [ OK ] 15 3.14.39 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.12 [ OK ] 20 3.19.5 [ OK ] 21 4.0.0 [ OK ] 22 4.1-rc1 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-25header: handler new parameter net in sock_create_kern()Hauke Mehrtens
Linux commit eeb1bd5c4 added a new parameter to sock_create_kern(). In the original function it was replaced with &init_net every time, now it is taken from the parameter. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-25header: remove last parameter from sk_alloc()Hauke Mehrtens
Linux commit 11aa9c28 added a new parameter to sk_alloc() which is not available on older kernel versions. Just ignore it on these older versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-25header: do not backport wait functions on kernel >= 3.18.12Hauke Mehrtens
This feature was backported to kernel 3.18.12 and we should not activate it on these kernel versions any more. Reported-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-25backport: allow compilation with Ubuntu's 3.13Emmanuel Grumbach
Canonical backported: Author: Or Gerlitz <ogerlitz@mellanox.com> Date: Mon Jan 20 13:59:19 2014 +0200 net: Add GRO support for UDP encapsulating protocols This is commit 2da204a8f67fbe25816cbce8cc8551f03d5b951a in their tree. Cope with that. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> [changed bool, it should be build when the kernel version is != 3.13.11] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-25backports: fix netdev->tstats backportJohannes Berg
Given a correct spatch, there's no need for the other manual patch. Thanks to Julia for pointing out my error in building the original spatch, and how to fix it. Change-Id: I0226a6c4d0fb7630abee315f1839ba63534aacbb Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-11patches: refresh patches on next-20150511backports-20150511Hauke Mehrtens
2015-05-11header: add dummy add_device_randomness()Hauke Mehrtens
add_device_randomness() is now used by ath9k. This function was introduced in commit a2080a67abe9 , and then backported to many stable kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-11patches: add ifdef around vb2_ioctl_expbuf()Hauke Mehrtens
There are some new places where vb2_ioctl_expbuf() is used, add ifdefs around these palaces. This should be replaced by a spatch or something else. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-11header: add possible_{write,read}_pnet() on kernel >= 4.1Hauke Mehrtens
backports only adds the possible_{write,read}_pnet() functions for kernel < 4.1. This results in a compile error on kernel 4.1. This patch make it use the original functions on these kernel versions. This fixes a problem introduced in 3d418885971. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-05-11backports: fix incorrect disabling of CONFIG optionsStefan Assmann
gentree.py incorrectly disabled CONFIG options that share part of the name with another already disabled CONFIG option. For example if CONFIG_E100 was disabled you no longer could enable CONFIG_E1000 or CONFIG_E1000E. Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-11backports: handle netdev->tstatsJohannes Berg
This adds the necessary backporting to handle netdev->tstats which was introduced in 3.14 (and some helper macros in 3.15). For some reason my spatch isn't reliably patching the occurrence in net/mac80211/tx.c, so for now I'm including a manual patch. Change-Id: Ib22e307a9bd31f6c31372ef8cc2828ca6e14fce4 Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-11backports: include missing device.hJohannes Berg
debugfs.h needs device.h, otherwise you get a warning backport-include/linux/debugfs.h:11:10: warning: ‘struct device’ declared inside parameter list Change-Id: Ic669c855d47a8114649d1d319fcb1bcdc024415c Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-11backports: update mac80211 LED patchJohannes Berg
The recent mac80211 LED changes broke the patch, fix it up and make it apply again. Change-Id: I4bf9595fb947886e68fa08592bd2cd3b7965f223 Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-28devel: update the test kernelsHauke Mehrtens
2015-04-27backports: fix coccinelle version checkEliad Peller
bpreqs.py assumes the max rc level is 20. However, backports currently requires coccinelle 1.0.0-rc24 (which is the latest rc before 1.0.0). This resulted in 1.0.0-rc24 getting higher weight than 1.0.0, which failed the dependency check. Fix it by increasing the max rc to 25 (and use a constant for it) Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-26patches: refresh patches on next-20150424backports-20150424Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.106 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.73 [ OK ] 12 3.11.10 [ OK ] 13 3.12.39 [ OK ] 14 3.13.11 [ OK ] 15 3.14.37 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.10 [ OK ] 20 3.19.3 [ OK ] 21 4.0-rc6 [ OK ] manual changes done to patches/collateral-evolutions/network/0053-remove_wait_on_bit_timeout/btusb.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-26patches: do not use EPROBE_DEFER in mediaHauke Mehrtens
This was added in commit 4f528afc. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
