2015-11-24patches: refresh on next-20151120backports-20151120Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.72 [ OK ] 4 3.3.8 [ OK ] 5 3.4.110 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.92 [ OK ] 12 3.11.10 [ OK ] 13 3.12.49 [ OK ] 14 3.13.11 [ OK ] 15 3.14.56 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.23 [ OK ] 20 3.19.8 [ OK ] 21 4.0.9 [ OK ] 22 4.1.12 [ OK ] 23 4.2.5 [ OK ] 24 4.3-rc7 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-24dependencies: make SOC_CAMERA_PLATFORM depend on kernel >= 3.9Hauke Mehrtens
soc camera uses the member link from the platform data struct soc_camera_device, this member was added in kernel 3.9. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-24patches: remove call to is_platform_device member of struct soc_camera_deviceHauke Mehrtens
struct soc_camera_device got the is_platform_device member function in kernel 3.19. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-24patches: remove access to fwnode member in struct deviceHauke Mehrtens
The firmware device node was added to struct device in ce793486e "driver core / ACPI: Represent ACPI companions using fwnode_handle" do not access it on older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-24header: add netif_tx_napi_add()Hauke Mehrtens
Older kernel versions do not support to only set NAPI for TX queues, so call the normal NAPI function and do it also for the used RX part. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-24backports: add nsecs_to_jiffies()Hauke Mehrtens
This method is declared in the header sine a long time, but the function is not exported since 3.17. Add it to backports, but rename it so it will not collide with the original version if it gets exported. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-24backports: add led_set_brightness_sync()Hauke Mehrtens
2015-11-24header: add of_node_full_name()Hauke Mehrtens
This function was added in commit 74a7f0844 "devicetree: add helper inline for retrieving a node's full name". Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-24header: include old media header files from new positionsHauke Mehrtens
The media header files were reorganized and the platform header files are now moved to include/linux/platform_data/media/. place some dummy files there and include the original files from there. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-23copy: add new header files for media devicesHauke Mehrtens
The media includes were reorganized, we have to include more files now. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-23copy: remove camera-rcar.hHauke Mehrtens
This file was removed in upstream kernel commit 22bc8625 "[media] rcar_vin: Remove obsolete platform data support" Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-23header: move smp_mb__after_atomic definition to the correct fileLuca Coelho
The smp_mb__after_atomic definition is in barrier.h in the mainline, but we currently include the backport in atomic.h. This may cause problems with certain include chain combinations. Move it to the correct place. Signed-off-by: Luca Coelho <luciano.coelho@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-23header: remove asm-generic/barrier.hHauke Mehrtens
This code is already in asm/barrier.h and that should always be included when asm-generic/barrier.h is. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-23header: make asm/atomic.h include asm/barrier.hHauke Mehrtens
asm/barrier.h was created in kernel version 3.4, before that version the code was in asm/atomic.h. Include it so we can add code to asm/barrier.h and use it also in kernel < 3.4. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15patches: refresh on next-20151115backports-20151115Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.72 [ OK ] 4 3.3.8 [ OK ] 5 3.4.110 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.92 [ OK ] 12 3.11.10 [ OK ] 13 3.12.49 [ OK ] 14 3.13.11 [ OK ] 15 3.14.56 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.23 [ OK ] 20 3.19.8 [ OK ] 21 4.0.9 [ OK ] 22 4.1.12 [ OK ] 23 4.2.5 [ OK ] 24 4.3-rc7 [ OK ] Bigger, manual changes were needed on patches/collateral-evolutions/media/0002-no_dmabuf/v4l2.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15defconfigs: update media defconfigHauke Mehrtens
2015-11-15defconfigs: update wifi defconfigsHauke Mehrtens
This adds the new driver CPTCFG_RTL8XXXU and removes the config option for CPTCFG_B43_PCMCIA. pcmcia support in b43 is now done in ssb. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15patches: remove wpan_dev_hard_header() on kernel < 3.18Hauke Mehrtens
