VIDEO_COBALT selects VIDEO_ADV7604, but VIDEO_ADV7604 should only be
build on kernel versions >= 3.13. On older kernel versions this causes
this warning which makes Kconfig ignore the dependency on kernel version
>= 3.13.
warning: (VIDEO_COBALT) selects VIDEO_ADV7604 which has unmet direct
dependencies (MEDIA_SUPPORT && !KERNEL_3_13 && m && <choice> &&
VIDEO_V4L2 && I2C && VIDEO_V4L2_SUBDEV_API && GPIOLIB)
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
mac80211 makes use of the new AEAD crypto api since commit 957e0fe629.
This patch provides a backport layer which converts the new API to the
old one used in older kernel versions. This backport is based on this
mainline commit: 996d98d85.
Cc: Johannes Berg <johannes.berg@intel.com>
This patch, adding a missing include to rhashtable.c, is not needed any
more, because it went into upstream in commit 6d7954130.
The uuid member was added to the struct mei_cl_device_id in this commit:
commit c93b76b34b4d8dbe8e3443eb27e49ac60034342b
Author: Tomas Winkler <tomas.winkler@intel.com>
Date: Thu May 7 15:54:02 2015 +0300
mei: bus: report also uuid in module alias
rt6_nexthop() got an additional parameter in commit 2647a9b0. Instead
of only backporting it for kernel < 3.10 do it now for kernel version <
4.2.
This additional include is needed to prevent this error with kernel 3.10:
In file included from /home/hauke/compat-wireless/tmp/backport-include/linux/wait.h:3:0,
from include/linux/mmzone.h:9,
from include/linux/gfp.h:4,
from include/linux/kmod.h:22,
from include/linux/module.h:13,
from /home/hauke/compat-wireless/tmp/backport-include/linux/module.h:3,
from /home/hauke/compat-wireless/tmp/drivers/nfc/mei_phy.c:21:
/home/hauke/compat-wireless/tmp/drivers/nfc/mei_phy.c: In function ‘mei_nfc_send’:
include/linux/wait.h:296:33: error: ‘TASK_INTERRUPTIBLE’ undeclared (first use in this function)
prepare_to_wait(&wq, &__wait, TASK_INTERRUPTIBLE); \
On kernel 3.0 we have to include linux/interrupt.h, because it
otherwise results in a long compile errors about missing HI_SOFTIRQ for
example. It looks like it was not possible to activate tracing without
this patch on these drivers at all.
Commit 8e879bf1f in backports converted some bluetooth patches into an
spatch. There was a problem in this conversion, the second argument is
not struct socket, but struct sock. This causes some warnings in the
kernel build.
Cc: Luis R. Rodriguez <mcgrof@do-not-panic.com>
This refresh patches again after application of all pending
patches.
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --verbose \
--refresh /home/mcgrof/linux-next /home/mcgrof/build/backports-20150525
real 3m25.658s
user 27m6.472s
sys 3m38.704s
mcgrof@drvbp1 ~/build/backports-20150525 $ time \
/home/mcgrof/backports/devel/ckmake --allyesconfig
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
real 53m59.426s
user 1440m34.548s
sys 219m41.952s
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
pycocci is now part of Coccinelle upstream. Coccinelle has a plan
to actually extend multithreaded support to enable us to not have
to script this out. Until then pyccoci is used and I'll sync both
solutions up as there is a bit of latency between a coccinelle release
and what we may need from pycocci.
Please send patches or report issues about pycocci to the coccinelle
mailing list.
This commit syncs pycocci with the upstream pycocci with just one
minor change introduced:
commit cf8ef1aee7d40cddfee0f8707b2f481eb8258b4d
Author: Luis R. Rodriguez <mcgrof@suse.com>
Date: Fri May 29 15:15:57 2015 -0700
pycocci: update Python script to print errors clearly
When you run into errors with the pycocci script errors
seem cryptic, fix this. While at it also spit out what the
script will run, as typically when debugging you just want
to runt he same commands on your own.
For instance, when run on a 32 core machine you'll now see:
mcgrof@drvbp1 ~/linux-next (git::master)$ time pycocci rename-dma.cocci ./
spatch --sp-file rename-dma.cocci --in-place --recursive-includes --relax-include-path --use-coccigrep --timeout 120 --dir ./ -max 32 -index 0
spatch --sp-file rename-dma.cocci --in-place --recursive-includes --relax-include-path --use-coccigrep --timeout 120 --dir ./ -max 32 -index 27
real 0m50.074s
user 14m50.168s
sys 2m8.260s
This replaces the 436 line of unified diff with 152
lines of grammar Coccinelle SmPL patch. SmPL patch
equivalence proof tests reveals only cosmetic changes
between using Coccinelle SmPL and unified diff as shown
below. The difference shown are the results of two
trees, one in which we applied the SmPL patch, and another
in which the old unified patch series were used. This
gives us an idea of what Coccinelle did differently.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
mcgrof@ergon ~/backports (git::master)$ time \
./gentree.py --clean --prove-cocci \
patches/collateral-evolutions/network/0054-struct-proto_ops-sig.cocci \
/home/mcgrof/linux-next/ /home/mcgrof/build/backports-20150525
Copy original source files ...
Applying patches from patches to
/home/mcgrof/build/backports-20150525 ...
Proving Coccinelle SmPL patch: 0054-struct-proto_ops-sig.cocci
Aggregating patch for Coccinelle SmPL 0054-struct-proto_ops-sig proof: ieee802154.patch
Aggregating patch for Coccinelle SmPL 0054-struct-proto_ops-sig proof: nfc.patch
Aggregating patch for Coccinelle SmPL 0054-struct-proto_ops-sig proof: bluetooth.patch
Review the difference between what the tree looks like
by applying your SmPL patch, then reverting that and
only applying your the patches in the patch series.
Change directory to /home/mcgrof/build/backports-20150525 and run 'git diff'
diff stat of the changes:
net/bluetooth/hci_sock.c | 11 +++++------
1 file changed, 5 insertions(+), 6 deletions(-)
Done!
real 0m21.965s
user 0m45.947s
sys 0m4.072s
Now when I change directory to /home/mcgrof/build/backports-20150525 and
run 'git diff' I get:
diff --git a/net/bluetooth/hci_sock.c b/net/bluetooth/hci_sock.c
index 9326bc8..9ca0166 100644
--- a/net/bluetooth/hci_sock.c
+++ b/net/bluetooth/hci_sock.c
@@ -956,7 +956,8 @@ static int hci_sock_recvmsg(struct socket *sock,
struct msghdr *msg, size_t len,
#if LINUX_VERSION_CODE < KERNEL_VERSION(4,1,0)
static int backport_hci_sock_recvmsg(struct kiocb *iocb, struct socket
*sock,
- int flags){
+ int flags)
return hci_sock_recvmsg(sock, msg, len, flags);
#endif /* LINUX_VERSION_CODE < KERNEL_VERSION(4,1,0) */
@@ -1198,7 +1199,8 @@ drop:
static int backport_hci_sock_sendmsg(struct kiocb *iocb, struct socket
*sock,
- struct msghdr *msg, size_t len){
+ struct msghdr *msg, size_t len)
return hci_sock_sendmsg(sock, msg, len);
@@ -1360,12 +1362,9 @@ static const struct proto_ops hci_sock_ops = {
.getname = hci_sock_getname,
#if LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0)
.sendmsg = hci_sock_sendmsg,
-#else
- .sendmsg = backport_hci_sock_sendmsg,
-#endif /* LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0) */
-#if LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0)
.recvmsg = hci_sock_recvmsg,
#else
+ .sendmsg = backport_hci_sock_sendmsg,
.recvmsg = backport_hci_sock_recvmsg,
.ioctl = hci_sock_ioctl,
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
This modifies we backport the struct proto_ops and struct proto
declarations from adding #idefs around the function prototype
arguments to just declaring our own new backport callback for
older kernels with the extra argument which calls the the
upstream function. This is done because we cannot write an
SmPL grammar patch to backport the collateral evolution as we
do it now. The backport strategy we provide now is equivalent
in terms of functionality but also a lot more clear, it also
leaves the upstream code unmodified as much as possible, this
should enable anyone reviewing the code to be able to more
easily determine exactly what is going on.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
real 53m48.791s
user 1437m15.048s
sys 217m20.652s
Both bt_sock_recvmsg() and bt_sock_stream_recvmsg() are used
within bluetooth code but the backport actually required is only
for the struct proto_ops and struct proto sendmsg and recvmsg
callbacks. The bt_sock_recvmsg() and bt_sock_stream_recvmsg()
are not callbacks, they are exported but are used all within
the code we provide and carry.
This will help simplify the network/0054-struct-proto_ops-sig
collateral evolution port to Coccinelle SmPL.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
The brcmfmac driver now uses the ACPI_COMPANION() macro which was
introduced in v3.13 kernel. This provides a backport of that macro
for older kernels.
Signed-off-by: Arend van Spriel <arend@broadcom.com>
Signed-off-by: Jonathan Liu <net147@gmail.com>
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
Linux commit eeb1bd5c4 added a new parameter to sock_create_kern(). In
the original function it was replaced with &init_net every time, now it
is taken from the parameter.