wpan_dev_hard_header() accesses ieee802154_ptr which is not available on older kernel versions, remove this function on such kernel versions. We do not compile cfg802154 on such kernel versions any way, but the 6lowpan stack uses this header file and we need 6lowpan for bluetooth. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15patches: add forward declaration of struct wpan_dev to cfg802154.hHauke Mehrtens
Normally this forward declaration is coming from netdevice.h, but it was only added in more recent kernel versions there. This patch fixes the build with older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15header: add empty implementation of irq_of_parse_and_map()Hauke Mehrtens
When CONFIG_OF is not set kernel < 3.5 does not provide an empty implementation of this function, more recent kernels do so. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15header: make inet_frags_init_net() return somethingHauke Mehrtens
The return type changed from void to int to return some error code. Some code is now checking the return value which fails on older kernel versions when the function returns void. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15header: add inet_frags_uninit_net()Hauke Mehrtens
inet_frags_uninit_net() was added in commit 1d6119baf06 "net: fix percpu memory leaks" and is used by the 6lowpan part of ieee802154 in backports. percpu_counter_destroy() was added in kernel 3.9, so do not add this function on older kernel versions. This is currently only used by the 6lowpan part of ieee802154 which is only activated for kernel >= 3.18. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15header: add upstream version of clamp()Hauke Mehrtens
saa7164-encoder.c uses clamp() with constant values which fails on kernel version < 3.18 because the code wants to creates values of the same type and wants to assign variable values to them. The new code works with this kind of usage, use the new code also on older kernel versions to fix this problem. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15haeder: add napi_complete_done()Hauke Mehrtens
Upstream commit 3b47d30396 "net: gro: add a per device gro flush timer" added napi_complete_done(). On older kernel versions we will just use the old napi_complete() function, this should work without any problems, we only do not get the new improvements which need a more recent net subsystem. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15dependencies: make NFC_MRVL depend on kernel >= 3.3Hauke Mehrtens
This driver uses of_find_property() and devm_gpio_free() which are not available in this kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15dependencies: make NFC_FDP depend on kernel >= 3.13Hauke Mehrtens
This driver now uses the gpio consumer api. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15dependencies: make NFC_FDP_I2C depend on kernel >= 3.18Hauke Mehrtens
This driver makes use of the device_property..() functions which were introduces in kernel 3.18 with commit b31384fa5de37a "Driver core: Unified device properties interface for platform firmware" Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15copy: add drivers/net/wireless/realtek/Hauke Mehrtens
The realtek drivers were reorganized and are now located under realtek directory. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15copy: add new file include/trace/events/vb2.hHauke Mehrtens
2015-11-15backports: add of_find_property_value_of_size()Eliad Peller
commit 2e98a32a274274fca0e6e ("backport: add of_property_read_u64_array()") added a call to of_find_property_value_of_size(), which is a static function, causing compilation error. Implement it locally as well. Signed-off-by: Eliad Peller <eliadx.peller@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> [remove of_find_property_value_of_size() from backport-3.10.c] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07patches: refresh on next-20151013backports-20151013Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.72 [ OK ] 4 3.3.8 [ OK ] 5 3.4.110 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.92 [ OK ] 12 3.11.10 [ OK ] 13 3.12.49 [ OK ] 14 3.13.11 [ OK ] 15 3.14.56 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.23 [ OK ] 20 3.19.8 [ OK ] 21 4.0.9 [ OK ] 22 4.1.12 [ OK ] 23 4.2.5 [ OK ] 24 4.3-rc7 [ OK ] manual changes done to the following patches: * patches/collateral-evolutions/network/0059-uuid-in-mei/nfc.patch * patches/collateral-evolutions/network/0013-fix-makefile-includes/brcmfmac.patch * patches/collateral-evolutions/network/0062-acpi-gpio-remove/hci_bcm.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07dependencies: VIDEO_MT9P031 uses gpio consumerHauke Mehrtens
VIDEO_MT9P031 uses the GPIO consumer and should only be build on kernel version >= 3.13 Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07backport: add of_property_read_u64_array()Hauke Mehrtens