Linux commit 11aa9c28 added a new parameter to sk_alloc() which is not
available on older kernel versions. Just ignore it on these older
versions.
This feature was backported to kernel 3.18.12 and we should not
activate it on these kernel versions any more.
Reported-by: Jonas Gorski <jogo@openwrt.org>
Canonical backported:
Author: Or Gerlitz <ogerlitz@mellanox.com>
Date: Mon Jan 20 13:59:19 2014 +0200
net: Add GRO support for UDP encapsulating protocols
This is commit 2da204a8f67fbe25816cbce8cc8551f03d5b951a in their
tree.
Cope with that.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
[changed bool, it should be build when the kernel version is != 3.13.11]
Given a correct spatch, there's no need for the other manual
patch. Thanks to Julia for pointing out my error in building
the original spatch, and how to fix it.
Change-Id: I0226a6c4d0fb7630abee315f1839ba63534aacbb
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
add_device_randomness() is now used by ath9k. This function was
introduced in commit a2080a67abe9 , and then backported to many stable
kernel versions.
There are some new places where vb2_ioctl_expbuf() is used, add ifdefs
around these palaces.
This should be replaced by a spatch or something else.
backports only adds the possible_{write,read}_pnet() functions for
kernel < 4.1. This results in a compile error on kernel 4.1. This patch
make it use the original functions on these kernel versions. This fixes
a problem introduced in 3d418885971.
Cc: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
gentree.py incorrectly disabled CONFIG options that share part of the
name with another already disabled CONFIG option.
For example if CONFIG_E100 was disabled you no longer could enable
CONFIG_E1000 or CONFIG_E1000E.
This adds the necessary backporting to handle netdev->tstats which
was introduced in 3.14 (and some helper macros in 3.15).
For some reason my spatch isn't reliably patching the occurrence
in net/mac80211/tx.c, so for now I'm including a manual patch.
Change-Id: Ib22e307a9bd31f6c31372ef8cc2828ca6e14fce4
debugfs.h needs device.h, otherwise you get a warning
backport-include/linux/debugfs.h:11:10: warning: ‘struct device’ declared inside parameter list
Change-Id: Ic669c855d47a8114649d1d319fcb1bcdc024415c
The recent mac80211 LED changes broke the patch, fix it
up and make it apply again.
Change-Id: I4bf9595fb947886e68fa08592bd2cd3b7965f223
bpreqs.py assumes the max rc level is 20. However,
backports currently requires coccinelle 1.0.0-rc24
(which is the latest rc before 1.0.0).
This resulted in 1.0.0-rc24 getting higher weight
than 1.0.0, which failed the dependency check.
Fix it by increasing the max rc to 25 (and use
a constant for it)
Signed-off-by: Eliad Peller <eliad@wizery.com>
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.106 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.73 [ OK ]
12 3.11.10 [ OK ]
13 3.12.39 [ OK ]
14 3.13.11 [ OK ]
15 3.14.37 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.10 [ OK ]
20 3.19.3 [ OK ]
21 4.0-rc6 [ OK ]
manual changes done to
patches/collateral-evolutions/network/0053-remove_wait_on_bit_timeout/btusb.patch
This was added in commit 4f528afc.
devm_gpiod_get_optional() was not backported to older kernel versions
and the devm_gpiod_get_optional() function in kernel 3.16 has less
parameters.
The nxp-nci NFC driver was added in Linux commit dece45855 and needs an
additional header file.
These functions are used by some media drivers since 4f528afc.
v4l2 makes use of TRACE_DEFINE_ENUM. This was introduced in 0c564a538
and is not supported in older kernel versions, implement it empty.
This was introduced in commit 9b174527e and is used by the media
drivers.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.106 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.73 [ OK ]
12 3.11.10 [ OK ]
13 3.12.39 [ OK ]
14 3.13.11 [ OK ]
15 3.14.37 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.10 [ OK ]
20 3.19.3 [ OK ]
21 4.0-rc6 [ OK ]
The genl changes were backported to RHEL 7.0
This fixes compalation on RHEL 7.1
This backport is not needed because it is already provided by all
supported kernel versions.
This macro is used by some media drivers and was added to the kernel in
commit 95c0fd457.
struct net_device now has a new member name_assign_type which contains
the type of the mac address. It is currently only used to be shown in
sysfs. It should be save to just ignore it on older kernel versions.
This file is needed by some media drivers.
It only contains inline functions and macros, so it is save to copy it.
This adds the DIV_ROUND_CLOSEST_ULL macro which was added to the kernel
in 350f28a7a. In addition this patch fixes some problems in the
DIV_ROUND_CLOSEST macro. Both are copied from the kernel.