This function was added in commit b31384fa5 "Driver core: Unified device properties interface for platform firmware". Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07header: change check for ACPI_COMPANIONHauke Mehrtens
Instead of using the kernel version to check if we have to add a backport for ACPI_COMPANION check for it directly. RedHat 7 backported this change to their kernel and writes a warning without this change. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07header: add nla_get_le32() and nla_get_le64()Hauke Mehrtens
These functions were added in commit c648a0138 "netlink: add nla_get for le32 and le64" Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07header: add __GFP_KSWAPD_RECLAIMHauke Mehrtens
This was added to the mainline kernel in commit ac4f832eb2 "mm, page_alloc: distinguish between being unable to sleep, unwilling to sleep and avoiding waking kswapd". Instead of __GFP_KSWAPD_RECLAIM the old mm code did not got any flag. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07header: add ktime_get_ns()Hauke Mehrtens
We also have to add the prototype of ktime_t ktime_get(), because including linux/hrtimer.h caused some strange build errors. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07header: adapt renaming of mei_cl_ to mei_cldev_Hauke Mehrtens
Commit d49dc5e76 "mei: bus: use mei_cldev_ prefix for the API functions" changed the prefix for these functions. On older kernel versions they are still exported under their old name, name our code use the old names on older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07patches: add missing header in 6lowpan/core.hHauke Mehrtens
This include is missing in kernel version <= 3.5. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07patches: argument removed from struct ipv6_stub->ndisc_send_na()Hauke Mehrtens
Commit 38cf595b1 "ipv6: remove unused neigh parameter from ndisc functions" removed one parameter from the callback function ndisc_send_na(). This semantic patch makes the code add NULL for that parameter on older kernel versions. Null was passed in most of the callers before. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07backports: add ktime_get_seconds()Johannes Berg
Since commit 84b00607aeb8 ("mac80211: use ktime_get_seconds") mac80211 uses ktime_get_seconds(). This patch provide a backport using ktime_get_ts() for it. [commit message and time64_t taken from Arend's patch] Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07backports: handle "genetlink: simplify genl_notify"Emmanuel Grumbach
Handle the recent genl_notify() prototype change. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07gentree: fix Makefile symbol disablingJohannes Berg
Currently, a Makefile line like this: obj-$(CONFIG_IPW2100) += ipw2x00/ will get mangled into #obj-$(CONFIG_IPW2100+= ipw2x00/ when disabled by the gentree script. Fix the regular expression to contain the entire match as the first group, so it gets all preserved when replaced later by "#\1" using expression.sub(). This then makes it come out as #obj-$(CONFIG_IPW2100) += ipw2x00/ Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07backport: backport debugfs_create_bool()Johannes Berg
The prototype for this function is changing upstream, so backport a copy of the new one that has a bool * argument instead of u32 *. Signed-off-by: Johannes Berg <johannes.berg@intel.com> [debugfs_{read,write}_file_bool() is in kernel 4.3, do not add it there] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07backports: add backport for of_platform_default_populate()Arend van Spriel
Since commit 69b5f4da2636 ("bcma: add support for population subnodes also when build as module") the bcma driver uses the function of_platform_default_populate(). This patch provides the stub function. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-02devel: update the test kernel versionsbackports-20150923Hauke Mehrtens
2015-11-02patches: refresh patches on next-20150923Hauke Mehrtens
2015-11-02copy: copy new usbnet header filesHauke Mehrtens
The following upstream commit added a new header files used by usbnet: commit c40a2c8817e42273a4627c48c884b805475a733f Author: Oliver Neukum <oneukum@suse.com> Date: Mon Sep 7 16:05:38 2015 +0200 CDC: common parser for extra headers Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-02bpgit: ignore stderrJohannes Berg
In order to make it possible to use GIT_TRACE, ignore stderr in the bpgit scripting. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-02backports: fix version check for page_is_pfmemallocFelix Fietkau
The upstream commit that added it was backported in 4.1.9 Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
